Conversion from long code to short code
Apendiixator
Czech Republic
C?ID=569308
Hello everyone,
I have a defect in the ESP on my Fabia, apparently due to incorrect coding. The ECU has been replaced in the past. However, this type of ESP unit only allows a short code. Before changing the ECU I had this long code on the ESP: VCID: D5FC6C9C4C0C29A28CD-50D0
Does anyone know how to transform it into a shortcode?
Thank you
Friday,06,December,2024,16:23:43:57328
VCDS Version: 24.7.1.0 (x64)  HEX-NET2 CB: 0.4643.5
Chassis Type: 5J (5J - Skoda Fabia II (2007 > 2010))
Scan: 01 02 03 08 09 15 16 17 19 25 37 44 46 55 56 76 77
VIN: TMBGD65J193132851   Mileage: 187000km-116196miles
   Part No SW: 03C 906 057 F    HW: 03C 906 057 M
   Component: BOSCH ME7.5.20  G   9715
   Revision: 21H01---    Serial number: SKZ7Z0I5316238
   Coding: 0000071
   Shop #: WSC 33281 004 1048576
   VCID: A700165423F06B32BE1-5184
   VINID: 91D49750615A0490C10C22050420B9D2D5
Readiness: 0110 0101
Address 03: ABS Brakes        Labels: 6R0-907-37x-ESP80.clb
   Part No SW: 6R0 907 379 E    HW: 6R0 907 379 N
   Component: ESP 8.0 front   H06 0002
   Coding: 0002368
   Shop #: WSC 13765 790 00000
   VCID: C0D2ADC8A69EBC0A9FB-50F4
00493 - ESP-Sensor Unit (G419)
                    Fault Status: 01101000
                    Reset counter: 227
                    Mileage: 187009 km
   VCID: D5FC6C9C4C1C29A2DCD-50F4
            00-00 - -
Address 09: Cent. Elect.        Labels:. 6Qx-937-049-C.lbl
   Part No: 6Q1 937 049 F
   Component: 0000 BN-SG.         2S36
   Coding: 25742
   Shop #: WSC 62125
   VCID: BE2ED330D96ACAFAED7-50F4
   Part No: 1C0 909 605 F
   Component: QA AIRBAG VW61 Q5Q6 0004
   Coding: 20801
   Shop #: WSC 13765
   VCID: A700165426F06B32BE1-50F4
Address 17: Instruments        Labels: 5J0-920-xxx-17.clb
   Part No: 5J0 920 811 B
   VCID: A61E1B5021FA723A857-50F4
   Part No: 6N0 909 901
   Component: 000G GATEWAY CAN    2S36
   Coding: 00014
   Shop #: WSC 13765
   VCID: F0B23D08D3BE6C8A2FB-50F4
Address 25: Immobilizer        Labels: 5J0-920-xxx-25.clb
   Component: IMMOBILIZER    V2802476
   Coding: 18121
   TMBGD65J193132851     SKZ7Z0I5316238
   Part No: 6R0 423 156
   Component: LenkhilfeTRW        V272
   Coding: 10140
   Shop #: WSC 13765
   VCID: ED8C247CC48C816204D-50F4
Address 46: Central Conv.        Labels:. 6Q0-959-433.clb
   Part No: 5J0 959 433 A
   VCID: B134F80C18342582605-4B3C
Address 55: Headlight Range        Labels: 5J0-907-357.lbl
   Part No: 5J0 907 357
   Component: Low AFS         H02 0002
   Revision: 00000002    Serial number:
   Coding: 0000002
   VCID: EE8E2370CC8A7A7A3D7-50F4
   Part No SW: 5J0 035 161 A    HW: 5J0 035 161 A
   Component: Radio         005 0013
   Revision: R0005000    Serial number: SKZAZ4H7562159
   Coding: 05000400000600
   VCID: A0120D484ADE9C0AFFB-50F4
End-----(Elapsed Time: 03:30, VBatt start/end: 14.2V/0.0V. VIgn 0.0V)------
AINils
Germany (AIB)
C?ID=56975
Is there no scan before changing ESP/ABS?
