Unfold ORVM on ignition ON only
spk
India
C?ID=566391
Everytime I lock and unlock my car, the ORVM gets folded and unfolded. I want the folding behaviour as it is, but need ti unfold only when I turn on the ignition, not while unlocking.
The scan file is as follows. Any help will be appreciated.
Sunday,14,January,2024,12:40:08:24446
VCDS Version: 23.11.0.0  HEX-V2 CB: 0.4643.4
VIN: MEXK21CW8NT003241   License Plate:
Chassis Type: CW-VW27 (2Q0)
Scan: 01 03 05 08 09 15 17 19 2B 44 5F
VIN: MEXK21CW8NT003241   Mileage: 10802km-6712miles
Address 01: Engine (J623-DTBA)       Labels: None
   Part No SW: 04C 906 025 DF    HW: 04C 907 309 CF
   Component: R3 1.0l TFS   H80 2833
   Revision: DYH80000    CVN: CF5ECE3D
   Coding: 01190012232408001000
   Shop #: WSC 39657 005 1048576
   ASAM Dataset: EV_ECM10TFS01104C906025DF 003004
   ROD: EV_ECM10TFS01104C906025DF_003.rod
   VCID: 678BABD12FE823D28E9-8032
   VINID: 755A1B0814E721E9000030842084E1E484
   Part No SW: 5QP 614 517     HW: 2Q0 614 517 L
   Component: ESC_base      H13 0201
   Serial number: 36900862210922
   Coding: 99058B643F4199B0D1FEFC1A72E262A649B6AD06224A26242C541254454E4665926DB56044526424342A482AA231D643178C6BC2E8A8AC5015350A
   Shop #: WSC 00793 648 00200
   ASAM Dataset: EV_Brake1BOSCHESPMQBA0 005001
   ROD: EV_Brake1BOSCHESPMQBA0_005_VW27.rod
   VCID: 0E45BE7560D2929AADF-805A
   Part No SW: 3Q0 959 435 Q    HW: 3Q0 959 435 Q
   Component: VWKESSYMQB    037 1400
   Revision: 00037000    Serial number: 0580412042 Dataset Number: V03935342GU 0001
   Coding: 032C0C0623
   ASAM Dataset: EV_KessyHellaMQBAB 004055
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 48C9486D42360CAAA73-801C
Address 08: Auto HVAC (J255)       Labels:* None
   Part No SW: 6JM 907 057 A    HW: 6JM 907 057 A
   Component: Climatronic   035 0208
   Coding: 012100000400003100000401524011050101350000000000000000000000
   ASAM Dataset: EV_ACClimaBHBMQBA0Touch 001008
   ROD: EV_ACClimaBHBMQBA0Touch.rod
   VCID: 4ACD72655C3AFEBAB17-801E
   Part No SW: 2Q0 937 089 D    HW: 2Q0 937 089 C
   Component: BCM A0 Std    H12 0954
   Serial number: 014041021A0207 Dataset Number: V03935360VS 0001
   ASAM Dataset: EV_BCMA0 207001
   ROD: EV_BCMA0_207_VW27.rod
   VCID: 3B2327A103E057323A1-806E
   Subsystem 1 - Part No SW: 5Q0 955 559 C    HW: 5Q0 955 559 C  Labels: 5Q0-955-547.CLB
   Component: RLS  054 0206
   Serial number: S3Y21M06D29H16M12S36
   Coding: 02184D
   Driver door control module:
   Subsystem 2 - Part No SW: 5QR 959 801 A    HW: 5QR 959 801 A
   Component: FHSG_DRV  003 0010
   Serial number: AP0883RHNA3721007603
   Coding: 2D2203
   Part No SW: 2Q0 959 655 AP    HW: 2Q0 959 655 AP
   Component: VW22Airbag    020 0511
   Revision: --------    Dataset Number: V03935352DL 0001
   Coding: 88CCC000000000007C000000008800000065
   Shop #: WSC 01234 785 00200
   ASAM Dataset: EV_AirbaVW22BPAVW27X 001036
   ROD: EV_AirbaVW22BPAVW27X.rod
   VCID: 0B43B76113C0A7B24A1-805E
   Subsystem 1 - Part No SW: -----------    HW: 442 062 505 21
   Serial number: 3577Y53A90477AC1013%
   Subsystem 2 - Part No SW: -----------    HW: 442 062 505 21
   Serial number: 3587Y51AF0477AC0C25I
   Subsystem 3 - Part No SW: -----------    HW: 442 0B1 806 21
   Serial number: 3517710B3066BC66A24F
   Subsystem 4 - Part No SW: -----------    HW: 442 0B2 406 21
   Serial number: 3527711A906150F101A+
   Subsystem 5 - Part No SW: -----------    HW: 442 132 206 21
   Component: FrontSensor_D  290 118A
   Serial number: 355AG33BEC4D3CB51428
   Part No SW: 2GP 920 310 A    HW: 2GP 920 310 A
   Component: KOMBI         030 3091
   Coding: 252400102180000C020828001000000000000509
   ASAM Dataset: EV_DashBoardJCIMQBAB 010005
   ROD: EV_DashBoardJCIMQBAB_010_VW27.rod
   VCID: 392F3DA909DC652228D-806C
Address 19: CAN Gateway (J533)       Labels:* Redir Fail!
   Part No SW: 2Q0 909 901 E    HW: 2Q0 937 089 C
   Component: GW MQB A0     H12 0954
   Serial number: 014041021A0207 Dataset Number: V03935352YA 0001
   Coding: 010100082000570000000000000F00000001070000000000000000000000
   GVL: 01403C0000000600400000000000480000000000000000000000000000000000
   ASAM Dataset: EV_GatewA0 013026
   ROD: EV_GatewA0_VW27.rod
   VCID: 34310C9D2EBE984AFBB-8060
   Generator:
   Component: 4-00-01-00-04
   Subsystem 2 - Part No SW: 3G0 959 442 AH    HW: 3G0 959 442 AH  Labels: 3C8-959-537.CLB
   Component: E221__MFL-PR6  H50 0500
   Serial number: PR6-0440036146214306
   Coding: 280C00
131699 - Control unit for information electronics 1
          U1054 00 [00001000] - No Communication
          [Timeout Knoten 0x73 / 5F - Steuerger‰t f¸r Informationselektronik 1]
                    Reset counter: 210
                    Mileage: 10768 km
                    Date: 2024.01.06
                    Time: 13:51:28
                    Terminal 30 power supply: 12.3 V
                    Terminal 15: OFF
   Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
   Component: ELV-MQBB      H09 0021
   Serial number: 21000179408002
   Coding: 0000000000000000
   ROD: EV_ELVMarqMQBA0_VW27.rod
   VCID: 313F0589D1ACAD6290D-8064
Address 44: Steering Assist (J500)       Labels: None
   Part No SW: 5QR 909 144 C    HW: 5QR 909 144 A
   Component: EPS_ECU       430 4250
   Serial number: 000023.04.21000 Dataset Number: V03935356GT 0001
   Coding: 00000000000000000100020101000100000001000101
   ASAM Dataset: EV_SteerAssisNSKGEN3MQB 004008
   ROD: EV_SteerAssisNSKGEN3MQB.rod
   VCID: 56F596159882AA5A25F-8002
   Part No SW: 6JR 035 180     HW: 6JR 035 180
   Component: MU-R--R2      H04 0562
   Serial number: VWZ7Z2Y9100528  Dataset Number: V03935361FB 0001
   Coding: 22160508000000000000000000000000000000000000000000
   ASAM Dataset: EV_MUREGIO 001010
   ROD: EV_MUREGIO.rod
   VCID: 03539F413B90EFF2321-8056
End----------(Elapsed Time: 00:43, VBatt start/end: 12.1V/12.1V)-----------
Westbury, UK
What's an ORVM?
spk
India
C?ID=566391
sorry for the short form. I mean Outside Rear View Mirror that mirrors fitted on doors
TTT
C?ID=547002
PAMABM from the MO9BCM.
spk
India
C?ID=566391
IDE00001-ENG130235-Production mode-Entry_control,not_active ,3
IDE00001-ENG115730-Production mode-Exterior lighting,not_active ,3
IDE00001-ENG112304-Production mode-Heckwischer,not_active ,3
IDE00001-ENG98647-Production mode-Interior lights,not_active ,3
IDE00001-ENG115729-Production mode-Scheinwerferreinigung,not_active ,3
IDE00001-ENG130231-Production mode-Window_regulator_nr_1,not_active ,3
IDE00001-ENG130232-Production mode-Window_reversing_threshold,not_active ,3
IDE00002-Transport mode,active ,4
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking,DELAY ,5
IDE02269-ENG149191-Acknowledgement signals-Akustische_Rueckmeldung_entriegeln,active ,5
IDE02269-ENG149190-Acknowledgement signals-Akustische_Rueckmeldung_global,active ,5
IDE02269-ENG149195-Acknowledgement signals-Akustische_Rueckmeldung_Signalhorn,active ,5
IDE02269-ENG149192-Acknowledgement signals-Akustische_Rueckmeldung_verriegeln,active ,5
IDE02269-ENG149194-Acknowledgement signals-Dauer_der_Akustischen_Rueckmeldung_vom_Einfachhorn,normal ,5
IDE02269-ENG149193-Acknowledgement signals-Menuesteuerung_akustische_Rueckmeldung,active ,5
IDE02269-ENG149189-Acknowledgement signals-Optische_Rueckmeldung_3.Bremsleuchte,not active ,5
IDE02269-ENG149188-Acknowledgement signals-Optische_Rueckmeldung_Komfortschliessen,not active ,5
IDE02269-ENG130230-Acknowledgement signals-pa_quittungston_beim_zweiten_ZV_Auf_Befehl,not active ,5
IDE02269-ENG130229-Acknowledgement signals-pa_quittungston_beim_zweiten_ZV_Zu_Befehl,not active ,5
IDE02488-Anti-theft system interior monitoring,No Response From Subnet Component,3
IDE02711-ENG149246-Rear wiper-Automatisches_Heckwischen,not active ,8
IDE02711-ENG112304-Rear wiper-Heckwischer,Keine_Spannungsanforderung ,8
IDE02711-ENG149248-Rear wiper-Heckwischer_Weiterlauf,not active ,8
IDE02711-ENG115850-Rear wiper-Komfortwischen_Heck,active ,8
IDE02711-ENG149251-Rear wiper-Komfortwischen_Heck_Intervallpausenzeit_Stufe_1,5 s,8
IDE02711-ENG149252-Rear wiper-Komfortwischen_Heck_Intervallpausenzeit_Stufe_2,3 s,8
IDE02711-ENG149250-Rear wiper-Komofortwischen_Heck_Intervallpausenzeit_Stufe_Automatik,7 s,8
IDE02711-ENG149249-Rear wiper-Komofortwischen_Heck_Intervallpausenzeit_Stufe_Intervall,7 s,8
IDE02711-ENG149245-Rear wiper-Menuesteuerung_Komfortwischen_HW,active ,8
IDE02711-ENG148996-Rear wiper-rear_window_wiper,nur Komfortwischen ,8
IDE02711-ENG149247-Rear wiper-Traenenwischen_Heck,not active ,8
IDE02711-ENG154831-Rear wiper-Zeit_wasch_min_heck,0 ms,8
IDE02957-ENG154500-Ambient lighting-Ambience_borders_front,installed ,8
IDE02957-ENG133384-Ambient lighting-Ambient_Farbliste_HMI,not active ,8
IDE02957-ENG154513-Ambient lighting-Ambiente_Farbwahl_FPA_waehlbare_Kopplung,not active ,8
IDE02957-ENG154514-Ambient lighting-Ambiente_Farbwahl_FPA_waehlbare_Kopplung_Status_hmi_default,not active ,8
IDE02957-ENG149168-Ambient lighting-Ambientelicht_mit_raste_heckdeckel,not enabled ,8
IDE02957-ENG126836-Ambient lighting-Ambientemenue mit alle Zonen,not active ,8
IDE02957-ENG126835-Ambient lighting-Ambientemenue mit globalem aus,not active ,8
IDE02957-ENG154907-Ambient lighting-Applikationsleisten_Tuer,not installed ,8
IDE02957-ENG154995-Ambient lighting-Cupholderbeleuchtung,not installed ,8
IDE02957-ENG125648-Ambient lighting-Dachbeleuchtung,not installed ,8
IDE02957-ENG125029-Ambient lighting-Defaultwert Ambienteprofil Farbe,NOT-DEFINED ,8
IDE02957-ENG149163-Ambient lighting-Defaultwert_Ambienteprofil_Fussraum,0 %,8
IDE02957-ENG149164-Ambient lighting-Defaultwert_Ambienteprofil_Tuer,30 %,8
IDE02957-ENG149165-Ambient lighting-Defaultwert_Ambienteprofil_Vorn,30 %,8
IDE02957-ENG125651-Ambient lighting-Farbwahl ueber Fahrprofil,not installed ,8
IDE02957-ENG125650-Ambient lighting-Farbwahl ueber HMI,not installed ,8
IDE02957-ENG114629-Ambient lighting-Footwell lighting,not installed ,8
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung,not enabled ,8
IDE02957-ENG155264-Ambient lighting-Lautsprecherbeleuchtung,not installed ,8
IDE02957-ENG125647-Ambient lighting-Mittelkonsolenbeleuchtung,not installed ,8
IDE02957-ENG125649-Ambient lighting-Panoramaschiebedachbeleuchtung,not installed ,8
IDE02957-ENG149167-Ambient lighting-Tuerinnengriff_mit_Tuertafel,not installed ,8
IDE02957-ENG149166-Ambient lighting-Tuerinnengriffbeleuchtung_mit_I-Tafel,not installed ,8
IDE03638-IDE04231-Stationary cornering lamp-Steering wheel angle: offset,0.0 °,16
IDE03638-ENG116677-Stationary cornering lamp-Abdimmgeschwindigkeit,40.0 %/s,16
IDE03638-ENG149111-Stationary cornering lamp-bei_Rueckwaertsfahrt,both sides ,16
IDE03638-ENG116682-Stationary cornering lamp-Maximaltemperatur,100.0 °C,16
IDE03638-ENG149114-Stationary cornering lamp-Obere_Geschwindigkeitsschwelle,40.0 km/h,16
IDE03638-ENG149117-Stationary cornering lamp-obere_Grenztemperatur,95.0 °C,16
IDE03638-ENG149116-Stationary cornering lamp-Oberer_Lenkradwinkel,90 °,16
IDE03638-ENG149113-Stationary cornering lamp-Untere_Geschwindigkeitsschwelle,0.0 km/h,16
IDE03638-ENG149118-Stationary cornering lamp-untere_Grenztemperatur,80.0 °C,16
IDE03638-ENG149115-Stationary cornering lamp-Unterer_Lenkradwinkel,30 °,16
IDE03638-ENG116674-Stationary cornering lamp-Vorschrift,ECE_R119 ,16
IDE03638-ENG149112-Stationary cornering lamp-Zeitwert_Einschaltzeit_Abbiegelicht,15 min,16
IDE04927-IDE01446-Window heater-Running time of heated front window,600 s,9
IDE04927-MAS01535-Window heater-Rear window defogger,installed ,9
IDE04927-MAS01564-Window heater-Front windshield heater,not installed ,9
IDE04927-ENG142182-Window heater-Abschalttemperatur_fuer_Frontscheibenheizung,35.0 °C,9
IDE04927-ENG142181-Window heater-Abschalttemperatur_fuer_Heckscheibenheizung,35.0 °C,9
IDE04927-ENG126613-Window heater-Aussenspiegelheizung,0 s,9
IDE04927-ENG142180-Window heater-Heckscheibenheizung_Zeitwert,600 s,9
IDE04927-ENG142179-Window heater-Temperaturabhaengige_Einschaltzeit_FSH,not active ,9
IDE04927-ENG142178-Window heater-Temperaturabhaengige_Einschaltzeit_HSH,not active ,9
IDE05145-Light configuration,21 34 00 14 02 00 7F 00 00 00 00 00 00 00 00 00 21 3E 00 15 04 00 7F 00 00 00 00 00 00 00 00 00 04 48 00 4A 14 00 64 08 09 18 06 00 9C 00 00 00 04 4C 00 4C 14 00 64 08 0A 18 07 00 9C 00 00 00 01 44 00 4B 14 00 7F 08 0A 7F 00 00 00 00 00 00 01 3A 00 49 14 00 7F 08 09 7F 00 00 00 00 00 00 05 36 00 1A 0B 1E 7F 0D 0F 7F 00 00 00 00 00 00 05 40 00 1B 0C 1E 7F 0E 0F 7F 00 00 00 00 00 00 20 37 00 1C 0D 0F 7F 00 00 00 00 00 00 00 00 00 20 41 00 1D 0E 0F 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 38 00 22 12 16 64 00 00 00 00 00 00 00 00 00 0A 42 00 23 13 17 64 00 00 00 00 00 00 00 00 00 ,208
IDE05548-ENG149125-Additional interior light-Signal_mapping_ambient_lighting_doors_lin,0 ,38
IDE05548-ENG149126-Additional interior light-Signal_mapping_door_handle_lighting_lin,0 ,38
IDE05548-ENG149127-Additional interior light-Signal_mapping_puddle_light_lin,puddle light ,38
IDE05822-Anti-theft alarm system vehicle inclination sensor,No Response From Subnet Component,38
IDE05823-DWA Interior monitoring parameter set,No Response From Subnet Component,38
IDE06089-ENG149261-Seat heater level current consumption allocation-Art_der_Sitzheizungsregelung,Time-controlled ,36
IDE06089-ENG155386-Seat heater level current consumption allocation-Not_networked_seat_heater_rearseats,not connected ,36
IDE06089-ENG141976-Seat heater level current consumption allocation-Sitzheitzung_CAN,not installed ,36
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,1 s,36
IDE06089-ENG149262-Seat heater level current consumption allocation-Sitzheizung PWM Stufe 1,0 %,36
IDE06089-ENG149263-Seat heater level current consumption allocation-Sitzheizung PWM Stufe 2,20 %,36
IDE06089-ENG149264-Seat heater level current consumption allocation-Sitzheizung PWM Stufe 3,0 %,36
IDE06089-ENG149265-Seat heater level current consumption allocation-Sitzheizung PWM Stufe 4,80 %,36
IDE06089-ENG149266-Seat heater level current consumption allocation-Sitzheizung PWM Stufe 5,0 %,36
IDE06089-ENG149267-Seat heater level current consumption allocation-Sitzheizung PWM Stufe 6,100 %,36
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss,0.05 ,36
IDE06089-ENG149271-Seat heater level current consumption allocation-Sitzheizung Stufe 0 Ansteuerzeit,2 min,36
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,24.00 °C,36
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,22.00 °C,36
IDE06089-ENG149269-Seat heater level current consumption allocation-Sitzheizung Stufe 4 Ansteuerzeit,10 min,36
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,32.00 °C,36
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,30.00 °C,36
IDE06089-ENG149268-Seat heater level current consumption allocation-Sitzheizung Stufe 6 Ansteuerzeit,15 min,36
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,40.00 °C,36
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,38.00 °C,36
IDE06089-ENG154774-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase HI,Sollspannungsanforderung 14.7 ,36
IDE06089-ENG155904-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase LO,Sollspannungsanforderung 13.5 ,36
IDE06096-ENG149157-Interior lights-Innenlicht_bei_offenem_Heckdeckel_einschalten,active ,8
