Advice on ACC Retrofit (2019 Audi A3)
Neilios
C?ID=192526
Hi all I was wondering if anyone once be able to offer some advice? I’ve got a few retrofits in progress (tv, acc, blind spot assist) the car is booked in for component production removal on the units next week. However the other day I noticed that steering wheel electrics (diag 16) is missing from my autoscan.
The cars a late 2019 and I understand that Audi probably removed it for various reasons. I’ve since got the correct unit for my car however I was wondering if the steering wheel airbag harness was the same? The last thing I want to do is install it and the bag go off.
Tuesday,26,November,2024,15:14:38:61128
VCDS Version: 24.7.1.0  HEX-NET2 CB: 0.4643.5
Dealer/Shop Name: Wols
Workshop Code: 210 00115 000123
VIN: WAUZZZ8V7KA069747   License Plate: N17WOL
Mileage: 47645km-29605mi   Repair Order: Pre CP removal
Chassis Type: 8V-AU37 (3Q0)
Scan: 01 02 03 08 09 10 15 17 19 22 29 39 42 44 47 4B 52 5F 65 6C
          A9 BB BC D6 D7
VIN: WAUZZZ8V7KA069747   Mileage: 47645km-29605miles
Address 01: Engine (J623-DNUE)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 259 N    HW: 06K 907 425 J
   Component: 2.0l R4 TFSI  H13 0001
   Revision: --H13---    CVN: 015AEF11
   Coding: 0A2540322426010B2004
   Shop #: WSC 00115 210 00123
   ASAM Dataset: EV_ECM20TFS0208V0906259N 001002
   ROD: EV_ECM20TFS0208V0906259N_AU37.rod
   VCID: 4BC80BEE234BFCD2FA9-801E
   VINID: 9D196AAAA2261DB4401891C41CA1159B1D
17186 - Databus
          U1123 00 [00100111] - Received Error Message
                    Mileage: 47645 km
                    Date: 2024.11.26
                    Time: 15:11:04
                    Engine RPM: 793.75 /min
                    Normed load value: 13.7 %
                    Coolant temperature: 97 �C
                    Intake air temperature: 50 �C
                    Voltage terminal 30: 14.179 V
                    ACC variants (coding): CCS
                    CCS Switch: CCS operating unit
                    Cruise control switch actuation-Main switch: Not operated
                    Cruise control switch actuation-Set: Not operated
                    Cruise control switch actuation-Resume: Not operated
                    Cruise control switch actuation-Accelerate: Not operated
                    Cruise control switch actuation-DELAY: Not operated
                    Cruise control switch actuation-Cancel: Not operated
                    Cruise control switch actuation-Main switch hardware: Not operated
                    Cruise control switch actuation-Limit button: Not operated
                    Cruise control switch actuation-Main switch CAN: Not operated
                    Cruise control switch actuation-Large increment: Not operated
                    ACC variants: ACC
                    Engine: operating status: IS
Readiness: 1010 0001
   Part No SW: 0GC 300 014 B    HW: 0GC 927 711 H
   Component: GSG DQ381     H06 2404
   Revision: 00H06V07    CVN: 3C9C978E
   ROD: EV_TCMDQ381061.rod
   VCID: 241A8052EE5513AA1B3-8070
   No subsystems:
   Part No SW: 8V0 614 517 D    HW: 8V0 614 517 C
   Component: ESC           H25 0640
   Revision: 00000000    Serial number: 60439000000545 Dataset Number: 8V0909504Z  0056
   Coding: 329C938D549F23B28B980B684098694CC92AC4D1D0029677024150040208420000000012121212B835351919323200
   Shop #: WSC 06314 790 00021
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 037008
   ROD: EV_Brake1UDSContiMK100IPB_037_AU37.rod
   VCID: 3A265E2A7CD1755A51F-806E
   Part No SW: 8V0 820 043 AF    HW: 8V0 820 043 AF
   Component: AC Automat    H03 0150
   Revision: 20003000    Serial number: 00000001753835 Dataset Number: 8V0909862C
   Coding: 03100004000000011000000000001100
   ASAM Dataset: EV_AirCondiFrontVaAU37X 008025
   VCID: 76BE8A1A0849D13A757-8022
   Humidity sensor: exterior:
   Subsystem 1 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Serial number: F771139900PAG0MUFU03
   Part No SW: 5Q0 937 084 DC    HW: 5Q0 937 084 CF
   Component: BCM MQBAB M+  H38 0273
   Serial number: 00001905300489 Dataset Number: 8V0909514AB 0026
   ROD: EV_BCMBOSCH_019_VW37.rod
   VCID: 7CAA983236658B6A033-8028
   Subsystem 1 - Part No SW: 8V2 955 119 A    HW: 8V2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 190118  043 0580
   Serial number:         190124180008
   Coding: 0A47F7
   Serial number: 21801367X81A955547A0
   Coding: 00006C
   Subsystem 3 - Part No SW: 8V0 941 531 AR    HW: 8V0 941 531 AR
   Component: E1 - LDS MQB  H06 0032
   Serial number: 04 12 2018  20000367
   Serial number: 000000000ZY190152HTL
   Serial number: 00000000000046534691
   Steering Column Switch:
   Subsystem 6 - Part No SW: 82A 953 521 A    HW: 5Q1 953 549
   Component: J527 SMLS MQB  004 0060
   Serial number: 00000021021904400213
797955 - Steering Column Control Module
          B105D 07 [00001001] - Mechanical Failure
          [Schaltermodul Lenks�ule (SMLS)->mechanischer Fehler]
                    Reset counter: 230
                    Mileage: 47520 km
                    Date: 2024.11.20
                    Time: 16:29:29
                    Terminal 15 status: On
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Position lamps: Not operated
                    Low beam: Not operated
                    Voltage: 14.7 V
                    Outside temperature: 4.5 �C
   Part No SW: 5QA 919 298 D    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0050
   Serial number: 000308417319120 Dataset Number: V03935259QF 0007
   Coding: 0270161051
   ASAM Dataset: EV_EPHVA2CAU3700000 009041
   ROD: EV_EPHVA2CAU3700000_VW41.rod
   VCID: 51F41986C167D602805-8004
   Part No SW: 5Q0 959 655 BT    HW: 5Q0 959 655 BT
   Component: AirbagVW21    007 0403
   Serial number: 003FNR51WDXN Dataset Number: 8V0909602AC 0002
   Coding: 98CCC0000C0000005C5400CA00C8000000C5
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
   VCID: 1378D38E3BFB6412F29-8046
   Subsystem 1 - Part No SW: -----------    HW: 480 001 902 19
   Serial number: 3570000000069C28A93V
   Subsystem 2 - Part No SW: -----------    HW: 480 001 902 19
   Serial number: 35800000000CEBCC4836
   Subsystem 3 - Part No SW: -----------    HW: 480 402 002 19
   Component: SideSensor_Dr  003 6149
   Serial number: 3510001B32E5A556371$
   Subsystem 4 - Part No SW: -----------    HW: 480 402 002 19
   Component: SideSensor_Pr  003 6149
   Serial number: 3520001C52E838F2864C
   Subsystem 5 - Part No SW: -----------    HW: 480 400 702 19
   Serial number: 3550001022C00983981P
   Subsystem 6 - Part No SW: -----------    HW: 480 401 402 19
   Component: PedP_Sensor_D  003 6149
   Serial number: 2280001BD2EABE45555Q
   Subsystem 7 - Part No SW: -----------    HW: 480 401 402 19
