Resolved 5f Module faulty? (2014 A8)
Resolved
Bazza
Scotland
C?ID=438412
Hi guys, I am hoping someone can assist and point me in the right direction.
Symptoms - ACC and Braking Guard unavailable intermittent. Sometimes works fine the throws up the warning for a few seconds then works again. Sometimes it will repeatedly alarm every few seconds as if it detects a fault, clears then detects it again.
I have cleared the faults many times and they all suggest faults in other modules except 5F which is now showing an EEPROM error. I had wondered about re-entering the coding into the module but there is no bubble suggesting any of the security codes so I have not tried this. The Invalid Security/Release Code in the scan first appeared after updating the firmware and maps but everything has been working for 6 months without any issues.
Can anyone confirm that it is indeed 5F or could it be one of the subsystems?
Thanks in advance.
Saturday,30,November,2024,14:41:40:26473
VIN: WAUZZZ4H3EN010093   License Plate:
Chassis Type: 4H-AU64 (4H0)
Scan: 01 02 03 05 06 08 09 13 15 16 17 19 20 30 34 36 3B 42 44 46
          47 52 53 55 56 5F 62 6C 6D 6F 72 81 82 85 88 89 8B 8E 8F 90
          AC
VIN: WAUZZZ4H3EN010093   Mileage: 181634km-112862miles
Address 01: Engine (J623-CTBA)       Labels:. 059-907-401-V2.clb
   Part No SW: 4H0 907 401 P    HW: 4G0 907 401 E
   Component: 3.0TDI EDC17  X14 0002
   Revision: 58X14---    CVN: D220FBC80000000038D3FF82
   Coding: 0A2A4032056601030800
   Shop #: WSC 10714 002 1048576
   ASAM Dataset: EV_ECM30TDI0114H0907401P 001002
   ROD: EV_ECM30TDI0114H0907401P.rod
   VCID: 313F1F60E1AF2C12E05-8064
   VINID: 9D196AAAA1180D57800400090CCCA36267
   Part No SW: 4H1 927 158 CL    HW: 0BK 927 156 AD
   Component: 0BK 30 TDIRdW H16 1002
   Revision: --H16---    CVN: 840FCFA4
   VCID: 7CA1FE54766D117A033-8028
Address 03: ABS Brakes (J104)       Labels: 4H0-907-379.clb
   Part No SW: 4H0 907 379 AA    HW: 4H0 907 379 AA
   Component: ESP PREMIUM   H10 0665
   Coding: 60E5AB8006A7D501E300
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ESPPremi 005024
   ROD: EV_ESPPremi_005_AU64.rod
   VCID: 71BFDF60212F6C12A05-8024
   Part No SW: 4H0 907 064 DB    HW: 4H0 907 064 DB
   Component: BCM2 2.0      H35 0510
   Coding: 05B76F4E000000000000
   VCID: 6C81CE14068D81FA933-8038
   Serial number: 0213000353351002
   Part No SW: 4H0 959 760 E    HW: 4H0 959 760 E
   Component: MEM-BFS       H08 0153
   Revision: AA000000    Serial number: 00000082085020
   Coding: C038320085047201010001010101112131313333283333
   VCID: 35372B7015470032BCD-8060
Address 08: Auto HVAC (J255)       Labels:| 4H0-820-043.clb
   Part No SW: 4H0 820 043 P    HW: 4H0 820 043 P
   Component: Klima 2 Zonen H20 0201
   Coding: 3621002E340000
   ASAM Dataset: EV_AirCondiFront 003001
   ROD: EV_AirCondiFront_002.rod
   VCID: 2D070310FD9748F2C4D-8078
   Part No SW: 4H0 907 063 AB    HW: 4H0 907 063 AB
   Component: BCM1 2.0      H20 0242
   Revision: 19020001    Serial number: 00000051011902
   Coding: 0105001440349FE2C9014084A0001800009DC30A2F08020180000894610017000040002D0B0000
   VCID: 6889B2041275ADDAF7B-803C
   Subsystem 1 - Part No SW: 4H2 955 119 C    HW: 4H2 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS641 130524  H36 0090
   Serial number:         130604122302
   Coding: 0045F7
   Serial number: 21930883
   Coding: 02004E
   Subsystem 3 - Part No SW: 4H0 941 531 F    HW: 4H0 941 531 F
   Component: E1 - LDS  H01 0044
   Serial number: 14 11 2013  00001113
   Component: EVLS-SG  H08 0300
   Serial number: WA106973000005341858
   Coding: 020300
   Serial number: ECA987D6000000000001
   Part No SW: 4H0 907 561 C    HW: 4H0 907 561
   Component: ACC3          H21 0032
   Serial number: 00000000000000 Dataset Number: 4H0909863E  0036
   Coding: 7C04010201
   Shop #: WSC 61965 001 104857
   ASAM Dataset: EV_AdaptCruisContrAU64X 002024
   ROD: EV_AdaptCruisContrAU64X_002.rod
   VCID: 2B030D08C38346C2DA9-807E
