B8.5 S4 - Enable Ambient Interior Lighting Control - 11-29-24
raceshop147
Connecticut
C?ID=559829
Hello
Trying to Enable Adjustable Ambiance/Background lighting (Foot Lighting)
There are two stages to this, one is enabling the Ambiance lighting and the second is activating the menu to control the brightness.
[Hidden menu] [car] [carmenuoperation] [interior light] Set to 5
[Hidden menu] [car] [cardevicelist] [interior light] Enable
Reset MMI
Was able to get the “interior lighting” option to come up on my MMI (version HN+_US_AUSG_P0733) but it is grayed out and cannot be accessed “the selected system is currently not available”
Fyi- These were both selected in the green menu and the MMI was reset
After reset I opened up the VCDS
Enable Ambiance Lighting.
[09 – Cent. Elect.]
[Coding - 07] -> Long Coding Helper -> Byte 16 Bit 6 - Set this bit manually to “1” - (1 = active)
My options are:
Bit 4 Load monitoring front footwell lighting active
Bit 5 Load monitoring rear footwell lighting active
Bit 6 Ambientlighting active/installed
Bit 7 Ambient lighting via MMI/Car Menu
Enabling the MMI Menu
MMI
[56 - Radio]
[Coding - 07] -> Long Coding Helper -> Byte 8 Bit 7 - Interior Light Settings active - (1 = active)
MMI
Code: Enable the Interior lighting (extended) MMI item:
[07 - Control Head]
[Adaptation - 10] -> Channel 1 add 2 to the existing value
Control head was “no response from controller” multiple times
Not sure what I’m doing wrong but I have a grayed out interior lighting option I am trying to access to get this to work
Here is my scan data:
Friday,29,November,2024,10:06:06:39951
Dealer/Shop Name: raceshop147
VIN: WAUDGAFL0FA014811   License Plate: N1CK
Mileage: 192810km-119806mi   Repair Order: RS147-07
Chassis Type: FL-AU48 (8R0)
Scan: 01 03 05 08 09 15 16 17 19 22 36 3C 42 44 46 47 52 53 56 5F
          62 6C 72 A9
VIN: WAUDGAFL0FA014811   Mileage: 192810km-119806miles
Address 01: Engine (J623-CTUB)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 8K5 907 551 G    HW: 4G0 907 551 A
   Component: 3.0l V6 TFSIH07 0007
   Revision: --H07---    CVN: 96197FE3
   Coding: 0A190034052600060000
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM30TFS0218K5907551G 001007
   ROD: EV_ECM30TFS021_AU48.rod
   VCID: 3A2D236C0CD6592A51F-806E
   VINID: 9D19545D159C016440044201040B430CE7
Readiness: 0000 0100
Address 03: ABS Brakes (J104)       Labels:. 8K0-907-379-V2.clb
   Part No SW: 8K0 907 379 CP    HW: 8K0 907 379 CP
   Component: ESP8 quattro  H09 0020
   Coding: 281D1A01
   Shop #: WSC 06325 000 00000
   VCID: 094F8CA0193082B2085-805C
   Part No SW: 8K0 907 064 JM    HW: 8K0 907 064 JM
   Component: BCM2 2.0      H14 0650
   Coding: 0F814040000000000000
   VCID: 04519D943E12DFDA7B3-8050
   Subsystem 1 - Part No SW: 8K0 959 754 BB    HW: 8K0 959 754 BB
   Serial number: 0814000086284002
   Serial number: 0214000108797008
Address 08: Auto HVAC (J255)       Labels:. 8Kx-820-043-3Z.clb
   Part No SW: 8K1 820 043 AQ    HW: 8K1 820 043 AQ
   Revision: C1000000    Serial number: 01130620142186
   Coding: 6600228000
   VCID: 77ABFA587FC484426E1-8022
   Part No SW: 8K0 907 063 DH    HW: 8K0 907 063 DH
   Revision: 08016001    Serial number: 00000838730601
   Coding: 26000035853CAFE0240249C300003D0D0F9C9308A2090221000008004000030100000030000000
   Shop #: WSC 06325 123 12345
   VCID: 78A9F96472DA8B3A67B-802C
   Subsystem 1 - Part No SW: 8K1 955 119 B    HW: 8K1 955 119 B  Labels: 1KX-955-119.CLB
   Component: MITSUBA280414  H18 0461
   Serial number: 1404250701566
   Coding: 004577
   Serial number: 22759946
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000000506141794
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R96EA03
   Serial number: 03484337000000000001
   Part No SW: 8K0 959 655 Q    HW: 8K0 959 655 Q
   Component: AirbagVW-AU10 H51 0812
   Serial number: 003NDD124HC2   Dataset Number: 8K0909602R  0001
   Coding: 303844354730383131304A55304C384B3053
   Shop #: WSC 56311 001 1048576
   ASAM Dataset: EV_AirbaECUVWAUDI010 003114
   VCID: 4BC376A8534CD0A2FA9-801E
