Need help with ABS coding. Replaced module (2012 Jetta MK60EC1)
gediger
Canon City, CO, USA
C?ID=562064
Thursday,05,December,2024,11:57:38:25104
VIN: 3VWDX7AJ4CM338612   License Plate: 111111
Mileage: 104750km-65088mi   Repair Order: 1952
Chassis Type: AJ-VW36 (6N0)
Scan: 01 02 03 08 09 15 17 19 25 2E 56 77
VIN: 3VWDX7AJ4CM338612   Mileage: 104750km-65088miles
Address 01: Engine (CBT)       Labels: 07K-906-055-CBT.clb
   Part No SW: 07K 906 055 DK    HW: 07K 906 055
   Component: 2,5l R5/4V      G01 5683
   Revision: T4H06---    Serial number:
   Coding: 0000075
   Shop #: WSC 43464 000 1048576
   VCID: 7AADE32810D978DA11F-802E
   VINID: 0E69D4A0745A1137430C8181081648236D
049441 - No Communication with ABS Brake Control Module
               U0121 - 000 -  - Intermittent
                    Mileage: 104753 km
                    Date: 2019.04.28.
                    Time: 00:12:03
                    Speed: 254.0 km/h
                    Temperature: 23.0 C
                    Temperature: 21.0 C
                    Absolute Pres.: 830.0 mbar
049682 - Steering Column Control Module
               U0212 - 000 - No Communications - Intermittent
                    Date: 2047.15.31
                    Time: 31:63:63
                    Temperature: 21.0 C
                    Temperature: 21.0 C
049508 - No Communications with HVAC Control Module (J301)
               U0164 - 000 -  - Intermittent
                    Date: 2047.15.31
                    Time: 31:63:63
                    Speed: 254.0 km/h
                    Temperature: 21.0 C
                    Temperature: 21.0 C
049478 - No Communication with Diagnostic Gateway
               U0146 - 000 -  - Intermittent
                    Date: 2047.15.31
                    Time: 31:63:63
                    Speed: 254.0 km/h
                    Temperature: 21.0 C
                    Temperature: 21.0 C
               U1017 - 000 -  - Intermittent
                    Mileage: 104753 km
                    Date: 2019.04.28.
                    Time: 00:36:30
                    Speed: 255.0 km/h
                    Temperature: 18.0 C
                    Temperature: 21.0 C
050197 - Implausible Data Received from ABS Control Module
               U0415 - 000 -  - Intermittent
                    Mileage: 104753 km
                    Date: 2019.04.28.
                    Time: 00:36:30
                    Speed: 255.0 km/h
                    Temperature: 18.0 C
                    Temperature: 21.0 C
Readiness: 0010 0100
   Part No SW: 09G 927 750 LF    HW: 09G 927 750 LF
   Component: AQ 250 6F           2041
   Revision: 00H97000    Serial number:
   Coding: 0000840
   Shop #: WSC 00066 000 00000
   VCID: 005991C07605220A5FB-8054
                    Fault Frequency: 9
                    Reset counter: 171
                    Mileage: 88310 km
                    Date: 2016.10.24.
                    Time: 16:34:46
   Revision: 00H31001
   Shop #: WSC 00066 790 00187
   VCID: 7DA7E8340DF74FE234D-8028
                    Mileage: 104753 km
                    Date: 2019.04.28.
                    Time: 03:22:44
                    Count: 16391
                    Count: 24576
                    Count: 195
                    Count: 46336
                    Count: 256
                    Fault Status: 01100101
                    Mileage: 104753 km
                    Date: 2019.04.28.
                    Time: 03:19:47
                    Count: 3
                    Count: 12288
                    Count: 279
                    Count: 43008
                    Count: 64256
                    Count: 256
                    Mileage: 104753 km
                    Date: 2019.04.28.
                    Time: 03:19:47
                    Count: 3
                    Count: 12288
                    Count: 295
                    Count: 43008
                    Count: 64256
                    Count: 256
                    Mileage: 104753 km
                    Date: 2019.04.28.
