Bentley gt 2004 - imobilizer activated
bboctavian
Romania
C?ID=435860
Hello, i have a Bentley gt with problem about ignition, on cluster shows me: imobilizer activated
The think is my steering lock work.. on i put key in ignition will unlock the steering and when i pull out, lock the steering.
but car has same error: imobilizer activated
already change the ignition relay, check all the fuse.
i will post here a full scan:
Monday,02,December,2024,04:00:52:11366
Chassis Type: 3W - Bentley Continental (2004 > 2007)
Scan: 01 02 03 05 06 07 08 09 11 13 15 16 17 18 19 23 26 28 34 36
          37 38 46 47 53 54 57 65 66 68 69 6C 71 75 76 77
   Part No SW: 3D0 909 137 G    HW: 3D0 909 137 G
   Component: 43 Kessy            6850
   Revision: 00H24072    Serial number: VWZ3Z0D7159945
   Coding: 0405741
   Shop #: WSC 04940 001 00001
   VCID: 2B030DF13F17F632DA9-5160
   Subsystem 1 - Part No: 4E0 905 852 D
   Component: ELV                 1834
                    Fault Frequency: 14
                    Reset counter: 126
                    Date: 2064.00.00
                    Time: 00:00:14
00166 - Access/Start Authorization Switch (E415)
                    Reset counter: 166
                    Date: 2064.00.00
                    Time: 00:00:14
Address 06: Seat Mem. Pass        Labels: 3W0-959-759.clb
   Part No: 3W0 959 759 A
   Component:    CM Seat Pass.    0009
   Coding: 0000002
   Shop #: WSC 45678 123 45725
   VCID: 47CB514183BF3252DE1-5160
01900 - Passengers Seat Fore / Aft Adjusting Motor (V31)
01975 - Passengers Seat Height Adjustment Motor (V191)
01904 - Passengers Backrest Adjusting Motor (V46)
01903 - Seat Tilt Adjustment Motor (V231)
01976 - Seat Depth Adjustment Motor (V234)
Address 08: Auto HVAC        Labels: 3W7-907-040.clb
   Part No: 3W0 907 040 B
   Component: Climatronic BY614   0030
   Coding: 0000002
   VCID: 30391A9D163195EAEFB-5160
00785 - Temp Sensor in Instrument Panel (G56)
            010 - Open or Short to Plus
Address 09: Cent. Elect.        Labels:
   VCID: 55F78B094C0390C25CD-513C
   Note: Excessive Comm Errors
Address 16: Steering wheel        Labels: 3D0-953-549.lbl
   Part No: 3D0 953 549 E
   Component: Lenks�ulenmodul     3401
   Coding: 0000212
   Shop #: WSC 00083 000 00000
   VCID: 2F3B19E10B0F8A12F61-5160
Address 36: Seat Mem. Drvr        Labels: 3W0-959-759.clb
   Part No: 3W0 959 760 A
   Component:    CM Seat Driver   0008
   Coding: 0000002
   Shop #: WSC 07926 107 51015
   VCID: 3FDB49A1DB6F7A92661-513C
00003 - Control Module
Address 37: Navigation        Labels:
Address 38: Roof Electronics        Labels: None
   Part No: 3W0 907 135 C
   Component: Dachmodul           0702
   Coding: 0000157
   VCID: 36352C85F455BBDAB57-513C
   Part No: 3W0 035 456 C
   Component: 12K-AUDIOVERST      4121
   VCID: 3431168DE229A9CA8B3-513C
Address 65: Tire Pressure        Labels: 3D0-907-273-V1.clb
   Part No: 3W0 907 273
   Component: Reifendruckueberw.  0022
   Coding: 0010344
   Shop #: WSC 00999 444 64523
   VCID: 76B5EC85B4D5FBDA757-513C
Address 76: Park Assist        Labels: 3W0-919-283-V1.clb
   Part No: 3W0 919 283
   Component: 02 Einparkhilfe     0203
   VCID: 7AADF8B580CD9FBA11F-513C
No Faults Found
Address 77: Telephone        Labels: None
   Part No: 3W0 035 729 C
   Component: Telefon             0241
   VCID: 372B2181F35F42D2AE1-5160
End----(Elapsed Time: 09:29, VBatt start/end: 12.7V/13.2V. VIgn 0.0V)------
Jef
HQ
What is causing this? I would start with inspecting the wiring and terminals for the E415. From the control module's point of view, it doesn't know the difference between a rat chewing on the wiring harness over some one trying to hack up the harness to steal the car.
bboctavian
Romania
C?ID=435860
Hello Jef, i measure the wires from ignition switch to kessy and all wires is ok. Can be the kessy with problem? (no water damage inside)
Jef
HQ
If the wiring is to factory design, then yes, it is possible the kessy itself has failed. Or, it could be the E415. The E415 I suspect is hot swappable, no relearns needed. Where as replacing the kessy will create immobilizer issues... but if the kessy is the root issue, then the 00166 fault code would go away.
Dr Sheldon
Windsor UK
C?ID=334979
Im sure as sure that some of those wires carry data !!
How did you measure them ??
Dr Sheldon
Windsor UK
C?ID=334979
The Integrity of that data - HOW ?
bboctavian
Romania
C?ID=435860
I measure the continuity from KESSY to IGNITION SWITCH...
and think is after i measure that wires no error on :
now i havee just error about module from the left door on the kessy...
