Resolved Audi A3 8P MK60EC1 and original ABS pump is damaged
Resolved
V3lmu
Oulu, Finland
C?ID=229426
Hey! :)
Car info:
Audi A3 8P MY08
1,9TDI, 77kW.
Engine code: BLS
PR code for this car.
The car's original ABS pump has broken, and no fault codes have been read from the car with VCDS during the current owner's time. A new pump has been installed, but the ABS pump needs to be coded so that the fault lights disappear from the instrument cluster.
Could someone help me find the code?
Auto-Scan:
Thursday,28,November,2024,19:02:12:00464
VCDS Version: 24.9.1.0 (x64)  HEX-V2 CB: 0.4656.4
Data version: 20240926 DS359.0
Dealer/Shop Name: J.P - V3lmu
VIN: WAUZZZ8P89A067470   License Plate: AUDI A3 8P -08
Mileage: 257730km-160145mi   Repair Order: 1. kierros - 28.11.24
Chassis Type: 8P-AU35 (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 55 56 62 72
VIN: WAUZZZ8P89A067470   Mileage: 257730km-160145miles
Address 01: Engine        Labels: 03G-906-021-BLS.clb
   Part No SW: 03G 906 056 R    HW: 03G 906 021 AB
   Component: R4 1,9L EDC G000SG  2916
   Revision: --H09---    Serial number: AUX7Z0H9FNT0SA
   Coding: 0000071
   Shop #: WSC 06314 000 00000
   VCID: 363526CFB44760BA8D7-8062
   VINID: 9D196AAAA220209440187107007E111B64
005705 - Powertrain Data Bus
               P1649 - 000 - Missing Message from ABS Controller - Intermittent
                    Mileage: 257677 km
                    Date: 2024.11.26
                    Time: 13:18:54
                    Voltage: 12.24 V
                    Bin. Bits: 00101100
                    Torque: 0.0 Nm
                    Bin. Bits: 00000000
   Part No SW: 1K0 907 379 AD    HW: 1K0 907 379 AD
   Component: ESP MK60EC1   H35 0104
   Revision: 00H35001
   Coding: 000000000000000000000000000000000000
   Shop #: WSC 00046 412 40960
   VCID: 74B1DCC7EEBB32AA733-8020
01486 - System Function Test Activated
                    Reset counter: 215
                    Mileage: 257677 km
                    Date: 2024.11.26
                    Time: 14:36:23
                    Count: 3
                    Count: 12288
                    Count: 320
                    Count: 43264
                    Fault Status: 01100101
                    Reset counter: 215
                    Mileage: 257677 km
                    Date: 2024.11.26
                    Time: 14:36:23
                    Count: 3
                    Count: 12288
                    Count: 279
                    Count: 43264
                    Reset counter: 215
                    Mileage: 257677 km
                    Date: 2024.11.26
                    Time: 14:36:23
                    Count: 3
                    Count: 12288
                    Count: 295
                    Count: 43264
                    Reset counter: 215
                    Mileage: 257677 km
                    Date: 2024.11.26
                    Time: 14:36:23
                    Count: 3
                    Count: 12288
                    Count: 270
                    Count: 43264
                    Reset counter: 215
                    Mileage: 257677 km
                    Date: 2024.11.26
                    Time: 14:36:23
                    Count: 3
                    Count: 12288
                    Count: 195
                    Count: 43264
   Part No SW: 8P0 820 043 BH    HW: 8P0 820 043 BH
   Component: KlimavollautomatH09 0100
   Revision: 000050      Serial number: 8P0820043BH
   VCID: 73B3DFDBE7B535926A9-8026
01273 - Fresh Air Blower (V2)
                    Fault Status: 00101010
                    Reset counter: 226
                    Mileage: 253828 km
                    Date: 2024.09.08
                    Time: 15:57:21
