Intermittent ABS fault: 00283 / 012 - Electrical fault in circuit
S8stephen
Scarborough, UK
C?ID=304813
Hi folks, I recently encountered an ABS fault while driving and before I could get home the Parking brake fault flashed up and the power assist on the steering stopped resulting in a very weighted steering on the drive home. After connecting my HexNet scan tool VCDS the primary code was 00283 - ABS Wheel Speed Sensor, Front Left (G47) and -1x electrical fault in circuit. Thinking (hoping) it was simply a faulty speed sensor I replaced it. The old sensor that was untouched by me on my 7+ years of ownership was a Bosch 0265007929 came off and I replaced it with a Bosch 0265007930 which I understand is the new equivalent model sensor. I reset the fault code and drove the car with no ABS faults for two X 20 mile journeys then once again same ABS code 00293 flashed up again!. So silly question: should diagnosis start with the sensor wiring to the ABS module or is there any likelihood of it being the wheel bearing (sensor ring)? I have read somewhere that the fault would be different if it was the bearing… hoping that you can help? Thank you.
My car is a 2006 S8 d3 4e
WAUZZZ4E67N003566
Bruce
Near Philadelphia, PA, USA
Hi Stephen,
Thanks for the VIN number but we ask our users to post an autoscan so that we can know how the car is configured before we go digging into other resources. Could you post it please?
Don't know how? See the blue bar at the top of the page and the "How To" menu.
S8stephen
Scarborough, UK
C?ID=304813
Saturday,07,December,2024,14:17:23:60735
VCDS Version: 24.7.0.0 (x64)  HEX-V2 CB: 0.4643.4
VIN: WAUZZZ4E67N003566   License Plate:
Chassis Type: 4E (4L0)
Scan: 01 02 03 05 06 07 08 09 0E 11 31 15 16 17 19 1D 1E 28 34 36
          37 38 42 46 47 4F 52 53 55 56 57 61 62 65 67 6C 72 76 77
VIN: WAUZZZ4E67N003566   Mileage: 269950km-167739miles
0E-Media Player 1 -- Status: Not registered 0001
11-Engine II -- Status: Malfunction 0010
31-Engine other -- Status: Malfunction 0010
1D-Driver Ident. -- Status: OK 0000
1E-Media Player 2 -- Status: Malfunction 0010
38-Roof Electronics -- Status: Malfunction 0010
Address 01: Engine        Labels:. 07L-910-552-BSM1.clb
   Part No SW: 4E0 910 552     HW: 4E0 907 552
   Component: 5.2L V10/4V FSI    ª0060
   Revision: 5AH11---    Serial number: AUX3Z0F5397064
   Coding: 01060003190F0160
   Shop #: WSC 54321 123 12345
   VCID: 5F98AA22BB334F02069-800A
   VINID: 9D196AAAA115187780003146184279E91A
               P1653 - 008 -  - Intermittent
                    Mileage: 269933 km
                    Temperature: 88.0°C
                    Temperature: 44.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 11.684 V
001281 - Vehicle Speed Sensor
               P0501 - 002 - Implausible Signal
                    Fault Status: 01100010
                    Mileage: 269944 km
                    Date: 2024.12.01
                    Time: 18:10:05
                    RPM: 2031 /min
                    Load: 19.2 %
                    Temperature: 91.0°C
                    Temperature: 20.0°C
                    Voltage: 14.224 V
006435 - Please Check DTC Memory of ECU Number 2
               P1923 - 008 -
                    Fault Status: 01101000
                    Mileage: 269955 km
                    Date: 2024.12.07
                    Time: 14:15:18
                    Temperature: 18.0°C
                    Temperature: 15.0°C
                    Absolute Pres.: 970.0 mbar
                    Voltage: 11.430 V
Readiness: 0000 0001