IDE06096-ENG98648-Interior lights-Interior lighting,Keine_Spannungsanforderung ,8
IDE08786-MAS10528-Assistance light functions-Rain light sensor,Rain light sensor ,9
IDE08786-MAS10545-Assistance light functions-Humidity sensor,not installed ,9
IDE08786-MAS13782-Assistance light functions-Will Beam assistant: responsivity adjustable via BAP,not active ,9
IDE08786-ENG149124-Assistance light functions-AFL_Zeitverzoegerung,0 ms,9
IDE08786-ENG149123-Assistance light functions-Assistenzfahrlicht_bei_Regen,active ,9
IDE08786-ENG124476-Assistance light functions-Sunlight photo sensor,not installed ,9
IDE10286-ENG130228-Configuration of light collective diagnostic line 1: instance 1-Defektbit,82 °,7
IDE10286-ENG127071-Configuration of light collective diagnostic line 1: instance 1-DTCDFCC,85 °,7
IDE10286-ENG130193-Configuration of light collective diagnostic line 1: instance 1-Leuchte_0,not active ,7
IDE10286-ENG130194-Configuration of light collective diagnostic line 1: instance 1-Leuchte_1,not active ,7
IDE10286-ENG130203-Configuration of light collective diagnostic line 1: instance 1-Leuchte_10,not active ,7
IDE10286-ENG130204-Configuration of light collective diagnostic line 1: instance 1-Leuchte_11,not active ,7
IDE10286-ENG130205-Configuration of light collective diagnostic line 1: instance 1-Leuchte_12,not active ,7
IDE10286-ENG130206-Configuration of light collective diagnostic line 1: instance 1-Leuchte_13,not active ,7
IDE10286-ENG130207-Configuration of light collective diagnostic line 1: instance 1-Leuchte_14,not active ,7
IDE10286-ENG130208-Configuration of light collective diagnostic line 1: instance 1-Leuchte_15,not active ,7
IDE10286-ENG130209-Configuration of light collective diagnostic line 1: instance 1-Leuchte_16,not active ,7
IDE10286-ENG130210-Configuration of light collective diagnostic line 1: instance 1-Leuchte_17,not active ,7
IDE10286-ENG130211-Configuration of light collective diagnostic line 1: instance 1-Leuchte_18,not active ,7
IDE10286-ENG130212-Configuration of light collective diagnostic line 1: instance 1-Leuchte_19,not active ,7
IDE10286-ENG130195-Configuration of light collective diagnostic line 1: instance 1-Leuchte_2,not active ,7
IDE10286-ENG130213-Configuration of light collective diagnostic line 1: instance 1-Leuchte_20,not active ,7
IDE10286-ENG130214-Configuration of light collective diagnostic line 1: instance 1-Leuchte_21,not active ,7
IDE10286-ENG130215-Configuration of light collective diagnostic line 1: instance 1-Leuchte_22,not active ,7
IDE10286-ENG130216-Configuration of light collective diagnostic line 1: instance 1-Leuchte_23,not active ,7
IDE10286-ENG130217-Configuration of light collective diagnostic line 1: instance 1-Leuchte_24,not active ,7
IDE10286-ENG130218-Configuration of light collective diagnostic line 1: instance 1-Leuchte_25,not active ,7
IDE10286-ENG130219-Configuration of light collective diagnostic line 1: instance 1-Leuchte_26,not active ,7
IDE10286-ENG130220-Configuration of light collective diagnostic line 1: instance 1-Leuchte_27,not active ,7
IDE10286-ENG130221-Configuration of light collective diagnostic line 1: instance 1-Leuchte_28,not active ,7
IDE10286-ENG130222-Configuration of light collective diagnostic line 1: instance 1-Leuchte_29,not active ,7
IDE10286-ENG130196-Configuration of light collective diagnostic line 1: instance 1-Leuchte_3,not active ,7
IDE10286-ENG130223-Configuration of light collective diagnostic line 1: instance 1-Leuchte_30,not active ,7
IDE10286-ENG130224-Configuration of light collective diagnostic line 1: instance 1-Leuchte_31,not active ,7
IDE10286-ENG130225-Configuration of light collective diagnostic line 1: instance 1-Leuchte_32,not active ,7
IDE10286-ENG130226-Configuration of light collective diagnostic line 1: instance 1-Leuchte_33,not active ,7
IDE10286-ENG130227-Configuration of light collective diagnostic line 1: instance 1-Leuchte_34,not active ,7
IDE10286-ENG130197-Configuration of light collective diagnostic line 1: instance 1-Leuchte_4,not active ,7
IDE10286-ENG130198-Configuration of light collective diagnostic line 1: instance 1-Leuchte_5,not active ,7
IDE10286-ENG130199-Configuration of light collective diagnostic line 1: instance 1-Leuchte_6,active ,7
IDE10286-ENG130200-Configuration of light collective diagnostic line 1: instance 1-Leuchte_7,not active ,7
IDE10286-ENG130201-Configuration of light collective diagnostic line 1: instance 1-Leuchte_8,active ,7
IDE10286-ENG130202-Configuration of light collective diagnostic line 1: instance 1-Leuchte_9,not active ,7
IDE10286-ENG127072-Configuration of light collective diagnostic line 1: instance 1-Wiederstand,0_Ohm ,7
IDE10288-ENG130228-Configuration of light collective diagnostic line 2: instance 1-Defektbit,83 °,7
IDE10288-ENG127071-Configuration of light collective diagnostic line 2: instance 1-DTCDFCC,86 °,7
IDE10288-ENG130193-Configuration of light collective diagnostic line 2: instance 1-Leuchte_0,not active ,7
IDE10288-ENG130194-Configuration of light collective diagnostic line 2: instance 1-Leuchte_1,not active ,7
IDE10288-ENG130203-Configuration of light collective diagnostic line 2: instance 1-Leuchte_10,not active ,7
IDE10288-ENG130204-Configuration of light collective diagnostic line 2: instance 1-Leuchte_11,not active ,7
IDE10288-ENG130205-Configuration of light collective diagnostic line 2: instance 1-Leuchte_12,not active ,7
IDE10288-ENG130206-Configuration of light collective diagnostic line 2: instance 1-Leuchte_13,not active ,7
IDE10288-ENG130207-Configuration of light collective diagnostic line 2: instance 1-Leuchte_14,not active ,7
IDE10288-ENG130208-Configuration of light collective diagnostic line 2: instance 1-Leuchte_15,not active ,7
IDE10288-ENG130209-Configuration of light collective diagnostic line 2: instance 1-Leuchte_16,not active ,7
IDE10288-ENG130210-Configuration of light collective diagnostic line 2: instance 1-Leuchte_17,not active ,7
IDE10288-ENG130211-Configuration of light collective diagnostic line 2: instance 1-Leuchte_18,not active ,7
IDE10288-ENG130212-Configuration of light collective diagnostic line 2: instance 1-Leuchte_19,not active ,7
IDE10288-ENG130195-Configuration of light collective diagnostic line 2: instance 1-Leuchte_2,not active ,7
IDE10288-ENG130213-Configuration of light collective diagnostic line 2: instance 1-Leuchte_20,not active ,7
IDE10288-ENG130214-Configuration of light collective diagnostic line 2: instance 1-Leuchte_21,not active ,7
IDE10288-ENG130215-Configuration of light collective diagnostic line 2: instance 1-Leuchte_22,not active ,7
IDE10288-ENG130216-Configuration of light collective diagnostic line 2: instance 1-Leuchte_23,not active ,7
IDE10288-ENG130217-Configuration of light collective diagnostic line 2: instance 1-Leuchte_24,not active ,7
IDE10288-ENG130218-Configuration of light collective diagnostic line 2: instance 1-Leuchte_25,not active ,7
IDE10288-ENG130219-Configuration of light collective diagnostic line 2: instance 1-Leuchte_26,not active ,7
IDE10288-ENG130220-Configuration of light collective diagnostic line 2: instance 1-Leuchte_27,not active ,7
IDE10288-ENG130221-Configuration of light collective diagnostic line 2: instance 1-Leuchte_28,not active ,7
IDE10288-ENG130222-Configuration of light collective diagnostic line 2: instance 1-Leuchte_29,not active ,7
IDE10288-ENG130196-Configuration of light collective diagnostic line 2: instance 1-Leuchte_3,not active ,7
IDE10288-ENG130223-Configuration of light collective diagnostic line 2: instance 1-Leuchte_30,not active ,7
IDE10288-ENG130224-Configuration of light collective diagnostic line 2: instance 1-Leuchte_31,not active ,7
IDE10288-ENG130225-Configuration of light collective diagnostic line 2: instance 1-Leuchte_32,not active ,7
IDE10288-ENG130226-Configuration of light collective diagnostic line 2: instance 1-Leuchte_33,not active ,7
IDE10288-ENG130227-Configuration of light collective diagnostic line 2: instance 1-Leuchte_34,not active ,7
IDE10288-ENG130197-Configuration of light collective diagnostic line 2: instance 1-Leuchte_4,not active ,7
IDE10288-ENG130198-Configuration of light collective diagnostic line 2: instance 1-Leuchte_5,not active ,7
IDE10288-ENG130199-Configuration of light collective diagnostic line 2: instance 1-Leuchte_6,not active ,7
IDE10288-ENG130200-Configuration of light collective diagnostic line 2: instance 1-Leuchte_7,active ,7
IDE10288-ENG130201-Configuration of light collective diagnostic line 2: instance 1-Leuchte_8,not active ,7
IDE10288-ENG130202-Configuration of light collective diagnostic line 2: instance 1-Leuchte_9,active ,7
IDE10288-ENG127072-Configuration of light collective diagnostic line 2: instance 1-Wiederstand,0_Ohm ,7
IDE11421-ENG116719-Leaving concept-Bedingungen zur Beendigung des Standlichtnachlaufs,Time ,6
IDE11421-ENG116720-Leaving concept-Standlicht-Nachlaufzeit,30 min,6
IDE11421-ENG179280-Leaving concept-VLK_Deaktivierung_der_Diagnose,not active ,6
IDE11421-ENG126843-Leaving concept-ZV verriegeln bei Klemme 15 Ein,active ,6
IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI,00000000  ,3
IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2,00000100  ,3
IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI,00000110  ,3
IDE11944-MAS10510-Keyless access and start authorization-Kessy,installed ,5
IDE11944-ENG174170-Keyless access and start authorization-central_locking_system_selective_sigle_door_kessy_NAR,not active ,5
IDE11944-ENG179141-Keyless access and start authorization-Kessy Bewegungsüberwachung IDGeber,active ,5
IDE11944-ENG179142-Keyless access and start authorization-Kessy Protokollvariante EntryExit,active ,5
IDE11944-ENG179143-Keyless access and start authorization-Kessy Ruhephase EntryExit,not active ,5
IDE11944-ENG149273-Keyless access and start authorization-Kessy_Komfort_oeffnen,not active ,5
IDE11944-ENG149274-Keyless access and start authorization-Kessy_Komfort_schliessen,active ,5
IDE11944-ENG149275-Keyless access and start authorization-Oeffnung_Heckdeckel_bei_Wiederentriegelung,not active ,5
IDE11944-ENG149000-Keyless access and start authorization-Steering_wheel_locking_system,installed ,5
MAS01490-IDE08581-Energy management-Recuperation,active ,5
MAS01490-MAS12921-Energy management-Predictive energy management,not active ,5
MAS01490-ENG149047-Energy management-Eingriff_durch_Energiemanagement,active ,5
MAS01490-ENG98636-Energy management-Hybrid,No ,5
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle,1000 lx,24
MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell,4000 lx,24
MAS08228-ENG142231-Light sensor-HMI_Exterior_light_on_rain,active ,24
MAS08228-ENG142232-Light sensor-HMI_exterior_light_sensitivity,NOT-DEFINED ,24
MAS08228-ENG142229-Light sensor-HMI_Wiper_Comfort_Rain_Sensor_OFF,active ,24
MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung,4300 mV,24
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung,1400 mV,24
MAS16372-Security version number,1 ,2
ENG153709-ENG155626-Aktivierung_Entwicklungsdiagnose-Reaktion_LOG_DTC,First_dtc ,9
ENG148492-MAS01577-Anti-theft protection-Parking heater,not installed ,5
ENG148492-ENG149232-Anti-theft protection-Akustischer_Alarm_Signalhorn,active ,5
ENG148492-ENG115864-Anti-theft protection-Alarmsignal,frequency_modulated ,5
ENG148492-ENG148991-Anti-theft protection-anti_theft_alarm_system,active ,5
ENG148492-ENG148992-Anti-theft protection-anti_theft_alarm_with_simple_horn,not installed ,5
ENG148492-ENG148993-Anti-theft protection-anti_theft_alarm_without_Thatcham,No ,5
ENG148492-ENG148990-Anti-theft protection-deactivation_button_anti_theft_alarm_sensor,not installed ,5
ENG148492-ENG154590-Anti-theft protection-Deaktivierung_DWA_ueber_MMI,not active ,5
ENG148492-ENG123016-Anti-theft protection-Diebstahlschutz_mit_Anhaenger,active ,5
ENG148492-ENG149229-Anti-theft protection-DWA_Alarmverzoegerung,immidiat_driver_door_contact_thatcham ,5
ENG148492-ENG149230-Anti-theft protection-DWA_Camper_Modus,not active ,5
ENG148492-ENG148994-Anti-theft protection-interior_monitoring_sensor,No ,5
ENG148492-ENG149231-Anti-theft protection-Sirenen_Alarmzahl,10_Alarme ,5
ENG148492-ENG142008-Anti-theft protection-tilt_sensor,No ,5
ENG148492-ENG149228-Anti-theft protection-Verzoegerung_Panikalarm,keine_verzoegerung ,5
ENG141649-ENG122212-Außenlicht_Blinker-ABBA_Blinken,not active ,5
ENG141649-ENG133379-Außenlicht_Blinker-Abbruch Komfortblinken,active ,5
ENG141649-ENG130187-Außenlicht_Blinker-Blinkkontrolleuchte_fuer_Anhaenger,separte ,5
ENG141649-ENG121966-Außenlicht_Blinker-Crash flashing,not active ,5
ENG141649-ENG122207-Außenlicht_Blinker-DWA_Alarm_Blinken,not active ,5
ENG141649-ENG122206-Außenlicht_Blinker-DWA_Schaerfungsquittung,not active ,5
ENG141649-ENG142195-Außenlicht_Blinker-Dynamische_Blink_Delay,0 ms,5
ENG141649-ENG126819-Außenlicht_Blinker-Emergency_alert_blinken,not active ,5
ENG141649-ENG115774-Außenlicht_Blinker-Komfortblinken,active ,5
ENG141649-ENG115854-Außenlicht_Blinker-Komfortblinken_Blinkzyklen,5 ,5
ENG141649-ENG122208-Außenlicht_Blinker-Multi_kollisions_Blinken,not active ,5
ENG141649-ENG122209-Außenlicht_Blinker-Notwarn_blinken_NBA_Phase_2,not active ,5
ENG141649-ENG121967-Außenlicht_Blinker-Panic flashing,not active ,5
ENG141649-ENG122211-Außenlicht_Blinker-Richtungs_blinken_links,not active ,5
ENG141649-ENG122210-Außenlicht_Blinker-Richtungs_blinken_rechts,not active ,5
ENG141649-ENG249932-Außenlicht_Blinker-Rollenmodusblinken,not active ,5
ENG141649-ENG122201-Außenlicht_Blinker-Schluessel_Anlern_Blinken,not active ,5
ENG141649-ENG121968-Außenlicht_Blinker-Taxi alarm flashing,not active ,5
ENG141649-ENG286352-Außenlicht_Blinker-Telematikblinken_OCU_Blinken,not active ,5
ENG141649-ENG122202-Außenlicht_Blinker-UGDO_ Anlern_Blinken,not active ,5
ENG141649-ENG122214-Außenlicht_Blinker-Warnblinken_Zuendung_AUS,not active ,5
ENG141649-ENG122213-Außenlicht_Blinker-Warnblinken_Zuendung_EIN,not active ,5
ENG141649-ENG122204-Außenlicht_Blinker-ZV_Blinken_auf,not active ,5
ENG141649-ENG122203-Außenlicht_Blinker-ZV_Blinken_zu,not active ,5
ENG141647-MAS10529-Außenlicht_Front-Low beam: bulb type,H7 ,9
ENG141647-ENG149099-Außenlicht_Front-Allwetterlicht_Ausschaltgrenze,350 km/h,9
ENG141647-ENG149098-Außenlicht_Front-Allwetterlicht_Einschaltgrenze,350 km/h,9
ENG141647-ENG149106-Außenlicht_Front-Fahrlicht_bei_Tag,Daytime running lamps ,9
ENG141647-ENG149097-Außenlicht_Front-Lichthupe_bei_Zuendung_aus_moeglich,active ,9
ENG141647-ENG126567-Außenlicht_Front-max_scheinwerfer_2limitieren,in_Betrieb_lassen ,9
ENG141647-ENG149100-Außenlicht_Front-Scheinwerferferreinigungsansteuerung_und_Abblendlichtanzeige_bei_Dauerfahrlicht,not active ,9
ENG141647-ENG149103-Außenlicht_Front-Standlicht_aktiviert_zusaetzlich_Tagfahrlicht,active ,9
ENG141647-ENG149101-Außenlicht_Front-Tagfahrlicht_Aktivierung_durch_BAP_oder_Bedienfolge_moeglich,not active ,9
ENG141647-ENG149104-Außenlicht_Front-Tagfahrlicht_Dauerfahrlicht_bei_Handbremse_abschalten,not active ,9
ENG141647-ENG149107-Außenlicht_Front-Tagfahrlicht_nur_in_Schalterstellung_AUTO,not active ,9
ENG141647-ENG149105-Außenlicht_Front-Tagfahrlicht-Dauerfahrlicht_aktiviert_zusaetzlich_Standlicht,not active ,9
ENG141647-ENG149102-Außenlicht_Front-Werkseinstellung_fuer_Tagfahrlicht_Freischaltung_BAP_/_Bedienfolge,active ,9
ENG141648-MAS10533-Aussenlicht_Heck-Brake light is turn signal,No ,5
ENG141648-ENG179109-Aussenlicht_Heck-Bremslicht_mit_Schlusslichtfunktion,not active ,5
ENG141648-ENG149110-Aussenlicht_Heck-Nebelschlusslicht_Warngeschwindigkeit,255 km/h,5
ENG141648-ENG115847-Aussenlicht_Heck-Notbremsanzeige_NBA,active ,5
ENG141648-ENG155652-Aussenlicht_Heck-Schlusslicht_mit_Brems_und_Blinklichtfunktion,not active ,5
ENG141648-ENG149109-Aussenlicht_Heck-Schlusslicht_mit_Bremslichtfunktion,not active ,5
ENG141656-MAS10538-Außenlicht_uebergreifend-Light rotary sw. connection,Discrete signal current ,16
ENG141656-MAS10541-Außenlicht_uebergreifend-Light rotary switch with fog light,Yes ,16
ENG141656-MAS10542-Außenlicht_uebergreifend-Light rotary switch with fog tail light,No ,16
ENG141656-MAS10543-Außenlicht_uebergreifend-Light rotary sw. with AFL,Yes ,16
ENG141656-MAS10544-Außenlicht_uebergreifend-Light rotary switch with park. light pos.,Yes ,16
ENG141656-ENG248495-Außenlicht_uebergreifend-ABL_off_ECE48_Rev6,No ,16
ENG141656-ENG133381-Außenlicht_uebergreifend-Bedingungen zur Parklichtbegrenzung,Energy management ,16
ENG141656-ENG133380-Außenlicht_uebergreifend-Bedingungen zur Standlichtbegrenzung,Energy management ,16
ENG141656-ENG126566-Außenlicht_uebergreifend-beidseitiges_dauerparklicht,active ,16
ENG141656-ENG281103-Außenlicht_uebergreifend-CHo_Nachlauf,0 ms,16
ENG141656-ENG149092-Außenlicht_uebergreifend-Coming_home_Leuchten,Low beam ,16
ENG141656-ENG149089-Außenlicht_uebergreifend-Coming_Home_Verbaustatus,automatic ,16
ENG141656-ENG149093-Außenlicht_uebergreifend-Coming-home_Einschaltereignis,Driver_door ,16
ENG141656-ENG248654-Außenlicht_uebergreifend-ECE48_Rev6_aktiv,not active ,16
ENG141656-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach,active ,16
ENG141656-ENG126818-Außenlicht_uebergreifend-Fahrlichtwarnung_Hinweis_Konfig,in 0 and SL position ,16
ENG141656-ENG137034-Außenlicht_uebergreifend-Faktor fuer Verfuegbarkeitstimer,Faktor fuer x5 Minuten ,16
ENG141656-ENG154619-Außenlicht_uebergreifend-Fernlicht_LH,Keine_Spannungsanforderung ,16
ENG141656-ENG154177-Außenlicht_uebergreifend-Fog lamp,Keine_Spannungsanforderung ,16
ENG141656-ENG149096-Außenlicht_uebergreifend-Helligkeitsschwelle_Forward-Messung,100 ,16
ENG141656-ENG149094-Außenlicht_uebergreifend-Helligkeitsschwelle_Infrarot-Messung,72 ,16
ENG141656-ENG155156-Außenlicht_uebergreifend-keine_LCM_blinker,false ,16
ENG141656-ENG149086-Außenlicht_uebergreifend-Kontrollleuchte_fuer_Begrenzungslicht,integriert_in_Suchbeleuchtung ,16
ENG141656-ENG149095-Außenlicht_uebergreifend-Leaving-Home_Verbausstatus,Enabled ,16
ENG141656-ENG126569-Außenlicht_uebergreifend-lho_aktiviert,active ,16
ENG141656-ENG126570-Außenlicht_uebergreifend-lho_zeit,10 seconds ,16
ENG141656-ENG149005-Außenlicht_uebergreifend-Lichtdrehschalter_mit_Nebellicht_bei_Assistenzfahrlicht,Yes ,16
ENG141656-ENG115862-Außenlicht_uebergreifend-Lichtwarnungsverhalten,klemmenabhaengig ,16
ENG141656-ENG142034-Außenlicht_uebergreifend-Light_Control_Module,not installed ,16
ENG141656-ENG98354-Außenlicht_uebergreifend-Low beam,Keine_Spannungsanforderung ,16
ENG141656-ENG149088-Außenlicht_uebergreifend-Menueeinstellung_CHO_LHO,Menuesteuerung_Zeit_aktivieren ,16
ENG141656-ENG149091-Außenlicht_uebergreifend-Menueeinstellung_Cominghome,10 seconds ,16
ENG141656-ENG149090-Außenlicht_uebergreifend-Menuesteuerung_Coming_Home_Werkseinstellung,active ,16
ENG141656-ENG149087-Außenlicht_uebergreifend-Parklicht_ueber_LSS_aktiviert,One-sided ,16
ENG141656-ENG126565-Außenlicht_uebergreifend-standlicht_aus_bei_kl_s_aus_s_kontakt,active ,16
ENG141656-ENG137035-Außenlicht_uebergreifend-Standlicht-Verfuegbarkeit,24 s,16
ENG141656-ENG248823-Außenlicht_uebergreifend-TFL_off_ECE48_Rev6,No ,16
ENG141656-ENG154174-Außenlicht_uebergreifend-Turn signal lamp,Keine_Spannungsanforderung ,16
ENG148494-MAS10534-Background lighting-Input medium: search illumination,HMI ,21
ENG148494-ENG142240-Background lighting-Daempfung Abdimmen KL 58xd PWM,0.00 s,21
ENG148494-ENG154582-Background lighting-Daempfung_Abdimmen_KL_58xs_PWM,0.00 s,21
ENG148494-ENG154583-Background lighting-Daempfung_Abdimmen_KL_58xt_PWM,0.00 s,21
ENG148494-ENG154584-Background lighting-Daempfung_Aufdimmen_KL_58xd_PWM,0.00 s,21
ENG148494-ENG154585-Background lighting-Daempfung_Aufdimmen_KL_58xt_PWM,0.00 s,21
ENG148494-ENG179120-Background lighting-Daempfung_Aufdimmen_KL58xs_PWM,0.00 s,21
ENG148494-ENG142242-Background lighting-Helligkeit_RLS_Daempfung_Abdimmen,0.0 s,21
ENG148494-ENG142241-Background lighting-Helligkeit_RLS_Daempfung_Aufdimmen,0.0 s,21
ENG148494-ENG149159-Background lighting-KL58_Einschalten_mit_Rampe,not active ,21
ENG148494-ENG149160-Background lighting-KL58_Verriegelungsausschalten,active ,21
ENG148494-ENG149161-Background lighting-Lichtsensor_wirkt_auf_Suchbeleuchtung,active ,21
ENG148494-ENG149162-Background lighting-Suchbeleuchtung_Festwert,60 %,21
ENG148494-ENG142234-Background lighting-Umgebungs_helligkeit_auswahl,Fotosensor_Kombi ,21
ENG148494-ENG130188-Background lighting-Warnblinktastersuchbeleuchtung_Aktivierung,always_active ,21
ENG148494-ENG130190-Background lighting-Warnblinktastersuchbeleuchtung_Faktor,0.072 ,21
ENG148494-ENG130189-Background lighting-Warnblinktastersuchbeleuchtung_Grundwert,1.0 %,21
ENG122925-DWA_Interior_Monitoring_Data_Set_Development,No Response From Subnet Component,21
ENG248426-ENG252093-Elektronische_Rückwandklappe-eRWK_Abbruchblinken_Heck,not active ,9
ENG248426-ENG248659-Elektronische_Rückwandklappe-eRWK_Abstand_Umfeld_frei,120 cm,9
ENG248426-ENG248660-Elektronische_Rückwandklappe-eRWK_Abstand_Umfeld_Nahbereich,20 cm,9
ENG248426-ENG248661-Elektronische_Rückwandklappe-eRWK_bei_eingeschraenkter_Oeffnungsweite,not active ,9
ENG248426-ENG248662-Elektronische_Rückwandklappe-eRWK_Heck_sperren_bei_Hindernis,not active ,9
ENG248426-ENG248663-Elektronische_Rückwandklappe-eRWK_Oeffnungsblinken_Heck,not active ,9
ENG248426-ENG248664-Elektronische_Rückwandklappe-eRWK_ohne_FFB_HDF,not active ,9
ENG248426-ENG252079-Elektronische_Rückwandklappe-eRWK_Pruefung_Umfelderkennung,1.6 s,9
ENG248426-ENG252068-Elektronische_Rückwandklappe-eRWK_Start_Umfelderkennung,2.0 s,9
ENG148609-ENG148997-Fahrerinformation-Cockpit_button_1,installed ,5
ENG148609-ENG148998-Fahrerinformation-Cockpit_button_2,not installed ,5
ENG148609-ENG148999-Fahrerinformation-Cockpit_button_3,not installed ,5
ENG148609-ENG149003-Fahrerinformation-Cockpit_button_4,not installed ,5
ENG141650-MAS10514-Fernlicht_assistent-Expanded high beam control,Halogen ,6
ENG141650-ENG149120-Fernlicht_assistent-Fernlichtassistent_Reset,not active ,6
ENG141650-ENG149122-Fernlicht_assistent-Fernlichtassistent_Zeitverzoegerungswert,800 ms,6
ENG141650-ENG149119-Fernlicht_assistent-Menuesteuerung_Fernlichtassistent,not installed ,6
ENG141650-ENG149121-Fernlicht_assistent-Menuesteuerung_Fernlichtassistent_Werkseinstellung,not installed ,6
ENG248411-ENG248631-Front doors-cockpittaster2_funktion,not active ,1
ENG248411-ENG252063-Front doors-Deaktivierung_LS_mit_ext_Ver_Entriegelung,not active ,1
ENG248411-ENG248723-Front doors-Laderaumschließung Taster togglen,not active ,1
ENG248411-ENG248768-Front doors-NFZ_Schliessung,not active ,1
ENG248411-ENG248784-Front doors-pa_Schlosstyp_vorne,Einmotorenschloss ,1
ENG248411-ENG133390-Front doors-Wiederverriegelung_Laderaum,not installed ,1
ENG248444-ENG248688-Global-Freischaltung_der_Kisi_Auswurffunktion,No ,1
ENG248444-ENG248689-Global-Freischaltung_KiSi_Taster_bei_extern_verriegeltem_Fahrzeug,No ,1
ENG248444-ENG248691-Global-Funktion_SAFE,No ,1
ENG248444-ENG248774-Global-pa_eKiSi,No ,1
ENG248444-ENG248776-Global-pa_FFb_Sbt_Tausch_Seite,No ,1
ENG248444-ENG248809-Global-Schiebetuer_Auswurffunkion_bei_intern_verriegelt_aktiv,No ,1
ENG248444-ENG248810-Global-Schiebetuertaste_Armaturentafel_bei_extern_verriegelt_aktiv,No ,1
ENG248445-ENG248698-Heckklappe: Türen-HD_Innentaster_im_Heck,not installed ,1
ENG248445-ENG248782-Heckklappe: Türen-pa_Schlosstyp_Heck,Federsteller ,1
ENG248445-ENG248787-Heckklappe: Türen-pa_Typ_Heck,Klappe ,1
ENG141645-MAS00212-HW_Verbau-Insufficient washer fluid,not installed ,8
ENG141645-MAS06495-HW_Verbau-Engine hood contact switch,installed ,8
ENG141645-MAS10521-HW_Verbau-Exterior temp. sensor,installed ,8
ENG141645-ENG126574-HW_Verbau-auspraegung_Bremsfluessigkeitsschalter,Open ,8
ENG141645-ENG115848-HW_Verbau-Signalhorn_ohne_KL15,active ,8
ENG141645-ENG149002-HW_Verbau-Signalhorn_ueber_LIN,horn_via_LIN ,8
ENG141645-ENG142011-HW_Verbau-trunk_lid_conrol_unit,not installed ,8
ENG148603-ENG115658-Innen_beleuchtung_KL58_xd_max-x0,0 lx,10
ENG148603-ENG101574-Innen_beleuchtung_KL58_xd_max-X1,8 lx,10
ENG148603-ENG99557-Innen_beleuchtung_KL58_xd_max-X2,200 lx,10
ENG148603-ENG102140-Innen_beleuchtung_KL58_xd_max-X3,300 lx,10
ENG148603-ENG102936-Innen_beleuchtung_KL58_xd_max-X4,500 lx,10
ENG148603-ENG115659-Innen_beleuchtung_KL58_xd_max-y0,16.0 ,10
ENG148603-ENG99777-Innen_beleuchtung_KL58_xd_max-Y1,16.0 ,10
ENG148603-ENG100480-Innen_beleuchtung_KL58_xd_max-Y2,100.0 ,10
ENG148603-ENG100773-Innen_beleuchtung_KL58_xd_max-Y3,100.0 ,10
ENG148603-ENG100631-Innen_beleuchtung_KL58_xd_max-Y4,100.0 ,10
ENG148602-ENG115658-Innen_beleuchtung_KL58_xd_min-x0,0 lx,10
ENG148602-ENG101574-Innen_beleuchtung_KL58_xd_min-X1,8 lx,10
ENG148602-ENG99557-Innen_beleuchtung_KL58_xd_min-X2,220 lx,10
ENG148602-ENG102140-Innen_beleuchtung_KL58_xd_min-X3,300 lx,10
ENG148602-ENG102936-Innen_beleuchtung_KL58_xd_min-X4,500 lx,10
ENG148602-ENG115659-Innen_beleuchtung_KL58_xd_min-y0,6.0 ,10
ENG148602-ENG99777-Innen_beleuchtung_KL58_xd_min-Y1,6.0 ,10
ENG148602-ENG100480-Innen_beleuchtung_KL58_xd_min-Y2,100.0 ,10
ENG148602-ENG100773-Innen_beleuchtung_KL58_xd_min-Y3,100.0 ,10
ENG148602-ENG100631-Innen_beleuchtung_KL58_xd_min-Y4,100.0 ,10
ENG148607-ENG115658-Innen_beleuchtung_KL58_xd_PWM-x0,0 ,12
ENG148607-ENG101574-Innen_beleuchtung_KL58_xd_PWM-X1,10 ,12
ENG148607-ENG99557-Innen_beleuchtung_KL58_xd_PWM-X2,50 ,12
ENG148607-ENG102140-Innen_beleuchtung_KL58_xd_PWM-X3,100 ,12
ENG148607-ENG102936-Innen_beleuchtung_KL58_xd_PWM-X4,220 ,12
ENG148607-ENG103548-Innen_beleuchtung_KL58_xd_PWM-X5,253 ,12
ENG148607-ENG115659-Innen_beleuchtung_KL58_xd_PWM-y0,2.0 %,12
ENG148607-ENG99777-Innen_beleuchtung_KL58_xd_PWM-Y1,2.0 %,12
ENG148607-ENG100480-Innen_beleuchtung_KL58_xd_PWM-Y2,6.0 %,12
ENG148607-ENG100773-Innen_beleuchtung_KL58_xd_PWM-Y3,10.0 %,12
ENG148607-ENG100631-Innen_beleuchtung_KL58_xd_PWM-Y4,80.0 %,12
ENG148607-ENG102174-Innen_beleuchtung_KL58_xd_PWM-Y5,100.0 %,12
ENG148599-ENG115658-Innen_beleuchtung_KL58_xs_max-x0,0 lx,8
ENG148599-ENG101574-Innen_beleuchtung_KL58_xs_max-X1,8 lx,8
ENG148599-ENG99557-Innen_beleuchtung_KL58_xs_max-X2,50 lx,8
ENG148599-ENG102140-Innen_beleuchtung_KL58_xs_max-X3,500 lx,8
ENG148599-ENG115659-Innen_beleuchtung_KL58_xs_max-y0,100.0 ,8
ENG148599-ENG99777-Innen_beleuchtung_KL58_xs_max-Y1,100.0 ,8
ENG148599-ENG100480-Innen_beleuchtung_KL58_xs_max-Y2,100.0 ,8
ENG148599-ENG100773-Innen_beleuchtung_KL58_xs_max-Y3,100.0 ,8
ENG148605-ENG115658-Innen_beleuchtung_KL58_xs_PWM-x0,0.0 %,6
ENG148605-ENG101574-Innen_beleuchtung_KL58_xs_PWM-X1,50.0 %,6
ENG148605-ENG99557-Innen_beleuchtung_KL58_xs_PWM-X2,100.0 %,6
ENG148605-ENG115659-Innen_beleuchtung_KL58_xs_PWM-y0,0.0 %,6
ENG148605-ENG99777-Innen_beleuchtung_KL58_xs_PWM-Y1,50.0 %,6
ENG148605-ENG100480-Innen_beleuchtung_KL58_xs_PWM-Y2,100.0 %,6
ENG148601-ENG115658-Innen_beleuchtung_KL58_xt_max-x0,0 lx,8
ENG148601-ENG101574-Innen_beleuchtung_KL58_xt_max-X1,8 lx,8
ENG148601-ENG99557-Innen_beleuchtung_KL58_xt_max-X2,50 lx,8
ENG148601-ENG102140-Innen_beleuchtung_KL58_xt_max-X3,500 lx,8
ENG148601-ENG115659-Innen_beleuchtung_KL58_xt_max-y0,100.0 ,8
ENG148601-ENG99777-Innen_beleuchtung_KL58_xt_max-Y1,100.0 ,8
ENG148601-ENG100480-Innen_beleuchtung_KL58_xt_max-Y2,100.0 ,8
ENG148601-ENG100773-Innen_beleuchtung_KL58_xt_max-Y3,100.0 ,8
ENG148600-ENG115658-Innen_beleuchtung_KL58_xt_min-x0,0 lx,8
ENG148600-ENG101574-Innen_beleuchtung_KL58_xt_min-X1,8 lx,8
ENG148600-ENG99557-Innen_beleuchtung_KL58_xt_min-X2,50 lx,8
ENG148600-ENG102140-Innen_beleuchtung_KL58_xt_min-X3,500 lx,8
ENG148600-ENG115659-Innen_beleuchtung_KL58_xt_min-y0,6.0 ,8
ENG148600-ENG99777-Innen_beleuchtung_KL58_xt_min-Y1,6.0 ,8
ENG148600-ENG100480-Innen_beleuchtung_KL58_xt_min-Y2,100.0 ,8
ENG148600-ENG100773-Innen_beleuchtung_KL58_xt_min-Y3,100.0 ,8
ENG148606-ENG115658-Innen_beleuchtung_KL58_xt_PWM-x0,0.0 %,6
ENG148606-ENG101574-Innen_beleuchtung_KL58_xt_PWM-X1,50.0 %,6
ENG148606-ENG99557-Innen_beleuchtung_KL58_xt_PWM-X2,100.0 %,6
ENG148606-ENG115659-Innen_beleuchtung_KL58_xt_PWM-y0,0.0 %,6
ENG148606-ENG99777-Innen_beleuchtung_KL58_xt_PWM-Y1,50.0 %,6
ENG148606-ENG100480-Innen_beleuchtung_KL58_xt_PWM-Y2,100.0 %,6
ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0,0 lx,8
ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1,8 lx,8
ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2,50 lx,8
ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3,510 lx,8
ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0,6.0 ,8
ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1,6.0 ,8
ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2,100.0 ,8
ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3,100.0 ,8
ENG148597-ENG115658-Innenbeleuchtung_Abdimmen-x0,0 ms,22
ENG148597-ENG101574-Innenbeleuchtung_Abdimmen-X1,100 ms,22
ENG148597-ENG115664-Innenbeleuchtung_Abdimmen-x10,1000 ms,22
ENG148597-ENG99557-Innenbeleuchtung_Abdimmen-X2,200 ms,22
ENG148597-ENG102140-Innenbeleuchtung_Abdimmen-X3,300 ms,22
ENG148597-ENG102936-Innenbeleuchtung_Abdimmen-X4,400 ms,22
ENG148597-ENG103548-Innenbeleuchtung_Abdimmen-X5,500 ms,22
ENG148597-ENG113992-Innenbeleuchtung_Abdimmen-X6,600 ms,22
ENG148597-ENG115661-Innenbeleuchtung_Abdimmen-x7,700 ms,22
ENG148597-ENG115662-Innenbeleuchtung_Abdimmen-x8,800 ms,22
ENG148597-ENG115663-Innenbeleuchtung_Abdimmen-x9,900 ms,22
ENG148597-ENG115659-Innenbeleuchtung_Abdimmen-y0,100.0 %,22
ENG148597-ENG99777-Innenbeleuchtung_Abdimmen-Y1,100.0 %,22
ENG148597-ENG115668-Innenbeleuchtung_Abdimmen-y10,0.0 %,22
ENG148597-ENG100480-Innenbeleuchtung_Abdimmen-Y2,95.0 %,22
ENG148597-ENG100773-Innenbeleuchtung_Abdimmen-Y3,80.0 %,22
ENG148597-ENG100631-Innenbeleuchtung_Abdimmen-Y4,40.0 %,22
ENG148597-ENG102174-Innenbeleuchtung_Abdimmen-Y5,20.0 %,22
ENG148597-ENG113993-Innenbeleuchtung_Abdimmen-Y6,10.0 %,22
ENG148597-ENG115665-Innenbeleuchtung_Abdimmen-y7,5.0 %,22
ENG148597-ENG115666-Innenbeleuchtung_Abdimmen-y8,3.0 %,22
ENG148597-ENG115667-Innenbeleuchtung_Abdimmen-y9,1.0 %,22
ENG148598-ENG115658-Innenbeleuchtung_Fotosensor-x0,0 ,22
ENG148598-ENG101574-Innenbeleuchtung_Fotosensor-X1,50 ,22
ENG148598-ENG99557-Innenbeleuchtung_Fotosensor-X2,100 ,22
ENG148598-ENG102140-Innenbeleuchtung_Fotosensor-X3,200 ,22
ENG148598-ENG102936-Innenbeleuchtung_Fotosensor-X4,253 ,22
ENG148598-ENG115659-Innenbeleuchtung_Fotosensor-y0,0 lx,22
ENG148598-ENG99777-Innenbeleuchtung_Fotosensor-Y1,50 lx,22
ENG148598-ENG100480-Innenbeleuchtung_Fotosensor-Y2,100 lx,22
ENG148598-ENG100773-Innenbeleuchtung_Fotosensor-Y3,200 ,22