This controller never had long coding, so I think you got wrong in your memory
Apendiixator
Czech Republic
C?ID=569308
I only have the previous scan in this form:
Address 03: ABS brakes Labels:
Note: Excessive amount of transmission errors
AINils
Germany (AIB)
C?ID=56975
This is quite nothing...
  • Agree
Apendiixator
Czech Republic
C?ID=569308
It will change when the code is changed, but you are right that it probably has nothing to do with the coding of the unit. It's a shame that VCDS can't offer the code for this ESP. I would like to verify its correctness
Bruce
Near Philadelphia, PA, USA
In the autoscan, you have:
Coding: 0002368
What was the original coding?
Apendiixator
Czech Republic
C?ID=569308
That's NOT coding, that's a VCID which is something completely different!
Yes, that's right. See my top post. If someone can seriously explain what the VCID information means, I'm interested. Everything else is obvious.
Apendiixator
Czech Republic
C?ID=569308
Unfortunately, I don't know the original code. when the car reached my garage, I did a complete scan. But address 03 did not show concrete details. See #3 Unfortunately, I did not notice this deficiency. because I was focusing on engine failures. I fix the ESP fault as a secondary fault, but now it is clear that the coding is not the reason for the fault. BMV 5 and 126 show correct values, so the defect lies in the vehicle speed sensing module. Unfortunately, I cannot confirm this information 100% because the owner of the car has no interest in removing the defect. I Thank you all for your support.
Apendiixator
Czech Republic
C?ID=569308
This is a scan that I took at the entrance of the car to my garage. I have nothing else :-(
Ètvrtek,29,Srpen,2024,17:44:27:57328
VCDS -- Windows VAG/VAS Emulator Bìží na Windows 10 x64
VCDS verze: SVO 23.3.1.0  HEX-NET2 CB: 0.4643.5
Verze dat: 20230703 DS346.2
www.vag-com.cz
VIN: TMBGD65J193132851   Výrobní štítek:
Model: 5J (5J - Skoda Fabia II (2007 > 2010))
Sken: 01 02 03 08 09 15 16 17 19 25 37 44 46 55 56 76 77
VIN: TMBGD65J193132851   Kilometry: 186720km
Adresa 01: Motor        Labely: Chyba pøesmìrování
   Øídící jednotka SW: 03C 906 057 F    HW: 03C 906 057 M
   Díl: BOSCH ME7.5.20  G   9813
   Revize: 21H01---    Seriové èíslo: SKZ7Z0I5316238
   Kódování: 0000071
   Dílna #: WSC 13765 790 00000
   VCID: A700165423F06B32EE1-5184
1 nalezena chyba:
000801 - snimac otacek motoru (G28)
               P0321 - 008 - neverohodny signal - Sporadická
             info o závadì:
                    Stav závad: 00101000
                    Priorita závad: 0
                    Frekvence závad: 2
                    Poèítadlo resetù: 255
                    Kilometry: 186719 km
                    Indikace èasu: 0
             info o závadì:
                    Otáèky: 269 /min
                    Výkon/klapka: 100.0 %
                    Rychlost: 0.0 km/h
                    Teplota: 42.0*C
                    Teplota: 28.0*C
                    Tlak: 0.0 mbar
                    Napìtí: 0.000 V
Adresa 03: ABS brzdy        Labely:
   Pozn.: Nadmìrné množství pøenosových chyb
Adresa 08: Klima/topení        Labely: SVO\6Q0-820-045-V1.clb
   Øídící jednotka: 5J0 820 045
   Díl: Klimaanlage        X0850
   VCID: E29647400D52CE1AF9F-50D0
Nenalezena žádná chyba.
Adresa 09: Centrální elektrika        Labely:. 6Qx-937-049-C.lbl
   Øídící jednotka: 6Q1 937 049 F
   Díl: 0000 BN-SG.         2S36
   Kódování: 25742
   Dílna #: WSC 62125
   VCID: BE2ED330D96ACAFABD7-50D0
2 závad nalezeno.
