I bought my daughter a 2011 Tourage TDI. Previous owner installed a lift and 255/70r/18 tires. Looks awesome but I'd like to have the speedo and mileage match reality. Is it possible to adjust tire size in vcds?
Sunday,24,November,2024,13:52:50:06424
VCDS Version: 24.7.1.0 (x64) HEX-V2 CB: 0.4643.4
VIN: WVGFK9BP7BD005402 License Plate:
Mileage: 158141km-98264mi Repair Order:
Chassis Type: BP-VW52 (7P6)
Scan: 01 02 03 05 08 09 15 16 17 19 42 46 52 53 55 56 5F 62 65 69
6C 6D 72
VIN: WVGFK9BP7BD005402 Mileage: 158141km-98264miles
Address 01: Engine (J623-CATA) Labels:. 059-907-401-V2.clb
Part No SW: 7P0 907 401 J HW: 7P0 907 401 E
Component: 3.0TDI FSA H21 0008
Revision: 56H21--- CVN: 66FD960056573130D45710C1
Coding: 292A4012233600050000
Shop #: WSC 14247 005 1048576
ASAM Dataset: EV_ECM30TDI0117P0907401J 002007
ROD: EV_ECM30TDI0117P0907401J_002.rod
VCID: 36353129F8C6EC3AB57-8062
VINID: 9E65D66C94A01D2500005100085E1013ED
4949 - Exhaust Gas Temp Bank 1 Sensor 2
P2084 00 [01100000] - Implausible Signal
Address 02: Auto Trans (J217) Labels:| 0C8-927-7XX-V1.clb
Part No SW: 0C8 927 750 G HW: 0C8 927 750 G
Component: AL1000 AISIN 001 3407
Serial number: CVN: CB5A7D50
Coding: 001368
Shop #: WSC 63277 003 1048576
ROD: EV_TCMAL991031_002_VW52.rod
VCID: 303907311AA2C20AEFB-8064
Address 03: ABS Brakes (J104) Labels:* 7P0-907-379.clb
Part No SW: 7P0 907 379 K HW: 7P0 907 379 A
Component: MK25A H36 0418
Revision: -------- Serial number: 406810010EC010 Dataset Number: 7P0012v____ 7P10
Coding: 5B7613C349242558DAF8C89392D4A4407700
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_MK25AXT 007001
ROD: EV_ESPMK25A00700.rod
VCID: 45D746E5B52077A22CD-8010
Part No SW: 4H0 907 064 AK HW: 4H0 907 064 AK
Component: BCM2 2.0 H24 0217
Coding: 09860000000000000000
VCID: 72BDCD39D4AEB01A59F-8026
Subsystem 1 - Part No SW: 7P6 959 754 M HW: 7P6 959 754 M
Component: FBSTOUAREGIDG H04 0051
Serial number: 0810000123658015
Subsystem 2 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Component: J764 ELV MLB H60 0046
Serial number: 7221000296071001
Fault Status: 00101101
Mileage: 154840 km
Date: 2024.08.21
Time: 21:15:54
Address 08: Auto HVAC (J255) Labels:| 7P6-907-040.clb
Part No SW: 7P6 907 040 AG HW: 7P6 907 040 AG
Component: Klima 2 Zonen H18 0613
Coding: B606200880
VCID: 79AFFA158958C342185-802C
U1101 00 [00011000] - Active
Reset counter: 90
Mileage: 154840 km
Date: 2024.08.21
Time: 22:21:58
Part No SW: 4H0 907 063 L HW: 4H0 907 063 D
Component: BCM1 2.0 H12 0092
Revision: 15012002 Serial number: 00000000965522
Coding: 26001012973C5D010020180300005D0C431C660882010261000000020000
VCID: 313F02351128CB02E05-8064
Subsystem 1 - Part No SW: 7P0 955 119 HW: 7P0 955 119 Labels: 1KX-955-119.CLB
Component: WWS 110226 31 0020
Serial number: 90243400110308215329
Coding: 004DBD
Subsystem 2 - Part No SW: 7P0 955 559 D HW: 7P0 955 559 D Labels: 8K0-955-559.CLB
Component: RLFS H09 0011
Serial number: 10133919
Coding: 035223
Subsystem 3 - Part No SW: 7P6 941 431 E HW: 7P6 941 431 E
Component: E1 - LDS H04 0031
Serial number: 00000000000103110310
