Looking for some info from (mostly) outside of US users, these cars are not popular in US.
2013 Q5 hybrid no start, getting the hybrid error in the dash along with brake/steering malfunction.
My actual questions if anyone has any info: can i bypass somehow the hybrid and start the gas engine with the regular 12V starter at least to see if the gas engine runs OK. Is there a way to charge the hybrid battery other than thru the car's system? Is the code for battery (low charge) a sign it needs to be replaced? Usually other cars will give you codes like "batt pack needs replacement" not "low charge".
I am posting a scan before installing a 12V battery (the big one). I didn't touch the small 12V battery but if I measure voltage it shows 12V or so in my world, that is a good 12V battery (didn't load test it).
Monday,02,December,2024,15:48:35:52624
VCDS Version: 24.7.1.0 (x64)
VIN: WA1C8AFP3DA083322 License Plate:
Mileage: 126200km-78417mi Repair Order:
Chassis Type: FP-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 36 3C 40 42 44 46 47 51 52 53
56 5F 62 6C 6D 72 8C
VIN: WA1C8AFP3DA083322 Mileage: 126200km-78417miles
09-Cent. Elect. -- Status: Malfunction 1010
40-AC Compressor -- Status: Malfunction 0010
51-Electric Drive -- Status: Malfunction 0010
8C-HV Battery -- Status: Malfunction 1010
Address 01: Engine (0-MA--CHJA) Labels:. 06H-907-115-CAB.clb
Part No SW: 8R1 907 115 D HW: 8R0 907 115 G
Component: 2.0l R4/4V TF H57 0003
Revision: NDH57--- CVN: 85499172
Coding: 6A2A0013442600062000
Shop #: WSC 06342 000 00000
ASAM Dataset: EV_ECM20TFS0118R1907115D 002005
ROD: EV_ECM20TFS.rod
VCID: 3663466C898AED2621-8062
VINID: 9D10532115A00D44402030C2083327DC6F
8 Faults Found:
17111 - Battery Energy Control Module
P0A1F 00 [01100000] - -
Mileage: 126202 km
Date: 2024.10.18
Time: 16:38:20
Engine RPM: 0.00 /min
Coolant temperature: 24 C
Intake air temperature: 27 C
Voltage terminal 30: 9.188 V
Current speed of electric motor: 0.0 /min
Operating state of electric drive-Bits 0-7: 00010101
Transfer electric drive to combustion drive-Bits 0-7: 00000000
Electric drive motor: mode of operation-Bits 0-7: 00000000
Operational state of the hybrid battery-Bits 0-7: 00000000
High-volt. battery: charge state: abs. value: 20.40 %
Coolant temperature of H-V / hybrid battery: 24.5 C
17062 - Battery Energy Control Module
P0A1F 00 [01100101] - -
Mileage: 126202 km
Date: 2024.10.07
Time: 18:02:59
Coolant temperature: 20 C
Intake air temperature: 23 C
Voltage terminal 30: 10.554 V
Operating state of electric drive-Bits 0-7: 00000101
Operational state of the hybrid battery-Bits 0-7: 00000101
High-volt. battery: charge state: abs. value: 19.20 %
Coolant temperature of H-V / hybrid battery: 18.0 C
18178 - Implausible Data Received from Diagnostic Gateway Module
U0447 00 [00101111] - -
Fault Frequency: 13
Mileage: 126202 km
Date: 2024.08.29
Time: 13:57:05
Engine RPM: 610.00 /min
Normed load value: 22.7 %
Coolant temperature: 25 C
Intake air temperature: 31 C
Voltage terminal 30: 10.790 V
