Car was on accident and loss code help (MK100IPB)
MaxxLetlotlo
Botswana
C?ID=522582
Saturday,30,November,2024,16:38:06:39152
VCDS Version: 24.7.1.0 (x64)  HEX-NET2 CB: 0.4643.5
VIN: WVWZZZAUZEW133614   License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 2B 42 44 52 55 5F A5
          A9
VIN: WVWZZZAUZEW133614   Mileage: 60824km-37794miles
01-Engine -- Status: Cannot be reached 0100
02-Auto Trans -- Status: Cannot be reached 0100
05-Acc/Start Auth. -- Status: Cannot be reached 0100
08-Auto HVAC -- Status: Cannot be reached 0100
10-Park/Steer Assist -- Status: Cannot be reached 0100
13-Auto Dist. Reg -- Status: Cannot be reached 0100
14-Susp. Elect. -- Status: Cannot be reached 0100
2B-Steer. Col. Lock -- Status: Cannot be reached 0100
42-Door Elect, Driver -- Status: Cannot be reached 0100
52-Door Elect, Pass. -- Status: Cannot be reached 0100
55-Headlight Range -- Status: Cannot be reached 0100
A5-Frt Sens. Drv. Assist -- Status: Cannot be reached 0100
A9-Struct. Borne Sound -- Status: Cannot be reached 0100
Address 01: Engine (J623-CHHB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259     HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0009
   Revision: --H13---    CVN: FBA47E06
   Coding: 091D00324464050B3000
   ASAM Dataset: EV_ECM20TFS0215G0906259 001013
   ROD: EV_ECM20TFS0215G0906259.rod
   VCID: EB88284FB30CFF521A9-80BE
   VINID: 9E69EAAAA465A959C10C318110A066B078
20664 - Oxygen (Lambda) Sensor B1 S1
          P0132 00 [00100100] - Signal too High
                    Mileage: 60775 km
                    Date: 2024.12.01
                    Time: 15:09:59
                    Engine RPM: 835.00 /min
                    Normed load value: 4.7 %
                    Coolant temperature: 61 °C
                    Intake air temperature: 50 °C
                    Ambient air pressure: 900 mbar
                    Voltage terminal 30: 11.464 V
                    Engine: operating status: IS
                    ECU_STATE: SYN_ENG_IGK_ON
                    T_ES: 125 min
                    T_AST_SAE: 0 s
                    TTIP_MES_LS_UP[1]: -2048.0000 °C
                    TEG_DYN_LS_UP[1]: 104.9750 °C
                    Lambda probes actual: bank1: 1.2002
15027 - Fuel Level too Low
          P1250 00 [00100110] - -
                    Mileage: 60775 km
                    Date: 2024.12.01
                    Time: 15:10:00
                    Engine RPM: 788.50 /min
                    Normed load value: 7.5 %
                    Voltage terminal 30: 11.484 V
                    STATE_LS_SAE[1]: OL_ERR
                    T_AST_SAE: 0 s
                    MAP_MES_SAE: 28 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.997 V
                    FAC_TPS_1_SAE: 12.890625 %
                    FUP_H_SAE: 12080.0 kPa
15197 - Intake Manifold Flap Position Sensor (Bank 1)
          P2014 00 [10101111] - Electrical Malfunction
                    Mileage: 60775 km
                    Date: 2024.12.01
                    Time: 12:55:56
                    Engine RPM: 800.75 /min
                    Normed load value: 11.8 %
                    Coolant temperature: 106 °C
                    Intake air temperature: 62 °C
                    Voltage terminal 30: 14.062 V
                    T_AST_SAE: 0 s
                    MAP_MES_SAE: 40 kPa
                    FUP_H_SAE: 11980.0 kPa
22008 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [00101111] - -
                    Mileage: 60775 km
                    Date: 2024.12.01
                    Time: 12:55:57
                    Engine RPM: 803.50 /min
                    Normed load value: 12.5 %
                    Voltage terminal 30: 14.023 V
