15202 - Actuator Module for Turbocharger 1 P00AF 00 [11101101] - Stuck
KraftwerkTurbo
Brighton, MI
C?ID=102239
Code 15202 - Actuator Module for Turbocharger 1 P00AF 00 [01100000] - Stuck keep coming back, sending car into limp mode.
Ran output test, and actuator seemed to move ok.
Today, removed actuator from wastegate, ran output test again. Not much 'range' (1/2" or so), but seems to move in/out fine.
Moved wastegate flapper by hand. Moves, but has some radial play. And depending on shaft position, can be made to 'hang'.
I do not want to just 'throw' a new turbo on without having more evidence that it is the wastegate flapper, or the actuator.
What should be next step?
Thanks.
Tuesday,05,November,2024,18:47:02:37142
VCDS Version: 24.7.1.0 (x64) HEX-NET2 CB: 0.4643.5
Dealer/Shop Name: KraftwerkTurbo
VIN: WAUGFAFCXGN171093 License Plate:
Chassis Type: FC-AU57 (4G8)
Scan: 01 02 03 05 08 09 15 16 17 19 36 3B 3C 42 44 46 52 53 55 5F
62 6C 72 8F 90 47
VIN: WAUGFAFCXGN171093 Mileage: 140675km-87411miles
Address 01: Engine (J623-CYNB) Labels:. 06L-907-115-V1.clb
Part No SW: 4G5 907 115 A HW: 8T2 907 115
Component: 2.0l R4 TFSI H13 0003
Revision: --H13--- CVN: 154CD0A9
Coding: 0A2A00322426010E2002
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ECM20TFS0204G5907115A 001004
ROD: EV_ECM20TFS0204G5907115A.rod
VCID: 28029483427A0A2A37B-807C
VINID: 9D1957591593A177811C10090C7DEA6FA4
Part No SW: 4G0 927 158 BG HW: 0BK 927 156 AM
Component: 0BK 20TFSIUSA H19 1003
Revision: --H19--- CVN: 3397E7D5
VCID: 74BAB0F3CE323ECA4B3-8020
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V2.clb
Part No SW: 4G0 907 379 S HW: 4G0 907 379 S
Component: ESP9 Premium H01 0530
Coding: 41A7964182E569821B00
ROD: EV_ESP9BOSCHAU57X_004_AU57.rod
VCID: 41D42927C100DB62105-8014
Part No SW: 4H0 907 064 GR HW: 4H0 907 064 GR
Component: BCM2 2.0 H37 0572
Coding: 0DA86F4E000000000000
VCID: 7F506FDFF7F46D92261-802A
Serial number: 3216000029932013
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-2Z.clb
Part No SW: 4G0 820 043 BP HW: 4G0 820 043 BP
Component: KLIMA 2 ZONEN H14 0112
Serial number: 09031600112054
Coding: 64013018C90000
ASAM Dataset: EV_AirCondiBasisUDS 003009
ROD: EV_AirCondiBasisUDS_003.rod
VCID: 6E8EA29BA01E141ABD7-803A
0560 - Supply Voltage Terminal 30 for Coolant Pump
B11D5 15 [00001000] - Open or Short to Plus
Part No SW: 4H0 907 063 DM HW: 4H0 907 063 AM
Component: BCM1 2.0 H20 0311
Revision: 21020001 Serial number: 00001305716301
Coding: 01050011043C9FE08100488780003800CF9CD208A608022180000414F110150200600034030000
VCID: 76BE8AFBD8CE2CDA757-8022
Component: WWS57X 160207 H38 0080
Serial number: 160216153321
Coding: 0045F7
Component: G397_RLFS H06 0004
Serial number: 61525548
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 AL HW: 4G0 941 531 AL
Component: E1 - LDS H07 0044
Serial number: 10 03 2016 00001486
Component: USHL4.2 H30 0030
Serial number: 00000000095Z022B0F76
Subsystem 5 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA123093000019483370
Coding: 020300
Subsystem 6 - Part No SW: 4G0 907 658 A HW: 4G0 907 658 A
Component: Humidity_Sens H03 0002
Serial number: D5D88A18000000000001
Part No SW: 4G0 959 655 B HW: 4G0 959 655 B
Component: Airbag10.43 H62 0086
Revision: -------- Serial number: 003G0002ZUCC Dataset Number: 4G0909602N 0002
