Resolved How to code new module for MK7 VW GTI
Resolved
94LSC
Upstate NY, USA
C?ID=293997
I guess I'm still waiting for my Verification. I bought my HEX+CAN directly from Ross-Tech. (It's the third version I've purchased.)
Here's my question: My Rear Left Blind Spot Radar Module 5Q0907685B was damaged so I bought a used replacement. Unfortunately, I didn't do my research and thought I could just plug it in and then set the coding so it would work with the car. I never had any issues with the car before this, so I never got a baseline scan. When I tried plugging the new Module in, I had one of the ABS sensors unplugged and I got what seemed like 20 faults and I was afraid I killed my car. After plugging everything in except for the new module, I was able to reset all the faults except for the ones related to the Blind Spot Radar Module. How does one go about programming the car to accept the replacement Module? I did save the current scan. I'm afraid to plug the replacement module back in. Will it wipe any of my coding if I do? If I don't have the original coding, is there a way to change the coding so the replacement Module will work with my car? PLEASE HELP!
Derek
UK (ilexa)
C?ID=56983
Hello
Please post the old scan so we can see the vehicle configuration
Ideally you'd also post a scan with the new part fitted, but I can understand you don't want to risk that again yet, so that can hopefully wait until someone with good knowledge of this system looks at your scan
Best regards
Derek
No sir, the HEX+CAN with serial number HCxxx296 was not purchased directly from Ross-Tech. Moreover, the e-mail address you used to join the forum does not exist in our customer records, and while we have one other customer with your surname, that person is nowhere near upstate NY. Please see:
I believe you are in Category 2.
You should always make a baseline scan of any car you own (or any car you do any work on).
Please post it.
94LSC
Upstate NY, USA
C?ID=293997
My mistake. After searching some more, I see I bought it from AWE Tuning. I'll resubmit the form,
94LSC
Upstate NY, USA
C?ID=293997
Now that I know, I will always do a baseline scan. For what it's worth, my car is a Manual transmission Autobahn with ACC.
Here is my scan after I got all the faults cleared with the Rear Left Blind Spot Radar Module disconnected. Let me know if I messed anything up.
Monday,25,November,2024,11:17:19:32137
VCDS Version: 24.7.1.0 (x64)
VIN: 3VW547AU1HM04xxxx   License Plate:
Mileage: 119391km-74186mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 05 08 09 13 14 15 16 17 19 2B 32 3C 42 44 47 52 55 5F
          75 A9
VIN: 3VW547AU1HM04xxxx   Mileage: 119391km-74186miles
Address 01: Engine (J623-CXCB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 9C0 BB0 1    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0001
   Revision: --H13---    CVN: 5D41D716
   Coding: 091900122444002F1000
   Shop #: WSC 00066 790 00218
   ASAM Dataset: EV_ECM20TFS0205G09C0BB01 001003
   ROD: EV_ECM20TFS0205G09C0BB01.rod
   VCID: 3D70B7F7AC0C277EE0-8068
   VINID: 0E69C510746505874010824408B698C61A
No ASAM data for: "EV_ECM20TFS0205G09C0BB01" (VW37)
Readiness: 1010 0101
Address 03: ABS Brakes (J104)       Labels:* 5Q0-907-379-ESP-V1.clb
   Part No SW: 5Q0 614 517 AQ    HW: 5Q0 614 517 AF
   Component: ESC           H62 0400
   Revision: 00000000    Serial number: 50047000000065
   Coding: 01FA6BA1542409744080020440C56880D62A900240021636144350D1C089430000000012121212B835351919323200
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 036010
   ROD: EV_Brake1UDSContiMK100ESP_036_VW37.rod
   VCID: 000E0E039B7E8A96CB-8054
   Part No SW: 5Q0 959 435 B    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0710
   Revision: 00021000    Serial number: 0425878648 Dataset Number: V03935252QK 0001
   Coding: 032C0C
   VCID: 3B74B9EFB218294EDE-806E