CAN status - engine control module-Bits 0-7: 00000000
CAN status - transmission control module-Bits 0-7: 00000000
CAN status - brake control module 1-Bits 0-7: 00000000
CAN status - brake control module 2-Bits 0-7: 00000000
Cruise control switch actuation-Bits 0-7: 00000000
17427 - Implausible Data Received from Transmission Control Module
U0402 00 [00101000] - -
Fault Frequency: 11
Mileage: 126202 km
Date: 2024.10.07
Time: 11:33:17
Coolant temperature: 27 C
Intake air temperature: 30 C
Voltage terminal 30: 11.638 V
4629 - ECM Power Relay Load Circuit
P068A 00 [00100100] - Opens Too Early
Vehicle speed: 255 km/h
Coolant temperature: 19 C
Intake air temperature: 22 C
Voltage terminal 30: 11.944 V
Status transition of transmission control module sequencing-Bits 0-7: 00000000
Status transition of engine control module sequencing-Bits 0-7: 00000000
Electric drive torque: actual value: 0.0 Nm
Emachine_achievable_enginetorque_maximum_value: 0.0 Nm
Clutch K0: Status-Bits 0-7: 00000000
18187 - Service Mode Active
U1106 00 [10101111] - -
Mileage: 126202 km
Date: 2024.08.26
Time: 18:26:01
Coolant temperature: 39 C
Intake air temperature: 46 C
Voltage terminal 30: 14.206 V
Unlearning counter according OBD: 0
Mean injection time: 0.000 ms
Engine operating condition-Channel 87: Idle
Relative load value: 70.29 %
Engine torque: 0.0 Nm
14623 - HV Battery Pack
P0A7D 00 [11101101] - State of Charge Low
Mileage: 126202 km
Date: 2024.08.29
Time: 13:57:22
Engine RPM: 516.00 /min
Normed load value: 65.9 %
Coolant temperature: 26 C
Intake air temperature: 35 C
Voltage terminal 30: 11.685 V
Current speed of electric motor: 233.0 /min
Operating state of electric drive-Bits 0-7: 00001010
Electric drive motor: mode of operation-Bits 0-7: 00000100
Operational state of the hybrid battery-Bits 0-7: 00000001
High-volt. battery: charge state: abs. value: 22.00 %
Coolant temperature of H-V / hybrid battery: 26.0 C
12593 - HV Components
P0AB9 00 [10101111] - System Failure
Mileage: 126202 km
Date: 2024.10.07
Time: 11:17:17
Voltage terminal 30: 11.473 V
Status transition of transmission control module sequencing-Bits 0-7: 00000011
Status transition of engine control module sequencing-Bits 0-7: 00000010
Clutch K0: Status-Bits 0-7: 00000010
Transfer electric drive to combustion drive-Bits 0-7: 00000011
Readiness: 1110 1101
Part No SW: 8R1 927 158 K HW: 0BW 927 156 P
Component: 0BW 20TFSIUSA H16 1001
Revision: --H16--- CVN: 37B6CCC8
ASAM Dataset: EV_TCMAL551111 002022
ROD: EV_TCMAL551111.rod
VCID: 468336ACF96A7DA6B1-8012
12483 - System Voltage
P0562 00 [00101000] - Too Low
Mileage: 126202 km
Date: 2024.10.18
Time: 16:53:48
Voltage terminal 30: 8.929 V
Voltage supply of regulator valves: 8.891 V
Voltage terminal 15: 9.1 V
Engine RPM: 0 /min
Transmission input speed: 0.00 /min
Driving position: N
Control Module temperature: 25 C
selected gear: without traction
Starting clutch status: Kupplung geoeffnet
E-machine cut-out clutch status: geoeffnet
M015_Time Normal Mode: 26 s
M019_Time Since Reset: 7650 ms
M018_Time In Afterrun: 0 s
ATF temperature: 26 C
