Passat B8 DQ250 DSG calibration
pingu
Finland
HUC-2H
I'm about to do a DSG calibration for my 2016 Passat B8 estate with DQ250 transmission.
The current wiki page instructions for this procedure are for older version of VCDS, so they do not apply anymore.
The nevest VCDS has totally different approach to do the calibration for the transmission, including the following selectable actions:
IDE00498-Resetting of all adaptation values
IDE02903-Basic setting of transmission
IDE02909-Start double clutch fast adaptation
IDE07863-Calibration of synchro-points
The main reason for doing this is that, mainly after starting the car and the first time getting it moving, it does not matter if it's reversing or going forward, it feels that the car clutch engages at a different point than where the car is expecting it to engage. So, it basically launches a bit when initially getting moving.
It shifts without a problem, and, for example, when I stop at traffic lights and get going again, it does not behave this way.
The transmission had an oil change just a moment ago. The clutch isn't slipping, so in other ways, it's working like it's expected to.
With the current way, the software has the capability to calibrate the transmission.
Which/What of the above actions should I execute?
And in which order?
And is there a test/calibration drive needed to do after any of these actions?
I currently have an HEX-CAN interface, is this adequate to execute these tasks?
Thanks for any possible comments and advice.
DrPeter
16.4905° S, 151.7375° W
We have Basic Settings Procedures for many transmissions. To ensure we provide you with the correct procedure, we will need an Auto-Scan of the vehicle in question.
Thank you,
drpeter
pingu
Finland
HUC-2H
Could not do a scan just for this, but this is an older scan, when it had some issues with the steering angle sensor, which is now although sorted.
I hope this is enought for this need.
Windows Based VAG/VAS Emulator Running on Windows 8 x64
 VCDS Version: Release 23.11.0(x64) Data version: 20231027 DS351.0
 Dealer/Shop Name:
 Workshop Code: 000 00000 000000
 Self-Diagnosis Log
 Saturday,31,August,2024,15:58:53:25691
 VIN: WVWZZZ3CZGE076154 License Plate: ENX-163
 Mileage: 199234km-123798mi Repair Order:
 Chassis Type: 3C-VW48 (5Q0)
 Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 2B 42 44 52 55 5F 6D
 A5 BB BC
 VIN: WVWZZZ3CZGE076154 Mileage: 199234km-123798miles
Time: 18:51:10
Self-Diagnosis Log
 Page 2
 Address 01: Engine (J623-CRLB) Labels:. 04L-907-309-V1.clb
 Part No SW: 04L 906 026 ET HW: 04L 907 309 R
 Component: R4 2.0l TDI H22 1990
 Revision: B5H22--- CVN: 49FF1F44
 Coding: 011D003A03641D083000
 Shop #: WSC 11200 205 00000
 ASAM Dataset: EV_ECM20TDI01104L906026ET 002002
 ROD: EV_ECM20TDI01104L906026ES_002_VW48.rod
 VCID: 000482849B675891C3-8054
 VINID: 9E69EAAAA0D3A975401C604510D01BE1D0
 17158 - Implausible Data Received from ESP Control Module
 U0416 00 [00101100] - -
 Mileage: 198477 km
 Date: 2024.08.25
  Engine RPM: 1262.00 /min
 Normed load value: 49.8 %
 Coolant temperature: 86 °C
 Intake air temperature: 67 °C
 Voltage terminal 30: 14.400 V
 Drivetrain coordinator: brake fault status-Bits 0-7: 4
 Acceleration: 0.129 m/s2