ENG148598-ENG100631-Innenbeleuchtung_Fotosensor-Y4,500 ,22
ENG148596-ENG115658-Innenbeleuchtung_Hochdimmen-x0,0 ms,22
ENG148596-ENG101574-Innenbeleuchtung_Hochdimmen-X1,100 ms,22
ENG148596-ENG115664-Innenbeleuchtung_Hochdimmen-x10,1000 ms,22
ENG148596-ENG99557-Innenbeleuchtung_Hochdimmen-X2,200 ms,22
ENG148596-ENG102140-Innenbeleuchtung_Hochdimmen-X3,300 ms,22
ENG148596-ENG102936-Innenbeleuchtung_Hochdimmen-X4,400 ms,22
ENG148596-ENG103548-Innenbeleuchtung_Hochdimmen-X5,500 ms,22
ENG148596-ENG113992-Innenbeleuchtung_Hochdimmen-X6,600 ms,22
ENG148596-ENG115661-Innenbeleuchtung_Hochdimmen-x7,700 ms,22
ENG148596-ENG115662-Innenbeleuchtung_Hochdimmen-x8,800 ms,22
ENG148596-ENG115663-Innenbeleuchtung_Hochdimmen-x9,900 ms,22
ENG148596-ENG115659-Innenbeleuchtung_Hochdimmen-y0,0.0 %,22
ENG148596-ENG99777-Innenbeleuchtung_Hochdimmen-Y1,1.0 %,22
ENG148596-ENG115668-Innenbeleuchtung_Hochdimmen-y10,100.0 %,22
ENG148596-ENG100480-Innenbeleuchtung_Hochdimmen-Y2,3.0 %,22
ENG148596-ENG100773-Innenbeleuchtung_Hochdimmen-Y3,5.0 %,22
ENG148596-ENG100631-Innenbeleuchtung_Hochdimmen-Y4,11.0 %,22
ENG148596-ENG102174-Innenbeleuchtung_Hochdimmen-Y5,22.0 %,22
ENG148596-ENG113993-Innenbeleuchtung_Hochdimmen-Y6,40.0 %,22
ENG148596-ENG115665-Innenbeleuchtung_Hochdimmen-y7,80.0 %,22
ENG148596-ENG115666-Innenbeleuchtung_Hochdimmen-y8,95.0 %,22
ENG148596-ENG115667-Innenbeleuchtung_Hochdimmen-y9,100.0 %,22
ENG148604-ENG115658-Innenbeleuchtung_KL58xd_log_Bus-x0,0.0 %,12
ENG148604-ENG101574-Innenbeleuchtung_KL58xd_log_Bus-X1,6.0 %,12
ENG148604-ENG99557-Innenbeleuchtung_KL58xd_log_Bus-X2,16.0 %,12
ENG148604-ENG102140-Innenbeleuchtung_KL58xd_log_Bus-X3,30.0 %,12
ENG148604-ENG102936-Innenbeleuchtung_KL58xd_log_Bus-X4,60.0 %,12
ENG148604-ENG103548-Innenbeleuchtung_KL58xd_log_Bus-X5,100.0 %,12
ENG148604-ENG115659-Innenbeleuchtung_KL58xd_log_Bus-y0,10 ,12
ENG148604-ENG99777-Innenbeleuchtung_KL58xd_log_Bus-Y1,10 ,12
ENG148604-ENG100480-Innenbeleuchtung_KL58xd_log_Bus-Y2,100 ,12
ENG148604-ENG100773-Innenbeleuchtung_KL58xd_log_Bus-Y3,150 ,12
ENG148604-ENG100631-Innenbeleuchtung_KL58xd_log_Bus-Y4,220 ,12
ENG148604-ENG102174-Innenbeleuchtung_KL58xd_log_Bus-Y5,253 ,12
ENG148595-ENG149169-Innenbeleuchtung_Tasterdimmung-tasterdimmung_x0,0 ms,10
ENG148595-ENG149170-Innenbeleuchtung_Tasterdimmung-tasterdimmung_x1,2000 ms,10
ENG148595-ENG149171-Innenbeleuchtung_Tasterdimmung-tasterdimmung_x2,3000 ms,10
ENG148595-ENG149172-Innenbeleuchtung_Tasterdimmung-tasterdimmung_x3,4000 ms,10
ENG148595-ENG149173-Innenbeleuchtung_Tasterdimmung-tasterdimmung_x4,5100 ms,10
ENG148595-ENG149174-Innenbeleuchtung_Tasterdimmung-tasterdimmung_y0,1.0 %,10
ENG148595-ENG149175-Innenbeleuchtung_Tasterdimmung-tasterdimmung_y1,5.0 ,10
ENG148595-ENG149176-Innenbeleuchtung_Tasterdimmung-tasterdimmung_y2,15.0 ,10
ENG148595-ENG149177-Innenbeleuchtung_Tasterdimmung-tasterdimmung_y3,40.0 ,10
ENG148595-ENG149178-Innenbeleuchtung_Tasterdimmung-tasterdimmung_y4,100.0 ,10
ENG248447-ENG248714-Inszenierung CHoLHo-Inszenierung CHo/LHo Aktivieren,not active ,36
ENG248447-ENG115658-Inszenierung CHoLHo-x0,0 ms,36
ENG248447-ENG101574-Inszenierung CHoLHo-X1,200 ms,36
ENG248447-ENG115664-Inszenierung CHoLHo-x10,2000 ms,36
ENG248447-ENG248838-Inszenierung CHoLHo-x11,200 ms,36
ENG248447-ENG248839-Inszenierung CHoLHo-x12,400 ms,36
ENG248447-ENG248840-Inszenierung CHoLHo-x13,600 ms,36
ENG248447-ENG248841-Inszenierung CHoLHo-x14,800 ms,36
ENG248447-ENG248842-Inszenierung CHoLHo-x15,1000 ms,36
ENG248447-ENG99557-Inszenierung CHoLHo-X2,400 ms,36
ENG248447-ENG102140-Inszenierung CHoLHo-X3,600 ms,36
ENG248447-ENG102936-Inszenierung CHoLHo-X4,800 ms,36
ENG248447-ENG103548-Inszenierung CHoLHo-X5,1000 ms,36
ENG248447-ENG113992-Inszenierung CHoLHo-X6,1200 ms,36
ENG248447-ENG115661-Inszenierung CHoLHo-x7,1400 ms,36
ENG248447-ENG115662-Inszenierung CHoLHo-x8,1600 ms,36
ENG248447-ENG115663-Inszenierung CHoLHo-x9,1800 ms,36
ENG248447-ENG115659-Inszenierung CHoLHo-y0,0.0 %,36
ENG248447-ENG99777-Inszenierung CHoLHo-Y1,3.0 %,36
ENG248447-ENG115668-Inszenierung CHoLHo-y10,100.0 %,36
ENG248447-ENG136987-Inszenierung CHoLHo-Y11,3.0 %,36
ENG248447-ENG136988-Inszenierung CHoLHo-Y12,7.0 %,36
ENG248447-ENG136989-Inszenierung CHoLHo-Y13,12.0 %,36
ENG248447-ENG136990-Inszenierung CHoLHo-Y14,17.0 %,36
ENG248447-ENG136991-Inszenierung CHoLHo-Y15,24.0 %,36
ENG248447-ENG100480-Inszenierung CHoLHo-Y2,7.0 %,36
ENG248447-ENG100773-Inszenierung CHoLHo-Y3,12.0 %,36
ENG248447-ENG100631-Inszenierung CHoLHo-Y4,17.0 %,36
ENG248447-ENG102174-Inszenierung CHoLHo-Y5,24.0 %,36
ENG248447-ENG113993-Inszenierung CHoLHo-Y6,33.0 %,36
ENG248447-ENG115665-Inszenierung CHoLHo-y7,44.0 %,36
ENG248447-ENG115666-Inszenierung CHoLHo-y8,59.0 %,36
ENG248447-ENG115667-Inszenierung CHoLHo-y9,78.0 %,36
ENG148608-ENG148900-Lenkradhebel-Art des Lenkstockschalters,LSS ohne Elektronik ,5
ENG148608-ENG149233-Lenkradhebel-Aussenspiegelheizung_aktivierungssignal,Hardwaresignal ,5
ENG148608-ENG155105-Lenkradhebel-FAS-Taster,not installed ,5
ENG148608-ENG149006-Lenkradhebel-Fernlichtstellung,FL tastend ,5
ENG148608-ENG148901-Lenkradhebel-GRA-Bedienung,MFL-Bedienung ,5
ENG148608-ENG149001-Lenkradhebel-heated_mirror,not installed ,5
ENG148608-ENG149004-Lenkradhebel-speed_limiter,not installed ,5
ENG148608-ENG179276-Lenkradhebel-Umschaltung GRA zu SL,Direct ,5
ENG148608-ENG154803-Lenkradhebel-Verbauort_Lenkstockschalter,CAN ,5
ENG148608-ENG149234-Lenkradhebel-Versorgung_Lenkstockschalters_KL30,installed ,5
ENG124861-ENG115018-Leuchte 0 BLK VL B35-Dimming_AB_0,127 ,16
ENG124861-ENG115022-Leuchte 0 BLK VL B35-Dimming_CD_0,0 ,16
ENG124861-ENG115023-Leuchte 0 BLK VL B35-Dimming_Direction_CD_0,maximize ,16
ENG124861-ENG115027-Leuchte 0 BLK VL B35-Dimming_Direction_EF_0,maximize ,16
ENG124861-ENG115031-Leuchte 0 BLK VL B35-Dimming_Direction_GH_0,maximize ,16
ENG124861-ENG115026-Leuchte 0 BLK VL B35-Dimming_EF_0,0 ,16
ENG124861-ENG115030-Leuchte 0 BLK VL B35-Dimming_GH_0,0 ,16
ENG124861-ENG126576-Leuchte 0 BLK VL B35-Fehlerort_mittleres_Byte_DTC-DFCC_0,20 ,16
ENG124861-ENG115751-Leuchte 0 BLK VL B35-Lampendefektbit_Position_0,52 ,16
ENG124861-ENG115019-Leuchte 0 BLK VL B35-Light_Control_HD_AB_0,Always ,16
ENG124861-ENG115016-Leuchte 0 BLK VL B35-Light_Function_A_0,Blinken_links_Hellphase ,16
ENG124861-ENG115017-Leuchte 0 BLK VL B35-Light_Function_B_0,not_activ ,16
ENG124861-ENG115020-Leuchte 0 BLK VL B35-Light_Function_C_0,not_activ ,16
ENG124861-ENG115021-Leuchte 0 BLK VL B35-Light_Function_D_0,not_activ ,16
ENG124861-ENG115024-Leuchte 0 BLK VL B35-Light_Function_E_0,not_activ ,16
ENG124861-ENG115025-Leuchte 0 BLK VL B35-Light_Function_F_0,not_activ ,16
ENG124861-ENG115028-Leuchte 0 BLK VL B35-Light_Function_G_0,not_activ ,16
ENG124861-ENG115029-Leuchte 0 BLK VL B35-Light_Function_H_0,not_activ ,16
ENG124861-ENG115013-Leuchte 0 BLK VL B35-Type_Of_Load_0,LED_Blinkleuchten ,16
ENG124872-ENG115193-Leuchte11WARNBLK TASTERC54-Dimming_AB_11,100 ,16
ENG124872-ENG115197-Leuchte11WARNBLK TASTERC54-Dimming_CD_11,0 ,16
ENG124872-ENG115198-Leuchte11WARNBLK TASTERC54-Dimming_Direction_CD_11,maximize ,16
ENG124872-ENG115202-Leuchte11WARNBLK TASTERC54-Dimming_Direction_EF_11,maximize ,16
ENG124872-ENG115206-Leuchte11WARNBLK TASTERC54-Dimming_Direction_GH_11,maximize ,16
ENG124872-ENG115201-Leuchte11WARNBLK TASTERC54-Dimming_EF_11,0 ,16
ENG124872-ENG115205-Leuchte11WARNBLK TASTERC54-Dimming_GH_11,0 ,16
ENG124872-ENG126586-Leuchte11WARNBLK TASTERC54-Fehlerort_mittleres_Byte_DTC-DFCC_11,0 ,16
ENG124872-ENG115735-Leuchte11WARNBLK TASTERC54-Lampendefektbit_Position_11,0 ,16
ENG124872-ENG115194-Leuchte11WARNBLK TASTERC54-Light_Control_HD_AB_11,Always ,16
ENG124872-ENG115191-Leuchte11WARNBLK TASTERC54-Light_Function_A_11,Warnblink_taster ,16
ENG124872-ENG115192-Leuchte11WARNBLK TASTERC54-Light_Function_B_11,not_activ ,16
ENG124872-ENG115195-Leuchte11WARNBLK TASTERC54-Light_Function_C_11,not_activ ,16
ENG124872-ENG115196-Leuchte11WARNBLK TASTERC54-Light_Function_D_11,not_activ ,16
ENG124872-ENG115199-Leuchte11WARNBLK TASTERC54-Light_Function_E_11,not_activ ,16
ENG124872-ENG115200-Leuchte11WARNBLK TASTERC54-Light_Function_F_11,not_activ ,16
ENG124872-ENG115203-Leuchte11WARNBLK TASTERC54-Light_Function_G_11,not_activ ,16
ENG124872-ENG115204-Leuchte11WARNBLK TASTERC54-Light_Function_H_11,not_activ ,16
ENG124872-ENG115188-Leuchte11WARNBLK TASTERC54-Type_Of_Load_11,LED_Kleinleistung_ohne_OL_mitUeberspg_absch ,16
ENG124873-ENG115212-Leuchte12NL LB40-Dimming_AB_12,100 ,16
ENG124873-ENG115216-Leuchte12NL LB40-Dimming_CD_12,0 ,16
ENG124873-ENG115217-Leuchte12NL LB40-Dimming_Direction_CD_12,maximize ,16
ENG124873-ENG115221-Leuchte12NL LB40-Dimming_Direction_EF_12,maximize ,16
ENG124873-ENG115225-Leuchte12NL LB40-Dimming_Direction_GH_12,maximize ,16
ENG124873-ENG115220-Leuchte12NL LB40-Dimming_EF_12,0 ,16
ENG124873-ENG115224-Leuchte12NL LB40-Dimming_GH_12,0 ,16
ENG124873-ENG126587-Leuchte12NL LB40-Fehlerort_mittleres_Byte_DTC-DFCC_12,34 ,16
ENG124873-ENG115750-Leuchte12NL LB40-Lampendefektbit_Position_12,56 ,16
ENG124873-ENG115213-Leuchte12NL LB40-Light_Control_HD_AB_12,Always ,16
ENG124873-ENG115210-Leuchte12NL LB40-Light_Function_A_12,Nebel_licht_links ,16
ENG124873-ENG115211-Leuchte12NL LB40-Light_Function_B_12,Abbiegelicht_links ,16
ENG124873-ENG115214-Leuchte12NL LB40-Light_Function_C_12,not_activ ,16
ENG124873-ENG115215-Leuchte12NL LB40-Light_Function_D_12,not_activ ,16
ENG124873-ENG115218-Leuchte12NL LB40-Light_Function_E_12,not_activ ,16
ENG124873-ENG115219-Leuchte12NL LB40-Light_Function_F_12,not_activ ,16
ENG124873-ENG115222-Leuchte12NL LB40-Light_Function_G_12,not_activ ,16
ENG124873-ENG115223-Leuchte12NL LB40-Light_Function_H_12,not_activ ,16
ENG124873-ENG115207-Leuchte12NL LB40-Type_Of_Load_12,allgemeineScheinwerfer ,16
ENG124874-ENG114958-Leuchte13NL RB3-Dimming_AB_13,100 ,16
ENG124874-ENG114962-Leuchte13NL RB3-Dimming_CD_13,0 ,16
ENG124874-ENG114963-Leuchte13NL RB3-Dimming_Direction_CD_13,maximize ,16
ENG124874-ENG114967-Leuchte13NL RB3-Dimming_Direction_EF_13,maximize ,16
ENG124874-ENG114971-Leuchte13NL RB3-Dimming_Direction_GH_13,maximize ,16
ENG124874-ENG114966-Leuchte13NL RB3-Dimming_EF_13,0 ,16
ENG124874-ENG114970-Leuchte13NL RB3-Dimming_GH_13,0 ,16
ENG124874-ENG126588-Leuchte13NL RB3-Fehlerort_mittleres_Byte_DTC-DFCC_13,35 ,16
ENG124874-ENG114955-Leuchte13NL RB3-Lampendefektbit_Position_13,66 ,16
ENG124874-ENG114959-Leuchte13NL RB3-Light_Control_HD_AB_13,Always ,16
ENG124874-ENG114956-Leuchte13NL RB3-Light_Function_A_13,Nebellichtrechts ,16
ENG124874-ENG114957-Leuchte13NL RB3-Light_Function_B_13,Abbiegelicht_rechts ,16
ENG124874-ENG114960-Leuchte13NL RB3-Light_Function_C_13,not_activ ,16
ENG124874-ENG114961-Leuchte13NL RB3-Light_Function_D_13,not_activ ,16
ENG124874-ENG114964-Leuchte13NL RB3-Light_Function_E_13,not_activ ,16
ENG124874-ENG114965-Leuchte13NL RB3-Light_Function_F_13,not_activ ,16
ENG124874-ENG114968-Leuchte13NL RB3-Light_Function_G_13,not_activ ,16
ENG124874-ENG114969-Leuchte13NL RB3-Light_Function_H_13,not_activ ,16
ENG124874-ENG114954-Leuchte13NL RB3-Type_Of_Load_13,allgemeineScheinwerfer ,16
ENG124876-ENG115252-Leuchte15 SAFE LED C55-Dimming_AB_15,100 ,16
ENG124876-ENG115256-Leuchte15 SAFE LED C55-Dimming_CD_15,0 ,16
ENG124876-ENG115257-Leuchte15 SAFE LED C55-Dimming_Direction_CD_15,maximize ,16
ENG124876-ENG115261-Leuchte15 SAFE LED C55-Dimming_Direction_EF_15,maximize ,16
ENG124876-ENG115265-Leuchte15 SAFE LED C55-Dimming_Direction_GH_15,maximize ,16
ENG124876-ENG115260-Leuchte15 SAFE LED C55-Dimming_EF_15,0 ,16
ENG124876-ENG115264-Leuchte15 SAFE LED C55-Dimming_GH_15,0 ,16
ENG124876-ENG126590-Leuchte15 SAFE LED C55-Fehlerort_mittleres_Byte_DTC-DFCC_15,0 ,16
ENG124876-ENG115800-Leuchte15 SAFE LED C55-Lampendefektbit_Position_15,0 ,16
ENG124876-ENG115253-Leuchte15 SAFE LED C55-Light_Control_HD_AB_15,Always ,16
ENG124876-ENG115250-Leuchte15 SAFE LED C55-Light_Function_A_15,Safe_LED ,16
ENG124876-ENG115251-Leuchte15 SAFE LED C55-Light_Function_B_15,not_activ ,16
ENG124876-ENG115254-Leuchte15 SAFE LED C55-Light_Function_C_15,not_activ ,16
ENG124876-ENG115255-Leuchte15 SAFE LED C55-Light_Function_D_15,not_activ ,16
ENG124876-ENG115258-Leuchte15 SAFE LED C55-Light_Function_E_15,not_activ ,16
ENG124876-ENG115259-Leuchte15 SAFE LED C55-Light_Function_F_15,not_activ ,16
ENG124876-ENG115262-Leuchte15 SAFE LED C55-Light_Function_G_15,not_activ ,16
ENG124876-ENG115263-Leuchte15 SAFE LED C55-Light_Function_H_15,not_activ ,16
ENG124876-ENG115247-Leuchte15 SAFE LED C55-Type_Of_Load_15,LED_Kleinleistung_ohne_OL_mitUeberspg_absch ,16
ENG124877-ENG115271-Leuchte16BLK SLC11-Dimming_AB_16,100 ,16
ENG124877-ENG115275-Leuchte16BLK SLC11-Dimming_CD_16,0 ,16
ENG124877-ENG115276-Leuchte16BLK SLC11-Dimming_Direction_CD_16,maximize ,16
ENG124877-ENG115280-Leuchte16BLK SLC11-Dimming_Direction_EF_16,maximize ,16
ENG124877-ENG115284-Leuchte16BLK SLC11-Dimming_Direction_GH_16,maximize ,16
ENG124877-ENG115279-Leuchte16BLK SLC11-Dimming_EF_16,0 ,16
ENG124877-ENG115283-Leuchte16BLK SLC11-Dimming_GH_16,0 ,16
ENG124877-ENG126591-Leuchte16BLK SLC11-Fehlerort_mittleres_Byte_DTC-DFCC_16,23 ,16
ENG124877-ENG115649-Leuchte16BLK SLC11-Lampendefektbit_Position_16,57 ,16
ENG124877-ENG115272-Leuchte16BLK SLC11-Light_Control_HD_AB_16,Always ,16
ENG124877-ENG115269-Leuchte16BLK SLC11-Light_Function_A_16,Blinken_links_Hellphase ,16
ENG124877-ENG115270-Leuchte16BLK SLC11-Light_Function_B_16,not_activ ,16
ENG124877-ENG115273-Leuchte16BLK SLC11-Light_Function_C_16,not_activ ,16
ENG124877-ENG115274-Leuchte16BLK SLC11-Light_Function_D_16,not_activ ,16
ENG124877-ENG115277-Leuchte16BLK SLC11-Light_Function_E_16,not_activ ,16
ENG124877-ENG115278-Leuchte16BLK SLC11-Light_Function_F_16,not_activ ,16
ENG124877-ENG115281-Leuchte16BLK SLC11-Light_Function_G_16,not_activ ,16
ENG124877-ENG115282-Leuchte16BLK SLC11-Light_Function_H_16,not_activ ,16
ENG124877-ENG115266-Leuchte16BLK SLC11-Type_Of_Load_16,LED_Blinkleuchten ,16
ENG124878-ENG115290-Leuchte17 BLK SR A72-Dimming_AB_17,100 ,16
ENG124878-ENG115294-Leuchte17 BLK SR A72-Dimming_CD_17,0 ,16
ENG124878-ENG115295-Leuchte17 BLK SR A72-Dimming_Direction_CD_17,maximize ,16
ENG124878-ENG115299-Leuchte17 BLK SR A72-Dimming_Direction_EF_17,maximize ,16
ENG124878-ENG115303-Leuchte17 BLK SR A72-Dimming_Direction_GH_17,maximize ,16
ENG124878-ENG115298-Leuchte17 BLK SR A72-Dimming_EF_17,0 ,16
ENG124878-ENG115302-Leuchte17 BLK SR A72-Dimming_GH_17,0 ,16
ENG124878-ENG126592-Leuchte17 BLK SR A72-Fehlerort_mittleres_Byte_DTC-DFCC_17,25 ,16
ENG124878-ENG115799-Leuchte17 BLK SR A72-Lampendefektbit_Position_17,67 ,16
ENG124878-ENG115291-Leuchte17 BLK SR A72-Light_Control_HD_AB_17,Always ,16
ENG124878-ENG115288-Leuchte17 BLK SR A72-Light_Function_A_17,Blinken_rechts_Hellphase ,16
ENG124878-ENG115289-Leuchte17 BLK SR A72-Light_Function_B_17,not_activ ,16
ENG124878-ENG115292-Leuchte17 BLK SR A72-Light_Function_C_17,not_activ ,16
ENG124878-ENG115293-Leuchte17 BLK SR A72-Light_Function_D_17,not_activ ,16
ENG124878-ENG115296-Leuchte17 BLK SR A72-Light_Function_E_17,not_activ ,16
ENG124878-ENG115297-Leuchte17 BLK SR A72-Light_Function_F_17,not_activ ,16
ENG124878-ENG115300-Leuchte17 BLK SR A72-Light_Function_G_17,not_activ ,16
ENG124878-ENG115301-Leuchte17 BLK SR A72-Light_Function_H_17,not_activ ,16
