2015 Passat TDI SEL - TPMS issue
pbj0071
Alabama, USA
C?ID=551390
Hello, new to the site and new to VCDS software. Constant TPMS light on in gauge cluster. Reset it but it comes back. Here's what the VCDS pulled up, hoping someone can tell me what I need to correct. Thanks in advance.
Sunday,24,November,2024,16:57:52:61531
VCDS Version: 24.7.1.0  HEX-V2 CB: 0.4643.4
VIN: 1VWCV7A39FC073226   License Plate: AUTO
Mileage: 138920km-86320mi   Repair Order:
Gateway Installation List:  7N0 907 530 AR
09-Cent. Elect. -- Status: Not registered 0011
46-Central Conv. -- Status: Not registered 0001
4C-Tire Pressure II -- Status: Not registered 0001
4F-Centr. Electr. II -- Status: Not registered 0001
6C-Back-up Cam. -- Status: Cannot be reached 1100
75-Telematics -- Status: Not registered 0011
77-Telephone -- Status: Not registered 0011
Address 65: DTCs cleared
                Address 65: Tire Pressure       Labels: 1K0-937-08x-65.clb
Control Module Part Number: 5K0 937 087 AE    HW: 5K0 937 087 AE
  Component and/or Version: RDK           122 0821
           Software Coding: 018705
            Work Shop Code: WSC 12345 123 12345
                      VCID: 78A9FB5312DC4E7A67B-802C
Fault Codes have been Erased
                    Mileage: 138928 km
                    Date: 2045.14.11
                    Time: 17:10:51
                    Fault Status: 01100101
                    Mileage: 138928 km
                    Date: 2045.14.11
                    Time: 17:10:51
01487 - System Function Test
                    Reset counter: 206
                    Mileage: 138928 km
                    Date: 2045.14.11
                    Time: 17:10:51
Westbury, UK
You need to post an Auto-Scan which is complete and not edited, there are faults showing in other modules which are often relevant.
pbj0071
Alabama, USA
C?ID=551390
Thanks, it's below.
y,24,November,2024,17:44:00:61531
VIN: 1VWCV7A39FC073226   License Plate: B8
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 36 42 44 46 47 4C 4F
          52 56 62 65 6C 72 75 77
VIN: 1VWCV7A39FC073226   Mileage: 138920km-86320miles
Address 01: Engine (J623-CVCA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 997 016 D    HW: 04L 907 309 K
   Component: R4 2.0l TDI   H20 9466
   Revision: 8AH20---    CVN: C3699F2538D3FF82B866C2AD
   Coding: 011D0012032410089000
   Shop #: WSC 04918 444 00000
   ASAM Dataset: EV_ECM20TDI01104L997016D 004002
   ROD: EV_ECM20TDI01104L997016D.rod
   VCID: 34310F634EB46A1A8B3-8060
   VINID: 0669D39874432564C01C308218959F5EDA
   Part No SW: 02E 300 061 T    HW: 02E 927 770 AL
   Component: GSG DSG AG6     531 4518
   Revision: 05653104    Serial number: 00001412082533
   Shop #: WSC 09003 957 00200
   VCID: 2517E227F9EE03920CD-8070
   Part No SW: 1K0 907 379 BS    HW: 1K0 907 379 BS
   Component: ESP MK60EC1   H46 0166
   Revision: 00H46001
   Coding: C54BC0F5492900FDA30D03E6921F0042A41C0012
   VCID: 04519FA35E141A9A7B3-8050
   Part No SW: 5K0 959 434 E    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 092 1202
   Revision: 00092000    Serial number: 0356738589 Dataset Number: 560116v____ 0002
   Coding: 130C0C
   ROD: EV_KESSYPQ35G_A02_VW32.rod
   VCID: 372B386F5FC28102AE1-8062
   Part No SW: 561 907 044 AR    HW: 561 907 044 AR
   Component: Climatronic   H03 0808
   Revision: 00001K01
   Coding: 0650019012
   VCID: 678BA82F4FE2D182FE1-8032
   Part No SW: 5K0 937 087 AE    HW: 5K0 937 087 AE
   Component: BCM PQ35 H+   122 0174
   Revision: BL122001
   Coding: EF200E1B882B2AD4898802013600854800F1A08645A005B064806000BC70
   Shop #: WSC 05512 002 104857
   Component: RLS 051214 05  54  0403
   Coding: 02300A
                    Reset counter: 6
                    Mileage: 128199 km
                    Date: 2018.09.14.
                    Time: 09:58:01
                    Voltage: 13.85 V
01800 - Light Switch (E1)
                    Fault Status: 01101000
                    Fault Frequency: 29
                    Reset counter: 206
                    Mileage: 128201 km
                    Date: 2018.09.14.
                    Time: 10:35:21
                    Voltage: 13.85 V
03189 - Bulb for Side Marker Light; Front Right
                    Fault Status: 00101010
                    Reset counter: 232
                    Mileage: 138296 km
                    Date: 2019.04.05.
                    Time: 14:38:54
                    Voltage: 14.10 V
   Part No SW: 5C0 959 655 AB    HW: 5C0 959 655 AB
   Component: AirbagVW10    500 0975
   Serial number: 003LZD053M9P   Dataset Number: 560003v__A_ 0135
   Coding: 00004D53
   Shop #: WSC 03809 003 1048576
   ASAM Dataset: EV_AirbaVW10SMEVW360 001030
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 72BDC97B7420242A59F-8026
   Serial number: 6940000Y150001AEN60R
   Coding: 303047
   Serial number: 3572MSME302D4B4AZZZ/
   Serial number: 3582MSME14653B4BZZZ$
   Serial number: 3516KSME233B6633ZZZQ
   Serial number: 3526KSME61717933ZZZR
   Serial number: 3556LSME1E723B33ZZZ
   Serial number: 3566LSME4F4E7B33ZZZD
          B10B3 00 [00001000] - Function Restriction due to Implausible Message(s)
                    Reset counter: 246
                    Mileage: 138920 km
                    Date: 2024.11.24.
                    Time: 17:02:41
   Part No SW: 1K5 953 521 BR    HW: 5K0 953 569 AH
   Component: LENKS.MODUL   016 0162
   Revision: FF010042    Serial number: 20141108200367
   Coding: 000A140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 7EA5ED4B3078704A2D7-802A
   Component: E221__MFL-8LP  H07 0023
   Serial number: 00000000000001009120
   Coding: E20000
   Part No SW: 561 920 970 G    HW: 561 920 970 G
   Component: KOMBI         H05 0813
   Coding: 231E01
   VCID: 1E65CDCBD038D04A4D7-804A
   Part No SW: 7N0 907 530 AR    HW: 7N0 907 530 AM
   Component: J533  Gateway H55 1653
   Revision:   H55       Serial number: 31011503000268
   Coding: 351002
   VCID: 005993B34A0C06BA5FB-8054
                    Mileage: 138920 km
                    Date: 2019.04.17.
                    Time: 16:56:02
                    Reset counter: 206
                    Mileage: 138920 km
                    Date: 2019.04.17.
                    Time: 16:56:06
   Component: IMMO          H05 0813
   Coding: 000007
   VCID: 6A8DD11B5CF0ECEAE1F-803E
   Revision: 00000000    Serial number: 14000352467005
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X_VW32.rod
   VCID: 30390373BAAC563AEFB-8064
Address 2E: Media Player 3
   Part No SW: 561 959 760 B    HW: 561 959 760 B
   Component: MEM-FS        H04 0183
   Revision: AA000000    Serial number: 00000133074879
   Coding: 00581B0000000000000021010100202020202120202020
   VCID: 221DF93BE4C0F4AA69F-8076
   Part No SW: 561 959 701 A    HW: 3C0 959 793 C
   Revision: 12110009    Serial number: 0009288512
   Coding: 0405FD
   ROD: EV_TSGFPQ25BRFVW46X.rod
   VCID: 1C61C7C3C624C25AA33-8048
   Slave Driver:
   Subsystem 1 - Part No SW: 561 959 811 B    HW: 561 959 811 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG_HL  006 5470
   Serial number: 14202630150202164257
   Coding: 800000
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 215    3501
   Revision: 00H22000
   VCID: 392F3E5765569772585-806C
                    Fault Status: 00101101
                    Reset counter: 246
                    Mileage: 138920 km
                    Date: 2019.04.17.
                    Time: 17:02:26
                    Voltage: 13.63 V
                        DU
                    Temperature: 35.0°C
                    RPM: 2010 /min
                    Speed: 49.0 km/h
                    Speed: 49.0 km/h
   Part No SW: 5C6 035 456 C    HW: 5C6 035 456 C
   Component: KonzernAmp10K H08 6831
   Revision: --------    Serial number: EAA098C0034410 Dataset Number: 560050v____ 0007
   ROD: EV_AudioVerst10KanalSTT3_VW32.rod
   VCID: 2809EB13827C1EFA37B-807C
   Component: EZE_2         H55 1653
   Coding: 01030108
   VCID: 6FBBC00F679209C2B61-803A
   Subsystem 1 - Part No SW: 561 959 591 A    HW: 561 959 591 A
   Component: J245 P05 9BA3  H08 0005
   Serial number: 53388786011416401338
   Coding: 181100
   Component: Analoguhr  009 0005
   Part No SW: 561 959 702 A    HW: 3C0 959 792 C
   Revision: 14110009    Serial number: 0009290827
   Coding: 0405FC
   ROD: EV_TSGBPQ25BRFVW46X.rod
   VCID: 1D67CAC7DD3ECB5254D-8048
   Slave Passenger:
   Subsystem 1 - Part No SW: 561 959 812 B    HW: 561 959 812 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG_HR  006 5470
   Serial number: 14202631150203071144
   Coding: 800000
Address 56: Radio
Address 65: Tire Pressure (J502)       Labels:. 1K0-937-08x-65.clb
   Component: RDK           122 0821
   Coding: 018705
                    Mileage: 138928 km
                    Date: 2019.04.17.
                    Time: 17:41:11
                    Mileage: 138928 km
                    Date: 2019.04.17.
                    Time: 17:41:11
                    Reset counter: 206
                    Mileage: 138928 km
                    Date: 2019.04.17.
                    Time: 17:41:11
Address 6C: Back-up Cam.
   Part No SW: 561 035 285 A    HW: 561 035 285 A
   Component: OCULowUSA     020 0156
   Serial number: 000003554140533 Dataset Number: 561098V____ 0017
   Coding: 02140102C2403A007F1606000000
   ASAM Dataset: EV_OCULow 002009
   ROD: EV_OCULow_002.rod
   VCID: 1471AFE32EF48A1AEB3-8040
0036 - Databus
          [CAN TO GPS data]
                    Reset counter: 206
                    Mileage: 138920 km
                    Date: 2024.11.24.
                    Time: 16:56:07
   Part No SW: 5N0 035 729 E    HW: 5N0 035 729 E
   Component: TELEFON       H07 0593
   Revision: 1B001001    Serial number: 00007666752349 Dataset Number: 5N0035729E  0001
   Coding: 0A10030080010110
   ROD: EV_UHVUMI.rod
   VCID: 323D097BB4A0642A99F-8066
9455635 - Telephone Microphone
          B1048 13 [00001001] - Open Circuit
                    Reset counter: 206
                    Mileage: 138920 km
                    Date: 2024.11.24.
                    Time: 16:56:03
          B104F 13 [00001001] - Short to GND
                    Reset counter: 206
                    Mileage: 138920 km
                    Date: 2024.11.24.
                    Time: 16:56:03
          B104E 13 [00001001] - Short to GND
                    Reset counter: 206
                    Mileage: 138920 km
                    Date: 2024.11.24.
                    Time: 16:56:03
End----------(Elapsed Time: 01:20, VBatt start/end: 13.5V/13.4V)-----------
What's the back-story here? At first glance, this seems to be a conflict between a "direct" TPMS module that's looking for physical sensors and TPMS and having TPMS enabled in the ABS as well?
pbj0071
Alabama, USA
C?ID=551390
Well, I'm guessing that's where I'm hoping to get some help from the group. If you see something you think I should change, let me know and I'll give it a try.
As mentioned above, have you changed any components or made any changes ?
pbj0071
Alabama, USA
C?ID=551390
Yes, I played around in the ABS coding and probably jacked it up. I'm just not sure if I have a direct or indirect system. From what I'm gathering, I have an "Indirect" system. Need to know what to disable and what to enable in the coding.
Check you PC for any old or previous VCDS scans (before you made any changes) ; check your "C" drive for files marked "scans" or "logs" etc.
pbj0071
Alabama, USA
C?ID=551390
will do. If I can find it, I'll repost it.
Westbury, UK
... and for the CodingLog.csv and AdpLog.csv files in the C:\Ross-Tech\VCDS\Debug folder
Just curious, what were you trying to accomplish?
Well, since you have an physical 65-Tire Pressure module, I'd say you have direct.