145408 - Function Restriction due to Faults in Other Modules
          U1113 00 [00001001] - -
          [FAULT_CIS_NAVI_FAIL]
                    Reset counter: 160
                    Mileage: 181634 km
                    Date: 2024.11.30
                    Time: 14:38:25
                    Control Module temperature: 29  C
                    Voltage terminal 15: 14.665 V
                    Longitudinal_acceleration_vehicle_reference: 0.00 m/s
   Component: Airbag10.43   H81 0084
   Revision: --------    Serial number: 003P100134E8 Dataset Number: 4H0909602J  0012
   Coding: 30333045313430303037554A305234483053
   VCID: 3B233D4833E3D6424A9-806E
   Serial number: 3575HRB400O50O5U91SX
   Serial number: 3585HRB400C50MESJHAZ
   Serial number: 3515JRB400250OCCSPLW
   Serial number: 3525JRB400250OCCI9B/
   Serial number: 3554VRB40512E3MO91KJ
   Serial number: 3564VRB404R2E3MOKG9H
   Revision: --------    Serial number: 99999MKE000W3
   Coding: 0000FC
   VCID: 372B21780F4BF222AE1-8062
   Subsystem 1 - Part No SW: 4H0 951 528 J    HW: 4H0 951 528 J
   Component: E221 - MFL  H09 0010
   Serial number: 01 08 2013  33037486
   Part No SW: 4H0 920 950 P    HW: 4H0 920 950 P
   Component: TDieGBACC---- H53 0621
   Revision: 36081095    Serial number: 658191113592031
   Coding: 338F08001F552700010000
   ASAM Dataset: EV_RBD4K 004048
   ROD: EV_RBD4K_AU64.rod
   VCID: 35372B7015C70032BCD-8060
   Analog_clock:
   Subsystem 1 - Part No SW: 4H0 919 204 H    HW: 4H0 919 204 H
   Component: Analoguhr D4  H05 0225
   Serial number: 2131106000318
   Part No SW: 4H0 907 468 AE    HW: 4H0 907 468 AC
   Component: J533--Gateway H13 0050
   Revision: --------    Serial number: 00000001178864 Dataset Number: 4H0909515K  0080
   Coding: 80CD077D00
   GVL: FF8FE918FEE3E8CFC000
   ASAM Dataset: EV_GatewPkoUDS 001019
   VCID: 74B1D6745E3D593A4B3-8020
   Subsystem 1 - Part No SW: 4H0 915 181 F    HW: 4H0 915 181 F
   Component: J367-BDM  H08 0181
   Serial number: 50309953161911092705
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 C    HW: 8K0 959 663 C
   Serial number: 13311003409021200410
   Part No SW: 4H0 857 511     HW: 4H0 857 511
   Component: FLA           H04 0020
   Revision: AA001002
   Coding: 04028B6B74745D545420363E00
   VCID: 678BB1381F6BA2A2FE1-8032
Address 30: Special Function II (J843)       Labels: 8K0-907-440.clb
   Part No SW: 4H0 907 440     HW: 4H0 907 440
   Component: STS           H06 0030
   Revision: S0H06000    Serial number: 00000000049971
   Coding: 01010101000000000001000202
   VCID: 6491A634EE5DC9BADB3-8030
   Dataset Number: 4H0909553H  0037
   Coding: 008002
   ROD: EV_AirSuspe_003_AU64.rod
   VCID: 2F3B1918F79B3AE2F61-807A
   Component: MEM-FS        H08 0153
   Revision: AA000000    Serial number: 00000082090461
   Coding: C0383B0085057201010001010101112131313333203333
   Part No SW: 4H0 907 637 K    HW: 4H0 907 637 F
   Component: SARA 6D       H03 0056
   Revision: --------    Serial number: EJ1BPA7701BAWJ
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 372B21780FCBF222AE1-8062
   Part No SW: 4H0 959 793 R    HW: 4H0 959 793 G
   Component: TSG FA        H06 0273
   Revision: --------    Serial number: 0000082364399
   Coding: 011F1E005E01628202083003
   VCID: 48C9528472B58DDAD7B-801C
   Component: RCEPS         H39 0010
   Revision: 00001000    Serial number: 0011033746 Dataset Number: 4H0909852F  0020
   Coding: 101001010001
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   VCID: 323D106CE4A9170A99F-8066
   Revision: 00002001    Serial number: 0319931160
   Coding: 011B0E2280B93881B320C7840C0316470000000000000000000000000000
   Subsystem 1 - Part No: 4H0 951 177
   Component: DWA-Sensor  H01 0010
   Subsystem 3 - Part No SW: 4H0 947 135 A    HW: 4H0 947 135 A
   Component: Dachelektroni  H13 0080
   Serial number: A2013000000000750197
   Subsystem 4 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
   Serial number: 93094031