                    Time: 03:19:47
                    Count: 3
                    Count: 12288
                    Count: 270
                    Count: 43008
                    Count: 64256
                    Count: 256
Address 08: Auto HVAC        Labels: 5C0-820-047.clb
   Part No SW: 5C0 820 047 AQ    HW: 5C0 820 047 AQ
   Component: J301  Klimaanlage   0203
   Revision: 2001010S    Serial number: 00000000584487
   VCID: 6FBBC27C5B9B2D72B61-803A
                    Reset counter: 80
                    Mileage: 104753 km
                    Date: 2019.04.28.
                    Time: 04:45:58
   Part No SW: 5C0 937 087 E    HW: 5C0 937 087 A
   Component: BCM25 JLB H3  H66 0251
   Revision: B2066001    Serial number: 04371265110928
   Coding: 7B994B1808AB0B0000382000240884C500C2502E60000000300000000000
   VCID: 2F3B027C971B6D72F61-807A
   Subsystem 1 - Part No SW: 6R0 959 801 M    HW: 6R0 959 801 M  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  002 3464
   Coding: 820000
   Subsystem 2 - Part No SW: 6R0 959 802 P    HW: 6R0 959 802 P  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  002 3464
   Coding: 820000
   Subsystem 3 - Part No SW: 5K0 959 542 A    HW: 5K0 959 542 A  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H09 0013
   Serial number: 0631403
   Coding: 020000
   Subsystem 4 - Part No SW: 6R0 959 811 D    HW: 6R0 959 811 D
   Component: J388__TSG_HL  002 3464
   Coding: 800000
   Subsystem 5 - Part No SW: 6R0 959 812 D    HW: 6R0 959 812 D
   Component: J389__TSG_HR  002 3464
   Coding: 800000
   Part No SW: 5C0 959 655 E    HW: 5C0 959 655 E
   Component: AirbagVW10G   013 0807
   Serial number: 003GTM025J8I   Dataset Number: 160003v____ 0154
   Coding: 00003936
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01020
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 34310D107EBD4EAA8B3-8060
   Subsystem 1 - Part No SW: 5C6 959 339     HW: 5C6 959 339
   Component: BF-Gewichtss.  H10 0027
   Serial number: 6940000Y1100007S4Z00
   Coding: 303241
   Serial number: 3572MSME79340462ZZZS
   Serial number: 3582MSME50251263ZZZI
   Serial number: 3516KSME100B7E12ZZZP
   Serial number: 3526KSME374D2013ZZZN
   Serial number: 3556LSME25671612ZZZO
   Serial number: 3566LSME2D291612ZZZV
12656896 - No Communication with ABS Brake Control Module
          U0121 00 [00001000] - -
          [Lost Communication With Vehicle Dynamics Control Module]
                    Reset counter: 80
                    Mileage: 104753 km
                    Date: 2024.12.05.
                    Time: 04:45:57
9482752 - Seat Occupied Recognition
          B10B2 00 [00001000] - Function Restriction due to Missing Message(s)
                    Reset counter: 80
                    Mileage: 104753 km
                    Date: 2024.12.05.
                    Time: 04:46:13
   Part No SW: 5C6 920 951 B    HW: 5C6 920 951 B
   Component: KOMBI         H04 0604
   Coding: 270201
   Shop #: WSC 00066 000 00123
   VCID: 2A0D1368AC79085A21F-807E
12656896 - Function Restricted due to Missing Message(s)
          U1111 00 [00001000] - -
          [Steuerger t f r Bremse: keine Kommunikation]
                    Reset counter: 80
                    Mileage: 104753 km
                    Date: 2024.12.05.