pbj0071
Alabama, USA
C?ID=551390
Monday,21,December,2020,14:19:45:05031
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
VIN: 1VWCV7A39FC073226   License Plate: NOT RUNNING
Mileage: 70880km-44042mi   Repair Order:
Chassis Type: A3 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 36 37 42 44 46 47 4F
          52 56 62 72 75 77
VIN: 1VWCV7A39FC073226   Mileage: 70880km-44042miles
Address 01: Engine (J623-CVCA)       Labels: None
   Revision: 8AH20---
   ASAM Dataset: EV_CEM20TDI01104L997016D 004002
   ROD: N/A
   VCID: 346084FF9F28C89E89-8060
No ASAM data for: "EV_CEM20TDI01104L997016D" (VW41)
17158 - ROD - Unknown Error Code
          - 00 [032]
   VCID: 254669BBECF2A1160E-8070
28907 - No Communications with Cruise Control (Front) Distance Sensor
            U0235 - 000 -  - Intermittent
                    Fault Frequency: 9
                    Reset counter: 19
                    Mileage: 66195 km
                    Date: 2020.09.27
                    Time: 16:04:06
   Revision: 00H46001
   Coding: C54BC0F5492900FDA30D03E6921F0042A1100012
   VCID: 0400143F8708B81E79-8050
Address 05: Acc/Start Auth. (J518)       Labels: 5K0-959-434.clb
   Coding: 130C0C
   ASAM Dataset: EV_EKSSYPQ35G A02717
   ROD: N/A
   VCID: 377AB3F38E5E2386AC-8062
No ASAM data for: "EV_EKSSYPQ35G" (VW41)
   Revision: 00001K01
   Coding: 0050019012
   ASAM Dataset: EV_ACClimaHBBVW411 A01001
   ROD: N/A
   VCID: 67DA23B39E7E7306FC-8032
No ASAM data for: "EV_ACClimaHBBVW411" (VW36 *)
9473393 - ROD - Unknown Error Code
          - 00 [009]
                    Fault Frequency: 50
                    Reset counter: 45
                    Mileage: 67287 km
                    Date: 2020.10.08
                    Time: 18:36:46
   Coding: 00004D53
   ASAM Dataset: EV_AirbaWV10SMEVW360 001030
   ROD: N/A
   VCID: 72EC42E7A5BC86AE5B-8026
   Coding: 303047
No ASAM data for: "EV_AirbaWV10SMEVW360" (VW41)
   Coding: 000A140000
   ASAM Dataset: EV_MSLSNGVOLWSXS A01004
   ROD: N/A
   VCID: 7EF466D7E1E4D2CE2F-802A
   Coding: E20000
No ASAM data for: "EV_MSLSNGVOLWSXS" (VW36 *)
   Coding: 231E01
   VCID: 1E34465701A472CE4F-804A
   Coding: 461000
   VCID: 0008182F9310A43E5D-8054
   Coding: 000007
   ASAM Dataset: EV_Mimo_UDS_VDD_RM09 A03710
   ROD: N/A
   VCID: 6ADC5A878D6C4E6EE3-803E
No ASAM data for: "EV_Mimo_UDS_VDD_RM09" (VW36 *)
Address 2B: Steer. Col. Lock (J764)       Labels: 5K0-905-861.clb
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 306888EF6B30F4BEED-8064
   VCID: 224C72A73DDC562E6B-8076
   Part No SW: 3C0 035 684 Q    HW: 3C0 035 684 Q
   Component: RNS-MID       H27 5382
   Revision: AB001001    Serial number: VWZ6Z7P9338128
   Coding: 04090042010000A6000B
   VCID: 316E8DEB683AFDB6E2-8064
   Subsystem 1 - Part No: 7L6 919 859
   Component: NAR V9  8213
            000 -  -
                    Reset counter: 46
                    Mileage: 53840 km
   Coding: 0405FD
   ASAM Dataset: EV_TSGFP2Q5BRFVW46X A04001
   ROD: N/A
   VCID: 1C304C5F17B860DEA1-8048
   Coding: 800000
No ASAM data for: "EV_TSGFP2Q5BRFVW46X" (VW41)
131584 - ROD - Unknown Error Code
          - 00 [008]
                    Reset counter: 58
   Revision: 00H22000
   VCID: 397EB5CB704A35F65A-806C
Address 46: Central Conv.
   ASAM Dataset: EV_AudioEvrst10KanalSTT3 S01001
   ROD: N/A
   VCID: 2858608F53E0BC7E35-807C
No ASAM data for: "EV_AudioEvrst10KanalSTT3" (VW41)
   Coding: 01030108
   VCID: 6FEA4B93BE8EAB46B4-803A
   Coding: 181100
   Coding: 0405FC
   ASAM Dataset: EV_TSGBPQ25BRFWV46X A04001
   ROD: N/A
   VCID: 1D36415B0CA269D656-8048
   Coding: 800000
No ASAM data for: "EV_TSGBPQ25BRFWV46X" (VW41)
          - 00 [008]
                    Reset counter: 60
            000 -  -
                    Reset counter: 46
                    Mileage: 53840 km
Address 75: Telematics (J949)       Labels: None
   Coding: 02140102C24232007F1606000000
   ROD: EV_OCULow.rod
   VCID: 1420247FFF68289EE9-8040
Address 77: Telephone (J412)       Labels: 5N0-035-729.clb
   ROD: EV_UHVUMI.rod
   VCID: 326C82E7653CC6AE9B-8066
End-------------------------(Elapsed Time: 04:32)--------------------------
Found one from the first year I had the car.
pbj0071
Alabama, USA
C?ID=551390
No good answer for you....ventured into too deep of water on this one.