 U0428 00 [00101000] - -
 Mileage: 198477 km
 Date: 2024.08.25
 Time: 18:51:10
 Engine RPM: 1212.50 /min
 Normed load value: 47.8 %
Self-Diagnosis Log
Page 3
 Cruise Control System (CCS): status-Bits 0-7: 7
 Part No SW: 0D9 300 041 A HW: 02E 927 770 AQ
 Component: DQ250-6F MQB H53 4801
 Revision: 06253104 Serial number: TFK01508252149 CVN: 000098E9
 Shop #: WSC 05311 115 00066
 ROD: EV_TCMDQ250021.rod
 VCID: 1628C4DCE9E3C62109-8042
 No fault code found. -------------------------------------------------------------------------------
Self-Diagnosis Log
 Page 4
 Part No SW: 3Q0 907 379 AB HW: 3Q0 907 379 G
 Component: ESC H42 0723
 Revision: 00000000 Serial number: 62545000001500
 Coding: 0FEC6A8F34270B720778060541C749F0562CD0E0608292F13862F078C202
 Shop #: WSC 00015 115 08193
 VCID: 7AF0F06CFDBB02418D-802E
 0292 - Steering angle sensor
 B1168 04 [00001000] - Internal System Fault
 Reset counter: 254
 Mileage: 198477 km
 Date: 2024.08.25
 Time: 18:51:10
 16401 - Tire Pressure Warning
 C102D 00 [00001000] - -
 Reset counter: 34
 Mileage: 198463 km
 Date: 2024.08.25
 Time: 18:19:14
 16412 - Display for Tire Pressure Monitoring
 C1146 02 [10001001] - Signal Failure
 Reset counter: 254
 Mileage: 198477 km
 Date: 2024.08.25
 Time: 18:51:20
 16413 - Display for Tire Pressure Monitoring
 Reset counter: 254
 Mileage: 198477 km
Self-Diagnosis Log
 Page 5
 Date: 2024.08.25
 Time: 18:51:20
 16418 - Display for Tire Pressure Monitoring
 C1146 02 [00001000] - Signal Failure
 Reset counter: 39
 Mileage: 198477 km
 Date: 2024.08.25
 Time: 18:51:20
 PartNoSW:3Q0959435C HW:3Q0959435C
 Component: VWKESSYMQB 036 0709
 Revision: 00036000 Serial number: 0378966778 Dataset Number: V03935225QE 0001
 Coding: 0F00000703
 Shop #: WSC 05311 115 00309
 ROD: EV_KessyHellaMQBAB.rod
 VCID: 3A70306CBD3BC241CD-806E
 65794 - Function Restricted due to Insufficient Voltage
 U1400 00 [00001000] - -
 Reset counter: 23
 Mileage: 197648 km
 Date: 2024.02.08
 Time: 12:46:58
 221700 - Sensor for Rear Lid/Hatch Opening
 B1303 31 [00001001] - No Signal
 Reset counter: 5
 Mileage: 173393 km
 Date: 2023.01.25
 Time: 20:08:25
Self-Diagnosis Log
 Page 6
 PartNoSW:5G1907044J HW:5G1907044J
 Component: Climatronic H04 1202
 Revision: 00001K10 Dataset Number: 0000
 Coding: 12020104204101011115500C0010180A
 ASAM Dataset: EV_ACClimaBHBVW37X 005137
 VCID: 2F661138767917E96A-807A
 Fresh air blower control module (front): A/C pressure/coolant temperature sensor: Air quality sensor:
Humidity sensor: exterior:
 328452 - Motor for Rear Temperature Flap
 B108E 71 [00001000] - Actuator Stuck
 Fault Frequency: 13
 Reset counter: 36
 Mileage: 196057 km
 Date: 2024.01.08
 Time: 18:47:25
 Voltage terminal 30: 14.4 V
 Outside temperature: -6.0 °C
 Inside temperature: 22.8 °C
 Rear temperature flap: actual value: 0.0 %
 Rear temperature flap: actual value: 179
 Rear temperature flap: specified value: 184
 263425 - Air Quality Sensor
 B10AF 04 [00001000] - Internal System Fault
 Reset counter: 7
 Mileage: 193128 km
 Date: 2023.11.16
 Time: 23:38:00
 Voltage terminal 30: 14.5 V
 System run time-Engine running time: 40 s
 System run time-Terminal 15 on: 40 s
Time: 12:45:38
Self-Diagnosis Log
 Page 7
 B10CD 00 [00001000] - -
