Audi q5 2010
PAUL60
Grenada
C?ID=600289
hi am new can i get some assistance with coding my used ABS module
the original got damaged it an accident
Wednesday,27,November,2024,18:01:10:38087
VIN: WA1LKAFP3AA028883   License Plate:
Chassis Type: FP-AU48 (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 36 42 46 47 52 53 55 56 5F
          62 6C 6D 72
VIN: WA1LKAFP3AA028883   Mileage: 130750km-81244miles
04-Steering Angle -- Status: Sporadic communication error 1000
17-Instruments -- Status: Sporadic communication error 1000
6C-Back-up Cam. -- Status: Sporadic communication error 1000
Address 01: Engine (J623-CALB)       Labels:| 06E-907-559-CAL.clb
   Part No SW: 8R0 907 559 G    HW: 8F0 907 559 A
   Component: 3.2 SIMOS8.2  H06 0004
   Revision: --------    CVN: 6030C727
   Coding: 0121000A190F0121
   Shop #: WSC 06335 000 00000
   ASAM Dataset: EV_ECM32FSI0218R0907559G 001004
   ROD: EV_ECM32FSI0218R0907559G.rod
   VCID: 44D694A66E12935A3B3-8010
   VINID: 9D105C6D15A00D14400882080CE72AA0BD
8 Faults Found:
7117 - Cylinder 3
          P0303 00 [11101101] - Misfire Detected
                    Mileage: 130753 km
                    Date: 2024.11.27
                    Time: 13:16:43
                    Engine RPM: 687.00 /min
                    Normed load value: 30.6 %
                    Coolant temperature: 91 °C
                    Intake air temperature: 62 °C
                    Ambient air pressure: 950 mbar
                    Voltage terminal 30: 13.710 V
                    Engine speed: actual: 672 /min
                    MAF_ENVD: 125.28235 mg/stroke
                    Coolant temperature (unfiltered): 92.3 °C
                    Engine: operating status: IS
                    T_AST_ENVD: 0.00 s
                    Vehicle speed: actual: 0 km/h
7115 - Cylinder 2
          P0302 00 [01100101] - Misfire Detected
                    Mileage: 130753 km
                    Date: 2024.11.27
                    Time: 16:33:12
                    Engine RPM: 739.00 /min
                    Normed load value: 22.4 %
                    Coolant temperature: 45 °C
                    Intake air temperature: 50 °C
                    Voltage terminal 30: 11.679 V
                    T_AST_ENVD: 0.00 s
6024 - Bank 2: CMP Sens 4 (G301) / Engine Speed Sensor (G28)
          P0019 00 [01100000] - Incorrect Correlation
                    Mileage: 130757 km
                    Date: 2024.11.27
                    Time: 16:52:18
                    Engine RPM: 1348.00 /min
                    Normed load value: 47.8 %
                    Vehicle speed: 27 km/h
                    Coolant temperature: 95 °C
                    Intake air temperature: 37 °C
                    Engine speed: actual: 1664 /min
                    MAF_ENVD: 408.52940 mg/stroke
                    Coolant temperature (unfiltered): 93.0 °C
                    Engine: operating status: PL
                    ENVD_CAM_EX_2: 16
                    Vehicle speed: actual: 6 km/h
6342 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit
          P0030 00 [11101101] - Malfunction / Open Circuit
                    Mileage: 130753 km
                    Date: 2024.11.27
                    Time: 13:16:40
                    Engine RPM: 720.00 /min
                    Normed load value: 33.7 %
                    Coolant temperature: 90 °C
                    Voltage terminal 30: 13.812 V
                    Engine speed: actual: 736 /min
                    MAF_ENVD: 130.72941 mg/stroke
                    Battery voltage: 11.476563 V
                    STATE_LS_ENVD[1]: 1
6337 - Oxygen (Lambda) Sensor Heating; B2 S2
          P1122 00 [11101101] - Open Circuit
                    Mileage: 130753 km