   Part No SW: 5GM 907 044 E    HW: 5GM 907 044 E
   Revision: 00001K04    Dataset Number: 0000
   Coding: 00020014200100000004000012111402
   VCID: 4682D81BF9DA64A6B1-8012
   Part No SW: 5Q0 937 087 AN    HW: 5Q0 937 087 AN
   Component: BCM PQ37BOSCH 032 0223
   Revision: --------    Serial number: C864040117005K Dataset Number: V03935250TU 0001
   Shop #: WSC 00066 790 00225
   ASAM Dataset: EV_BodyContrModul1UDSBosc 017002
   ROD: EV_BCMBOSCH_017.rod
   VCID: 071C151FBE50BDAE8A-8052
   Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    161119  043 0551
   Serial number: 97022066161203125541
   Component: RLHS  042 0105
   Serial number: S3Y16M12D21H17M46S42
   Coding: 00A8DD
   Sunroof control module:
   Subsystem 3 - Part No SW: 5GD 959 591 A    HW: 5GD 959 591 A
   Component: J245 PS60.006  H07 0170
   Serial number: 03690832510111162249
   Coding: 181803
   Humidity sensor: interior:
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V2.clb
   Part No SW: 5Q0 907 572 H    HW: 5Q0 907 572 H
   Dataset Number: V03935253UC 0205
   Coding: 2D00008141FFC428949C810510301600000000000000000000
   VCID: 3C76BAF3B7162E76D7-8068
2172 - Databus
                    Reset counter: 92
                    Mileage: 119388 km
                    Date: 2024.11.24
                    Time: 13:05:15
                    Control Module temperature: 23 °C
                    Voltage terminal 15: 11.5 V
2068 - Databus
                    Reset counter: 92
                    Mileage: 119388 km
                    Date: 2024.11.24
                    Time: 13:05:15
   Serial number: 16111641350444 Dataset Number: V03935229UY 0003
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 387EA6E3832E025633-806C
   Serial number: 003GCR070FMG Dataset Number: 5GM003V____ 0046
   VCID: 479CD51FFED07DAE4A-8012
   Serial number: IBH000000000006EWQ0
   Coding: 303131
   Subsystem 2 - Part No SW: -----------    HW: 480 001 512 16
   Serial number: 35700000000A8B30702D
   Subsystem 3 - Part No SW: -----------    HW: 480 001 612 16
   Serial number: 35800000000C0AAC002J
   Subsystem 4 - Part No SW: -----------    HW: 480 402 012 16
   Serial number: 3510001C3237EE316694
   Subsystem 5 - Part No SW: -----------    HW: 480 402 012 16
   Serial number: 3520001AF237EE333133
   Subsystem 6 - Part No SW: -----------    HW: 480 401 012 16
   Serial number: 3550002A923A3F865202
   Subsystem 7 - Part No SW: -----------    HW: 480 401 012 16
   Serial number: 3560002A923A3F850386
   Part No SW: 5Q0 953 507 HL    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 19121604400936
   Coding: 0400
   ROD: EV_SMLSKLOMQB_018_VW37.rod
   Part No SW: 5G1 920 856 B    HW: 5G1 920 856 B
   Component: KOMBI         344 8311
   Coding: 0BAD0912BD88CF0502886A095000000000000000
   VCID: 2D5087B77C6CB7FE50-8078
   Component: GW MQB High   515 5286
   Serial number: 06021700840382 Dataset Number: V03935252FW 0001
   Coding: 0101000870085900FB00023B880F00000001050000000000000000000000
   Shop #: WSC 00066 790 07026
   GVL: 01503C5000000600404C900080004C0000000000000000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 2F6C9DBF7660C5EE62-807A
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 S    HW: 5G0 959 442 S  Labels: 3C8-959-537.CLB
   Serial number: 27160003177220036486
   Coding: 34FFFF
   Revision: 00000000    Serial number: 16000222107003
   Coding: 5500000000000000
   VCID: 346692D39F46E6361F-8060
Address 32: Differential Locks (J492)       Labels:| 0CQ-907-554-V2.clb
   Part No SW: 0CQ 907 554 E    HW: 0CQ 907 554 E
   Component: Quersperre    H52 8042
   Serial number: HA1-00024.10.16 Dataset Number: v1260x015G0 0000
   Coding: 0001
   ASAM Dataset: EV_LockElectHA1VW37X 001007
   ROD: EV_LockElectHA1VW37X.rod
   Serial number: 0423368751 Dataset Number: V03935217RX 0027
   Coding: 01011103