 Reset counter: 22
 Mileage: 197648 km
 Date: 2024.02.08
  Voltage terminal 30: 11.5 V
 CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 1
 CAN input signal(s) status-Back-up lamp: OFF
 263682 - Exterior Air Quality/Humidity Sensor
 B137A 31 [00001000] - No Signal
 Fault Frequency: 13
 Reset counter: 39
 Mileage: 197154 km
 Date: 2024.01.28
 Time: 12:13:50
 Outside temperature: -0.5 °C
 System run time-Engine running time: 255 s
 System run time-Terminal 15 on: 255 s
Self-Diagnosis Log
 Page 8
 Part No SW: 5Q0 937 086 AK HW: 5Q0 937 086 AK
 Revision: -------- Serial number: 86583008150641 Dataset Number: V03935225VC 0001
 Coding: 00011E46C2C102FF57C44014001C572C1C80000000000000000000000000
 ROD: EV_BCMBOSCH_015.rod
 VCID: 030E8D888A714389DE-8056
  Subsystem 1 - Part No SW: 3G1 955 119 A HW: 3G1 955 119 Labels: 5QX-955-119-V1.CLB
 Component: WWS 150802 042 0607
 Serial number: 150818024131
 Component: RLHS 037 0059
 Serial number: S5Y15M09D16H23M39S35
 Coding: 90A8DD
 Subsystem 3 - Part No SW: 3G0 941 633 H HW: 3G0 941 633 H
 Component: E1 - LDS MQB H01 0032
 Serial number: 03 06 2015 10000547
 Humidity sensor: interior:
 204290 - Remote key 1
 B1479 18 [00001000] - Current Too Low
 Mileage: 195349 km
 Date: 2023.12.25
 Time: 15:33:39
 Terminal 15 status: OFF
 Terminal 50 status: OFF
 CAN-Bus_aktiv: OFF
 OFF: Not operated
 Position lamps: Not operated
204546 - Remote key 2
Self-Diagnosis Log
 Page 9
 Low beam: Not operated
 last_wakeup: Pin A31 Lock/Unlock Taster: Tankklappenrückmeldung
 Voltage: 12.5 V
 Outside temperature: -50.0 °C
  B147A 18 [00001001] - Current Too Low
 Reset counter: 0
 Mileage: 184420 km
 Date: 2023.07.11
 Time: 13:41:58
 CAN-Bus_aktiv: OFF
 OFF: Not operated
 Voltage: 12.6 V
 203016 - Unlock Switch in Rear Lid Handle
 B140B 29 [00001000] - Signal Implausible
Self-Diagnosis Log
 Page 10
 Part No SW: 5QA 919 298 HW: 5Q0 919 298 C
 Component: PLA 3.0 12KH08 0161
 Serial number: 000305183615253 Dataset Number: V03935223VR 0001
 Coding: 0271061851
 ASAM Dataset: EV_EPHVA2CAU3700000 009017
 VCID: 0D1AABB0DC3505F9B8-8058
 1081105 - Switch for Parking Aid
 B107F 11 [00001000] - Short to Ground
 Reset counter: 39
 Mileage: 199192 km
 Date: 2024.08.30
 Time: 13:02:37
 13679372 - Databus
 Reset counter: 39
 Mileage: 198477 km
 Date: 2024.08.25
 Time: 18:51:10
 13637426 - Databus
 Reset counter: 39
 Mileage: 198477 km
 Date: 2024.08.25
 Time: 18:51:10
 13679386 - Databus
Self-Diagnosis Log
 Page 11
  Reset counter: 39
 Mileage: 198477 km
 Date: 2024.08.25
 Time: 18:51:10
Control Module temperature: 38 °C
Self-Diagnosis Log
 Page 12
 Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
 PartNoSW:3Q0907572B HW:3Q0907572B
 Dataset Number: V03935222ZA 0001
 Coding: 320067C351FFC428949C804D
 ROD: EV_ACCBOSCHVW48X.rod
 VCID: 346C1E549F5F343117-8060
 10 Faults Found:
 2052 - Databus
 Reset counter: 39
 Mileage: 198477 km
 Date: 2024.08.25
 Time: 18:51:09
  Voltage terminal 15: 14.0 V
 Longitudinal_acceleration_vehicle_reference: 0.00 m/s2
 0795 - Databus
 Reset counter: 39
 Mileage: 198477 km
 Date: 2024.08.25
 Time: 18:51:10
 Voltage terminal 15: 13.9 V
 0803 - Databus
Self-Diagnosis Log
 Page 13
 Reset counter: 39
 Mileage: 198477 km
 Date: 2024.08.25
