hello
i have skoda octavia 2016 with faulty ecu, i brought new ecu with same HW and SW number, immoed off, dpf off egr off and put on car, car works but with loss of power and U0101 error while transmission works fine
could someone help me find the problem causing this loss of power
Wednesday,27,November,2024,16:18:05:04619
VCDS Version: 24.7.1.0 (x64) HEX-V2 CB: 0.4643.4
VIN: TMBAJ7NEXG0202501 License Plate:
Chassis Type: NE-SK37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 5F
VIN: TMBAJ7NEXG0202501 Mileage: 321948km-200049miles
Address 01: Engine (J623-----) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 BP HW: 04L 907 309 R
Component: R4 2,0L EDC H22 1198
Revision: B5H22--- CVN: 6EFE19BA
Coding: 011D0012032401090000
Shop #: WSC 73430 031 00000
ASAM Dataset: EV_ECM20TDI01104L906026BP 002002
ROD: EV_ECM20TDI01104L906026BP_002.rod
VCID: 79AFEBDF89587272185-802C
VINID: 91D491687795A17002002140046C508CAE
13871 - Coolant Pump for Intercooler
P023B 00 [00100111] - Short to GND
Mileage: 321947 km
Date: 2024.10.02
Time: 06:24:06
Engine RPM: 792.50 /min
Normed load value: 45.1 %
Coolant temperature: 70 °C
Intake air temperature: 52 °C
Voltage terminal 30: 12.080 V
Air mass at air mass meter 1: 36.9 kg/h
EGR temp. sensor 2: B1: raw value: 2222.0 °C
Outside temperature sensor 1: B1: raw value: 19.5 °C
Intake air temperature before throttle valve: calculated: 0.0 K
Charge air cooler output: temp. sensor 1: B1: raw value: 38.7 °C
Heater supp.pump 1 bank 1 charg.air cool.circuit: activat.: 10.00 %
Turbocharger 1 charger output: temp. sensor 1: B1: raw value: 52.8 °C
19228 - Bank 1: Camshaft A (Intake)
P0010 00 [11101101] - Position Actuator Malfunction
Mileage: 321947 km
Date: 2024.10.02
Time: 06:24:05
Engine RPM: 745.00 /min
Normed load value: 50.6 %
Intake air temperature: 53 °C
Voltage terminal 30: 12.020 V
Camshaft adjustment intake bank 1: actual value: 10.02 °
Camshaft adjustment intake bank 1: specified value: 10.00 °
Camshaft adjustment intake bank 1: activation: 7.275 %
Camshaft adaptation intake bank 1: phase position: 0.15 °
Engine oil temperature: 66.0 °C
28388 - Coolant Pump 3
P26F4 00 [10101111] - Electrical Malfunction / Open Circuit
Mileage: 321947 km
Date: 2024.10.02
Time: 06:19:27
Engine RPM: 0.00 /min
Coolant temperature: 71 °C
Intake air temperature: 55 °C
Voltage terminal 30: 12.580 V
Heater support pump 1 bank 1 second.circuit: activat.: 93.56 %
Outside temperature sensor 1: B1: raw value: 23.5 °C
Shut-off timer: last engine shut-off time: 224 s
5927 - Sensor for Exhaust Flap
P048B 00 [10101111] - Electrical Malfunction
Mileage: 321947 km
Date: 2024.10.02
Time: 06:19:27
Intake air temperature: 56 °C
Particulate filter output: temp. sensor 1: bank 1: raw value: -0.0 °C
Exh.recircul.valve 1 bank 1: pos.feedback - Specified value: 0.00 %
Exh.recircul.valve 1 bank 1: pos.feedback - Actual value: 0.00 %
Exh.recircul.valve 1 bank 1: pos.feedback - Offset closed: 1.22 %
Exhaust recirculation valve 1 bank 1: monitoring - status-Bits 0-7: 0
Exhaust recirculation valve 1 bank 1: monitoring - status-Bits 0-7: 7
Exh.recircul.valve 1 bank 1: pos.feedback - Raw voltage: 0.0 mV
20001 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
P0036 00 [10101111] - Malfunction / Open Circuit
Mileage: 321947 km
Date: 2024.10.02
Time: 06:19:28
Oxygen sensor bank 1 after oxi cat: signal qual. pump flow controller: 13
Oxyg.sensor bank 1 after oxi cat: signal quality temp regulator: 13
Oxygen sensor bank 1 after oxi cat: electric. corrected Pump current: 0.0000000 A
Oxygen sensor bank 1 after oxi cat: heater activation: 0.000 %
O2 sensor bank 1 dwnstrm oxi cat: adjustable resistor value: 0.0 Ohm
Oxyg.sens.bank 1 after oxi cat: curr.pump curr.adaptat.: 1.0000
4718 - No Communication with Transmission Control Module
U0101 00 [10101111] - -
Mileage: 321947 km
Date: 2024.10.02
Time: 06:19:26
Requested transmission torque: 1000.0 Nm
Cruise Control System (CCS): status-Bits 0-7: 7
selected gear-Bits 0-7: 0
Engine control module reset status-Bits 0-7: 2
Transmission torque intervention status-Bits 0-7: 0