Address 02: Auto Trans        Labels: 09E-927-156.lbl
   Part No SW: 4E1 910 156 K    HW: 09E 927 156 B
   Component: AG6 09E 5,2 FSI RdW 0020
   Revision: --H01---    Serial number:        0087677
   Coding: 0000001
   Shop #: WSC 02313 785 00200
   VCID: 2B000EF2BF0BE3A2DA1-807E
Address 03: ABS Brakes        Labels: 4E0-910-517.clb
   Part No SW: 4E0 910 517 D    HW: 4E0 614 517 AB
   Component: ESP 5.7 allrad  H46 0500
   Coding: 0001627
   Shop #: WSC 02313 000 00000
   VCID: 2412E5CED2D52CDA1BB-8070
00283 - ABS Wheel Speed Sensor; Front Left  (G47)
Address 05: Acc/Start Auth.        Labels: 4E0-910-131.lbl
   Part No SW: 4E0 910 131     HW: 4E0 909 131 K
   Component:     FBS AUDID3  H10 0190
   Revision: 01904910    Serial number: AUX3Z0F5397064
   Coding: 0412672
   Shop #: WSC 02311 785 00200
   VCID: 58EA813EDE1DB83A473-800C
Address 06: Seat Mem. Pass        Labels: None
   Part No SW: 4E0 910 760 D    HW: 4E0 959 760 B
   Component: Sitzmemory BFS H02  0010
   Revision: 00000000    Serial number: 5DS 008 795-03
   Coding: 4063328
Address 07: Control Head        Labels: 4E0-910-7xx-07.clb
   Part No SW: 4E0 910 769 Q    HW: 4E0 035 729 A
   Component: Interfacebox    H43 5570
   Revision: 00000000    Serial number: 300FZ067568958
   Coding: 0000002
   Shop #: WSC 00000 000 08192
   VCID: 3A2E3BB640514A2A517-806E
   Subsystem 1 - Part No: 4E0 910 611
   Component: E0380 BedienteilH03 0040
   Subsystem 2 - Serial number: 00000000013248
   Subsystem 3 - Serial number: 0130.06.060000000100010002ÿ
   Subsystem 4 - Serial number: 010002ÿ
   Part No SW: 4E0 910 043 B    HW: 4E0 820 043 G
   Component: KLIMAAUTOMAT    017 0450
   Revision: 00000032    Serial number: 00000000100165
   Coding: 0123001
   VCID: 1C62DD2EEAA5141AA3B-8048
00714 - Centre Right Vent Positioning Motor (V111)
            003 - Mechanical Failure
                    Fault Status: 01100011
                    Fault Frequency: 218
                    Reset counter: 169
                    Mileage: 267679 km
                    Date: 2024.08.10
                    Time: 08:39:32
                    Voltage: 11.80 V
                    Temperature: 22.0°C
                    (no units): 196.0
                    (no units): 195.0
                    Temperature: 20.0°C
                    Fault Status: 00101010
                    Reset counter: 203
                    Mileage: 267679 km
                    Date: 2024.08.10
                    Time: 08:39:33
                    Temperature: 26.0°C
00065 - Rear Left Footwell Heater (Z42)
                    Reset counter: 87
                    Mileage: 267679 km
                    Date: 2024.08.10
                    Time: 08:39:34
                    Voltage: 11.80 V
00066 - Rear Right Footwell Heater (Z43)
                    Reset counter: 159
                    Mileage: 267679 km
                    Date: 2024.08.10
                    Time: 08:39:34
                    Voltage: 11.80 V
Address 09: Cent. Elect.        Labels: 4E0-910-279.clb
   Part No SW: 4E0 910 279 Q    HW: 4E0 907 279 Q
   Component: ILM Fahrer      H15 0230
   Coding: 0133121
   VCID: 36362F867449AE4AB5F-8062
   Subsystem 1 - Part No: 4E2 910 113 B
   Component: Wischer WWS D3  H50 0420
   Coding: 00000035
   Shop #: WSC 02313
   Subsystem 2 - Part No: 4E0 910 557 A  Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH13 0090
   Coding: 00150573
   Shop #: WSC 02313
Address 0E: Media Player 1
Address 11: Engine II        Labels:. 07L-910-552-BSM2.clb
   Shop #: WSC 00673 210 83197
                    Mileage: 269933 km