                    Date: 2024.11.27
                    Time: 13:16:40
                    Battery voltage: 11.578125 V
                    STATE_LS_ENVD[2]: 1
6201 - Function Restriction due to Faults in Other Modules
          U1113 00 [01101101] - -
                    Mileage: 130753 km
                    Date: 2024.11.27
                    Time: 13:16:39
                    Engine RPM: 703.00 /min
                    Normed load value: 30.2 %
                    Engine speed: actual: 992 /min
                    MAF_ENVD: 190.64705 mg/stroke
                    Engine load: 32.031250 %
6134 - Function Restriction due to Faults in Other Modules
                    Mileage: 130753 km
                    Date: 2024.11.27
                    Time: 13:21:57
                    Engine RPM: 771.00 /min
                    Normed load value: 55.7 %
                    Vehicle speed: 1 km/h
                    Voltage terminal 30: 12.390 V
                    MAF_ENVD: 245.11764 mg/stroke
                    Coolant temperature (unfiltered): 87.0 °C
                    Engine load: 40.625000 %
                    Vehicle speed: actual: 1 km/h
7948 - Cylinder Disabling
          P130A 00 [01101000] - -
                    Mileage: 130753 km
                    Date: 2024.11.27
                    Time: 13:17:44
                    Engine RPM: 715.00 /min
                    Voltage terminal 30: 13.913 V
                    Engine speed: actual: 768 /min
                    MAF_ENVD: 174.30588 mg/stroke
                    Coolant temperature (unfiltered): 86.3 °C
                    T_AST_ENVD: 25.70 s
Readiness: 1010 1101
Address 02: Auto Trans (J217)       Labels:| 0B6-927-156.clb
   Part No SW: 8R0 927 158 F    HW: 0B6 927 156
   Component: 0B6 32 FSIUSA H05 0005
   Revision: --H05---    CVN: 1C14BFCA
   Coding: 001012
   ASAM Dataset: EV_TCMAL651 A01006
   ROD: EV_TCMAL651.rod
   VCID: 40DE98B67A0A8F7A1FB-8014
Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V1.clb
   Part No SW: 8R0 907 379 M    HW: 8R0 907 379 M
   Component: ESP8 quattro  H06 0020
   Coding: 041D18
   VCID: 4ACABA9E4CB6452AC1F-801E
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 138
                    Mileage: 130753 km
                    Date: 2024.11.27
                    Time: 11:45:39
                    Hex Value: 0x0000
                    Hex Value: 0x0782
                    Hex Value: 0x0016
                    Hex Value: 0x0293
                    Hex Value: 0x00FF
02214 - Tire Pressure Warning
                    Reset counter: 138
                    Mileage: 130753 km
                    Date: 2024.11.27
                    Time: 11:45:39
                    Hex Value: 0x0000
                    Hex Value: 0x0782
                    Hex Value: 0x001D
                    Hex Value: 0x1D93
                    Hex Value: 0x00FF
01794 - Control Module - Incorrect Chassis (VIN) Number
            000 - - - MIL ON
                    Fault Status: 11100000
                    Reset counter: 138
                    Mileage: 130753 km
                    Date: 2024.11.27
                    Time: 11:45:45
                    Hex Value: 0x0000
                    Hex Value: 0x0082
                    Hex Value: 0x0041
                    Hex Value: 0x1393
                    Hex Value: 0x00FF
   Part No SW: 8K0 907 064 DS    HW: 8K0 907 064 DS
   Component: BCM2 1.1      H02 0324
   Coding: 090500
   VCID: 045654A62E12535A7B3-8050
   Subsystem 1 - Part No SW: 8T0 959 754 A    HW: 8T0 959 754 A
   Serial number: 0509000043343014
   Serial number: 0210000026151001
   Part No SW: 8T1 820 043 AK    HW: 8T1 820 043 AK
   Component: KLIMA 3 ZONEN H08 0171
   Revision: C1000000    Serial number: 01250820091040
   Coding: 46112000
   VCID: 7AAA2A5E5CD615AA11F-802E
03220 - Stop Valve for Coolant for Climatronic (N422)
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 105
                    Mileage: 130260 km
                    Date: 2009.04.28
                    Time: 00:21:57
                    Reset counter: 146
                    Mileage: 130278 km
                    Date: 2009.04.28
                    Time: 00:00:34
                    Reset counter: 145
                    Mileage: 130278 km
                    Date: 2009.04.30
                    Time: 04:49:06
00710 - Defroster Flap Positioning Motor (V107)
                    Fault Status: 00100011
                    Reset counter: 159
                    Mileage: 130278 km
                    Date: 2009.04.28
                    Time: 00:01:31
                    Voltage: 12.70 V
                    Temperature: 28.0°C
                    Temperature: 33.0°C
                    Count: 10692
                    Bin. Bits: 01000000
                    Bin. Bits: 10000011
                    Time: 2.55 s
03037 - Rear Temperature Selection Potentiometer (G538)
                    Fault Status: 00101010
                    Reset counter: 155
                    Mileage: 130417 km
                    Date: 2024.11.15
                    Time: 14:53:18
                    Voltage: 14.20 V
                    Voltage: 4.90 V
   Component: BCM1 1.0      H25 0380
   Revision: 10025001    Serial number: 00000000331710
   Coding: 26001091063CAF010000080300001D0D0F1C460800010161000000
   Shop #: WSC 00046 000 00000
   VCID: 3C26EC461662EB9A433-8068
   Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 090729  H10 0041
   Serial number: 90243014090718044955
   Coding: 01DD13
   Component: RLS  H04 0003
   Serial number: 10578069
   Coding: 024D25
   Component: E1 - LDS  H08 0090
   Serial number: 00000000001308091052
   Subsystem 4 - Part No SW: 8K0 907 410 B    HW: 8K0 907 410 B
   Component: HOMELINK  H01 0010
                    Fault Status: 01101100
                    Reset counter: 2
                    Mileage: 128850 km
                    Date: 2024.08.19
                    Time: 00:16:00
03206 - Control Circuit / Actuator for Right Low-Beam Shutter
                    Reset counter: 29
                    Mileage: 124957 km
                    Date: 2024.04.04
                    Time: 20:48:00
                    Reset counter: 146
                    Mileage: 130278 km
                    Date: 2009.04.28
   Part No SW: 8K0 919 475 J    HW: 8K0 919 475 A
   Component: PARKHILFE 8K  H06 0050
   Revision: 11001001    Serial number: 39840923101039
   Coding: 300105
   VCID: 40DE98B67A8A8F7A1FB-8014
01545 - Sensor for Parking Aid; Rear Left (G203)
                    Reset counter: 137
                    Mileage: 130753 km
                    Date: 2024.11.27
                    Time: 13:05:19
                    Temperature: 53.0°C
02069 - Front Parking Aid Sensors
                    Reset counter: 137
                    Mileage: 130753 km
                    Date: 2024.11.27
                    Time: 13:05:18
                    Temperature: 53.0°C
Address 15: Airbags (J234)       Labels:* 8R0-959-655.clb
   Part No SW: 8R0 959 655 F    HW: 8R0 959 655 F
   Serial number: 003GPD90486+   Dataset Number: 8R0909602B  0020
   Coding: 303633313432303030304A55304C38523053
   ROD: EV_AirbaAU10SMEAU416.rod
   VCID: 47CC83AA5F24B842DE1-8012
   Subsystem 1 - Part No SW: 8R0 959 339     HW: 8R0 959 339
   Serial number: 5810000R0900004CM1
   Serial number: 6334MSME4B513825C
   Serial number: 6344MSME4A1068407
   Serial number: 6352QSME6537061EJ
   Serial number: 6362QSME7E374E0A.
