Hi
I'm hoping for some help on a coding issue I'm having on a 2007 VW Caddy. I do not know much about the history of the van other than its got an ECU and ABS module from a VW Touran and has already had the Immobilser and a remap to 145bhp. the owner before me say the ABS module gave up on him and had it replaced with a used unit where both module and pump part numbers are identical to the original which I do have and have checked to verify this. upon trying to recode the unit as the fault code says it needs it the unit takes the code with code accepted but the ABS and traction light still remains on as does the fault code. hopfully below is the data and catalog of fault codes its thrown up.
thank you in advance for any help and advice given
Saturday,23,November,2024,10:36:26:64489
VCDS Version: 24.7.1.0 (x64) HEX-V2 CB: 0.4643.5
VIN: WVGZZZ1TZ6W190006 License Plate: EU07
Mileage: 276780km-171983mi Repair Order:
Chassis Type: 1T (1K0)
Scan: 01 03 08 09 11 31 15 16 17 19 25 42 44 46 4F 52 56
VIN: WVGZZZ1TZ6W190006 Mileage: 276780km-171983miles
09-Cent. Elect. -- Status: Malfunction 1010
11-Engine II -- Status: Cannot be reached 1100
31-Engine other -- Status: Cannot be reached 1100
Address 01: Engine Labels: 03G-906-016-BKC.clb
Part No SW: 03G 906 016 CB HW: 028 101 227 2
Component: R4 1,9L EDC 0000SG 6176
Revision: 12345678 Serial number: XXXXXXXXXXXXXX
Coding: 0003031
Shop #: WSC 35110 377 00162
VCID: 65906910096E78B2CCD-8030
VINID: 9E65EAAAA064A869C1240000188B735BD4
19794 - Control Circuit for Glow Plug Controller 1
P3338 - 000 - Electrical Malfunction
RPM: 798 /min
Torque: 38.0 Nm
Voltage: 14.06 V
Bin. Bits: 11000000
Temperature: 45.0°C
Bin. Bits: 11111111
17903 - Switch-Over Valve for EGR Cooler (N345)
P1495 - 000 - Open or Short to Ground
RPM: 798 /min
Torque: 38.0 Nm
Voltage: 14.06 V
Bin. Bits: 11000000
Mass Air / Rev.: 260.0 mg/str
Mass Air / Rev.: 430.0 mg/str
17848 - EGR Valve (N18)
P1440 - 000 - Open Circuit
RPM: 798 /min
Torque: 36.0 Nm
Voltage: 14.06 V
Bin. Bits: 11000000
Mass Air / Rev.: 425.0 mg/str
Readiness: 1 2 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.clb
Part No: 1K0 907 379 P
Component: ASR FRONT MK70 0105
Coding: 0017106
Shop #: WSC 57466 005 104857
VCID: 3FDC9B78CB720262661-806A
Part No SW: 2K0 820 047 BB HW: 2K0 820 047 BB
Component: Climatic PQ35 141 1010
Revision: 00141028 Serial number: 00000000000000
VCID: 66926E1CF46873AAC57-8032
00898 - Control Circuit A/C compressor
010 - Open or Short to Plus
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-M.lbl
Part No SW: 3C0 937 049 AH HW: 3C0 937 049 AH
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 01000007112026
Coding: 00884F030004100047000000000000000008FB075C000100000000000000
Shop #: WSC 35110 377 08192
VCID: 6FBC0B38DB92B2E2B61-803A
Subsystem 1 - Part No: 1T0 955 119 D Labels: 1KX-955-119.CLB
Component: Wischer 250506 020 0501
Coding: 00038805
Shop #: WSC 35110
00926 - Terminal 30
Reset counter: 198
Mileage: 276786 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 5.00 V
Address 11: Engine II
Address 15: Airbags Labels: 6Q0-909-605-VW52.lbl
Part No SW: 6Q0 909 605 AH HW: 6Q0 909 605 AH
Component: 09 AIRBAG VW52 023 2400
Revision: 04023000 Serial number: 0037TD0EBGLS
Coding: 0012345
Shop #: WSC 35110 377 00157
VCID: 7DA0217081FED07234D-8028
Part No SW: 1K0 953 549 AN HW: 1K0 953 549 AN
Component: Lenksäulenmodul 636 0070
Coding: 0000001
VCID: 7EA2267C8CF8CB6A2D7-802A
Part No: 1T0 920 962 E
Component: KOMBIINSTRUMENT VDD 4312
Coding: 0000013
Shop #: WSC 00011 888 06946
VCID: 3632FE5CE448C32AB57-8062
Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533 Gateway H07 0052
Revision: H07 01 Serial number: 300507F2002059
Coding: EB801F060002037401
VCID: 303EC844062CED1AEFB-8064
Fault Status: 00110100
Reset counter: 237
Mileage: 276773 km
Time: 00:25:51
Reset counter: 237
Mileage: 276773 km
Time: 00:24:47
01342 - Engine Control Module 2 (Slave 1)
Reset counter: 197
Mileage: 276773 km
Time: 00:19:06
Component: IMMO VDD 4312
01176 - Key
Part No SW: 1T0 959 701 D HW: 1T0 959 701 D
Component: Tuer-SG 006 1206
Coding: 0000560
VCID: 382EF064EE5C355AA7B-806C
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K2 909 144 M
Component: EPS_ZFLS Kl.140 H08 1901
Shop #: WSC 35110 666 38454
02546 - Steering Limit Stop
Mileage: 276760 km
Temperature: 9.0°C
Voltage: 11.70 V
Voltage: 11.50 V
Mileage: 276760 km
Temperature: 7.0°C
Voltage: 12.50 V
Voltage: 12.30 V
Address 46: Central Conv. Labels:. 1K0-959-433-MIN.clb
Part No: 1K0 959 433 CP
Component: KSG 0401
Coding: 988A0C087F2D8405485A030010C0
Shop #: WSC 00046 412 819200
VCID: 005E5884F60CBD9A5FB-8054
02483 - Module for Locking of Rear Lid (F327)
Address 4F: Centr. Electr. II (J533) Labels:. 1K0-907-532.clb
Part No SW: 1K0 907 532 HW: 1K0 907 951
Coding: 00000000
VCID: 66926E1CF86873AAC57-8032
Part No SW: 1T0 959 702 D HW: 1T0 959 702 D
Coding: 0000560
VCID: 3928F560D5562C52585-806C
Address 56: Radio Labels: 1K0-035-1xx-56.clb
Part No SW: 1K0 035 186 AD HW: 1K0 035 186 AD
Component: Radio BVX 034 0046
Revision: 00034000 Serial number: VWZ1Z2G4777782
Coding: 0020200
VCID: 688E6024FE7C65DAF7B-803C
00849 - S-contact at Ignition/Starter Switch (D)
End----(Elapsed Time: 01:07, VBatt start/end: 11.7V/11.7V. VIgn 11.7V)-----
