- Nov 27, 2024
- 21
- 1
- Top of the Grapevine, CA, USA
- C?ID=603462
Greetings,
Ran first scans yesterday and more today. The 01-Engine -- Status: Malfunction 0010 did not show up on any previous scans until after I pulled the under hood 5 amp fuse F15 while the car was running. (I pulled it thinking it was the horn fuse and wanted to see it the fuse was blown) This posted scan results are ,after completing two resets, driving auto, then this new scan. The Jetta, during this drive drove will with no performance issues.
I am also curious of the meaning of the Date: 2019.04.21 which is present in all 10 fault codes related to Status: 01- Engine -- Status: Malfunction 0010 and wondering why the previous scans resulted in 01-Engine -- Status: OK 0000 until after I pulled this fuse (auto stalled) placed fuse back, and drove the auto with no performance issues.
(The auto does have intermittent issues with the glow plug light and check engine light turning on (resulting in the engine not revving past 2K rpm in neutral and not being able to drive the car past around 50 MPH) and these 10 codes may be useful to eventually figure this main issue out.)
My horn also does not work and before, which does not show up on this newest scan, I cleared the codes I saved the scan results. I plan to post these as separate posts after I learn more of the basics of the VCDS tool.
Hope I am making sense and thank you for any clarification of these questions.
Thursday,28,November,2024,12:05:22:19900
VCDS Version: 24.7.1.0 (x64) HEX-V2 CB: 0.4643.5
VIN: 3VWPL7AJ0DM654504 License Plate: Note: After reset
Mileage: 290010km-180203mi Repair Order:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 56 62 72 77
VIN: 3VWPL7AJ0DM654504 Mileage: 290010km-180203miles
Part No SW: 03L 997 030 E HW: 03L 907 309 AA
Component: R4 2.0l TDI G000AG 9983
Revision: 12H15--- Serial number:
Coding: 0050078
Shop #: WSC 03466 005 1048576
VCID: 303ECFD2A627884AEFB-8064
VINID: 0E69E070745A0147461441401092042300
10 Faults Found:
012332 - Relay for Low Heater Output
P302C - 000 - Short to Ground - Intermittent
Mileage: 289997 km
Date: 2019.04.21.
Time: 19:25:22
RPM: 1058 /min
Voltage: 14.36 V
(no units): 0.0
Temperature: 3.6°C
Bin. Bits: 00000000
Temperature: 5.4°C
012333 - Relay for High Heater Output
P302D - 000 - Short to Ground - Intermittent
Mileage: 289997 km
Date: 2019.04.21.
Time: 19:25:22
RPM: 1058 /min
Voltage: 14.36 V
(no units): 0.0
Temperature: 3.6°C
Bin. Bits: 00000000
Temperature: 5.4°C
000899 - Glow Plug Control Module
P0383 - 000 - Short to Ground - Intermittent
Mileage: 289997 km
Date: 2019.04.21.
Time: 19:25:22
RPM: 1058 /min
Voltage: 14.36 V
Temperature: 3.6°C
Bin. Bits: 10110000
Time: 2.52 s
Temperature: 3.6°C
009778 - Relay for Fuel Pump 2 (J49)
P2632 - 000 - Open Circuit - Intermittent
Mileage: 289997 km
Date: 2019.04.21.
Time: 19:25:24
Voltage: 12.92 V
Pressure: 8.0 bar
Inj. Quantity: 0.0 mg/str
Lambda: 11.0 %
Lambda: 6.3 %
001575 - Fuel Pump Relay Control Circuit
P0627 - 000 - Open Circuit - Intermittent
Mileage: 289997 km
Date: 2019.04.21.
Time: 19:25:24
Voltage: 12.84 V
Pressure: 8.0 bar
Lambda: 11.0 %
Lambda: 6.3 %
008853 - Fuel Pressure Regulator Valve (N276)
P2295 - 000 - Short to Ground - Intermittent
Mileage: 289997 km
Date: 2019.04.21.
Time: 18:08:47
Voltage: 11.70 V
Pressure: 8.0 bar
Lambda: 15.0 %
Lambda: 7.9 %
000145 - Valve for Fuel Metering (N290)
P0091 - 000 - Short to Ground - Intermittent
Mileage: 289997 km
Date: 2019.04.21.
Time: 18:08:47
Voltage: 11.70 V
Pressure: 8.0 bar
Lambda: 16.6 %
Lambda: 0.0 %
008448 - Throttle Actuator Control Circuit
P2100 - 000 - Open Circuit - Intermittent
Mileage: 289997 km
Date: 2019.04.21.
Time: 18:08:47
Load: 100.0 %
Lambda: 99.4 %
Mass Air / Rev.: 0.0 mg/str
Temperature: 4.5°C
008450 - Throttle Valve Actuator Module (J338): Motor Circuit
P2102 - 000 - Signal Low - Intermittent
Mileage: 289997 km
Date: 2019.04.21.
Time: 18:08:47
Load: 100.0 %
Lambda: 99.4 %
Temperature: 4.5°C
001592 - Throttle Body Actuator Bank 1 (J338)
P0638 - 000 - Implausible Signal - Intermittent
Mileage: 289997 km
Date: 2019.04.21.