01598 - napeti baterie
            27-10 - neverohodny signal - Sporadická
            07-10 - signal prilis maly - Sporadická
Adresa 15: Airbagy        Labely: 6Q0-909-605-VW5.lbl
   Øídící jednotka: 1C0 909 605 F
   Díl: QA AIRBAG VW61 Q5Q6 0004
   Kódování: 20801
   Dílna #: WSC 13765
   VCID: A700165426F06B32EE1-50D0
Adresa 17: Pøístrojová deska        Labely: SVO\5J0-920-xxx-17.clb
   Øídící jednotka: 5J0 920 811 B
   Díl: KOMBIINSTR.    V2802476
   Kódování: 19113
   Dílna #: WSC 13765
   VCID: A61E1B5021FA723AD57-50D0
Adresa 19: CAN Gateway        Labely: SVO\6N0-909-901-19.clb
   Øídící jednotka: 6N0 909 901
   Díl: 000G GATEWAY CAN    2S36
   Kódování: 00014
   Dílna #: WSC 13765
   VCID: F0B23D08D3BE6C8A7FB-50D0
Adresa 25: Imobilizér        Labely: SVO\5J0-920-xxx-25.clb
   Díl: IMMOBILIZER    V2802476
   Kódování: 19113
   Dílna #: WSC 13765
Adresa 44: Posilovaè øízení        Labely: SVO\6Q0-423-156.clb
   Øídící jednotka: 6R0 423 156
   Díl: LenkhilfeTRW        V272
   Kódování: 10140
   Dílna #: WSC 13765
   VCID: ED8C247CC48C816254D-50D0
Adresa 46: Komfort systém        Labely:. SVO\6Q0-959-433.clb
   Øídící jednotka: 5J0 959 433 A
   Díl: 05 Komfortgerát     0001
   Kódování: 00019
   Dílna #: WSC 13765
   VCID: B134F80C18342582305-4B3C
Adresa 55: Reg.sklonu svìtel        Labely: 5J0-907-357.lbl
   Øídící jednotka: 5J0 907 357
   Díl: Low AFS         H02 0002
   Revize: 00000002    Seriové èíslo:
   Kódování: 0000002
   VCID: EE8E2370CC8A7A7A6D7-50D0
1 nalezena chyba:
00446 - omezeni funkce z duvodu podpeti
            002 - dolni hranice prekrocena - Sporadická
             info o závadì:
                    Èasování: 0.6 *ATDC
                    Raw, Form. N/A: 000 000 000
Adresa 56: Rádio (J503)       Labely:. SVO\5M0-035-1xx-56.clb
   Øídící jednotka SW: 5J0 035 161 A    HW: 5J0 035 161 A
   Díl: Radio         005 0013
   Revize: R0005000    Seriové èíslo: SKZAZ4H7562159
   Kódování: 05000400000600
   VCID: A0120D484ADE9C0AAFB-50D0
2 závad nalezeno.
00872 - hlubkovy reproduktor vzadu vlevo (R15)
            011 - Preruseni - Sporadická
00873 - hlubkovy reproduktor vzadu vpravo (R17)
Konec--(Uplynulý èas: 03:44, VBat zaèátek/konec: 13.9V/13.6V. VIgn 0.1V)---
Apendiixator
Czech Republic
C?ID=569308
can you try 0002139 ?
It is currently coded to 002368. And according to the calculation, it appears to be correct. I can try your code if I have a car in the garage.but how did you calculate it? Thank you
Dr Sheldon
Windsor UK
C?ID=334979
Yes The fault is actually in the vehicle rotation module (G419):
So replace it then !! If you are sure it is not wiring or Power supply !!
Not sure what you are asking here ?? Silver Bullet ??
Apendiixator
Czech Republic
C?ID=569308
Read the whole article and then give your opinion. The glitch is now clear. Needless talk
If anything deserves enlightenment, it's this:
