- Nov 8, 2024
- 9
- 0
- Epsom Surrey, UK
- C?ID=585034
Hi
I have an Audi TTS 2017 with Zenon lights, I had to replace the right lamp due to damage, I purchased a used one with same part number, I took the 3 modues out and put them into the replacement light it all worked but a warning light came up saying Low voltage on one of the modules this one had water damage it was full of water, so i purchaded a used one to replace it now the main beam will not work and it throws up more warnings, Please see attached.
I purchased a VCDS (have no experiance) as Gendon told me i could put the original module back into the light and copy the code then put the replacement in and paste the code in.
To save me removing the front bumper and putting in the origianl module, can i just copy the codes from the left side and put them into the right side?
Any help or videos on this would help and i appriate any help.
Cheers
Dave
Cheers
Dave
Wednesday,27,November,2024,14:05:47:18619
VCDS Version: 24.7.1.0 (x64) HEX-V2 CB: 0.4643.5
VIN: TRUZZZFV3H1022347 License Plate: BP17GYD
Mileage: 69129km-42954mi Repair Order: e2
Chassis Type: FV-AU37 (8S0)
Scan: 01 02 03 05 08 09 10 14 15 16 17 19 22 2B 42 44 47 52 55 5F
A5 A9
VIN: TRUZZZFV3H1022347 Mileage: 69129km-42954miles
Address 01: Engine (J623-CJXG) Labels:. 06K-907-425-V1.clb
Part No SW: 8S0 906 259 B HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0004
Revision: --H13--- CVN: 900D09E2
Coding: 0A1D00322426050B3004
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_ECM20TFS0208S0906259B 001005
ROD: EV_ECM20TFS0208S0906259B.rod
VCID: 3C26EE0EC6EF2C5A433-8068
VINID: 92296AAAA5A60D80400820C41C0D19A818
15462 - Control Circuit for Coolant Bypass Valve
P2681 00 [00101000] - Open Circuit
Fault Frequency: 75
Mileage: 68763 km
Date: 2024.11.15
Time: 13:47:35
Engine RPM: 960.00 /min
Normed load value: 7.1 %
Coolant temperature: 56 °C
Intake air temperature: 43 °C
Voltage terminal 30: 11.953 V
Engine: operating status: IS
Engine temp. management actuator: raw value: 2598
Engine temperature management actuator: stop open: 139
Engine temperature management actuator: after-run stop: 3956
RVC_SP: 164.50 °
RVC_AV: 164.03 °
RVCPWM: 0.000 %
Readiness: 0010 0001
Part No SW: 0D9 300 014 R HW: 02E 927 770 AS
Component: DQ250-6A MQB H54 5003
Revision: 06454104 Serial number: TFK01703291181 CVN: 0000FFF8
Shop #: WSC 04742 780 00200
ROD: EV_TCMDQ250021.rod
VCID: 270C21622F699F823E1-8072
Part No SW: 8S0 907 379 F HW: 8S0 907 379 F
Component: ESC H42 0530
Revision: 00000000 Serial number: 60847000000930
Coding: 24AA608D1A9B15AB41940868C298970633240658A8821043E960CC
ASAM Dataset: EV_Brake1UDSContiMK100IPB 060017
ROD: EV_Brake1UDSContiMK100IPB_060.rod
VCID: 44D696EEBE1F549A3B3-8010
Part No SW: 3Q0 959 435 E HW: 3Q0 959 435 E
Component: VWKESSYMQB 036 0811
Revision: 00036000 Serial number: 0437691483 Dataset Number: 8S0909577F 0026
Coding: 030C0C1720
ASAM Dataset: EV_KessyHellaMQBAB 004039
ROD: EV_KessyHellaMQBAB.rod
133124 - Databus
[Message Klemmen_status_01 missing]
Reset counter: 112
Mileage: 68387 km
Date: 2024.11.05
Time: 09:30:10
Terminal_15_Kessy_specified_value: OFF
Terminal_15_Kessy_actual_value: OFF
Terminal_15_central electric_actual_value: Timeout
Terminal_15red_Kessy_specified_value: OFF
Terminal_15red_Kessy_actual_value: OFF
