Hi guys.
I drove to work today and my Audi A5 2019 2,0TDI (140kW) let me down.
First it wanted to keep too high gear every uphill and later the power start to disappear (about 2 kilometers after the first symptom).
"The power transmission fault" appeared on the instrument panel (I don't know is right translate because I have finnish language user interface on the car).
The engine was running with a rather rough sound before it shut off completely.
The tow truck brought the car home and I just went to read the fault codes.
This is it. Few meters long
Friday,29,November,2024,16:38:07:58500
VCDS Version: 24.7.1.0 (x64) HEX-V2 CB: 0.4643.4
Dealer/Shop Name: Aalto Special Motors
VIN: WAUZZZF53KA027692 License Plate: BVU-829
Mileage: 232683km-144582mi Repair Order:
Chassis Type: F5-AU49 (8W5)
Scan: 01 02 03 08 09 15 16 17 18 19 29 39 42 44 46 52 5F 69 6D 81
A5 AC BB BC D6 D7
VIN: WAUZZZF53KA027692 Mileage: 232683km-144582miles
AC-Reductant Control -- Status: Malfunction 0010
Address 01: Engine (J623-DETA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 PP HW: 04L 907 309 L
Component: R4 2.0l TDI H36 6277
Revision: B1H36--- CVN: 9D55CE97427F2E01500CA509500CA509
Coding: 0A25403A2336050834000000000000000000000000000000
Shop #: WSC 06314 790 00001
ASAM Dataset: EV_ECM20TDI01104L906026PP 005004
ROD: EV_ECM20TDI01104L906026PP.rod
VCID: 074B95B24FA37C721E1-8052
VINID: 9D196AAAA5850DB44008718908657BBDB9
19 Faults Found:
4794 - Mass Air Flow Sensor (G70)
P0101 00 [01100101] - Implausible Signal
Mileage: 232681 km
Date: 2024.11.29
Time: 07:28:48
Engine RPM: 2149.50 /min
Vehicle speed: 57 km/h
Coolant temperature: 84 °C
Intake air temperature: 51 °C
Voltage terminal 30: 14.920 V
Mass airflow sensor 1 bank 1 airflow: raw value: 377.4 mg/stroke
Standardized airflow ratio: filtered: 1.4221
Exhaust recirc.valve 1 bank 1: posit.feedback - Actual value: 0.00 %
Throttl.valve adapt. 1 bank 1: posit feedback - Actual value: 0.00 %
Charge air pressure: specified value: 782 hPa
Charge air cooler inlet: pressure sensor 1 bank 1: raw value: 1132.2 hPa
Mean injection quantity: 0.00 mg/stroke
19226 - Particulate Trap Bank 1
P2002 00 [01100101] - Efficiency Below Threshold
Mileage: 232665 km
Date: 2024.11.28
Time: 21:41:31
Engine RPM: 1541.00 /min
Normed load value: 69.4 %
Vehicle speed: 58 km/h
Coolant temperature: 82 °C
Intake air temperature: 69 °C
Voltage terminal 30: 12.980 V
Exhaust mass flow of low-pressure EGR: calculated: 3.304
Differential pressure ratio: low-pressure EGR: 46.8 kg/h
Exh.recircul. 2: differential pres.sensor 1 bank 1: adap. value: 25.8 hPa
Exhaust recirculat.2: different.press.sens.1 bank 1: raw value: 22.8 hPa
Exh.recircul.valve 1 bank 1: pos.feedback - Actual value: 78.14 %
Exhaust recirc.valve 2 bank 1: posit.feedback - Actual value: 75.04 %
Exh. gas recirc. 2: diff. press. sensor 1 bank 1: dyn. value: 27.5 hPa
28413 - Reductant Level Sensor
P203D 00 [00100111] - Short to Plus
Mileage: 232667 km
Date: 2024.11.29
Time: 07:17:16
Engine RPM: 929.00 /min
Normed load value: 31.8 %
Coolant temperature: 12 °C
Intake air temperature: 12 °C
Voltage terminal 30: 11.500 V
Reducing agent quality sensor: urea concentration: 399.99 %