2543 - Transmission Control Unit
P1701 00 [00101000] - Locked
Mileage: 126202 km
Date: 2024.10.18
Time: 15:12:10
Voltage terminal 30: 10.989 V
Immobilizer Snapshot 1-Param 0: 11
Immobilizer Snapshot 1-Param 1: 11
Immobilizer Snapshot 1-Param 2: 8A
Immobilizer Snapshot 1-Param 3: 20
Immobilizer Snapshot 1-Param 4: 00
Immobilizer Snapshot 1-Param 5: 00
Status data bus communication diagnostic interface-State Deashboard received: not received
Status data bus communication diagnostic interface-State ECM received: not received
Status data bus communication diagnostic interface-State ESP received: not received
Status data bus communication diagnostic interface-State Gateway received: not received
Status data bus communication diagnostic interface-State Parking Brake received: not received
Status data bus communication diagnostic interface-State Steering Angle received: not received
Status data bus communication diagnostic interface-State Steering Assist received: not received
13785 - HV Components
P0AB9 00 [00101110] - System Failure
Fault Frequency: 15
Mileage: 126202 km
Date: 2024.10.07
Time: 11:33:02
Voltage terminal 30: 11.133 V
Transmission output speed: 0.00 /min
Engine torque: -33 Nm
ATF temperature: 30 C
Accelerator pedal position: 14.9 %
E-machine cut-out clutch status: applied
Engine RPM: 0 /min
Transfer speed from ESP: valid
Transfer speed from ESP: 0.00 km/h
Address 03: ABS Brakes (J104) Labels:. 8R0-907-379-V1.clb
Part No SW: 8R0 907 379 T HW: 8R0 907 379 T
Component: ESP8 quattro H09 0060
Coding: 2D1D1C
VCID: 51A915F00824AA1E14-8004
01119 - Gear Recognition Signal
Reset counter: 171
Mileage: 126202 km
Date: 2024.10.18
Time: 15:12:11
Hex Value: 0x0000
Hex Value: 0x4082
Hex Value: 0x000B
Hex Value: 0x278A
Hex Value: 0x0000
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 131
Mileage: 126202 km
Date: 2024.10.25
Time: 12:15:54
Hex Value: 0x0000
Hex Value: 0x0280
Hex Value: 0x0015
Hex Value: 0x0284
Hex Value: 0x0000
Reset counter: 171
Mileage: 126202 km
Date: 2024.10.25
Time: 14:46:00
Hex Value: 0x0000
Hex Value: 0x5082
Hex Value: 0x0029
Hex Value: 0x245F
Hex Value: 0x0000
Part No SW: 8K0 907 064 GP HW: 8K0 907 064 FP
Component: BCM2 2.0 H12 0633
Coding: 0DC54040000000000000
VCID: 0407ECA487D68FB6EF-8050
Subsystem 1 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Serial number: 2313000042121010
02812 - Supply Voltage (Terminal 30) for Electronic Steering Column Lock
Fault Frequency: 12
Reset counter: 171
Mileage: 126202 km
Date: 2024.10.18
Time: 16:53:49
Fault Frequency: 9
Reset counter: 171
Mileage: 126202 km
Date: 2024.10.24
Time: 15:52:20
Fault Status: 00101101
Reset counter: 171
Mileage: 126202 km
Date: 2024.10.25
Time: 14:46:42
Address 08: Auto HVAC (J255) Labels:. 8Kx-820-043-3Z.clb
Part No SW: 8K1 820 043 T HW: 8K1 820 043 T
Revision: C1000000 Serial number: 01210320130486
Coding: 64C120C000
VCID: 39794D50B094025ECC-806C
Reset counter: 171
Mileage: 126202 km
Date: 2024.10.25
Time: 14:45:40
Voltage: 8.40 V
Temperature: 32.0 C
Reset counter: 131