   ROD: EV_HREntryHella_VW37.rod
729604 - Local Data Bus
          U10BA 00 [00001001] - No Communication
                    Reset counter: 52
                    Mileage: 119388 km
                    Date: 2024.11.24
                    Time: 13:05:14
   Serial number: 3001170605103A Dataset Number: V03935249RC 0001
   Coding: 003E13200000020000000000
   ROD: EV_DCUDriveSideEWMAXKLO.rod
   VCID: 4384C10FCAE8518E96-8016
   Serial number: 00000000000005237874
   Coding: 011000
65799 - Door Warning / Entry Lighting
          B1775 01 [00001001] - Electrical Failure
                    Reset counter: 52
                    Mileage: 119388 km
                    Date: 2024.11.24
                    Time: 13:18:34
   Part No SW: 3QM 909 144     HW: 3QM 909 144
   Dataset Number: V03935245KK 0001
   Coding: 8102
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 0C162A33A736DEF6A7-8058
   Revision: 00000001    Serial number: VWZ8Z1GBA02VM4N Dataset Number: 5GM050v____ 0212
   Coding: 2200000000AAAAAA000000000000
   ROD: EV_AMPMst12C1Gen2ALPI_VW37.rod
   VCID: 6DD047B7BCEC77FE10-8038
   Serial number: 230117060500BA Dataset Number: V03935249RE 0001
   ROD: EV_DCUPasseSideEWMAXKLO.rod
   VCID: 428AC40BD5F258869D-8016
   Serial number: 00000000000005236638
   Coding: 091000
   Revision: --------    Serial number: -------------- Dataset Number: V03935205NP 0021
   Coding: 021203010B000400
   ROD: EV_HeadlRegulVWAFS_VW37.rod
   VCID: 408ECE03DBFE4A968B-8014
   Subsystem 1 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0004
   Coding: 2E0000
   Subsystem 2 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0004
   Coding: 2E0000
   Part No SW: 3Q0 035 876 A    HW: 3Q0 035 876 A
   Component: MU-S-NS-US    840 0753
   Serial number:                Dataset Number: V03935247DB 0001
   Coding: 027300020000000051220002001808009F0203F401200105C6
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 326A94CB6552E8060D-8066
   Subsystem 1 - Part No SW: 5GM 919 605     HW: 5GM 919 605
   Component: ABT_Std-2_Nav  H53 1031
   Serial number: VWZ8Z9SJX00J4L
   Subsystem 2 - Part No SW: 3G0 919 866 BB    HW: -----------
   Component: NAR 2017  --- 0525
                    Reset counter: 52
                    Mileage: 119388 km
                    Date: 2024.11.24
                    Time: 13:06:05
                    Voltage terminal 30: 11.6 V
                    SDARS_tuner_status_2-Satellite radio antenna status: electrically OK
                    SDARS_tuner_status_2-Audio Signal: Not available
                    SDARS_tuner_status_2-Antenna current: 137 mA
                    SDARS_tuner_status_2-Reception quality: weak_signal
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 07
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 07
   Dataset Number: V03935236TB 0001
   ROD: EV_OCULowMQB.rod
   Component: SAS-GEN 2     H06 0014
   Serial number: 161107200559
   VCID: 6BD449AF82F879CE0E-803E
End-------------------------(Elapsed Time: 05:12)--------------------------
That's not surprising as it will cause a cascade of faults in other modules.
Smells like tuna. ;)
ACC faults:
FAULT_BRAKINGLIGHT_FAIL
FAULT_TSK_IRREV_FAIL
Lane Change fault:
Private CAN - no signal/no communication
The latter is also no surprise given that the new module isn't plugged in. Plug it in, run another scan, and let's see what's what with it.
94LSC
Upstate NY, USA
C?ID=293997
Here is the scan after I plugged the module in the first time. I had Malfunction status on 01 Engine, 03 ABS Brakes, 09 Cent. Elect., 13 Auto Dist. Reg, 15 Airbags, 2B Steer. Col. Lock, 32 Differential Locks, 3C Lane Change, 52 Door Elect Driver, 55 Headlight Range, and 5F Information Electr. What do you think caused that to happen? Is the Blind Spot Radar Module tied to another car's VIN? Do you think it will do it again if I plug the module back in?