                    Temperature: 26.5 C
                    (no units): 169.0
                    (no units): 248.0
Address 09: Cent. Elect.        Labels:. 8P0-907-279-30-H.lbl
   Part No SW: 8P0 907 279 N    HW: 8P0 907 279 N
   Component: Bordnetz-SG     H54 2801
   Revision: 00H54000    Serial number: 00000009046535
   Coding: 088A0F8190141380EF00000A0000000000084A0564060403642000000000
   Shop #: WSC 06314 000 08192
   VCID: 48C95837CEB3E64AEFB-801C
   Subsystem 1 - Part No: 8P1 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer AU350   H10 0040
   Coding: 00056595
   Shop #: WSC 06314
Address 15: Airbags (J234)       Labels:* 8P0-959-655-10.clb
   Part No SW: 8P0 959 655 J    HW: 8P0 959 655 J
   Component: Airbag AU1042 H06 0090
   Revision: --------    Serial number: 003000000000 Dataset Number: 8P0909602L  0001
   Coding: 303142383038303030354A55304C38503053
   ROD: EV_Airba10AURB4_AU35.rod
   VCID: 49CF5D33D9391F42F05-801C
   Serial number: 3572DRB400008098D37Y
   Serial number: 3582DRB4000080992AB-
   Serial number: 35128RB40000469C3F1P
   Serial number: 35228RB40000471EC55O
   Serial number: 35547RB4000047E7952S
   Serial number: 35647RB4000047E798C%
13636864 - Control Module for ABS Brakes
          U1015 00 [00001000] - No Communications
          [Lost Communication With Vehicle Dynamics Control Module]
                    Reset counter: 0
                    Mileage: 257677 km
                    Date: 2024.11.26
                    Time: 13:18:54
Address 16: Steering wheel        Labels: 8P0-953-549-F.lbl
   Part No SW: 8P0 953 549 F    HW: 8P0 953 549 F
   Component: J0527           H36 0070
   Coding: 0000042
   VCID: 41DF4513ED89D702285-8014
   Part No SW: 8P0 920 931 S    HW: 8P0 920 931 S
   Component: KOMBIINSTR. VDO H18 0830
   Revision: D0H18006    Serial number: 2249H006049000
   Coding: 0004128
   Shop #: WSC 80093 222 69422
   VCID: 43D34F1BF795C5123A9-8016
   Part No SW: 1K0 907 530 S    HW: 1K0 907 951
   Component: J533__Gateway   H16 0210
   Revision:   H16       Serial number: 3400K08A2208C8
   Coding: E9817F06100202002102
   VCID: 372B2BCBB34D99B2961-8062
                    Reset counter: 216
                    Mileage: 245206 km
                    Date: 2024.04.04
                    Time: 13:28:47
                    Reset counter: 0
                    Mileage: 257677 km
                    Date: 2024.11.26
                    Time: 13:18:54
   Revision: D0H18006    Serial number: AUX7Z0H9FNT0SA
   Part No SW: 8P0 959 801 K    HW: 8P0 959 801 K
   Component: Tuer-SG         H03 0060
   Coding: 0000180
01706 - Switch for Mirror-Adjust (E43)
   Part No: 1K0 909 144 C
   Component: EPS_ZFLS Kl. 232    2301
   Revision: 00H15000
   Shop #: WSC 02069 000 90108
   VCID: 2A0D02BF70FF345A19F-807E
                    Reset counter: 10
                    Mileage: 257677 km
                    Date: 2024.11.26
                    Time: 13:18:54
                    Voltage: 12.25 V
                        DD
                    Temperature: 14.0 C
                    Fault Status: 00101101
                    Reset counter: 10
                    Mileage: 257677 km
                    Date: 2024.11.26
                    Time: 13:21:24
                    Voltage: 12.25 V
                        DU
                    Temperature: 15.0 C
                    Speed: 49.0 km/h
Address 46: Central Conv.        Labels: 8P0-959-433.lbl
   Part No: 8P0 959 433 L
   Component:    KSG          H11 0080
   Coding: 1880200002186D0985054C8F0167
   VCID: 45D75103F9A1FB2214D-8010
Address 47: Sound System        Labels: 8Px-035-382.lbl
   Part No SW: 8P4 035 382 D    HW: 8P4 035 382 D
   Component: AB2 SUBWOOFERBOXH06 0180