Time: 18:08:53
Voltage: 11.48 V
Lambda: 99.4 %
Bin. Bits: 00000000
Component: GSG DSG AG6 512 9430
Revision: 05551213 Serial number: 00001209032252
Shop #: WSC 44612 001 1048576
VCID: 14766342327F546AEB3-8040
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Revision: 00H31001
Coding: 114B600C492700FE881006E4921D0042B70000
Shop #: WSC 00066 000 00000
VCID: 7DA026E62DF5B52234D-8028
Part No SW: 7N0 907 426 BH HW: 7N0 907 426 BH
Component: AC Manuell H20 0505
Revision: 00001018
Coding: 0010002002
Shop #: WSC 00066 000 00120
VCID: 7BA428FE3361BB120A9-802E
Part No SW: 5K0 937 084 J HW: 5K0 937 084 J
Component: BCM PQ35 B 021 3068
Revision: BG021001
Coding: 2F380E1A802F3EC4008800C17000004449000086535D0560648020200040
VCID: 3928F2F6795D4902585-806C
Subsystem 1 - Part No: 5K1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 15121 26 0512
Coding: 009795
02092 - Enabling Heated Seat
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 221
Mileage: 289997 km
Date: 2019.04.21.
Time: 01:01:25
Voltage: 11.70 V
Reset counter: 220
Mileage: 289997 km
Date: 2019.04.21.
Time: 01:01:25
Voltage: 11.70 V
Part No SW: 5C0 959 655 M HW: 5C0 959 655 M
Component: AirbagVW10G 014 0726
Serial number: 003L4R00UVUH Dataset Number: 1KM003v__B_ 0047
Coding: 00004E42
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3C26EBE276EF7C2A433-8068
Subsystem 1 - Part No SW: 1KM 959 339 B HW: 1KM 959 339 B
Component: BF-Gewichtss. 006 0001
Serial number: ---0000R--000061ZC00
Subsystem 2 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Serial number: 3572MSME680E1272ZZZX
Subsystem 3 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Serial number: 3582MSME3F291172ZZZY
Serial number: 3511HSME5C2B4A2EZZZ+
Serial number: 3521HSME41574C2EZZZV
Serial number: 35527SME2646682EZZZO
Serial number: 35627SME5148682EZZZP
Part No SW: 5K0 953 507 AH HW: 5K0 953 549 B
Revision: -------- Serial number: 90440LJD001BP Dataset Number: 5K0953507AH D005
Coding: 188A140000
Shop #: WSC 00066 000 00185
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 76B239CA0843E67A757-8022
Subsystem 1 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H09 0013
Serial number: 0642371
Coding: 820000
Part No SW: 5K0 920 973 C HW: 5K0 920 973 C
Component: KOMBI H05 0705
Coding: 270F01
VCID: 3138CAD6A1AD8142E05-8064
Part No SW: 7N0 907 530 AF HW: 7N0 907 530 AF
Component: J533 Gateway H52 1634
Revision: H52 Serial number: 02121203270971
Coding: 352002
VCID: 74B603C21EBFF46A4B3-8020
Part No SW: 5N0 919 879 HW: 5N0 919 879
Component: Kompass 002 0002
Revision: 00002000 Serial number: 1225223RKLGR07
Coding: 0000002
VCID: 7EA221EA2CF3AE3A2D7-802A
Component: IMMO H05 0705
VCID: 6A8A1DBA4CFB329AE1F-803E
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Revision: A1001003 Serial number: 7663731410
Coding: 010100
VCID: 2A0ADDBA8CFBF29A21F-807E
Component: TUER-SG FT 002 0501
Revision: 13110009 Serial number: 0005930258
Coding: 0004B5
Shop #: WSC 01383 790 50316
VCID: 5BE4487E93A15B126A9-800E
Slave Driver:
Subsystem 1 - Part No SW: 3C0 959 703 C HW: 3C0 959 795 D Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 008 1509
Serial number: 00000007376251
Coding: 000490
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 70 3305
Revision: 00H22000
Shop #: WSC 02069 000 90108
VCID: 372CF4CE43495F72AE1-8062
Component: TUER-SG BT 002 0501
Revision: 15110009 Serial number: 0005926182
Coding: 0004B4
VCID: 5CE64B6296AF5C2A633-8008
Slave Passenger:
Subsystem 1 - Part No SW: 3C0 959 704 C HW: 3C0 959 794 D Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 008 1509
Serial number: 00000007253491
Coding: 000490
Part No SW: 1K0 035 180 AF HW: 1K0 035 180 AF
Component: Radio Prem-8 H04 0008
Revision: -----08S Serial number: VWZ4Z7M3394831
Coding: 01000400040007
VCID: 64967382AE5F64EADB3-8030
Reset counter: 220
Mileage: 289997 km
Date: 2019.04.21.
Time: 01:02:02
Part No SW: 7P6 035 730 K HW: 7P6 035 730 K
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007663647509 Dataset Number: 7P6035730K 0001
Coding: 0A10040000010110
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_002.rod
VCID: 3A2AEDFA7CDB421A51F-806E
End----------(Elapsed Time: 01:18, VBatt start/end: 12.2V/12.2V)-----------
