2019 RS3 Water Pump Issue?
Stark_Knight17
Dallas, TX, USA
C?ID=562058
Hi,
I was driving the other day in the highway when my car suddenly gave me the coolant pump failure alert. I immediately slowed down and checked readouts. No coolant appeared to be leaking and the engine didn’t seem hot. So I limped it home and monitored everything closely. Oil temp never went above 204F and coolant was sitting at 185F. I recently replaced the water pump 1,000 miles ago so I have doubts the water pump has failed again. Doing basic research, I’ve read the fault could be for a sensor as the car can’t directly monitor the pump. I also replaced my wastegate hose/sensor because that failed which made me think of that possibility.
The car doesn’t seem to be leaking coolant and yesterday I tested it out by letting it idle to temp and taking it for a short easy drive. It held temps and didn’t go above 200F for coolant.
As I’m not the best at diagnosis, does anyone have any recommendations on which readouts to monitor to help determine what the issue is or any other suggestions? Below is the code I got. Any help is appreciated! Also I apologize if the format seems off. Pasting data from a screenshot.
33688 - Coolant pump
P1B1C 00 [01100101] - Mechanical malfunction
Mileage: 66167 km
Date: 2024.12.01
Time: 09:21:09
Engine RPM: 2411.00 / min
Normed load value: 18.8 %
Vehicle speed: 128 km/h
Coolant temperature: 82 °C
Intake air temperature: 12 °C
Voltage terminal 30: 14.460 V
Engine torque: 149.1 Nm
Accelerator pedal travel: 29.91 %
Intake_manifold_model_air_mass_flow_filtered value: 126.8 kg/h
ExhMgT_fetak_htlfa_msg: 1.000
Dr Sheldon
Windsor UK
C?ID=334979
Can we have the Priveledge of the Required AutoScan
Stark_Knight17
Dallas, TX, USA
C?ID=562058
I have unfortunately cleared codes trying to see if I could get it to trip again. I’m assuming an auto scan would be useless without it right now? Otherwise I can probably provide one later tonight.
Nah, it still provides context, especially when you're asking what values to monitor.
Just a "heads up" if you are using non oem or non genuine parts ; they can prematurely fail or not function at all. Sounds like the pump is working, but beware of other electrical (unknown origin) parts.
EuroX
Northern NJ USA
C?ID=208579
Are we sure there is no debris possibly blocking the flow of coolant?
Stark_Knight17
Dallas, TX, USA
C?ID=562058
Sounds good, I've attached it below with the original error
Sunday,01,December,2024,11:05:33:64504
VCDS Version: Release 24.7.1 (x64) Running on Windows 11 x64
                Address 01: Engine       Labels: 07K-907-309-V1.clb
Control Module Part Number: 8V0 907 404 J    HW: 07K 907 309 E
  Component and/or Version: R5 2.5l TFSI  X22 0002
           Software Coding: 0A250032246600053620
            Work Shop Code: WSC 00000 000 00000
              ASAM Dataset: EV_ECM25TFS0118V0907404J 001003 (AU37)
                       ROD: EV_ECM25TFS0118V0907404J.rod
                      VCID: 40D951C5AA0C7C8A1FB-8014
                    Mileage: 66167 km
                    Date: 2024.12.01
                    Time: 09:21:09
                    Engine RPM: 2411.00 /min
                    Intake_manifold_model_air_mass_flow_filtered_value: 126.8 kg/h
                    ExhMgT_fetak_hllfa_msg: 1.000
Readiness: 0010 0001
Monday,02,December,2024,19:29:20:64504
VIN: WUABWHFF1KA900682   License Plate:
Chassis Type: FF-AU37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 17 19 22 29 2B 39 3C 42 44 47
          4B 52 5F 65 6C A5 BB BC CF D6 D7
VIN: WUABWHFF1KA900682   Mileage: 66232km-41154miles
Address 01: Engine (------DAZA)       Labels:. 07K-907-309-V1.clb
   Part No SW: 8V0 907 404 J    HW: 07K 907 309 E
   Component: R5 2.5l TFSI  X22 0002
   Revision: 53X22000    CVN: 3E7961AC
   VINID: 9E54529D859605B44900018808A15E0230
Readiness: 0010 0101
   Part No SW: 0DL 300 013 E    HW: 0GC 927 711 G
   Component: GSG DQ500     H06 3023
   Revision: 00H06V07    CVN: 72AD2BB5