Terminal_S_Kessy_specified_value: OFF
Terminal_S_Kessy_actual_value: OFF
Terminal_S_central electric_actual_value: Timeout
Terminal_50_Kessy_specified_value: On
Terminal_50_Kessy_actual_value: On
ZAT_pressed: On
Request active: Condition met
Enabling Steering Column Lock: Condition not met
Enabling immobilizer: Condition not met
Control Module Voltage: 12.417 V
Vehicle speed: 0.0 km/h
Engine RPM: 0.0 /min
Status of vehicle locking: Vehicle unlocked
Coding information: coded
Coding information: Not coded
Driver door: closed
Front Passenger Door: closed
Left rear door: closed
Right rear door: closed
Active_LF_scans: GO_Scan_1
ID-sensor 1 authentication: status: No response
ID-sensor 2 authentication: status: No response
ID-sensor 3 authentication: status: No response
ID-sensor 4 authentication: status: No response
SPN_Byte 0: 00
SPN_Byte 1: 00
SPN_Byte 2: 00
Address 08: Auto HVAC (E87) Labels:* None
Part No SW: 8S0 820 043 HW: 8S0 820 043
Component: AC Automat H05 0040
Revision: 20010000 Serial number: 17070000009000
Coding: 410040000011101100
ASAM Dataset: EV_AirCondiVAPrehAU33x 003011
ROD: EV_AirCondiVAPrehAU33x.rod
VCID: 6C861E4EF60F7CDA933-8038
Humidity sensor: exterior:
Rear A/C Control Head 1:
Subsystem 2 - Part No SW: 8S0 820 373 A HW: 8S0 820 373 A
Component: E774 BuA_1 H07 0020
Serial number: 00000000000000039234
Rear A/C Control Head 2:
Subsystem 3 - Part No SW: 8S0 820 359 A HW: 8S0 820 359 A
Component: E775 BuA_2 H07 0020
Rear A/C Control Head 3:
Subsystem 4 - Part No SW: 8S0 820 359 HW: 8S0 820 359
Component: E776 BuA_3 H07 0020
Rear A/C Control Head 4:
Subsystem 5 - Part No SW: 8S0 820 359 B HW: 8S0 820 359 B
Component: E777 BuA_4 H07 0020
Rear A/C Control Head 5:
Subsystem 6 - Part No SW: 8S0 820 373 B HW: 8S0 820 373 B
Component: E778 BuA_5 H07 0020
Part No SW: 5Q0 937 084 CG HW: 5Q0 937 084 CG
Component: BCM MQBAB H H34 0236
Serial number: 02001710301594 Dataset Number: 8S0909514N 0025
ROD: EV_BCMBOSCH_017.rod
VCID: 7F5CD9029779F742261-802A
Subsystem 1 - Part No SW: 8S2 955 119 B HW: 8S2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: 43x RL 170218 038 0371
Serial number: 00000001702150302782
Coding: 1BC7F7
Component: G397_RLFS H06 0004
Serial number: 62753962
Coding: 00005D
Subsystem 3 - Part No SW: 8V0 941 531 AA HW: 8V0 941 531 AA
Serial number: 18 01 2017 00000302
Subsystem 4 - Part No SW: 5Q0 951 171 HW: 5Q0 951 171
Serial number: 000000000ZY1705903HJ
Serial number: 00000000000069112514
Valve block 1 in front seat driver side:
Subsystem 6 - Part No SW: 8S0 907 182 HW: 8S0 907 182
Component: N475 VB1 FSv H07 0021
Serial number: 7008173235E164512753
Coding: 810500
Valve block 1 in front seat passenger side:
Subsystem 7 - Part No SW: 8S0 907 182 HW: 8S0 907 182
Component: N477 VB1 BFSv H07 0021
Serial number: 7008173235E164512729
Coding: 810500
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-283.clb
Part No SW: 5Q0 919 283 F HW: 5Q0 919 283
Component: PARKHILFE 4K H10 0054
Revision: -------- Serial number: 39261710105561 Dataset Number: 8S0909526C 0018
Coding: 0000040011
ROD: EV_EPHVA14AU3700000_002_AU37.rod
Address 14: Susp. Elect. (J250) Labels: 8V0-907-376.clb
Part No SW: 8V0 907 376 G HW: 8V0 907 376 F
Component: DAEMPFUNGS-SG H11 0082
Serial number: 310317042 Dataset Number: 8S0909554E 0015