   Revision: CJ007001    Serial number: 00000000051111
   Coding: 030000
   VCID: 1D67D3D08DB7B87254D-8048
   Part No SW: 4H0 959 792 G    HW: 4H0 959 792 G
   Component: TSG BF        H06 0273
   Revision: --------    Serial number: 0000082129899
   Coding: 011F1E005E01628202083002
   VCID: 3C213E54366DD17A433-8068
                    Fault Status: 01101100
                    Reset counter: 160
                    Mileage: 181634 km
                    Date: 2024.11.30
                    Time: 14:38:24
   Part No SW: 4H0 907 801 G    HW: 4H0 907 801 A
   Component: EPB-4         H03 0014
   Revision: --------    Serial number: 00000000887581 Dataset Number: 4H0909522D  0017
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2C010E14C68D41FAD33-8078
   Part No SW: 4H4 907 357 B    HW: 7P6 907 357 B
   Component: MxB-ECU       001 0049
   Revision: --------    Serial number: -------------- Dataset Number: 4H0909865C  0018
   Coding: 02F6021022630200
   ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 004002
   ROD: EV_HeadlRegulAUDIMXBAU64X_004_AU64.rod
   Subsystem 1 - Part No SW: 7PP 941 472 F    HW: 7PP 941 472 F  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H07 7530
   Coding: E00200
   Subsystem 2 - Part No SW: 7PP 941 472 E    HW: 7PP 941 472 E  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H06 7510
   Coding: E00200
13706027 - Databus
          [Empfangener Fehlerwert in PSD_Segment_ID: CAN Message PSD_01]
                    Reset counter: 160
                    Mileage: 181634 km
                    Date: 2024.11.30
                    Time: 14:38:26
13706028 - Databus
          [Empfangener Fehlerwert in PSD_Vorgaenger_Segment_ID: CAN Message PSD_01]
                    Reset counter: 160
                    Mileage: 181634 km
                    Date: 2024.11.30
                    Time: 14:38:26
   Part No SW: 4G0 035 061 S    HW: 4G0 035 061
   Component: Radio U DAB   H60 0154
   Revision: AB001007    Serial number: 109K20D7801289
   Coding: 010103010000000001
   VCID: 2D070310FD1748F2C4D-8078
   Part No SW: 4H0 035 654 E    HW: 4H0 035 670 P
   Component: H-BNT-EU      H47 1072
   Revision: --------    Serial number: 179K70D7516545
   Coding: 02010100000BFFFF7FB8EF1E00000003080001000100000002
   VCID: 2809F204D2F56DDA37B-807C
   Subsystem 1 - Part No: 8R0 060 884 KL
   Component: EUR 2023  3600
   Subsystem 2 - Part No SW: 4H0 919 604 G    HW: 4H0 919 604 G
   Component: DU8 D4 SV NB  H48 0021
   Serial number: AUZ8ZDDC900WL8B
   Subsystem 3 - Part No SW: 4H2 919 600 H    HW: 4H2 919 600
   Component: E380 BDT D4  H09 0065
   Serial number: 00000000138202
   Component: CD-Database  5571
16347 - Control Module - EEPROM Error
                    Fault Status: 00101110
                    Mileage: 181634 km
                    Date: 2024.11.30
                    Time: 13:37:38
                    Voltage: 11.50 V
                    ON Time: 6663 h
                    Reset counter: 160
                    Mileage: 181634 km
                    Date: 2024.11.30
                    Time: 14:38:28
                    Bin. Bits: 00000000 00001000
                    Bin. Bits: 00000100 00000000
                    Bin. Bits: 00000000 00000000
                    Reset counter: 160
                    Mileage: 181634 km
                    Date: 2024.11.30
                    Time: 14:38:36
                    Voltage: 14.60 V
                    Reset counter: 160
                    Mileage: 181634 km
                    Date: 2024.11.30
                    Time: 14:38:36
                    Bin. Bits: 00000000 00000100
03623 - Invalid Security/Release Code
                    Reset counter: 160
                    Mileage: 181634 km
                    Date: 2024.11.30
                    Time: 14:38:26
                    Hex Value: 0x0004
                    Hex Value: 0x0009
                    Count: 7
   Part No SW: 4H0 959 795 D    HW: 4H0 959 795 D