                    Temperature: 88.0°C
                    Temperature: 44.0°C
                    Voltage: 11.811 V
                    Mileage: 269944 km
                    Date: 2024.12.01
                    Time: 18:10:05
                    RPM: 2030 /min
                    Load: 18.0 %
                    Temperature: 91.0°C
                    Temperature: 20.0°C
                    Voltage: 14.351 V
Address 15: Airbags        Labels: 4E0-910-655-94.lbl
   Part No SW: 4E0 910 655 D    HW: 4E0 959 655 H
   Component:    Airbag 9.41  H13 3710
   Revision: 91H13371    Serial number: 0037P000LLTK
   Coding: 0431707
   VCID: 2708F2C2A3E3C7C23E9-8072
   Subsystem 1 - Serial number: 63328RB40149CA9BY
   Subsystem 2 - Serial number: 63428RB40149CA87U
   Subsystem 3 - Serial number: 63528RB40149CA45P
   Subsystem 4 - Serial number: 63628RB40149CB2BV
   Subsystem 5 - Serial number: 63729RB4015FE7D50
   Subsystem 6 - Serial number: 63829RB4015FE7BF9
                    Reset counter: 209
                    Mileage: 269933 km
                    Date: 2024.12.01
                    Time: 17:54:12
Address 16: Steering wheel        Labels: 4E0-910-549.lbl
   Part No SW: 4E0 910 549     HW: 4E0 953 549
   Component: Lenksäulenmodul H14 0040
   Coding: 0112141
   VCID: 6594B8CA996F15D2CC5-8030
   Component: Lenkradmodul    H06 0030
Address 17: Instruments        Labels: 4E0-910-xxx-17.lbl
   Part No SW: 4E0 910 951 E    HW: 4E0 920 951 E
   Component: KOMBIINSTR. VDO H82 0520
   Revision: D03         Serial number: AUDID3F5000060
   Coding: 0048813
   Shop #: WSC 00586 210 91538
Address 19: CAN Gateway        Labels:. 4L0-910-468.clb
   Part No SW: 4L0 910 468     HW: 4L0 907 468
   Component: J533__Gateway   H06 0040
   Revision: 00H06000    Serial number: 0900B0661581CD
   Coding: F5F5DFFF50761E
   Shop #: WSC 00751 210 93636
   VCID: 6C82CDEE7A85249A93B-8038
                    Reset counter: 168
                    Mileage: 269911 km
                    Date: 2024.12.01
                    Time: 16:58:04
Address 1D: Driver Ident.        Labels: 4E0-910-218.lbl
   Part No SW: 4E0 910 218 A    HW: 4E2 905 218 B
   Component: FPI_1           H01 0020
   Revision: 01000102    Serial number: 28062006210124
   VCID: 1F18EA22FBB30F02469-804A
Address 1E: Media Player 2        Labels: 4E0-910-111.lbl
   Part No SW: 4E0 910 111 F    HW: 4E0 035 111 A
   Component: CD-Changer      H44 0470
   Revision: 00000000    Serial number: AUZ5ZBF8168846
                    Reset counter: 169
                    Mileage: 269955 km
                    Date: 2024.12.07
                    Time: 14:15:26
                    Reset counter: 169
                    Mileage: 269955 km
                    Date: 2024.12.07
                    Time: 14:15:16
   Part No SW: 4E0 910 158     HW: 4E0 919 158 D
   Component: KLIMA-STG. FOND 017 0230
   Revision: 00000019    Serial number: 00000000042851
   Coding: 0000000
   VCID: 619CACDA8D4779F230D-8034
01866 - Rear Right Air Outlet Motor Position Sensor (G350)
Address 34: Level Control        Labels: 4E0-910-553.clb
   Part No SW: 4E0 910 553 J    HW: 4E0 907 553 F
   Component: LUFTFDR.-CDC    H06 6310
   Coding: 0013510
   Shop #: WSC 00409 210 01865
   VCID: 2A0E0BF6B0F1FAAA217-807E
01575 - Control Switched Off
                    Fault Status: 11100000
                    Reset counter: 169
                    Mileage: 269955 km
                    Date: 2024.12.07
                    Time: 11:42:50
   Component: Sitzmemory FS  H02  0010
   Coding: 4063342
