- Jan 16, 2019
- 28
- 12
- Cornwall, UK
- C?ID=358455
Hi, I have a strange code that has appeared as the title. I have followed the advise on the link below but can't seem to clear it. Would appreciate some help if anyone has aly ideas ?
http://wiki.ross-tech.com/wiki/index.php/VW_Golf_VII_(5G/AU)_Instrument_Cluster#Service_Reminder
Please keep it simple as I'm very amateur at this.
Sunday,01,December,2024,11:29:44:44739
VCDS Version: 24.7.1.0 (x64)
Dealer/Shop Name: DOODY CARS
VIN: WVWZZZAUZEP007042 License Plate:
Mileage: 207521km-128947mi Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 13 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZEP007042 Mileage: 207521km-128947miles
Address 01: Engine (J623-CLHA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 M HW: 04L 907 309 B
Component: R4 1,6L EDC H22 5517
Revision: 84H22--- CVN: B53D877B
Coding: 01110012034505092000
Shop #: WSC 00028 028 00072
ASAM Dataset: EV_ECM16TDI01104L906021M 002009
ROD: EV_ECM16TDI01104L997021.rod
VCID: 2F6DC09D76B38FEE62-807A
VINID: 9E69EAAAA465A9580000700408AEF4E366
Part No SW: 5Q0 907 379 AA HW: 5Q0 907 379 G
Component: ESC H31 0457
Revision: 00000000 Serial number: 615030000005DF
Coding: 01FA8AA1242009730377060441C52580512490C06082A4F3F440F074C002
Shop #: WSC 00028 028 00025
VCID: 7BF524CDF24BA34E9E-802E
Address 08: Auto HVAC (J301) Labels:| 5G0-907-426.clb
Part No SW: 5G0 907 426 M HW: 5G0 907 426 M
Component: AC Manuell H01 0705
Revision: 00001K06 Dataset Number: 0000
Coding: 00120104202100001000000000000000
VCID: 3561F2F594EFB53E28-8060
1048834 - Functional Limitation due to Energy Management
B10CD 00 [00001000] - -
Fault Frequency: 13
Reset counter: 53
Mileage: 206728 km
Date: 2024.11.13
Time: 09:27:24
Voltage terminal 30: 11.4 V
Auxiliary heater: in stages-Enabling for auxiliary heater operation: No enabling
Auxiliary heater: in stages-Act.val.: 1
Auxiliary heater: in stages-Target value: 3
Auxiliary heater: in stages-Specified value for control: 3
1048835 - Functionality limited due to Engine Control Module
P1719 00 [00001000] - -
Fault Frequency: 29
Reset counter: 53
Mileage: 206733 km
Date: 2024.11.13
Time: 09:37:38
Voltage terminal 30: 14.0 V
Auxiliary heater: in stages-Enabling for auxiliary heater operation: Enabling stage 3
Auxiliary heater: in stages-Act.val.: 2
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 084 S HW: 5Q0 937 084 S
Component: BCM MQBAB M H14 0112
Serial number: 00011314701031 Dataset Number: 5G0063v____ 0001
Coding: 03000842C24102730BA44080B10403281000000000000000000000000000
ROD: EV_BCMBOSCH_011.rod
VCID: 489F8B01F31D38D643-801C
Subsystem 1 - Part No SW: 5G2 955 119 A HW: 5G2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 130514 042 0551
Serial number: 130523132915
Subsystem 2 - Part No SW: 5Q0 955 559 HW: 5Q0 955 559 Labels: 5Q0-955-547.CLB
Component: RLS 024 0042
Serial number: Y13M06D06H06M21S51S4
Coding: 00A8DD
Component: Sensor, DWA 005 0313
Serial number: 000000000ZY131001SXL
Serial number: 00000000000056818445
B1263 01 [00001001] - Electrical Failure
Reset counter: 210
Terminal 15 status: OFF
Terminal 50 status: OFF
CAN-Bus_aktiv: On
OFF: operated
Position lamps: Not operated
Low beam: Not operated
last_wakeup: gültiges Funktelegramm
Voltage: 12.1 V
Outside temperature: 15.0 °C
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V1.clb
Part No SW: 5Q0 907 572 A HW: 5Q0 907 572 A
Component: ACC Bosch MQB H03 0141
Serial number: 01061376510301 Dataset Number: 5g0114v____ 1009
Coding: 00000300FE0339
ASAM Dataset: EV_ACCMRRBoschVW372 001013
Part No SW: 5Q0 959 655 M HW: 5Q0 959 655 M
Component: AirbagVW20 011 0361
Serial number: 003M1R036D0W Dataset Number: 5G0003v____ 0079
Shop #: WSC 00028 028 00053
VCID: 4A9BB109ED11CAC655-801E