Sensor 2 for temp. reducing agent: act. value: 3003.6 °C
Sensor for reducing agent fill level: voltage: 13107.0 mV
Reducing agent metering system heating circuit 1: actual current: 0.0 A
Reducing agent metering system heating circuit 2: actual current: 0.0 A
Pump for reducing agent: speed: 0.0 /min
Mean temperature of SCR catalyst: 11.5 °C
28414 - Reductant Level Sensor
P203C 00 [00100110] - Short to GND
Mileage: 232661 km
Date: 2024.11.28
Time: 21:37:53
Engine RPM: 0.00 /min
Coolant temperature: 13 °C
Intake air temperature: 10 °C
Voltage terminal 30: 11.660 V
Sensor 2 for temp. reducing agent: act. value: 2.0 °C
Mean temperature of SCR catalyst: 99.4 °C
31274 - Reductant Qualilty Sensing Module
P14BC 00 [00100111] - Short to Plus
[Reductant Quality ModulCircuit High]
Mileage: 232667 km
Date: 2024.11.29
Time: 07:17:16
Coolant temperature: 8 °C
Intake air temperature: 9 °C
Voltage terminal 30: 11.640 V
Sensor 2 for temp. reducing agent: act. value: 1.5 °C
Mean temperature of SCR catalyst: 16.2 °C
31273 - Reductant Qualilty Sensing Module
P14BD 00 [00100000] - Short to GND
Mileage: 232661 km
Date: 2024.11.28
Time: 21:37:53
Engine RPM: 1801.00 /min
Normed load value: 68.2 %
Vehicle speed: 99 km/h
Intake air temperature: 81 °C
Voltage terminal 30: 12.900 V
Reducing agent quality sensor: urea concentration: 33.50 %
Sensor 2 for temp. reducing agent: act. value: 7.5 °C
Mean temperature of SCR catalyst: 304.5 °C
31271 - Control Module for Reductant Quality
U02A2 00 [00100110] - No Communications
Mileage: 232667 km
Date: 2024.11.29
Time: 07:17:22
Coolant temperature: 20 °C
Intake air temperature: 20 °C
Voltage terminal 30: 11.800 V
Mean temperature of SCR catalyst: 91.5 °C
28419 - Control Circuit for Reductant Heating 3
P20C4 00 [00100110] - Short to Plus
Mileage: 232683 km
Date: 2024.11.29
Time: 13:00:20
Intake air temperature: 19 °C
Voltage terminal 30: 11.700 V
Reducing agent quality sensor: urea concentration: 33.00 %
Mean temperature of SCR catalyst: 100.7 °C
31268 - Reductant Quality Module
P21CE 00 [01100101] - Malfunction
Mileage: 232683 km
Date: 2024.11.29
Time: 13:56:56
Voltage terminal 30: 11.720 V
Mean temperature of SCR catalyst: 99.2 °C
31267 - Reductant Quality Module
Mileage: 232683 km
Date: 2024.11.29
Time: 07:34:48
Coolant temperature: 80 °C
Voltage terminal 30: 11.920 V
Mean temperature of SCR catalyst: 261.4 °C
16922 - Reductant Pressure Sensor Circuit
P204A 00 [01100101] - Electrical Malfunction
Mileage: 232661 km
Date: 2024.11.28
Time: 21:37:54
Engine RPM: 1804.50 /min
Normed load value: 54.9 %
Intake air temperature: 80 °C
Voltage terminal 30: 12.940 V
Outside temperature sensor 1: B1: raw value: 3.0 °C
Pressure sensor for reducing agent: measured pressure: -500 hPa
Sensor for reducing agent tank temperature: temperature: 8.1 °C
Reducing agent pump: activation: 0.00 %
Sensor for reducing agent fill level: fill level height: 32767 mm
16945 - Reductant Control Module
U140D 00 [10101110] - Supply Voltage Too High
[Reductant Control ModuleSupply Voltage Too High]
Mileage: 232663 km
Date: 2024.11.28
Time: 21:39:22
Engine RPM: 1667.00 /min
Normed load value: 71.0 %