   Component: PedP_Sensor_P  003 6149
   Serial number: 2290001BD2EABE43D74Y
   Subsystem 8 - Part No SW: -----------    HW: 480 000 602 19
   Serial number: I0M00000000FD9D8C83Z
   Subsystem 9 - Part No SW: -----------    HW: 480 000 602 19
   Serial number: I0N000000002BA0DF73G
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI2
   Part No SW: 8V0 920 790 C    HW: 8V0 920 790 C
   Component: FBenRDW       H19 0109
   Dataset Number: 8V0909525AC 0023
   Coding: 24AD08C22A9006000101E8841000000000000000
   ASAM Dataset: EV_DashBoardFPKAU37X 001032
   ROD: EV_DashBoardFPKAU37X.rod
   VCID: 3C2A583276E54B6A433-8068
   Component: GW MQB High   442 4367
   Revision: --------    Serial number: 0009156029 Dataset Number: 8V0909515R  0101
   Coding: 030100043F085A005B00826A3C0B00000001010000000000000000000000
   GVL: 01CE3C1000000000400C00000002C80000000000000200000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 6E8EA27A7019E9FABD7-803A
   Generator:
   Component: 1-01-13-01-04
   Subsystem 2 - Part No SW: 8W0 951 523 F    HW: 8W0 951 523 F
   Component: J453 MFL  H04 0004
   Serial number: 20190215002252 30040
   Serial number: 758860039119012915AD
   Part No SW: 0CQ 907 554 K    HW: 0CQ 525 130
   Component: Haldex4Motion H55 7762
   Serial number: HA1-00025.01.19 Dataset Number: v1260x015G0 0000
   Coding: 0001
   ROD: EV_AllWheelContrHA1VW37X_002_VW36.rod
   VCID: 4DCC05F6DD5FF2E2E4D-8018
Address 29: Left Light (J1018)       Labels: 8S0-907-397.clb
   Part No SW: 8S0 907 397 D    HW: 8S0 907 397 D
   Component: LCM_MQB       H07 0022
   Dataset Number: 8V0909519D  0006
   VCID: 42D626CA14013D9A09F-8016
Address 39: Right Light (J1023)       Labels: 8S0-907-397.clb
   Dataset Number: 8V0909520D  0006
   Part No SW: 5Q0 959 593 F    HW: 5Q0 959 593 F
   Component: TSG FS001 0287
   Serial number: YE007SB814895 Dataset Number: 8V0909872N  0061
   Coding: 005E8A205001000000001002
   VCID: 44DA20D20E1533AA3B3-8010
   Part No SW: 3Q0 909 144 M    HW: 3Q0 909 144 L
   Dataset Number: 8V0909852AA 0001
   Coding: 831F0000
   ROD: EV_SteerAssisMQB_015.rod
   Part No SW: 81A 035 466 B    HW: 81A 035 466
   Component: MIB2_amp_P_A3 H10 0440
   Revision: 00000001    Serial number: AUZ8ZAJ5F025SF2 Dataset Number: 8V0909510G  0007
   Coding: 0173030000AAAA2AAA0000010000
   ASAM Dataset: EV_AMPMst16C9Gen2ALPI 001002
   ROD: EV_AMPMst16C9Gen2ALPI_AU37.rod
   Component: FCM MQB Low   002 0345
   Serial number: 15021910523569 Dataset Number: 8V0909583B  0009
   Coding: 000000050900147600102B03020000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 002006
   ROD: EV_MultiModulContiVW48X_002_VW41.rod
   VCID: 353C4D1655CF9A22BCD-8060
   Part No SW: 5Q0 959 592 F    HW: 5Q0 959 592 F
   Component: TSG BFS001 0287
   Serial number: YE007SB900617 Dataset Number: 8V0909873N  0061
   Coding: 005E82205C01000000001002
   VCID: 43D823CE0B1B3492029-8016
Address 5F: Information Electr. (J794)       Labels:* 8V0-035-MIB-HGH2.clb
   Part No SW: 8V1 035 035 C    HW: 8V1 035 035 C
   Component: MU-P-LND-EU   055 1326
   Serial number: A698B0KS035376 Dataset Number: 8V2909545T  0032
   Coding: 017353010000000011111102000A00312F0027E701700100DE
   VCID: 3236760AA4A18D1A99F-8066
   Subsystem 1 - Part No SW: V03 959 802 TK    HW: -----------
   Component: ECE 2021  --- 0189
   Multimedia System 1:
   Component: DU High  H49 0014
   Serial number: AUZ8Z9J1Y0G5U9