   Part No SW: 4E0 910 888 P    HW: 4E0 919 887 D
   Component: MNS ECE         H48 1060
   Revision: 00000000    Serial number: 364F 067572668
   VCID: 3B203EB24F6B73224A1-806E
Address 38: Roof Electronics        Labels: 4E0-910-135.lbl
   Part No SW: 4E0 910 135 A    HW: 4E0 907 135 A
   Component: Dachknoten D3   H04 0090
   Serial number: 00000617100155
   Coding: 0232912
   VCID: 1D64D02AF1BF1D12545-8048
02138 - Control Circuit for Front Right Interior Lights
                    Fault Status: 01101100
                    Reset counter: 169
                    Mileage: 262136 km
                    Date: 2022.12.01
                    Time: 11:18:00
02139 - Control Circuit for Left Front Interior Lights
                    Reset counter: 167
                    Mileage: 262136 km
                    Date: 2022.12.01
                    Time: 11:23:00
Address 42: Door Elect, Driver        Labels: 4E1-910-802-42.lbl
   Part No SW: 4E1 910 802 B    HW: 4E2 959 802 B
   Component: Türsteuer.FS BRM003 0100
   Coding: 0032623
   VCID: 201AE9DEC6CD30FA7F3-8074
Address 46: Central Conv.        Labels:. 4E0-910-289.lbl
   Part No SW: 4E0 910 289 D    HW: 4E0 907 289 D
   Component: Komfortgeraet   H07 0010
   Revision: 00100007    Serial number:  W040606290218
   Coding: 0005885
   Subsystem 1 - Part No: 4E0 910 853
   Component: Heckdeckel   P27H08 0090
   Subsystem 2 - Part No: 4E0 907 719
   Component: Neigungssensor  H05 0020
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 169
                    Mileage: 269955 km
                    Date: 2024.12.07
                    Time: 14:16:50
                    Reset counter: 169
                    Mileage: 229702 km
                    Date: 2021.01.25
                    Time: 14:26:24
Address 47: Sound System        Labels: 4E0-910-223.lbl
   Part No SW: 4E0 910 223 R    HW: 4E0 035 223 G
   Component: DSP-High D3     H02 0120
   Revision: PROD_01     Serial number: 00000000002235
   Coding: 0000027
   VCID: 2C020DEEBA05E49AD3B-8078
Address 4F: Centr. Electr. II        Labels: None
   Part No SW: 4E0 910 280 A    HW: 4E0 907 280 B
   Component: ILM Beifahrer   H11 0070
   Revision:             Serial number: 00000000000507
   Coding: 0010111
   VCID: 1E66D726FCB9060A4DF-804A
   Subsystem 1 - Part No: 4E0 910 511
   Component: UGDO HL ECE     H06 0050
   Subsystem 2 - Serial number: 0253439TJ8EZ06
                    Fault Status: 00101101
                    Reset counter: 209
                    Mileage: 262136 km
Address 52: Door Elect, Pass.        Labels: 4E1-910-802-52.lbl
   Part No SW: 4E1 910 802 B    HW: 4E2 959 801 B
   Component: Türsteuer.BF BRM003 0100
   Coding: 0032623
Address 53: Parking Brake        Labels: 4E0-910-801.clb
   Part No SW: 4E0 910 801 C    HW: 4E0 907 801 A
   Component: EPB  A32C0220   H02 0220
   Revision: A32C0220
   Coding: 0000731
   Shop #: WSC 31414 210 01865
                    Fault Frequency: 9
                    Reset counter: 209
                    Mileage: 269928 km
                    Date: 2024.12.01
                    Time: 17:56:17
                    Voltage: 13.15 V
                    Count: 236
   Part No SW: 4F0 910 357 F    HW: 4F0 907 357 F
   Coding: 0000018
   VCID: 290CF4FAB5F7F1B228D-807C
   Subsystem 1 - Part No: 4F0 941 329 D
   Component: AFS-Modul links H01 0010
   Subsystem 2 - Part No: 4F0 941 329 D
   Component: AFS-Modul rechtsH02 0020
   Part No SW: 4E0 910 541 T    HW: 4E0 035 541 P
   Component: TUNER EU/US/RDW H42 0630
   Revision: 00000000    Serial number: 396FM067541201
   Coding: 0000001