   Component: TSG HL        H06 0276
   Revision: --------    Serial number: 0000081651464
   Coding: 010F1E004000628202083002
   Part No SW: 4H0 907 428 B    HW: 7P6 907 441 D
   Component: TopView       H05 0220
   Revision: 11001001    Serial number: 82330JF0119418
   Coding: 020E000001000000000102000000
   ASAM Dataset: EV_CamerSysteTopViewAUDI 007026
   ROD: EV_CamerSysteTopViewAUDI_007_AU64.rod
   Part No SW: 4H0 959 107 AC    HW: 4H0 959 107 AC
   Component: HDSG-Modul    H12 0046
   Revision: 10012001    Serial number: 308300110 Dataset Number: 4H0909541F  0007
   Coding: 021004C020
   ASAM Dataset: EV_DeckLidContrUnit 001032
   ROD: EV_DeckLidContrUnit.rod
   VCID: 6FBBD918371B7AE2B61-803A
Address 6F: Centr. Conv. II (J773)       Labels:* None
   Part No SW: 4H0 907 412     HW: 4H0 907 412
   Component: ALM           H05 0004
   Revision: --------    Serial number: 000000130565 Dataset Number: 4F0000000__ U001
   Coding: 220000
   ASAM Dataset: EV_Ambie 001008
   ROD: EV_Ambie.rod
   VCID: 6393A528EBD3CE82229-8036
   Component: TSG HR        H06 0276
   Revision: --------    Serial number: 0000081652803
Address 81: Gear Shift (J587)       Labels: 3Y0-927-731.clb
   Part No SW: 4H2 927 731 A    HW: 4H2 927 731 A
   Component: GSM-RL        H08 0083
   Revision: 0R0D5015    Serial number: SN131017  0176
   ROD: EV_GSM2x3Mono_AU64.rod
Address 82: Head Up Display (J898)       Labels:| 4G0-919-604.clb
   Part No SW: 4H0 919 617 A    HW: 4H0 919 617 A
   Component: HeadUpDisplay H08 0019
   Coding: C30000
   ASAM Dataset: EV_HUDContiC7 001025
   ROD: EV_HUDContiC7_AU57.rod
   VCID: 2E05041CF09133EAFD7-807A
   Component: DPC-SG        H26 0081
   Revision: --------    Serial number: 262130025421000 Dataset Number: 4H0909547F  0046
   Coding: EA040000
   ROD: EV_OnBoardCamerDPC.rod
Address 88: Multicont. Seat Driver (J873)       Labels:* None
   Part No SW: 4H0 907 182 H    HW: 4H0 907 182 H
   Component: IVB           H07 0042
   Serial number: 00013616065602 Dataset Number: 4H0909880D  0019
   Coding: 776FF2
   ROD: EV_IVBDriveSideFrnt_AU57.rod
Address 89: Multicont. Seat Pass. (J872)       Labels:* None
   Serial number: 00013616075601 Dataset Number: 4H0909881D  0019
   Coding: 376FF2
   Part No SW: 4H0 907 541 C    HW: 4H0 907 541
   Coding: 7C04010201
   Shop #: WSC 36497 005 1048576
   ASAM Dataset: EV_AdaptCruisContr2AU64X 002021
   ROD: EV_AdaptCruisContr2AU64X_002.rod
   VCID: 290FF700C97F54D2285-807C
                    Reset counter: 160
                    Mileage: 181634 km
                    Date: 2024.11.30
                    Time: 14:38:25
                    Voltage terminal 15: 14.561 V
                    Velocity_vehicle_reference: -0.00 m/s
   Part No SW: 4H0 907 107 F    HW: 4H0 907 107
   Component: BV-SG         H31 0081
   Serial number: 005000210611137 Dataset Number: 4H0909548H  0033
   Coding: 01C22B001111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
   VCID: 2A0D080CCC795FCA21F-807E
0118 - Function Restriction due to Faults in Other Modules
          [Main_Unit_Navigation_Signal_error]
                    Reset counter: 160
                    Mileage: 181634 km
                    Date: 2024.11.30
                    Time: 14:38:27
                    Outside temperature: 13.0  C
                    Voltage terminal 15: 14.8 V
                    Control Module temperature: 25.0  C
   Dataset Number: 4H0909614C  0003
   Coding: 00660600031F0376000308004248D2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   Dataset Number: 4H0909615C  0003
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   Part No SW: 4H0 907 355 C    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H09 0011
   Revision: 00000000    Serial number: 132660586 Dataset Number: 4H0909571E  0015
   ROD: EV_RDCMA00100.rod
End----------(Elapsed Time: 02:55, VBatt start/end: 14.7V/14.7V)-----------
I believe the "Control Module - EEPROM Error" fault refers to the main unit.