Vehicle speed: 92 km/h
Intake air temperature: 67 °C
Voltage terminal 30: 12.840 V
Mean temperature of SCR catalyst: 311.9 °C
16951 - Reductant Control Module
U140F 00 [00100000] - Function Limited due to Overvoltage
[Reductant Control ModuleFunction restriction due to excessive voltage]
Mileage: 232661 km
Date: 2024.11.28
Time: 21:38:05
Engine RPM: 1290.00 /min
Normed load value: 73.3 %
Vehicle speed: 93 km/h
Intake air temperature: 71 °C
Mean temperature of SCR catalyst: 304.6 °C
16948 - Voltage Sensor 1
P06B0 00 [00100111] - Open Circuit
Mileage: 232683 km
Date: 2024.11.29
Time: 07:34:36
Intake air temperature: 50 °C
Voltage terminal 30: 11.960 V
Mean temperature of SCR catalyst: 262.0 °C
16937 - Control Circuit for Reductant Heating 2
P20C0 00 [00100110] - Short to Plus
Mileage: 232683 km
Date: 2024.11.29
Time: 13:00:21
9645 - Reductant
P20E8 00 [01100101] - Pressure too Low
Mileage: 232595 km
Date: 2024.11.28
Time: 20:49:44
Engine RPM: 1300.50 /min
Normed load value: 4.3 %
Vehicle speed: 35 km/h
Coolant temperature: 60 °C
Intake air temperature: 44 °C
Voltage terminal 30: 14.800 V
Outside temperature sensor 1: B1: raw value: 3.5 °C
Pressure sensor for reducing agent: measured pressure: 188 hPa
Sensor for reducing agent tank temperature: temperature: 7.7 °C
Reducing agent pump: activation: 50.00 %
9643 - Reductant
Mileage: 232584 km
Date: 2024.11.28
Time: 17:58:42
Engine RPM: 1523.00 /min
Normed load value: 60.0 %
Vehicle speed: 110 km/h
Coolant temperature: 85 °C
Intake air temperature: 75 °C
Voltage terminal 30: 13.060 V
Outside temperature sensor 1: B1: raw value: 4.0 °C
Pressure sensor for reducing agent: measured pressure: 81 hPa
Sensor for reducing agent tank temperature: temperature: 8.6 °C
10615 - Reductant Tank Temperature Sensor
P205B 00 [01100101] - Implausible Signal
Mileage: 232667 km
Date: 2024.11.29
Time: 07:17:13
Voltage terminal 30: 11.420 V
Sensor for reducing agent tank temperature: temperature: -0.0 °C
4096 - Bank 1: CMP Sensor (G40) / Engine Speed Sensor (G28)
P0016 00 [01100101] - Incorrect Correlation
Mileage: 232679 km
Date: 2024.11.29
Time: 07:27:23
Engine RPM: 1220.00 /min
Normed load value: 51.0 %
Vehicle speed: 65 km/h
Intake air temperature: 66 °C
Engine start: start synchronization: EPM_MODE_OK
Engine start: start synchronization-Test_Program_Epm st Op Mode State t UBYTE: 48
Readiness: 1 1 0 0 0
Address 02: Auto Trans (J217) Labels:| 0CJ-927-156.clb
Part No SW: 8W2 927 155 ED HW: 0HK 927 156 B
Component: 0CL 20TDIRdWH01 0002
Revision: --H01--- Serial number: 0000000512 CVN: D587BFD2
ASAM Dataset: EV_TCMDL382021 002031
ROD: EV_TCMDL382021_AU49.rod
MTF pump:
Subsystem 1 - Part No SW: 0CK 927 152 AA HW: 0CK 321 281 L
Component: V553 MTFP 003 0576
Serial number: 75145041180335002711
Address 03: ABS Brakes (J104) Labels: 8W0-907-379-PLU-V1.clb
Part No SW: 8W0 907 379 AF HW: 8W0 907 379 J
Component: ESP9 Plus H16 0777
Dataset Number: 8W2909504J 0004 CVN: F66A9658
Coding: 0CAA489A28A40A9D51A4489A007F5292E5B5D2301214508A12004A49A7AD4B
Shop #: WSC 06334 790 00001
ROD: EV_ESP9BOSCHCMP_004_AU49.rod
VCID: 094F938A59B70A02085-805C
Address 08: Auto HVAC (E87) Labels:* Redir Fail!