Subsystem 4 - Part No SW: 4H0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0020
Serial number: 0000001805569R0BLA06
Address 15: Airbags (J234) Labels:| 7P0-959-655.clb
Part No SW: 7P0 959 655 B HW: 7P0 959 655 B
Component: VW10Airbag025 H05 0023
Revision: -------- Serial number: 003JX001UYB2 Dataset Number: 7P6003v____ 0785
Coding: 000000000000000000000000000000003235
ROD: EV_AirbaVW10BPAVW526_001.rod
VCID: 40D957F1AA02528A1FB-8014
Subsystem 1 - Part No SW: 7P6 959 339 HW: 7P6 959 339
Component: BF-Gewichtss. 003 0005
Serial number: 5850000R10A010213N
Serial number: 3575LRB405F0DGES9H4W
Serial number: 3585LRB405F0DGESBHNB
Serial number: 3515RRB40550ESC6G928
Serial number: 3525RRB40570ESC6MOH4
Serial number: 3555NRB405F0AMH0I93A
Serial number: 3565NRB405909GGSE9HZ
Part No SW: 4H0 953 568 A HW: 7P6 953 507
Component: Lenks.Modul H08 0007
Revision: -------- Serial number: 90815KC300047
Coding: 000015
Subsystem 1 - Part No SW: 7P6 959 542 HW: 7P6 959 542
Component: E221__MFL-TAS H03 0027
Serial number: 0061983
Mileage: 154840 km
Date: 2024.08.21
Time: 21:39:27
Address 17: Instruments (J285) Labels:| 7P6-920-xxx-17.clb-SRI1
Part No SW: 7P6 920 980 N HW: 7P6 920 980 N
Component: Kombi H13 0239
Revision: 11240062 Serial number: 658280211593015
Coding: 8B6733022B00CF05020004
ASAM Dataset: EV_KombiUDSRBVW526 001013
ROD: EV_KombiUDSRBVW526_VW52.rod
VCID: 47CB4CED8F2C65B2DE1-8012
Part No SW: 7P6 907 530 C HW: 7P6 907 530 A
Component: GW-CAN-L-MOST H08 5202
Revision: -------- Serial number: 00000000106852
Coding: 0001037500
GVL: FB0F40051D7F000000
ASAM Dataset: EV_GatewVW526UDS 001006
ROD: EV_GatewUDS_VW52.rod
VCID: 38293F11F2D21A4AA7B-806C
Subsystem 1 - Part No SW: 7P0 915 181 A HW: 7P0 915 181
Component: Batt_Sensor H07 0140
Serial number: 00000000005650692626
Part No SW: 4H0 959 793 F HW: 4H0 959 793 F
Component: TSG FA H07 0162
Revision: -------- Serial number: 0000113595941
Coding: 011D07200000453005080000
VCID: 3C212301C66A366A433-8068
Revision: 00002001 Serial number: 0144291154
Coding: 0186123A28B9500080A00620210000000000000000000000000000000000
Subsystem 1 - Part No SW: 7P6 959 719 HW: 7P6 959 719
Component: GTO BT H19 0059
Serial number: 349104583
Part No SW: 4H0 959 792 F HW: 4H0 959 792 F
Component: TSG BF H07 0162
Revision: -------- Serial number: 0000113699417
VCID: 3B23201DC36431524A9-806E
Address 53: Parking Brake (J540-) Labels:| 7P0-907-801.clb
Part No SW: 7P0 907 801 E HW: 7P0 907 801 E
Component: EPB H51 1100
Revision: 00000000 Serial number: A1121300053 Dataset Number: A001
Coding: 01040000
ROD: EV_ParkbA7.rod
VCID: 35373625E5C0E722BCD-8060
Slave 3:
0038 - Databus
[Steuerger t PSM - Notbremsung nicht verf gbar]
Reset counter: 90
Mileage: 154840 km
Date: 2024.08.21
Time: 23:14:12
Voltage: 9.4 V
0033 - Dynamic Start Assist Function Not Available
C10DE 00 [00001000] - -
Reset counter: 6
Mileage: 155855 km
Date: 2024.09.13
Time: 12:59:51
Voltage: 14.4 V
Address 55: Headlight Range (J745) Labels:. 7P6-907-357.clb
Part No SW: 7P6 907 357 HW: 7L6 907 357 C