Saturday,23,November,2024,17:24:47:32137
          75 A9
VIN: 3VW547AU1HM04xxxx   Mileage: 119388km-74184miles
32-Differential Locks -- Status: Malfunction 0010
17178 - ROD - Unknown Error Code
          - 00 [00100100]
                    Mileage: 119388 km
                    Date: 2024.11.22
                    Time: 16:44:53
17181 - ROD - Unknown Error Code
          - 00 [00101111]
                    Mileage: 119388 km
                    Date: 2024.11.23
                    Time: 18:16:21
21322 - ROD - Unknown Error Code
          - 00 [00100100]
                    Mileage: 119388 km
                    Date: 2024.11.17
                    Time: 23:39:10
23130 - ROD - Unknown Error Code
          - 00 [00100100]
                    Mileage: 119388 km
                    Date: 2024.11.17
                    Time: 23:39:10
0071 - Rear Left Wheel Speed Sensor
          C101C 4A [00001000] - Incorrect Component(s) Installed
                    Reset counter: 91
                    Mileage: 119388 km
                    Date: 2024.11.17
                    Time: 23:39:10
16417 - Display for Tire Pressure Monitoring
          C1146 02 [00001000] - Signal Failure
                    Reset counter: 91
                    Mileage: 119388 km
                    Date: 2024.11.17
                    Time: 23:39:20
   Coding: 032C0C
   Coding: 00A8DD
   Coding: 181803
15626 - Bulb for Left Brake Lamp / Turn Signal
          B1333 15 [00001001] - Open or Short to Plus
                    Reset counter: 51
                    Mileage: 119388 km
                    Date: 2024.11.23
                    Time: 18:16:21
                    Terminal 15 status: On
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    Status Bremslichtschalter (HW): On
                    Status Bremslichtschalter (CAN): On
                    OFF: operated
                    Position lamps: Not operated
                    Low beam: Not operated
                    Voltage: 14.6 V
                    Outside temperature: 7.0 °C
15882 - Bulb for Right Brake Lamp / Turn Signal
          B1334 15 [00001001] - Open or Short to Plus
                    Reset counter: 51
                    Mileage: 119388 km
                    Date: 2024.11.23
                    Time: 18:16:21
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Voltage: 14.6 V
2172 - Databus
                    Reset counter: 51
                    Mileage: 119388 km
                    Date: 2024.11.23
                    Time: 18:16:21
                    Control Module temperature: 26 °C
                    Voltage terminal 15: 14.4 V
0863 - Databus
          U1122 00 [00001000] - Implausible Message
                    Reset counter: 91
                    Mileage: 119388 km
                    Date: 2024.11.17
                    Time: 23:39:09
                    Control Module temperature: 17 °C
                    Voltage terminal 15: 11.3 V
2101 - Databus
                    Reset counter: 91
                    Mileage: 119388 km
                    Date: 2024.11.17
                    Time: 23:39:09
0815 - Databus
                    Reset counter: 91
                    Mileage: 119388 km
                    Date: 2024.11.17
                    Time: 23:39:09
2068 - Databus
                    Reset counter: 52
                    Mileage: 119388 km
                    Date: 2024.11.17
                    Time: 23:39:09
   Coding: 303131
          B10B3 00 [00001000] - Function Restriction due to Implausible Message(s)
                    Reset counter: 91
                    Mileage: 119388 km
                    Date: 2024.11.17
                    Time: 23:39:26
   Coding: 0400
   Generator:
   Coding: 34FFFF
13637378 - Databus
                    Reset counter: 91
                    Mileage: 119388 km
                    Date: 2024.11.17
                    Time: 23:39:10
                    ELV State: 04
                    Information Clamps: 77 60
                    CoCo State: A0 01
                    WFS State: 17 06
                    Vehicle speed: 0.00 km/h
                    Voltage: 61
                    AD-Value H-bridge: 30
                    Clamp15 flip flop: SSTx: button contacts: 06
                    CAN signals: 00
   Coding: 0001
16656 - Databus
                    Reset counter: 91
                    Mileage: 119388 km
                    Date: 2024.11.17
                    Time: 23:39:08
   Coding: 01011103
337792 - Databus
                    Reset counter: 91
                    Mileage: 119388 km
                    Date: 2024.11.17
                    Time: 23:39:10
                    Reset counter: 51
                    Mileage: 119388 km
                    Date: 2024.11.17
                    Time: 23:39:08
   Coding: 011000
                    Reset counter: 51
                    Mileage: 119388 km
                    Date: 2024.11.17
                    Time: 23:39:07
   Coding: 8102
   Coding: 091000
   Coding: 2E0000
   Coding: 2E0000
13705985 - Databus
                    Reset counter: 91
                    Mileage: 119388 km
                    Date: 2024.11.17
                    Time: 23:39:10
                    Reset counter: 51
                    Mileage: 119388 km
                    Date: 2024.11.17
                    Time: 23:39:36
                    Voltage terminal 30: 11.4 V
                    SDARS_tuner_status_2-Audio Signal: available.
