Hi
I see lots of posts about memory seat functions but have got really confused now. My wife is 5'2" and I am 6'2", on our A6 the memory function was great but in the S5 coupe it doesn't have the memory buttons. I believe the coupe may have the other hardware needed and I was wondering if I enable this somehow in the long coding it may work with the key fobs.
I have looked on the MMI and under car settings/seats it has entry assist ticked but that doesn't seem to do anything either.
Any advice greatly appreciated.
Saturday,30,November,2024,13:26:43:00013
VCDS Version: 24.7.1.0 (x64) HEX-V2 CB: 0.4643.4
VIN: WAUZZZF50HA039436 License Plate:
Chassis Type: F5-AU49 (8W5)
Scan: 01 02 03 06 08 09 15 16 17 19 29 2B 36 39 42 44 46 47 52 5F
81 A5 A9 D6 D7
VIN: WAUZZZF50HA039436 Mileage: 57076km-35465miles
Address 01: Engine (J623-CWGD) Labels:. 06M-907-309-V1.clb
Part No SW: 8W0 907 559 G HW: 06M 907 309 D
Component: V6 3.0l TFSI H21 0010
Revision: B2H21000 CVN: 827C02BD
Coding: 1A2A00322326050B34080000000000000000000000000000
Shop #: WSC 34307 001 1048576
ASAM Dataset: EV_ECM30TFS0118W0907559G 001013
ROD: EV_ECM30TFS0118W0907559G.rod
VCID: 49CEA2DC69390292C85-801C
VINID: 9D196AAAA5850184400C9103180427B0C6
30201 - Control Module for Exhaust Flap
P14AB 00 [01100100] - Mechanical Malfunction
Mileage: 55899 km
Date: 2024.04.24
Time: 15:22:18
Engine RPM: 1260.00 /min
Normed load value: 5.9 %
Vehicle speed: 25 km/h
Coolant temperature: 96 °C
Intake air temperature: 21 °C
Voltage terminal 30: 13.020 V
Engine status: COENG_RUNNING
Part No SW: 8W0 927 158 B HW: 0D5 927 156 H
Component: 0D5 30TSIRdW H05 1007
Revision: --H05--- CVN: 9E0C67C9
Coding: 100000
ASAM Dataset: EV_TCMALX52011 002010
ROD: EV_TCMALX52011.rod
VCID: 41DEBAFC5109CAD2105-8014
Address 03: ABS Brakes (J104) Labels: 8W0-907-379-PLU-V1.clb
Part No SW: 8W0 907 379 G HW: 8W0 907 379 J
Component: ESP9 Plus H06 0719
Dataset Number: 8W2909504B 0003 CVN: B085950A
Coding: 1CAA149A30A50A9F11A2489400835292E6A5D238280C508812004A4967A54B
Shop #: WSC 06324 790 00001
ASAM Dataset: EV_ESP9BOSCHCMP 001001
ROD: EV_ESP9BOSCHCMP_001.rod
7 Faults Found:
12615680 - FlexRay Databus
U0080 00 [00100000] - Defective
[FlexRay_controller_is_not_sychronous_to_the_bus]
420352 - TPMS Warning; Front Left Tire
C1054 00 [00101000] - Pressure too Low
Mileage: 56484 km
Date: 2024.09.29
Time: 12:57:14
96 00 00 18 88 24 00 00 F0 70
416768 - TPMS Warning; Front Right Tire
C1056 00 [00101000] - Pressure too Low
Mileage: 56484 km
Date: 2024.09.29
Time: 12:57:14
420096 - TPMS Warning; Rear Left Tire
C1058 00 [00101000] - Pressure too Low
Mileage: 56484 km
Date: 2024.09.29
Time: 12:57:14
417024 - TPMS Warning; Rear Right Tire
C105A 00 [00101000] - Pressure too Low
Mileage: 56484 km
Date: 2024.09.29
Time: 12:57:14
415488 - TPMS Warning; Front Left Tire
C1055 00 [00100000] - Flat
419328 - TPMS Warning; Front Right Tire
C1057 00 [00100000] - Flat
Address 06: Seat Mem. Pass (J521) Labels:* None
Part No SW: 4M0 959 760 A HW: 4M0 959 760 A
Component: MEM-BFS 008 0031
Serial number: 00000253853795 Dataset Number: 8W2909866B 0011
Coding: 00321004000CB0010003010141010000000000000000000000000000802003
Shop #: WSC 06325 790 00001
ASAM Dataset: EV_SCMPasseSideCONTIAU736 006009
ROD: EV_SCMPasseSideCONTIAU736_AU49.rod
VCID: 3634D92008C77D6AB57-8062
Address 08: Auto HVAC (E87) Labels:* Redir Fail!