Part No SW: 8W0 820 043 T HW: 8W0 820 043 T
Component: Klima Zone 3 H60 0251
Coding: 141840195544400D02000100080000000000000000000000000000000000
Shop #: WSC 06335 790 00001
ROD: EV_AirCondiBHTCAU491.rod
VCID: 44D142BE3E15976A3B3-8010
Subsystem 1 - Part No SW: 4M1 820 021 B HW: 4M1 820 021 B
Component: J126 FLuftV H09 0003
Serial number: 00000000000003100387
Humidity sensor: exterior:
Subsystem 2 - Part No SW: 4H0 907 658 A HW: 4H0 907 658 A
Component: AQ_Hum_Sensor H02 0007
Serial number: C7419E5900PAG0MUFU02
Subsystem 3 - Part No SW: 8W0 919 158 HW: 8W0 919 158
Component: E265 Kli Fond H40 0080
Address 09: Cent. Elect. (J519) Labels:* Redir Fail!
Part No SW: 8W0 907 063 DG HW: 8W0 907 063 BG
Component: BCM1 MLBevo H13 0313
Dataset Number: 8W2909514G 0042
Coding: 07501943C13900CD0505001018BD80F9110B3108000000000000000020001C010A440222025601
ASAM Dataset: EV_BCM1BOSCHAU736 019008
ROD: EV_BCM1BOSCHAU736_019.rod
VCID: 035381A27B9B5052429-8056
Subsystem 1 - Part No SW: 8W6 955 119 B HW: 8W6 955 119
Component: 494 LL 091118 036 0481
Serial number: 00000001811060300274
Coding: FFC7F7
Serial number: 22185622X81A955555A0
Coding: 02005D
Subsystem 3 - Part No SW: 4M0 941 531 AG HW: 4M0 941 531 AG
Component: E1 - LDS H06 0008
Serial number: 29 09 2018 01655961
Subsystem 4 - Part No SW: 8W0 857 511 HW: 8W0 857 511
Component: Y7_Innenspieg H09 0002
Serial number: GX1CE112101823610365
Interior Light Module:
Subsystem 5 - Part No SW: 4K0 947 135 B HW: 4K0 947 135 B
Component: Dachmodul H42 0413
Serial number: B01032377
Coding: 0D0104
Subsystem 6 - Part No SW: 8W0 925 301 BC HW: 8W0 925 301 BC
Component: SL-B9/Q5NF H17 0010
Serial number: 2818000151566007
65689 - Heated Seat Backrest; Front Left
B14E1 15 [00001000] - Open or Short to Plus
Fault Frequency: 8
Reset counter: 84
Mileage: 232247 km
Date: 2024.11.25
Time: 15:32:52
average_Voltage_terminals: 12.50 V
Outside air temperature sensor-Outside air temperature on CAN: 6.50 °C
interior_temperature: 8.00 °C
Vehicle speed: 8.47 km/h
Address 15: Airbags (J234) Labels:| 8W0-959-655.clb
Part No SW: 8W0 959 655 F HW: 8W0 959 655 F
Component: Airbag10.44 H03 0107
Serial number: 003UP00MNUGK Dataset Number: 8W2909602AF 0001
Coding: AACCF0C00C800000585400F3D04C00000000
ASAM Dataset: EV_AirbaAU10BPAAU736 006016
ROD: EV_AirbaAU10BPAAU736_006.rod
VCID: 4CC16A9E16455F2AF33-8018
Subsystem 1 - Part No SW: ----------- HW: 442 060 712 18
Serial number: 3577Y00C12BA797482FF
Subsystem 2 - Part No SW: ----------- HW: 442 060 712 18
Serial number: 3587Y00A72CC50F1510+
