2012 AUDI A7 3.0S. GATEWAY OR BCM??
EuroMasterTek
Las Vegas, USA
C?ID=104263
We got on Monday this 2012 A7 totally dead, no dashboard, no start, no crank, nothing, like battery is disconnected, first thing was check for Batt Volt, it was good, 12.4V, connected maintainer, scanned, only a couple modules were detected, only Gateway has comms with CVDS, codes for BCM, U0141-Body Control Module (Central Electric 2) no comm, U100A-Control Module for Access/Start Authorization no comm, U1049 -Optical data bus - Open circuit, U100A-No Communications with Control Module for Access/Start Authorization. Checked all fuses and relays on every single fuse box, included the one under the Wiper washer fluid tank, all are good. With the VCDS scanner tried to run some output tests over the GATEWAY but nothing seems to work. Running out of options here, for experience I'm going for the GATEWAY, but what are the chances the BCM could be bad too? thanks!!
Monday,02,December,2024,11:28:45:27081
VCDS Version: 24.7.0.0 (x64)  HEX-NET CB: 0.4656.4
Dealer/Shop Name: EuroMasterTek
VIN: WAUYGAFC4CN106767   License Plate: NANCY A7
Mileage: 0000   Repair Order:
Chassis Type: 4G0
Scan: 01 02 03 05 08 09 10 15 16 17 19 36 3B 3C 42 44 46 52 53 55
          56 5F 62 6C 6D 72 8F 90
03-ABS Brakes -- Status: Malfunction 0110
04-Steering Angle -- Status: Cannot be reached 0100
05-Acc/Start Auth. -- Status: Cannot be reached 0100
10-Park/Steer Assist -- Status: Cannot be reached 0100
15-Airbags -- Status: Cannot be reached 0100
3B-Sensor Elect. -- Status: Malfunction 0010
3C-Lane Change -- Status: Cannot be reached 0100
46-Central Conv. -- Status: Cannot be reached 0100
55-Headlight Range -- Status: Cannot be reached 0100
8F-Pretens. Frt Left -- Status: Cannot be reached 0100
90-Pretens. Frt Right -- Status: Cannot be reached 0100
Address 01: Engine
   Part No SW: 4G0 927 158 P    HW: 0BK 927 156 AJ
   Component: 0BK 30TFSIUSA H16 1006
   Revision: --H16---
   Coding: 000002
   ASAM Dataset: EV_TCMAL551211 002018
   ROD: EV_TCMAL551211_002_AU48.rod (VIN: N/A)
   VCID: 3B36C115B20C694ED6-806E
12560 - Body Control Module (Central Electric 2)
          U0141 00 [00100111] - No Communications
                    Mileage: 67259 km
                    Date: 2024.11.29
                    Time: 17:39:53
                    Voltage terminal 30: 10.956 V
                    Engine RPM: 0 /min
                    Status data bus communication diagnostic interface-State Deashboard received: not received
                    Status data bus communication diagnostic interface-State ECM received: not received
                    Status data bus communication diagnostic interface-State ESP received: not received
                    Status data bus communication diagnostic interface-State Gateway received: not received
                    Status data bus communication diagnostic interface-State Parking Brake received: not received
                    Status data bus communication diagnostic interface-State Steering Angle received: not received
                    Status data bus communication diagnostic interface-State Steering Assist received: not received
Address 03: ABS Brakes
Address 05: Acc/Start Auth.
Address 08: Auto HVAC
Address 09: Cent. Elect.