                    Time: 04:45:56
   Part No SW: 6N0 909 901     HW: 5C0 937 087 A
   Component: GW-K-CAN TP20 H66 0251
   Revision: B2066001
   Coding: 102200
   VCID: 70B9C1004AA5328AAFB-8024
                    Reset counter: 80
                    Mileage: 104753 km
                    Date: 2019.04.28.
                    Time: 04:45:59
   Component: IMMO          H04 0604
   VCID: 6A8DD3686CF9C85AE1F-803E
   Revision: A1001003    Serial number: 7660658353
   VCID: 290FEC64A9FF0342285-807C
   Part No SW: 1K0 035 164 C    HW: 1K0 035 164 C
   Component: LOW NAR SDARS H02 0004
   Revision: -----03S    Serial number: VWZ4Z6L3217377
   Coding: 01000400020006
   VCID: 221DFB48D4C9D01A69F-8076
                    Reset counter: 37
                    Mileage: 104753 km
                    Date: 2019.04.28.
                    Time: 04:45:58
                    Mileage: 104753 km
                    Date: 2019.04.28.
                    Time: 07:42:13
   Part No SW: 7P6 035 730 F    HW: 7P6 035 730 F
   Component: TELEFON       H09 2902
   Revision: 1B001001    Serial number: 00007660548913 Dataset Number: 7P6035730F  0001
   Coding: 0A10040000010110
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_UHVNA A01719
   ROD: UHVNA.rod
   VCID: 3537301475C757A2BCD-8060
End----(Elapsed Time: 01:13, VBatt start/end: 11.6V/11.5V. VIgn 11.4V)-----
                Address 03: ABS Brakes       Labels: 1K0-907-379-60EC1F.clb
Control Module Part Number: 1K0 907 379 BL    HW: 1K0 907 379 BL
  Component and/or Version: ESP MK60EC1   H31 0152
           Software Coding: 00000000000000000000000000000000000000
            Work Shop Code: WSC 00066 790 00187
                    Mileage: 104753 km
                    Date: 2019.04.28.
                    Time: 02:45:03
                    Count: 7
                    Count: 28672
                    Count: 195
                    Count: 41472
                    Mileage: 104753 km
                    Date: 2019.04.28.
                    Time: 02:45:03
                    Count: 2
                    Count: 28672
                    Count: 279
                    Count: 41472
                    Mileage: 104753 km
                    Date: 2019.04.28.
                    Time: 02:45:03
                    Count: 2
                    Count: 28672
                    Count: 295
                    Count: 41472
                    Mileage: 104753 km
                    Date: 2019.04.28.
                    Time: 02:45:03
                    Count: 2
                    Count: 28672
                    Count: 270
                    Count: 41472
                    Mileage: 104753 km
                    Date: 2019.04.28.
                    Time: 02:45:03
                    Count: 7
                    Count: 28672
                    Count: 195
                    Count: 41472
                    Mileage: 104753 km
                    Date: 2019.04.28.
                    Time: 02:45:03
                    Count: 2
                    Count: 28672
                    Count: 279
                    Count: 41472
                    Mileage: 104753 km
                    Date: 2019.04.28.
                    Time: 02:45:03
                    Count: 2
                    Count: 28672
                    Count: 295
                    Count: 41472
                    Mileage: 104753 km
                    Date: 2019.04.28.
                    Time: 02:45:03
                    Count: 2
                    Count: 28672
                    Count: 270
                    Count: 41472
                    Mileage: 104753 km
                    Date: 2019.04.28.
                    Time: 02:45:03
                    Count: 7
                    Count: 28672
                    Count: 195
                    Count: 41472
                    Mileage: 104753 km
                    Date: 2019.04.28.
                    Time: 02:45:03
                    Count: 2
                    Count: 28672
                    Count: 279
                    Count: 41472
                    Mileage: 104753 km
                    Date: 2019.04.28.
                    Time: 02:45:03
                    Count: 2
                    Count: 28672
                    Count: 295
                    Count: 41472
                    Mileage: 104753 km
                    Date: 2019.04.28.
