Wednesday,04,December,2024,10:54:09:43129
VCDS Version: 24.7.0.0 (x64) HEX-V2 CB: 0.4643.4
VIN: WVWZZZCD4RW155774 License Plate: AUTO ELECTRIC MK8
Mileage: 26802km-16653mi Repair Order:
Chassis Type: CD-VW38 (5WA)
Scan: 01 02 03 05 08 09 10 13 15 17 19 23 2B 3C 42 44 4B 52 5F 6C
75 A5 CA 8107 811E 811F 8120 8121 C002 C003
VIN: WVWZZZCD4RW155774 Mileage: 26802km-16653miles
CA-Sunroof -- Status: OK 0000
8107-Antenna -- Status: OK 0000
Address 01: Engine (J623-DTUA) Labels:. 05L-907-309-V1.clb
Part No SW: 05L 906 022 HQ HW: 05L 907 309 AA
Component: R4 2.0l TDI H80 2092
Revision: ECH80--- Dataset Number: V03935380VW 0001 CVN: F79557EA89980D2189980D2143FB2DAA
Coding: 012504320364050830080000000000000000000000000000
ASAM Dataset: EV_ECM20TDI01105L906022HQ 008001
ROD: EV_ECM20TDI01105L906022HR.rod
VCID: 7DA6002D6D7BE972345-8028
VINID: 9E69EAAAA4D41229C11451C71021783ADC
23765 - Control unit for information electronics 1
U1054 00 [00100100] - No Communication
[Information electronics control module 1No Communication]
Mileage: 26802 km
Date: 2024.12.03
Time: 16:15:44
Engine RPM: 855.00 /min
Normed load value: 27.1 %
Coolant temperature: 37 °C
Intake air temperature: 8 °C
Voltage terminal 30: 14.780 V
selected gear-Bits 0-7: 0
Readiness: 0 0 0 1 1
Part No SW: 0GC 906 555 Q HW: 0GC 300 047 L
Component: GSG DQ381 H06 4161
CVN: EF58E8C8
ASAM Dataset: EV_TCMDQ381062 001001
ROD: EV_TCMDQ381062_VW38.rod
VCID: 49CEA4FD693385D2C8D-801C
Subsystem 1 - Part No SW: 5WA 713 033 CD HW: 610 5
Component: ZSB_SB_AUTO H08 1034
Serial number: 20231103000089981072
Subsystem 2 - Part No SW: 5H0 713 059 R HW: 5H0 713 059 R
Component: ZSB_SB_Mono H01 0014
Serial number: 92478WKK00512
Subsystem 3 - Part No SW: 0GC 927 373 M HW: 0GC 927 373 M
Component: SMOP DQ381 H04 0001
Serial number: C7458810700005974827
41681 - Parking Lock
U01BA 00 [00101000] - No Communication
Mileage: 26802 km
Engine RPM: 0.00 /min
Coolant temperature: 215 °C
Clutch: primary stat: New
selected gear: GANG_1
Driving position: P
Engine torque: 200 Nm
Control Module temperature: 17 °C
Accelerator pedal position: 100.0 %
DTC memory status: 229
41683 - PARK Cannot be Engaged
P07E4 00 [00101000] - -
Mileage: 26802 km
Driving position: P
DTC memory status: 233
41689 - No Communications with Parking Brake Control Module
U0128 00 [00101000] - -
Mileage: 26802 km
Driving position: P
DTC memory status: 266
41732 - Gear Shift Control Module 2
U0291 00 [00101000] - No Communication
Mileage: 26802 km
Driving position: P
DTC memory status: 294
Address 03: ABS Brakes (J104) Labels: 5WA-614-517-V1.clb
Part No SW: 5WA 614 517 CF HW: 5WA 614 517 N
Component: ESC H13 0135
Serial number: 63163000013494 Dataset Number: V03935397FY 0001 CVN: BCB3764D
Coding: 34FC2C9042254271527EA00705C761866DB658554AC8670821BCB831018FF100002814
ASAM Dataset: EV_Brake1ESCEPBMQB37W 013058
ROD: EV_Brake1ESCEPBMQB37W_013_VW38.rod
VCID: 0E4457E150DDE2EADDF-805A SFD
Address 05: Acc/Start Auth. (J518) Labels: 5WA-959-436.clb
Part No SW: 5WA 959 436 Q HW: 5WA 959 436 Q
Component: Kessy IOBOX 100 0725
Serial number: --------------- Dataset Number: V03935341VY 0001
ASAM Dataset: EV_Kessy37w 004024
ROD: EV_Kessy37w_004_VW38.rod
VCID: 629C5351F4C5368A297-8036
Address 08: Auto HVAC (J979) Labels:* Redir Fail!