                    Engine oil temperature: 109.0 °C
                    Time since engine start: 1283.0 s
                    T_ES: 0 min
                    Cruise control switch actuation-Main switch: Not operated
                    Cruise control switch actuation-Set: Not operated
                    Cruise control switch actuation-Resume: Not operated
                    Cruise control switch actuation-Accelerate: Not operated
                    Cruise control switch actuation-DELAY: Not operated
                    Cruise control switch actuation-Cancel: Not operated
                    Cruise control switch actuation-Main switch hardware: Not operated
                    Cruise control switch actuation-Limit button: Not operated
                    Cruise control switch actuation-Main switch CAN: Not operated
                    Cruise control switch actuation-Large increment: Not operated
                    STATE_ERR_ABC_PRED: 18
22057 - No Communications with Parking Assist Control Module A
          U0159 00 [00101111] - -
                    Mileage: 60775 km
                    Date: 2024.12.01
                    Time: 12:55:56
                    Voltage terminal 30: 14.003 V
                    Time since engine start: 1282.3 s
                    T_ES: 0 min
                    STATE_ERR_ABC_PRED: 0
19875 - No Communication with ABS Brake Control Module
          U0121 00 [10101111] - -
                    Mileage: 60775 km
                    Date: 2024.12.01
                    Time: 12:55:57
                    T_ES: 0 min
Readiness: 1010 0001
   Part No SW: 0D9 300 040 L    HW: 02E 927 770 AN
   Component: DQ250-6F MQB  H52 4025
   Revision: 05652103    Serial number: TFK01303230597 CVN: 00002F9F
   ROD: EV_TCMDQ250021.rod
   VCID: A0120F630A4AEC0AFFB-80F4
21153 - Gear 1
          P072C 00 [00000010] - Not Selectable
21159 - Gear R
          P072B 00 [00000010] - Not Selectable
10906 - Cooling Oil Valve
          P179D 00 [00000010] - Electrical Malfunction
21221 - No Communications with Parking Brake Control Module
          U0128 00 [00001011] - -
                    Mileage: 60775 km
                    Date: 2024.12.01
                    Time: 12:55:57
   Part No SW: 5Q0 907 379 AB    HW: 5Q0 907 379 H
   Component: ESC           H31 0557
   Revision: 00000000    Serial number: 615230000005F5
   Shop #: WSC 51682 001 1048576
   VCID: FCAA1B13C66268EA833-80A8
13 Faults Found:
0195 - Control module not coded
          U1013 00 [10001001] - -
          [ECU marked as Not Configured because vehicle ID is invalid]
                    Reset counter: 79
                    Date: 2024.12.01
                    Time: 12:55:58
          C1017 54 [10001001] - Missing Calibration / Basic Setting
                    Reset counter: 79
                    Date: 2024.12.01
                    Time: 12:55:58
          C1079 54 [10001001] - Missing Calibration / Basic Setting
                    Reset counter: 79
                    Date: 2024.12.01
                    Time: 12:55:58
0279 - Brake Pressure Sensor 1
          C107A 54 [10001001] - Missing Calibration / Basic Setting
                    Reset counter: 79
                    Date: 2024.12.01
                    Time: 12:55:58
0295 - Steering angle sensor
          B1168 54 [10001001] - Missing Calibration / Basic Setting
                    Reset counter: 79
                    Date: 2024.12.01
                    Time: 12:55:58
0398 - Control Module Incorrectly Coded
          U1014 00 [00001001] - -
          [Vehicle equipped with vacuum sensor but no vacuum sensor coded]
                    Reset counter: 79
                    Mileage: 60775 km
