2012 Passat TDI NMS retrofit remote start
Spykce
C?ID=171985
I purchased the parts for retrofitting remote start on my wifes 2012 Passat. I was looking through the forums for the steps to perform once the parts are installed but was not having any luck. I was curious if anyone knows what all needs done. The steps mention putting a code in if you are using ODIS but not much else.
Here's the guide the parts came with: https://static.nhtsa.gov/odi/tsbs/2014/MC-10124454-9999.pdf
Thank you for any help.
Derek
UK (ilexa)
C?ID=56983
Hello.
You won't be able to use the SVM code for this as that's for the dealer machine, but it may still be possible with some coding or adaptation changes using VCDS
Please post an autoscan and hopefully someone who is familiar with this retrofit will be able to help you
Best regards
Derek
Spykce
C?ID=171985
Thanks, I figured that code wouldn't help me using VCDS but I wanted to give everyone the information I had. I will post an Auto Scan this evening when I get home.
It's actually for the factory servers more than the dealer's tool.
Spykce
C?ID=171985
Here is the Auto Scan. I see I have some other things to look into as well but regardless, if anyone knows what may need to happen after installing the remote start kit I would be very appreciative. Only other retrofit I have done was a tow module on my Q5 which took a lot of research but I found some others that had done it and helped me along.
Thursday,05,December,2024,19:00:20:59952
VCDS Version: 24.7.1.0 (x64)
VIN: 1VWBN7A33CC076789   License Plate:
Mileage: 395950km-246031mi   Repair Order:
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 2E 37 42 44 46 4F 52 56 62 72
          77
VIN: 1VWBN7A33CC076789   Mileage: 395950km-246031miles
37-Navigation -- Status: Cannot be reached 1100
   Component: R4 2.0l TDI   X21 9982
   Revision: 71X21---    Serial number:                CVN: D240C61FD45710C1
   Coding: 001D0012042400000000
   ROD: EV_ECM20TDI01103L997009J.rod
   VCID: 3B75F339B28F904EDE-806E
   VINID: 0669D27874430D34C01C61C82480421E3F
7925 - Cylinder 1 Glow Plug
          P06C5 00 [01100000] - Incorrect Installation
8862 - Exhaust Pressure Sensor 1
          P0471 00 [01100000] - Implausible Signal
Readiness: 0 0 0 1 0
   Part No SW: 02E 300 057 P    HW: 02E 927 770 AL
   Component: GSG DSG AG6     512 9435
   Revision: 05551213    Serial number: 00001201202053
   Shop #: WSC 09003 957 00200
   VCID: 2643324D910D3DA691-8072
   Revision: 00H31001
   Coding: C54BC0F549290000A31203EC92220042A71000
   VCID: 7DF13D21E41B5E7EA0-8028
   Part No SW: 561 907 044 H    HW: 561 907 044 H
   Component: Climatronic   043 0202
   Revision: 00001001
   Coding: 0010001002
   VCID: 1C3710A51741F77637-8048
9473042 - Motor for Left Temperature Flap
          B108C 12 [00001000] - Short to Plus
                    Fault Frequency: 70
                    Reset counter: 159
                    Mileage: 393538 km
                    Date: 2024.12.05.
                    Time: 17:48:18
9473041 - Motor for Left Temperature Flap
          B108C 11 [00001000] - Short to Ground
                    Fault Frequency: 68
                    Reset counter: 159
                    Mileage: 393589 km
                    Date: 2024.12.05.
                    Time: 16:40:01
9473138 - Motor for Left Temperature Flap
          B108C 54 [00001001] - Missing Calibration / Basic Setting
                    Reset counter: 65
                    Mileage: 393538 km
                    Date: 2024.12.05.
                    Time: 17:48:18
   Part No SW: 5K0 937 087 AA    HW: 5K0 937 087 AA
   Component: BCM PQ35 H+   121 0164
   Revision: BL121001
   Coding: 6F200E3B902B08D408880005120085800571008640A00560648060000C70
   VCID: 74E71805D7511F36DF-8020
                    Reset counter: 229
                    Mileage: 371366 km
                    Date: 2019.04.02.