ENG124878-ENG115285-Leuchte17 BLK SR A72-Type_Of_Load_17,LED_Blinkleuchten ,16
ENG124879-ENG115309-Leuchte18BLK HLA71-Dimming_AB_18,100 ,16
ENG124879-ENG115313-Leuchte18BLK HLA71-Dimming_CD_18,0 ,16
ENG124879-ENG115314-Leuchte18BLK HLA71-Dimming_Direction_CD_18,maximize ,16
ENG124879-ENG115318-Leuchte18BLK HLA71-Dimming_Direction_EF_18,maximize ,16
ENG124879-ENG115322-Leuchte18BLK HLA71-Dimming_Direction_GH_18,maximize ,16
ENG124879-ENG115317-Leuchte18BLK HLA71-Dimming_EF_18,0 ,16
ENG124879-ENG115321-Leuchte18BLK HLA71-Dimming_GH_18,0 ,16
ENG124879-ENG126593-Leuchte18BLK HLA71-Fehlerort_mittleres_Byte_DTC-DFCC_18,22 ,16
ENG124879-ENG115651-Leuchte18BLK HLA71-Lampendefektbit_Position_18,8 ,16
ENG124879-ENG115310-Leuchte18BLK HLA71-Light_Control_HD_AB_18,Always ,16
ENG124879-ENG115307-Leuchte18BLK HLA71-Light_Function_A_18,Blinken_links_Hellphase ,16
ENG124879-ENG115308-Leuchte18BLK HLA71-Light_Function_B_18,not_activ ,16
ENG124879-ENG115311-Leuchte18BLK HLA71-Light_Function_C_18,not_activ ,16
ENG124879-ENG115312-Leuchte18BLK HLA71-Light_Function_D_18,not_activ ,16
ENG124879-ENG115315-Leuchte18BLK HLA71-Light_Function_E_18,not_activ ,16
ENG124879-ENG115316-Leuchte18BLK HLA71-Light_Function_F_18,not_activ ,16
ENG124879-ENG115319-Leuchte18BLK HLA71-Light_Function_G_18,not_activ ,16
ENG124879-ENG115320-Leuchte18BLK HLA71-Light_Function_H_18,not_activ ,16
ENG124879-ENG115304-Leuchte18BLK HLA71-Type_Of_Load_18,Blinkleuchten ,16
ENG124880-ENG115328-Leuchte19BLK HRC8-Dimming_AB_19,100 ,16
ENG124880-ENG115332-Leuchte19BLK HRC8-Dimming_CD_19,0 ,16
ENG124880-ENG115333-Leuchte19BLK HRC8-Dimming_Direction_CD_19,maximize ,16
ENG124880-ENG115337-Leuchte19BLK HRC8-Dimming_Direction_EF_19,maximize ,16
ENG124880-ENG115341-Leuchte19BLK HRC8-Dimming_Direction_GH_19,maximize ,16
ENG124880-ENG115336-Leuchte19BLK HRC8-Dimming_EF_19,0 ,16
ENG124880-ENG115340-Leuchte19BLK HRC8-Dimming_GH_19,0 ,16
ENG124880-ENG126594-Leuchte19BLK HRC8-Fehlerort_mittleres_Byte_DTC-DFCC_19,24 ,16
ENG124880-ENG115785-Leuchte19BLK HRC8-Lampendefektbit_Position_19,24 ,16
ENG124880-ENG115329-Leuchte19BLK HRC8-Light_Control_HD_AB_19,Always ,16
ENG124880-ENG115326-Leuchte19BLK HRC8-Light_Function_A_19,Blinken_rechts_Hellphase ,16
ENG124880-ENG115327-Leuchte19BLK HRC8-Light_Function_B_19,not_activ ,16
ENG124880-ENG115330-Leuchte19BLK HRC8-Light_Function_C_19,not_activ ,16
ENG124880-ENG115331-Leuchte19BLK HRC8-Light_Function_D_19,not_activ ,16
ENG124880-ENG115334-Leuchte19BLK HRC8-Light_Function_E_19,not_activ ,16
ENG124880-ENG115335-Leuchte19BLK HRC8-Light_Function_F_19,not_activ ,16
ENG124880-ENG115338-Leuchte19BLK HRC8-Light_Function_G_19,not_activ ,16
ENG124880-ENG115339-Leuchte19BLK HRC8-Light_Function_H_19,not_activ ,16
ENG124880-ENG115323-Leuchte19BLK HRC8-Type_Of_Load_19,Blinkleuchten ,16
ENG124862-ENG115037-Leuchte1BLK VRB23-Dimming_AB_1,127 ,16
ENG124862-ENG115041-Leuchte1BLK VRB23-Dimming_CD_1,0 ,16
ENG124862-ENG115042-Leuchte1BLK VRB23-Dimming_Direction_CD_1,maximize ,16
ENG124862-ENG115046-Leuchte1BLK VRB23-Dimming_Direction_EF_1,maximize ,16
ENG124862-ENG115050-Leuchte1BLK VRB23-Dimming_Direction_GH_1,maximize ,16
ENG124862-ENG115045-Leuchte1BLK VRB23-Dimming_EF_1,0 ,16
ENG124862-ENG115049-Leuchte1BLK VRB23-Dimming_GH_1,0 ,16
ENG124862-ENG126571-Leuchte1BLK VRB23-Fehlerort_mittleres_Byte_DTC-DFCC_1,21 ,16
ENG124862-ENG115732-Leuchte1BLK VRB23-Lampendefektbit_Position_1,62 ,16
ENG124862-ENG115038-Leuchte1BLK VRB23-Light_Control_HD_AB_1,Always ,16
ENG124862-ENG115035-Leuchte1BLK VRB23-Light_Function_A_1,Blinken_rechts_Hellphase ,16
ENG124862-ENG115036-Leuchte1BLK VRB23-Light_Function_B_1,not_activ ,16
ENG124862-ENG115039-Leuchte1BLK VRB23-Light_Function_C_1,not_activ ,16
ENG124862-ENG115040-Leuchte1BLK VRB23-Light_Function_D_1,not_activ ,16
ENG124862-ENG115043-Leuchte1BLK VRB23-Light_Function_E_1,not_activ ,16
ENG124862-ENG115044-Leuchte1BLK VRB23-Light_Function_F_1,not_activ ,16
ENG124862-ENG115047-Leuchte1BLK VRB23-Light_Function_G_1,not_activ ,16
ENG124862-ENG115048-Leuchte1BLK VRB23-Light_Function_H_1,not_activ ,16
ENG124862-ENG115032-Leuchte1BLK VRB23-Type_Of_Load_1,LED_Blinkleuchten ,16
ENG124881-ENG115347-Leuchte20BR LA70-Dimming_AB_20,127 ,16
ENG124881-ENG115351-Leuchte20BR LA70-Dimming_CD_20,0 ,16
ENG124881-ENG115352-Leuchte20BR LA70-Dimming_Direction_CD_20,maximize ,16
ENG124881-ENG115356-Leuchte20BR LA70-Dimming_Direction_EF_20,maximize ,16
ENG124881-ENG115360-Leuchte20BR LA70-Dimming_Direction_GH_20,maximize ,16
ENG124881-ENG115355-Leuchte20BR LA70-Dimming_EF_20,0 ,16
ENG124881-ENG115359-Leuchte20BR LA70-Dimming_GH_20,0 ,16
ENG124881-ENG126595-Leuchte20BR LA70-Fehlerort_mittleres_Byte_DTC-DFCC_20,57 ,16
ENG124881-ENG115629-Leuchte20BR LA70-Lampendefektbit_Position_20,9 ,16
ENG124881-ENG115348-Leuchte20BR LA70-Light_Control_HD_AB_20,Always ,16
ENG124881-ENG115345-Leuchte20BR LA70-Light_Function_A_20,Brake lamp ,16
ENG124881-ENG115346-Leuchte20BR LA70-Light_Function_B_20,not_activ ,16
ENG124881-ENG115349-Leuchte20BR LA70-Light_Function_C_20,not_activ ,16
ENG124881-ENG115350-Leuchte20BR LA70-Light_Function_D_20,not_activ ,16
ENG124881-ENG115353-Leuchte20BR LA70-Light_Function_E_20,not_activ ,16
ENG124881-ENG115354-Leuchte20BR LA70-Light_Function_F_20,not_activ ,16
ENG124881-ENG115357-Leuchte20BR LA70-Light_Function_G_20,not_activ ,16
ENG124881-ENG115358-Leuchte20BR LA70-Light_Function_H_20,not_activ ,16
ENG124881-ENG115342-Leuchte20BR LA70-Type_Of_Load_20,LED_Bremsleuchten ,16
ENG116957-ENG115366-Leuchte21BR RC8-Dimming_AB_21,127 ,16
ENG116957-ENG115370-Leuchte21BR RC8-Dimming_CD_21,0 ,16
ENG116957-ENG115371-Leuchte21BR RC8-Dimming_Direction_CD_21,maximize ,16
ENG116957-ENG115375-Leuchte21BR RC8-Dimming_Direction_EF_21,maximize ,16
ENG116957-ENG115379-Leuchte21BR RC8-Dimming_Direction_GH_21,maximize ,16
ENG116957-ENG115374-Leuchte21BR RC8-Dimming_EF_21,0 ,16
ENG116957-ENG115378-Leuchte21BR RC8-Dimming_GH_21,0 ,16
ENG116957-ENG126596-Leuchte21BR RC8-Fehlerort_mittleres_Byte_DTC-DFCC_21,58 ,16
ENG116957-ENG115811-Leuchte21BR RC8-Lampendefektbit_Position_21,25 ,16
ENG116957-ENG115367-Leuchte21BR RC8-Light_Control_HD_AB_21,Always ,16
ENG116957-ENG115364-Leuchte21BR RC8-Light_Function_A_21,Brake lamp ,16
ENG116957-ENG115365-Leuchte21BR RC8-Light_Function_B_21,not_activ ,16
ENG116957-ENG115368-Leuchte21BR RC8-Light_Function_C_21,not_activ ,16
ENG116957-ENG115369-Leuchte21BR RC8-Light_Function_D_21,not_activ ,16
ENG116957-ENG115372-Leuchte21BR RC8-Light_Function_E_21,not_activ ,16
ENG116957-ENG115373-Leuchte21BR RC8-Light_Function_F_21,not_activ ,16
ENG116957-ENG115376-Leuchte21BR RC8-Light_Function_G_21,not_activ ,16
ENG116957-ENG115377-Leuchte21BR RC8-Light_Function_H_21,not_activ ,16
ENG116957-ENG115361-Leuchte21BR RC8-Type_Of_Load_21,LED_Bremsleuchten ,16
ENG124882-ENG115385-Leuchte22BR MC9-Dimming_AB_22,100 ,16
ENG124882-ENG115389-Leuchte22BR MC9-Dimming_CD_22,0 ,16
ENG124882-ENG115390-Leuchte22BR MC9-Dimming_Direction_CD_22,maximize ,16
ENG124882-ENG115394-Leuchte22BR MC9-Dimming_Direction_EF_22,maximize ,16
ENG124882-ENG115398-Leuchte22BR MC9-Dimming_Direction_GH_22,maximize ,16
ENG124882-ENG115393-Leuchte22BR MC9-Dimming_EF_22,0 ,16
ENG124882-ENG115397-Leuchte22BR MC9-Dimming_GH_22,0 ,16
ENG124882-ENG126597-Leuchte22BR MC9-Fehlerort_mittleres_Byte_DTC-DFCC_22,44 ,16
ENG124882-ENG115780-Leuchte22BR MC9-Lampendefektbit_Position_22,41 ,16
ENG124882-ENG115386-Leuchte22BR MC9-Light_Control_HD_AB_22,Always ,16
ENG124882-ENG115383-Leuchte22BR MC9-Light_Function_A_22,Brake lamp ,16
ENG124882-ENG115384-Leuchte22BR MC9-Light_Function_B_22,not_activ ,16
ENG124882-ENG115387-Leuchte22BR MC9-Light_Function_C_22,not_activ ,16
ENG124882-ENG115388-Leuchte22BR MC9-Light_Function_D_22,not_activ ,16
ENG124882-ENG115391-Leuchte22BR MC9-Light_Function_E_22,not_activ ,16
ENG124882-ENG115392-Leuchte22BR MC9-Light_Function_F_22,not_activ ,16
ENG124882-ENG115395-Leuchte22BR MC9-Light_Function_G_22,not_activ ,16
ENG124882-ENG115396-Leuchte22BR MC9-Light_Function_H_22,not_activ ,16
ENG124882-ENG115380-Leuchte22BR MC9-Type_Of_Load_22,LED dritte Bremsleuchte ,16
ENG124883-ENG115404-Leuchte23SL HLC7-Dimming_AB_23,30 ,16
ENG124883-ENG115408-Leuchte23SL HLC7-Dimming_CD_23,0 ,16
ENG124883-ENG115409-Leuchte23SL HLC7-Dimming_Direction_CD_23,maximize ,16
ENG124883-ENG115413-Leuchte23SL HLC7-Dimming_Direction_EF_23,maximize ,16
ENG124883-ENG115417-Leuchte23SL HLC7-Dimming_Direction_GH_23,maximize ,16
ENG124883-ENG115412-Leuchte23SL HLC7-Dimming_EF_23,0 ,16
ENG124883-ENG115416-Leuchte23SL HLC7-Dimming_GH_23,0 ,16
ENG124883-ENG126598-Leuchte23SL HLC7-Fehlerort_mittleres_Byte_DTC-DFCC_23,41 ,16
ENG124883-ENG115781-Leuchte23SL HLC7-Lampendefektbit_Position_23,10 ,16
ENG124883-ENG115405-Leuchte23SL HLC7-Light_Control_HD_AB_23,Always ,16
ENG124883-ENG115402-Leuchte23SL HLC7-Light_Function_A_23,Position lamps ,16
ENG124883-ENG115403-Leuchte23SL HLC7-Light_Function_B_23,Parklichtlinks ,16
ENG124883-ENG115406-Leuchte23SL HLC7-Light_Function_C_23,not_activ ,16
ENG124883-ENG115407-Leuchte23SL HLC7-Light_Function_D_23,not_activ ,16
ENG124883-ENG115410-Leuchte23SL HLC7-Light_Function_E_23,not_activ ,16
ENG124883-ENG115411-Leuchte23SL HLC7-Light_Function_F_23,not_activ ,16
ENG124883-ENG115414-Leuchte23SL HLC7-Light_Function_G_23,not_activ ,16
ENG124883-ENG115415-Leuchte23SL HLC7-Light_Function_H_23,not_activ ,16
ENG124883-ENG115399-Leuchte23SL HLC7-Type_Of_Load_23,allgemeine_LED_12W ,16
ENG124884-ENG115423-Leuchte24SL HRA69-Dimming_AB_24,30 ,16
ENG124884-ENG115427-Leuchte24SL HRA69-Dimming_CD_24,0 ,16
ENG124884-ENG115428-Leuchte24SL HRA69-Dimming_Direction_CD_24,maximize ,16
ENG124884-ENG115432-Leuchte24SL HRA69-Dimming_Direction_EF_24,maximize ,16
ENG124884-ENG115436-Leuchte24SL HRA69-Dimming_Direction_GH_24,maximize ,16
ENG124884-ENG115431-Leuchte24SL HRA69-Dimming_EF_24,0 ,16
ENG124884-ENG115435-Leuchte24SL HRA69-Dimming_GH_24,0 ,16
ENG124884-ENG126599-Leuchte24SL HRA69-Fehlerort_mittleres_Byte_DTC-DFCC_24,42 ,16
ENG124884-ENG115669-Leuchte24SL HRA69-Lampendefektbit_Position_24,26 ,16
ENG124884-ENG115424-Leuchte24SL HRA69-Light_Control_HD_AB_24,Always ,16
ENG124884-ENG115421-Leuchte24SL HRA69-Light_Function_A_24,Position lamps ,16
ENG124884-ENG115422-Leuchte24SL HRA69-Light_Function_B_24,Parklichtrechts ,16
ENG124884-ENG115425-Leuchte24SL HRA69-Light_Function_C_24,not_activ ,16
ENG124884-ENG115426-Leuchte24SL HRA69-Light_Function_D_24,not_activ ,16
ENG124884-ENG115429-Leuchte24SL HRA69-Light_Function_E_24,not_activ ,16
ENG124884-ENG115430-Leuchte24SL HRA69-Light_Function_F_24,not_activ ,16
ENG124884-ENG115433-Leuchte24SL HRA69-Light_Function_G_24,not_activ ,16
ENG124884-ENG115434-Leuchte24SL HRA69-Light_Function_H_24,not_activ ,16
ENG124884-ENG115418-Leuchte24SL HRA69-Type_Of_Load_24,allgemeine_LED_12W ,16
ENG124885-ENG115442-Leuchte25KZL HA60-Dimming_AB_25,100 ,16
ENG124885-ENG115446-Leuchte25KZL HA60-Dimming_CD_25,0 ,16
ENG124885-ENG115447-Leuchte25KZL HA60-Dimming_Direction_CD_25,maximize ,16
ENG124885-ENG115451-Leuchte25KZL HA60-Dimming_Direction_EF_25,maximize ,16
ENG124885-ENG115455-Leuchte25KZL HA60-Dimming_Direction_GH_25,maximize ,16
ENG124885-ENG115450-Leuchte25KZL HA60-Dimming_EF_25,0 ,16
ENG124885-ENG115454-Leuchte25KZL HA60-Dimming_GH_25,0 ,16
ENG124885-ENG126600-Leuchte25KZL HA60-Fehlerort_mittleres_Byte_DTC-DFCC_25,48 ,16
ENG124885-ENG115725-Leuchte25KZL HA60-Lampendefektbit_Position_25,40 ,16
ENG124885-ENG115443-Leuchte25KZL HA60-Light_Control_HD_AB_25,Always ,16
ENG124885-ENG115440-Leuchte25KZL HA60-Light_Function_A_25,Position lamps ,16
ENG124885-ENG115441-Leuchte25KZL HA60-Light_Function_B_25,not_activ ,16
ENG124885-ENG115444-Leuchte25KZL HA60-Light_Function_C_25,not_activ ,16
ENG124885-ENG115445-Leuchte25KZL HA60-Light_Function_D_25,not_activ ,16
ENG124885-ENG115448-Leuchte25KZL HA60-Light_Function_E_25,not_activ ,16
ENG124885-ENG115449-Leuchte25KZL HA60-Light_Function_F_25,not_activ ,16
ENG124885-ENG115452-Leuchte25KZL HA60-Light_Function_G_25,not_activ ,16
ENG124885-ENG115453-Leuchte25KZL HA60-Light_Function_H_25,not_activ ,16
ENG124885-ENG115437-Leuchte25KZL HA60-Type_Of_Load_25,allgemeine_LED_6W ,16
ENG124886-ENG115461-Leuchte26NSL A65-Dimming_AB_26,0 ,16
ENG124886-ENG115465-Leuchte26NSL A65-Dimming_CD_26,0 ,16
ENG124886-ENG115466-Leuchte26NSL A65-Dimming_Direction_CD_26,maximize ,16
ENG124886-ENG115470-Leuchte26NSL A65-Dimming_Direction_EF_26,maximize ,16
ENG124886-ENG115474-Leuchte26NSL A65-Dimming_Direction_GH_26,maximize ,16
ENG124886-ENG115469-Leuchte26NSL A65-Dimming_EF_26,0 ,16
ENG124886-ENG115473-Leuchte26NSL A65-Dimming_GH_26,0 ,16
ENG124886-ENG126601-Leuchte26NSL A65-Fehlerort_mittleres_Byte_DTC-DFCC_26,0 ,16
ENG124886-ENG115627-Leuchte26NSL A65-Lampendefektbit_Position_26,0 ,16
ENG124886-ENG115462-Leuchte26NSL A65-Light_Control_HD_AB_26,Always ,16
ENG124886-ENG115459-Leuchte26NSL A65-Light_Function_A_26,not_activ ,16
ENG124886-ENG115460-Leuchte26NSL A65-Light_Function_B_26,not_activ ,16
ENG124886-ENG115463-Leuchte26NSL A65-Light_Function_C_26,not_activ ,16
ENG124886-ENG115464-Leuchte26NSL A65-Light_Function_D_26,not_activ ,16
ENG124886-ENG115467-Leuchte26NSL A65-Light_Function_E_26,not_activ ,16
ENG124886-ENG115468-Leuchte26NSL A65-Light_Function_F_26,not_activ ,16
ENG124886-ENG115471-Leuchte26NSL A65-Light_Function_G_26,not_activ ,16
ENG124886-ENG115472-Leuchte26NSL A65-Light_Function_H_26,not_activ ,16
ENG124886-ENG115456-Leuchte26NSL A65-Type_Of_Load_26,not_active ,16
ENG124887-ENG115480-Leuchte27 KL58XS C67-Dimming_AB_27,100 ,16
ENG124887-ENG115484-Leuchte27 KL58XS C67-Dimming_CD_27,0 ,16
ENG124887-ENG115485-Leuchte27 KL58XS C67-Dimming_Direction_CD_27,maximize ,16
ENG124887-ENG115489-Leuchte27 KL58XS C67-Dimming_Direction_EF_27,maximize ,16
ENG124887-ENG115493-Leuchte27 KL58XS C67-Dimming_Direction_GH_27,maximize ,16
ENG124887-ENG115488-Leuchte27 KL58XS C67-Dimming_EF_27,0 ,16
ENG124887-ENG115492-Leuchte27 KL58XS C67-Dimming_GH_27,0 ,16
ENG124887-ENG126602-Leuchte27 KL58XS C67-Fehlerort_mittleres_Byte_DTC-DFCC_27,8 ,16
ENG124887-ENG115648-Leuchte27 KL58XS C67-Lampendefektbit_Position_27,0 ,16
ENG124887-ENG115481-Leuchte27 KL58XS C67-Light_Control_HD_AB_27,Always ,16
ENG124887-ENG115478-Leuchte27 KL58XS C67-Light_Function_A_27,Dimmung_Klemme_58_xs ,16
ENG124887-ENG115479-Leuchte27 KL58XS C67-Light_Function_B_27,not_activ ,16
ENG124887-ENG115482-Leuchte27 KL58XS C67-Light_Function_C_27,not_activ ,16
ENG124887-ENG115483-Leuchte27 KL58XS C67-Light_Function_D_27,not_activ ,16
ENG124887-ENG115486-Leuchte27 KL58XS C67-Light_Function_E_27,not_activ ,16
ENG124887-ENG115487-Leuchte27 KL58XS C67-Light_Function_F_27,not_activ ,16
ENG124887-ENG115490-Leuchte27 KL58XS C67-Light_Function_G_27,not_activ ,16
ENG124887-ENG115491-Leuchte27 KL58XS C67-Light_Function_H_27,not_activ ,16
ENG124887-ENG115475-Leuchte27 KL58XS C67-Type_Of_Load_27,LED_Kleinleistung_ohne_OL_mitUeberspg_absch ,16
ENG124888-ENG115499-Leuchte28RFL C3-Dimming_AB_28,100 ,16
ENG124888-ENG115503-Leuchte28RFL C3-Dimming_CD_28,0 ,16
ENG124888-ENG115504-Leuchte28RFL C3-Dimming_Direction_CD_28,maximize ,16
ENG124888-ENG115508-Leuchte28RFL C3-Dimming_Direction_EF_28,maximize ,16
ENG124888-ENG115512-Leuchte28RFL C3-Dimming_Direction_GH_28,maximize ,16