Calculated reducing transmission intervention torque: 1000.0 Nm
Readiness: 1 5 0 0 1
Part No SW: 0D9 300 041 P HW: 02E 927 770 AQ
Component: DQ250-6F MQB H53 4508
Revision: 06253104 Serial number: TFK01602030361 CVN: 0000AF56
Shop #: WSC 73430 031 00063
ROD: EV_TCMDQ250021.rod
VCID: 2517F7AF556026920CD-8070
P1734 00 [00000010] - -
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-ESP-V1.clb
Part No SW: 3Q0 907 379 T HW: 3Q0 907 379 C
Component: ESC H32 0393
Revision: 00000000 Serial number: 60496000001967
Coding: 1A07629124210970007E060441C9245846249000608224F200610070C002
ROD: EV_Brake1UDSContiMK100ESP_034_SK37.rod
VCID: 4BC36117934430E2FA9-801E
21 Faults Found:
0128 - Function Restricted due to Insufficient Voltage
U1400 00 [00001000] - -
[undervoltage]
Reset counter: 215
Mileage: 321944 km
Date: 2024.09.30
Time: 00:00:42
0129 - Function Restricted due to Excessive Voltage
U1401 00 [00001000] - -
[Overvoltage]
Reset counter: 215
Mileage: 321944 km
0297 - Steering angle sensor
B1168 16 [00001000] - Voltage Too Low
Fault Frequency: 28
Reset counter: 215
Mileage: 321944 km
Date: 2024.09.26
Time: 00:01:09
8222 - Databus
[FCAN : Getriebe_11 message is not received]
Reset counter: 215
Mileage: 321944 km
Date: 2024.10.02
Time: 00:01:23
8226 - Databus
[FCAN : Getriebe_14 message is not received]
Reset counter: 215
Mileage: 321944 km
Date: 2024.10.02
Time: 00:01:24
8246 - Databus
[FCAN: Motor_Code_01 message is not received]
Reset counter: 215
Mileage: 321944 km
Date: 2024.09.26
Time: 00:01:14
8250 - Databus
[FCAN: Motor_07 message is not received]
Reset counter: 215
Mileage: 321944 km
Date: 2024.09.26
Time: 00:01:14
8252 - Databus
[FCAN: Motor_11 message is not received]
Reset counter: 215
Mileage: 321944 km
Date: 2024.09.26
Time: 00:01:09
8254 - Databus
[FCAN: Motor_12 message is not received]
Reset counter: 215
Mileage: 321944 km
Date: 2024.09.26
Time: 00:01:09
8256 - Databus
[FCAN: Motor_14 message is not received]
Reset counter: 215
Mileage: 321944 km
Date: 2024.09.26
Time: 00:01:10
8258 - Databus
[FCAN: Motor_20 message is not received]
Reset counter: 215
Mileage: 321944 km
Date: 2024.09.26
Time: 00:01:09
8286 - Databus
[FCAN: MO_Timeout_ESP signal is invalid]
Reset counter: 213
Date: 2024.09.24
Time: 15:36:11
8291 - Databus
[FCAN: MO_QBit_Motormomente signal is invalid]
Reset counter: 214
Mileage: 321944 km
Date: 2024.09.26
Time: 00:00:51
8351 - Databus
U1122 00 [00001000] - Implausible Message
[FCAN: Motor_17_alt veraltet bit is set]
Reset counter: 215
Mileage: 321944 km
Date: 2024.09.26
Time: 00:01:11
16401 - Tire Pressure Warning
C102D 00 [00001000] - -
Reset counter: 213
Date: 2024.09.24
Time: 15:36:11
16409 - Display for Tire Pressure Monitoring
C1146 02 [00001000] - Signal Failure
Reset counter: 215
Mileage: 321944 km
Date: 2024.10.02
Time: 00:08:30
16410 - Display for Tire Pressure Monitoring
Reset counter: 215
Mileage: 321944 km
Date: 2024.10.02
Time: 00:08:30
16412 - Display for Tire Pressure Monitoring
Reset counter: 215
Mileage: 321944 km
Date: 2024.10.02
Time: 00:08:30
16413 - Display for Tire Pressure Monitoring
Reset counter: 215
Mileage: 321944 km
Date: 2024.10.02
Time: 00:08:30
16416 - Display for Tire Pressure Monitoring
Reset counter: 215
Mileage: 321944 km
Date: 2024.10.02
Time: 00:08:30
16417 - Display for Tire Pressure Monitoring
Reset counter: 213
Mileage: 321944 km
Date: 2024.09.24
Time: 15:35:42
Part No SW: 5E0 907 044 Q HW: 5E0 907 044 Q
Component: Climatronic H04 1002
Revision: 00001K07
Coding: 02010004000100011005000000101000
ROD: EV_ACClimaBHBVW37X_004_VW37.rod
VCID: 333319F7EBB44822929-8066
Air quality sensor:
10 Faults Found:
459778 - Comfort System CAN Bus (SAE Medium Speed Bus)
U0011 00 [00001000] - Performance
Reset counter: 212
459009 - Databus
[Airbagsteuergerät - kein Signal/Kommunikation]
Fault Frequency: 9
Reset counter: 212
Mileage: 321944 km
Date: 2024.09.12
Time: 01:32:37
459012 - Databus
[ESP-Steuergerät - kein Signal/Kommunikation]
Reset counter: 213
Mileage: 321943 km
Date: 2024.08.29
Time: 12:23:18
459015 - Databus
[Feuchtesensor innen - kein Signal/Kommunikation]
Reset counter: 175
Mileage: 311933 km