Bazza
Scotland
C?ID=438412
Thanks for the reply Uwe.
I forgot to highlight that it also shows a voltage of 11.50 V. I haven't seen this before.
Would it be naïve to hope that fitting a used unit, getting an independent garage to remove the component protection and use the coding from the original unit would cure the problem?
When I get the chance, I will remove the module so I get the exact same part number. They seem to be few and far between and not cheap but I can only hope. A new one is over £4,000 as far as I can tell.
When I bought the car almost 5 years ago, the first time it rained I had a water leak at the top of the windscreen. Although the windscreen was replaced ASAP, I am wondering if water has slowly caused corrosion over time.
Once I get the module out, I will check for damage.
I will keep you posted.
I would hope so to. The biggest catch will be dealing with component protection. In order for a garage to do that, they ODIS and proper authorization from Audi to access the servers...
Bazza
Scotland
C?ID=438412
Thanks Ewe
Think I will bite the bullet and get one.
I had to replace one of the radars with a used one earlier this year (came from Japan). Had to pay £100 for a scan before they would remove the component protection which cost another £100 plus a charge for connection to the server despite me telling them what was wrong (with the help of VCDS of course).
I have seen a unit with the same part number that is shown on the scan (I have not physically seen the unit to double check) and it is claimed to be new. As far as I am lead to believe, a new module would assign itself to the car without needing a visit to a garage with ODIS. Is this correct? It would make life a lot easier even though it would cost a bit more.
Bazza
Thanks Ewe
No, I really don't think so.
-Uwe- (spelled Uniform, Whiskey, Echo)
Bazza
Scotland
C?ID=438412
Sorry Uwe, Please accept my sincere apologies for getting your name wrong.
If the new module will need component protection removing and a visit to a garage with ODIS anyway, I might as well choose a used one on price.
Apart from the obvious radio, sat nav, phone, cruise control and lane assist, do you have any ideas what other systems will be affected if the 5F module is locked due to component protection?
I am also thinking about removing the module to see if there is any obvious damage such as corrosion before ordering a replacement but the thought of pulling everything apart twice does not appeal. Would the car be drivable if the unit was completely removed until I source a replacement?
Bazza
Dr Sheldon
Windsor UK
C?ID=334979
Yes that is very wise and sensible. With regard to the ballache of locating and removing it then - No Pain No Gain !!
I believe so - However , remove the old alone and see for yourself. This is a great forum and resource but you do have to some of the leg work !!
There is some physical limitations that cannot be helped !!
Dr Sheldon
Windsor UK
C?ID=334979
Typo
However, remove the old one and see for yourself.
Bazza
Scotland
C?ID=438412
Thanks for the quick response Dr Sheldon.
I totally agree that this is a great forum and resource and I am willing to some leg work myself but there is no harm in trying to gather as much info from others who may have similar experience before I make a start.
I will of course keep you all updated how I get on to add to the pool of knowledge. May take some time before I get the chance to get things done - I have to work on the car outside (north east Scotland is cold and windy at this time of year) and it is dark when I leave for work and dark when I get home and I work every second weekend.
Bazza
:thumbs:
I've never swapped one of these so I really don't know, sorry.