Part No SW: 5WA 907 007 AC HW: 5WA 907 007 AC
Component: AC Automat H31 3623
Serial number: --------------- Dataset Number: V03935418JG 0001
Coding: 002110119211120010000010101011110000131100200000000000000000
ASAM Dataset: EV_ACClimaPREVW38X 001102
ROD: EV_ACClimaPREVW38X_VW38.rod
VCID: 084861F932B9BCDA173-805C
Air quality sensor:
Subsystem 1 - Part No SW: 5Q0 907 659 D HW: 5Q0 907 659 D
Component: G238 _AQS H02 0003
Serial number: 00000000000002660249
Subsystem 2 - Part No SW: 11A 907 049 HW: 11A 907 049
Component: E265 KPH H02 0183
Serial number: G07S14.11.2300973565
Interior temperature sensor:
Subsystem 3 - Part No SW: 5WA 907 527 A HW: 5WA 907 527 A
Component: E857 H01 0103
Serial number: 00002071123122517518
B10CD 00 [00001001] - -
[Function limitation due to energy management 03]
Fault Frequency: 14
Mileage: 26802 km
Date: 2024.12.03
Time: 14:12:45
Voltage terminal 30: 13.7 V
CAN input signal(s) status-Transport mode: OFF
CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 1
CAN input signal(s) status-Back-up lamp: OFF
Blower reduction: No switch-off: no reduction
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 5WA 937 086 BS HW: 5WA 937 086 BA
Component: BCM37w_M1134 0183
Serial number: BXJ53F221123940 Dataset Number: V03935400FM 0001
ASAM Dataset: EV_BCM37w 007001
ROD: EV_BCM37w_007_VW38.rod
VCID: 23121655AB5F7F82621-8076 SFD
Subsystem 1 - Part No SW: 5H2 955 119 B HW: 5H2 955 119
Component: FWISCHER_MYJT 003 0061
Serial number: 907353F0402330000982
Subsystem 2 - Part No SW: 5Q0 955 547 C HW: 5Q0 955 547 C Labels: 5Q0-955-547.CLB
Component: RLHS 054 0206
Serial number: S6Y23M11D30H21M14S12
Subsystem 3 - Part No SW: 5H0 941 193 AN HW: 5H0 941 193 AN
Component: LiSi H06 0008
Serial number: 92471WJV000PQ
Subsystem 4 - Part No SW: 5H0 925 200 R HW: 5H0 925 200 R
Component: DiETa H07 0008
Serial number: 92471WKD002PW
Subsystem 5 - Part No SW: 5Q0 951 605 B HW: 5Q0 951 605 B
Component: Sirene, DWA 004 0007
Serial number: 00000000000003568854
Subsystem 6 - Part No SW: 5Q0 951 172 A HW: 5Q0 951 172 B
Component: Sensor, DWA 005 0403
Serial number: 0000000000000JQD7EXP
Subsystem 7 - Part No SW: 5H0 959 561 BQ HW: 5H0 959 561 BQ
Component: -VW----LINDA- 504 0831
Serial number: MW3LND04122300010253
Steering Column Switch:
Subsystem 8 - Part No SW: 5Q1 953 507 GB HW: 5Q1 953 549 F
Component: J527 SMLS MQB 005 0080
Serial number: 00000014112308491689
15400960 - Secure Onboard Communication
U14FD 00 [00101100] - Time Server not Available
[Sichere on-board Kommunikation: Zeitserver nicht verfügbar]
Reset counter: 39
Mileage: 26802 km
Date: 2024.12.03
Time: 15:39:17
Terminal 15 status: OFF
Terminal 50 status: OFF
Engine run: OFF
Status of brake lamp switch: discrete: OFF
Brake lamp switch via CAN: status: OFF
Voltage: 13.9 V
Outside temperature: 8.0 °C
Light switch position: automatic
15403264 - Release / Enable Active
B184C 00 [00101100] - -
[Freischaltung aktiv]
Reset counter: 39
Mileage: 26802 km
Date: 2024.12.03
Time: 16:16:15
Terminal 15 status: On
Engine run: On
Voltage: 14.9 V
Light switch position: Position lamps
Role of vehicle diagnostic to be protected: Basic
Type of vehicle diagnostic to be protected: Short: time-controlled
Status of vehicle diagnostic to be protected: SFD individualization feature set
Duration of vehicle diagnostic to be protected: 89 minutes
Address 10: Park/Steer Assist (J446) Labels:* None