Date: 2024.06.20
Time: 21:26:58
459013 - Databus
[Diagnoseinterface für Datenbus - kein Signal/Kommunikation]
Reset counter: 212
459525 - Databus
[Diagnoseinterface für Datenbus - bitte Fehlerspeicher auslesen]
Reset counter: 215
Mileage: 321943 km
Date: 2024.08.29
Time: 06:16:46
459023 - Databus
[Motorsteuergerät - kein Signal/Kommunikation]
Reset counter: 215
Mileage: 321943 km
Date: 2024.08.29
Time: 06:16:46
263426 - Air Quality Sensor
B10AF 31 [00001000] - No Signal
Reset counter: 212
Mileage: 321944 km
Date: 2024.09.15
Time: 04:26:44
Voltage terminal 30: 12.6 V
Outside temperature: 24.5 °C
System run time-Terminal 15 on: 176 s
263425 - Air Quality Sensor
B10AF 04 [00001000] - Internal System Fault
Fault Frequency: 167
Reset counter: 207
Mileage: 312008 km
Date: 2024.06.21
Time: 01:15:51
Voltage terminal 30: 13.5 V
Outside temperature: 28.5 °C
System run time-Engine running time: 23 s
System run time-Terminal 15 on: 24 s
262658 - High Pressure Sensor
B10AE 31 [00001000] - No Signal
Reset counter: 212
Mileage: 321944 km
Date: 2024.09.15
Time: 04:26:34
Engine RPM: 0 /min
Temperature downstream of evaporator: 29.0 °C
System run time-Terminal 15 on: 167 s
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 084 CJ HW: 5Q0 937 084 AL
Component: BCM MQBAB M H24 0175
Serial number: 01061605501292 Dataset Number: 5E0063t____ 0075
Coding: 0C001842424702FB47E04000000407080000000000000000000000000000
Shop #: WSC 73430 790 00000
ROD: EV_BCMBOSCH_015.rod
VCID: 025D8C33E48E31AA49F-8056
Subsystem 1 - Part No SW: 5E1 955 119 HW: 5E1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS371 160201 041 0570
Serial number: 160216073214
Coding: 065DDD
40 Faults Found:
5130 - Bulb for Front Left Turn Signal
B11E8 15 [00001001] - Open or Short to Plus
Reset counter: 83
Mileage: 316412 km
Date: 2024.07.11
Time: 00:19:41
Terminal 15 status: On
Terminal 50 status: OFF
CAN-Bus_aktiv: On
OFF: operated
Position lamps: Not operated
Low beam: Not operated
Voltage: 12.2 V
Outside temperature: 33.5 °C
5386 - Bulb for Front Right Turn Signal
B11EA 15 [00001001] - Open or Short to Plus
Reset counter: 83
Mileage: 316412 km
Date: 2024.07.11
Time: 00:19:41
CAN-Bus_aktiv: On
OFF: operated
Voltage: 12.2 V
6666 - Bulb for Low Beam Headlamp Left
B1217 15 [00001001] - Open or Short to Plus
Reset counter: 175
Mileage: 321944 km
Date: 2024.10.02
Time: 01:49:17
CAN-Bus_aktiv: On
OFF: Not operated
Low beam: operated
Voltage: 14.6 V
Outside temperature: 15.0 °C
6922 - Bulb for Low Beam Headlamp Right
B1218 15 [00001001] - Open or Short to Plus
Reset counter: 175
Mileage: 321944 km
Date: 2024.10.02
Time: 01:49:17
CAN-Bus_aktiv: On
OFF: Not operated
Low beam: operated
Voltage: 14.4 V
8714 - Bulb for Left Fog Lamp
B121F 15 [00001001] - Open or Short to Plus
Fault Frequency: 15
Mileage: 298920 km
Date: 2024.04.24
Time: 03:00:39
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 12.3 V
Outside temperature: 30.0 °C
8970 - Bulb for Right Fog Lamp
B1220 15 [00001001] - Open or Short to Plus
Fault Frequency: 129
Mileage: 298920 km
Date: 2024.04.24
Time: 03:00:39
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 12.3 V
10506 - Bulb for Left Tail Light
B12BE 15 [00001001] - Open or Short to Plus
Reset counter: 174
Mileage: 321906 km
Date: 2024.08.28
Time: 05:00:20
CAN-Bus_aktiv: On
Status Bremslichtschalter (HW): On
Status Bremslichtschalter (CAN): On
OFF: Not operated
Voltage: 12.4 V
Outside temperature: 36.5 °C
10515 - Bulb for Left Tail Light
B12BE 01 [00001001] - Electrical Failure
Reset counter: 168
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 12.6 V
Outside temperature: 36.0 °C
10771 - Bulb for Right Tail Light
B12BF 01 [00001001] - Electrical Failure
Reset counter: 180
Mileage: 298920 km
Date: 2024.04.24
Time: 03:00:39
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 12.3 V
12298 - License Plate Light
B12CA 15 [00001001] - Open or Short to Plus
Reset counter: 133
Mileage: 298920 km
Date: 2024.04.24
Time: 03:00:39
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 12.3 V
14602 - Bulb for Left Brake Lamp / Tail Lamp
B133A 15 [00001001] - Open or Short to Plus