 Time: 18:51:10
 Voltage terminal 15: 14.1 V
 2101 - Databus
 Reset counter: 39
 Mileage: 198477 km
 Date: 2024.08.25
 Time: 18:51:09
 0836 - Databus
 Reset counter: 39
 Mileage: 173228 km
 Date: 2023.01.23
 Time: 14:21:40
 Control Module temperature: 22 °C
 Voltage terminal 15: 11.3 V
 1538 - Sensor for Automatic Distance Control
 C110B F0 [00001000] - Limited Visibility
Control Module temperature: 8 °C
Self-Diagnosis Log
 Page 14
 Reset counter: 15
 Mileage: 197390 km
 Date: 2024.02.01
 Time: 15:51:54
  Voltage terminal 15: 13.8 V
 Velocity_vehicle_reference: 9.16 m/s
 Longitudinal_acceleration_vehicle_reference: 0.56 m/s2
 1542 - Sensor for Automatic Distance Control
 Reset counter: 15
 Mileage: 197390 km
 Date: 2024.02.01
 Time: 15:51:54
 1127 - Databus
 Reset counter: 36
 Mileage: 199114 km
 Date: 2024.08.28
 Time: 18:01:59
 1219 - Databus
Control Module temperature: 28 °C
 Voltage terminal 15: 12.5 V
Self-Diagnosis Log
 Page 15
 Reset counter: 35
 Mileage: 198828 km
 Date: 2024.08.27
 Time: 18:09:42
 Control Module temperature: 36 °C
 Voltage terminal 15: 14.5 V
 Velocity_vehicle_reference: 16.59 m/s
 Longitudinal_acceleration_vehicle_reference: 0.13 m/s2
 2068 - Databus
 Reset counter: 39
 Mileage: 198477 km
 Date: 2024.08.25
 Time: 18:51:10
Self-Diagnosis Log
 Page 16
 Part No SW: 3Q0 959 655 BB HW: 3Q0 959 655 BB
 Component: Airbag VW20 013 0195
 Revision: -------- Serial number: 003STPGH2XH+ Dataset Number: 3G0003V____ 0037
 Coding: 88CCC000008000005C5400CC000800000065
 Shop #: WSC 05314 000 00001
 ROD: EV_AirbaVW20TS6VW48X.rod
 VCID: 7F060178E6992769BA-802A
  Subsystem 1 - Part No SW: ----------- HW: 454 003 108 15
 Serial number: 3576U00000011B48161+
 Subsystem 2 - Part No SW: ----------- HW: 454 003 108 15
 Serial number: 3586U000000A6A58161D
 Subsystem 3 - Part No SW: ----------- HW: 454 802 608 15
 Serial number: 3516R127CF9070000009
 Subsystem 4 - Part No SW: ----------- HW: 454 803 008 15
 Serial number: 3526R4650F8070000002
 Subsystem 5 - Part No SW: ----------- HW: 454 801 808 15
 Serial number: 3556VF9A8D607000000W
Self-Diagnosis Log
 Page 17
 Part No SW: 3Q0 953 521 AM HW: 5Q0 953 569 B
 Component: Lenks.Modul 100 0205
 Revision: FF034034 Serial number: 20150908500238 Dataset Number: 3G0094V____ 0001
 Coding: 0410
 Shop #: WSC 00015 115 00001
 ASAM Dataset: EV_SMLSVALEOMQBLRH 001005
 ROD: EV_SMLSVALEOMQBLRH.rod
 VCID: 7BFEF568F2813B4996-802E
 PartNoSW:3G0920751A HW:3G0920751A
 Component: KOMBI 301 6421
 Coding: 07A409182F84000800886B011001000000000000
 VCID: 234EED082AB1A389FE-8076
Coding: 9309
Self-Diagnosis Log
 Page 18
 Address 18: Aux. Heat (J364) Labels:| 5Q0-963-272.clb
 PartNoSW:5Q0963272E HW:5Q0963272E
 Component: STH-MQB 007 0072
 VCID: 38742A648337D0513B-806C
 Auxiliary heating remote control:
 Subsystem 1 - Part No SW: 5Q0 963 513 A HW: 5Q0 963 513 A
 Component: R149 T91-LIN 003 0301
 Serial number: 00000000000001209076
  0040 - Shutdown by Battery Management Module
 B1381 00 [00001000] - -
 Reset counter: 23
 Mileage: 197686 km
 Date: 2024.02.09
 Time: 14:46:46
 Parking heater: operating condition: OFF
 71
 Coolant temperature of parking heater: -18 °C
 Coolant temperature: -22 °C
 Engine running status: not detected