Mileage: 126202 km
Temperature: 10.0 C
Voltage: 11.00 V
Output: 0 W
Output: 0 W
Temperature: 27.0 C
Load: 127.0 %
Part No SW: 8K0 907 063 DJ HW: 8K0 907 063 DJ
Component: BCM1 1.0 H16 0103
Revision: 09016001 Serial number: 00000566208101
Coding: 26000091863CAFC00000480300003D0D0F1C4608E0090221000008004000010200040034000000
VCID: 7AFB925CF512C94685-802E
Subsystem 1 - Part No SW: 8R1 955 119 A HW: 8R1 955 119 Labels: 1KX-955-119.CLB
Component: WWS416 130311 H11 0050
Serial number: 90243014130302050816
Coding: 01DD13
Component: G397_RLFS H06 0002
Serial number: 21108882
Coding: 02005C
Component: E1 - LDS H03 0031
Serial number: 00000000001103130335
Component: USHL4.2 H30 0030
Serial number: 0000002274555R572E02
Subsystem 5 - Part No SW: 3D0 941 329 HW: 3D0 941 329
H05 0012
Subsystem 6 - Part No SW: 3D0 941 329 HW: 3D0 941 329
H05 0012
Subsystem 7 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: AE294B96000000000001
Fault Frequency: 9
Reset counter: 171
Mileage: 126202 km
Date: 2024.10.24
Time: 15:52:07
Reset counter: 171
Mileage: 126202 km
Date: 2024.10.25
Time: 14:47:05
Address 15: Airbags (J234) Labels:* 8R0-959-655.clb
Part No SW: 8R0 959 655 F HW: 8R0 959 655 F
Serial number: 003GPD91E2TQ Dataset Number: 8R0909602B 0021
Coding: 303634313432303030304A55304C38523053
Shop #: WSC 06335 000 00000
ROD: EV_AirbaAU10SMEAU416.rod
VCID: 479D3BA8FE6064AE4A-8012
Subsystem 1 - Part No SW: 8R0 959 339 A HW: 8R0 959 339 A
Component: BF-Gewichtss. H02 0040
Serial number: 5810000R130000C54E
Serial number: 6334MSME78334464C
Serial number: 6344MSME78330C7CQ
Serial number: 6352QSME4230255EC
Serial number: 6362QSME533208728
Serial number: 63732SME492F436ED
Serial number: 63832SME2C2D05483
13635840 - Supply voltage
U1011 00 [00001000] - Voltage too Low
Reset counter: 171
Mileage: 126202 km
Date: 2024.10.18
Time: 16:35:01
B10B4 00 [00001000] - Function Restriction due to Undervoltage
Reset counter: 171
Mileage: 126202 km
Date: 2024.10.18
Time: 16:34:17
Part No SW: 8K0 953 568 L HW: 8K0 953 568 L
Component: Lenks.Modul H03 0005
Revision: -------- Serial number: 90372MCB00045
Coding: 000037
VCID: 43852FB8C258488E96-8016
Reset counter: 171
Mileage: 126202 km
Date: 2024.10.25
Time: 11:00:03
Reset counter: 171
Mileage: 126202 km
Date: 2024.10.25
Time: 14:45:52
Address 17: Instruments (J285) Labels:. 8R0-920-xxx-17.clb
Part No SW: 8R0 920 981 D HW: 8R0 920 981 D
Component: KOMBIINSTR. H35 0556
Revision: 00200000 Serial number: UWU209F3E
Coding: 8BB723000B01D705020000
VCID: 3B755758BAA8304EDE-806E
Reset counter: 171
Mileage: 126202 km
Date: 2024.10.25
Time: 14:45:41
Part No SW: 8R0 907 468 K HW: 8R0 907 468 E
Component: GW-BEM 5CAN-M H11 0055
Revision: 2A120022 Serial number: 2242A133040034
Coding: 80D00AFF00
VCID: 479D3BA8F66064AE4A-8012
Subsystem 1 - Part No SW: 8R0 915 181 A HW: 8R0 915 181 A
Component: J367-BDM H07 0180
Serial number: 40067D19581581109698
Subsystem 2 - Part No SW: 8R0 915 181 B HW: 8R0 915 181 B
Component: J367-BDMLear2 H07 5040
Serial number: 40065723041770211766
02256 - Quiescent Current