Address 10: Park/Steer Assist
Address 15: Airbags
Address 16: Steering wheel
Address 17: Instruments
   Part No SW: 4G0 907 468 G    HW: 4G0 907 468 A
   Component: J533--Gateway H08 0214
   Revision: --------    Serial number: 00000000345088
   Coding: 00C1033000
   Shop #: WSC 02391 785 00200
   GVL: FDA1E80CDE63600D00
   ROD: EV_GatewUDS_AU57.rod (VIN: N/A)
   VCID: 3424EA299F52A63617-8060
   Subsystem 1 - Part No SW: 8X0 915 181     HW: 8X0 915 181
   Component: J367-BDM  H07 0141
   Serial number: 00000000003790410655
5505 - Body Control Module (Central Electric 2)
          U0141 00 [00001001] - No Communications
                    Reset counter: 52
                    Mileage: 67259 km
                    Date: 2024.11.29
                    Time: 17:39:52
                    Voltage terminal 30: 10.9 V
                    Voltage terminal 15: 10.9 V
                    Control Module temperature: 17  C
                    System status: Terminal 15 on
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Terminal 15 status: On
                    Datenfeld: 0
5520 - No Communications with Control Module for Access/Start Authorization
          U100A 00 [00001001] - -
                    Reset counter: 52
                    Mileage: 67259 km
                    Date: 2024.11.29
                    Time: 17:39:52
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 0
0267 - Optical data bus
          U1049 00 [00001001] - Open circuit
                    Reset counter: 92
                    Mileage: 67259 km
                    Date: 2024.12.02
                    Time: 09:35:55
                    Voltage terminal 15: 0.0 V
                    System status: Awake_Timer_active
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Terminal 15 status via CAN: OFF
                    Terminal 15 status: OFF
                    Datenfeld: 0
          U140B 00 [00001001] - -
          [Powermanagement active]
                    Reset counter: 52
                    Mileage: 67100 km
                    Date: 2024.11.13
                    Time: 22:31:11
                    Voltage terminal 30: 11.3 V
                    Control Module temperature: 21  C
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 1
Address 36: Seat Mem. Drvr
   Part No SW: 4G0 907 637 B    HW: 4G0 907 637 B
   Component: SARA 6D       H02 0004
   Revision: --------    Serial number: EJ1BPA42035RA20
   ASAM Dataset: EV_SARA 006014
   ROD: EV_SARA_006.rod (VIN: N/A)
   VCID: 2D12FF4D7C78F7FE58-8078
3801344 - Function Restricted due to Missing Message(s)
          U1111 00 [00101111] - -
          [Internal Monitoring (MSG)]
                    Fault Frequency: 55
                    Reset counter: 52
                    Mileage: 67259 km
                    Date: 2024.11.29
                    Time: 17:39:51
                    DCU Temperature: 22  C
                    Voltage Clamp 15: 11.4 V
                    Voltage Clamp 30: 10.9 V
                    Ignition Cycle Count: 21269
                    WAUYGAFC4CN106767
Address 3C: Lane Change
   Component: RCEPS         H35 0010
   Revision: 00001000    Serial number: 0007259825 Dataset Number: 4G8909852J  0028
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod (VIN: N/A)
   VCID: 3228EC316546A80605-8066
4205828 - Steering angle sensor
          B1168 54 [00001000] - Missing Calibration / Basic Setting
                    Reset counter: 92
                    Mileage: 67259 km
                    Date: 2024.11.29
                    Time: 17:39:56
                    Write only channel
5258753 - Steering End Stops Not Learned
          C10AC F0 [10001001] - Unknown Error Elaboration
          [Lenkungsendanschl ge nicht angelernt]
                    Fault Frequency: 54
                    Reset counter: 58
                    Mileage: 67259 km
                    Date: 2024.11.29
                    Time: 17:39:56
                    Write only channel
18689 - Terminal 30
          U140A 00 [00001000] - Open Circuit
          [Ausfall der Versorgungsspannung (Kl30 oder Kl31) im Stillstand (unkritisch)]
                    Reset counter: 92
                    Mileage: 67259 km
                    Date: 2024.11.29
                    Time: 17:39:53
                    Write only channel
3161616 - Function Restricted due to Missing Message(s)
          U1111 00 [00001000] - -
          [Ausfall Botschaft "PDU_Klemmen_Status_01"]
                    Reset counter: 92
                    Mileage: 67259 km
                    Date: 2024.11.29
                    Time: 17:39:55
                    Write only channel
Address 46: Central Conv.        Labels:. 4H0-907-064-46.clb
   Part No SW: 4H0 907 064 BC    HW: 4H0 907 064 BC
   Component: BCM2 2.0      H31 0333
   VCID: 6B9631558AEC39CE06-803E
No Faults Found
Address 52: Door Elect, Pass.