Component: AFS-ECU H04 0110
Revision: -------- Serial number: -------------- Dataset Number: 7P0036v____ 0007
Coding: 010A00010F000400
ASAM Dataset: EV_HeadlRegulVWAFS 005006
ROD: EV_HeadlRegulVWAFS_VW52.rod
VCID: 7CA1E301866AF66A033-8028
Subsystem 1 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0001
Coding: 130000
Subsystem 2 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0001
Coding: 130000
Part No SW: 4G0 035 082 HW: 4G0 035 082
Component: Radio U SIRIU H51 0052
Revision: AB001007 Serial number: 471B/0B7562398
Coding: 020007020100000001
VCID: 5DE78E853D301F6214D-8008
Part No SW: 7P6 035 664 HW: 7P6 035 664
Component: H-BN-NA H43 0170
Revision: -------- Serial number: 445CW0B7511565
Coding: 010200050040E1EE01022B0C00000003F0080101
VCID: 75B7F625A5C0A7227CD-8020
Subsystem 1 - Part No: 8R0 060 884 P
Component: NAR 2010 0407
Subsystem 2 - Part No SW: 7P6 919 603 C HW: 7P6 919 603 C
Component: DU8 SV Touch H26 0045
Serial number: VWZ8Z9M7900H4K
Subsystem 3 - Part No SW: 7P6 919 603 C HW: 7P6 919 603 C
Component: CD-Database 1886
Part No SW: 4H0 959 795 B HW: 4H0 959 795 B
Component: TSG HL H09 0162
Revision: -------- Serial number: 0000113707820
Coding: 011C07200000253005080000
VCID: 3A2D2519CC5E085A51F-806E
Address 65: Tire Pressure (J502) Labels: 3Y0-907-273.clb
Part No SW: 7P6 907 273 F HW: 7P6 907 273 F
Component: RDKBERU25 H09 0008
Serial number: 10000000024305 Dataset Number: 7P6096v____ 0016
ASAM Dataset: EV_RDKBERU25 003006
ROD: EV_RDKBERU25_VW52.rod
VCID: 3FDB540DD7FC2D72661-806A
8392964 - TPMS Transceiver in Front Left Wheel Well
C104C 04 [00001000] - Internal System Fault
8393220 - TPMS Transceiver in Front Right Wheel Well
C104D 04 [00001000] - Internal System Fault
8393473 - TPMS Transceiver in Rear Left Wheel Well
C104E 01 [00001000] - Electrical Failure
8393729 - TPMS Transceiver in Rear Right Wheel Well
C104F 01 [00001000] - Electrical Failure
Address 69: Trailer (J345) Labels: Redir Fail!
Part No SW: 7P0 907 383 B HW: 7P0 907 383 B
Component: Anhaenger H07 0100
Revision: 5A001001 Serial number: 00000143309755
Coding: 020D000000000000
VCID: 372B3C2DFF4C1532AE1-8062
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 7P6 907 441 A HW: 4H0 907 441
Component: SG Rueckfahrkamera 0020
Revision: 00H04000 Serial number: 525 PA8J110885
Coding: 0110001
VCID: 372B3C2DF34C1532AE1-8062
Address 6D: Trunk Elect. (----) Labels:| 7N0-959-107.clb
Part No SW: 7P6 959 107 HW: 7P6 959 107
Component: HDSG-Modul H10 0611
Revision: 22010001 Serial number: 052100099 Dataset Number: 7p0771v____ 0009
Coding: 0533314003
ASAM Dataset: EV_HeckkTouar 202135
ROD: EV_HeckkTouar.rod
0054 - Pinch Protection Strip 1
B11DB 11 [00001000] - Short to Ground
Mileage: 154840 km
Date: 2024.08.21
Time: 21:44:42
Voltage terminal 30: 0.80 V
0057 - Pinch Protection Strip 2
B11DC 11 [00001000] - Short to Ground
Mileage: 154840 km
Date: 2024.08.21
Time: 21:44:42
Component: TSG HR H09 0162
Revision: -------- Serial number: 0000113659601
End----------(Elapsed Time: 01:59, VBatt start/end: 14.6V/14.6V)-----------