Left seat belt tensioner:
Component: BeltPretRevFL H35 0340
Serial number: 34169677B29051340192
Coding: 333135
Right seat belt tensioner:
Component: BeltPretRevFR H35 0340
Serial number: 34169676B31051340410
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 002 805 13
Serial number: 357670000009A2102D0M
Subsystem 4 - Part No SW: ----------- HW: 480 002 805 13
Serial number: 35867000000089402D0M
Subsystem 5 - Part No SW: ----------- HW: 480 403 105 13
Serial number: 3516502AF105EDD2708O
Subsystem 6 - Part No SW: ----------- HW: 480 403 105 13
Serial number: 3526502AF105EDD402CQ
Subsystem 7 - Part No SW: ----------- HW: 480 402 705 13
Serial number: 3556502BB1050661C21$
Address 16: Steering wheel (J527) Labels:. 5Q0-953-549.clb
Part No SW: 5Q0 953 507 AG HW: 5Q0 953 549 A
Revision: -------- Serial number: 06061304220974 Dataset Number: ----------
Coding: 0D00
Shop #: WSC 40195 333 37120
ROD: EV_SMLSKLOMQB_009.rod
No ASAM data for: "EV_SMLSKLOMQB" (VW37)
Part No SW: 5G0 920 961 A HW: 5G0 920 961 A
Component: KOMBI 252 2210
Coding: 27A41A002780260001882A01040000
VCID: 285F2B81535DD8D6A3-807C
1048578 - No Basic Setting
B2010 00 [00001001] - -
Reset counter: 14
Mileage: 207521 km
Date: 2024.12.01
Time: 10:52:50
Part No SW: 5Q0 907 530 M HW: 5Q0 907 530 M
Component: GW MQB High 212 2147
Revision: -------- Serial number: 31051310800412 Dataset Number: 5G0067v____ 1407
Coding: 030100040B087300EF00005C080F00010001000000000000000000000000
GVL: 01503C0000000000400C80000000480000000000000000000000000000000000
ASAM Dataset: EV_GatewConti 009011
ROD: EV_GatewConti_009.rod
VCID: 3B75E4CDB2CB634EDE-806E
Generator:
Subsystem 2 - Part No SW: 5G0 959 442 K HW: 5G0 959 442 K Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H14 0035
Serial number: 27130000599140053192
Coding: 2C0000
Subsystem 3 - Part No SW: 5Q0 915 181 C HW: 5Q0 915 181 C
Component: J367-BDMHella H03 8042
Serial number: 7784760603
Part No SW: 5Q4 959 393 HW: 5Q4 959 393
Component: TSG FS 007 0006
Serial number: 0000062852575 Dataset Number: 5G0222v____ 0042
Coding: 003002208001028000001000
ROD: EV_DCUDriveSideEWMAXKLO.rod
VCID: 55A1527534AF953EC8-8000
Subsystem 1 - Part No SW: 5Q4 959 812 A HW: 5Q4 959 812 A Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG DRV 007 0002
Serial number: 00000000000001586000
Coding: 0D0000
Part No SW: 5Q0 909 144 L HW: 5Q0 909 144 L
Component: EPS_MQB_ZFLS 119 1021
Dataset Number: 5G0074v____ 0128
Coding: 81
ROD: EV_SteerAssisMQB_008.rod
VCID: 3D71EAD5ACDF6D7EE0-8068
Part No SW: 5Q4 959 392 HW: 5Q4 959 392
Component: TSG BFS 007 0006
Serial number: 0000062597701 Dataset Number: 5G0157v____ 0046
Coding: 003000208001028000801000
ROD: EV_DCUPasseSideEWMAXKLO.rod
VCID: 7F0DD0DDE653BF6EB2-802A
Subsystem 1 - Part No SW: 5Q4 959 811 A HW: 5Q4 959 811 A Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 007 0002
Serial number: 00000000000001591646
Coding: 050000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD1.clb
Part No SW: 5G0 035 820 A HW: 5G0 035 820 A
Component: MU-S-D-ER 040 0421
Serial number: V5C00306130506 Dataset Number: 5G0CV1v____ 0001
Coding: 02730000FF00000021111201002800001F0100060100010001
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 1F4D305D06131F6ED2-804A
Subsystem 1 - Part No SW: 5G0 919 605 HW: 5G0 919 605
Component: ABT_Std_Radio H44 0020
Serial number: VWZ8Z9N24035BG
End-------------------------(Elapsed Time: 03:24)--------------------------
Sunday,01,December,2024,12:13:34:44739
Coding: 00A8DD
Coding: 333135
Coding: 333135
Coding: 0D00
Reset counter: 14
Mileage: 207521 km
Date: 2024.12.01
Time: 11:55:39
Generator:
Coding: 2C0000
Coding: 0D0000
Coding: 81
Coding: 050000
End-------------------------(Elapsed Time: 03:27)-------------------------->