                    Time: 02:45:03
                    Count: 2
                    Count: 28672
                    Count: 270
                    Count: 41472
Address 0x03,1K0 907 379 BL,Basic Settings,Group 002
Ziddywerks
Northern NJ USA
C?ID=208579
Are we certain BL is the correct replacement for the BS? If your in a rush I can provide correct coding for a fee.
gediger
Canon City, CO, USA
C?ID=562064
I am not sure, I ordered the module by the number printed on the original module and that is what I received (1K0 907 379 BJ).
gediger
Canon City, CO, USA
C?ID=562064
I am happy to pay to get the coding.
DjDvr
Romania
C?ID=267309
Disk size ? LHD or RHD? Start/Stop yes/no ? TPMS yes/no ? and I can calculate the coding for you
gediger
Canon City, CO, USA
C?ID=562064
Front rotors are 288 mm, rear drums, LHD, no start/stop, with TPMS. Thank you for your help!
DjDvr
Romania
C?ID=267309
114B400C09250002881122E5901B0041380000 try , car ON
Ziddywerks
Northern NJ USA
C?ID=208579
Above coding is not correct or even close to being accurate.
DjDvr
Romania
C?ID=267309
curious to know what is that wrong , it's still a jetta 5k , no 2013+ , it's vin Matched , the rest can be modified as needed. If you can dump it directly from VW ok , but the coding should work just fine with a correct brakes pressure and everything. I left out TPMS as I don't know if they have button or it was cluster based , again something easily changeable.
the MC will not matter as much but for sub 2013 it should be 22.2 , easily changeable as well
boostboy
hello i am having issues entering abs coding. It says coding rejected out of range. Ive read through all threads regarding this and tried adding 00 at the end and tried changing WSC number but it still will not accept. The coding was calculated based on PR codes and should be absolutely correct however it will not take. Only my original coding gets accepted. Any ideas?
heres the coding I am trying to enter for ABS 65A74F01A6EDF2805B00
Wednesday,18,December,2024,13:27:57:50406
VIN: WAUF2BFC0DN045902   License Plate: PARKSTUCKS6
Mileage: 169362km-105236mi   Repair Order:
Chassis Type: FC-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 28 34 36 3B 3C 42 44 46
          47 52 53 55 56 5F 62 6C 72 85 8B 8E 8F 90 A9 BA
VIN: WAUF2BFC0DN045902   Mileage: 169362km-105236miles
A9-Struct. Borne Sound -- Status: Malfunction 0010
Address 01: Engine (------CRDB)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 4G0 906 560 B    HW: 4H0 906 014
   Component: 4.0l V8TFSI / X62 0008
   Revision: NCX62---    CVN: E0042D3D
   Coding: 1A2A003265460A0E1000
   Shop #: WSC 04919 123 12345
   ASAM Dataset: EV_ECM40TFS0114G0906560B 001008
   ROD: EV_ECM40TFS0114G0906560B.rod
   VCID: 270BFB33AF615A523E1-8072
   VINID: 9D1956092593014780105240087A381B9C
17875 - Exhaust Pressure Control Valve
          P0475 00 [00100111] - Electrical Malfunction
                    Mileage: 169362 km
                    Date: 2024.12.18
                    Time: 13:20:55
                    Engine RPM: 740.00 /min
                    Normed load value: 5.5 %
                    Coolant temperature: 92  C
                    Intake air temperature: 36  C
                    Ambient air pressure: 920 mbar
                    Voltage terminal 30: 13.970 V
                    Engine status: COENG_RUNNING
17876 - Exhaust Pressure Control Valve 2
          P049F 00 [00100111] - Malfunction
                    Mileage: 169362 km