7 Faults Found:
9443859 - Driver's Front Airbag Crash Sensor
          B101A 15 [10001001] - Open or Short to Plus
                    Mileage: 124812 km
                    Date: 2024.03.30
                    Time: 21:18:43
9444115 - Front Passenger's Front Airbag Crash Sensor
          B101B 15 [10001001] - Open or Short to Plus
                    Mileage: 124812 km
                    Date: 2024.03.30
                    Time: 21:18:43
9445973 - Seat occupied recognition control module
          B1022 55 [10001001] - Not Configured
                    Mileage: 124812 km
                    Date: 2024.03.30
                    Time: 21:18:46
13697280 - Component Protection
          U1101 00 [10001001] - Active
                    Mileage: 124812 km
                    Date: 2024.03.30
                    Time: 21:18:43
12658176 - No Communications with Steering Angle Sender (G85)
          U0126 00 [00001000] - -
          [Steer Angle Control Unit no signal/communication]
                    Reset counter: 146
                    Mileage: 130278 km
                    Date: 2009.04.28
                    Time: 00:00:46
13635840 - Supply voltage
          U1011 00 [00001000] - Voltage too Low
          [Powersupply  lower threshold fall short of]
                    Reset counter: 145
                    Mileage: 130278 km
                    Date: 2009.04.30
                    Time: 04:48:58
          B10B4 00 [00001000] - Function Restriction due to Undervoltage
          [Bladder Mat: functional restriction because of low voltage]
                    Reset counter: 145
                    Mileage: 130278 km
                    Date: 2009.04.29
                    Time: 22:49:40
   Revision: --------    Serial number: 90315IHK0003N
   Coding: 000017
   VCID: 3D20E1420D78E29274D-8068
Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 980 K    HW: 8R0 920 980 K
   Component: KOMBIINSTR.   H10 0253
   Revision: 00000000    Serial number: BZ550UT89
   Coding: 8B1622000300D705020000
   VCID: 41D89DB271808672105-8014
   Part No SW: 8T0 907 468 T    HW: 8T0 907 468 K
   Component: GW-BEM 4CAN-M H09 0105
   Revision: EB800053    Serial number: 5300E097258082
   Coding: 00C303
   VCID: 52FAA2FEA4E60DEAB9F-8006
   Subsystem 1 - Part No SW: 8R0 915 181     HW: 8R0 915 181
   Component: J367-BDM  H07 0107
   Serial number: 00000000004140645872
00384 - Optical Databus
                    Fault Status: 00101011
                    Reset counter: 145
                    Mileage: 130260 km
                    Date: 2009.04.28
                    Time: 00:35:01
                    Bin. Bits:    10000
                    Voltage: 12.50 V
                    Count: 11
                    Bin. Bits:    00000
                    Fault Frequency: 124
                    Reset counter: 138
                    Mileage: 130260 km
                    Date: 2009.04.28
                    Time: 00:40:30
                    Bin. Bits:    10111
                    Voltage: 12.20 V
                    Count: 6
                    Text: FFF1746D00820101
                    Raw, Index/Key Err.: 241 116 109
                    Raw, Form. N/A: 000 130 001
                    Reset counter: 145
                    Mileage: 130278 km
                    Date: 2009.04.29
                    Time: 19:21:35
                    Bin. Bits:    10111
                    Voltage: 11.90 V
                    Count: 6
                    Bin. Bits:    00000
                    Time: 25.40 s
                    Fault Frequency: 9
                    Reset counter: 145
                    Mileage: 130278 km
                    Date: 2009.04.29
                    Time: 22:28:43
                    Bin. Bits:    10000
                    Voltage: 11.40 V
                    Count: 13
                    Reset counter: 146
                    Mileage: 130278 km
                    Date: 2009.04.30
                    Time: 15:45:37
                    Bin. Bits:    10000
                    Voltage: 12.90 V
                    Count: 15
                    Bin. Bits:    01000
                    Time: 25.40 s
                    Reset counter: 146
                    Mileage: 130278 km
                    Date: 2009.04.28
                    Time: 00:00:46
                    Bin. Bits:    00111
                    Voltage: 12.60 V
                    Count: 6
                    Bin. Bits:    00110
                    Time: 0.40 s
   Part No SW: 8R0 959 760 B    HW: 8R0 959 760 B
   Component: MEM-FS        H06 0074