                    Date: 2024.12.01
                    Time: 12:55:59
8278 - Control Module Incorrectly Coded
          U1014 00 [10001001] - -
          [FCAN: Mismatch between bytecoding and Lenkerposition signal]
                    Reset counter: 79
                    Date: 2024.12.01
                    Time: 12:55:58
8286 - Databus
          U1123 00 [10001001] - Received Error Message
          [FCAN: MO_Timeout_ESP signal is invalid]
                    Reset counter: 79
                    Date: 2024.12.01
                    Time: 12:55:58
8290 - Coding Not Possible
          U10BC 00 [10001001] - -
          [FCAN: Unplausible VIN number]
                    Reset counter: 79
                    Mileage: 60775 km
                    Date: 2024.12.01
                    Time: 12:56:03
8306 - Databus
          U1122 00 [10001001] - Implausible Message
                    Reset counter: 79
                    Mileage: 60775 km
                    Date: 2024.12.01
                    Time: 12:56:03
8308 - Control Module Incorrectly Coded
          [FCAN: StartStop not coded but MO_StartStopp_Status not equal 0]
                    Reset counter: 79
                    Date: 2024.12.01
                    Time: 12:55:58
8311 - Control Module Incorrectly Coded
          [FCAN: Damper not coded but Fahrwerk_01 message received]
                    Reset counter: 79
                    Date: 2024.12.01
                    Time: 12:55:58
32848 - Control Module for Electric Parking Brake
          C10E2 F1 [10001001] - Switches/Motors Detected
                    Reset counter: 79
                    Date: 2024.12.01
                    Time: 12:55:58
   Revision: 00021000    Serial number: 0194355857 Dataset Number: 5G0IJ1v____ 0001
   Coding: 030C0C
   VCID: BA26DD0B8CD696DAD1F-80EE
   Part No SW: 5G0 907 044 T    HW: 5G0 907 044 T
   Component: Climatronic   H02 0805
   Revision: 00001K06
   Coding: 00120004100100001105000011101800
   VCID: B822C703B2DA84CA27B-80EC
   Air quality sensor:
459024 - Databus
          [Frontsensorik - kein Signal/Kommunikation]
                    Reset counter: 79
                    Mileage: 60775 km
                    Date: 2024.12.01
                    Time: 13:03:58
   Part No SW: 5Q0 937 085 Q    HW: 5Q0 937 085 Q
   Component: BCM MQBAB HNA H14 0112
   Serial number: 00011325200147 Dataset Number: 5G0063v____ 0001
   Coding: 03011A42424122FB49E44000000C0728180A000000000000000000000000
   ROD: EV_BCMBOSCH_011.rod
   VCID: C7C0B4FFCF24FB325E1-8092
   Component: WWS    130825  042 0551
   Serial number:         130916165905
   Component: RLFS  024 0042
   Serial number: Y13M09D21H22M20S12S1
   Coding: 31E8DD
550420 - Databus
          [TSG_FT_01 Datenbus empfangener Fehlerwert]
                    Reset counter: 80
                    Mileage: 60775 km
                    Date: 2024.12.01
                    Time: 15:32:15
                    Terminal 15 status: On
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    Status Bremslichtschalter (HW): On
                    Status Bremslichtschalter (CAN): On
                    OFF: operated
                    Position lamps: Not operated
                    Low beam: Not operated
                    Voltage: 13.7 V
                    Outside temperature: 39.5 °C
Address 10: Park/Steer Assist
Address 13: Auto Dist. Reg
   Part No SW: 5Q0 907 376     HW: 5Q0 907 376
   Component: DAEMPFUNGS-SG H15 0115
   Serial number: 03091341355526 Dataset Number: 5G0532v____ 0022
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: F6BE093BF84E32BAF57-80A2
835584 - MIL Request Signal Active (Check TCM for errors too!)