Bazza
Scotland
C?ID=438412
I have ordered a replacement unit from Ebay and it should arrive at the beginning of next week.
Will keep you updated how things go.
Wish me luck. :)
Bazza
Scotland
C?ID=438412
Thought I would delve in and see if I could get the MMI module out to have a look.
No signs of water damage but looks like I am not the first person to have looked at it.
Will see if I can tidy up this connection before the replacement unit arrives.
Bazza
Bazza
Scotland
C?ID=438412
Out of curiosity, I cleared all the codes and ran another scan.
No surprises considering what has been disconnected including the switches and vents when removing the trim.
What I had not expected was that when I took the car for a short drive, the ACC worked as it should so it does not depend on the other systems but is influenced by them.
Bazza
Scotland
C?ID=438412
I received a replacement 5f module which as far as I could tell was new old stock and never been used. I installed it in the car, cleared fault codes and took this scan.
Monday,16,December,2024,17:40:08:26473
          AC
VIN: WAUZZZ4H3EN010093   Mileage: 181861km-113003miles
0233 - Button or Switch in Operating Unit
          B10C7 07 [00001001] - Mechanical Failure
                    Reset counter: 165
                    Mileage: 181861 km
                    Date: 2024.12.16
                    Time: 17:36:50
   Coding: 0045F7
   Coding: 02004E
   Coding: 020300
   Coding: 7C04010201
   Coding: 0000FC
16773127 - Analog Clock
          U1096 00 [00001001] - No Communications
          [LIN Slave Analoguhr keine Kommunikation]
                    Reset counter: 165
                    Mileage: 181861 km
                    Date: 2024.12.16
                    Time: 17:36:50
   Coding: 80CD077D00
   Voltage stabilizer:
          U1101 00 [00001001] - Active
                    Reset counter: 165
                    Mileage: 181861 km
                    Date: 2024.12.16
                    Time: 17:36:50
                    Voltage terminal 30: 14.6 V
                    Voltage terminal 15: 14.6 V
                    Control Module temperature: 20  C
                    System status: Terminal 15 on
                    Engine running: On
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
   Revision: AA001002
   Coding: 008002
   ROD: EV_SARA2.rod
   Coding: 030000
                    Reset counter: 165
                    Mileage: 181861 km
                    Date: 2024.12.16
                    Time: 17:36:48
   Coding: E00200
   Coding: E00200
   Part No SW: 4H0 035 670 P    HW: 4H0 035 670 P
   Component: H-BNT-EU      H47 0798
   Revision: --------    Serial number: 179G20E7520791
   Coding: 00000000000000000000000000000000000000000000000000
   VCID: 313F1F60E12F2C12E05-8064
   Subsystem 1 - Part No: 8R0 060 884 BK
   Component: EUR 2014  1703
                    Reset counter: 165
                    Mileage: 181861 km
                    Date: 2024.12.16
                    Time: 17:36:51
                    Text: DU902A,Front,M,0,0,6
                    Reset counter: 165
                    Mileage: 181861 km
                    Date: 2024.12.16
                    Time: 17:36:50
                    Voltage: 14.60 V
03175 - Invalid Data Set
                    Reset counter: 165
                    Mileage: 181861 km
                    Date: 2024.12.16
                    Time: 17:36:49
                    Voltage: 14.60 V
02084 - Component Protection
                    Fault Status: 01100101
                    Reset counter: 165
                    Mileage: 181861 km
                    Date: 2024.12.16
                    Time: 17:36:50
                    Reset counter: 165
                    Mileage: 181861 km
                    Date: 2024.12.16
                    Time: 17:36:50
   Coding: 021004C020
   Coding: 220000
   ROD: EV_Ambie.rod
   Coding: C30000
   Coding: EA040000
   Coding: 776FF2
   Coding: 376FF2
   Coding: 7C04010201
   ROD: EV_BC7.rod
   ROD: EV_RGS_L.rod
   ROD: EV_RGS_R.rod
End----------(Elapsed Time: 02:52, VBatt start/end: 14.6V/14.7V)-----------
I changed the coding from all zeros to the coding from the original unit and this is the new scan.