Fault Status: 00100001
Reset counter: 171
Mileage: 126202 km
Date: 2024.08.29
Time: 16:09:01
Fault Frequency: 8
Reset counter: 171
Mileage: 126202 km
Date: 2024.08.29
Time: 19:09:02
Bin. Bits: 00000
Voltage: 12.70 V
Count: 7
03999 - Voltage converter
Fault Status: 00101100
Reset counter: 171
Mileage: 126202 km
Date: 2024.10.18
Time: 15:29:22
Bin. Bits: 10111
Voltage: 10.90 V
Count: 6
Reset counter: 171
Mileage: 126202 km
Date: 2024.10.26
Time: 00:00:01
Bin. Bits: 00000
Voltage: 11.60 V
Count: 7
Bin. Bits: 10000
Time: 0.90 s
03713 - Control Module for HV Battery Management
Reset counter: 171
Mileage: 126202 km
Date: 2024.10.26
Time: 00:00:05
Bin. Bits: 10000
Voltage: 12.10 V
Count: 7
Bin. Bits: 10000
Time: 4.90 s
Part No SW: 8R0 959 760 D HW: 8R0 959 760 B
Component: MEM-FS H07 0076
Revision: AA000000 Serial number: 00000054128306
Coding: 00581B00000000000000
VCID: 428B2ABCDD4241869D-8016
Reset counter: 171
Mileage: 126202 km
Date: 2024.10.25
Time: 14:46:40
Part No SW: 8T0 907 566 B HW: 8T0 907 566 B
Component: SWA Master H04 0060
Serial number: 0192982128 Dataset Number: 8R0909535E 0019
Coding: 010211
Shop #: WSC 19275 005 1048576
VCID: 3F8D2348A6B02C6EF2-806A
Subsystem 1 - Part No SW: 8T0 907 568 B HW: 8T0 907 568 B
Component: SWA Slave H04 0060
Serial number: 0192294264
Coding: 000102
114178 - Function Restricted due to Insufficient Voltage
U1400 00 [00001000] - -
136194 - Supply voltage
730117 - Control Module 2 for Lane-Change Assist
C1115 F0 [00001001] - Automatic Calibration Not Possible
Reset counter: 131
Mileage: 126202 km
Date: 2024.08.26
Time: 17:37:12
Address 40: AC Compressor (J842) Labels: 8R0-260-797.clb
Part No SW: 8R0 260 797 C HW: 8R0 260 797 C
Component: ES34 H01 0001
ASAM Dataset: EV_AirCondiCompr_ES34 S03001
ROD: EV_AirCondiCompr_ES34.rod
VCID: 3C775444B7A63776D7-8068
Reset counter: 171
Mileage: 126202 km
Date: 2024.10.25
Time: 14:45:42
Voltage terminal 15: 8.5 V
Compressor speed: 0 /min
Compressor current: 0.0 A
Compressor temperature: 29 C
Compressor main status: Not available
Compressor enabling: Not available
Compressor speed specified value: 0 /min
Availability of high voltage: available.
Hybrid battery voltage: 252.0 V
Compressor motor current: 0.0 A
Fault Frequency: 9
Reset counter: 171
Mileage: 126202 km
Date: 2024.10.18
Time: 16:35:21
Voltage terminal 15: 8.8 V
Compressor temperature: 0 C
Hybrid battery voltage: 100.0 V
10489328 - Function Restriction
B200D F0 [00001000] - due to Internal Communcations Error
Fault Frequency: 9
Reset counter: 171
Mileage: 126202 km
Date: 2024.08.26
Time: 17:56:51
Voltage terminal 15: 12.2 V
Compressor temperature: 35 C
Hybrid battery voltage: 118.0 V
Part No SW: 8K0 959 793 R HW: 8K0 959 793 P
Component: TSG FA H02 0508
Revision: Serial number: 0000055856701
Coding: 011D13205E00440004
Shop #: WSC 00000 126 28888
VCID: 4FAD13881E10BCEE02-801A
Reset counter: 171
Mileage: 126202 km
Date: 2024.10.18
Time: 16:53:54
Reset counter: 171
Mileage: 126202 km
Date: 2024.10.25
Time: 14:46:40
Part No SW: 8R0 909 144 F HW: 8R0 909 144 B