Part No SW: 8W0 820 043 T HW: 8W0 820 043 T
Component: Klima Zone 3 H55 0205
Coding: 4608000D5544440D02020100880000000000000000000000000000000000
Shop #: WSC 06335 790 00001
ROD: EV_AirCondiBHTCAU491.rod
VCID: 44D0B3E84E1BDFFA3B3-8010
Subsystem 1 - Part No SW: 4M1 820 021 A HW: 4M1 820 021 A
Component: J216 FLuftV H08 0003
Serial number: 00000000000001470948
Humidity sensor: exterior:
Subsystem 2 - Part No SW: 4H0 907 658 A HW: 4H0 907 658 A
Component: AQ_Hum_Sensor H01 0006
Serial number: 6E7806A880PAG0MUFU02
Subsystem 3 - Part No SW: 8W0 919 158 HW: 8W0 919 158
Component: E265 Kli Fond H40 0080
131078 - Reference Voltage
B10AD 16 [00001001] - Voltage Too Low
Reset counter: 125
Mileage: 43155 km
Date: 2022.02.10
Time: 08:24:23
Voltage terminal 30: 12.06 V
Outside temperature: 4.50 °C
327971 - Motor for Fresh Air / Recirculated Air Flap
B11AF 07 [00001000] - Mechanical Failure
Reset counter: 101
Mileage: 56369 km
Date: 2024.09.05
Time: 14:25:07
Fresh-air door motor / specified value: 11132
Fresh air flap motor: actual value: 11217
System run time-Engine running time: 106 s
System run time-Terminal 15 on: 108 s
Fresh air flap motor: diagnostic-Last operating state: No routine started
Fresh air flap motor: diagnostic-Operating condition: Blocking handling
Voltage terminal 30: 15.08 V
Outside temperature: 21.00 °C
0386 - Functional Limitation due to Energy Management
B10CD 00 [00001001] - -
Reset counter: 71
Mileage: 57076 km
Date: 2024.11.30
Time: 13:20:43
Address 09: Cent. Elect. (J519) Labels:* Redir Fail!
Part No SW: 8W0 907 063 CG HW: 8W0 907 063 BG
Component: BCM1 MLBevo H13 0267
Dataset Number: 8W2909514D 0032
Coding: 07501143E17900CD050D8F151BAD84F9110B3104000000000000000020001A810A450122025601
VCID: 025C75F0148F11CA49F-8056
Subsystem 1 - Part No SW: 8W6 955 119 A HW: 8W6 955 119 A
Component: 494 RL 170309 036 0471
Serial number: 00000001703040300294
Coding: 5FC7F7
Serial number: 20392869X81A955555A0
Coding: 02005D
Subsystem 3 - Part No SW: 4M0 941 531 AA HW: 4M0 941 531 AA
Component: E1 - LDS H06 0008
Serial number: 27 02 2017 00801246
Subsystem 4 - Part No SW: 8W0 857 511 HW: 8W0 857 511
Component: Y7_Innenspieg H09 0002
Serial number: GX1CE106021723610006
Coding: 230000
Interior Light Module:
Subsystem 5 - Part No SW: 8W0 947 135 BQ HW: 8W0 947 135
Component: J528-Dachele H14 0130
Serial number: B00346966
Subsystem 6 - Part No SW: 8W0 925 301 BC HW: 8W0 925 301 BC
Component: SL-B9/Q5NF H17 0010
Serial number: 2617000018950006
Valve block 1 in front seat driver side:
Subsystem 7 - Part No SW: 8W0 907 182 HW: 8W0 907 182
Component: J873 MKS_FSv H03 0033
Serial number: 7008174235B171018610
Coding: BF0500
Valve block 1 in front seat passenger side:
Subsystem 8 - Part No SW: 8W0 907 182 HW: 8W0 907 182
Component: J872 MKS_BFSv H03 0033