ENG124888-ENG115507-Leuchte28RFL C3-Dimming_EF_28,0 ,16
ENG124888-ENG115511-Leuchte28RFL C3-Dimming_GH_28,0 ,16
ENG124888-ENG126603-Leuchte28RFL C3-Fehlerort_mittleres_Byte_DTC-DFCC_28,52 ,16
ENG124888-ENG115647-Leuchte28RFL C3-Lampendefektbit_Position_28,43 ,16
ENG124888-ENG115500-Leuchte28RFL C3-Light_Control_HD_AB_28,only_if_closed ,16
ENG124888-ENG115497-Leuchte28RFL C3-Light_Function_A_28,Rueckfahrlicht ,16
ENG124888-ENG115498-Leuchte28RFL C3-Light_Function_B_28,not_activ ,16
ENG124888-ENG115501-Leuchte28RFL C3-Light_Function_C_28,not_activ ,16
ENG124888-ENG115502-Leuchte28RFL C3-Light_Function_D_28,not_activ ,16
ENG124888-ENG115505-Leuchte28RFL C3-Light_Function_E_28,not_activ ,16
ENG124888-ENG115506-Leuchte28RFL C3-Light_Function_F_28,not_activ ,16
ENG124888-ENG115509-Leuchte28RFL C3-Light_Function_G_28,not_activ ,16
ENG124888-ENG115510-Leuchte28RFL C3-Light_Function_H_28,not_activ ,16
ENG124888-ENG115494-Leuchte28RFL C3-Type_Of_Load_28,2*21W_Nebelschluss_Rueckfahrleuchte_mit_Teilausfallerkennung ,16
ENG124889-ENG115518-Leuchte29 KL30G A69-Dimming_AB_29,100 ,16
ENG124889-ENG115522-Leuchte29 KL30G A69-Dimming_CD_29,0 ,16
ENG124889-ENG115523-Leuchte29 KL30G A69-Dimming_Direction_CD_29,maximize ,16
ENG124889-ENG115527-Leuchte29 KL30G A69-Dimming_Direction_EF_29,maximize ,16
ENG124889-ENG115531-Leuchte29 KL30G A69-Dimming_Direction_GH_29,maximize ,16
ENG124889-ENG115526-Leuchte29 KL30G A69-Dimming_EF_29,0 ,16
ENG124889-ENG115530-Leuchte29 KL30G A69-Dimming_GH_29,0 ,16
ENG124889-ENG126604-Leuchte29 KL30G A69-Fehlerort_mittleres_Byte_DTC-DFCC_29,1 ,16
ENG124889-ENG115764-Leuchte29 KL30G A69-Lampendefektbit_Position_29,0 ,16
ENG124889-ENG115520-Leuchte29 KL30G A69-Light_Control_HD_AB_29,Always ,16
ENG124889-ENG115516-Leuchte29 KL30G A69-Light_Function_A_29,Klemme_30_G ,16
ENG124889-ENG115517-Leuchte29 KL30G A69-Light_Function_B_29,not_activ ,16
ENG124889-ENG115519-Leuchte29 KL30G A69-Light_Function_C_29,not_activ ,16
ENG124889-ENG115521-Leuchte29 KL30G A69-Light_Function_D_29,not_activ ,16
ENG124889-ENG115524-Leuchte29 KL30G A69-Light_Function_E_29,not_activ ,16
ENG124889-ENG115525-Leuchte29 KL30G A69-Light_Function_F_29,not_activ ,16
ENG124889-ENG115528-Leuchte29 KL30G A69-Light_Function_G_29,not_activ ,16
ENG124889-ENG115529-Leuchte29 KL30G A69-Light_Function_H_29,not_activ ,16
ENG124889-ENG115513-Leuchte29 KL30G A69-Type_Of_Load_29,allgemeine_Gluehlampe12W ,16
ENG124863-ENG115056-Leuchte2SL VLB22-Dimming_AB_2,100 ,16
ENG124863-ENG115060-Leuchte2SL VLB22-Dimming_CD_2,24 ,16
ENG124863-ENG115061-Leuchte2SL VLB22-Dimming_Direction_CD_2,maximize ,16
ENG124863-ENG115065-Leuchte2SL VLB22-Dimming_Direction_EF_2,minimize ,16
ENG124863-ENG115069-Leuchte2SL VLB22-Dimming_Direction_GH_2,maximize ,16
ENG124863-ENG115064-Leuchte2SL VLB22-Dimming_EF_2,28 ,16
ENG124863-ENG115068-Leuchte2SL VLB22-Dimming_GH_2,0 ,16
ENG124863-ENG126577-Leuchte2SL VLB22-Fehlerort_mittleres_Byte_DTC-DFCC_2,74 ,16
ENG124863-ENG115726-Leuchte2SL VLB22-Lampendefektbit_Position_2,72 ,16
ENG124863-ENG115057-Leuchte2SL VLB22-Light_Control_HD_AB_2,Always ,16
ENG124863-ENG115054-Leuchte2SL VLB22-Light_Function_A_2,Daytime running lamps ,16
ENG124863-ENG115055-Leuchte2SL VLB22-Light_Function_B_2,not_activ ,16
ENG124863-ENG115058-Leuchte2SL VLB22-Light_Function_C_2,Position lamps ,16
ENG124863-ENG115059-Leuchte2SL VLB22-Light_Function_D_2,Parklichtlinks ,16
ENG124863-ENG115062-Leuchte2SL VLB22-Light_Function_E_2,Blinkenlinksaktiv ,16
ENG124863-ENG115063-Leuchte2SL VLB22-Light_Function_F_2,not_activ ,16
ENG124863-ENG115066-Leuchte2SL VLB22-Light_Function_G_2,not_activ ,16
ENG124863-ENG115067-Leuchte2SL VLB22-Light_Function_H_2,not_activ ,16
ENG124863-ENG115051-Leuchte2SL VLB22-Type_Of_Load_2,LEDTagfahrlichtmodulSignal ,16
ENG124890-ENG115537-Leuchte30 INNENLICHT A68-Dimming_AB_30,100 ,16
ENG124890-ENG115541-Leuchte30 INNENLICHT A68-Dimming_CD_30,0 ,16
ENG124890-ENG115542-Leuchte30 INNENLICHT A68-Dimming_Direction_CD_30,maximize ,16
ENG124890-ENG115546-Leuchte30 INNENLICHT A68-Dimming_Direction_EF_30,maximize ,16
ENG124890-ENG115550-Leuchte30 INNENLICHT A68-Dimming_Direction_GH_30,maximize ,16
ENG124890-ENG115545-Leuchte30 INNENLICHT A68-Dimming_EF_30,0 ,16
ENG124890-ENG115549-Leuchte30 INNENLICHT A68-Dimming_GH_30,0 ,16
ENG124890-ENG126605-Leuchte30 INNENLICHT A68-Fehlerort_mittleres_Byte_DTC-DFCC_30,7 ,16
ENG124890-ENG115797-Leuchte30 INNENLICHT A68-Lampendefektbit_Position_30,0 ,16
ENG124890-ENG115538-Leuchte30 INNENLICHT A68-Light_Control_HD_AB_30,Always ,16
ENG124890-ENG115535-Leuchte30 INNENLICHT A68-Light_Function_A_30,Interior lighting ,16
ENG124890-ENG115536-Leuchte30 INNENLICHT A68-Light_Function_B_30,not_activ ,16
ENG124890-ENG115539-Leuchte30 INNENLICHT A68-Light_Function_C_30,not_activ ,16
ENG124890-ENG115540-Leuchte30 INNENLICHT A68-Light_Function_D_30,not_activ ,16
ENG124890-ENG115543-Leuchte30 INNENLICHT A68-Light_Function_E_30,not_activ ,16
ENG124890-ENG115544-Leuchte30 INNENLICHT A68-Light_Function_F_30,not_activ ,16
ENG124890-ENG115547-Leuchte30 INNENLICHT A68-Light_Function_G_30,not_activ ,16
ENG124890-ENG115548-Leuchte30 INNENLICHT A68-Light_Function_H_30,not_activ ,16
ENG124890-ENG115532-Leuchte30 INNENLICHT A68-Type_Of_Load_30,allgemeine_Gluehlampe12W ,16
ENG124891-ENG115556-Leuchte31AMBL 1C65-Dimming_AB_31,0 ,16
ENG124891-ENG115560-Leuchte31AMBL 1C65-Dimming_CD_31,0 ,16
ENG124891-ENG115561-Leuchte31AMBL 1C65-Dimming_Direction_CD_31,maximize ,16
ENG124891-ENG115565-Leuchte31AMBL 1C65-Dimming_Direction_EF_31,maximize ,16
ENG124891-ENG115569-Leuchte31AMBL 1C65-Dimming_Direction_GH_31,maximize ,16
ENG124891-ENG115564-Leuchte31AMBL 1C65-Dimming_EF_31,0 ,16
ENG124891-ENG115568-Leuchte31AMBL 1C65-Dimming_GH_31,0 ,16
ENG124891-ENG126606-Leuchte31AMBL 1C65-Fehlerort_mittleres_Byte_DTC-DFCC_31,0 ,16
ENG124891-ENG115707-Leuchte31AMBL 1C65-Lampendefektbit_Position_31,0 ,16
ENG124891-ENG115557-Leuchte31AMBL 1C65-Light_Control_HD_AB_31,Always ,16
ENG124891-ENG115554-Leuchte31AMBL 1C65-Light_Function_A_31,not_activ ,16
ENG124891-ENG115555-Leuchte31AMBL 1C65-Light_Function_B_31,not_activ ,16
ENG124891-ENG115558-Leuchte31AMBL 1C65-Light_Function_C_31,not_activ ,16
ENG124891-ENG115559-Leuchte31AMBL 1C65-Light_Function_D_31,not_activ ,16
ENG124891-ENG115562-Leuchte31AMBL 1C65-Light_Function_E_31,not_activ ,16
ENG124891-ENG115563-Leuchte31AMBL 1C65-Light_Function_F_31,not_activ ,16
ENG124891-ENG115566-Leuchte31AMBL 1C65-Light_Function_G_31,not_activ ,16
ENG124891-ENG115567-Leuchte31AMBL 1C65-Light_Function_H_31,not_activ ,16
ENG124891-ENG115551-Leuchte31AMBL 1C65-Type_Of_Load_31,not_active ,16
ENG124892-ENG115575-Leuchte32AMBL 2C64-Dimming_AB_32,100 ,16
ENG124892-ENG115579-Leuchte32AMBL 2C64-Dimming_CD_32,0 ,16
ENG124892-ENG115580-Leuchte32AMBL 2C64-Dimming_Direction_CD_32,maximize ,16
ENG124892-ENG115584-Leuchte32AMBL 2C64-Dimming_Direction_EF_32,maximize ,16
ENG124892-ENG115588-Leuchte32AMBL 2C64-Dimming_Direction_GH_32,maximize ,16
ENG124892-ENG115583-Leuchte32AMBL 2C64-Dimming_EF_32,0 ,16
ENG124892-ENG115587-Leuchte32AMBL 2C64-Dimming_GH_32,0 ,16
ENG124892-ENG126607-Leuchte32AMBL 2C64-Fehlerort_mittleres_Byte_DTC-DFCC_32,4 ,16
ENG124892-ENG115654-Leuchte32AMBL 2C64-Lampendefektbit_Position_32,0 ,16
ENG124892-ENG115576-Leuchte32AMBL 2C64-Light_Control_HD_AB_32,Always ,16
ENG124892-ENG115573-Leuchte32AMBL 2C64-Light_Function_A_32,Ambientelicht_1 ,16
ENG124892-ENG115574-Leuchte32AMBL 2C64-Light_Function_B_32,not_activ ,16
ENG124892-ENG115577-Leuchte32AMBL 2C64-Light_Function_C_32,not_activ ,16
ENG124892-ENG115578-Leuchte32AMBL 2C64-Light_Function_D_32,not_activ ,16
ENG124892-ENG115581-Leuchte32AMBL 2C64-Light_Function_E_32,not_activ ,16
ENG124892-ENG115582-Leuchte32AMBL 2C64-Light_Function_F_32,not_activ ,16
ENG124892-ENG115585-Leuchte32AMBL 2C64-Light_Function_G_32,not_activ ,16
ENG124892-ENG115586-Leuchte32AMBL 2C64-Light_Function_H_32,not_activ ,16
ENG124892-ENG115570-Leuchte32AMBL 2C64-Type_Of_Load_32,LED_Kleinleistung_ohne_OL_mitUeberspg_absch ,16
ENG124893-ENG115594-Leuchte33AMBL 3C72-Dimming_AB_33,127 ,16
ENG124893-ENG115598-Leuchte33AMBL 3C72-Dimming_CD_33,0 ,16
ENG124893-ENG115599-Leuchte33AMBL 3C72-Dimming_Direction_CD_33,maximize ,16
ENG124893-ENG115603-Leuchte33AMBL 3C72-Dimming_Direction_EF_33,maximize ,16
ENG124893-ENG115607-Leuchte33AMBL 3C72-Dimming_Direction_GH_33,maximize ,16
ENG124893-ENG115602-Leuchte33AMBL 3C72-Dimming_EF_33,0 ,16
ENG124893-ENG115606-Leuchte33AMBL 3C72-Dimming_GH_33,0 ,16
ENG124893-ENG126608-Leuchte33AMBL 3C72-Fehlerort_mittleres_Byte_DTC-DFCC_33,42 ,16
ENG124893-ENG115655-Leuchte33AMBL 3C72-Lampendefektbit_Position_33,26 ,16
ENG124893-ENG115595-Leuchte33AMBL 3C72-Light_Control_HD_AB_33,Always ,16
ENG124893-ENG115592-Leuchte33AMBL 3C72-Light_Function_A_33,Position lamps ,16
ENG124893-ENG115593-Leuchte33AMBL 3C72-Light_Function_B_33,Parklichtrechts ,16
ENG124893-ENG115596-Leuchte33AMBL 3C72-Light_Function_C_33,not_activ ,16
ENG124893-ENG115597-Leuchte33AMBL 3C72-Light_Function_D_33,not_activ ,16
ENG124893-ENG115600-Leuchte33AMBL 3C72-Light_Function_E_33,not_activ ,16
ENG124893-ENG115601-Leuchte33AMBL 3C72-Light_Function_F_33,not_activ ,16
ENG124893-ENG115604-Leuchte33AMBL 3C72-Light_Function_G_33,not_activ ,16
ENG124893-ENG115605-Leuchte33AMBL 3C72-Light_Function_H_33,not_activ ,16
ENG124893-ENG115589-Leuchte33AMBL 3C72-Type_Of_Load_33,allgemeine_LED_6W ,16
ENG124894-ENG115613-Leuchte34AMBL 4C71-Dimming_AB_34,127 ,16
ENG124894-ENG115617-Leuchte34AMBL 4C71-Dimming_CD_34,0 ,16
ENG124894-ENG115618-Leuchte34AMBL 4C71-Dimming_Direction_CD_34,maximize ,16
ENG124894-ENG115622-Leuchte34AMBL 4C71-Dimming_Direction_EF_34,maximize ,16
ENG124894-ENG115626-Leuchte34AMBL 4C71-Dimming_Direction_GH_34,maximize ,16
ENG124894-ENG115621-Leuchte34AMBL 4C71-Dimming_EF_34,0 ,16
ENG124894-ENG115625-Leuchte34AMBL 4C71-Dimming_GH_34,0 ,16
ENG124894-ENG126609-Leuchte34AMBL 4C71-Fehlerort_mittleres_Byte_DTC-DFCC_34,41 ,16
ENG124894-ENG115796-Leuchte34AMBL 4C71-Lampendefektbit_Position_34,10 ,16
ENG124894-ENG115614-Leuchte34AMBL 4C71-Light_Control_HD_AB_34,Always ,16
ENG124894-ENG115611-Leuchte34AMBL 4C71-Light_Function_A_34,Position lamps ,16
ENG124894-ENG115612-Leuchte34AMBL 4C71-Light_Function_B_34,Parklichtlinks ,16
ENG124894-ENG115615-Leuchte34AMBL 4C71-Light_Function_C_34,not_activ ,16
ENG124894-ENG115616-Leuchte34AMBL 4C71-Light_Function_D_34,not_activ ,16
ENG124894-ENG115619-Leuchte34AMBL 4C71-Light_Function_E_34,not_activ ,16
ENG124894-ENG115620-Leuchte34AMBL 4C71-Light_Function_F_34,not_activ ,16
ENG124894-ENG115623-Leuchte34AMBL 4C71-Light_Function_G_34,not_activ ,16
ENG124894-ENG115624-Leuchte34AMBL 4C71-Light_Function_H_34,not_activ ,16
ENG124894-ENG115608-Leuchte34AMBL 4C71-Type_Of_Load_34,allgemeine_LED_6W ,16
ENG124864-ENG115075-Leuchte3SL VRB36-Dimming_AB_3,100 ,16
ENG124864-ENG115079-Leuchte3SL VRB36-Dimming_CD_3,24 ,16
ENG124864-ENG115080-Leuchte3SL VRB36-Dimming_Direction_CD_3,maximize ,16
ENG124864-ENG115084-Leuchte3SL VRB36-Dimming_Direction_EF_3,minimize ,16
ENG124864-ENG115088-Leuchte3SL VRB36-Dimming_Direction_GH_3,maximize ,16
ENG124864-ENG115083-Leuchte3SL VRB36-Dimming_EF_3,28 ,16
ENG124864-ENG115087-Leuchte3SL VRB36-Dimming_GH_3,0 ,16
ENG124864-ENG126578-Leuchte3SL VRB36-Fehlerort_mittleres_Byte_DTC-DFCC_3,76 ,16
ENG124864-ENG115645-Leuchte3SL VRB36-Lampendefektbit_Position_3,76 ,16
ENG124864-ENG115076-Leuchte3SL VRB36-Light_Control_HD_AB_3,Always ,16
ENG124864-ENG115073-Leuchte3SL VRB36-Light_Function_A_3,Daytime running lamps ,16
ENG124864-ENG115074-Leuchte3SL VRB36-Light_Function_B_3,not_activ ,16
ENG124864-ENG115077-Leuchte3SL VRB36-Light_Function_C_3,Position lamps ,16
ENG124864-ENG115078-Leuchte3SL VRB36-Light_Function_D_3,Parklichtrechts ,16
ENG124864-ENG115081-Leuchte3SL VRB36-Light_Function_E_3,Blinkenrechtsaktiv ,16
ENG124864-ENG115082-Leuchte3SL VRB36-Light_Function_F_3,not_activ ,16
ENG124864-ENG115085-Leuchte3SL VRB36-Light_Function_G_3,not_activ ,16
ENG124864-ENG115086-Leuchte3SL VRB36-Light_Function_H_3,not_activ ,16
ENG124864-ENG115070-Leuchte3SL VRB36-Type_Of_Load_3,LEDTagfahrlichtmodulSignal ,16
ENG124865-ENG115094-Leuchte4TFL LB43-Dimming_AB_4,127 ,16
ENG124865-ENG115098-Leuchte4TFL LB43-Dimming_CD_4,127 ,16
ENG124865-ENG115099-Leuchte4TFL LB43-Dimming_Direction_CD_4,maximize ,16
ENG124865-ENG115103-Leuchte4TFL LB43-Dimming_Direction_EF_4,maximize ,16
ENG124865-ENG115107-Leuchte4TFL LB43-Dimming_Direction_GH_4,maximize ,16
ENG124865-ENG115102-Leuchte4TFL LB43-Dimming_EF_4,0 ,16
ENG124865-ENG115106-Leuchte4TFL LB43-Dimming_GH_4,0 ,16
ENG124865-ENG126579-Leuchte4TFL LB43-Fehlerort_mittleres_Byte_DTC-DFCC_4,75 ,16
ENG124865-ENG115808-Leuchte4TFL LB43-Lampendefektbit_Position_4,68 ,16
ENG124865-ENG115095-Leuchte4TFL LB43-Light_Control_HD_AB_4,Always ,16
ENG124865-ENG115092-Leuchte4TFL LB43-Light_Function_A_4,Daytime running lamps ,16
ENG124865-ENG115093-Leuchte4TFL LB43-Light_Function_B_4,not_activ ,16
ENG124865-ENG115096-Leuchte4TFL LB43-Light_Function_C_4,Position lamps ,16
ENG124865-ENG115097-Leuchte4TFL LB43-Light_Function_D_4,Parklichtrechts ,16
ENG124865-ENG115100-Leuchte4TFL LB43-Light_Function_E_4,not_activ ,16
ENG124865-ENG115101-Leuchte4TFL LB43-Light_Function_F_4,not_activ ,16
ENG124865-ENG115104-Leuchte4TFL LB43-Light_Function_G_4,not_activ ,16
ENG124865-ENG115105-Leuchte4TFL LB43-Light_Function_H_4,not_activ ,16
ENG124865-ENG115089-Leuchte4TFL LB43-Type_Of_Load_4,LEDTagfahrlichtmodulVersorgung ,16
ENG124866-ENG114977-Leuchte5 TFL RB6-Dimming_AB_5,127 ,16
ENG124866-ENG114981-Leuchte5 TFL RB6-Dimming_CD_5,127 ,16
ENG124866-ENG114982-Leuchte5 TFL RB6-Dimming_Direction_CD_5,maximize ,16
ENG124866-ENG114986-Leuchte5 TFL RB6-Dimming_Direction_EF_5,maximize ,16
ENG124866-ENG114990-Leuchte5 TFL RB6-Dimming_Direction_GH_5,maximize ,16
ENG124866-ENG114985-Leuchte5 TFL RB6-Dimming_EF_5,0 ,16
ENG124866-ENG114989-Leuchte5 TFL RB6-Dimming_GH_5,0 ,16
ENG124866-ENG126580-Leuchte5 TFL RB6-Fehlerort_mittleres_Byte_DTC-DFCC_5,73 ,16
ENG124866-ENG114974-Leuchte5 TFL RB6-Lampendefektbit_Position_5,58 ,16
ENG124866-ENG114978-Leuchte5 TFL RB6-Light_Control_HD_AB_5,Always ,16
ENG124866-ENG114975-Leuchte5 TFL RB6-Light_Function_A_5,Daytime running lamps ,16
ENG124866-ENG114976-Leuchte5 TFL RB6-Light_Function_B_5,not_activ ,16
ENG124866-ENG114979-Leuchte5 TFL RB6-Light_Function_C_5,Position lamps ,16
ENG124866-ENG114980-Leuchte5 TFL RB6-Light_Function_D_5,Parklichtlinks ,16
ENG124866-ENG114983-Leuchte5 TFL RB6-Light_Function_E_5,not_activ ,16
ENG124866-ENG114984-Leuchte5 TFL RB6-Light_Function_F_5,not_activ ,16
ENG124866-ENG114987-Leuchte5 TFL RB6-Light_Function_G_5,not_activ ,16
ENG124866-ENG114988-Leuchte5 TFL RB6-Light_Function_H_5,not_activ ,16
ENG124866-ENG114973-Leuchte5 TFL RB6-Type_Of_Load_5,LEDTagfahrlichtmodulVersorgung ,16
ENG124867-ENG115115-Leuchte6ABL LB44-Dimming_AB_6,127 ,16
ENG124867-ENG115119-Leuchte6ABL LB44-Dimming_CD_6,127 ,16
ENG124867-ENG115120-Leuchte6ABL LB44-Dimming_Direction_CD_6,maximize ,16
ENG124867-ENG115124-Leuchte6ABL LB44-Dimming_Direction_EF_6,maximize ,16
ENG124867-ENG115128-Leuchte6ABL LB44-Dimming_Direction_GH_6,maximize ,16
ENG124867-ENG115123-Leuchte6ABL LB44-Dimming_EF_6,0 ,16
ENG124867-ENG115127-Leuchte6ABL LB44-Dimming_GH_6,0 ,16