                    Date: 2024.12.18
                    Time: 13:20:55
12352 - Coolant Pump for Intercooler
          P023A 00 [00100111] - Open Circuit
                    Mileage: 169362 km
                    Date: 2024.12.18
                    Time: 13:20:55
                    Normed load value: 7.1 %
                    Voltage terminal 30: 14.017 V
4715 - No Communication with Instrument Cluster
          U0155 00 [00100111] - -
          [Lost Communication WithInstrument Panel Cluster (IPC) Control Module]
                    Mileage: 169362 km
                    Date: 2024.12.18
                    Time: 13:20:59
                    Engine RPM: 652.00 /min
                    Normed load value: 5.1 %
                    Voltage terminal 30: 14.065 V
                    selected gear-Bits 0-7: 0
                    Cruise control switch actuation-Bits 0-7: 0
Readiness: 1110 1100
   Part No SW: 4G0 927 158 BD    HW: 0BK 927 156 AM
   Component: 0BK 40TFSIRdW H16 1006
   Revision: --H16---    CVN: 000FD926
   VCID: 71BFD56B512554E2A05-8024
   Part No SW: 4G0 907 379 J    HW: 4G0 907 379 J
   Component: ESP PREMIUM   H09 0361
  my s6 Coding: 65B64F01A66DF2805B00
c7 rs6 coding:07A1DF01E085FB80FB00
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ESPPremiAU57X 004028
   VCID: 3829284F72DFC5AAA7B-806C
0081 - Function Restricted due to Missing Message(s)
          U1111 00 [00001001] - -
          [ComScl_PDU_QSP_02_Timeout]
                    Reset counter: 78
                    Mileage: 169362 km
                    Date: 2024.12.18
                    Time: 13:20:53
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 40
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 01
                    F-Type: 01
                    Uz: B9
   Part No SW: 4H0 907 064 DR    HW: 4H0 907 064 CR
   Component: BCM2 2.0      H32 0510
   Coding: 0D882007000000000000
   VCID: 7CA1F45F06E7298A033-8028
   Serial number: 2312000163209015
03175 - Invalid Data Set
                    Reset counter: 78
                    Mileage: 169362 km
                    Date: 2024.12.18
                    Time: 13:20:51
   Part No SW: 4G0 820 043 AE    HW: 4G0 820 043 AE
   Component: KLIMA 4 ZONEN H13 0076
   Serial number: 04081200040002
   Coding: 688120B84D
   Shop #: WSC 63577 004 1048576
   ASAM Dataset: EV_AirCondiComfoUDS 002036
   VCID: 629DAA2784C3FF7A29F-8036
   Part No SW: 4H0 907 063 CG    HW: 4H0 907 063
   Revision: 11012002    Serial number: 00000001396961
   Coding: 0600A00116349FE28F0080C7A0002908CF98D208A2080321800008402000
   VCID: 6FBBD31347914212B61-803A
   Component: WWS57X 120717  H36 0080
   Serial number:         120725135243
   Coding: 0045F7
   Serial number: 20481298
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 D    HW: 4G0 941 531 D
   Component: E1 - LDS  H07 0044
   Serial number: 03 08 2012  00000464
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R2FZL02
   Subsystem 5 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA103816000001672000
   Coding: 020300
   Subsystem 6 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: 2A088046000000000001
   Part No SW: 4H0 919 475 AG    HW: 4H0 919 475 AG
   Component: PARKHILFE ACC H01 0072
   Revision: 11001001    Serial number: 61061221400866
   Coding: A8C90A
   ASAM Dataset: EV_EPHVA18AU57X0000 003008
   ROD: EV_EPHVA18AU57X0000_003.rod
   VCID: 77ABEB733F410AD26E1-8022
   Part No SW: 4G0 907 561 A    HW: 4G0 907 561
