2006 vw jetta tdi bew automatic dsg. camshaft sensor was bad replaced but still have codes for it. all wiring seems good from testing. the main issue is the transmission is flying into neutral when you accelerate. the 18097 code i know could be a ton of things. when this happens you can cut the car off and turn it back on and it takes gear fine again. also unable to perform basic setting for steering angle sensor. if someone could highlight the exact steps for this operation i would appreciate it and aslo what word address should i go in to perform it and security access code
Tuesday,03,December,2024,11:13:42:00549
VCDS Version: 24.7.1.0 (x64) HEX-NET2 CB: 0.4643.5
VIN: 3VWST71K46M784467 License Plate:
Mileage: 357210km-221960mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 52 56 62 72 7D
VIN: 3VWST71K46M784467 Mileage: 357210km-221960miles
7D-Aux. Heat -- Status: Malfunction 0010
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 03G 906 016 AC HW: 028 101 223 9
Component: R4 1,9L EDC G000DG 7551
Revision: --H02--- Serial number: VWZ7Z0F3428767
Coding: 0050078
Shop #: WSC 00066 000 00000
VCID: 649ADFAD825B9D7ADB3-8030
VINID: 0E69E390705B1067472041061C50EA28CF
000833 - Camshaft Position Sensor (G40)
P0341 - 000 - Implausible Signal
Fault Status: 01110000
Mileage: 357215 km
Time: 00:20:25
RPM: 798 /min
Voltage: 14.21 V
Bin. Bits: 00101000
Idle Stabilization: 1.5 KW
(no units): 48.0
Component: GSG DSG AG6 521 4019
Revision: 05652104 Serial number: 00001401171953
Shop #: WSC 02069 000 90108
VCID: 147ACF6D127BADFAEB3-8040
18097 - Powertrain Data Bus
P1689 - 000 - Implausible Message from Elect. Load Controller
Mileage: 357215 km
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.clb
Part No SW: 1K0 907 379 AA HW: 1K0 907 379 AA
Revision: 00H13001
Coding: 0021122
VCID: 71B4A6F94DA938D2A05-8024
Part No: 1K0 820 047 EC
Component: Climatic PQ35 090 0505
VCID: 6984CE996579C012E85-803C
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-M.lbl
Part No SW: 3C0 937 049 D HW: 3C0 937 049 D
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000000275806
Coding: 14018E234004150000140000001400000008730B5C
Shop #: WSC 25049 444 54636
VCID: 2A067195A0FF0B0A21F-807E
Subsystem 1 - Part No: 1K1 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer VW350 013 0402
Coding: 00063445
Shop #: WSC 25049
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 188
Mileage: 357215 km
Voltage: 14.00 V
Address 0F: Digital Radio Labels: 8E0-035-593-XM.lbl
Part No SW: 8E0 035 593 E HW: 8E0 035 593 E
Component: SDAR XM H03 0080
Revision: 00000000 Serial number: AUZ4Z7F3043950
VCID: 2B087491AF051202DA9-807E
Reset counter: 187
Mileage: 357215 km
Time: 00:20:26
Part No SW: 1K0 909 605 P HW: 1K0 909 605 P
Component: 39 AIRBAG VW8R 032 7900
Revision: 03032000 Serial number: 0038FD04S41X
Coding: 0013113
VCID: 39245ED95559B092585-806C
Subsystem 1 - Part No: 1K0 959 339 E
Component: BF-Gewichtsens. 006 0005
Subsystem 2 - Serial number: 6332MSME0E465A3BO
Subsystem 3 - Serial number: 6342MSME0E475D24L
Subsystem 4 - Serial number: 6351HSME092E49038
Subsystem 5 - Serial number: 6361HSME09232250Y
Subsystem 6 - Serial number: 63727SME08795B7AH
Subsystem 7 - Serial number: 63827SME08794C157
Part No SW: 1K0 953 549 AH HW: 1K0 953 549 AH
Component: J0527 034 0070
Coding: 0010021
VCID: 78A29BDD2ED3699A67B-802C
Part No: 1K0 920 953 D
Component: KOMBIINSTRUMENT 3HL 4312
Coding: 0023203
Shop #: WSC 25049 067 57207
VCID: 2C0A778DAA0B153AD33-8078
Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 28001061091493
Coding: 3F3F0B60071002
Component: IMMO 3HL 4312
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2377
Coding: 0001269
VCID: 363E55E564475FEAB57-8062
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K1 909 144 K
Component: EPS_ZFLS Kl.5 D06 1701
VCID: 33386CF177354AC2929-8066
02546 - Steering Limit Stop
Mileage: 7200 km
Temperature: 18.0 C
Voltage: 14.10 V
Voltage: 14.00 V
Address 46: Central Conv. Labels:. 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AF
Component: KSG 0401
Coding: 137803281B09058F880F048051A0
VCID: 74BAAFED32BB0DFA4B3-8020
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0001269
VCID: 372058E1634DA6E2AE1-8062
Address 56: Radio
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 D
Component: Tuer-SG 021 2434
Coding: 0000144
VCID: 313466F98D2978D2E05-8064
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 D
Coding: 0000144
VCID: 323669F5882F43CA99F-8066
Component: PTC-Element 0404
VCID: 2D0C7A8991111C32C4D-8078
00361 - Heater Element for Auxiliary Heater (Z35)
014 - Defective
End----(Elapsed Time: 01:24, VBatt start/end: 12.1V/