Reset counter: 180
Mileage: 298920 km
Date: 2024.04.24
Time: 03:00:39
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 12.3 V
131330 - Supply voltage
U1011 00 [00001000] - Voltage too Low
[VersorgungsspannungSpannung zu niedrig]
Reset counter: 215
Mileage: 321944 km
Date: 2024.09.12
Time: 08:03:54
CAN-Bus_aktiv: On
OFF: operated
Voltage: 8.5 V
Outside temperature: 22.5 °C
131585 - Function Restricted due to Excessive Voltage
[Funktionseinschränkungdurch Überspannung]
Reset counter: 215
Mileage: 321944 km
Date: 2024.09.30
Time: 00:00:09
Terminal 15 status: OFF
CAN-Bus_aktiv: On
OFF: operated
Voltage: 16.5 V
Reset counter: 215
Mileage: 321944 km
Date: 2024.09.14
Time: 09:45:54
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 8.4 V
Outside temperature: 22.0 °C
132363 - Voltage Supply; Terminal 30; Left
B140D 13 [00001000] - Open Circuit
Mileage: 321944 km
Date: 2024.09.15
Time: 00:04:14
CAN-Bus_aktiv: On
OFF: operated
Voltage: 12.9 V
Outside temperature: 23.0 °C
133131 - Voltage Supply Terminal 30
B1423 13 [00001000] - Open Circuit
Mileage: 321944 km
Date: 2024.09.15
Time: 00:04:14
CAN-Bus_aktiv: On
OFF: operated
Voltage: 12.9 V
136458 - Terminal 15
B1148 15 [00001000] - Open or Short to Plus
Reset counter: 215
Mileage: 321944 km
Date: 2024.09.30
Time: 00:00:31
CAN-Bus_aktiv: On
OFF: operated
Voltage: 15.7 V
137217 - Outside temperature sensor
B103F 1B [00001000] - Resistance Too High
Mileage: 321944 km
Date: 2024.09.15
Time: 00:04:24
CAN-Bus_aktiv: OFF
OFF: operated
Voltage: 13.3 V
Outside temperature: 77.5 °C
395273 - Control Circuit for Signal Horn
B1344 14 [00001000] - Open or Short to Ground
Mileage: 321944 km
Date: 2024.09.12
Time: 01:33:46
CAN-Bus_aktiv: On
OFF: operated
last_wakeup: Pin A44 Klemme 15
Voltage: 12.4 V
Outside temperature: 19.5 °C
529941 - Databus
Reset counter: 212
CAN-Bus_aktiv: On
OFF: operated
Voltage: 13.5 V
Outside temperature: -50.0 °C
531221 - Databus
Reset counter: 212
CAN-Bus_aktiv: On
OFF: operated
Voltage: 12.9 V
533269 - Databus
Reset counter: 215
Mileage: 321943 km
Date: 2024.08.29
Time: 12:23:19
CAN-Bus_aktiv: On
OFF: operated
Voltage: 12.3 V
533525 - Databus
Fault Frequency: 42
Reset counter: 215
Mileage: 321943 km
Date: 2024.08.29
Time: 12:23:17
CAN-Bus_aktiv: On
OFF: operated
Voltage: 12.3 V
533781 - Databus
Fault Frequency: 8
Reset counter: 215
Mileage: 321943 km
Date: 2024.08.29
Time: 12:23:17
CAN-Bus_aktiv: On
OFF: operated
Voltage: 12.3 V
535317 - Databus
Reset counter: 212
CAN-Bus_aktiv: On
OFF: operated
Voltage: 13.5 V
536085 - Databus
Reset counter: 212
CAN-Bus_aktiv: On
OFF: operated
Voltage: 13.5 V
541973 - Databus
Reset counter: 215
Mileage: 321943 km
Date: 2024.08.29
Time: 06:16:45
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 12.2 V
Outside temperature: 33.0 °C
542229 - Databus
Reset counter: 215
Mileage: 321943 km
Date: 2024.08.29
Time: 06:16:45
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 12.2 V
542485 - Databus
Reset counter: 215
Mileage: 321943 km
Date: 2024.08.29
Time: 06:16:51
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 12.2 V
554517 - Databus
Fault Frequency: 42
Reset counter: 215
Mileage: 321943 km
Date: 2024.08.29
Time: 12:23:17
CAN-Bus_aktiv: On
OFF: operated
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-283.clb
Part No SW: 5Q0 919 283 F HW: 5Q0 919 283
Component: PARKHILFE 4K H10 0054
Revision: -------- Serial number: 39291604701848 Dataset Number: 5E0039t____ 0001
Coding: 0001050011
VCID: 3C2132CBC6EA875A433-8068
12 Faults Found:
1078804 - Rear Left Parking Aid Sensor
B1076 14 [00001000] - Open or Short to Ground
Fault Frequency: 13
Reset counter: 79
Mileage: 298920 km
Date: 2024.04.24
Time: 03:06:33
1079572 - Rear Right Parking Aid Sensors
B1079 14 [00001000] - Open or Short to Ground
Reset counter: 12
Mileage: 309430 km
Date: 2024.06.07
Time: 16:44:15
1079060 - Center Rear Left Parking Aid Sensor
B1077 14 [00001000] - Open or Short to Ground
Reset counter: 95
Mileage: 298920 km
Date: 2024.04.24
Time: 03:06:33
1079316 - Center Rear Right Parking Aid Sensor
B1078 14 [00001000] - Open or Short to Ground