   VCID: 2C011575368488EAD33-8078
   Part No SW: 8V0 614 517 D    HW: 8V0 614 517 C
   Component: ESC           H25 0640
   Revision: 00000000    Serial number: 60439000000252 Dataset Number: 8V0909504Z  0056
   Coding: 2EAA6B7DD4990BA989970B6C40936974D62BD091D00296361841508402A8420000000012121212B835351919323200
   Shop #: WSC 06335 790 00021
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 037008
   ROD: EV_Brake1UDSContiMK100IPB_037_AU37.rod
   VCID: 3A2D232DCCD0265A51F-806E
   Part No SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
   Component: VWKESSYMQB    037 1204
   Revision: 00037000    Serial number: 0508275440 Dataset Number: 8V0909577G  0002
   Coding: 030C0C1720
   ASAM Dataset: EV_KessyHellaMQBAB 004046
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 43D35EC9BB1A6792029-8016
   Part No SW: 8V0 820 043 AF    HW: 8V0 820 043 AF
   Component: AC Automat    H03 0150
   Revision: 20003000    Serial number: 00000001745572 Dataset Number: 8V0909862C
   Coding: 03000015010000000000000000001400
   ASAM Dataset: EV_AirCondiFrontVaAU37X 008025
   VCID: 76B5F71DB848823A757-8022
   Humidity sensor: exterior:
   Subsystem 1 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Serial number: 72D0139900PAG0MUFU03
263681 - Exterior Air Quality/Humidity Sensor
          B137A 04 [00001000] - Internal System Fault
                    Reset counter: 35
                    Mileage: 66186 km
                    Date: 2024.12.01
                    Time: 09:43:03
                    Outside temperature: 10 °C
                    Voltage terminal 30: 14.1 V
                    System run time-Terminal 15 on: 25 s
                    Air quality status: Measuring value not available
   Part No SW: 5Q0 937 085 BS    HW: 5Q0 937 085 BF
   Component: BCM MQBAB MNA H38 0273
   Serial number: 00001906200612 Dataset Number: 8V0909514AB 0026
   Shop #: WSC 06325 790 00021
   ROD: EV_BCMBOSCH_019_VW37.rod
   VCID: 0B43B6E9D3CAEFD23A9-805E
   Component: WWS371 181221  043 0585
   Serial number:         190118190846
   Coding: 0A47F7
   Serial number: 21817640X81A955547A0
   Coding: 00006C
   Subsystem 3 - Part No SW: 8V0 941 531 AR    HW: 8V0 941 531 AR
   Component: E1 - LDS MQB  H06 0032
   Serial number: 14 12 2018  20000989
   Serial number: 00000000000046623364
   Sunroof control module:
   Component: J245 PS73.404  H04 0005
   Serial number: 0000FST0029TI5R00000
   Coding: 101F00
   Steering Column Switch:
   Subsystem 6 - Part No SW: 82A 953 521 CQ    HW: 5Q1 953 549
   Component: J527 SMLS MQB  004 0060
   Serial number: 00000008021904406031
   Part No SW: 5QA 919 294 C    HW: 5QA 919 294
   Component: PDC 8 KanalH07 0050
   Serial number: 000308418019050 Dataset Number: 8V0909526K  0064
   Coding: 0470155811
   ASAM Dataset: EV_EPHVA18AU3700000 009039
   ROD: EV_EPHVA18AU3700000_VW41.rod
   VCID: 4CC175F59644A8EAF33-8018
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V2.clb
   Part No SW: 5Q0 907 572 P    HW: 5Q0 907 572 J
   Dataset Number: 8V1909863AD 0003
   Coding: B50087C119FFC4247498815580302600000000000000000004
   Shop #: WSC 06324 790 00021
   VCID: 44D15DD5BE1460AA3B3-8010
Address 14: Susp. Elect. (J250)       Labels: 8V0-907-376.clb
   Part No SW: 8V0 907 376 H    HW: 8V0 907 376 F
   Component: DAEMPFUNGS-SG H11 0083
   Serial number:       150219135 Dataset Number: 8V0909554H  0001
   ASAM Dataset: EV_AudiMagneRide 003007
   ROD: EV_AudiMagneRide_003.rod
   VCID: 46D547DD882852BA257-8012
   Serial number: 003GCR0B9VL1 Dataset Number: 8V0909602R  0002
   Coding: 9DFCFCC0008000005000001AC24800000065
   VCID: 47CB4AD98F224BB2DE1-8012
   Left seat belt tensioner:
   Serial number: 34230167A14021930796
   Coding: 333135
   Right seat belt tensioner:
   Serial number: 34230168A14021920549
   Coding: 333135
   Subsystem 3 - Part No SW: 5C6 959 339 C    HW: 5C6 959 339 C
   Component: BF-Gewichtss.  H10 0047
   Serial number: 694000000000001VGH20
   Coding: 303439