   VCID: 313C1C9A9D278972E0D-8064
Address 57: TV Tuner        Labels: None
   Part No SW: 4E0 910 148 E    HW: 4E0 919 148
   Component: R0078 TVhybridT     0470
   Revision: R0H05000    Serial number: 76300700388801
   Coding: 0000003
   VCID: 2514F8CAD9EFD5D20C5-8070
Address 61: Battery Regul.        Labels: 4E0-910-181.lbl
   Part No SW: 4E0 910 181 C    HW: 4E0 915 181 C
   Component: J0644 BEM       H12 0550
   Revision: 00000000    Serial number: 00000000011975
   Shop #: WSC 00235 210 81345
   Subsystem 1 - Part No: 4E0 915 105 A
   Component: von VA0  31070882DK
   Coding: 34453039313531303541205641303331303730383832444B
   Shop #: WSC 00586 210 83216
Address 62: Door, Rear Left        Labels: 4E0-910-802.lbl
   Part No SW: 4E0 910 802 A    HW: 4E0 959 801 C
   Component: Türsteuer.HL BRM003 0100
   Coding: 0032623
Address 65: Tire Pressure        Labels: 4E0-910-273.lbl
   Part No SW: 4E0 910 273 A    HW: 4F0 907 273 A
   Component: Reifendruck 3   H05
   Revision: 00050340    Serial number: 00000900046144
   Coding: 0212329
                    Reset counter: 209
                    Mileage: 269933 km
                    Date: 2024.12.01
                    Time: 17:54:19
                    (no units): 255.0
                    Voltage: 0.00 V
                    (no units): 27.0
                    Temperature: 0.0°C
                    Temperature: 0.0°C
                    Temperature: 0.0°C
                    Temperature: 0.0°C
   Part No SW: 4E0 910 754 S    HW: 4E0 035 753 A
   Component: SDS 3502 UK     H45 0630
   Revision: 00000000    Serial number: 00000606230355
   Shop #: WSC 12336 024 394758
Address 6C: Back-up Cam.        Labels: 4E0-910-441.clb
   Part No SW: 4E0 910 441     HW: 4L0 907 441 A
   Component: J772__Rearview      0050
   Revision: --H12---    Serial number: 525PA8-J6610DB
   Coding: 1021302
   VCID: 5CE29D2EAA25541A63B-8008
Address 72: Door, Rear Right        Labels: 4E0-910-802.lbl
   Part No SW: 4E0 910 802 A    HW: 4E0 959 802 D
   Component: Türsteuer.HR BRM005 0180
   Coding: 0032623
Address 76: Park Assist        Labels: 4E0-910-283.lbl
   Part No SW: 4E0 910 283 C    HW: 4E0 919 283 C
   Component: Parkhilfe 8-Kan H12 0040
   Revision: 00H12000    Serial number: 08720617900335
   Coding: 0321008
   VCID: 2310E6D2D7DB2BE2621-8076
   Part No SW: 4E0 910 336 M    HW: 4E0 862 335
   Component: Handyvorb2      H20 1130
   Revision: 00000000    Serial number: 00000005168999
   Coding: 0010900
   Shop #: WSC 00196 210 90007
End----(Elapsed Time: 02:38, VBatt start/end: 11.5V/11.5V. VIgn 11.5V)-----
The ABS module clearly thinks this is an electrical fault, so I'd start with the wiring.
S8stephen
Scarborough, UK
C?ID=304813
Hi Gents,
So after replacing the ABS / pad wear sensor wiring harness, and replacing the wheel speed sensor, both using new Audi OEM parts - I have the same issue. Just removed the ABS pump and sending off to be reconditioned… more to follow. Cheers.
ahidley
Pennsylvania, USA
C?ID=549110
Did the ABS control module reconditioning fix the issue?
Where did you send it for reconditioning?
S8stephen
Scarborough, UK
C?ID=304813
Hi - apologies for not replying earlier, moving home over the past couple weeks… Yes the ABS module was sent to ECU Testing located in Heanor - Derbyshire. After a couple days they contacted me after they tested the module and confirmed there was an issue. I gave the approval to repair and the unit was ready the next day. I Fitted the the repaired unit, bled the brakes all round and replaced with Motul RBF600. Problem solved👍😊