Reset counter: 180
Mileage: 298920 km
Date: 2024.04.24
Time: 03:06:33
1080340 - Parking Aid Speaker
B107C 14 [00001000] - Open or Short to Ground
Reset counter: 215
Mileage: 321944 km
Date: 2024.09.30
Time: 00:00:25
13635840 - Supply voltage
[Versorgungsspannung - zu niedrig]
Reset counter: 215
Mileage: 321944 km
Date: 2024.10.02
Time: 00:52:41
[Funktionseinschränkung durch Unterspannung - unterer Grenzwert unterschritten]
Reset counter: 215
Mileage: 321944 km
Date: 2024.09.30
Time: 00:00:40
13893888 - Function Restricted due to Excessive Voltage
[Funktionseinschränkung durch Überspannung - oberer Grenzwert überschritten]
Reset counter: 215
12656913 - Databus
[Bremsensteuergerät - ESP_10 - kein Signal/keine Kommunikation]
Reset counter: 215
Mileage: 321943 km
Date: 2024.08.29
Time: 12:23:17
12656920 - Databus
[Bremsensteuergerät - ESP_21 - kein Signal/keine Kommunikation]
Reset counter: 215
Mileage: 321943 km
Date: 2024.08.29
Time: 12:23:17
13637426 - Databus
Fault Frequency: 30
Reset counter: 215
Mileage: 321944 km
Date: 2024.09.15
Time: 04:26:49
12648721 - Databus
[Getriebesteuergerät - Getriebe_11 - kein Signal/keine Kommunikation]
Reset counter: 215
Mileage: 321944 km
Date: 2024.10.02
Time: 00:01:23
Part No SW: 3Q0 959 655 AS HW: 3Q0 959 655 AS
Component: Airbag VW20 013 0200
Revision: -------- Serial number: 003SQP3SSBQ6 Dataset Number: 5E0003t____ 0057
Coding: 98CCC000000000005C5400CC000800000065
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 0F7BB507A7DC4CC2D61-805A
Subsystem 1 - Part No SW: ----------- HW: 454 001 502 16
Serial number: 3576U0000002D2352912
Subsystem 2 - Part No SW: ----------- HW: 454 002 601 14
Serial number: 3586U0000001F949DE0V
Subsystem 3 - Part No SW: ----------- HW: 454 802 101 16
Serial number: 3516R2FA2B609000000B
Subsystem 4 - Part No SW: ----------- HW: 454 802 601 16
Serial number: 3526R8B7D7E09000000Q
Subsystem 5 - Part No SW: ----------- HW: 454 801 501 16
Serial number: 3556VB90D6009000000C
Part No SW: 5Q0 953 507 GP HW: 5Q0 953 549 E
Component: Lenks. Modul 003 0120
Revision: -------- Serial number: 16011604220142
Coding: 1410
ASAM Dataset: EV_SMLSKLOMQB 020001
ROD: EV_SMLSKLOMQB_018_VW37.rod
VCID: 0A4DA413DCBE69EA01F-805E
131108 - Databus
U1121 00 [00011000] - Missing Message
[Time-Out Gateway_71: Time-Out BSG]
Reset counter: 212
Operating time: 737783 min
Terminal 30 power supply: 12.6 V
Voltage at switch: 4.98 V
Terminal 15 status: active
System status: 30
131140 - Databus
[Time-Out Klemmen_Status_01: Time-Out Gateway]
Reset counter: 212
Mileage: 321944 km
Date: 2024.09.15
Time: 00:08:09
Operating time: 747025 min
Terminal 30 power supply: 13.4 V
Terminal 15 status: not active
System status: 30
617752 - Selector Lever Park Position Lock Switch
B1162 29 [00011000] - Signal Implausible
Reset counter: 212
Mileage: 299504 km
Date: 2024.04.24
Time: 06:21:19
Operating time: 703936 min
Terminal 30 power supply: 14.5 V
Vehicle speed: 10 km/h
System status: 30
Part No SW: 5E0 920 781 B HW: 5E0 920 781 B
Component: KOMBI 206 7652
Coding: 07A502082180000801086A001000000000000000
Shop #: WSC 73430 031 12345
ASAM Dataset: EV_DashBoardJCIMQBAB 009005
ROD: EV_DashBoardJCIMQBAB_009_SK37.rod
VCID: 270BFDA72F6C34823E1-8072
18 Faults Found:
9456128 - Engine Control Module (ECM) not authorized
B104A 00 [00001001] - -
Mileage: 321944 km
Date: 2024.09.15
Time: 00:00:06
9456433 - Key
B104B 31 [00001000] - No Signal
Reset counter: 215
9456681 - Key
B104C 29 [00001000] - Implausible Signal
[Versorgungsspannung - unterer Grenzwert unterschritten Versorgungsspannung Spannung dauerhaft zu niedrig]
Reset counter: 215
Mileage: 321944 km
Date: 2024.09.12
Time: 08:05:17
13639427 - Databus
[Steuergerät für Motor: bitte Fehlerspeicher auslesen]
Reset counter: 214
Mileage: 321944 km
Date: 2024.09.26
Time: 00:02:37
13639936 - Databus
[Steuergerät für BCM / Bordnetz / el. ZE: bitte Fehlerspeicher auslesen]
Reset counter: 212
Mileage: 321944 km
Date: 2024.09.15
Time: 00:09:29
[Funktionseinschränkung durch Überspannung funktionelle Einschränkungen aufgrund vorübergehender Überspannung in der Versorgung.]