 Fuel level: 14 l
 Heating performance: 0 W
Serial number: 29150001583530095323
Self-Diagnosis Log
 Part No SW: 5Q0 907 530 AF HW: 5Q0 907 530 M
 Component: GW MQB High 212 2227
 Revision: -------- Serial number: 01091510801297 Dataset Number: 3G0067V____ 2213
 Coding: 030300045F017300FB00025A1C0F00010001070000000000000000000000
 GVL: 01543C0008000600408C90000004C80000000000000000000000000000000000
 ROD: EV_GatewConti_013.rod
 VCID: 75EAE350D4A56D39E0-8020
 Generator:
Page 19
  Subsystem 2 - Part No SW: 5G0 959 442 K HW: 5G0 959 442 K Labels: 3C8-959-537.CLB
 Component: E221__MFL-DC1 H16 0040
  Coding: 2FFFFF
 Subsystem 3 - Part No SW: 3Q0 915 181 A HW: 3Q0 915 181 A
 Component: J367-BDMHella H04 8050
 Serial number: 5414707503
 Analog clock:
 Subsystem 4 - Part No SW: 3G0 919 204 C HW: 3G0 919 204 C
 Component: Analoguhr 209 2002
 131699 - Control unit for information electronics 1
 U1054 00 [00001000] - No Communication
 Reset counter: 27
 Mileage: 197812 km
 Date: 2024.02.12
 Time: 19:19:40
 Terminal 30 power supply: 11.6 V
 Terminal 15: OFF
Self-Diagnosis Log
 Page 20
 Address 2B: Steer. Col. Lock (J764) Labels:| 1EA-905-861.clb
 Part No SW: 3Q0 905 861 HW: 3Q0 905 861
 Component: ELV-MQBB H05 0031
 Serial number: 15000072149004
 Coding: 0800000000000000
 ROD: EV_ELVMarquMQBB_VW37.rod
 VCID: 71E2D740A0CD41193C-8024
 PartNoSW:5Q0959593E HW:5Q0959593B
 Component: TSG FS 020 0041
 Serial number: 180815BHI05141 Dataset Number: V03935272KC 0001
 Coding: 003F1B20D000020000001000
 VCID: 438E4D88CAF183899E-8016
Self-Diagnosis Log
 Page 21
 Address 44: Steering Assist (J500) Labels:| 5Q0-909-143.clb
 PartNoSW:5Q0909143K HW:5Q0909143E
 Component: MQB_PP_APA 204 2033
 Revision: 00000000 Serial number: 0000366613 Dataset Number: 3G0074V____ 0137
 Coding: 01010010005001
 Shop #: WSC 00015 115 00309
 ASAM Dataset: EV_SteerAssisVWBSMQBA 008027
 ROD: EV_SteerAssisVWBSMQBA_008.rod
 VCID: 3B7E3568B201FB49D6-806E
 5263361 - Function Limitation due to Missing Initialization
 B2020 00 [00001000] - -
 Reset counter: 39
 Mileage: 198477 km
 Date: 2024.08.25
 Time: 18:51:10
 Write only channel
 PartNoSW:5Q0959592E HW:5Q0959592B
 Component: TSG BFS 020 0041
 Serial number: 200815BHK11933 Dataset Number: V03935268PR 0001
 Coding: 003F1120D000020000001000
 VCID: 4280488CD5EB8A8195-8016
 65639 - Motor for Window Regulator
 B1487 29 [00001000] - Signal Implausible
 Reset counter: 39
 Mileage: 199171 km
 Date: 2024.08.30
 Time: 11:47:08
Self-Diagnosis Log
 Page 22
 PartNoSW:7P6907357C HW:7P6907357B
 Component: AFS-ECU H01 0110
 Coding: 039A00004F200200
 Shop #: WSC 05311 000 08193
 ROD: EV_HeadlRegulAFSMQBMLB_VW48.rod
 VCID: 3F864178A619E769FA-806A
 Subsystem 1 - Part No SW: 7PP 941 572 AB HW: 7PP 941 572 A Labels: 3D0-941-329.CLB
 Component: LED LeiMo li. H09 0003
 Coding: E02400
 Subsystem 2 - Part No SW: 7PP 941 572 AB HW: 7PP 941 572 A Labels: 3D0-941-329.CLB
 Component: LED LeiMo re. H09 0003
 Coding: E02400
 Subsystem 3 - Part No SW: 3G0 941 329 _ HW: 3G0 941 329 _ Labels: 3D0-941-329.CLB
 Component: LeiMo links H02 0003
 Coding: E02400
 Subsystem 4 - Part No SW: 3G0 941 329 _ HW: 3G0 941 329 _ Labels: 3D0-941-329.CLB
 Component: LeiMo rechts H02 0003
 Coding: E02400
 13705995 - Databus