Part No SW: 5R3 919 294 HW: 5R3 919 294
Component: PDC 08 Kanal H05 1550
Serial number: 000995460323331 Dataset Number: V03935375FW 0001
Coding: 0040014011
ASAM Dataset: EV_EPHVA18VW3800000 002036
ROD: EV_EPHVA18VW3800000_VW38.rod
VCID: 7CA00D297661E07A03B-8028
Address 13: Auto Dist. Reg (J428) Labels:* None
Part No SW: 5WA 907 572 C HW: 5WA 907 572 A
Component: ACC BOSCH MQB H45 0461
Dataset Number: V03935392FC 0001
Coding: 0D0318F7407740451247400800D040C4AE4020000000000000000000000000
ASAM Dataset: EV_FRONTRADARBOSCHVW380 004021
ROD: EV_FRONTRADARBOSCHVW380_004_VW38.rod
VCID: 4EC497E1905DA2EA9DF-801A
1127 - Databus
U1121 00 [00101000] - Missing Message
[FAULT_TIMEOUT_PSD_04]
Mileage: 26802 km
Date: 2024.12.03
Time: 16:15:44
1218 - Databus
[FAULT_TIMEOUT_PSD_05]
Mileage: 26802 km
Date: 2024.12.03
Time: 16:15:44
1219 - Databus
[FAULT_TIMEOUT_PSD_06]
Mileage: 26802 km
Date: 2024.12.03
Time: 16:15:44
Address 15: Airbags (J234) Labels:* 5WA-959-655.clb
Part No SW: 5WA 959 655 L HW: 5WA 959 655 L
Component: AirbagVW40 010 0636
Serial number: 000000003C0J2RA Dataset Number: V03935376EV 0001
Coding: 88CC008000F0C000000000000000000051540000205400004000F68000930065
ASAM Dataset: EV_AirbaVW40SMEVW38X 001032
ROD: EV_AirbaVW40SMEVW38X.rod
VCID: 60985959FAC9249A3F3-8034 SFD
Subsystem 1 - Part No SW: ----------- HW: 480 051 611 23
Component: SideSensor_Dr 000 0149
Serial number: 351000098C8FFE93A81Z
Subsystem 2 - Part No SW: ----------- HW: 480 051 611 23
Component: SideSensor_Pr 000 0149
Serial number: 3520000C4CC7221683D6
Subsystem 3 - Part No SW: ----------- HW: 480 002 510 23
Serial number: 357000000009D1A8FB62
Subsystem 4 - Part No SW: ----------- HW: 480 002 610 23
Serial number: 35800000000DDC051C6Z
Subsystem 5 - Part No SW: ----------- HW: 480 052 211 23
Component: FrontSensor_D 000 014A
Serial number: 3550000A0C8F6F93A57R
1054208 - Databus
[NWD: 0x3C0 Klemmen_Status_01 Timeout]
Reset counter: 65
Mileage: 26802 km
Date: 2024.12.02
Time: 18:47:49
Address 17: Instruments
Part No SW: 5WA 907 530 AB HW: 5WA 907 530 L
Component: GW2020 High 778 7105
Revision: -------- Serial number: 771049110023320 Dataset Number: V03935393AA 0001
Coding: 0000808D0700000000000000012303337301600900000300030100000001010000000000000000000000000000000000
GVL: 3D000000020840CC80008002C800104004004002004400000000000000000044
ASAM Dataset: EV_GatewMQB2020 006012
ROD: EV_GatewMQB2020_006_VW38.rod
VCID: 084861F932B9BCDA173-805C SFD
Generator:
Component: 5-00-14-00-04
Subsystem 2 - Part No SW: 5WA 915 181 C HW: 5WA 915 181 C
Component: J367-BDMHella H11 9080
Serial number: 2082873206
Subsystem 3 - Part No SW: 1EA 959 442 E HW: 1EA 959 442 E
Component: MFL H03 0219
Serial number: 17036218142922302252
Subsystem 4 - Part No SW: 5H0 959 542 N HW: 5H0 959 542 N
Component: KLR_JSS_1Zone 089 0023
Serial number: 3136188AA23321084802
8 Faults Found:
3145728 - Databus
U1124 00 [00101000] - Additional Installations Detected
[Multiple_plug_CAN_and_Ethernet]
2175091 - Control unit for information electronics 1
U1054 00 [00101000] - No Communication
[Information_electronics_control_module_1_no_communication]
1049254 - Ethernet Databus Branch 6
U1231 00 [00101111] - No Communication
[Ethernet_databus_no_communication_branch_6_/_port_7]
Mileage: 26802 km
Date: 2024.12.03
Time: 15:51:51
2498675 - Ethernet Module for Information Electronics 1
