2016 Golf R MK7
VCDS 15.7.1, while in the Engine module, long coding - Byte 9 disabled the 2nd bit (exhaust flaps installed) receiving the below error from VCDS "Coding Rejected. Error 22: Conditions not correct or request sequence error"
I've tried turning off the car a few times and back on to no avail - same error every time.
The debug log shows each attempt but doesn't appear to log any additional information on the error I'm seeing.
Any assistance in this area will be greatly appreciated.
Picture illustrating the error:
Last full VCDS scan:
Address 01:8V0 906 259 H recoded (Long Coding) from 091900122426000E3004 to 091900122426000E3000 (01357/011/00200) Tuesday,24,November,2015,21:50:32:41740
Address 01:8V0 906 259 H recoded (Long Coding) from 091900122426000E3004 to 091900122426000E3000 (01357/011/00200) Tuesday,24,November,2015,21:50:53:41740
Address 01:8V0 906 259 H recoded (Long Coding) from 091900122426000E3004 to 091900122426000E3000 (01357/011/00200) Tuesday,24,November,2015,21:52:27:41740
Address 01:8V0 906 259 H recoded (Long Coding) from 091900122426000E3004 to 091900122426000E3000 (01357/011/00200) Tuesday,24,November,2015,21:53:18:41740
Address 01:8V0 906 259 H recoded (Long Coding) from 091900122426000E3004 to 091900122426000E3000 (01357/011/00200) Tuesday,24,November,2015,21:54:36:41740
Saturday,21,November,2015,20:34:09:41740
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
VIN: WVWUF7AU7GWXXXXXX License Plate: XXX
Mileage: 1306km-811mi Repair Order:
Chassis Type: AU (5Q0)
Scan: 01 03 05 08 09 14 15 16 17 19 22 2B 42 44 52 55 5F 75 A9
VIN: WVWUF7AU7GWXXXXXX Mileage: 1306km-811miles
Address 01: Engine (J623-CYFB) Labels: 06K-907-425-V1.clb
Part No SW: 8V0 906 259 H HW: 06K 907 425 E
Component: 2.0l R4 TFSI H13 0002
Revision: --H13---
Coding: 091900122426000E3004
ASAM Dataset: EV_ECM20TFS0208V0906259H 001003
ROD: EV_ECM20TFS0208V0906259H_VW37.rod
VCID: 45AFAA3FC402EA162E-8010
Part No SW: 3Q0 907 379 AA HW: 3Q0 907 379 F
Component: ESC H42 0623
Revision: 00000000 Serial number: 62075000000318
Coding: 01FA6BA15428096E057E030841C36980D62A90A0C08296B7004000D4C006
ROD: EV_Brake1UDSContiMK100IPB_VW37.rod
VCID: 79D716CFF87A5EF61A-802C
Address 05: Acc/Start Auth. (J518) Labels: 5Q0-959-435.clb
Revision: 00021000 Serial number: 0374846389
Coding: 030C0C
ROD: EV_KessyHellaMQBAB_AU37.rod
VCID: 3A55C9C3BDFC95EE53-806E
1057547 - Antenna for Keyless Entry System; Interior Antenna 1
B1172 13 [008] - Open Circuit
Reset counter: 114
Mileage: 1055 km
Date: 2015.11.12
Time: 21:15:37
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5G0 907 044 BD HW: 5G0 907 044 BD
Component: Climatronic H03 1001
Revision: 00001K08
Coding: 00020004200100000005000012111402
ROD: EV_ACClimaBHBVW37X_SK37.rod
VCID: 6AF539838DDCE56EE3-803E
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 5Q0 937 085 AJ HW: 5Q0 937 085 AF
Component: BCM MQBAB HNA H24 0175
Serial number: 01061520500559
Coding: 00010A46C041A2E169E44000091C07201800000000000000000000000000
ROD: EV_BCMBOSCH_AU37.rod
VCID: 01277E2F90AA063652-8054
Slave 1:
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 150714 043 0551
Serial number: 150717231741
Slave 2:
Component: RLHS 037 0059
Serial number: S4Y15M08D04H06M38S19
Coding: 90A8DD
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 A HW: 5Q0 907 376 A
Component: DAEMPFUNGS-SG H16 0120
Serial number: 19071541350371
ROD: EV_DRCONTITEMIC.rod
VCID: 3753D0F78EEE8886AC-8062
Part No SW: 5Q0 959 655 J HW: 5Q0 959 655 J
Component: AirbagVW20 010 0830
Serial number: 003GCR02TVLC
VCID: 47B3A037FE0EF806DC-8012
Seat occupant detection; front passenger side:
Component: BF-Gewichtss. H11 0021
Serial number: IBH0000000000031DM87
Coding: 303058
Subsystem 2 - Part No SW: ----------- HW: 480 001 807 15
Serial number: 357000000005B111151+