   Component: ACC3          H17 0400
   Serial number: 00000000000000 Dataset Number: 4G0909863C  0034
   Coding: 7601010102
   ASAM Dataset: EV_AdaptCruisContrAU57X 002010
   VCID: 2809F80FA27F552A37B-807C
93440 - Function Restriction due to Faults in Other Modules
          U1113 00 [00001001] - -
          [FAULT_CIS_VIDEO_FAIL]
                    Reset counter: 78
                    Mileage: 169362 km
                    Date: 2024.12.18
                    Time: 13:21:03
                    Control Module temperature: 30  C
                    Voltage terminal 15: 14.331 V
                    Longitudinal_acceleration_vehicle_reference: 0.00 m/s
   Part No SW: 4G0 959 655 A    HW: 4G0 959 655 A
   Component: Airbag10.43   H32 0032
   Revision: --------    Serial number: 003D8002A1VP Dataset Number: 4G0909602E  0007
   Coding: 303234373131303030344A55304C34473053
   VCID: 33331F636BB926F2929-8066
   Subsystem 1 - Part No SW: 5C6 959 339 A    HW: 5C6 959 339 A
   Component: BF-Gewichtss.  H15 0045
   Serial number: 6940000Y120000HD2S0U
   Serial number: 3575HRB405N1G0QMDP1$
   Serial number: 3585HRB404P1G1DOB17B
   Serial number: 3515JRB40511D2AS5PKD
   Serial number: 3525JRB40611D2ASNGQU
   Serial number: 3554VRB40551DKASL9F2
   Serial number: 3564VRB404R1DKAS60F0
   Part No SW: 4H0 953 568 H    HW: 4H0 953 568 H
   Revision: --------    Serial number: 90372LH5000OT
   Coding: 00043C
   VCID: 3829284F725FC5AAA7B-806C
   Subsystem 1 - Part No SW: 4H0 951 528 E    HW: 4H0 951 528 E
   Component: E221 - MFL  H08 0009
   Serial number: 29 05 2012  B0185116
   Part No SW: 4G0 920 981 M    HW: 4G0 920 981 M
   Component: TBenUsaAccNv  H76 0515
   Revision: 28460207    Serial number: 658090812596024
   Coding: 03CF09051F41CF05020200
   ASAM Dataset: EV_RBD4K 004046
   ROD: EV_RBD4K_AU57.rod
   VCID: 3537217B65CD38C2BCD-8060
9459739 - Fuel Level Sensor 2
          B1058 1B [00001001] - Resistance Too High
                    Reset counter: 78
                    Mileage: 169362 km
                    Date: 2024.12.18
                    Time: 13:20:53
   Part No SW: 4G0 907 468 AC    HW: 4G0 907 468 AA
   Component: J533--Gateway H11 0035
   Revision: --------    Serial number: 00000000637233 Dataset Number: 4G0909515C  0062
   Coding: 00E1034800
   GVL: FDAFE84CFEE2600D5100
   ASAM Dataset: EV_GatewPkoUDS 001016
   Subsystem 1 - Part No SW: 8X0 915 181     HW: 8X0 915 181
   Component: J367-BDM  H07 0141
   Serial number: 00000000003790034026
   Part No SW: 4G0 919 158 K    HW: 4G0 919 158 K
   Component: KLIMA FOND    H07 0076
   Serial number: 06081200040425
   Coding: 20
   ASAM Dataset: EV_ClimaContrUnitRearUDS 002018
   VCID: 372B2B737FC1CAD2AE1-8062
0116 - Temperature Sensor for Rear Right Seat
          B1114 15 [00001001] - Open or Short to Plus
                    Reset counter: 78
                    Mileage: 169362 km
                    Date: 2024.12.18
                    Time: 13:20:53
0124 - Rear Right Seat Heater
          B1118 15 [00001001] - Open or Short to Plus
                    Reset counter: 78
                    Mileage: 169362 km
                    Date: 2024.12.18
                    Time: 13:20:53
   Part No SW: 4G0 907 553 F    HW: 4G0 907 553 F
   Component: LUFE-DAEMPFER H18 0782
   Dataset Number: 4G0909553F  0034
   Coding: 008002
   ASAM Dataset: EV_AirSuspe 003024
   ROD: EV_AirSuspe_003_AU64.rod
   VCID: 2E050E17809B0B1AFD7-807A
