VW T6 halogen rear fuel foglight coding / LED Canbus cancelling
Maligator
C?ID=508928
As above,
Can anyone tell me the security access code and what to change to enable duel rear foglights on a 2017 VW transporter please?
Is it also possible to cancel the Canbus error for LED headlight bulbs?
Monday,02,December,2024,08:50:24:34356
VCDS Version: 24.7.0.0 (x64)  HEX-V2 CB: 0.4643.4
VIN: WV1ZZZ7HZJX007956   License Plate: T6
Mileage: 96760km-60123mi   Repair Order:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 09 13 15 17 19 25 5F 61
VIN: WV1ZZZ7HZJX007956   Mileage: 96760km-60123miles
Address 01: Engine (2D2D2-CXGA)       Labels:. 04L-907-309-V2.clb
   Part No SW: 04L 906 056 JS    HW: 04L 907 445
   Component: R4 2.0l TDI   H02 4044
   Revision: 23002001
   Coding: 00114010430401090000
   Shop #: WSC 35110 790 50316
   ASAM Dataset: EV_ECM20TDI03004L906056JS 004004
   ROD: EV_ECM20TDI03004L906056JS_004.rod
   VCID: 074A99115FA557721E9-8052
   VINID: 9E606AAAA1D8A9AA0000724518BBAEF30E
Readiness: N/A
   Revision: 00000000    Serial number: 62307000000698
   Coding: 517E4098256284858A7E027BA48821E679F100
   VCID: 3FDA41F147F5DFB2669-806A
   Serial number: 29061713470737
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EA4FCF5007F16BA2DF-802A
   Part No SW: 7E0 937 090 C    HW: 7E0 937 090 C
   Component: BCM PQ25 Max4 H82 0752
   Revision: B9082001    Serial number: 4000 228170883
   Coding: A0A4303A0A613431922049742C2B8C500F00708F60464D60330400220800
   Shop #: WSC 35110 377 08192
   VCID: 2B0205A1A30D5312DA1-807E
   Subsystem 1 - Part No SW: 7E0 959 801 P    HW: 7E0 959 801 P  Labels: 7E0-959-80X-V2.CLB
   Component: J386__TSG_FT  003 0653
   Serial number: KU0KU014081772260740
   Coding: 1400B0
   Subsystem 2 - Part No SW: 7E0 959 802 P    HW: 7E0 959 802 P  Labels: 7E0-959-80X-V2.CLB
   Component: J387__TSG_BT  003 0653
   Serial number: KU0KU014081772261874
   Coding: 0400A0
   Subsystem 3 - Part No: 7E1 951 172
   Subsystem 5 - Part No: 7E1 951 172
03303 - Response Closing Status of Rear Left Door
                    Fault Status: 01101000
                    Fault Frequency: 15
                    Reset counter: 89
                    Mileage: 96731 km
                    Date: 2017.14.29
                    Time: 15:22:57
                    Fault Status: 00101010
                    Reset counter: 129
                    Mileage: 96733 km
                    Date: 2017.14.29
                    Time: 18:24:22
01495 - Bulb for High-Beams; Left (M30)
                    Fault Status: 01101010
                    Reset counter: 83
                    Mileage: 96733 km
                    Date: 2017.14.29
                    Time: 18:24:21
                    Reset counter: 88
                    Mileage: 96760 km
                    Date: 2018.14.00
                    Time: 09:41:30
   Part No SW: 7N0 907 572 C    HW: 7E0 907 572
   Serial number: 0708170452A8F5
   Coding: 00004000FE1779
   ROD: EV_ACCBEGVW361.rod
   VCID: 363424D568CF1EFAB5F-8062
   Part No SW: 7E0 959 655 G    HW: 7E0 959 655 G
   Component: VW10Airbag021 H08 0018
   Revision: --------    Serial number: 003V3005U9MH Dataset Number: 7E0003V____ 0905
   Coding: 000000000000000000000000000000003231
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 3A2C30E55CD7FA9A517-806E
   Part No SW: 7E0 920 970 S    HW: 7E0 920 970 S
   Component: KOMBI         H03 1107
   Coding: 450B010300
   Part No SW: 7E0 909 901     HW: 7E0 937 090 C
   Component: GW-K-CAN TP20 H82 0752
   Revision: B9082001
   Coding: 042305
   VCID: 6888BAAD727BB80AF73-803C
   Component: IMMO          H03 1107
   VCID: 6A8CC0A56CF78A1AE17-803E
   Part No SW: 1K8 035 150 L    HW: 1K8 035 150 L
   Component: MU-E-D-ER     056 7205
   Serial number: 11081700010306 Dataset Number: V03935266VJ 0001
   Coding: 065700003C00000041111101008000001F0000C60000010001
   ROD: EV_MUEnt4CGen2LGE_VW32.rod
   VCID: 2E040CB5909F263AFDF-807A
   Part No SW: 7E0 907 534     HW: 7E0 937 090 C
   Component: Batt.regelung H82 0752
   Coding: 030B7A73
   Shop #: WSC 50538 004 1048576
   Subsystem 1 - Part No SW: 7E0 915 181 K    HW: 7E0 915 181 K
   Serial number: 758857000017081502F6
End----(Elapsed Time: 01:41, VBatt start/end: 11.5V/11.5V. VIgn 11.4V)-----
I don't know if it applies to yours, we had a 2021 in the other week and the aftermarket (illegal) headlights were causing problems and when I went into coding there was nothing available and even ODIS said no so I converted it back to Halogen.
Westbury, UK
Your BCM is a PQ25 which IIRC does not have the ability to be configured to monitor LED bulbs, so I think you'll have to change back to Halogen - unless someone knows otherwise?
VWT6
Finland
C?ID=295527
Should be. It's documented in VCDS: 09-Central Electrics > Coding > Navigate to Byte 16...
Cool, but Byte 16, Bit 4 (Lamp Diagnostics for Low Beam active) is already un-checked in his coding.
VWT6
Finland
C?ID=295527
True it's unchecked - as are other T6 factory codings with halogen bulbs with active lamp diagnostics.
The description/coding is a bit confusing - thus the bit needs to be checked ("1") to deactivate the diagnostics :D
However, the coding logic for other lamp diagnostics in the other bytes is the opposite :facepalm:
The BCM picks that up as a fault and with incandescent bulbs you risk burning out the circuit.