ASAM Dataset: EV_AudiMagneRide 002008
ROD: EV_AudiMagneRide.rod
VCID: 45D08BEAB5256D922CD-8010
Part No SW: 5Q0 959 655 P HW: 5Q0 959 655 P
Component: AirbagVW20 010 0870
Serial number: 003M7R020VMS Dataset Number: 8S0909602A 0029
Coding: 88CCF0C00C8000005C5000CFC0C800000065
VCID: 4DC0B3CA6D5595D2E4D-8018
Subsystem 1 - Part No SW: ----------- HW: 480 000 704 17
Serial number: 357000000006F9F4422T
Subsystem 2 - Part No SW: ----------- HW: 480 000 704 17
Serial number: 3580000000083AF4422L
Subsystem 3 - Part No SW: ----------- HW: 480 012 203 17
Component: SideSensor_Dr 005 0108
Serial number: 351001A0937A8DB2BE7T
Subsystem 4 - Part No SW: ----------- HW: 480 402 702 17
Serial number: 3550002AD2439CA33042
Subsystem 5 - Part No SW: ----------- HW: 480 402 702 17
Component: FrontSensor_P 001 6149
Serial number: 3560002AB2439CA0A168
Subsystem 6 - Part No SW: ----------- HW: 480 400 602 17
Component: PedP_Sensor_C 001 6149
Serial number: 2300002A923E4842A3F5
Subsystem 7 - Part No SW: ----------- HW: 480 002 903 17
Serial number: I0M0000000017511B22R
Subsystem 8 - Part No SW: ----------- HW: 480 002 903 17
Serial number: I0N00000000C6511B22
Part No SW: 8S0 907 129 AL HW: 8S0 907 129 AL
Component: Lenks. Modul H07 0150
Revision: -------- Serial number: 91335QDJ00311
Coding: 281C
ASAM Dataset: EV_SMLSKLOMQB 050001
ROD: EV_SMLSKLOMQB_050.rod
VCID: 045656EEFE9F949A7B3-8050
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI2
Part No SW: 8S0 920 790 B HW: 8S0 920 790 B
Component: FBenRDW H40 0296
Coding: 24AD0850798406000121E8C09000800000000000
ASAM Dataset: EV_DashBoardBOSCHAU33X 001023
ROD: EV_DashBoardBOSCHAU33X.rod
VCID: 382EF21EF2D7007AA7B-806C
Part No SW: 8S0 907 468 E HW: 8S0 907 468 E
Component: GW MQB TT3 021 0286
Serial number: 04041710802625 Dataset Number: 8S0909515D 0029
Coding: 030100042F025A004B00026ABC0B00000000000000000000000000000001
GVL: 01D43C1000000600408C10000000CC0000000000000000000000000000000000
ASAM Dataset: EV_GatewContiAU33X 013005
ROD: EV_GatewContiAU33X_013.rod
VCID: 42DA90F6A40B5AAA09F-8016
Generator:
Subsystem 2 - Part No SW: 8S0 951 523 C HW: 8S0 951 523 C
Component: J453 MFL H07 0002
Serial number: 20170313203320 01622
Subsystem 3 - Part No SW: 8W0 915 181 HW: 8W0 915 181
Serial number: 6412512804
Address 22: AWD (J492) Labels:| 0CQ-907-554-V1.clb
Part No SW: 0CQ 907 554 C HW: 0CQ 525 130
Component: Haldex4Motion H52 7755
Serial number: HA1-00009.03.17 Dataset Number: v1260x015G0 0000
Coding: 0101
ROD: EV_AllWheelContrHA1VW37X_002_VW36.rod
Address 2B: Steer. Col. Lock (J764) Labels:| 1EA-905-861.clb
Part No SW: 3Q0 905 861 HW: 3Q0 905 861
Component: ELV-MQBB H05 0032
Serial number: 17000086948003
Coding: 0900000000000000
ROD: EV_ELVMarquMQBB_VW37.rod
VCID: 71B80F3AD12D9132A05-8024
Component: TSG FS 020 0041
Serial number: 280317ECS15375 Dataset Number: 8S0909872E 0021
Coding: 001F52225C01040100001402
ROD: EV_DCUDriveSideEWMAXKLO.rod
VCID: 43D495F2BB1153A2029-8016
B1487 54 [00001000] - Missing Calibration / Basic Setting
Reset counter: 110
Mileage: 68905 km
Date: 2024.11.20
Time: 08:55:56
Part No SW: 3Q0 909 144 K HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 506 5072
Dataset Number: 8S0909852D 0011
Coding: 9107
ROD: EV_SteerAssisMQB_013.rod
VCID: 3A2AE816CCDB126A51F-806E
Part No SW: 8S0 035 466 A HW: 8S0 035 466