   Revision: 00005       Serial number: 30674802999339
   VCID: 353721C3A9416BA284D-8060
   Part No SW: 8P0 959 802 K    HW: 8P0 959 802 K
   Coding: 0000180
   VCID: 44D14C07F29BC22A033-8010
   Part No: 8P0 907 357 J
   Component: Dynamische LWR  H01 0020
   Coding: 0000013
   Shop #: WSC 00046 000 00000
                    Reset counter: 0
                    Mileage: 257672 km
                    Date: 2024.11.26
                    Time: 13:18:54
   Part No SW: 8P0 035 186 P    HW: 8P0 035 186 P
   Component: R Concert2+     H03 0270
   Revision: 00H03000    Serial number: AUZ1Z3H3484493
   Coding: 0110211
   VCID: 3FDB43EB9B7DA1F25E1-806A
00871 - Bass Speaker Front Right (R23)
                    Reset counter: 110
                    Mileage: 245206 km
                    Date: 2024.04.04
                    Time: 13:28:32
Address 62: Door, Rear Left        Labels: 8P4-959-801.lbl
   Part No SW: 8P4 959 801 E    HW: 8P4 959 801 E
   Component: Tuer-SG         H04 0040
   Coding: 0000144
   Shop #: WSC 06314 000 1012544
00098 - Rear Left Central Locking (Safe) Motor (V163)
Address 72: Door, Rear Right        Labels: 8P4-959-802.lbl
   Part No SW: 8P4 959 802 E    HW: 8P4 959 802 E
   Coding: 0000144
   VCID: 42DD4A1FE88FCC1A31F-8016
End----------(Elapsed Time: 01:21, VBatt start/end: 14.1V/14.1V)-----------
Jef
HQ
1342201209280001C80F04EB901900813800
1142201209280001C80F04EB901900813800
What I come up with.... go with Boki's first. If it turns out mine works, then you owe me a few boxes of salmiakki.
edit due to lefties in Lapland being pointed out... the example I used to help build this was a RHD car.
Boki Ar
Arandjelovac, Serbia
C?ID=57300
Hi @Jef, your coding is RHD, we need LHD for Finland. Correct me if I'm wrong.
Boki Ar
C?ID=57300
Sorry, byte 15 is RHD, again.
Otherwise, your coding is more accurate, according to PR-1ZF.
Therefore: 1142201209280001880F04EB901900413800 :thumbs:
V3lmu
Oulu, Finland
C?ID=229426
The job is done. It took a lot of work and pain to get the G85 sensor adjusted, but in the end it was successful.
Saturday,30,November,2024,14:11:01:00464
VCDS Version: 24.7.1.0 (x64)  HEX-V2 CB: 0.4656.4
Mileage: 257800km-160189mi   Repair Order: koodauksen ja koeajon jälkeinen - 30.11.24
VIN: WAUZZZ8P89A067470   Mileage: 257800km-160189miles
   Coding: 0000071
   VCID: 363526CFB44760BAB57-8062
   Revision: 00H35001
   Coding: 1142401209280001880F02EB901900413800
   VCID: 74B1DCC7EEBB32AA4B3-8020
   VCID: 73B3DFDBE7B53592529-8026
                    Reset counter: 226
                    Mileage: 253828 km
                    Date: 2024.09.08
                    Time: 15:57:21
                    Temperature: 26.5°C
                    (no units): 169.0
                    (no units): 248.0
   VCID: 48C95837CEB3E64AD7B-801C
   Coding: 00056595
   Shop #: WSC 06314
   VCID: 49CF5D33D9391F42C85-801C
   Coding: 0000042
   VCID: 41DF4513ED89D702105-8014
   Coding: 0004128
   VCID: 43D34F1BF795C512029-8016
   VCID: 372B2BCBB34D99B2AE1-8062
                    Reset counter: 216
                    Mileage: 257800 km
                    Date: 2024.11.30
                    Time: 13:58:31
   Coding: 0000180
   Revision: 00H15000
   VCID: 2A0D02BF70FF345A21F-807E
   VCID: 45D75103F9A1FB222CD-8010
   VCID: 353721C3A9416BA2BCD-8060
   Coding: 0000180
   VCID: 44D14C07F29BC22A3B3-8010
   Coding: 0000013
   Coding: 0110211
   VCID: 3FDB43EB9B7DA1F2661-806A
                    Reset counter: 216
                    Mileage: 257800 km
                    Date: 2024.11.30
                    Time: 13:58:38
   Coding: 0000144
   Coding: 0000144
   VCID: 42DD4A1FE88FCC1A09F-8016
End----------(Elapsed Time: 01:17, VBatt start/end: 13.6V/13.7V)-----------