Subsystem 3 - Part No SW: ----------- HW: 442 0B1 111 18
Serial number: 3517700C52D6E144F42J
Subsystem 4 - Part No SW: ----------- HW: 442 0B1 111 18
Serial number: 35277009F2D2F48100EL
Subsystem 5 - Part No SW: ----------- HW: 442 0C0 412 18
Component: FrontSensor_D 1C5 014A
Serial number: 3557500AF2D14BD5142K
Subsystem 6 - Part No SW: ----------- HW: 442 0C0 412 18
Component: FrontSensor_P 1C5 014A
Serial number: 3567500AB2D14BD2A09Q
Subsystem 7 - Part No SW: ----------- HW: 442 0C0 412 18
Component: PedP_Sensor_C 1C5 014A
Serial number: 2307500AB2D14BD620DH
Subsystem 8 - Part No SW: ----------- HW: 442 432 711 18
Component: PedPSensor_D2 256 0887
Serial number: I0M9M00C12B39110F2CB
Subsystem 9 - Part No SW: ----------- HW: 442 432 711 18
Component: PedPSensor_P2 256 0887
Serial number: I0N9M00C12B39110B262
Part No SW: 4N0 907 129 S HW: 4N0 907 129 S
Component: Lenks.Modul H03 0005
VCID: 41DF4BAA21078242105-8014
Address 17: Instruments (J285) Labels:* None-SRI2
Part No SW: 8W6 920 771 B HW: 8W6 920 771 B
Component: TDIeRDW H10 0749
Coding: 05A441C6288000080C23AA601000200000000000
Shop #: WSC 32500 205 12345
ASAM Dataset: EV_DashBoardAU736 001032
16776982 - Databus
[SWA_01 communication error can_error_timeout]
Reset counter: 80
Mileage: 232126 km
Date: 2024.11.24
Time: 19:11:02
16776986 - Databus
[Allrad_06 communication error can_error_timeout]
Reset counter: 80
Mileage: 232126 km
Date: 2024.11.24
Time: 19:11:02
Address 18: Aux. Heat (J364) Labels:| 4M0-265-105.clb
Part No SW: 4M0 265 105 E HW: 4M0 265 105 E
Component: HSG H12 0100
Dataset Number: 8W2909858D 0014
Coding: 0D0B01
ASAM Dataset: EV_AuxilParkHeateEBEAU736 001016
ROD: EV_AuxilParkHeateEBEAU736.rod
VCID: 290FF30AB9776A02285-807C
Part No SW: 8W5 907 468 H HW: 8W5 907 468 G
Component: Gateway H43 0144
Revision: AS000001 Serial number: 018AS763618C11 Dataset Number: 8W2909515F 0049
Coding: 0301000100000640410700000059001248180007100000000175078F10000000
GVL: 01503C0008040000C08C08000004C80000080000000000000000000000000000
ASAM Dataset: EV_CGateCONTIAU491 003170
VCID: 4EC56096E0596D3A9D7-801A
Subsystem 1 - Part No SW: 8W0 951 523 F HW: 8W0 951 523 F
Component: J453 MFL H04 0004
Serial number: 20181210152147 21844
Subsystem 2 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Serial number: 4180879604
Address 29: Left Light (J1018) Labels: 4M0-907-397.clb
Part No SW: 4M0 907 397 AD HW: 4M0 907 397 D
Component: LCM_MLBevoH05 0024
Dataset Number: 8W2909519B 0003
VCID: 79AFE34A09571A82185-802C