Subsystem 3 - Part No SW: ----------- HW: 480 001 807 15
Serial number: 35800000000F5AB0151L
Subsystem 4 - Part No SW: ----------- HW: 480 402 207 15
Serial number: 3510002B91C2F031130Q
Subsystem 5 - Part No SW: ----------- HW: 480 402 207 15
Serial number: 3520002B91C52F2310C%
Subsystem 6 - Part No SW: ----------- HW: 480 402 907 15
Serial number: 3550002C51B7E8E5A1FW
Subsystem 7 - Part No SW: ----------- HW: 480 402 907 15
Component: FrontSensor_P 001 6149
Serial number: 3560002C31B7E8E3C21I
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 507 HL HW: 5Q0 953 549 E
Component: Lenks. Modul 003 0110
Revision: -------- Serial number: 31071504221383
Coding: 0400
ROD: EV_SMLSKLOMQB_SE37.rod
VCID: 07336037BE8E38061C-8052
Part No SW: 5G1 920 858 A HW: 5G1 920 858 A
Component: KOMBI 303 6420
Coding: 0BAD08123B80CF0502086A001400000000000000
VCID: 2E7DF59371B4494EFF-807A
Part No SW: 5Q0 907 530 AF HW: 5Q0 907 530 F
Component: GW MQB High 128 1223
Revision: -------- Serial number: 0003808517
Coding: 0101000830085900FB00022A880F00000001050000000000000000000000
ROD: EV_GatewLear.rod
VCID: 75CF1AFFD4623A967E-8020
Subsystem 2 - Part No SW: 5G0 959 442 Q HW: 5G0 959 442 Q
Component: E221__MFL-DC1 H10 0101
Serial number: 29150001391920085276
Coding: 30FFFF
Address 22: AWD (J492) Labels: 0CQ-907-554.clb
Part No SW: 0CQ 907 554 D HW: 0CQ 525 130
Component: Haldex4Motion H52 7082
Serial number: HA1-00001.06.15
Coding: 0001
ASAM Dataset: EV_AllWheelContrHA1VW37X 002013
ROD: EV_AllWheelContrHA1VW37X_AU21.rod
VCID: 46ADAD33F904E10E27-8012
Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 15000179178004
Coding: 5500000000000000
ROD: EV_ELVMarquMQB_AU37.rod
VCID: 3449E7FB9F98639E89-8060
Component: TSG FS 020 0041
Serial number: 070715BG709727
Coding: 003E13208000040000000000
ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
VCID: 43ABB427CA36D42600-8016
Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811
Serial number: 00000000000006835024
Coding: 111000
Part No SW: 3Q0 909 144 J HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 505 5063
Coding: 8102
ROD: EV_SteerAssisMQB.rod
VCID: 3957D6CFB8FA9EF65A-806C
Component: TSG BFS 020 0041
Serial number: 230715BGM16818
Coding: 003E13208000040000800000
ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
VCID: 42A5B123D52CDD2E0B-8016
Subsystem 1 - Part No SW: 5Q0 959 812 HW: 5Q0 959 812
Serial number: 00000000000006893087
Coding: 091000
Address 55: Headlight Range (J745) Labels: 7P6-907-357.clb
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Coding: 022202010B000400
ROD: EV_HeadlRegulVWAFS_SE26.rod
VCID: 40A1BB2BDB20CF3E1D-8014
Subsystem 1 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0002
Coding: 2E0000
Subsystem 2 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0002
Coding: 2E0000
Part No SW: 3Q0 035 876 HW: 3Q0 035 876
Component: MU-S-NS-US H25 0241
Serial number: VWZAZ2R0319584
Coding: 027300020000000051220002001808001F0207F401200105C6
ROD: EV_MUStd4CTSAT_VW26.rod
VCID: 71C72EEFA00A16B6A2-8024
Media Player Position 1:
Subsystem 1 - Part No SW: 5GM 919 605 HW: 5GM 919 605
Component: ABT_Std-2_Nav H52 1028
Serial number: VWZ8Z9RFC0003F
Engine Control Module 2:
Subsystem 2 - Part No SW: 3G0 919 866 B HW: -----------
Component: NAR 2015/16 --- 0220
Address 75: Telematics (J949) Labels: 5QE-035-285.clb
Part No SW: 5QE 035 285 A HW: 5QE 035 285 A
Component: OCULowMQBUS 007 0566
Coding: 02730002C2821A017F1E06020000
ROD: EV_OCULowMQB.rod
13636864 - Mobile Online Services
B149A F0 [008] - Vehicle Condition Report
Reset counter: 97
Mileage: 702 km
Date: 2015.11.02
Time: 18:24:30
Part No SW: 5G0 907 159 D HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0001
Serial number: 150706201128
VCID: 2F43E89776BE4046F4-807A
End-------------------------(Elapsed Time: 03:36)--------------------------