 Reset counter: 29
 Mileage: 197994 km
 Date: 2024.02.12
 Time: 22:14:02
 13705992 - Databus
 Reset counter: 39
 Mileage: 198477 km
Time: 18:51:09
Self-Diagnosis Log
 Page 23
 Date: 2024.08.25
 Part No SW: 3Q0 035 846 HW: 3Q0 035 846
 Component: MU-S-N-ER 820 0627
 Serial number: Dataset Number: 5G0CV1v____ 0001
 Coding: 02840201FF00000051110001000808001F0100C4012001008F
 ROD: EV_MUStd4CDELP_VW26.rod
 VCID: 6ED8CC3CB1F35EE121-803A
 Subsystem 1 - Part No SW: 3G0 919 605 D HW: 3G0 919 605 D
 Component: ABT_Std-2_Nav H43 4064
 Serial number: VWZ6Z9R2550276
 Subsystem 2 - Part No SW: V03 825 254 AJ HW: -----------
 Component: ECE DL3 2023 --- 1910
 PartNoSW:5Q0959107G HW:5Q0959107G
 Component: HDSG-Modul H12 0250
 Revision: -------- Serial number: 30205142500000 Dataset Number: V03935218Q 0001
 Coding: 0208
 ASAM Dataset: EV_DeckLidCONTIAU736 001011
 VCID: 3C7C3674B70FFC71DF-8068
Self-Diagnosis Log
 Part No SW: 3Q0 980 654 HW: 3Q0 980 654
 Component: MQB_B_MFK H04 0010
 Serial number: 08091511K11361 Dataset Number: 3G0HL1V____ 1211
 Coding: 000408020000040100221344C050A10010000E200040
 VCID: 74ECDE54DFDF7431D7-8020
 1123205 - Databus
 Reset counter: 33
 Mileage: 196618 km
 Date: 2024.01.23
 Time: 09:22:06
 Control Module temperature: 11 °C
 Outside temperature: 2.5 °C
 Vehicle speed: 6.29 km/h
 System run time: 4.7 s
 Voltage terminal 15: 13.1 V
 mid: 02 D9
 Status of camera: operational
 Engine_Running_Info: 1
 Software_Info_4: 0
 Software_Info_3: 1
 Software_Info_2: 0
 Software_Info_1: 0
 1123206 - Databus
 Reset counter: 33
 Mileage: 196618 km
 Date: 2024.01.23
 Time: 09:22:06
Page 24
Software_Info_4: 0
Self-Diagnosis Log
 Page 25
  mid: 02 D8
  Software_Info_3: 1
 Software_Info_2: 0
 Software_Info_1: 0
 1123173 - Databus
 Reset counter: 39
 Mileage: 198477 km
 Date: 2024.08.25
 Time: 18:51:10
 Control Module temperature: 37 °C
 Outside temperature: 22.5 °C
 Vehicle speed: 0.00 km/h
 System run time: 12.1 s
 mid: 02 DD
 Software_Info_4: 0
 Software_Info_3: 1
 Software_Info_2: 0
 Software_Info_1: 0
 1123080 - Databus
 Reset counter: 39
 Mileage: 198477 km
 Date: 2024.08.25
 Time: 18:51:10
 mid: 02 A8
Self-Diagnosis Log
 Page 26
 Software_Info_4: 0
 Software_Info_3: 1
 Software_Info_2: 0
 Software_Info_1: 0
 1122664 - Databus
 Reset counter: 36
 Mileage: 199114 km
 Date: 2024.08.28
 Time: 18:01:59
 Control Module temperature: 29 °C
 Outside temperature: 18.5 °C
 System run time: 219.3 s
 Voltage terminal 15: 12.3 V
 mid: 01 F7
 Software_Info_4: 0
 Software_Info_3: 1
 Software_Info_2: 0
 Software_Info_1: 0
 PartNoSW:5Q0959595E HW:5Q0959595B
 Component: TSG HFS 020 0041
 Serial number: 200815BHK08194 Dataset Number: V03935272KD 0001
 Coding: 000E11200100020000001000
 Shop #: WSC 29325 001 1048576
 VCID: 458A5390C4C5BDB9B0-8010
Self-Diagnosis Log
 Page 27
 Component: TSG HBFS 020 0041
 Serial number: 200815BHK08191 Dataset Number: V03935272QC 0001
End-------------------------(Elapsed Time: 06:43)--------------------------
This scan is difficult to read ; I believe you used the "print" function to generate this scan. Please use the copy and paste option , better still , follow these instructions:
pingu
Finland
HUC-2H
I guess the issue is not that important then?