   Subsystem 4 - Part No SW: -----------    HW: 480 002 702 19
   Serial number: 35700000000BA3C8E83+
   Subsystem 5 - Part No SW: -----------    HW: 480 002 702 19
   Serial number: 35800000000A40BC893U
   Subsystem 6 - Part No SW: -----------    HW: 480 402 002 19
   Component: SideSensor_Dr  003 6149
   Serial number: 3510001C52E98074B21%
   Subsystem 7 - Part No SW: -----------    HW: 480 402 002 19
   Component: SideSensor_Pr  003 6149
   Serial number: 3520001B32E5A55517D6
   Subsystem 8 - Part No SW: -----------    HW: 480 401 902 19
   Serial number: 3550001302BF5A81743/
   Subsystem 9 - Part No SW: -----------    HW: 480 401 902 19
   Component: FrontSensor_P  004 6149
   Serial number: 3560001302BF5A82C669
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI2
   Part No SW: 8V0 920 890 B    HW: 8V0 920 890 B
   Component: FBenUSA       H19 0108
   Dataset Number: 8V0909525AC 0023
   Coding: 084F18D37E88CF050284EC041800001000000000
   ASAM Dataset: EV_DashBoardFPKAU37X 001032
   ROD: EV_DashBoardFPKAU37X.rod
   VCID: 3C212535C6E4186A433-8068
   Component: GW MQB High   442 4367
   Revision: --------    Serial number: 0009162692 Dataset Number: 8V0909515R  0101
   Coding: 0301000434085D005B00801EB80B00000001010000000000000000000000
   GVL: 01CE3C000000060040CC80000002CC0000040000000200000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 6E85DF7DC018BAFABD7-803A
   Generator:
   Component: 1-01-09-01-04
   Subsystem 2 - Part No SW: 8W0 951 523 F    HW: 8W0 951 523 F
   Component: J453 MFL  H04 0004
   Serial number: 20190215204611 22854
   Subsystem 3 - Part No SW: 8S0 915 181 C    HW: 8S0 915 181 C
   Serial number: 5051870405
   Part No SW: 0CQ 907 554 K    HW: 0CQ 525 130
   Component: Haldex4Motion H55 7762
   Serial number: HA1-00004.02.19 Dataset Number: v1260x015G0 0000
   Coding: 0601
   ROD: EV_AllWheelContrHA1VW37X_002_VW36.rod
   VCID: 4DC778F16D5EA1E2E4D-8018
Address 29: Left Light (J1018)       Labels: 8S0-907-397.clb
   Part No SW: 8S0 907 397 D    HW: 8S0 907 397 D
   Component: LCM_MQB       H07 0022
   Dataset Number: 8V0909519D  0006
   VCID: 42DD5BCDA4006E9A09F-8016
   Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
   Component: ELV-MQBB      H08 0021
   Serial number: 19000031621005 Dataset Number: 8V0909564C  0005
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 313F040111A6E502E05-8064
Address 39: Right Light (J1023)       Labels: 8S0-907-397.clb
   Dataset Number: 8V0909520D  0006
   Part No SW: 3Q0 907 566 H    HW: 3Q0 907 566
   Component: MRR1Rear      H25 0630
   Revision: --------    Dataset Number: 8V0909535G  0006
   Coding: 04C002
   Shop #: WSC 06342 790 00021
   ROD: EV_RearRadarS1BoschVW48X_AU37.rod
   VCID: 3D272831DDFE116274D-8068
   Part No SW: 5Q0 959 593 F    HW: 5Q0 959 593 F
   Component: TSG FS001 0287
   Serial number: YE007SBF24105 Dataset Number: 8V0909872N  0061
   Coding: 005E1B205000008000000002
   Part No SW: 3Q0 909 144 M    HW: 3Q0 909 144 L
   Dataset Number: 8V0909852AA 0001
   Coding: 911E0000
   ROD: EV_SteerAssisMQB_015.rod
   Part No SW: 81A 035 466 B    HW: 81A 035 466
   Component: MIB2_amp_P_A3 H10 0440
   Revision: 00000001    Serial number: AUZ8ZAJ5F026DV4 Dataset Number: 8V0909510G  0007
   Coding: 0173030000AAAA2AAA0000010000
   ASAM Dataset: EV_AMPMst16C9Gen2ALPI 001002
   ROD: EV_AMPMst16C9Gen2ALPI_AU37.rod
   VCID: 2411FD555E5440AA1B3-8070
   Component: FCM MQB Low   002 0345
   Serial number: 27021910802579 Dataset Number: 8V0909583B  0009
   Coding: 000000050900143206112300040000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 002006
   ROD: EV_MultiModulContiVW48X_002_VW41.rod
   VCID: 35373011E5CEC922BCD-8060
   Part No SW: 5Q0 959 592 F    HW: 5Q0 959 592 F
   Component: TSG BFS001 0287
   Serial number: YE007SBD28255 Dataset Number: 8V0909873N  0061
   Coding: 005E13205C00008000000002
Address 5F: Information Electr. (J794)       Labels:* 8V0-035-MIB-HGH2.clb
   Part No SW: 8V1 035 880 C    HW: 8V1 035 880 C
   Component: MU-P-LNS-US   055 1363