U1645 00 [00101111] - No Communication
[Information_electronics_control_module_1_no_communication_vlan]
Mileage: 26802 km
Date: 2024.12.03
Time: 15:52:01
8397569 - Quiescent Current
U1406 00 [00101000] - Too High
8397571 - LV Energy Management
B1802 F1 [00101111] - Warning Triggered
Fault Frequency: 25
Mileage: 26802 km
Date: 2024.12.03
Time: 15:50:13
23
B184C 00 [00101111] - -
[Unlock_protection_of_vehicle_diagnosis_active]
Mileage: 26802 km
Date: 2024.12.02
Time: 17:15:19
2232425 - Rear View Camera System Control Module
U104C 00 [00101000] - No communication
Address 23: Brake Booster
Address 2B: Steer. Col. Lock (J764) Labels:| 1EA-905-861.clb
Part No SW: 2Q0 905 861 B HW: 2Q0 905 861 B
Component: ELV-MQBB H10 0040
Serial number: 23000263243004 Dataset Number: V03935336NF 0001
Coding: 8800000000000000
ROD: EV_ELVMarqMQBA0_VW38.rod
VCID: 323CE311E4A5E60A997-8066
12666372 - Databus
[Timeout Message Gateway_73]
Reset counter: 65
Mileage: 26802 km
Date: 2024.12.03
Time: 15:39:17
Result lock conditions: invalid
ESCL locked: No
ESCL unlocked: Yes
Lock sensor: Not operated
Unlock sensor: operated
Error mode 1: not active
Error mode 2: not active
Clamp S: OFF
Clamp 15: OFF
Clamp 15 Status: valid
Remote Start: not active
Driver door: closed
Central locking locked external: unlocked
Central locking safed external: Vehicle not secured
Clamp Request: No
Request highside lock: No
HW highside lock: OFF
Highside unlock: No
Motor break: not active
Activation lowside unlock: OFF
Activation lowside lock: OFF
I2C overflow: No
I2C error pathflags: No
I2C resetinfo: No
I2C error cpu: No
I2C error rom: No
I2C error ram: No
I2C length failure: No
I2C error sda: No
I2C communication failure: i2c no comm failure
I2C state esp 10: i2c timeout
I2C cnd haco message: valid
Coco reset: No
Coco supply: On
Password IMS OK: Yes
Signature IMS OK: Yes
IMS responded: Yes
Positive authentification in current KL15 cycle: No
Lifestate: Immobilizer download obtained
Learn mode: Adapted
Authentication valid (T1): No
State of authentication state machine: WFS_AUTH_INIT_e
Vehicle speed: 0.00 km/h
UBat internal: 13.0 V
UMotorBridge: 7.2 V
Lock condition engine speed: Condition not met
Lock condition clamp S: Condition met
Lock condition clamp 15: Condition met
Lock condition E2E clamp status: Condition met
Lock condition timeout clamp status: Condition met
Lock condition vehicle speed: Condition met
Lock condition E2E vehicle speed: Condition not met
Lock condition timeout vehicle speed: Condition not met
Lock condition Mode1: Condition met
Lock condition drive readiness: Condition met
Lock condition selector lever position parking: Condition not met
Clamp enable ESCL: not enabled
Lock condition timeout distance pulse: Condition not met
Lock condition E2E distance pulse: Condition not met
Lock condition difference distance pulse: Condition not met
12666380 - Databus
[Timeout Message Diagnose_01]
Reset counter: 65
Mileage: 26802 km
Date: 2024.12.03
Time: 15:39:17
ESCL locked: No
ESCL unlocked: Yes
Clamp S: OFF
Clamp 15: OFF
Driver door: closed
Clamp Request: No
Highside unlock: No
I2C overflow: No
I2C resetinfo: No
I2C error cpu: No
I2C error rom: No
I2C error ram: No
I2C error sda: No
Coco reset: No
Coco supply: On
IMS responded: Yes
Learn mode: Adapted
UBat internal: 12.9 V
UMotorBridge: 7.2 V
Address 3C: Lane Change (J1086) Labels:* Redir Fail!