ENG124867-ENG126581-Leuchte6ABL LB44-Fehlerort_mittleres_Byte_DTC-DFCC_6,26 ,16
ENG124867-ENG115765-Leuchte6ABL LB44-Lampendefektbit_Position_6,54 ,16
ENG124867-ENG115116-Leuchte6ABL LB44-Light_Control_HD_AB_6,Always ,16
ENG124867-ENG115113-Leuchte6ABL LB44-Light_Function_A_6,Abblendlichtlinks ,16
ENG124867-ENG115114-Leuchte6ABL LB44-Light_Function_B_6,coming_home_leaving_home ,16
ENG124867-ENG115117-Leuchte6ABL LB44-Light_Function_C_6,Fernlichtlinks ,16
ENG124867-ENG115118-Leuchte6ABL LB44-Light_Function_D_6,Headlamp flasher ,16
ENG124867-ENG115121-Leuchte6ABL LB44-Light_Function_E_6,not_activ ,16
ENG124867-ENG115122-Leuchte6ABL LB44-Light_Function_F_6,not_activ ,16
ENG124867-ENG115125-Leuchte6ABL LB44-Light_Function_G_6,not_activ ,16
ENG124867-ENG115126-Leuchte6ABL LB44-Light_Function_H_6,not_activ ,16
ENG124867-ENG115110-Leuchte6ABL LB44-Type_Of_Load_6,LED_Abblendlicht ,16
ENG124868-ENG115134-Leuchte7ABL RB5-Dimming_AB_7,127 ,16
ENG124868-ENG115138-Leuchte7ABL RB5-Dimming_CD_7,127 ,16
ENG124868-ENG115139-Leuchte7ABL RB5-Dimming_Direction_CD_7,maximize ,16
ENG124868-ENG115143-Leuchte7ABL RB5-Dimming_Direction_EF_7,maximize ,16
ENG124868-ENG115147-Leuchte7ABL RB5-Dimming_Direction_GH_7,maximize ,16
ENG124868-ENG115142-Leuchte7ABL RB5-Dimming_EF_7,0 ,16
ENG124868-ENG115146-Leuchte7ABL RB5-Dimming_GH_7,0 ,16
ENG124868-ENG126582-Leuchte7ABL RB5-Fehlerort_mittleres_Byte_DTC-DFCC_7,27 ,16
ENG124868-ENG115807-Leuchte7ABL RB5-Lampendefektbit_Position_7,64 ,16
ENG124868-ENG115135-Leuchte7ABL RB5-Light_Control_HD_AB_7,Always ,16
ENG124868-ENG115132-Leuchte7ABL RB5-Light_Function_A_7,Abblendlichtrechts ,16
ENG124868-ENG115133-Leuchte7ABL RB5-Light_Function_B_7,coming_home_leaving_home ,16
ENG124868-ENG115136-Leuchte7ABL RB5-Light_Function_C_7,Fernlichtrechts ,16
ENG124868-ENG115137-Leuchte7ABL RB5-Light_Function_D_7,Headlamp flasher ,16
ENG124868-ENG115140-Leuchte7ABL RB5-Light_Function_E_7,not_activ ,16
ENG124868-ENG115141-Leuchte7ABL RB5-Light_Function_F_7,not_activ ,16
ENG124868-ENG115144-Leuchte7ABL RB5-Light_Function_G_7,not_activ ,16
ENG124868-ENG115145-Leuchte7ABL RB5-Light_Function_H_7,not_activ ,16
ENG124868-ENG115129-Leuchte7ABL RB5-Type_Of_Load_7,LED_Abblendlicht ,16
ENG124869-ENG115153-Leuchte8FL LB42-Dimming_AB_8,127 ,16
ENG124869-ENG115157-Leuchte8FL LB42-Dimming_CD_8,0 ,16
ENG124869-ENG115158-Leuchte8FL LB42-Dimming_Direction_CD_8,maximize ,16
ENG124869-ENG115162-Leuchte8FL LB42-Dimming_Direction_EF_8,maximize ,16
ENG124869-ENG115147-Leuchte8FL LB42-Dimming_Direction_GH_7,maximize ,16
ENG124869-ENG115161-Leuchte8FL LB42-Dimming_EF_8,0 ,16
ENG124869-ENG115165-Leuchte8FL LB42-Dimming_GH_8,0 ,16
ENG124869-ENG126583-Leuchte8FL LB42-Fehlerort_mittleres_Byte_DTC-DFCC_8,28 ,16
ENG124869-ENG115798-Leuchte8FL LB42-Lampendefektbit_Position_8,55 ,16
ENG124869-ENG115154-Leuchte8FL LB42-Light_Control_HD_AB_8,Always ,16
ENG124869-ENG115151-Leuchte8FL LB42-Light_Function_A_8,Fernlichtlinks ,16
ENG124869-ENG115152-Leuchte8FL LB42-Light_Function_B_8,Headlamp flasher ,16
ENG124869-ENG115155-Leuchte8FL LB42-Light_Function_C_8,not_activ ,16
ENG124869-ENG115156-Leuchte8FL LB42-Light_Function_D_8,not_activ ,16
ENG124869-ENG115159-Leuchte8FL LB42-Light_Function_E_8,not_activ ,16
ENG124869-ENG115160-Leuchte8FL LB42-Light_Function_F_8,not_activ ,16
ENG124869-ENG115163-Leuchte8FL LB42-Light_Function_G_8,not_activ ,16
ENG124869-ENG115164-Leuchte8FL LB42-Light_Function_H_8,not_activ ,16
ENG124869-ENG115148-Leuchte8FL LB42-Type_Of_Load_8,allgemeine_LED_12W ,16
ENG124870-ENG115172-Leuchte9FL RB7-Dimming_AB_9,127 ,16
ENG124870-ENG115176-Leuchte9FL RB7-Dimming_CD_9,0 ,16
ENG124870-ENG115177-Leuchte9FL RB7-Dimming_Direction_CD_9,maximize ,16
ENG124870-ENG115181-Leuchte9FL RB7-Dimming_Direction_EF_9,maximize ,16
ENG124870-ENG115185-Leuchte9FL RB7-Dimming_Direction_GH_9,maximize ,16
ENG124870-ENG115180-Leuchte9FL RB7-Dimming_EF_9,0 ,16
ENG124870-ENG115184-Leuchte9FL RB7-Dimming_GH_9,0 ,16
ENG124870-ENG126584-Leuchte9FL RB7-Fehlerort_mittleres_Byte_DTC-DFCC_9,29 ,16
ENG124870-ENG115804-Leuchte9FL RB7-Lampendefektbit_Position_9,65 ,16
ENG124870-ENG115173-Leuchte9FL RB7-Light_Control_HD_AB_9,Always ,16
ENG124870-ENG115170-Leuchte9FL RB7-Light_Function_A_9,Fernlichtrechts ,16
ENG124870-ENG115171-Leuchte9FL RB7-Light_Function_B_9,Headlamp flasher ,16
ENG124870-ENG115174-Leuchte9FL RB7-Light_Function_C_9,not_activ ,16
ENG124870-ENG115175-Leuchte9FL RB7-Light_Function_D_9,not_activ ,16
ENG124870-ENG115178-Leuchte9FL RB7-Light_Function_E_9,not_activ ,16
ENG124870-ENG115179-Leuchte9FL RB7-Light_Function_F_9,not_activ ,16
ENG124870-ENG115182-Leuchte9FL RB7-Light_Function_G_9,not_activ ,16
ENG124870-ENG115183-Leuchte9FL RB7-Light_Function_H_9,not_activ ,16
ENG124870-ENG115167-Leuchte9FL RB7-Type_Of_Load_9,allgemeine_LED_12W ,16
ENG124875-ENG115233-Leuchten14LOCKUNLOCKC61-Dimming_AB_14,100 ,16
ENG124875-ENG115237-Leuchten14LOCKUNLOCKC61-Dimming_CD_14,0 ,16
ENG124875-ENG115238-Leuchten14LOCKUNLOCKC61-Dimming_Direction_CD_14,maximize ,16
ENG124875-ENG115242-Leuchten14LOCKUNLOCKC61-Dimming_Direction_EF_14,maximize ,16
ENG124875-ENG115246-Leuchten14LOCKUNLOCKC61-Dimming_Direction_GH_14,maximize ,16
ENG124875-ENG115241-Leuchten14LOCKUNLOCKC61-Dimming_EF_14,0 ,16
ENG124875-ENG115245-Leuchten14LOCKUNLOCKC61-Dimming_GH_14,0 ,16
ENG124875-ENG126589-Leuchten14LOCKUNLOCKC61-Fehlerort_mittleres_Byte_DTC-DFCC_14,0 ,16
ENG124875-ENG115786-Leuchten14LOCKUNLOCKC61-Lampendefektbit_Position_14,0 ,16
ENG124875-ENG115234-Leuchten14LOCKUNLOCKC61-Light_Control_HD_AB_14,Always ,16
ENG124875-ENG115231-Leuchten14LOCKUNLOCKC61-Light_Function_A_14,Lock_Unlock_LED ,16
ENG124875-ENG115232-Leuchten14LOCKUNLOCKC61-Light_Function_B_14,not_activ ,16
ENG124875-ENG115235-Leuchten14LOCKUNLOCKC61-Light_Function_C_14,not_activ ,16
ENG124875-ENG115236-Leuchten14LOCKUNLOCKC61-Light_Function_D_14,not_activ ,16
ENG124875-ENG115239-Leuchten14LOCKUNLOCKC61-Light_Function_E_14,not_activ ,16
ENG124875-ENG115240-Leuchten14LOCKUNLOCKC61-Light_Function_F_14,not_activ ,16
ENG124875-ENG115243-Leuchten14LOCKUNLOCKC61-Light_Function_G_14,not_activ ,16
ENG124875-ENG115244-Leuchten14LOCKUNLOCKC61-Light_Function_H_14,not_activ ,16
ENG124875-ENG115228-Leuchten14LOCKUNLOCKC61-Type_Of_Load_14,LED_Kleinleistung_ohne_OL_mitUeberspg_absch ,16
ENG148593-Leuchtenkonfiguration (Aussenlicht Heck),0C 08 00 16 02 00 64 00 00 00 00 00 00 00 00 00 0C 18 00 18 04 00 64 00 00 00 00 00 00 00 00 00 22 09 00 39 18 00 7F 00 00 00 00 00 00 00 00 00 22 19 00 3A 18 00 7F 00 00 00 00 00 00 00 00 00 2A 29 00 2C 18 00 64 00 00 00 00 00 00 00 00 00 20 0A 00 29 08 09 1E 00 00 00 00 00 00 00 00 00 20 1A 00 2A 08 0A 1E 00 00 00 00 00 00 00 00 00 2D 28 00 30 08 00 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1A 2B 00 34 19 00 E4 00 00 00 00 00 00 00 00 00 ,160
ENG148594-Leuchtenkonfiguration (Sonstiges),24 00 00 00 3E 00 64 00 00 00 00 00 00 00 00 00 24 00 00 00 3F 00 64 00 00 00 00 00 00 00 00 00 24 00 00 00 40 00 64 00 00 00 00 00 00 00 00 00 21 39 00 17 02 00 64 00 00 00 00 00 00 00 00 00 21 43 00 19 04 00 64 00 00 00 00 00 00 00 00 00 24 00 00 08 26 00 64 00 00 00 00 00 00 00 00 00 08 00 00 01 25 00 64 00 00 00 00 00 00 00 00 00 08 00 00 07 29 00 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 24 00 00 04 2D 00 64 00 00 00 00 00 00 00 00 00 2D 1A 00 2A 08 0A 7F 00 00 00 00 00 00 00 00 00 2D 0A 00 29 08 09 7F 00 00 00 00 00 00 00 00 00 ,192
ENG126648-MAS02526-LIN-Mirrormode-Activation,not active ,1
ENG126648-ENG149044-LIN-Mirrormode-LIN4,not active ,1
ENG126648-ENG149045-LIN-Mirrormode-LIN5,not active ,1
ENG148592-ENG115658-LuB_Lichtrouter_Kennlinie_1-x0,0.0 %,12
ENG148592-ENG101574-LuB_Lichtrouter_Kennlinie_1-X1,5.0 %,12
ENG148592-ENG99557-LuB_Lichtrouter_Kennlinie_1-X2,50.0 %,12
ENG148592-ENG102140-LuB_Lichtrouter_Kennlinie_1-X3,75.0 %,12
ENG148592-ENG102936-LuB_Lichtrouter_Kennlinie_1-X4,110.0 %,12
ENG148592-ENG103548-LuB_Lichtrouter_Kennlinie_1-X5,126.5 %,12
ENG148592-ENG115659-LuB_Lichtrouter_Kennlinie_1-y0,0.0 %,12
ENG148592-ENG99777-LuB_Lichtrouter_Kennlinie_1-Y1,6.0 %,12
ENG148592-ENG100480-LuB_Lichtrouter_Kennlinie_1-Y2,16.0 %,12
ENG148592-ENG100773-LuB_Lichtrouter_Kennlinie_1-Y3,30.0 %,12
ENG148592-ENG100631-LuB_Lichtrouter_Kennlinie_1-Y4,60.0 %,12
ENG148592-ENG102174-LuB_Lichtrouter_Kennlinie_1-Y5,100.0 %,12
ENG122979-MAS00075-Networking-ABS Control Module,installed ,8
ENG122979-MAS00798-Networking-Transmission Control Module (TCM),installed ,8
ENG122979-MAS01374-Networking-Trailer,not installed ,8
ENG122979-MAS03175-Networking-Extended data bus,not installed ,8
ENG122979-MAS09880-Networking-Interval potentiometer,installed ,8
ENG122979-MAS09882-Networking-MFA button on BCM,not installed ,8
ENG122979-MAS10518-Networking-A/C electronics,installed ,8
ENG122979-MAS10570-Networking-Window lift type,MQB_window_regulator ,8
ENG122979-ENG149007-Networking-Door LIN,installed ,8
ENG122979-ENG252084-Networking-KL30_weckfaehig,wakable ,8
ENG122979-ENG149008-Networking-Roof LIN,installed ,8
ENG122979-ENG149009-Networking-Sounder LIN,not installed ,8
ENG122979-ENG149010-Networking-Wiper LIN,not installed ,8
ENG124714-ENG179221-OCU-Remote Lock Unlock Timer s0,15 s,8
ENG124714-ENG179222-OCU-Remote Lock Unlock Timer s2,0 s,8
ENG124714-ENG179223-OCU-Remote Lock Unlock Timer s4,15 s,8
ENG124714-ENG154722-OCU-RHF_Panikalarm,not active ,8
ENG117304-ENG148862-Patch_Code_Driver_Side_Rear-Parameter_1,Conditions not correct or request sequence error,8
ENG117304-ENG148865-Patch_Code_Driver_Side_Rear-Parameter_2,Conditions not correct or request sequence error,8
ENG148615-ENG148862-Patch_code_passenger-Parameter_1,Conditions not correct or request sequence error,8
ENG148615-ENG148865-Patch_code_passenger-Parameter_2,Conditions not correct or request sequence error,8
ENG117308-ENG148862-Patch_Code_Passenger_Side_Rear-Parameter_1,Conditions not correct or request sequence error,8
ENG117308-ENG148865-Patch_Code_Passenger_Side_Rear-Parameter_2,Conditions not correct or request sequence error,8
ENG141646-MAS00481-Querschnitts_funktionen-BAP,active ,5
ENG141646-MAS01065-Querschnitts_funktionen-Brand,VW ,5
ENG141646-MAS04194-Querschnitts_funktionen-Driver side,Right ,5
ENG141646-MAS10509-Querschnitts_funktionen-Traffic,Left ,5
ENG141646-MAS10511-Querschnitts_funktionen-Personalization transfer,installed ,5
ENG141646-MAS10527-Querschnitts_funktionen-Tracking System,not active ,5
ENG141646-ENG252090-Querschnitts_funktionen-anhaengerrangierassistent,not active ,5
ENG141646-ENG149084-Querschnitts_funktionen-CAN_Wecken_bei_Softtouchbetaetigung,active ,5
ENG141646-ENG154685-Querschnitts_funktionen-Hupe,Keine_Spannungsanforderung ,5
ENG141646-ENG149085-Querschnitts_funktionen-Klemmenfehler_auf_CAN_ausgeben,active ,5
ENG141646-ENG126575-Querschnitts_funktionen-mute_mode_aktiv,not active ,5
ENG141646-ENG148952-Querschnitts_funktionen-P_locked,installed ,5
ENG141646-ENG125011-Querschnitts_funktionen-pa_Funktion_2aus3,installed ,5
ENG117299-Reversing_Threshold_Driver_Side_Rear,Conditions not correct or request sequence error,1
ENG117298-Reversing_Threshold_Passenger_Side_Front,Conditions not correct or request sequence error,1
ENG117300-Reversing_Threshold_Passenger_Side_Rear,Conditions not correct or request sequence error,1
ENG179054-ENG179160-RLFS_ZF_TRW-p_n_1st_wipe_threshold,100 %,12
ENG179054-ENG179161-RLFS_ZF_TRW-p_n_highspeed_wipe_threshold,100 %,12
ENG179054-ENG179162-RLFS_ZF_TRW-p_n_interval_wipe_threshold,100 %,12
ENG179054-ENG179163-RLFS_ZF_TRW-p_n_LIN_Filter,3 ,12
ENG179054-ENG179164-RLFS_ZF_TRW-p_n_permanent_wipe_threshold,100 %,12
ENG179054-ENG179165-RLFS_ZF_TRW-p_n_RsEmergencyReducePercent,10 %,12
ENG179054-ENG179166-RLFS_ZF_TRW-p_t_ParkPosition_SpeedReset,1300 ms,12
ENG179054-ENG179167-RLFS_ZF_TRW-p_t_ParkPosition_WipeTimeout,1000 ms,12
ENG179054-ENG263513-RLFS_ZF_TRW-p_t_RsEmergencyReduce_Cycle,2.0 s,12
ENG179054-ENG263511-RLFS_ZF_TRW-p_t_RsEmergencyReduce_Delay,4.0 s,12
ENG179054-ENG179170-RLFS_ZF_TRW-p_t_tunnel_wipe_delay,6 s,12
ENG179054-ENG179171-RLFS_ZF_TRW-p_t_tunnel_wipe_window,15 s,12
ENG179054-ENG179172-RLFS_ZF_TRW-pa_lx_tunnel_light_on,1100 ,12
ENG179054-ENG179173-RLFS_ZF_TRW-pa_n_wisch_max_2,2 ,12
ENG179054-ENG179174-RLFS_ZF_TRW-pa_t_tunnel_delay_decrement,30 s,12
ENG179054-ENG179175-RLFS_ZF_TRW-pa_t_tunnel_delay_max,120 s,12
ENG179054-ENG179176-RLFS_ZF_TRW-Pa_t_tunnel_delay_on,1800 ms,12
ENG179054-ENG179177-RLFS_ZF_TRW-pa_t_tunnel_delay_step,5 s,12
ENG179054-ENG179178-RLFS_ZF_TRW-pa_v_RsActivationSpeed,5 km/h,12
ENG179054-ENG179179-RLFS_ZF_TRW-pa_v_wisch_max_1,20 km/h,12
ENG179054-ENG179180-RLFS_ZF_TRW-pa_v_wisch_max_2,4 km/h,12
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn,200 lx,1
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day,500 lx,1
ENG115729-IDE05534-Scheinwerferreinigung-Headlamp washer system,not installed ,10
ENG115729-ENG149254-Scheinwerferreinigung-Adaptives_Nachwischen_bei_SRA,not active ,10
ENG115729-ENG149255-Scheinwerferreinigung-Anzahl_Betaetigungen_Frontwaschanlage_pro_SRA_Aktivierung,10 ,10
ENG115729-ENG149253-Scheinwerferreinigung-SRA_bei_Waschwassermangel,not active ,10
ENG115729-ENG149258-Scheinwerferreinigung-SRA_Einweichpausenzeit,0 ms,10
ENG115729-ENG149259-Scheinwerferreinigung-SRA_Nachwaschzeit,0 ms,10
ENG115729-ENG149260-Scheinwerferreinigung-SRA_Pausenzeit,0 ms,10
ENG115729-ENG149256-Scheinwerferreinigung-SRA_Verzoegerungszeit,0 ms,10
ENG115729-ENG149257-Scheinwerferreinigung-SRA_Waschzeit,0 ms,10
ENG115729-ENG148897-Scheinwerferreinigung-windshield_washer_system,not installed ,10
ENG116588-MAS10520-Sonderfunktionen-Special function 1,not installed ,4
ENG116588-ENG273845-Sonderfunktionen-Blinkerueberwachung_MFG,not installed ,4
ENG116588-ENG130186-Sonderfunktionen-Signalprioritaet_fuer_Blinker,SMLS ,4
ENG116588-ENG126568-Sonderfunktionen-Sonderfunktionen_2,not enabled ,4
ENG141635-ENG149220-Spiegelverstellung-Funk_Spiegelanklappen,active ,5
ENG141635-ENG149221-Spiegelverstellung-Funk_Spiegelanklappung_Modus,by_look_command_via_remote_control_key ,5
ENG141635-ENG149219-Spiegelverstellung-Menue__Spiegel_absenkung,not active ,5
ENG141635-ENG149222-Spiegelverstellung-Menuesteuerung_Funk_Spiegel_anklappen,active ,5
ENG141635-ENG149043-Spiegelverstellung-only_ECU_FHSG_Driver_side,installed ,5
ENG141635-ENG149223-Spiegelverstellung-Profilfunktion_fuer_Anklappung_der_Aussenspiegel,not active ,5
ENG141635-ENG155908-Spiegelverstellung-Spiegel_ausklappen_ueber_FFB_auf,active ,5
ENG141635-ENG149218-Spiegelverstellung-Spiegelabsenkung_bei_Rueckwaertsfahrt,not active ,5
ENG141635-ENG149224-Spiegelverstellung-Spiegelanklappung_geschwindigkeitsabhaengig,active ,5
ENG141635-ENG149041-Spiegelverstellung-window_regulator_node_adress,getauscht ,5
ENG153969-ENG115658-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-x0,0.0 lx,10
ENG153969-ENG101574-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-X1,8.0 lx,10
ENG153969-ENG99557-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-X2,50.0 lx,10
ENG153969-ENG102140-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-X3,80.0 lx,10
ENG153969-ENG102936-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-X4,100.0 lx,10
ENG153969-ENG115659-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-y0,6.0 ,10