Reset counter: 215
16776962 - Databus
[Airbag_01 keine Kommunikation]
Fault Frequency: 9
Reset counter: 212
Mileage: 321944 km
Date: 2024.09.12
Time: 01:32:37
16776965 - Databus
[BEM_02 keine Kommunikation]
Reset counter: 212
16776968 - Databus
[ESP_24 keine Kommunikation]
Reset counter: 215
Mileage: 321943 km
Date: 2024.08.29
Time: 12:23:17
16776971 - Databus
[Motor_04 keine Kommunikation]
Reset counter: 215
Mileage: 321943 km
Date: 2024.08.29
Time: 06:16:43
16776973 - Databus
[RKA_01 keine Kommunikation]
Reset counter: 215
Mileage: 321943 km
Date: 2024.08.29
Time: 12:23:22
16776978 - Databus
[LH_EPS_01 keine Kommunikation]
Reset counter: 212
Mileage: 321944 km
Date: 2024.09.15
Time: 04:26:33
16776983 - Databus
[WBA_03 keine Kommunikation]
Fault Frequency: 13
Reset counter: 215
Mileage: 321944 km
Date: 2024.09.12
Time: 00:43:12
16776988 - Databus
[TSK_07 keine Kommunikation]
Reset counter: 215
Mileage: 321943 km
Date: 2024.08.29
Time: 06:16:43
16776993 - Databus
[ESP_21 keine Kommunikation]
Fault Frequency: 19
Reset counter: 215
Mileage: 317560 km
Date: 2024.07.25
Time: 00:21:42
16777018 - Function Restricted due to Interrupted Communications
U1110 00 [00001000] - -
[BAP_Audio_0x31 keine Kommunikation]
Reset counter: 192
Mileage: 321478 km
Date: 2024.08.23
Time: 00:50:06
[BAP_TEL_0x28 keine Kommunikation]
Reset counter: 181
Mileage: 320978 km
Date: 2024.08.19
Time: 23:16:45
Part No SW: 5Q0 907 530 AH HW: 5Q0 907 530 E
Component: GW MQB Mid 127 1244
Revision: -------- Serial number: 0004564301 Dataset Number: 3V0067t____ 0015
Coding: 030100045F087300EB0002481C0F00010001050000000000000000000000
GVL: 01543C0000000000400C00000000C80000000000000000000000000000000000
ROD: EV_GatewLear_013.rod
VCID: 77ABEDE7BF4C64026E1-8022
Generator:
Subsystem 2 - Part No SW: 3V0 919 719 A HW: 3V0 919 719 A
Component: E221__MFL-PR6 H02 0150
Serial number: 000000000C0704120716
12 Faults Found:
131594 - Parallel Parking Assistance Control Module
U104E 00 [00001000] - No communication
[Timeout Knoten 0x0A / 76 - Steuergerät für Parklenkassistent]
Reset counter: 212
Mileage: 321944 km
Date: 2024.09.15
Time: 04:33:27
Terminal 30 power supply: 12.7 V
Terminal 15: On
131602 - Power Steering Control Module
U101D 00 [00001000] - No Communication
[Timeout Knoten 0x12 / 44 - Steuergerät für Lenkhilfe]
Reset counter: 212
Mileage: 321944 km
Date: 2024.09.15
Time: 04:26:36
Terminal 30 power supply: 13.1 V
Terminal 15: On
131603 - No Communication with ABS Brake Control Module
U0121 00 [00001000] - -
[Timeout Knoten 0x13 / 03 - Steuergerät für ABS Bremse]
Reset counter: 215
Mileage: 321943 km
Date: 2024.08.29
Time: 12:23:19
Terminal 30 power supply: 12.1 V
Terminal 15: On
131605 - No Communications with Airbag Control Module
U0151 00 [00001000] - -
[Timeout Knoten 0x15 / 15 - Steuergerät für Airbag]
Reset counter: 212
Mileage: 321944 km
Date: 2024.09.15
Time: 04:33:29
Terminal 15: On
131702 - No Communication with Engine Control Module (SAE ECM/PCM)
U0100 00 [00001000] - -
[Timeout Knoten 0x76 / 01 - Motorsteuergerät]
Reset counter: 215
Mileage: 321943 km
Date: 2024.08.29
Time: 05:50:05
Terminal 30 power supply: 12.5 V
Terminal 15: OFF
131703 - No Communication with Transmission Control Module
U0101 00 [00001000] - -
[Timeout Knoten 0x77 / 02 - Steuergerät für Getriebe]
Fault Frequency: 11
Reset counter: 215
Mileage: 321944 km
Date: 2024.09.12
Time: 00:43:12
Terminal 30 power supply: 12.8 V
Terminal 15: On
197175 - Control unit for battery monitoring
U1050 00 [00001001] - No Communication
[BDM (LIN#1) Timeout]
Reset counter: 90
Mileage: 317036 km
Date: 2024.07.23
Time: 00:01:55
Terminal 30 power supply: 13.0 V
Terminal 15: On
66561 - Powertrain Databus
U0001 00 [00001000] - Unspecified Malfunction
[Bus defekt CAN-Antrieb]
Reset counter: 212
Mileage: 321944 km
Date: 2024.09.12
Time: 01:32:37
Terminal 30 power supply: 12.3 V
Terminal 15: On
66565 - Diagnostic Databus
U1202 00 [00001000] - Malfunction
[Bus defekt CAN-Diagnose]
Reset counter: 212
Mileage: 321944 km
Date: 2024.09.15
Time: 05:18:22
Terminal 15: On