Quite lovely approach for this.
My garage is else where from where I live. And at times life has means to affect how can one spend the time available.
So unfortunately I've not had the time available to drive to my garage and do a full scan just for this. So instead I used a scan few months back.
The car does not have any errors what comes to the transmission, which was the main reason I decided to try is a scan few months back would do.
pingu
Finland
HUC-2H
Okay, so here is a fresh new scan from the car in question.
Monday,02,December,2024,20:05:44:25691
VCDS Version: 24.7.1.0 (x64)
          A5 BB BC
VIN: WVWZZZ3CZGE076154   Mileage: 205803km-127880miles
   ROD: EV_ECM20TDI01104L906026FL.rod
   VCID: 000482849B675896CB-8054
   VCID: 1628C4DCE9E3C62601-8042
   ROD: EV_Brake1UDSContiMK100IPB_034_VW37.rod
   VCID: 7AF0F06CFDBB024685-802E
                    Reset counter: 102
                    Mileage: 203971 km
                    Date: 2024.10.27
                    Time: 12:35:29
   Part No SW: 3Q0 959 435 C    HW: 3Q0 959 435 C
   Coding: 0F00000703
   VCID: 3A70306CBD3BC246C5-806E
                    Reset counter: 35
                    Mileage: 202816 km
                    Date: 2024.10.06
                    Time: 12:30:58
   Part No SW: 5G1 907 044 J    HW: 5G1 907 044 J
   VCID: 2F661138767917EE62-807A
   Air quality sensor:
          B108E 71 [00001001] - Actuator Stuck
                    Fault Frequency: 12
                    Reset counter: 91
                    Mileage: 202251 km
                    Date: 2024.10.02
                    Time: 23:07:03
                    Voltage terminal 30: 14.2 V
                    Outside temperature: 16.0 °C
                    Inside temperature: 20.5 °C
                    Rear temperature flap: actual value: 24
                    Rear temperature flap: specified value: 243
                    Reset counter: 109
                    Mileage: 204612 km
                    Date: 2024.11.02
                    Time: 15:27:23
                    Voltage terminal 30: 14.3 V
                    Outside temperature: 4.0 °C
                    System run time-Engine running time: 36 s
                    System run time-Terminal 15 on: 36 s
65544 - Button(s) or Switch(es) in Operating Device
          B1312 07 [00001000] - Mechanical Failure
                    Reset counter: 138
                    Mileage: 204488 km
                    Date: 2024.11.02
                    Time: 14:03:39
                    Voltage terminal 30: 14.6 V
                    Outside temperature: 1.5 °C
                    Pressing a button-Defrost: Not operated
                    Pressing a button-Recirculating air: Not operated
                    Pressing a button-Rear window defogger: Not operated
                    Pressing a button-AC: Not operated
                    Pressing a button-Left heated seat: Not operated
                    Pressing a button-Right heated seat: Not operated
                    Pressing a button-OFF: Not operated
                    Pressing a button-Parking heater: Not operated
                    Pressing a button-AUTO: Not operated
                    Pressing a button-SYNC: Not operated
                    Pressing a button-Menu: operated
                    Pressing a button-Footwell air distribution: Not operated
                    Pressing a button-Upper body vent air distribution: Not operated
                    Pressing a button-Air distribution up: Not operated
                    Pressing a button-AC MAX: Not operated
                    Fault Frequency: 39
                    Reset counter: 135
                    Mileage: 202251 km
                    Date: 2024.10.02
                    Time: 23:07:06
                    System run time-Engine running time: 44 s
                    System run time-Terminal 15 on: 44 s
   VCID: 030E8D888A71438ED6-8056
   Coding: 90A8DD