Serial number: 7008174235B171120600
Coding: B30500
Address 15: Airbags (J234) Labels:| 8W0-959-655.clb
Part No SW: 8W0 959 655 F HW: 8W0 959 655 F
Component: Airbag10.44 H03 0106
Serial number: 003UP004ESL$ Dataset Number: 8W2909602AC 0007
Coding: AACCF0C00C800000585000F3D0CC00000000
ASAM Dataset: EV_AirbaAU10BPAAU736 006015
ROD: EV_AirbaAU10BPAAU736_006.rod
VCID: 4CC09BC8664B17BAF33-8018
Subsystem 1 - Part No SW: ----------- HW: 442 061 104 17
Serial number: 3577Y00B92246100D28S
Subsystem 2 - Part No SW: ----------- HW: 442 061 104 17
Serial number: 3587Y00BB2246100E25T
Subsystem 3 - Part No SW: ----------- HW: 442 0B2 104 17
Serial number: 3517700A525E5CE5B39W
Subsystem 4 - Part No SW: ----------- HW: 442 0B2 104 17
Serial number: 3527700A525E5CE0B2FX
Subsystem 5 - Part No SW: ----------- HW: 442 0C0 804 17
Component: FrontSensor_D 1C5 014A
Serial number: 3557500B521CB432A3AD
Subsystem 6 - Part No SW: ----------- HW: 442 0C0 804 17
Component: FrontSensor_P 1C5 014A
Serial number: 3567500B521CB43652DF
Subsystem 7 - Part No SW: ----------- HW: 442 0C2 104 17
Component: PedP_Sensor_C 1C5 014A
Serial number: 2307500A522BF6F2339E
Subsystem 8 - Part No SW: ----------- HW: 442 430 504 17
Component: PedPSensor_D2 256 0887
Serial number: I0M9M00B921303C180F7
Subsystem 9 - Part No SW: ----------- HW: 442 430 504 17
Component: PedPSensor_P2 256 0887
Serial number: I0N9M00B921303C1A465
Part No SW: 4M0 907 129 HA HW: 4M0 907 129 HA
Component: Lenks.Modul H11 0009
ROD: EV_SMLSKLOAU736_006.rod
VCID: 76B4192048473D6A757-8022
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI2
Part No SW: 8W5 920 790 C HW: 8W5 920 790 C
Component: FBenRDW H17 0313
Coding: 24AD19DA288006000123E9601000000000000000
ASAM Dataset: EV_DashBoardAU736 001022
VCID: 42DCB5F0540FD1CA09F-8016
16777024 - No Communication with Diagnostic Gateway
U0146 00 [00001000] - -
[BCME_0x23 communication error bap_error_timeout heartbeat]
Reset counter: 82
Mileage: 53588 km
Date: 2023.11.01
Time: 16:22:24
Part No SW: 8W5 907 468 D HW: 8W5 907 468 C
Component: Gateway H30 0308
Revision: 5A010004 Serial number: 0485A290917425 Dataset Number: 8W2909515B 0028
Coding: 0301000100008640540700000059001268100007000000000175078E10000000
GVL: 01503C100000020040BC08000000C80000080000000000000000000000000000
ASAM Dataset: EV_CGateCONTIAU491 002040
ROD: EV_CGateCONTIAU491_002_AU49.rod
VCID: 4ACC9DD06C3F098AC1F-801E
Subsystem 1 - Part No SW: 8W0 951 523 F HW: 8W0 951 523 F
Component: J453 MFL H04 0002
Serial number: 20170419174941 01029
Subsystem 2 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Serial number: 0467483804
8519683 - Energy Management Active
U140B 00 [00001001] - -
Reset counter: 71
Mileage: 56380 km
Date: 2024.09.11
Time: 22:18:22
EM_vehicle_state: 00 00