Well, there's your original ABS coding. I'd suggest putting that back in via copy & paste.
What's curious though is that this car didn't have a physical/direct TPMS module then, but it appears to now..?
pbj0071
Alabama, USA
C?ID=551390
Tuesday,14,January,2025,18:10:47:61531
VCDS Version: 24.12.0.1 (x64)  HEX-V2 CB: 0.4658.4
Data version: 20241120 DS361.3
Dealer/Shop Name: Home
VIN: 1VWCV7A39FC073226   License Plate: 87733
Mileage: 140490km-87296mi   Repair Order:
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 36 42 44 46 47 4F 52
          56 62 72 75 77
VIN: 1VWCV7A39FC073226   Mileage: 140490km-87296miles
2E-Media Player 3 -- Status: Not registered 0001
   ROD: EV_ECM20TDI01104L997016.rod
   VCID: 34310F634EB46A1AA7A-8060
Readiness: 0 0 0 1 1
   VCID: 2517E227F9EE0392204-8070
   Revision: 00H46001
   VCID: 04519FA35E141A9A57A-8050
   Coding: 130C0C
   ROD: EV_KESSYPQ35G_A02_VW41.rod
   VCID: 372B386F5FC28102828-8062
   Revision: 00001K01
   Coding: 0650019012
   VCID: 678BA82F4FE2D182D28-8032
   Revision: BL122001
   Coding: EF200E1B882B2AD4098802013600854800F1A08645A005B064806000BC70
   VCID: 78A9FB5312DC4E7A4B2-802C
   Coding: 02300A
   Coding: 00004D53
   VCID: 72BDC97B7420242A756-8026
   Coding: 303047
   Coding: 000A140000
   VCID: 7EA5ED4B3078704A01E-802A
   Coding: E20000
   Coding: 231E01
   ROD: EV_Kombi_UDS_VDD_RM09_004_VW41.rod
   VCID: 1E65CDCBD038D04A61E-804A
   Coding: 461000
   VCID: 005993B34A0C06BA732-8054
                    Mileage: 140497 km
                    Date: 2019.06.07.
                    Time: 18:03:49
   Coding: 000007
   VCID: 6A8DD11B5CF0ECEACD6-803E
   ROD: EV_ELVMarquMPVW36X_VW41.rod
   VCID: 30390373BAAC563AC32-8064
   VCID: 221DF93BE4C0F4AA456-8076
   Coding: 0405FD
   VCID: 1C61C7C3C624C25A8FA-8048
   Slave Driver:
   Coding: 800000
   Revision: 00H22000
   VCID: 392F3E576556977274C-806C
   ROD: EV_AudioVerst10KanalSTT3_VW41.rod
   VCID: 2809EB13827C1EFA1B2-807C
   Coding: 01030108
   VCID: 6FBBC00F679209C29A8-803A
   Coding: 181100
   Coding: 0405FC
   VCID: 1D67CAC7DD3ECB52784-8048
   Slave Passenger:
   Coding: 800000
Address 56: Radio
   ROD: EV_OCULow_002_VW41.rod
   VCID: 1471AFE32EF48A1AC7A-8040
0036 - Databus
          [CAN TO GPS data]
                    Reset counter: 241
                    Mileage: 140497 km
                    Date: 2025.01.14.
                    Time: 18:03:54
   ROD: EV_UHVUMI.rod
   VCID: 323D097BB4A0642AB56-8066
                    Reset counter: 241
                    Mileage: 140497 km
                    Date: 2025.01.14.
                    Time: 18:03:50
                    Reset counter: 241
                    Mileage: 140497 km
                    Date: 2025.01.14.
                    Time: 18:03:50
                    Reset counter: 241
                    Mileage: 140497 km
                    Date: 2025.01.14.
                    Time: 18:03:50
End----(Elapsed Time: 01:14, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
Its been awhile but got some items corrected. RR wheel sensor and hub were bad. Here's a current view of the VCDS. Could the address 19 issue be because I have an after market radio installed? Should I remove addresses 2E, 56, 75 & 77 based on that, Would it help correct 19? Help welcomed.
That's because:
However, you're never going to get the car completely fault-free with an aftermarket radio, so don't obsess over it.
Nah, since they're all still present and communicate, there's no point. If you want to physically remove them, then yes.