Part No SW: 2Q0 907 686 J HW: 2Q0 907 686 J
Component: HRE_Master H27 0288
Serial number: 00000634387860 Dataset Number: V03935373GS 0001
Coding: 9A9945D0
ASAM Dataset: EV_HREntryHellaGen3Mstr 001016
ROD: EV_HREntryHellaGen3Mstr_VW38.rod
VCID: 41DEBCDD51034D9210D-8014
Subsystem 1 - Part No SW: 2Q0 907 685 J HW: 2Q0 907 685 J
Component: HRE_Slave H27 0288
Serial number: 00000634436753
Lane change assistance display left:
Subsystem 2 - Part No SW: 5H1 949 145 HW: 5H1 949 145
Component: SWA LED VL H05 0005
Serial number: 00000000000016909060
Lane change assistance display right:
Subsystem 3 - Part No SW: 5H1 949 146 HW: 5H1 949 146
Component: SWA LED VR H05 0005
2228231 - Driver Assistance CAN
U1610 00 [00101000] - FAS CAN - Defective
Mileage: 26802 km
Date: 2024.12.03
Time: 15:32:35
Part No SW: 5Q0 959 593 L HW: 5Q0 959 593 F
Component: TSG FS004 0350
Serial number: YE007WK71498C Dataset Number: V03935387Z 0001
Coding: 003B1220D001040000001000
VCID: 4ACC9BF16C358ECAC17-801E
Subsystem 1 - Part No SW: 5Q0 959 407 G HW: 5Q0 959 163 C Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_DRV 007 0011
Serial number: 00000000000076066858
Coding: 0D0000
B1487 54 [00001001] - Missing Calibration / Basic Setting
Reset counter: 25
Mileage: 26802 km
Date: 2024.12.03
Time: 13:35:15
Address 44: Steering Assist (J500) Labels:| 5WA-907-14X-V1.clb
Part No SW: 5WA 907 145 G HW: 5WA 907 145 C
Component: BASGEN1MQB37 502 1040
Serial number: 03255171 Dataset Number: V03935358SR 0001
Coding: 0000000000000001000102010100010000000101010101
ROD: EV_SteerAssisBASGEN1MQB37_007_VW38.rod
Address 4B: Multifunc. Module
Part No SW: 5Q0 959 592 L HW: 5Q0 959 592 F
Component: TSG BFS004 0350
Serial number: YE007WK826198 Dataset Number: V03935386XH 0001
Coding: 003B1020DC01040000801000
Subsystem 1 - Part No SW: 5Q0 959 408 G HW: 5Q0 959 164 C Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_PSG 007 0011
Serial number: 00000000000075826455
Coding: 150000
Part No SW: 5H0 035 820 P HW: 5H0 035 820
Component: MU-O-ND-EU H61 1940
Serial number: WG8LGM171123000 Dataset Number: V03935454LF 0001
Coding: 23800008000000000000000000000000000000000000000000
ASAM Dataset: EV_MUOIMQB37w 001002
ROD: EV_MUOIMQB37w_001_VW38.rod
VCID: 2F3AEA65F797CBE2F69-807A SFD
Subsystem 1 - Part No SW: 5H0 919 605 B HW: 5H0 919 605 B
Component: ABT_W_10 H49 2103
Serial number: APUFP517112300010269
Subsystem 2 - Part No SW: V03 959 820 GB HW: -----------
Component: EUR 2023/24 --- 9085
1561 - Predictive Route Data
B1630 02 [00001001] - Signal Failure
Mileage: 26802 km
Date: 2024.12.04
Time: 10:41:25