   Revision: AA000000    Serial number: 00001001337351
   Coding: 00581300000044440000
   Part No SW: 8K0 959 793 H    HW: 8K0 959 793 D
   Component: TSG FA        H11 0306
   Revision:             Serial number: 0000009225286
   Coding: 011D03205E00440004
   VCID: 45D089A265A8AA522CD-8010
                    Reset counter: 145
                    Mileage: 130278 km
                    Date: 2009.04.30
                    Time: 04:49:18
   Revision: 00002001    Serial number: 0121065674
   Coding: 0126023A207A749404B0050000000000
   Component: GTO BF  H06 0050
   Serial number: 00000000000000163037
   Subsystem 3 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
   Component: J245EE19SKB12  H01 0220
   Subsystem 4 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
   Component: J394EE19SKB12  H01 0220
8 Faults Found:
02912 - Bulb for Side Marker Light; Rear Right (M38)
                    Fault Status: 11101100
                    Reset counter: 105
                    Mileage: 130260 km
                    Date: 2009.04.28
                    Time: 00:29:05
02202 - Trunk / Luggage Compartment Closing Assist; Position - Locked (F332)
                    Fault Status: 01101000
                    Reset counter: 105
                    Mileage: 130260 km
                    Date: 2009.04.28
                    Time: 00:47:42
02772 - Bulb for Right Brake / Turn Signal / Tail Lamp (M70)
                    Reset counter: 105
                    Mileage: 130260 km
                    Date: 2009.04.28
                    Time: 01:24:14
02615 - Fuel Tank Cap; Lock
                    Fault Status: 00101001
                    Reset counter: 173
                    Mileage: 130273 km
                    Date: 2009.04.28
                    Time: 02:25:14
02616 - Fuel Tank Cap; Unlock
                    Fault Frequency: 11
                    Reset counter: 177
                    Mileage: 130273 km
                    Date: 2009.04.28
                    Time: 03:42:34
00166 - Access/Start Authorization Switch (E415)
                    Reset counter: 145
                    Mileage: 130278 km
                    Date: 2009.04.29
                    Time: 22:48:26
                    Reset counter: 145
                    Mileage: 130278 km
                    Date: 2009.04.29
                    Time: 22:49:30
03073 - Rear Lid Closed Sensor 1
                    Reset counter: 146
                    Mileage: 130278 km
                    Date: 2009.04.30
                    Time: 15:20:32
   Part No SW: 8T0 035 223 H    HW: 8T0 035 223 H
   Component: DSP Prem      H04 0120
   Revision: 00004001    Serial number: 34880005470503
   VCID: 3334C77A3B3C24E2929-8066
                    Reset counter: 145
                    Mileage: 130278 km
                    Date: 2009.04.30
                    Time: 04:48:49
                    Voltage: 8.80 V
                    Temperature: 28.0°C
                    Temperature: 32.0°C
                    Bin. Bits: 01000000
                    Bin. Bits: 00000001
                    Bin. Bits: 00000000
                    Reset counter: 105
                    Mileage: 130260 km
                    Date: 2009.04.28
                    Time: 01:29:57
                    Voltage: 10.80 V
                    Temperature: 51.0°C
                    Temperature: 54.0°C
                    Bin. Bits: 00000100
00871 - Bass Speaker Front Right (R23)
                    Reset counter: 105
                    Mileage: 130260 km
                    Date: 2009.04.28
                    Time: 01:29:57
                    Voltage: 10.80 V
                    Temperature: 51.0°C
                    Temperature: 54.0°C
                    Bin. Bits: 00000100
02558 - Rear Left Mid-Range/Woofer Loudspeaker (R159)
                    Reset counter: 105
                    Mileage: 130260 km
                    Date: 2009.04.28
                    Time: 01:29:57
                    Voltage: 10.80 V
                    Temperature: 51.0°C
                    Temperature: 54.0°C
                    Bin. Bits: 00000100
02559 - Rear Right Mid-Range/Woofer Loudspeaker (R160)
                    Reset counter: 108
                    Mileage: 130260 km
                    Date: 2009.04.28
                    Time: 01:29:57
                    Voltage: 10.80 V
                    Temperature: 51.0°C
                    Temperature: 54.0°C
                    Bin. Bits: 00000100
                    Reset counter: 145
                    Voltage: 11.70 V