   Component: MEM-FS        H03 0154
   Revision: AA000000    Serial number: 00000036152047
   Coding: 00581B0000002001000001010101102030303232203232
   Shop #: WSC 02311 785 00200
   VCID: 77ABEB733FC10AD26E1-8022
   Component: SARA 6D red   H02 0053
   Revision: --------    Serial number: EJ1BPA7E003TW- Dataset Number: 4G0909573C  0006
   ASAM Dataset: EV_SARA2 005011
   ROD: EV_SARA2.rod
   Part No SW: 4G0 907 566 D    HW: 4G0 907 566
   Component: J769  SWA MasterH01 0040
   Revision: 00H01000    Serial number: 6PZ 010 287-03
   Coding: 0000001
   VCID: 3039106F962F1DEAEFB-8064
   Subsystem 1 - Part No: 4G0 907 568 D
   Component: J770  SWA Slave H01 0040
   Subsystem 2 - Serial number: 6PZ 010 287-23
   Subsystem 3 - Serial number: 5F13.08.1200H010003CF20039
   Subsystem 4 - Serial number: F20039
   Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
   Component: TSG FA        H04 0506
   Coding: 011F17005E00628002000013
   VCID: 45D751BB35ADA8422CD-8010
   Component: RCEPS         H36 0010
   Revision: 00001000    Serial number: 0006779330 Dataset Number: 4G0909852H  0027
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   VCID: 323D1A6794A32FFA99F-8066
   Revision: 00002001    Serial number: 0181693737
   Coding: 01060E3A00FA418583B00880020503050000000000000000000000000000
   Component: GTO BF  H01 0080
   Serial number: 00000000000000100672
   Subsystem 3 - Part No SW: 4G8 959 591     HW: 7P0 959 591 C
   Component: J245 PS40.039  H01 0008
   Serial number:     WOO17565053
   Coding: 101F00
   Subsystem 4 - Part No SW: 4G0 947 135 G    HW: 4G0 947 135
   Serial number: 0000000AP00001757762
03615 - Rear Right Reading Light
                    Fault Status: 01101100
                    Reset counter: 78
                    Mileage: 169362 km
                    Date: 2024.12.18
                    Time: 13:20:55
   Part No SW: 4G1 035 223 A    HW: 4G1 035 223 A
   Component: BOSE-G3C7-ANC H02 0540
   Revision: CJ002700    Serial number: 00000000003177
   Coding: 030000
   VCID: 1C61D4DFE6A7898AA33-8048
   Component: TSG BF        H03 0506
   Coding: 011F17005E00628002000002
   VCID: 46D556B708ABA35A257-8012
   Part No SW: 4H0 907 801 F    HW: 4H0 907 801 A
   Component: EPB-4         H03 0013
   Revision: --------    Serial number: 00000000438637 Dataset Number: 4G0909522B  0002
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2B030703B3897E32DA9-807E
Address 55: Headlight Range (J431)       Labels:| 4H4-907-357-V1.clb
   Part No SW: 4H4 907 357 C    HW: 4H4 907 357 A
   Component: ....AFS13.... H01 0020
   Serial number: 120814-0004-004
   Coding: 12216F33701AA400
   ASAM Dataset: EV_AdvanFrontSyste 005001
   ROD: EV_AdvanFrontSyste_AU21.rod
530180 - Local Data Bus
          U10BA 00 [10001001] - No Communication
                    Reset counter: 78
                    Mileage: 169362 km
                    Date: 2024.12.18
                    Time: 13:20:56
   Part No SW: 4G0 035 082 D    HW: 4G0 035 082
   Component: Radio U SIRIU H60 0112
   Revision: AB001007    Serial number: 156H$0C7621276
   Coding: 020007010000000001
   VCID: 211FE52BC1C5A462705-8074
   Part No SW: 4G0 035 746 B    HW: 4G0 035 746 B
   Component: H-BNT-NA      H49 0549
   Revision: --------    Serial number: 194H50C7508396
   Coding: 060200000203F9EF75128F1E00000003100001000000000000
   VCID: 2615F637A8EB435A057-8072
   Subsystem 1 - Part No: 8R0 060 884 AM
   Component: NAR 2012  0605