ENG153969-ENG99777-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-Y1,6.0 ,10
ENG153969-ENG100480-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-Y2,20.0 ,10
ENG153969-ENG100773-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-Y3,50.0 ,10
ENG153969-ENG100631-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-Y4,100.0 ,10
ENG153971-ENG115658-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-x0,0.0 lx,10
ENG153971-ENG101574-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-X1,8.0 lx,10
ENG153971-ENG99557-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-X2,50.0 lx,10
ENG153971-ENG102140-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-X3,80.0 lx,10
ENG153971-ENG102936-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-X4,100.0 lx,10
ENG153971-ENG115659-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-y0,6.0 ,10
ENG153971-ENG99777-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-Y1,6.0 ,10
ENG153971-ENG100480-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-Y2,20.0 ,10
ENG153971-ENG100773-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-Y3,50.0 ,10
ENG153971-ENG100631-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-Y4,100.0 ,10
ENG141632-MAS10512-Sunroof-Sunroof module MD1,not installed ,4
ENG141632-MAS10513-Sunroof-Sunroof module MD shade,not installed ,4
ENG141632-ENG149217-Sunroof-SAD_Komfort_oeffnen,not active ,4
ENG141632-ENG149216-Sunroof-SAD_Komfort_schliessen,not active ,4
ENG141632-ENG149215-Sunroof-SAD_Richtung_Komfortoeffnen,Open ,4
ENG248473-ENG261749-Türen HBFS-pa_NFZ_Funktion_HBFS_1,not active ,2
ENG248473-ENG248779-Türen HBFS-pa_Schiebetür_HBFS,No ,2
ENG248473-ENG248781-Türen HBFS-pa_schlosstyp_HBFS,No ,2
ENG248473-ENG248785-Türen HBFS-pa_tuerkontaktmodul_hbfs,ohne TKM ,2
ENG248474-ENG261743-Türen HFS-pa_NFZ_Funktion_HFS_1,not active ,2
ENG248474-ENG248780-Türen HFS-pa_Schiebetür_HFS,No ,2
ENG248474-ENG248783-Türen HFS-pa_schlosstyp_HFS,No ,2
ENG248474-ENG248786-Türen HFS-pa_tuerkontaktmodul_hfs,ohne TKM ,2
ENG148611-MAS10548-Verbau Personalisierung-Profile function,no key profile ,8
ENG148611-ENG252096-Verbau Personalisierung-Aktiver_Teilnehmer_Doorlocking_aktiviert,not active ,8
ENG148611-ENG252051-Verbau Personalisierung-Aktiver_Teilnehmer_ExteriorLight_aktiviert,not active ,8
ENG148611-ENG252071-Verbau Personalisierung-Aktiver_Teilnehmer_InteriorLight_aktiviert,not active ,8
ENG148611-ENG252085-Verbau Personalisierung-Aktiver_Teilnehmer_Mirror_aktiviert,not active ,8
ENG148611-ENG252072-Verbau Personalisierung-Aktiver_Teilnehmer_WiperComfort_aktiviert,not active ,8
ENG148611-ENG126849-Verbau Personalisierung-Aktivierungsoption_im_HMI-Menue_sichtbar,not active ,8
ENG148611-ENG133401-Verbau Personalisierung-Anzahl_Benutzerkonten,1 ,8
ENG148611-ENG133402-Verbau Personalisierung-Automatische_ Schluesselzuordnung,not active ,8
ENG148611-ENG126850-Verbau Personalisierung-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar,not active ,8
ENG148611-ENG246970-Verbau Personalisierung-IAA -Nutzer_management,not installed ,8
ENG148611-ENG246991-Verbau Personalisierung-pa_Two_Keys,not active ,8
ENG148611-ENG126848-Verbau Personalisierung-Personalisierung_aktiv,not active ,8
ENG148611-ENG126851-Verbau Personalisierung-Personalisierungsfunktionen_in_HMI-Menue_sichtbar,not active ,8
ENG148611-ENG142030-Verbau Personalisierung-Profil_Variante,Schluessel ,8
ENG148611-ENG133403-Verbau Personalisierung-PSO_FSG_Setup2_Bit_0,not active ,8
ENG148611-ENG133404-Verbau Personalisierung-PSO_FSG_Setup2_Bit_1,not active ,8
ENG148611-ENG133405-Verbau Personalisierung-PSO_FSG_Setup2_Bit_2,not active ,8
ENG148611-ENG133406-Verbau Personalisierung-PSO_FSG_Setup2_Bit_3,not active ,8
ENG148611-ENG133407-Verbau Personalisierung-PSO_FSG_Setup2_Bit_4,not active ,8
ENG148611-ENG133408-Verbau Personalisierung-PSO_FSG_Setup2_Bit_5,not active ,8
ENG148611-ENG133409-Verbau Personalisierung-PSO_FSG_Setup2_Bit_6,not active ,8
ENG148611-ENG133410-Verbau Personalisierung-PSO_FSG_Setup2_Bit_7,not active ,8
ENG148610-ENG148877-Vernetzungs-_Diagnosefunktionen-can_msg_1,00 00 ,20
ENG148610-ENG148878-Vernetzungs-_Diagnosefunktionen-can_msg_2,00 00 ,20
ENG148610-ENG148879-Vernetzungs-_Diagnosefunktionen-can_msg_3,00 00 ,20
ENG148610-ENG148880-Vernetzungs-_Diagnosefunktionen-can_msg_4,00 00 ,20
ENG148610-ENG148881-Vernetzungs-_Diagnosefunktionen-lin_msg_1,00 00 ,20
ENG148610-ENG148882-Vernetzungs-_Diagnosefunktionen-lin_msg_2,00 00 ,20
ENG148610-ENG148883-Vernetzungs-_Diagnosefunktionen-lin_msg_3,00 00 ,20
ENG148610-ENG148884-Vernetzungs-_Diagnosefunktionen-lin_msg_4,00 00 ,20
ENG148610-ENG148885-Vernetzungs-_Diagnosefunktionen-lin_msg_5,00 00 ,20
ENG148610-ENG148886-Vernetzungs-_Diagnosefunktionen-lin_msg_6,00 00 ,20
ENG148612-ENG148862-Window_Regulator_Supplier_Settings_Driver_Side_1-Parameter_1,0A 14 04 07 0A 0B 03 E8 03 E8 09 C4 09 C4 07 D0 05 DC 05 DC 05 DC 05 DC 05 DC 0C 00 32 01 2C 32 41 00 1E 04 0A 00 0A 00 0A 02 05 0F 04 82 82 14 04 04 32 32 1E 03 3C 28 05 3C C8 50 DC 14 42 68 03 E8 03 64 05 01 5E 1E 0A 32 1E 00 64 32 64 02 58 00 7D 14 02 5A 0A 01 A4 01 54 1B 0A 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 56 00 2E 03 ,128
ENG148612-ENG148865-Window_Regulator_Supplier_Settings_Driver_Side_1-Parameter_2,07 EA ,128
ENG148613-ENG148862-Window_Regulator_Supplier_Settings_Driver_Side_2-Parameter_1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 56 00 2E 00 ,128
ENG148613-ENG148865-Window_Regulator_Supplier_Settings_Driver_Side_2-Parameter_2,ED 56 ,128
ENG130135-ENG148862-Window_Regulator_Supplier_Settings_Driver_Side_3-Parameter_1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 56 00 2E 00 ,128
ENG130135-ENG148865-Window_Regulator_Supplier_Settings_Driver_Side_3-Parameter_2,ED 56 ,128
ENG117302-ENG148862-Window_Regulator_Supplier_Settings_Driver_Side_Rear_1-Parameter_1,Conditions not correct or request sequence error,128
ENG117302-ENG148865-Window_Regulator_Supplier_Settings_Driver_Side_Rear_1-Parameter_2,Conditions not correct or request sequence error,128
ENG117303-ENG148862-Window_Regulator_Supplier_Settings_Driver_Side_Rear_2-Parameter_1,Conditions not correct or request sequence error,128
ENG117303-ENG148865-Window_Regulator_Supplier_Settings_Driver_Side_Rear_2-Parameter_2,Conditions not correct or request sequence error,128
ENG130138-ENG148862-Window_Regulator_Supplier_Settings_Passener_Side_1-Parameter_1,Conditions not correct or request sequence error,128
ENG130138-ENG148865-Window_Regulator_Supplier_Settings_Passener_Side_1-Parameter_2,Conditions not correct or request sequence error,128
ENG130139-ENG148862-Window_Regulator_Supplier_Settings_Passener_Side_2-Parameter_1,Conditions not correct or request sequence error,128
ENG130139-ENG148865-Window_Regulator_Supplier_Settings_Passener_Side_2-Parameter_2,Conditions not correct or request sequence error,128
ENG130140-ENG148862-Window_Regulator_Supplier_Settings_Passener_Side_3-Parameter_1,Conditions not correct or request sequence error,128
ENG130140-ENG148865-Window_Regulator_Supplier_Settings_Passener_Side_3-Parameter_2,Conditions not correct or request sequence error,128
ENG117306-ENG148862-Window_Regulator_Supplier_Settings_Passenger_Side_Rear_1-Parameter_1,Conditions not correct or request sequence error,128
ENG117306-ENG148865-Window_Regulator_Supplier_Settings_Passenger_Side_Rear_1-Parameter_2,Conditions not correct or request sequence error,128
ENG117307-ENG148862-Window_Regulator_Supplier_Settings_Passenger_Side_Rear_2-Parameter_1,Conditions not correct or request sequence error,128
ENG117307-ENG148865-Window_Regulator_Supplier_Settings_Passenger_Side_Rear_2-Parameter_2,Conditions not correct or request sequence error,128
ENG130142-ENG148862-Window_Regulator_Supplier_Settings_Passenger_Side_Rear_3-Parameter_1,Conditions not correct or request sequence error,128
ENG130142-ENG148865-Window_Regulator_Supplier_Settings_Passenger_Side_Rear_3-Parameter_2,Conditions not correct or request sequence error,128
ENG124895-Window_Regulator_VW_Settings_Driver_Side,0A 0A 00 0A 00 0A 32 19 0F 01 A3 14 00 14 32 0A 32 32 03 FF 01 04 01 18 00 C8 01 18 01 02 0A 01 00 00 00 00 00 00 00 00 00 00 00 37 0F 0F 14 14 C8 C6 0B 05 02 1E B4 AA 02 64 4B B4 55 AA 0A 02 64 64 05 00 0F 0A 1E 0F 01 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 41 B4 06 0A 00 52 1B 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 56 00 2E 03 00 36 7A ,128
ENG117301-Window_Regulator_VW_Settings_Driver_Side_Rear,Conditions not correct or request sequence error,128
ENG130137-Window_Regulator_VW_Settings_Passenger_Side,Conditions not correct or request sequence error,128
ENG117305-Window_Regulator_VW_Settings_Passenger_Side_Rear,Conditions not correct or request sequence error,128
ENG148493-ENG115721-Windshield wiper-Frontwischer,Keine_Spannungsanforderung ,6
ENG148493-ENG133394-Windshield wiper-Frontwischer_Abtauposition,keine_Abtaupostition ,6
ENG148493-ENG149235-Windshield wiper-Frontwischer_Referenzlauf,active ,6
ENG148493-ENG126573-Windshield wiper-Frontwischer_Serviceposition,active ,6
ENG148493-ENG149241-Windshield wiper-Geschwindigkeitsabhaengige_Wischstufenrueckschaltung,active ,6
ENG148493-ENG149239-Windshield wiper-Menuesteuerung_Frontwischer,not active ,6
ENG148493-ENG154706-Windshield wiper-Mindestwaschzeit_Frontwischer,0 ms,6
ENG148493-ENG149042-Windshield wiper-rain_sensor_function,installed ,6
ENG148493-ENG149238-Windshield wiper-Regensensor_aktivieren,active ,6
ENG148493-ENG149242-Windshield wiper-Traenenwischen_Front_Status,not active ,6
ENG148493-ENG126844-Windshield wiper-Washer_Tipwiping_Variant,active ,6
ENG148493-ENG148995-Windshield wiper-windshield_wiper_typ,Direct ,6
ENG148493-ENG149237-Windshield wiper-Wischer_abparken_bei_Oeffnen_der_Motorhaube,not active ,6
ENG148493-ENG149236-Windshield wiper-Wischer_stop_bei_KL15_aus,not active ,6
ENG148493-ENG149244-Windshield wiper-Wischer_stop_bei_Motorstart,nur_Erststart ,6
ENG148493-ENG149243-Windshield wiper-Wischer_Stopp_bei_Oeffnen_der_Motorhaube,active ,6
ENG141651-MAS10522-ZV allgemein-Lock/unlock: direct button,Rocker sw. ,5
ENG141651-MAS10546-ZV allgemein-Radio freq.,434.42MHz ,5
ENG141651-MAS10554-ZV allgemein-Central locking without SAFE function,installed ,5
ENG141651-ENG179102-ZV allgemein-Abgesichertes Safen,not active ,5
ENG141651-ENG252045-ZV allgemein-Anti_theft_alarm_diagnostic_connection_monitoring,not active ,5
ENG141651-ENG248507-ZV allgemein-Auswertung_Batt_TranspID_Telegramm,not active ,5
ENG141651-ENG179106-ZV allgemein-Autolock_nur_bei_Motorlauf,not active ,5
ENG141651-ENG125653-ZV allgemein-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster,not active ,5
ENG141651-ENG252065-ZV allgemein-FFB_Sbt_Entriegelt,No ,5
ENG141651-ENG149179-ZV allgemein-Funk_bei_Klemme_15_ein,not active ,5
ENG141651-ENG179144-ZV allgemein-Kessy Wiederentriegelung mit Außenhaut,not active ,5
ENG141651-ENG149181-ZV allgemein-Menuesteuerung_Tuerentriegelung,active ,5
ENG141651-ENG115755-ZV allgemein-Notschließfunktion,active ,5
ENG141651-ENG179092-ZV allgemein-Schlossansteuerung,all_doors_connected_directly ,5
ENG141651-ENG149384-ZV allgemein-seitenselektive_Oeffnung,Yes ,5
ENG141651-ENG149180-ZV allgemein-ZV_Tuerentriegelung,Globale_Entriegelung ,5
ENG141654-ENG149213-ZV Autolock-Autolock_Autounlock_wirkt_auf_Heck,active ,5
ENG141654-ENG149211-ZV Autolock-automatisches_Entriegeln,active ,5
ENG141654-ENG149210-ZV Autolock-Automatisches_Verriegeln_bei_Geschwindigkeit,active ,5
ENG141654-ENG149212-ZV Autolock-Autounlock_NAR,not active ,5
ENG141654-ENG149214-ZV Autolock-Menuesteuerung_ZV_Autolock-Unlock,adjustable ,5
ENG141655-ENG149225-ZV Crash-Heckdeckel-Bedienstellen_nachCrash_temporaer_sperren,not active ,4
ENG141655-ENG149227-ZV Crash-SAD_PreCrash_Konturschliessen,not active ,4
ENG141655-ENG149226-ZV Crash-ZV-Entriegelung_nach_Seitencrash,active ,4
ENG141653-MAS07515-ZV Heck-Trunk lid remote unlocking: int. button,not installed ,5
ENG141653-MAS10551-ZV Heck-Rear lid lock control,Pulse control ,5
ENG141653-MAS10555-ZV Heck-Central locking: rear lock type,1 or 2 notch rear actuator ,5
ENG141653-MAS10561-ZV Heck-Rear lock with safety catch,No ,5
ENG141653-ENG149183-ZV Heck-Direkter_Auswurf_des_Heckdeckels,not active ,5
ENG141653-ENG126839-ZV Heck-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang,not active ,5
ENG141653-ENG149185-ZV Heck-Freigabenachlauf_Heck_nach_Einzeloeffnung_ueber_HDF-Funktaster,not active ,5
ENG141653-ENG149187-ZV Heck-Hecksteuerung_ohne_ZV,not active ,5
ENG141653-ENG137162-ZV Heck-Mindestbetaetigung_HDF_Innentaster,0.0 s,5
ENG141653-ENG261746-ZV Heck-Rear_lock_control_min_aktiv,not active ,5
ENG141653-ENG126630-ZV Heck-Reichweitenbegrenzung fuer Servoheck schliessen,not active ,5
ENG141653-ENG155905-ZV Heck-Softtouch_Auswertung,digitale_Logik ,5
ENG141653-ENG252095-ZV Heck-Zentralverrieglung_ohne_Heckdeckel,not active ,5
ENG141653-ENG149182-ZV Heck-ZV_entriegelt_auch_Heckdeckel,active ,5
ENG141653-ENG149184-ZV Heck-ZV_Heck_nur_direkt_auswerfen,not active ,5
ENG148616-IDE02021-ZV Komfort (Fensterheber)-Comfort closing,not active ,7
ENG148616-IDE02022-ZV Komfort (Fensterheber)-Comfort opening,not active ,7
ENG148616-MAS10525-ZV Komfort (Fensterheber)-Electrical window lift: front,active ,7
ENG148616-MAS10526-ZV Komfort (Fensterheber)-Electrical window left: rear,Yes ,7
ENG148616-ENG154964-ZV Komfort (Fensterheber)-BAP_Komfortschließen,not active ,7
ENG148616-ENG248524-ZV Komfort (Fensterheber)-Busruhe_bei_Fensterheberfreigabenachlauf,active ,7
ENG148616-ENG149202-ZV Komfort (Fensterheber)-Fahrertuerbedienung_Fensterheber_oeffnen,not active ,7
ENG148616-ENG149206-ZV Komfort (Fensterheber)-Fahrertuerbedienung_Fensterheber_schliessen,not active ,7
ENG148616-ENG149203-ZV Komfort (Fensterheber)-FH_SAD_Kl15Aus_Freigabezeit,600 s,7
ENG148616-ENG149196-ZV Komfort (Fensterheber)-Freigabenachlauf_FH_bei_Kl_15_aus,active ,7
ENG148616-ENG149197-ZV Komfort (Fensterheber)-Freigabenachlauf_FH_bei_Tueroeffnen,active ,7
ENG148616-ENG149201-ZV Komfort (Fensterheber)-Funk_Komfort_oeffnen,not active ,7
ENG148616-ENG149205-ZV Komfort (Fensterheber)-Funk_Komfort_schliessen,not active ,7
ENG148616-ENG155240-ZV Komfort (Fensterheber)-Kindersicherung_Beifahrerfenster,not active ,7
ENG148616-ENG149198-ZV Komfort (Fensterheber)-Komfortbedienung_global,active ,7
ENG148616-ENG149199-ZV Komfort (Fensterheber)-Komfortoeffnen_nur_FH_Fahrertuer,not active ,7
ENG148616-ENG155244-ZV Komfort (Fensterheber)-Komfortschliessen_Brasilien,not active ,7
ENG148616-ENG149209-ZV Komfort (Fensterheber)-Manuelle_ZV_Variantenprogrammierung,not active ,7
ENG148616-ENG149207-ZV Komfort (Fensterheber)-Menuesteuerung_Komfortbedienung_einstellbar,not active ,7
ENG148616-ENG149200-ZV Komfort (Fensterheber)-Schliesszylinder_Komfort_oeffnen,not active ,7
ENG148616-ENG149204-ZV Komfort (Fensterheber)-Schliesszylinder_Komfort_schliessen,not active ,7
ENG141652-MAS01914-ZV Türkonfiguration-Type of lock,1 Motor locks without Safe (NAR locks) ,5
ENG141652-MAS06443-ZV Türkonfiguration-Lock cylinder passenger door,not installed ,5
ENG141652-MAS10567-ZV Türkonfiguration-Four-door,Yes ,5
ENG141652-ENG273805-ZV Türkonfiguration-schliesszylinderlogik_lbs,active ,5
Elapsed Time: 01:31