Address 39: Right Light (J1023) Labels: 4M0-907-397.clb
Dataset Number: 8W2909520B 0003
Part No SW: 8W0 959 593 H HW: 8W0 959 593 F
Component: TSG FS 005 0130
Serial number: 0000357659781 Dataset Number: 8W2909872D 0026
Coding: 0010CB624000000000001400
ROD: EV_DCU2DriveSideMAXHCONT_AU37.rod
VCID: 4FFB7D92E7536432961-801A
Part No SW: 8W0 909 144 H HW: 8W0 909 144 B
Component: EPS_MLBEVO_ZF H08 0410
Dataset Number: 8W2909852Q 0032
Coding: 09000380008000
ASAM Dataset: EV_EPSZFAU49X 003023
ROD: EV_EPSZFAU49X_003.rod
VCID: 42DD44A62401995A09F-8016
Part No SW: 8W0 907 064 GB HW: 8W0 907 064 DB
Component: BCM2 MLBevo 025 0424
Dataset Number: 8W2909501G 0039
Coding: 01340000002000E06301A0000400480213030000804306502F04000000040030001F0001000010
Shop #: WSC 32500 205 00000
ASAM Dataset: EV_BCM2HellaAU736 016016
ROD: EV_BCM2HellaAU736_016_AU49.rod
VCID: 025D84A66481595A49F-8056
Part No SW: 8W0 959 392 H HW: 8W0 959 392 F
Component: TSG BFS 005 0130
Serial number: 0000357957552 Dataset Number: 8W2909873D 0026
Coding: 0010CB224000000000001400
ROD: EV_DCU2PasseSideMAXHCONT_AU37.rod
Part No SW: 8W0 035 183 J HW: 8W0 035 183 A
Component: MU-HS-N-EU 050 0235
Serial number: Dataset Number: 8W2909545Q 0042
Coding: 01940300FF0A000053110001000A00002F000EE401F001000E
ROD: EV_MUHigScl6C3DELP.rod
VCID: 3D27375A5DFFE6A274D-8068
Multimedia System 1:
Subsystem 1 - Part No SW: 8W1 919 604 HW: 8W1 919 604
Component: DU Std AU49x H32 0170
Serial number: TPO00111081800721078
Subsystem 2 - Part No SW: 8W0 919 614 N HW: 8W0 919 614 N
Component: ControlUnit_B H22 0134
Serial number: APVAK123111800020481
B201A 00 [00001000] - -
Fault Frequency: 14
Reset counter: 93
Mileage: 232126 km
Date: 2024.11.24
Time: 18:48:10
Voltage terminal 30: 12.1 V
Status_Software_Version_Management-module_name: C
Part No SW: 4M0 907 383 F HW: 4M0 907 383 B
Component: Anhaenger H27 0253
Revision: 9A001003 Serial number: 0501704254 Dataset Number: 8W2909527A 0005
Coding: 0110000202000000
VCID: 35372F7A65CF3EE2BCD-8060
Part No SW: 8W8 959 107 D HW: 8W8 959 107
Component: HDSG-Modul H13 0170
Revision: -------- Serial number: A2-C744-8781-0 Dataset Number: 8W2909541D 0009
Coding: 06B0
ROD: EV_DeckLidCONTIAU736_VW48.rod
VCID: 4ACD6C861C31411AC1F-801E
Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb
Part No SW: 8W1 713 041 N HW: 8W1 713 041 K
Component: GSM-LL H10 0077
Revision: 0L0D5012 Serial number: 18112950181236
ROD: EV_GSMWaehlZFAU736_AU49.rod
VCID: 3E25305650F9FDBA6D7-806A
Address A5: Frt Sens. Drv. Assist (R242) Labels:* Redir Fail!