65793 - Powertrain Databus (VAG Single-Wire Mode) (SAE L Shorted H)
U0009 00 [00001000] - -
[Eindrahtfehler CAN-Antrieb]
Reset counter: 212
Mileage: 321944 km
Date: 2024.09.15
Time: 04:57:19
Terminal 15: On
U1101 00 [00001000] - Active
Reset counter: 212
Mileage: 321944 km
Date: 2024.09.15
Time: 00:09:43
Terminal 15: On
1282 - Supply voltage
[Versorgungsspannung - unterer Grenzwert unterschritten]
Reset counter: 215
Mileage: 321944 km
Date: 2024.09.12
Time: 08:01:37
Terminal 30 power supply: 8.5 V
Terminal 15: On
Part No SW: 5Q4 959 593 E HW: 5Q4 959 593 B
Component: TSG FS 010 0031
Serial number: 0000189184530 Dataset Number: 5E0222t____ 0018
Coding: 00110120D000040000001100
ROD: EV_DCUDriveSideEWMAXKLO.rod
VCID: 47CB5D278F2CD482DE1-8012
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000009086801
Coding: 010200
9 Faults Found:
65548 - Supply voltage
Reset counter: 215
Mileage: 321944 km
Date: 2024.09.12
Time: 08:03:39
B1487 54 [00001001] - Missing Calibration / Basic Setting
Reset counter: 174
Mileage: 321944 km
Date: 2024.09.12
Time: 00:00:32
458752 - Databus
[Airbag_01 Datenbus fehlende Botschaft]
Reset counter: 212
Mileage: 321944 km
Date: 2024.09.15
Time: 04:33:31
458776 - Databus
[Gateway_71 Datenbus fehlende Botschaft]
Reset counter: 212
Date: 2024.09.15
Time: 00:10:39
458803 - Databus
[Motor_14 Datenbus fehlende Botschaft]
Reset counter: 215
Mileage: 321943 km
Date: 2024.08.29
Time: 06:16:53
458809 - Databus
[Systeminfo_01 Datenbus fehlende Botschaft]
Reset counter: 212
Date: 2024.09.15
Time: 00:10:39
589827 - Window Regulator; Rear Driver Side
B131F 54 [00001001] - Missing Calibration / Basic Setting
Reset counter: 175
Mileage: 321944 km
Date: 2024.10.02
Time: 00:03:10
589829 - Window Regulator; Rear Driver side
B131F F5 [00001000] - Supply Voltage too Low
Reset counter: 215
Mileage: 321944 km
Date: 2024.09.15
Time: 03:02:09
65653 - Child Safety Lock Switch
B129F 29 [00001000] - Implausible signal
Mileage: 303162 km
Date: 2024.05.06
Time: 13:21:01
Part No SW: 5Q0 909 144 S HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 126 1063
Dataset Number: 5E0074t____ 0018
Coding: 0303
Shop #: WSC 73430 790 00063
VCID: 44D14A2BBE1AFF9A3B3-8010
7 Faults Found:
26885 - Comfort limitation
C10D7 00 [00001000] - -
[Speicherinkonsistenz im Errorhandler]
Motor status: 00
Supply voltage: 0.00 V
Temperature: 80.0 °C
KFC: 69
KFA: 00 05
Freeze frame conditions: 21
4868 - Internal Fault
B200F F0 [00001000] - Unknown Error Elaboration
[Fehler im Abschaltpfadtest 2nd current check (PWM: 35/65/50)]
Mileage: 321944 km
Motor status: 00
System status: Reset
Supply voltage: 17.50 V
Temperature: 25.0 °C
KFC: 13
KFA: 00 04
nApplI_RotorSpeedFilt_xds16: 158 /min
mApplI_LimitedMotorTorque_xds16: 0.000 Nm
icuCurrentPhase_U_IRQ_xds16: -44.44 A
icuCurrentPhase_W_IRQ_xds16: 9.13 A
mApplI_TorsionBarTorque_xds16: 0.00 Nm
wrsCurrRotorPosIRQ_xdu16: 34.1 °
23552 - Databus
[PLA_01 Botschaft - CAN-Timeout]
Reset counter: 175
Mileage: 321944 km
Date: 2024.09.30
Time: 00:00:40
Motor status: 00
Supply voltage: 11.75 V
Temperature: 26.0 °C
KFC: 5C
KFA: 00 00
Freeze frame conditions: 5F
uioUdNotFilt_xdu16: 12.30 V
uAdSensI_SwitchedKl30_xdu16: 12.31 V
ASC_CTRL_GET_ILWS_ERR_FLAGS: 00
22272 - Databus
[KFC_MOTOR_11 Botschaft - CAN-Timeout]
Reset counter: 215
Mileage: 321944 km
Date: 2024.10.02
Time: 00:00:48
Motor status: 03
System status: Driving mode
Supply voltage: 10.75 V
Temperature: 13.0 °C
KFC: 57
KFA: 00 00
Freeze frame conditions: 20
uioUdNotFilt_xdu16: 10.84 V
uAdSensI_SwitchedKl30_xdu16: 10.84 V
22528 - Databus
[MOTOR_12 Botschaft - CAN-Timeout]
Reset counter: 215
Mileage: 321944 km
Date: 2024.10.02
Time: 00:00:48
Motor status: 03
KFC: 58
KFA: 00 00
23040 - Databus
[MOTOR_20 Botschaft - CAN-Timeout]
Reset counter: 215
Mileage: 321944 km
Date: 2024.10.02
Time: 00:00:48
Motor status: 03
KFC: 5A
KFA: 00 00
uioUdNotFilt_xdu16: 10.70 V
uAdSensI_SwitchedKl30_xdu16: 10.72 V
22784 - Databus
[MOTOR_14-Botschaft - CAN-Timeout]
Reset counter: 215
Mileage: 321944 km
Date: 2024.10.02
Time: 00:17:08
Motor status: 03
Supply voltage: 12.00 V