Coding: 303331343134303334374A55304C34473053
VCID: 343A70F38EB27ECA8B3-8060
Component: BF-Gewichtss. H11 0046
Serial number: 6940000Y160001GBCM0-
Serial number: 3575HRB405H3VRKK3GKQ
Serial number: 3585HRB401C55ASE7H07
Serial number: 3515JRB400O558L2E14U
Serial number: 3525JRB4012558L2SPKL
Serial number: 3554VRB40553R9VAMOOZ
Serial number: 3564VRB40673L0625OHA
Part No SW: 4H0 953 568 K HW: 4H0 953 568 K
Component: Lenks.Modul H06 0005
Revision: C0068538 Serial number: 90862PCF00018
Coding: 000034
VCID: 3B285BCFA36CB1B24A9-806E
Subsystem 1 - Part No SW: 4G0 951 528 A HW: 4G0 951 528 A
Serial number: 01 02 2016 E0001640
Part No SW: 4G8 920 986 P HW: 4G8 920 986 P
Component: TBenUsa H11 0106
Revision: 09001102 Serial number: 658130316596000
Coding: 0BE609040B41D705020000
ASAM Dataset: EV_RBD4K 004055
ROD: EV_RBD4K_AU57.rod
VCID: 45DC3D37D528F7422CD-8010
Address 19: CAN Gateway (J533) Labels:| 4H0-907-468.clb
Part No SW: 4G8 907 468 F HW: 4G8 907 468
Component: J533--Gateway H14 0083
Revision: -------- Serial number: 00000002184984 Dataset Number: 4G0909515K 0022
Coding: C0CD072910
GVL: FD81C80CDC20600D00040800
ASAM Dataset: EV_GatewPkoUDS 001028
VCID: 3B285BCFA3ECB1B24A9-806E
Serial number: 6804939503
Voltage stabilizer:
Serial number: 16011000000000000205
Component: MEM-FS H03 0157
Revision: AA000000 Serial number: 00000188035515
VCID: 77A087FFDFC455D26E1-8022
Part No SW: 4G0 907 637 H HW: 4G0 907 637 D
Component: SARA 3D H04 0056
Revision: -------- Serial number: EJ1BPA720NWAR9 Dataset Number: 4G0909573C 0006
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 333873EF8BBC79F2929-8066
Component: SWA Master H08 0060
Serial number: 0398604461 Dataset Number: 4G0909535C 0010
Coding: 040211
VCID: 392441C7A9D083A2585-806C
Component: SWA Slave H08 0060
Serial number: 0397995699
Coding: 040211
Part No SW: 4G8 959 793 J HW: 4G8 959 793 G
Component: TSG FA H03 0511
Coding: 011F17015E00628002000012
VCID: 47C0373FEFA4E552DE1-8012
Part No SW: 4G0 909 144 T HW: 4G0 909 144 Q
Component: RCevo H54 0202
Revision: 00000001 Serial number: 0000732894 Dataset Number: 4G0909852L 0037
Coding: 101000010001
ASAM Dataset: EV_RCEPS 106007
ROD: EV_RCEPS_106.rod
VCID: 3A265ECBACD688BA51F-806E
Revision: 00002001 Serial number: 0398605422
Coding: 0106063A00FA408580B0080402070E470000000000000000000000000000
Subsystem 1 - Part No SW: 4G0 959 719 HW: 4G0 959 719
Component: GTO BF H01 0081
Serial number: 00000000000000339007
Subsystem 3 - Part No SW: 4G8 959 591 A HW: 8V3 959 591 A
Component: J245 PS40.402 H03 0004
Serial number: 0000FST000UJCMB00000
Coding: 101F02
Subsystem 4 - Part No SW: 3AA 962 243 D HW: 3AA 962 243 D
Serial number: 93781294
Component: TSG BF H03 0511
Coding: 011F17015E00628002000002
VCID: 46DE3A3BE8AEFC5A257-8012
Part No SW: 4H0 907 801 L HW: 4H0 907 801 A
Component: EPB-4 H05 0017
Revision: -------- Serial number: 00000001772227 Dataset Number: 4G0909522F 0008
ASAM Dataset: EV_ParkiBrake 001029
ROD: EV_ParkiBrake_VW51.rod
VCID: 313479E771A04BE2E05-8064
Component: MxB-ECU 001 0100
Revision: -------- Serial number: -------------- Dataset Number: 4G0909865D 0017
Coding: 04FA021122200400
Coding: E01E00
Coding: E01E00
Address 5F: Information Electr. (J794) Labels:| 4G1-035-MIB-HGH2.clb
Part No SW: 4G1 035 025 L HW: 4G1 035 025