   Subsystem 1 - Part No SW: 8K0 959 339 C    HW: 8K0 959 339 C
   Serial number: 5810000R140000GRPC
   Serial number: 6334MSME457A4027C
   Serial number: 6344MSME45393349E
   Serial number: 6352QSME7740485AM
   Serial number: 6362QSME30452050/
   Serial number: 63732SME63410944U
   Serial number: 63832SME32462160O
   Part No SW: 8K0 953 568 M    HW: 8K0 953 568 M
   Revision: --------    Serial number: 90372NFC000HX
   Coding: 000016
   VCID: 44D15D947E921FDA3B3-8010
   Part No SW: 8K0 920 983     HW: 8K0 920 983
   Component: KOMBIINSTR.   H35 0564
   Revision: 00100000    Serial number: ZAI7AN96F
   Coding: 83B509008301D705020000
   VCID: 72BDCB4C14A6E16A59F-8026
   Part No SW: 8R0 907 468 P    HW: 8R0 907 468 D
   Component: GW-BEM 5CAN-M H11 0060
   Revision: 1Z120030    Serial number: 3041Z146120578
   Coding: 80C303FF00
   VCID: 4CC175B456C2D79AF33-8018
   Serial number: 3142063603
Address 22: AWD (J492)       Labels: 8K0-907-163.clb
   Part No SW: 8K0 907 163 B    HW: 8K0 907 163 A
   Component: 4 Wheel Drive H15 0100
   Serial number: 000306140001035 Dataset Number: 8K0909104D  0025
   VCID: 2F3B0238C7948C82F61-807A
   Component: MEM-FS        H06 0077
   Revision: AA000000    Serial number: 00000105596604
   Coding: 00581B00000000000000
   VCID: 3B232668036C60224A9-806E
   Part No SW: 8T0 907 566 B    HW: 8T0 907 566 B
   Serial number: 0336289139 Dataset Number: 8K0909535J  0029
   Coding: 010211
   Shop #: WSC 06324 000 00000
   VCID: 3FDB527817F47C02661-806A
   Subsystem 1 - Part No SW: 8T0 907 568 B    HW: 8T0 907 568 B
   Component: SWA Slave  H05 0071
   Serial number: 0337550543
   Coding: 010211
   Part No SW: 8T0 959 793 P    HW: 8T0 959 793 G
   Component: TSG FA        H09 0305
   Coding: 011C13204E00410001
   VCID: 56F597DC980E9D4A557-8002
   Part No SW: 8K0 909 144 J    HW: 8K0 909 144 B
   Component: RCEPS         H40 0509
   Revision: 00001000    Serial number: 0001646515 Dataset Number: 8K0909852K  0025
   Coding: 100000010001
   ASAM Dataset: EV_RCEPSAU48X 008016
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 3829396432DA4B3AA7B-806C
   Revision: 00002001    Serial number: 0338032396
   Coding: 0106143A00FA40458130013200000000
   Shop #: WSC 06324 123 12345
   Component: GTO BF  H01 0080
   Serial number: 00000000000000849750
   Subsystem 3 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
   Component: J245 PS050  H08 0043
   Revision: 00005001    Serial number: 94813030966905
   VCID: 2D071830CD18FE92C4D-8078
   Part No SW: 8T0 959 792 P    HW: 8T0 959 792 G
   Component: TSG BF        H09 0305
   Shop #: WSC 06342 000 00000
   VCID: 55F790D0850896525CD-8000
   Component: EPB-4         H02 0005
   Revision: --------    Serial number: 20000000461176
   ROD: EV_ParkiBrake_AU48.rod
   Revision: AB001007    Serial number: 156F.0E8022872
   Coding: 020007010000000001
   VCID: 2411FD149ED23FDA1B3-8070
   Part No SW: 8R1 035 746 F    HW: 8R1 035 746 D
   Component: H-BNT-NA      H41 0812
   Revision: --------    Serial number: 204FT0EB009331
   Coding: 110200000206A1EF55028B5E00000403140000000000000000
   VCID: 3A2D236C0C56592A51F-806E
   Subsystem 1 - Part No: 8R0 060 884 CA
   Component: NAR 2014  1002
   Component: DU7 High  H42 0104
   Serial number: A130FL0E3056313
   Subsystem 3 - Part No SW: 8T0 919 611 L    HW: 8T0 919 611 C
   Serial number: 00000001896085
   Component: CD-Database  5950
   Part No SW: 8T0 959 795 Q    HW: 8T0 959 795 H
   Component: TSG HL        H07 0305
   Coding: 010C13204000210001
   VCID: 59EF9CE0E910B232785-800C
   Revision: --H09---    Serial number: 525PA8-J449148
   Coding: 1000006
   VCID: 382939643E5A4B3AA7B-806C
   Component: TSG HR        H07 0305
   Part No SW: 8K0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0005
   Serial number: 140521202342
   VCID: 72BDCB4C1426E16A59F-8026
raceshop147
Connecticut
C?ID=559829
Checking back in on this to see if any one can support thank you
raceshop147
Connecticut
C?ID=559829
Is there a way to get this option to function?