Voltage terminal 30: 13.9 V
0021 - Functional Limitation due to Energy Management
[Function restriction via shutoff stage Q2]
Fault Priority: 9
Mileage: 26802 km
Date: 2024.12.04
Time: 10:41:25
Address 6C: Back-up Cam. (J772) Labels:| 5WA-980-556.clb
Part No SW: 5WA 980 556 B HW: 5WA 980 556 B
Component: RV eCompact H23 0254
Serial number: FCLK20240421000 Dataset Number: 000135342HF 0001
Coding: 02038004E43000
ASAM Dataset: EV_CamSysRVCCompaFicos 009020
ROD: EV_CamSysRVCCompaFicos_009_VW38.rod
VCID: 50F889998A69B41A8F3-8004
10489856 - No Basic Setting
B2010 00 [00101111] - -
[System not calibrated]
Part No SW: 5WA 035 284 F HW: 5WA 035 284 C
Component: OCU3HMQB37W H14 0144
Serial number: 0000000307VIBBG Dataset Number: V03935379BN 0001
Coding: 023800109068AC209405460071102607
ASAM Dataset: EV_OCU3HMQB37W 002012
ROD: EV_OCU3HMQB37W_002_VW38.rod
VCID: 49CEA4FD693385D2C8D-801C SFD
1191168 - Ethernet Databus Branch 2
U122D 00 [00001001] - No Communication
Mileage: 26802 km
Date: 2024.12.04
Time: 10:04:29
Ethernet counter checksum error: branch 2: 0
Ethernet counter connection interruptions: branch 2: 0
0080 - Databus
[Ethernet Databus missing message - Transceiverbox]
Mileage: 26802 km
Date: 2024.12.03
Time: 16:00:24
Voltage terminal 30: 13.8 V
12664832 - Databus
[Central Electrics: No Communication]
13633792 - Databus
[Gateway: no communication]
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 2Q0-980-653.clb
Part No SW: 5WA 980 653 D HW: 5WA 980 653
Component: MQB MFK 3.0 H12 3405
Serial number: EB7590904232920 Dataset Number: V03935412E 0001
Coding: 00000908116C4040109E40001030008000418000000000000000000000000000
ASAM Dataset: EV_MFK3ValeoMQB 005055
ROD: EV_MFK3ValeoMQB_005_VW38.rod
1126468 - Databus
[PSD_04_PSD_Vorgaenger_Segment_ID]
Mileage: 26802 km
Date: 2024.12.03
Time: 12:59:22
1126467 - Databus
[PSD_04_PSD_Segment_ID]
Mileage: 26802 km
Date: 2024.12.03
Time: 12:59:22
1122665 - Databus
[Timeout_PSD_05]
Mileage: 26802 km
Date: 2024.12.03
Time: 16:15:44
1122664 - Databus
[TIMEOUT_PSD_04]
Mileage: 26802 km
Date: 2024.12.03
Time: 16:15:44
1122672 - Databus
[Timeout_PSD_06]
Mileage: 26802 km
Date: 2024.12.03
Time: 16:15:44
Part No SW: 4K1 907 594 CB HW: 4K1 907 594
Component: SAD_STG_1 006 0040
Dataset Number: V03935402SS 0001
Coding: 508000738001
VCID: 77AA12054F47C3226E9-8022
Address 8107: Antenna
Address 811E: Burglary Protection FL
Address 811F: Burglary Protection FR
Address 8120: Burglary Protection RL
Address 8121: Burglary Protection RR
End----------(Elapsed Time: 02:20, VBatt start/end: 13.6V/13.6V)-----------