Static current shut-off stage: Deactivation stage 1
Auxiliary heater activation restriction request-Parking heater: Permitted
Auxiliary heater activation restriction request-Allowed parking heater runtime: 0 min
Address 29: Left Light (J1018) Labels: 4M0-907-397.clb
Part No SW: 4M0 907 397 AB HW: 4M0 907 397 B
Component: LCM_MLBevoH05 0024
Dataset Number: 8W2909519A 0002
VCID: 77AA14244F4D44626E1-8022
Address 2B: Steer. Col. Lock (J764) Labels:| 1EA-905-861.clb
Part No SW: 3Q0 905 861 A HW: 3Q0 905 861 A
Component: ELV-MLBevo H05 0032
Serial number: 17000082475014
Coding: 8800000000000000
ROD: EV_ELVMarquMQBB_VW37.rod
VCID: 323CE530E4AF614A99F-8066
Component: MEM-FS 008 0031
Serial number: 00000255522220 Dataset Number: 8W2909856B 0013
Coding: 00621004000CB0010003010141010000000000000000000000000000802003
Address 39: Right Light (J1023) Labels: 4M0-907-397.clb
Dataset Number: 8W2909520A 0002
Part No SW: 4M0 959 793 E HW: 4M0 959 793 C
Component: TSG FS 009 0057
Serial number: 0000254883361 Dataset Number: 8W2909872A 0018
Coding: 005F4A425001000500003482
ROD: EV_DCU2DriveSideMAXHCONT_AU37.rod
VCID: 40D8BFF85A03C3DA1FB-8014
B1487 54 [00001000] - Missing Calibration / Basic Setting
Reset counter: 101
Mileage: 56319 km
Date: 2024.07.16
Time: 17:26:06
Part No SW: 8W0 909 144 G HW: 8W0 909 144 B
Component: EPS_MLBEVO_ZF H08 0409
Dataset Number: 8W2909852N 0026
Coding: 09000380008000
ASAM Dataset: EV_EPSZFAU49X 003018
ROD: EV_EPSZFAU49X_003.rod
Part No SW: 8W0 907 064 CB HW: 8W0 907 064 B
Component: BCM2 MLBevo 018 0344
Dataset Number: 8W2909501B 0026
Coding: 013300002F9000006309A0000600000233020010004306502F04000000040030201F0001000000
ASAM Dataset: EV_BCM2HellaAU736 012013
ROD: EV_BCM2HellaAU736_012_AU49.rod
VCID: 7EA401006077752A2D7-802A
Subsystem 1 - Part No SW: 5Q0 951 177 HW: 5Q0 951 172
Serial number: 000000000ZY170900C2D
Subsystem 2 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000069424532
131120 - Remote key 1
B1479 18 [00001001] - Current Too Low
Reset counter: 66
Mileage: 56817 km
Date: 2024.11.14
Time: 10:49:57
Supply voltages-Terminal 30 power supply: 12.147 V
Supply voltages-Supply voltage Terminal 30 - 2: 12.147 V
Supply voltages-Supply voltage Terminal 30 - 3: 12.106 V
general_additional_freeze_frame-terminal_control_intern_status: 40 04 42 10 04 80
key_error_freeze_frame: 01011001 11111111 11111111 11111111
Part No SW: 8W0 035 465 HW: 8W0 035 465
Component: MIB2_amp_P_B9 H11 0420
Revision: 00000001 Serial number: AUZ8ZAHJA01QK28 Dataset Number: 8W2909510A 0007
Coding: 0194040800AFAAAFAA0000010000
ASAM Dataset: EV_AMPMst16C2Gen2ALPI 001012
ROD: EV_AMPMst16C2Gen2ALPI.rod
Part No SW: 4M0 959 792 E HW: 4M0 959 792 C
Component: TSG BFS 009 0057
Serial number: 0000255187293 Dataset Number: 8W2909873A 0018