          B147A 18 [00001000] - Current Too Low
   Coding: 0271061851
   VCID: 0D1AABB0DC3505FEB0-8058
   Part No SW: 3Q0 907 572 B    HW: 3Q0 907 572 B
   VCID: 346C1E549F5F34361F-8060
0836 - Databus
                    Reset counter: 143
                    Mileage: 202564 km
                    Date: 2024.10.05
                    Time: 08:47:11
                    Control Module temperature: 5 °C
                    Voltage terminal 15: 11.4 V
                    Reset counter: 135
                    Mileage: 205574 km
                    Date: 2024.11.23
                    Time: 21:33:13
                    Control Module temperature: 14 °C
                    Voltage terminal 15: 14.4 V
                    Velocity_vehicle_reference: 10.15 m/s
                    Longitudinal_acceleration_vehicle_reference: 0.34 m/s²
1396 - Sensor for Automatic Distance Control
                    Reset counter: 135
                    Mileage: 205577 km
                    Control Module temperature: 13 °C
                    Voltage terminal 15: 12.2 V
                    Status_ACC_System: ACC_Init
                    Reset counter: 135
                    Mileage: 205575 km
                    Date: 2024.11.23
                    Time: 21:34:06
                    Voltage terminal 15: 14.3 V
                    Velocity_vehicle_reference: 10.72 m/s
                    Longitudinal_acceleration_vehicle_reference: 2.38 m/s²
1397 - Sensor for Automatic Distance Control
                    Reset counter: 135
                    Mileage: 205577 km
   VCID: 7F060178E699276EB2-802A
   Coding: 0410
   VCID: 7BFEF568F2813B4E9E-802E
   Part No SW: 3G0 920 751 A    HW: 3G0 920 751 A
   VCID: 234EED082AB1A38EF6-8076
16777022 - Function Restricted due to Interrupted Communications
          U1110 00 [00001000] - -
                    Reset counter: 143
                    Mileage: 205767 km
                    Date: 2024.11.28
                    Time: 20:53:01
   Part No SW: 5Q0 963 272 E    HW: 5Q0 963 272 E
   Coding: 9309
   VCID: 38742A648337D05633-806C
   VCID: 75EAE350D4A56D3EE8-8020
   Generator:
   Coding: 2FFFFF
   Analog clock:
   VCID: 71E2D740A0CD411E34-8024
   ROD: EV_DCUDriveSideEWMAXKLO.rod
   VCID: 438E4D88CAF1838E96-8016
   Part No SW: 5Q0 909 143 K    HW: 5Q0 909 143 E
   ROD: EV_SteerAssisVWBSMQBA_008_VW48.rod
   VCID: 3B7E3568B201FB4EDE-806E
   ROD: EV_DCUPasseSideEWMAXKLO.rod
   VCID: 4280488CD5EB8A869D-8016
   VCID: 3F864178A619E76EF2-806A
   Coding: E02400
   Coding: E02400
   Coding: E02400
   Coding: E02400
13705995 - Databus
                    Fault Frequency: 13
                    Reset counter: 133
                    Mileage: 202391 km
                    Date: 2024.10.03
                    Time: 20:00:33
5538298 - LED Headlamp; Left
          C1177 F0 [00001000] - Over-Temp Protection Active
                    Reset counter: 131
                    Mileage: 205504 km
                    Date: 2024.11.19
                    Time: 20:30:18
5538554 - LED Headlamp; Right
          C1178 F0 [00001000] - Over-Temp Protection Active
                    Reset counter: 131
                    Mileage: 205504 km
                    Date: 2024.11.19
                    Time: 20:34:23
   VCID: 6ED8CC3CB1F35EE629-803A
7169 - Function Restricted due to Missing Message(s)
          U1111 00 [00001000] - -
                    Reset counter: 138
                    Mileage: 204488 km
                    Date: 2024.11.02
                    Time: 14:03:22
                    Voltage terminal 30: 14.7 V
                    BAP-BAP_Function_ID: 16
   Part No SW: 5Q0 959 107 G    HW: 5Q0 959 107 G
   Coding: 0208
   ROD: EV_DeckLidCONTIAU736_VW48.rod
   VCID: 3C7C3674B70FFC76D7-8068
   VCID: 74ECDE54DFDF7436DF-8020
   ROD: EV_DCURearDriveMAXKLO.rod
   VCID: 458A5390C4C5BDBEB8-8010
   ROD: EV_DCURearPasseMAXKLO.rod
End-------------------------(Elapsed Time: 06:28)--------------------------
