Door handle sensors stop working after every reset
NenNen
Pirate
Walking the Plank
Bulgaria
LP/IP
Hi every one. I have a strange problem with my AUDI S5 B8 2009 door keyless sensors. I have changed new door handle sensors and deleted error code via VCDS then it work once only and fail again after every one time drive
Every time if I need to make it work again I need to delete error code again.
IMPORTANT THINGS I NOTES:
If the car engine is not running,both sensors works perfect open and close door many times and all works
If i start engine and after short drive stop it, sensors stop works too
When i check VCDS log i notes the time when error code was printed and the sensors stop working.Every time i open the door, let say 8:00:00, the time when code was printed is 8:00:04
If the door is open after engine stopped, sensors stop working. Then i erase the error code and sensors start work again
If the door is open ten or twenty times when engine is not working, sensors works perfect until i start engine den stopped and open the door.
I do this exercise many days trying to understand the reasons why sensors stop, and I have no idea what's going on.One thing is 100% sure, both sensors works,but something block it every time i open the door when the car engine stop running.
Please help
This is the only error on VCDS log
Log deleted according forum rules.