                    Temperature: 42.0°C
                    Temperature: 44.0°C
                    Bin. Bits: 01000000
   Part No SW: 8K0 959 792 H    HW: 8K0 959 792 D
   Revision:             Serial number: 0000009209663
   VCID: 44D694A66E92935A3B3-8010
                    Reset counter: 145
                    Mileage: 130278 km
                    Date: 2009.04.30
                    Time: 04:49:12
   Revision: 00000003    Serial number: 00000000434032
   VCID: 3436C4663E3223DA8B3-8060
                    Fault Status: 11101101
                    Reset counter: 105
                    Mileage: 130260 km
                    Date: 2009.04.28
                    Time: 00:30:47
                    Voltage: 14.20 V
                    Count: 80
                    Hex Value: 0x0273
                    Hex Value: 0x0001
                    Hex Value: 0x1010
   Part No: 8K0 907 357 B
   Component: Dynamische LWR  H01 0030
   Coding: 0000006
   Shop #: WSC 06334 000 00000
   VCID: 3436C466323223DA8B3-8060
                    Reset counter: 107
                    Mileage: 130278 km
                    Date: 2009.04.30
                    Time: 04:48:41
                    Reset counter: 137
                    Mileage: 130278 km
                    Date: 2009.04.30
                    Time: 04:49:13
   Part No SW: 4F0 035 082 A    HW: 4F0 035 082
   Component: Radio U SIRIU H45 0021
   Revision: AB001007    Serial number: 335HZ097526165
   Coding: 020000010000000001
   VCID: 1D6001C2ADB8829254D-8048
   Part No SW: 8T1 035 664 A    HW: 8T1 035 664 A
   Component: H-BN-NA       H41 0042
   Revision: --------    Serial number: 490H0097514489
   Coding: 010200060005EDFF47001F0E002000030000
   VCID: 3632FE6E284E31CAB57-8062
   Subsystem 1 - Part No: 8R0 060 884 F
   Component: NAR 2009/2010  5304
   Component: DU7 High  H43 0306
   Serial number: 9356H$091054977
   Subsystem 3 - Part No SW: 8T0 919 609 F    HW: 8T0 919 609 F
   Serial number: 00000000344515
   Component: CD-Database  1293
00658 - Control Head
                    Reset counter: 145
                    Time Indication: 15
                    Voltage: 13.90 V
                    Reset counter: 105
                    Mileage: 130260 km
                    Date: 2009.04.28
                    Time: 00:55:31
                    Bin. Bits: 00000001 00100000
                    Bin. Bits: 00000000 10000000
                    Bin. Bits: 00000000 00000000
02259 - Information Display and Control Head (Front) (J685)
                    Reset counter: 145
                    Mileage: 130278 km
                    Date: 2009.04.30
                    Time: 15:21:15
                    Voltage: 14.40 V
02169 - Front Right Microphone (R141)
                    Reset counter: 105
                    Mileage: 130278 km
                    Date: 2009.04.30
                    Time: 15:16:35
                    Voltage: 12.00 V
   Part No SW: 8K0 959 795 C    HW: 8K0 959 795 C
   Revision:             Serial number: 0000101708787
   Coding: 010C03204000240004
   VCID: 42DA92BE74869D6A09F-8016
                    Reset counter: 145
                    Mileage: 130278 km
                    Date: 2009.04.30
                    Time: 04:49:09
   Part No SW: 8R0 907 441 A    HW: 4L0 907 441 B
   Revision: --H03---    Serial number: 525PA8-J97A0SI
   Coding: 1020010
Address 6D: Trunk Elect. (J605)       Labels: 8K9-827-851.clb
   Part No SW: 8R0 827 851 B    HW: 8R0 827 851 B
   Component: J605  Master  H27 0300
   Revision: --------    Serial number: 8R0827851B
   VCID: 3B24EF5A136CECA24A9-806E
   Subsystem 1 - Part No SW: 8R0 827 852 B    HW: 8R0 827 852 B
   Component: J756  Slave  H27 0300
   Serial number: 8R0827852B
   Revision:             Serial number: 0000101708793
                    Reset counter: 145
                    Mileage: 130278 km
                    Date: 2009.04.30
                    Time: 04:49:12
End----------(Elapsed Time: 02:06, VBatt start/end: 12.1V/13.5V)-----------
this forum i have a 2010 audi q5 with and ABS incorrect vin i got the car damaged and repaired it the original ABS WAS damaged can i get some assistance with coding
There are Component Protection faults in multiple modules. What modules have been replaced?
I suspect this car is going to need a therapy session with Audi's servers.
Jef
HQ
The current soft coding of the ABS module, 041D18, looks plausible, try recoding the ABS module with that same value. Based on the Auto-Scan, I suspect this vehicle was 1 cubic meter in size in recent history. :p