Component: RCEPS H37 0507
Revision: 00001000 Serial number: 0005317496 Dataset Number: 8R0909852VH 0001
Coding: 000000000100
ROD: EV_RCEPSAU48X_008.rod
VCID: 3B755758B2A8304EDE-806E
16400 - Function Restricted due to Insufficient Voltage
Reset counter: 171
Mileage: 126202 km
Date: 2024.10.18
Time: 16:53:47
Write only channel
16387 - Function Restricted due to Insufficient Voltage
Reset counter: 171
Mileage: 126202 km
Date: 2024.10.25
Time: 14:46:04
Write only channel
18689 - Terminal 30
U140A 00 [00001000] - Open Circuit
Reset counter: 171
Mileage: 126202 km
Date: 2024.10.26
Time: 00:00:10
Write only channel
19714 - Function Restricted due to Insufficient Voltage
Fault Frequency: 12
Reset counter: 171
Mileage: 126202 km
Date: 2024.10.18
Time: 16:32:20
Write only channel
Revision: 00002001 Serial number: 0302777554
Coding: 0126023A20FA709584B005321004000D
Component: GTO BF H01 0080
Serial number: 00000000000000649280
Subsystem 3 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H05 0220
Subsystem 4 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J394EE20SKB13 H05 0220
Reset counter: 171
Mileage: 126202 km
Date: 2024.10.25
Time: 14:46:42
01512 - Control Module for Sliding Roof
Fault Status: 01100101
Reset counter: 131
Mileage: 126202 km
Date: 2024.10.26
Time: 00:00:03
Reset counter: 171
Mileage: 126202 km
Date: 2024.11.27
Time: 14:13:36
Part No SW: 8T1 035 223 A HW: 8T1 035 223 A
Component: DSP Prem H05 0030
Revision: 00005001 Serial number: 94813012439802
VCID: 2D51690074DCAEFE50-8078
03029 - Subwoofer (R157)
Fault Status: 00101011
Reset counter: 131
Voltage: 12.20 V
Temperature: 12.0 C
Temperature: 12.0 C
Bin. Bits: 00000100
Address 51: Electric Drive (J841) Labels: 06F-907-080.clb
Part No SW: 06F 907 080 H HW: 06F 907 080 H
Component: MLB HYBRID H20 0002
Revision: -------- CVN: 9102B35A
ASAM Dataset: EV_DMCM030202106F907080H 001004
ROD: EV_DMCM030202106F907080H.rod
VCID: 2C57640447C6A7F647-8078
17318 - Control module locked
P16CA 00 [00100000] - -
Mileage: 126202 km
Date: 2024.10.18
Time: 15:12:10
FRF_IMMO_SNAPSHOT_BYTE1: 12
FRF_IMMO_SNAPSHOT_BYTE2: 12
FRF_IMMO_SNAPSHOT_BYTE3: 138
FRF_IMMO_SNAPSHOT_BYTE4: 40
FRF_IMMO_SNAPSHOT_BYTE5: 0
FRF_IMMO_SNAPSHOT_BYTE6: 0
Part No SW: 8K0 959 792 R HW: 8K0 959 792 P
Component: TSG BF H02 0508
Revision: Serial number: 0000054784289
VCID: 4E930E8C191AB5E609-801A
Reset counter: 171
Mileage: 126202 km
Date: 2024.10.18
Time: 16:38:08
Reset counter: 171
Mileage: 126202 km
Date: 2024.10.25
Time: 14:46:42
Part No SW: 8K0 907 801 L HW: 8K0 907 801 J
Component: EPB-4 H01 0003
Revision: -------- Serial number: 30000000024730
ROD: EV_ParkiBrake_AU48.rod
VCID: 387F4854839E1B5633-806C
10554390 - Supply voltage
Reset counter: 131
Mileage: 126202 km
Date: 2024.10.24
Time: 15:51:41
Voltage terminal 30: 8.9 V
Internal Fault ID: 40
Function light in parking brake button: OFF
Red operating lamp: OFF
Red warning lamp: OFF
Green operating lamp: OFF
Yellow warning lamp: OFF
Terminal 15 status: On
RWU: not active
DSD: not active
HTR: not active