          P1624 00 [10001001] - -
                    Reset counter: 80
                    Mileage: 60775 km
                    Date: 2024.12.01
                    Time: 12:56:00
36610 - Valve for DamPing Adjustment Front Right
          C1041 21 [10001001] - Signal Amplitude Too Low
                    Reset counter: 79
                    Mileage: 60775 km
                    Date: 2024.12.01
                    Time: 12:56:00
   Part No SW: 5Q0 959 655 AA    HW: 5Q0 959 655 AA
   Component: AirbagVW20    014 0386
   Serial number: 003MLR00FADP Dataset Number: 5G0003v____ 0089
   Coding: 98FCC0C0000000005C5400CF00C800000065
   VCID: FF50EC1FD77473F2A61-80AA
   Left seat belt tensioner:
   Component: BeltPretRevFL  H35 0340
   Serial number: 34169677B25091350298
   Coding: 333135
   Right seat belt tensioner:
   Component: BeltPretRevFR  H35 0340
   Serial number: 34169676B23091371361
   Subsystem 3 - Part No SW: -----------    HW: 480 003 108 13
   Serial number: 35767000000EB97DAD0J
   Subsystem 4 - Part No SW: -----------    HW: 480 003 108 13
   Serial number: 3586700000044D7DAD07
   Subsystem 5 - Part No SW: -----------    HW: 480 401 609 13
   Serial number: 3516502AF11FBEB402CW
   Subsystem 6 - Part No SW: -----------    HW: 480 401 609 13
   Serial number: 3526502A311FBEB621EQ
   Subsystem 7 - Part No SW: -----------    HW: 480 401 109 13
   Serial number: 3556502AF1118A54B3AJ
11 Faults Found:
          B1000 1B [10001001] - Resistance Too High
                    Mileage: 60775 km
                    Date: 2024.12.01
                    Time: 12:55:57
9437723 - Igniter for Passenger's Airbag
          B1002 1B [10001001] - Resistance Too High
                    Mileage: 60775 km
                    Date: 2024.12.01
                    Time: 12:55:57
          B1006 1B [10001001] - Resistance Too High
                    Mileage: 60775 km
                    Date: 2024.12.01
                    Time: 12:55:57
9439003 - Igniter for Seat Belt Tensioner; Passenger's Side
          B1007 1B [10001001] - Resistance Too High
                    Mileage: 60775 km
                    Date: 2024.12.01
                    Time: 12:55:57
9440283 - Driver side knee airbag igniter
          B100C 1B [10001001] - Resistance Too High
                    Mileage: 60775 km
                    Date: 2024.12.01
                    Time: 12:55:57
9439515 - Seat Belt Tensioner Igniter; rear; driver's side
          B1009 1B [10001001] - Resistance Too High
                    Mileage: 60775 km
                    Date: 2024.12.01
                    Time: 12:55:57
9439259 - Igniter for Seat Belt Tensioner; Rear Passenger's Side
          B1008 1B [10001001] - Resistance Too High
                    Mileage: 60775 km
                    Date: 2024.12.01
                    Time: 12:55:57
1049093 - Databus
          [NWD: 0x101 ESP_02 error value ESP_Querbeschleunigung]
                    Reset counter: 79
                    Mileage: 60775 km
                    Date: 2024.12.01
                    Time: 12:56:00
1050117 - Databus
          [NWD: 0x086 LWI_01 error value LWI_Lenkradwinkel]
                    Reset counter: 79
                    Mileage: 60775 km
                    Date: 2024.12.01
                    Time: 12:55:56
1049094 - Databus
          [NWD: 0x101 ESP_02 error value ESP_Laengsbeschleunigung]
                    Reset counter: 79
                    Mileage: 60775 km
                    Date: 2024.12.01
                    Time: 12:56:00
1049095 - Databus
          [NWD: 0x101 ESP_02 error value ESP_Gierrate]
                    Reset counter: 79
                    Mileage: 60775 km
                    Date: 2024.12.01
                    Time: 12:56:00
   Part No SW: 5Q0 953 507 BM    HW: 5Q0 953 549
   Revision: --------    Serial number: 16091304220042 Dataset Number: ----------
   Coding: 0C00
   ROD: EV_SMLSKLOMQB_009.rod
   VCID: 825665EBA4861E1AC9F-80D6
   Part No SW: 5G6 920 870 C    HW: 5G6 920 870 C
   Component: KOMBI         320 2210
   Coding: 27AD09187F80000E02886A03040000
   Shop #: WSC 60300 981 00000
   VCID: AF30FC5F47944372761-80FA
7 Faults Found:
16777010 - Function Restricted due to Interrupted Communications
          U1110 00 [00001001] - -