Part No SW: 8W6 907 217 B HW: 8W6 907 217 A
Component: BVS H17 0052
Dataset Number: 8W2909466C 0019
Coding: 0404090300000403022000A1A50000FC00F0C0200280
ROD: EV_BVSMLBevKOSTAAU736_002_AU49.rod
Address AC: Reductant Control (J880) Labels: 4M0-907-355.clb
Part No SW: 4M0 907 355 D HW: 4M0 907 355 B
Component: SCR-Stg-G3H05 0006
Dataset Number: 8W2909571D 0006
ASAM Dataset: EV_RDCMINERGAU736 005012
ROD: EV_RDCMINERGAU736.rod
VCID: 323D146694A129DA99F-8066
14 Faults Found:
0016 - Supply voltage
U1012 00 [00001101] - Voltage too High
[Kl30_Power_supply_Voltage_too_high]
Reset counter: 53
Mileage: 232663 km
Date: 2024.11.28
Time: 21:39:21
Terminal 30A voltage: 19.15 V
Terminal 30B voltage: 19.15 V
Supply voltage for external components: 4.90 V
Reducing agent quality sensor: voltage terminal 31: 0.00 V
Pump for reducing agent: speed: 0 /min
Pump for reducing agent: current: 0.00 A
Reducing agent pump: operating state: OFF
Reducing agent pump: end stage activation status: not active
Reducing agent pump: end stage temperature: 206 °C
Heating circuit 1 f. red. agent metering sys.: end stage temp.: 206 °C
Sensor for reducing agent tank temperature: temperature: 26 °C
Pressure sensor for reducing agent: voltage: 0.09 V
Sensor for reducing agent fill level: fill level height: 1002 mm
Reducing agent quality sensor: urea concentration: 107.00 %
Sensor 2 for temp. reducing agent: act. value: 82.00 °C
Heating circuit 1 for reducing agent: power: 0 W
Heating circuit 1 for reducing agent: power set value: 0 W
Heating circuit 1 for reducing agent: power limitation: 130 W
Heating circuit 3 for reducing agent: power: 0 W
Heating circuit 3 for reducing agent: power set value: 0 W
Heating circuit 3 for reducing agent: power limitation: 78 W
Heating circuit 2 for reducing agent metering: power: 0 W
Heating circuit 2 for reducing agent metering: activation: not active
Dataset_Elements: F51049
65794 - Reductant Pressure Sensor Circuit
P204A 00 [00001101] - Electrical Malfunction
[SCR_Pressure_sensor_Shortcut_to_Ground_Open_circuit]
Fault Frequency: 15
Reset counter: 53
Mileage: 232661 km
Date: 2024.11.28
Time: 21:37:51
Sensor for reducing agent fill level: fill level height: 106 mm
Sensor 2 for temp. reducing agent: act. value: 7.50 °C
262144 - Control Circuit for Reductant Heating 2
P20C0 00 [00001000] - Short to Plus
[SCR_Line_Heater_Shortcut_to_Vbat]
Reset counter: 93
Mileage: 232667 km
Terminal 30A voltage: 12.46 V
Terminal 30B voltage: 12.49 V
Supply voltage for external components: 5.00 V
Reducing agent pump: end stage temperature: -2 °C
Heating circuit 1 f. red. agent metering sys.: end stage temp.: -3 °C
Sensor for reducing agent tank temperature: temperature: 2 °C
Pressure sensor for reducing agent: voltage: 0.71 V
Sensor for reducing agent fill level: fill level height: 65515 mm
262656 - Control Circuit for Reductant Heating 3
P20C4 00 [00001000] - Short to Plus
[SCR_Tank_Heater_2_Shortcut_to_Vbat]
Fault Frequency: 16
Reset counter: 93
Mileage: 232667 km
Terminal 30A voltage: 12.49 V
Terminal 30B voltage: 12.50 V
Pressure sensor for reducing agent: voltage: 0.70 V
0018 - Function Restricted due to Excessive Voltage
U1401 00 [00001000] - -
[Kl30_Power_supply_reduced_functionalities_due_to_overvoltage_16V]
Reset counter: 92
Mileage: 232661 km
Date: 2024.11.28
Time: 21:38:03
Heating circuit 1 for reducing agent: power set value: 144 W