Address 53: Parking Brake
Address 55: Headlight Range
   Part No SW: 4G0 035 082 H    HW: 4G0 035 082
   Component: Radio U SIRIU H53 0138
   Revision: AB001007    Serial number: 236LY0B7501812
   Coding: 020007020100000001
   VCID: 2502076D2C88CFBE90-8070
                    Reset counter: 52
                    Mileage: 67259 km
                    Date: 2024.11.29
                    Time: 17:40:17
                    Bin. Bits: 00000000 00000001
Address 5F: Information Electr.        Labels:
   VCID: 55E277ADAC689F3EC0-FFFE
Address 62: Door, Rear Left
Address 6C: Back-up Cam.
Address 6D: Trunk Elect.
Address 72: Door, Rear Right
Address 8F: Pretens. Frt Left
Address 90: Pretens. Frt Right
End----(Elapsed Time: 01:16, VBatt start/end: 11.0V/11.7V. VIgn 0.0V)------
Address 19: DTCs cleared
Address 19,4G0 907 468 G,channel IDE01457-Energy management deactivation stage,adapted from,- ,to,1 ,
Address 19,4G0 907 468 G,channel IDE01457-Energy management deactivation stage,adapted from,1 ,to,0 ,
Address 0x19,4G0 907 468 G,UDS Basic Settings,IDE00498-Resetting of all adaptation values
Address 0x19,4G0 907 468 G,UDS Selective Output Tests,IDE01857-Start ring break diagnosis
Address 19,4G0 907 468 G,channel IDE01863-MOST light performance,adapted from,Decrease 0 dB ,to,Decrease 3 dB ,
Address 19,4G0 907 468 G,channel IDE01863-MOST light performance,adapted from,Decrease 3 dB ,to,Decrease 0 dB ,
Address 19,4G0 907 468 G,channel IDE01211-Static current measuring mode,adapted from,not active ,to,Static current measuring mode ,
Address 19,4G0 907 468 G,channel IDE01211-Static current measuring mode,adapted from,Static current measuring mode ,to,not active ,
                Address 19: CAN Gateway       Labels: 4H0-907-468.clb
Control Module Part Number: 4G0 907 468 G    HW: 4G0 907 468 A
  Component and/or Version: J533--Gateway H08 0214
           Software Coding: 00C1033000
            Work Shop Code: WSC 02391 785 00200
              ASAM Dataset: EV_GatewUDS 001025 (AU57)
                    Reset counter: 52
                    Mileage: 67256 km
                    Date: 2024.12.03
                    Time: 23:48:48
                    Voltage terminal 30: 11.2 V
                    Control Module temperature: 23  C
                    System status: A-/F-CAN / FlexRay_active
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 0
                    Reset counter: 52
                    Mileage: 67256 km
                    Date: 2024.12.03
                    Time: 23:48:48
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 0
                    Reset counter: 52
                    Mileage: 67256 km
                    Date: 2024.12.03
                    Time: 23:48:50
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 0
Jef
HQ
Same box, in the right rear of the car... with this dead, no ignition (terminal 15).
Fuses:
  • SF7 - ST1 (black) = 30A
  • SF8 - ST1 (black) = 20A
  • SF8 - ST2 (red) = 30A
Hands on, verify fuses are good... or even better, actually in there. Now on fuse panel SF, if you see an empty position with 2 terminals, that is a missing fuse.
Is there any back story on this? A tale of black to positive and red to dead maybe?
EuroX
Northern NJ USA
C?ID=208579
Clearly your issue is with power supply and or comms to central electrics and access start. Both those modules need to be online to do anything. Gateway is clearly alive so thats not your issue.