          [BAP_LDW_0x19 keine Kommunikation]
                    Reset counter: 79
                    Mileage: 60775 km
                    Date: 2024.12.01
                    Time: 12:55:59
16777028 - Function Restricted due to Interrupted Communications
          [BAP_AWV_0x1B keine Kommunikation]
                    Reset counter: 79
                    Mileage: 60775 km
                    Date: 2024.12.01
                    Time: 12:55:59
16776960 - Databus
          [ACC_02 keine Kommunikation]
                    Reset counter: 79
                    Mileage: 60775 km
                    Date: 2024.12.01
                    Time: 12:55:56
16776961 - Databus
          [ACC_04 keine Kommunikation]
                    Reset counter: 79
                    Mileage: 60775 km
                    Date: 2024.12.01
                    Time: 12:55:56
16776967 - Databus
          [EPB_02 keine Kommunikation]
                    Reset counter: 79
                    Mileage: 60775 km
                    Date: 2024.12.01
                    Time: 12:55:56
16776969 - Databus
          [LDW_02 keine Kommunikation]
                    Reset counter: 79
                    Mileage: 60775 km
                    Date: 2024.12.01
                    Time: 12:55:56
16776973 - Databus
          [RKA_01 keine Kommunikation]
                    Reset counter: 79
                    Mileage: 60775 km
                    Date: 2024.12.01
                    Time: 12:55:56
   Part No SW: 5Q0 907 530 M    HW: 5Q0 907 530 F
   Component: GW MQB High   125 1144
   Revision: --------    Serial number: 0000936835 Dataset Number: 5G0067v____ 1407
   Coding: 030100042B085900EF00067E9C0F00010001000000000000000000000000
   GVL: 01543C1000000600408C90000000CC0000000000000000000000000000000000
   ROD: EV_GatewLear_009.rod
   VCID: BB28D80F83ECAFD2CA9-80EE
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N  Labels: 3C8-959-537.CLB
   Serial number: 29180001409010038265
   Coding: 2DFFFF
   Subsystem 3 - Part No SW: 5Q0 915 181 C    HW: 5Q0 915 181 C
   Component: J367-BDMHella  H03 8042
   Serial number: 4970871303
131594 - Parallel Parking Assistance Control Module
          U104E 00 [00001001] - No communication
          [Timeout Knoten 0x0A / 76 - Steuergerät für Parklenkassistent]
                    Reset counter: 79
                    Mileage: 60775 km
                    Date: 2024.12.01
                    Time: 12:55:57
                    Terminal 30 power supply: 13.9 V
                    Terminal 15: On
131663 - No Communications with Front Sensor Package for Driver Assist. Systems
          U10E0 00 [00001001] - -
          [Timeout Knoten 0x4F / A5 - Frontsensorik für Fahrerassistenzsysteme]
                    Reset counter: 79
                    Mileage: 60775 km
                    Date: 2024.12.01
                    Time: 12:55:57
                    Terminal 15: On
131671 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [00001001] - -
          [Timeout Knoten 0x57 / 13 - Abstandsdistanzregelung]
                    Reset counter: 79
                    Mileage: 60775 km
                    Date: 2024.12.01
                    Time: 12:55:57
                    Terminal 15: On
   Part No SW: 5Q0 905 861     HW: 5Q0 905 861
   Component: ELV-MQBA      H06 0010
   Revision: 00000000    Serial number: 13000199855003
   Coding: 4900000000000000
   ASAM Dataset: EV_ELVMarquMQB 003008
   ROD: EV_ELVMarquMQB_003.rod
   VCID: F3B8302FEB3C2792D29-80A6
   Part No SW: 5Q0 959 593 A    HW: 5Q0 959 593
   Component: TSG FS        012 0006
   Serial number: 14091304081081 Dataset Number: 5G0222v____ 0042
   Coding: 003F1320D001048000001000
   ROD: EV_DCUDriveSideEWMAXKLO.rod
   VCID: BFD0AC1F97F4B3F2E61-80EA
   Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000002748375
   Coding: 0D0000
65608 - Lamp for Ambient Speaker Illumination
          B13C8 01 [00001001] - Electrical Failure
                    Fault Frequency: 14
                    Reset counter: 80
                    Mileage: 60775 km
                    Date: 2024.12.01
                    Time: 13:00:12
65650 - Turn Signal in Exterior Mirror
          B11FD 13 [00001001] - Open Circuit
                    Reset counter: 80