Temperature: 23.0 °C
KFC: 59
KFA: 00 00
uioUdNotFilt_xdu16: 12.20 V
uAdSensI_SwitchedKl30_xdu16: 12.21 V
Part No SW: 5Q4 959 592 E HW: 5Q4 959 592 B
Component: TSG BFS 010 0031
Serial number: 0000189009825 Dataset Number: 5E0157t____ 0018
ROD: EV_DCUPasseSideEWMAXKLO.rod
VCID: 46D550238826CD8A257-8012
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000009121891
Coding: 190200
8 Faults Found:
Reset counter: 215
Mileage: 321944 km
Date: 2024.09.12
Time: 08:03:47
Reset counter: 175
Mileage: 321944 km
Date: 2024.09.12
Time: 00:00:32
65593 - Switch for Central Locking
B122D 29 [00001000] - Signal Implausible
Fault Frequency: 36
Reset counter: 215
Mileage: 302912 km
Date: 2024.05.05
Time: 15:51:48
458752 - Databus
Reset counter: 212
Mileage: 321944 km
Date: 2024.09.15
Time: 04:33:31
458776 - Databus
Reset counter: 212
458803 - Databus
Reset counter: 215
Mileage: 321943 km
Date: 2024.08.29
Time: 06:16:53
458809 - Databus
Reset counter: 212
589845 - Window Regulator; Front Passenger side
B1320 F5 [00001000] - Supply Voltage too Low
Reset counter: 215
Mileage: 321944 km
Date: 2024.09.23
Time: 20:59:30
Address 5F: Information Electr. (J794) Labels:| 3V0-035-MIB-STD2.clb
Part No SW: 5Q0 035 864 A HW: 5Q0 035 864 A
Component: MU-S-N-ER H25 0245
Serial number: SKZAZ2S8295280 Dataset Number: 5E0CV1t____ 0261
Coding: 03730101FF00000011110001000800002F0200C401200100C6
ROD: EV_MUStd4CTSAT_VW26.rod
VCID: 313F13FF11A87A32E05-8064
Subsystem 1 - Part No SW: 5E0 919 605 J HW: 5E0 919 605 J
Component: ABT_Std-2_Nav H43 1031
Serial number: SKZ8Z9SLH003JV
13 Faults Found:
1537 - Supply voltage
[Supply voltage - lower limit value not reached]
Reset counter: 215
Mileage: 321944 km
Date: 2024.09.12
Time: 08:00:27
Voltage terminal 30: 9.1 V
1538 - Function Restricted due to Excessive Voltage
[Function restriction due to excessive voltage - upper limit value exceeded]
Reset counter: 215
Voltage terminal 30: 0.8 V
[Function restriction due to insufficient voltage - lower limit value not reached]
Reset counter: 215
Mileage: 321944 km
Date: 2024.09.12
Time: 08:01:46
Voltage terminal 30: 8.5 V
[Anti-theft protection - component protection active (0xEA6100)]
Reset counter: 212
Mileage: 321944 km
Date: 2024.09.22
Time: 01:22:23
Voltage terminal 30: 7.8 V
6697 - Databus
[Airbag: no communication]
Reset counter: 212
Mileage: 321944 km
Date: 2024.09.15
Time: 04:33:26
Voltage terminal 30: 13.2 V
Network diagnosis-Status: Enabled
6702 - Databus
[ESP: no communication]
Reset counter: 215
Mileage: 321943 km
Date: 2024.08.29
Time: 12:23:17
Voltage terminal 30: 12.3 V
6708 - Databus
[Engine: no communication]
Reset counter: 215
Mileage: 321943 km
Date: 2024.08.29
Time: 06:16:52
Voltage terminal 30: 12.1 V
6919 - Function Restricted due to Missing Message(s)
U1111 00 [00001000] - -
[Tire pressure monitoring (0x07) - function restriction due to communication error - BapErr_timeout: heartbeat]
Reset counter: 215
Mileage: 321943 km
Date: 2024.08.29
Time: 12:23:22
6922 - Function Restricted due to Missing Message(s)
[Park assist OPS (0x0A) - function restriction due to communication error - BapErr_timeout: heartbeat]
Reset counter: 212
Mileage: 321944 km
Date: 2024.09.15
Time: 04:33:28
Voltage terminal 30: 12.9 V
6950 - Function Restricted due to Missing Message(s)
[Brake (0x26) - function restriction due to communication error - BapErr_timeout: heartbeat]
Reset counter: 215
Mileage: 321943 km
Date: 2024.08.29
Time: 12:23:21
Voltage terminal 30: 12.2 V
[Tire pressure monitoring (0x07) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 215
Mileage: 321943 km
Date: 2024.08.29
Time: 12:23:25
BAP-BAP_Function_ID: 02
7178 - Function Restricted due to Missing Message(s)
[Park assist OPS (0x0A) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 212
Mileage: 321944 km
Date: 2024.09.15
Time: 04:33:32
7206 - Function Restricted due to Missing Message(s)
[Brake (0x26) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 215
Mileage: 321943 km
Date: 2024.08.29
Time: 12:23:25
End----------(Elapsed Time: 01:37, VBatt start/end: 12.4V/12.4V)-----------