   Subsystem 3 - Part No SW: 8V0 919 614 BJ    HW: 8V0 919 614 BJ
   Component: ControlUnit_H  H85 0855
   Serial number: ALJAL116111800050476
   Compact disc data bank:
   Component: Gracenote2  --- 1017
0007 - Connection between Antenna Amp 1 for Radio and Antenna
          B1272 13 [00001001] - Open Circuit
                    Reset counter: 230
                    Mileage: 47520 km
                    Date: 2024.11.20
                    Time: 16:28:32
                    Voltage terminal 30: 14.9 V
                    Status of antenna 1 for radio-Antenna current: 0 mA
                    Status of antenna 1 for radio-Connection between radio and antenna amplifier: electrically OK
                    Status of antenna 1 for radio-Connection between antenna amplifier and antenna: Open circuit
                    Status of antenna 1 for radio-Reception level antenna 1: 255 dB�V
Address 65: Tire Pressure (J502)       Labels: 4M0-907-273.clb
   Part No SW: 8S0 907 273     HW: 4M0 907 273 B
   Component: RDKHUFAU736   H05 0002
   Serial number: 30000000011688 Dataset Number: 8V0909850A  0003
   ROD: EV_RDKHUFAU736_AU37.rod
   VCID: 77A0871E0F43A8326E1-8022
   Component: RVC Compact   H15 0231
   Coding: 0273010122000003400040
   ROD: EV_CamSysRVRVCPANAMQBAB_006_VW48.rod
   VCID: 3924412679D77E42585-806C
10489856 - No Basic Setting
          B2010 00 [00001001] - -
                    Reset counter: 230
                    Mileage: 47520 km
                    Date: 2024.11.20
                    Time: 16:28:29
                    passive
   Part No SW: 8V0 907 159 A    HW: 4H0 907 159 A
   Serial number: 190112200118
   VCID: 3E2E523A60F9597A6D7-806A
   Part No SW: 8W1 959 595 D    HW: 8W1 959 595 D
   Component: TSG HFS003 0189
   Serial number: YE007SB42118A Dataset Number: 8V0909897J  0060
   Coding: 004C82204001000000001002
   VCID: 4ECE02FAD059C9FA9D7-801A
   Component: TSG HBFS003 0189
   Serial number: YE007SB41588A Dataset Number: 8V0909896J  0060
   Coding: 004E82204001000000001002
   Dataset Number: 8V0909471E  0008
   VCID: 1760A79E2F0348328E1-8042
   Dataset Number: 8V0909472E  0008
In your car (like many other newer ones), it's a sub-system of the BCM at address 09 rather than an individually addressable module:
Neilios
C?ID=192526
Ah thanks I missed that. I’m guessing though I’d have to add it for the acc as I found 5Q0953549E (which is the unit I’ve found to install) is applicable to later cars again I’m assuming for acc. But I’m not sure
downtime
Finland
C?ID=280813
^ Sorry was unclear that what are you needing or not needing to install?
If you have conventional cruise, then it's just swapping the stalks to one with ACC distance setting. If no conventional cruise, then on top of that, you need to pull one wire from steering column electronics to engine ECU
Neilios
C?ID=192526
Sorry I should have said in the original post. My car currently has conventional cruise control. I fitted the stalks for the one with acc distance setting. Then I the errors for “steering column electrics mechanical failure”
However I’ve no coded anything for acc yet I was thrown by 16 not being there. I miss the pre mqb days were it was a lot easier haha
downtime
Finland
C?ID=280813
The reason for error is that the LIN messages are different from ACC stalk. It will go away when you code ACC and have ACC running properly.