ECD: not active
ACC requested apply: not active
Auto Adjust: not active
Internal Parking Brake state: static
Status ParkingBrake left: Open
Status ParkingBrake right: Open
10554487 - Function Restricted due to Insufficient Voltage
Reset counter: 171
Mileage: 126202 km
Date: 2024.10.25
Time: 11:00:07
Voltage terminal 30: 8.4 V
Internal Fault ID: 42
RWU: not active
DSD: not active
HTR: not active
ECD: not active
Part No SW: 4G0 035 082 E HW: 4G0 035 082
Component: Radio U SIRIU H60 0121
Revision: AB001007 Serial number: 156C/0D7706457
Coding: 020007010000000001
VCID: 224B8A3C3D026186FD-8076
Reset counter: 171
Mileage: 126202 km
Date: 2024.10.25
Time: 14:46:42
Voltage: 6.90 V
Reset counter: 171
Mileage: 126202 km
Date: 2024.10.24
Time: 15:52:01
Voltage: 8.60 V
Part No SW: 8R1 035 746 C HW: 8R1 035 746 B
Component: H-BNT-NA H44 0624
Revision: -------- Serial number: 204C+0D7568737
Coding: 170200060005A1EF51038B4E00000403140000000000000002
VCID: 377D4B688680142E3A-8062
Subsystem 1 - Part No: 8R0 060 884 BA
Component: NAR 2013 0703
Component: DU7 High H42 0104
Serial number: A130CX0D2686519
Subsystem 3 - Part No SW: 8T0 919 611 L HW: 8T0 919 611 C
Serial number: 00000001449505
Component: CD-Database 4949
Reset counter: 171
Mileage: 126202 km
Date: 2024.10.25
Time: 14:46:42
Voltage: 6.70 V
03367 - Supply Voltage for Display Module
Reset counter: 171
Mileage: 126202 km
Date: 2024.10.25
Time: 14:46:13
Voltage: 7.10 V
Part No SW: 8K0 959 795 G HW: 8K0 959 795 D
Component: TSG HL H01 0506
Revision: Serial number: 0000054898837
Coding: 010C13204000240004
VCID: 468336ACF16A7DA6B1-8012
Reset counter: 171
Mileage: 126202 km
Date: 2024.10.18
Time: 16:53:54
Reset counter: 171
Mileage: 126202 km
Date: 2024.10.25
Time: 14:46:41
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8R0 907 441 A HW: 4L0 907 441 B
Revision: --H07--- Serial number: 525PA8-J31A08J
Coding: 1020010
VCID: 34677C6457F6FF361F-8060
Reset counter: 171
Mileage: 126202 km
Date: 2024.10.24
Time: 15:51:39
Reverse OFF
Count: 3
Reset counter: 171
Mileage: 126202 km
Date: 2024.10.25
Time: 14:45:42
Reverse OFF
Count: 3
Address 6D: Trunk Elect. (J605) Labels: 8K9-827-851.clb
Part No SW: 8R0 827 851 B HW: 8R0 827 851 B
Component: J605 Master H52 0330
Revision: -------- Serial number: 8R0827851B
Subsystem 1 - Part No SW: 8R0 827 852 B HW: 8R0 827 852 B
Component: J756 Slave H52 0330
Serial number: 8R0827852B
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb
Component: TSG HR H01 0506
Revision: Serial number: 0000054912526
Reset counter: 171
Mileage: 126202 km
Date: 2024.10.18
Time: 16:53:53
Reset counter: 171
Mileage: 126202 km
Date: 2024.10.25
Time: 14:46:40
Address 8C: HV Battery (J840) Labels: None
Part No SW: 8R0 915 591 HW: 8R0 915 591
Component: BMS H08 0543
Dataset Number: 0001 CVN: 446F8D58
Coding: 0A0200
Shop #: WSC 57767 001 1048576
ASAM Dataset: EV_BECM0722011 004016
ROD: EV_BECM0722011_004_AU48.rod
VCID: 78FF8854C31EDB56F3-802C
5833 - HV Battery Pack
P0A7D 00 [00100111] - State of Charge Low
Pack Voltage: 254.5 V