Heating circuit 1 for reducing agent: power limitation: 100 W
Heating circuit 3 for reducing agent: power set value: 144 W
0537 - Voltage Sensor 1
P06B0 00 [00001101] - Open Circuit
Reset counter: 53
Mileage: 232683 km
Date: 2024.11.29
Time: 07:34:17
Supply voltage for external components: 2.49 V
Pressure sensor for reducing agent: voltage: 0.07 V
Sensor for reducing agent fill level: fill level height: 107 mm
66560 - Reductant Level Sensor
P203D 00 [00001101] - Short to Plus
[SCR_Digital_Interface_Shortcut_to_Vbat]
Fault Frequency: 8
Reset counter: 53
Mileage: 232667 km
Date: 2024.11.29
Time: 07:16:14
Supply voltage for external components: 4.86 V
Sensor for reducing agent fill level: fill level height: 105 mm
Sensor 2 for temp. reducing agent: act. value: 1.50 °C
66562 - Reductant Level Sensor
P203C 00 [00001000] - Short to GND
[SCR_Digital_Interface_Shortcut_to_Ground]
Reset counter: 93
Mileage: 232661 km
Date: 2024.11.28
Time: 21:37:51
66561 - Reductant Level Sensor
P203D 00 [00001000] - Short to Plus
[SCR_Digital_Interface_Shortcut_to_5V_sensor_supply]
Reset counter: 93
Mileage: 232683 km
Date: 2024.11.29
Time: 13:03:42
Supply voltage for external components: 4.94 V
Sensor for reducing agent tank temperature: temperature: 25 °C
Pressure sensor for reducing agent: voltage: 0.06 V
Sensor 2 for temp. reducing agent: act. value: 0.50 °C
66887 - Reductant Quality Module
P21CE 00 [00001000] - Malfunction
[SCR_Digital_Interface_Quality_2_sensor_diagnostic_routines_error]
Reset counter: 93
Mileage: 232683 km
Date: 2024.11.29
Time: 07:34:46
66853 - Reductant Quality Module
U05A3 00 [00001000] - Implausible Signal
[SCR_Digital_Interface_2_Slow_Channel _Timeout]
Reset counter: 93
Mileage: 232683 km
Date: 2024.11.29
Time: 13:05:06
Sensor 2 for temp. reducing agent: act. value: -45.00 °C
66816 - Reductant Qualilty Sensing Module
P14BC 00 [00001101] - Short to Plus
[SCR_Digital_Interface_2_Shortcut_to_Vbat]
Reset counter: 53
Mileage: 232667 km
Date: 2024.11.29
Time: 07:16:14
66818 - Reductant Qualilty Sensing Module
P14BD 00 [00001000] - Short to GND
Reset counter: 93
Mileage: 232661 km
Date: 2024.11.28
Time: 21:37:51
66848 - Control Module for Reductant Quality
U02A2 00 [00001000] - No Communications
[SCR_Digital_Interface_2_Timeout]
Reset counter: 93
Mileage: 232667 km
Date: 2024.11.29
Time: 07:17:19
Supply voltage for external components: 4.84 V
Pump for reducing agent: current: 1.40 A
Reducing agent pump: operating state: recirc. mode
Reducing agent pump: activation: 30.00 %
Reducing agent pump: end stage activation status: active
Pressure sensor for reducing agent: voltage: 0.08 V
Part No SW: 8W0 959 595 H HW: 8W0 959 595 F
Component: TSG HFS 009 0130
Serial number: 0000358329603 Dataset Number: 8W2909897D 0026
Coding: 0000C9220000000000001000
ROD: EV_DCU2RearDriveMAXHCONT_VW37.rod
VCID: 51FF7BEAF16772C2805-8004
Component: TSG HBFS 009 0130
Serial number: 0000358329608 Dataset Number: 8W2909896D 0026
ROD: EV_DCU2RearPasseMAXHCONT_VW37.rod
Address D6: Light Ctrl Left 2 (A31) Labels: 7PP-941-592.clb
Part No SW: 7PP 941 592 CB HW: 7PP 941 592 C
Component: LED1L H10 2003
Dataset Number: 8W2909471A 0008
VCID: 1A6DDCC6EC11F19AB1F-804E
Address D7: Light Ctrl Right 2 (A27) Labels: 7PP-941-592.clb
Component: LED1R H10 2003
Dataset Number: 8W2909472A 0008
End----(Elapsed Time: 02:00, VBatt start/end: 11.9V/11.7V. VIgn 11.8V)-----
