ABS pump 1K0907379AD changed with 1K0907379BL and cannot code it
MateiBogdan
Pirate
Walking the Plank
Mozambic
WVWZZZ1KZ9W432067
Hello all !
I have a VW Golf 6 with the ABS pump 1K0907379AD and has the error "01130 - ABS Operation / 008 - Implausible Signal".
I have been searching for a while the forum for a compatible ABS pump code and found in the scrap yard one with code 1K0907379BL.
I got the code of the old pump from the scan log: 113B200D092500FC880B04EA902000403000 ( 18 bytes) and aded 00 at the end to make it for 19 bytes: 113B200D092500FC880B04EA90200040300000
and i get the message "Error 31 - request out of range"
Can anyone help me ?
LOG with old ABS Pump:
Removed.  Data from a clone/pirate copy of VCDS is not acceptable in Ross-Tech's forum.
LOG with replacement ABS Pump:
Dr Sheldon
Windsor UK
C?ID=334979
ABS pump 1K0907379AD changed with 1K0907379BL​
Why take that risk ?
  • Disagree
Reactions: TTT
MateiBogdan
Pirate
Walking the Plank
Mozambic
WVWZZZ1KZ9W432067
I couldn't find any other Pump codes that are compatible. A new one is really expensive aprox 1500Euros and the AD is faulty prone. On forum i saw that The BL is compatible with my VIN Nr (1K ) .... or I understood wrong ?!
I still have sever days to return the pump and refund, but the pump is allready on the car!
The guy i bought the car from, a friend of mine, used it with this fault aprox 2 years.
Dr Sheldon
Windsor UK
C?ID=334979
Foolish
  • Disagree
Reactions: TTT
TTT
C?ID=547002
Vcds 14.10.2. Now, even I could tell this is a clone. Hope I’m wrong?
MateiBogdan
Pirate
Walking the Plank
Mozambic
WVWZZZ1KZ9W432067
Got this allmost 10 years when i had an 2003 Audi A4.
So i dont know ... I guess !
This year I bought the Golf 6 with this problem, now came handy.
So to understand that the software and interface is to old ?
Bruce
Near Philadelphia, PA, USA
The plank will be pushed out shortly.
A device locked to a particular version is most often an illegal copy of VCDS. Yours is an illegal copy.
We support only the users of the legitimate VCDS systems. They can be obtained from Ross-Tech direct or from our listed distributors.
MateiBogdan
Pirate
Walking the Plank
Mozambic
WVWZZZ1KZ9W432067
I didnt knew that !
Thank you for heads up !
MateiBogdan
Pirate
Walking the Plank
Mozambic
WVWZZZ1KZ9W432067
I see that in my country the genuine VCDS is allmost 500 Euros ...
But can u tell me if this model of pump is compatible or need to find another code , and a then buy a genuine VCDS ?
Thanks !
MateiBogdan
Pirate
Walking the Plank
Mozambic
WVWZZZ1KZ9W432067
Thank you! I will look for this Package at the licenced distibutor in my country. I only saw the professional VCDS cost aprox 550$.
I dont have a workshop, i dont work at cars, just my own. And if it works mechanically well i dont do coding.
I'll return the pump and get the refund, after that i'll look for a service who has what it takes to change and code a compatible Abs pump.
Thank you all for your support !
Have a beautifull day !
You can close the post !
Release 14.10.2(x64) Data version: 20150311
A new record!
Nah, I think we've had one or two using version 12.12.