                    SDARS_tuner_status_2-Antenna current: 136 mA
                    SDARS_tuner_status_2-Reception quality: optimum_signal
End-------------------------(Elapsed Time: 05:02)--------------------------
iichel
Netherlands, Operation Market Garden
C?ID=284912
Can you wipe all errors and make a new scan? I'm sure many of the intermittent non confirmed ones will go away
94LSC
Upstate NY, USA
C?ID=293997
That was the scan from when I plugged the used replacement module into my car for the first time. That's when I started doing some research and found out I should not have done that. The first scan I posted is the latest one.
94LSC
Upstate NY, USA
C?ID=293997
Here is the new scan with the replacement module installed.
Thursday,28,November,2024,13:14:50:32137
          75 A9
Readiness: 1010 1101
   Coding: 032C0C
   Coding: 00A8DD
   Coding: 181803
   Coding: 303131
   Coding: 0400
   Generator:
   Coding: 34FFFF
   Coding: 0001
   Coding: 01011103
   Serial number: 0434766973
   Coding: 010111
267776 - Data Set Implausible
          B2012 00 [00001001] - -
                    Reset counter: 53
                    Mileage: 119391 km
                    Date: 2024.11.28
                    Time: 14:08:50
          U10BA 00 [00001000] - No Communication
                    Reset counter: 93
                    Mileage: 119391 km
                    Date: 2024.11.25
                    Time: 12:17:42
   Coding: 011000
                    Reset counter: 53
                    Mileage: 119391 km
                    Date: 2024.11.25
                    Time: 12:21:16
   Coding: 8102
   Coding: 091000
   Coding: 2E0000
   Coding: 2E0000
                    Reset counter: 53
                    Mileage: 119391 km
                    Date: 2024.11.25
                    Time: 12:18:05
                    Voltage terminal 30: 14.7 V
End-------------------------(Elapsed Time: 05:13)--------------------------
Right, but that scan still has the cascade of faults from the ABS, so the signal-to-noise ratio is poor.
OK, there's a data set fault for the module you replaced. That can't be fixed with VCDS.
What car did that module come out of?
94LSC
Upstate NY, USA
C?ID=293997
Should I go back and clear the faults again and repost? The module was out of a Passat. Same part number as the one originally in my car. Is that data set something that can be changed with ODIS? What are my options at this point? Thanks for your help with this.
Nah, I was just explaining why the scan in post #7 was less than idea. The scan in post #10 is fine.
That explains the dataset problem.
Unfortunately, "same part number" no longer guarantees compatibility. Dataset must be correct too.
I would think so. ODIS-S will probably need an on-line connection to be able to retrieve the proper dataset from VW's servers. ODIS-E should be able to do it if you happen to have the correct dataset.
94LSC
Upstate NY, USA
C?ID=293997
So if I buy a used one from a GTI, should it work as-is?
Same model year, same PR Codes, same part number, I would think so, but I can't make any guarantees.
94LSC
Upstate NY, USA
C?ID=293997
How does it work if you buy a new one from a dealer?
TTT
C?ID=547002
Its empty of dataset. So no.
94LSC
Upstate NY, USA
C?ID=293997
Just a follow-up on this. I ended up buying another used module out of a 2016 Golf Sportwagen. Seller verified it would work with my VIN. I plugged it in and everything is working with no faults. Thanks for all the help, I never could have gotten this sorted out without it. I appreciate the education...