Coding: 005F4A425C01000500003480
ROD: EV_DCU2PasseSideMAXHCONT_AU37.rod
VCID: 3FDABC0427FDBC22661-806A
196630 - Heated Exterior Mirror
B11F8 14 [00001000] - Open or Short to Ground
Fault Frequency: 142
Reset counter: 111
Mileage: 54685 km
Date: 2024.01.25
Time: 14:36:51
Reset counter: 80
Mileage: 55370 km
Date: 2024.04.04
Time: 16:35:59
Address 5F: Information Electr. (J794) Labels:* 8W0-035-MIB-HGH2.clb
Part No SW: 8W5 035 035 HW: 8W5 035 035
Component: MU-P-LND-EU 033 0917
Serial number: A829E0HB020539 Dataset Number: 8W2909545D 0030
Coding: 019454010000000053111102000A00102F0012E701700100DE
VCID: 74B023285E3B2F7A4B3-8020
Subsystem 1 - Part No SW: V03 959 802 DF HW: -----------
Component: ECE 2019/2020 --- 0177
Multimedia System 1:
Subsystem 2 - Part No SW: 8W2 919 605 HW: 8W2 919 605
Component: AU49x_DU_HIGH H40 0008
Serial number: AUZ8Z9HBK00H3W
Subsystem 3 - Part No SW: 8W0 919 614 T HW: 8W0 919 614 T
Component: ControlUnit_H H30 0206
Serial number: APVAK130031700040634
Compact disc data bank:
Component: Gracenote2 --- 1015
5688 - Control Head for Mulimedia System
B13C9 F2 [00001000] - On/Off Switch
Reset counter: 97
Mileage: 55661 km
Date: 2024.04.17
Time: 07:15:47
Voltage terminal 30: 15.1 V
6669 - Optical Data Bus for Digital Sound System
U10CC 00 [00001000] - Intermittent Disruption
[Optical data bus: sporadic open circuit in sound]
Reset counter: 95
Mileage: 56174 km
Date: 2024.06.13
Time: 16:50:50
Voltage terminal 30: 11.9 V
Temperature of MOST transceiver-max.value: -50 °C
Temperature of MOST transceiver-min.value: -11 °C
Temperature of MOST transceiver-Up-to-date: 15 °C
7219 - Function Restricted due to Missing Message(s)
U1111 00 [00001000] - -
[Emergency call module (0x33) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 89
Mileage: 55981 km
Date: 2024.05.06
Time: 20:07:27
Voltage terminal 30: 14.6 V
BAP-BAP_Function_ID: 10
Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb
Part No SW: 8W2 713 041 K HW: 4M2 713 041 F
Component: GSM-LL H09 0073
Revision: 0L0D5012 Serial number: 20170315002356
ASAM Dataset: EV_GSMWaehlZFAU736 001016
ROD: EV_GSMWaehlZFAU736_AU49.rod
VCID: 3C20CB0836EBA73A433-8068
Address A5: Frt Sens. Drv. Assist (R242) Labels:* Redir Fail!
Part No SW: 8W6 907 217 A HW: 8W6 907 217 A
Component: BVS H15 0050
Dataset Number: 8W2909466C 0018
Coding: 0404090400000403024023A0A50000FC00F0C020C020
ROD: EV_BVSMLBevKOSTAAU736_002_AU49.rod
Part No SW: 8W0 907 159 F HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0005
Serial number: 170403200662
Part No SW: 7PP 941 572 AC HW: 7PP 941 572 A
Component: LED1L H09 0008
Dataset Number: 8W2909471A 0008
VCID: 176A34A46F0DA4628E1-8042
Component: LED1R H09 0008
Dataset Number: 8W2909472A 0008
End----(Elapsed Time: 01:51, VBatt start/end: 11.2V/11.2V. VIgn 11.2V)-----