   Serial number: A702B0KS015381 Dataset Number: 8V2909545T  0032
   Coding: 017361020000000011220002041A00332F0028E4017001047E
   Subsystem 1 - Part No SW: V03 959 802 DK    HW: -----------
   Component: NAR 2018/2019  --- 0066
   Multimedia System 1:
   Component: DU High  H49 0014
   Serial number: AUZ8Z9J1Y0G9J3
   Subsystem 3 - Part No SW: 8V0 919 614 BT    HW: 8V0 919 614 BT
   Component: ControlUnit_H  H85 0858
   Serial number: ALJAL115051800050617
   Compact disc data bank:
   Component: Gracenote2  --- 3013
                    Reset counter: 162
                    Mileage: 64097 km
                    Date: 2024.10.15
                    Time: 18:50:28
                    Voltage terminal 30: 12.5 V
                    Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
                    Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
Address 65: Tire Pressure (J502)       Labels: 4M0-907-273.clb
   Part No SW: 8S0 907 273     HW: 4M0 907 273 B
   Component: RDKHUFAU736   H05 0002
   Serial number: 30000000006768 Dataset Number: 8V0909850A  0003
   ROD: EV_RDKHUFAU736_AU37.rod
   VCID: 77ABFA19BF42FB326E1-8022
   Component: RVC Compact   H15 0231
   Dataset Number: 8V0909460E  0005
   Coding: 0273010102002001400040
   ROD: EV_CamSysRVRVCPANAMQBAB_006_VW48.rod
   VCID: 392F3C21C9D62D42585-806C
   Part No SW: 3Q0 980 654 L    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H10 0610
   Serial number: 29011915K12105 Dataset Number: 8V0909466R  0016
   Coding: 040307010000020101222346814E490080000E20012000
   ROD: EV_MFKBoschMQBB_002.rod
   Part No SW: 8W1 959 395 D    HW: 8W1 959 395 D
   Component: TSG HFS003 0189
   Serial number: YE007SBB2052D Dataset Number: 8V0909897J  0060
   Coding: 000C13204000008000000002
   Component: TSG HBFS003 0189
   Serial number: YE007SBB22387 Dataset Number: 8V0909896J  0060
   Part No SW: 3Q0 907 590 H    HW: 3Q0 907 590
   Revision: --------
   Coding: 04C002
   ROD: EV_RearRadarS2BoschVW48X_AU37.rod
   Dataset Number: 8V0909471E  0008
   VCID: 176BDA999F021B328E1-8042
   Dataset Number: 8V0909472E  0008
End----------(Elapsed Time: 01:54, VBatt start/end: 12.3V/12.2V)-----------
Stark_Knight17
Dallas, TX, USA
C?ID=562058
They only sell OEM for it, couldn't do aftermarket so got a HEPU and made sure to match SKU and part numbers.
Stark_Knight17
Dallas, TX, USA
C?ID=562058
It's highly unlikely, I'd have to flush it again to see if something happened. When I changed it last I did a flush and vacuum fill.
I'm not seeing anything in the data for that ECU that shows direct feedback from either of the coolant circulation pumps, or the heater support pump for that matter. So I am at a loss to explain how the ECU determines that there's a "Mechanical malfunction" with the pump.
If I were chasing this, I'd type 'pump' in the the search/filter box on the Advanced Measuring Values screen and check every box where the description references 'coolant'. There are a number of other pumps that are not relevant here. Then drive the car while logging the data. Perhaps you can spot some kind of discrepancy?
Stark_Knight17
Dallas, TX, USA
C?ID=562058
Tried that last night and everything appeared to be normal. But I was able to take it to the dealer for a free diagnosis somehow and from what we could tell it looks like it may be either the thermostat or a vacuum line for a sensor that comes off the top of the pump. Seems it is most likely the thermostat as the car can get hotter than usual in low speed traffic and the feed hose to the radiator wasn't that hot while the car was at operating temperature.
Dr Sheldon
Windsor UK
C?ID=334979
EuroX
Northern NJ USA
C?ID=208579
AFAIK ecm determines this by checking coolant temp in comparison between thermostat temp sensor and other coolant temp sensors in the system.
dareckim11
Glasgow Scotland
C?ID=404683
Look at the water pump. A vacuum was connected to the pump. Check the vacuum in the pump for leaks. Vacuum hose, and valve.