Monday,16,December,2024,18:13:23:26473
          AC
VIN: WAUZZZ4H3EN010093   Mileage: 181867km-113006miles
   Coding: 0045F7
   Coding: 02004E
   Coding: 020300
   Coding: 7C04010201
          U1113 00 [00001000] - -
                    Reset counter: 206
                    Mileage: 181867 km
                    Date: 2024.12.16
                    Time: 18:07:48
                    Control Module temperature: 23  C
                    Voltage terminal 15: 14.626 V
   Coding: 0000FC
                    Reset counter: 166
                    Mileage: 181867 km
                    Date: 2024.12.16
                    Time: 18:07:46
   Coding: 80CD077D00
   Voltage stabilizer:
                    Reset counter: 166
                    Mileage: 181867 km
                    Date: 2024.12.16
                    Time: 18:07:46
                    Voltage terminal 30: 14.7 V
                    Control Module temperature: 26  C
                    Engine running: On
                    IN ZAS_Te_X: On
                    Datenfeld: 0
   Revision: AA001002
   Coding: 008002
   ROD: EV_SARA2.rod
   Coding: 030000
                    Reset counter: 166
                    Mileage: 181867 km
                    Date: 2024.12.16
                    Time: 18:07:44
   Coding: E00200
   Coding: E00200
                    Reset counter: 166
                    Mileage: 181867 km
                    Date: 2024.12.16
                    Time: 18:09:33
                    Reset counter: 166
                    Mileage: 181867 km
                    Date: 2024.12.16
                    Time: 18:09:32
                    Voltage: 14.80 V
                    Reset counter: 166
                    Mileage: 181867 km
                    Date: 2024.12.16
                    Time: 18:09:33
                    Reset counter: 166
                    Mileage: 181867 km
                    Date: 2024.12.16
                    Time: 18:09:33
   Coding: 021004C020
   Coding: 220000
   ROD: EV_Ambie.rod
   Coding: C30000
   Coding: EA040000
   Coding: 776FF2
   Coding: 376FF2
   Coding: 7C04010201
                    Reset counter: 206
                    Mileage: 181867 km
                    Date: 2024.12.16
                    Time: 18:11:43
                    Control Module temperature: 25  C
                    Voltage terminal 15: 14.664 V
   ROD: EV_BC7.rod
                    Reset counter: 206
                    Mileage: 181867 km
                    Date: 2024.12.16
                    Time: 18:11:45
                    Outside temperature: 12.0  C
                    Voltage terminal 15: 14.9 V
                    Control Module temperature: 24.0  C
   ROD: EV_RGS_L.rod
   ROD: EV_RGS_R.rod
End----------(Elapsed Time: 02:51, VBatt start/end: 14.8V/14.7V)-----------
I tried changing the coding back to all zeros so I was at the same starting point but it would not allow this as it was out of range.
Next step is an indy with ODIS I suppose unless anyone has other suggestions.
Bazza
Hardware is the same -- both are 4H0 035 670 P.
But software is quite different. Original is 4H0 035 654 E, version 1072 while the replacement 4H0 035 670 P version 0798. I'm not familiar enough with those to tell you what this means.
No other suggestions. ODIS with an account on Audi's servers to kill the CP, put a dataset in it, and possibly a software update..
Bazza
Scotland
C?ID=438412
Thanks Uwe
This is getting me worried where it will all stop. With the "new" module fitted, I was still getting intermittent ACC and braking guard warnings. Hopefully a function of not being programmed correctly but may be something else causing the issue. I have refitted the original unit as I can at least play music to drown out the "Bing" sounds :). The EEPROM defective alone warrants replacing the module.
When I decided to replace the module, I thought I would just get the maps update from THE NAVMAN but it seems that he has been shut down for some reason. I used him at the beginning of the year because there were many recommendations of his service but not sure who to trust for another update. I was thinking about swapping the hard drives between the modules I have but this may be chancing more pain. Maybe buy a cheap TomTom :)
Bazza
Why not just use Google Maps/Nav on your phone? I've not updated any maps in in-built nav systems in over a decade; the phone is better. Ideally, it's on the car's screen via Android Auto or Apple Car Play, but I'm guessing your 2014 doesn't support that. Still, it should give you nav directions via the car's audio system over bluetooth.
Bazza
Scotland
C?ID=438412
As you suspected, no option for android auto on this car. As you say, keep it simple and use a phone.
I like the car so much that I want to keep it as long as I can.
Can't say I blame you. We have a couple of that vintage / generation that I feel the same way about; one is a 2012 A6 and the other is a 2015 Touareg. The following generation got ridiculous in terms of complexity with mild hybrid nonsense and so on.