Component: MIB2_amp_P_TT H10 0440
Revision: 00000001 Serial number: AUZ8ZAG5C001NDQ Dataset Number: 8S0909510B 0012
Coding: 0133040000AA2A2AAA0000010000
ASAM Dataset: EV_AMPMst16C1Gen2ALPI 001012
ROD: EV_AMPMst16C1Gen2ALPI_AU37.rod
VCID: 3436C62EEEBFE41A8B3-8060
Component: TSG BFS 020 0041
Serial number: 290317ECT0492A Dataset Number: 8S0909873E 0021
Coding: 001F52225E01040100001402
ROD: EV_DCUPasseSideEWMAXKLO.rod
Part No SW: 4H4 907 357 G HW: 7P6 907 357 B
Component: MxB-ECU 001 0115
Revision: -------- Serial number: -------------- Dataset Number: 8S0909865F 0025
Coding: 03E602202B170200
ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005012
VCID: 3632FC26F8C3F60AB57-8062
Coding: E01400
Coding: E01400
Subsystem 3 - Part No SW: 8S0 941 329 HW: 8S0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H02 S002
Coding: E01400
Subsystem 4 - Part No SW: 8S0 941 329 HW: 8S0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H02 S002
Coding: E01800
Power module 1 for left matrix headlamp:
Subsystem 5 - Part No SW: ----------- HW: -----------
Component: MxB LeiMo li. H05 S007
Coding: E01400
Power module 1 for right matrix headlamp:
Component: MxB LeiMo re.
13705999 - Databus
U1123 00 [10001001] - Received Error Message
[Empfangener Fehlerwert im Signal Kamera_FDD_Funktionsstatus: CAN Message Kamera_Status]
Fault Frequency: 173
Reset counter: 91
Mileage: 67927 km
Date: 2024.10.26
Time: 16:34:04
5334321 - Output Stage for Right Matrix Headlamp
C1165 31 [10001001] - No Signal
Reset counter: 16
Mileage: 67927 km
Date: 2024.10.26
Time: 16:34:03
U1014 00 [10001001] - -
[Steuergeraet falsch codiert]
Reset counter: 16
Mileage: 67927 km
Date: 2024.10.26
Time: 16:34:04
5353456 - Fog mode active
C118E 00 [00001000] - -
Reset counter: 117
Mileage: 68774 km
Date: 2024.11.16
Time: 04:32:19
5276401 - Power Output Module for Right Headlamp
C1082 F1 [10001001] - Incorrectly Coded
Reset counter: 91
Mileage: 69127 km
Date: 2024.11.27
Time: 09:34:50
Address 5F: Information Electr. (J794) Labels:* 8V0-035-MIB-HGH2.clb
Part No SW: 8S0 035 021 G HW: 8S0 035 021 E
Component: MU-H-LND-EU 053 0892
Serial number: A710D0HS002623 Dataset Number: 8S0909545G 0037
Coding: 013354010000000011111102000A00102F0000E3007000009E
VCID: 2D00D34A0D95B5D2C4D-8078
Subsystem 1 - Part No SW: V03 959 801 FC HW: -----------
Component: ECE 2017 --- 0157
Subsystem 2 - Part No SW: 8S0 919 614 M HW: 8S0 919 614 M
Component: ControlUnit_H H30 0206
Serial number: APVAK112021700010138
Compact disc data bank:
Component: Gracenote2 --- 1015
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 5Q0-980-653.clb
Part No SW: 5Q0 980 653 G HW: 5Q0 980 653
Component: MQB_MFK H07 0060
Serial number: 10000630594 Dataset Number: 8S0909466B 0016
Coding: 0101040001010305000501000000010100
ROD: EV_MFKBoschAU370.rod
6684678 - Databus
[LWR_AFS_05_MXB_Status_SIG_FAILURE]
Fault Frequency: 8
Reset counter: 251
Mileage: 64470 km
Date: 2024.06.07
Time: 13:31:00
Control Module temperature: 37 °C
Outside temperature: 19.0 °C
Vehicle speed: 0.00 km/h
Voltage terminal 15: 11.9 V
Terminal 15 on: 11.0 s
Part No SW: 8S0 907 159 A HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0007
Serial number: 170208200457
VCID: 3B24ED12C3E12B624A9-806E
End----------(Elapsed Time: 01:46, VBatt start/end: 12.0V/12.0V)-----------