                    Time: 16:33:24
                    Voltage: 13.90 V
   Part No SW: 5C0 959 655     HW: 5C0 959 655
   Component: AirbagVW10G   013 0809
   Serial number: 003ENM020D90   Dataset Number: 560003v__A_ 0049
   Coding: 00003548
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01024
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 6FED1769B6773CEE22-803A
   Serial number: 6940000Y170001NKX40D
   Coding: 303044
   Serial number: 3572MSME1B59056AZZZ/
   Serial number: 3582MSME50253569ZZZT
   Serial number: 3516KSME20473917ZZZM
   Serial number: 3526KSME234D3D17ZZZ-
   Serial number: 3556LSME462A1414ZZZQ
   Serial number: 3566LSME71647B14ZZZ-
   Part No SW: 1K5 953 521 AK    HW: 5K0 953 569 B
   Revision: FF010040    Serial number: 20120119100689
   Coding: 088A140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 76E3220DC92D0D26E1-8022
   Component: E221__MFL-YVJ  H06 0022
   Coding: E20000
   Part No SW: 561 920 970 C    HW: 561 920 970 C
   Component: KOMBI         H07 0507
   Coding: 231E01
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04093
   VCID: 1A3B16BD1D75894625-804E
   Part No SW: 7N0 907 530 P    HW: 1K0 907 951
   Component: J533  Gateway H40 1623
   Revision:   H40       Serial number: 25031201290217
   Coding: 461000
   VCID: 3D71FD21A49B9E7EE0-8068
                    Reset counter: 55
                    Mileage: 374332 km
                    Date: 2019.04.28.
                    Time: 10:24:60
   Component: IMMO          H07 0507
   VCID: 6ADB067D8D95D9C675-803E
   Revision: A1001003    Serial number: 7661688202
   Coding: 020000
   VCID: 29593971401312DEBC-807C
Address 37: Navigation
   Revision: 13110009    Serial number: 0004204027
   Coding: 0404F5
   ROD: EV_TSGFPQ25BRFVW46X.rod
   VCID: 5BB553B952CFB04EFE-800E
   Slave Driver:
   Subsystem 1 - Part No SW: 561 959 811     HW: 561 959 811   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG_HL  004 4472
   Coding: 800000
   Part No: 1K0 909 144 N
   Component: EPS_ZFLS Kl. 290    3301
   Revision: 00H22000
   VCID: 3561E5015CAB463E28-8060
   Component: EZE_2         H40 1623
   Coding: 01030108
   VCID: 6FED1769BE773CEE22-803A
   Serial number: 53388786011201700311
   Coding: 181100
   Component: Analoguhr  008 0004
   Revision: 15110009    Serial number: 0004198419
   Coding: 0404F4
   ROD: EV_TSGBPQ25BRFVW46X.rod
   VCID: 5CB750A557C1B776F7-8008
   Slave Passenger:
   Subsystem 1 - Part No SW: 561 959 812     HW: 561 959 812   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG_HR  004 4472
   Coding: 800000
Address 56: Radio
   Part No SW: 5K0 035 730 E    HW: 5K0 035 730 E
   Component: TELEFON       H09 2902
   Revision: 1B001001    Serial number: 00007661341835 Dataset Number: 5K0035730E  0001
   Coding: 0A10040000010110
   Shop #: WSC 13576 002 1048576
   ASAM Dataset: EV_UHVNA A01719
   ROD: UHVNA.rod
   VCID: 275D3F495E0724AEAA-8072
9455635 - Telephone Microphone
          B1048 13 [00001001] - Open Circuit
                    Reset counter: 110
                    Mileage: 376565 km
                    Date: 2024.12.05.
                    Time: 00:06:10
          B104F 13 [00001001] - Short to GND
                    Reset counter: 58
                    Mileage: 374432 km
                    Date: 2024.12.05.
                    Time: 17:20:01
          B104E 13 [00001001] - Short to GND
                    Reset counter: 58
                    Mileage: 374432 km
                    Date: 2024.12.05.
                    Time: 17:20:01
End-------------------------(Elapsed Time: 02:59)--------------------------
2kaa52
Ceska Republica, Praha
C?ID=319193
Do you learned a remote start Key to the Car ( immobilizer ) ?
Thats First step should be done.
For all Others, you can contact me.
Spykce
C?ID=171985
The key is learned, I was hoping to install the wiring and relays tomorrow. Sent you a message as well.
wookie_farts
New Hampshire, USA
C?ID=604789
Any luck with this? I'm trying to install the remote start kit 561-065-760-B on my 2018 Passat GT. Got the harness installed, but now I'm hesitant to try the key learn after reading KESSY horror stories.
Spykce
C?ID=171985
I had a setback with my friend helping me.... lesson learned. I am currently working on getting a new BCM in then I will have to go back to this. 2kaa52 was being very helpful though. Hit them up
Spykce
C?ID=171985
I got my used BCM coded and installed, vehicle now starts with help from 2kaa52. I am waiting on a fuse that was also fried to get everything communicating how it should to continue the remote start process.
2kaa52
C?ID=319193
Let the Key learn at VW Dealership, dont use a locksmith service etc.
When Key is learned, we can Go on. Contact me by PM
Spykce
C?ID=171985
Got this finished up this morning with 2kaa52's help. Everything works great, super helpful! Don't be afraid to reach out for any help with this it was super easy with guidance