   Subsystem 2 - Part No SW: 4G1 919 612 Q    HW: 4G1 919 612 Q
   Component: E380 BDT C7  H11 0204
   Serial number: 90349LH3000KN
   Subsystem 3 - Part No: 8R0 060 961 D
   Component: CD-Database  4353
02259 - Information Display and Control Head (Front) (J685)
                    Reset counter: 78
                    Mileage: 169362 km
                    Date: 2024.12.18
                    Time: 13:20:57
                    Voltage: 14.30 V
03787 - Rotation Mechanism for Display Module Front
                    Reset counter: 78
                    Mileage: 169362 km
                    Date: 2024.12.18
                    Time: 13:20:53
                    Voltage: 14.40 V
   Component: TSG HL        H03 0506
   Coding: 010F17004000628002000002
   VCID: 49CF5D8B19B54C22C85-801C
Address 6C: Back-up Cam.        Labels: 4H0-907-441.clb
   Part No SW: 4G0 907 441 B    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0061
   Revision: --H06---    Serial number: 525 PA8J27G4HO
   Coding: 1080004
   VCID: 2615F637A4EB435A057-8072
   Component: TSG HR        H03 0506
   Part No SW: 4G0 907 217 A    HW: 4H0 907 217 A
   Component: DPC-SG        H25 0038
   Revision: --------    Serial number: 262130025421000 Dataset Number: 4G0909547C  0028
   Coding: EA060000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 2615F637A86B435A057-8072
   Part No SW: 4G0 907 541 A    HW: 4G0 907 541
   Coding: 7601010102
   ASAM Dataset: EV_AdaptCruisContr2AU57X 002008
   Part No SW: 4G0 907 107 D    HW: 4H0 907 107
   Component: BV-SG         H30 0038
   Serial number: 005000050808127
   Coding: 04819A1A0111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
0161 - Video Cable for Image Processing
          C1107 02 [00001001] - Signal Failure
          [No_camera_found_on_startup]
                    Reset counter: 78
                    Mileage: 169362 km
                    Date: 2024.12.18
                    Time: 13:21:02
                    Outside temperature: 18.5  C
                    Voltage terminal 15: 14.4 V
                    Control Module temperature: 23.0  C
   Dataset Number: 4G0909614B  0005
   Coding: 0066E608031F037E070308014240C2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 313F156B91A514E2E05-8064
   Dataset Number: 4G0909615B  0005
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   Part No SW: 4G0 907 159 B    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0010
   Serial number: 120717201452
   VCID: 2C01041FB687790AD33-8078
0005 - Incorrect Vehicle Type
          U10D9 00 [00001001] - -
          [Keine Funktion durch Falschverbau im Fahrzeug--> keine Funktion]
                    Reset counter: 78
                    Mileage: 169362 km
                    Date: 2024.12.18
                    Time: 13:20:53
   Part No SW: 4H0 907 145     HW: 4H0 907 145
   Component: AEM - LEAR    H05 0006
   Revision: 00001001    Serial number: 97804000593204 Dataset Number: 4G0909578A  0009
   ASAM Dataset: EV_AEMLearAU64X 002014
   ROD: EV_AEMLearAU64X_AU57.rod
   VCID: 6695B63768EB835AC57-8032
End----------(Elapsed Time: 02:44, VBatt start/end: 14.4V/14.5V)-----------
Boki Ar
Arandjelovac, Serbia
C?ID=57300
For what reason are you trying to code ABS?
First of all, your ABS system is not at all the same as the one we are talking about in this thread.
boostboy
That is true. Impulse post
that is true… impulse reply while I was searching through for posts about coding rejected errors