Component: MU-H-LNS-US 043 0387
Serial number: A278C0GB027009 Dataset Number: 4G1909545D 0029
Coding: 017501020000000013220002041A00102F0006E5F17001047E
VCID: 270097BF4F6405523E1-8072
Subsystem 1 - Part No SW: V03 959 801 GG HW: -----------
Component: NAR 2017 --- 0057
Multimedia System 1:
Subsystem 2 - Part No SW: 4G1 919 605 B HW: 4G1 919 605 B
Component: DU8 C7 SV H63 0007
Serial number: AUZ8Z9FY804AY9
Serial number: 90349PCB000AD
Compact disc data bank:
Component: Gracenote2 --- 3006
Component: TSG HL H03 0511
Coding: 010F17004000628002000002
VCID: 49C43107F9B01322C85-801C
Address 6C: Back-up Cam. (J772) Labels:| 4S0-980-556.clb
Part No SW: 4S0 980 556 HW: 4M0 980 556
Component: RVC Compact H08 0140
Dataset Number: 4G0909460D 0013
Coding: 0275000102002003000040
ASAM Dataset: EV_CamSysRVRVCPANAAU57X 001001
ROD: EV_CamSysRVRVCPANAAU57X_001_AU57.rod
VCID: 78A284C3D25A5AAA67B-802C
Component: TSG HR H03 0511
Component: RGS-VL H15 0080
Dataset Number: 4G0909614C 0001
Coding: 0006E008031F0300070308014244CA010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
Component: RGS-VR H15 0080
Dataset Number: 4G0909615C 0001
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
VCID: 323676EB74A670FA99F-8066
Part No SW: 4G5 035 223 C HW: 4G5 035 223
Component: MIB2_amp_P H02 0420
Serial number: 00000000034240 Dataset Number: 4G1909510L 0011
Coding: 0175010A018AF02A5A0000010000
ASAM Dataset: EV_AMPMst16C4Gen2BOSE 001001
ROD: EV_AMPMst16C4Gen2BOSE_AU57.rod
VCID: 221686AB2446E07A69F-8076
End----(Elapsed Time: 02:11, VBatt start/end: 12.0V/12.0V. VIgn 11.9V)-----
golfi_vend
Tartu, Estonia
C?ID=195131
NearlyComatose
Florida, USA
C?ID=606881
Dr Sheldon
Windsor UK
C?ID=334979
Turbo actuators are notorious for sticking when very hot, engine under load.
They will operate fine in the Workshop !!
An Oscilloscope is the way
If Vacuum then
1. Pressure transducer on the pipe
2. Solenoid Current
3. Solenoid Voltage (Command)
4. Map Sensor
5. Throttle Pedal
6. Position Sensor (if fitted)
If Electric
1. ----------------
2. Actuator Current
3. Actuator Voltage (Command)
4. Map Sensor
5. Throttle Pedal
6. Position Sensor
NearlyComatose
Florida, USA
C?ID=606881
If Vacuum then
2. Solenoid Current
4. Map Sensor
5. Throttle Pedal
If Electric
1. ----------------
2. Actuator Current
4. Map Sensor
5. Throttle Pedal
6. Position Sensor
Thank you for the reply.
This is great info. Based on your statement I think I'll replace the actuator. (I would love to own an O-scope, but I don't.)
I was already thinking that heat might be part of the issue because I have noticed that I can drive the car aggressively with no errors for some time after a cold start, but when starting a warm/hot engine, the error occurs the fist time I press hard on the pedal.
Regards,
Mike
Dr Sheldon
Windsor UK
C?ID=334979
My apologies I wrote that wrong !!
I should have written - The Turbo Vanes stick when hot to the point that the Actuator will not have the grunt to move it smoothly.
Replacing the Actuator is shooting the messenger in this case !!
Remove the turbo and service it or replace it !!
NearlyComatose
Florida, USA
C?ID=606881
Yikes, OK thanks for the response. Will do as suggested.
Regards,
Mike
Ziddywerks
Northern NJ USA
C?ID=208579
Perform correct adjustment of actuator and all will be well.