                    Mileage: 60775 km
                    Date: 2024.12.01
                    Time: 15:32:15
   Part No SW: 3Q0 909 144 D    HW: 3Q0 909 144 E
   Component: EPS_MQB_ZFLS  502 5011
   Dataset Number: 5G0074v____ 0235
   Coding: 9101
   ASAM Dataset: EV_SteerAssisMQB 009026
   ROD: EV_SteerAssisMQB_009_VW37.rod
   VCID: B338F02FABBC6792129-80E6
15873 - Steering angle sensor
          B1168 54 [00001001] - Missing Calibration / Basic Setting
                    Reset counter: 79
                    Mileage: 60775 km
                    Date: 2024.12.01
                    Time: 12:55:56
                    Motor status: 02
                    System status: Driving mode
                    Supply voltage: 14.00 V
                    Temperature: 56.0 °C
                    KFC: 3E
                    KFA: 00 01
                    Freeze frame conditions: 5B
                    uAdSensI_U5VFiltered_xdu16: 5.07820 V
                    uioUdNotFilt_xdu16: 13.94 V
                    uAdSensI_SwitchedKl30_xdu16: 13.93 V
                    ASC_CTRL_GET_ILWS_ERR_FLAGS: 14
19204 - Databus
          [ESP_02 Botschaft - SNA_Check]
                    Reset counter: 80
                    Mileage: 60775 km
                    Date: 2024.12.01
                    Time: 12:55:56
                    Motor status: 02
                    KFC: 4B
                    KFA: 00 04
                    Freeze frame conditions: 7F
                    uioUdNotFilt_xdu16: 14.09 V
                    uAdSensI_SwitchedKl30_xdu16: 14.08 V
21760 - Databus
          [HCA_01 Botschaft - CAN-Timeout]
                    Reset counter: 79
                    Mileage: 60775 km
                    Date: 2024.12.01
                    Time: 12:55:57
                    Motor status: 02
                    Supply voltage: 13.75 V
                    KFC: 55
                    KFA: 00 00
                    Freeze frame conditions: 5F
                    uioUdNotFilt_xdu16: 13.89 V
                    uAdSensI_SwitchedKl30_xdu16: 13.91 V
   Part No SW: 5Q0 959 592 A    HW: 5Q0 959 592
   Component: TSG BFS       012 0006
   Serial number: 12091302090551 Dataset Number: 5G0157v____ 0045
   Coding: 003F1120DE01048000801000
   ROD: EV_DCUPasseSideEWMAXKLO.rod
   VCID: BE2ED11B90FEBAFAED7-80EA
   Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000002707570
   Coding: 050000
   Part No SW: 7P6 907 357 A    HW: 7P6 907 357 A
   Revision: --------    Serial number: -------------- Dataset Number: 5G0036v____ 0015
   Coding: 029603000B010200
   ROD: EV_HeadlRegulVWAFS_VW37.rod
   VCID: BD2CD6179DF8A1E2F4D-80E8
   Subsystem 1 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H05 0012
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H05 0012
   Coding: 2E0000
13705992 - Databus
          [LWI_01: Fehlerwert im Signal LWI_Lenkradwinkel]
                    Reset counter: 80
                    Mileage: 60775 km
                    Date: 2024.12.01
                    Time: 12:55:56
Address A5: Frt Sens. Drv. Assist
   Component: SAS-GEN 2     H06 0011
   Serial number: 130726201022
End----------(Elapsed Time: 02:47, VBatt start/end: 13.8V/13.6V)-----------
What parts have been replaced?
That car is still huge mess with modules that "Cannot be reached" and various communication issues.
MaxxLetlotlo
Botswana
C?ID=522582
Nothing it just cut the cable for abs pump then join it now need code
Westbury, UK
With 14 "Cannot be reached"modules in your Auto-Scan I suspect that a missing ABS code might be the least of your problems :confused:
TTT
C?ID=547002
What do you mean cannot be reached? Engine, trans, abs read just fine to mention a few.
Westbury, UK
Look at the Installation List in the Auto-Scan - something is very confused...
TTT
C?ID=547002
I looked. Engine is readable. Reports fault codes. Have you seen?
Yes, but the Gateway is very confused about the state of this car, and since the Gateway routes traffic between the different data busses, whatever is causing this confusion absolutely needs to be addressed.
TTT
C?ID=547002
Maybe, but since gateway can interrogate engine ecu for fault codes, and report this back to vcds tells me that ecu is well reachable to both sides of the gateway.
Car is broken anyway, indeed.