Pack Current: -0.00 A
Isolation Resistance: 1020 kOhm
Maximum discharge current limit: 255 A
BMS_MaxDyn_EntladeStorm: 255 A
Contactor Voltage: 0 V
Crash status: 00
FAN status: 00
Pilot Line Status: 00
Fuse Status: 00
(Minus) Contactor Status: 00
(Plus) Contactor Status: 00
Terminal 15 status: 01
DFCC: 5833
Max Cell Temperature: 14 C
Min Cell Temperature: 13 C
Air inlet temperature: 14 C
Air outlet temperature: 14 C
LV Battery Voltage: 11.7 V
Min.cell voltage: 3.530 V
Max.cell Voltage: 3.539 V
Max.cell SOC: 21 %
Min.cell SOC: 19 %
Max Charge Pack Current(10s duration): 255 A
Max Discharge Pack Current(10s duration): 255 A
Max Pack Voltage: 510 V
Min Pack Voltage(10s duration): 510 V
Max.cell Voltage(10s duration): 65.535 V
Min.cell Voltage(10s duration): 65.535 V
Accelerator Pedal Position D: 100.0 %
Calculated LOAD Value: 100.0 %
Engine coolant temperature: 215 C
Engine RPM: 16383.75 /min
Vehicle Speed Sensor: 255 km/h
Absolute Throtle Position: 100.0 %
distance traveld since fault memory last cleared: 65535 km
control module system voltage: 11.733 V
absolute load: 25700.0 %
Time After Engine Start: 0 /min
5842 - HV Battery Charging
P1B16 00 [01101101] - No External Charger Detected
Mileage: 126202 km
Date: 2024.10.07
Time: 18:03:00
Pack Voltage: 255.4 V
Pack Current: -0.04 A
Isolation Resistance: 1016 kOhm
Maximum discharge current limit: 180 A
BMS_MaxDyn_EntladeStorm: 78 A
Contactor Voltage: 254 V
Crash status: 00
FAN status: 00
Fuse Status: 00
(Minus) Contactor Status: 01
(Plus) Contactor Status: 01
DFCC: 5842
Max Cell Temperature: 37 C
Min Cell Temperature: 35 C
Air inlet temperature: 37 C
Air outlet temperature: 38 C
LV Battery Voltage: 11.8 V
Min.cell voltage: 3.544 V
Max.cell Voltage: 3.553 V
Max.cell SOC: 23 %
Min.cell SOC: 22 %
Max Charge Pack Current(10s duration): 0 A
Max Discharge Pack Current(10s duration): 0 A
Max Pack Voltage: 254 V
Min Pack Voltage(10s duration): 254 V
Max.cell Voltage(10s duration): 3.555 V
Min.cell Voltage(10s duration): 3.542 V
Accelerator Pedal Position D: 14.9 %
Calculated LOAD Value: 0.0 %
Engine coolant temperature: 34 C
Vehicle Speed Sensor: 0 km/h
Absolute Throtle Position: 15.7 %
distance traveld since fault memory last cleared: 0 km
control module system voltage: 11.814 V
absolute load: 0.0 %
13744 - HV Battery Pack Air Flow Valve 1
P0AD5 00 [00100000] - Electrical Malfunction
Mileage: 126202 km
Date: 2024.10.18
Time: 16:38:20
Pack Voltage: 255.0 V
Pack Current: -0.01 A
BMS_MaxDyn_EntladeStorm: 22 A
Crash status: 00
FAN status: 00
Fuse Status: 00
DFCC: 13744
Max Cell Temperature: 25 C
Min Cell Temperature: 23 C
Air inlet temperature: 25 C
Air outlet temperature: 26 C
LV Battery Voltage: 9.4 V
Min.cell voltage: 3.539 V
Max.cell Voltage: 3.546 V
Max.cell SOC: 22 %
Min.cell SOC: 20 %
Max.cell Voltage(10s duration): 3.547 V
Min.cell Voltage(10s duration): 3.535 V
Engine coolant temperature: 24 C
control module system voltage: 9.414 V
Time After Engine Start: 366 /min
End-------------------------(Elapsed Time: 05:03)--------------------------
