- Jan 12, 2020
- 63
- 12
- London, UK
- C?ID=104745
HI chaps
Japanese spec Up
Trying to change adaptation of Units in 17 from KM to MIles
Controller accepts value but nothing changes
Assuming it needs security access?
Already tried
20103
25327
47115
Anyone know the correct security code for this variant of cluster?
Japanese spec Up
Already tried
20103
25327
47115
Thursday,19,September,2024,19:31:34:10550
VCDS Version: 24.7.0.0 (x64) HEX-NET2 CB: 0.4643.5
VIN: WVWZZZAAZED075983 License Plate:
Chassis Type: AA-VW12 (6N0)
Scan: 01 02 03 09 15 17 19 25 44 56 AD
VIN: WVWZZZAAZED075983 Mileage: 61890km-38456miles
AD-Brake Sensors -- Status: Malfunction 0010
Address 01: Engine (J623-CHYB) Labels:. 04C-906-020-CHY.clb
Part No SW: 04C 906 020 BT HW: 04C 907 309 N
Component: R3 1.0l MPI H23 9164
Revision: UOH23--- CVN: DA3016B5
Coding: 00140012020400000000
Shop #: WSC 64320 981 00000
ASAM Dataset: EV_ECM10MPI01104C906020BT 001009
ROD: EV_ECM10MPI01104C906020AM_VW12.rod
VCID: 6E8EA0552015961ABDF-803A
VINID: 9E69EAAAA451A955001C52480C2AE1E03D
4629 - ECM Power Relay Load Circuit
P068A 00 [00100100] - Opens Too Early
Engine RPM: 0.00 /min
Coolant temperature: 19 °C
Intake air temperature: 20 °C
Voltage terminal 30: 10.295 V
Mass flow through throttle valve: 0.0 kg/h
Effective_injection_duration: 0.000 ms
Engine operating condition: Idle
Address 02: Auto Trans (J514) Labels:* Redir Fail!
Part No SW: 0CT 927 750 M HW: 0CT 927 750 A
Component: SQ100 H10 0160
CVN: 375C68D5
Coding: 010120
Shop #: WSC 18884 004 1048576
ASAM Dataset: EV_TCMSQ101011 006014
ROD: EV_TCMSQ101011_006.rod
VCID: 52F614A5946DD2FAB97-8006
Address 03: ABS Brakes (J104) Labels: 1S0-614-517.clb
Part No SW: 1S0 614 517 E HW: 1S0 614 517 E
Component: EBC 460 ESP H08 0012
Serial number: A00HOKG
Coding: 11BF247189B402F6880324FD91AC408059B200
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_Brake1ESPMP1TRWVW120 016035
ROD: EV_Brake1ESPMP1TRWVW120.rod
VCID: 31347B29F1ABC9E2E0D-8064
0342 - Please Check Fault Codes in Transmission Control Module
U1026 00 [00001000] - -
[MSG_GE1_ZIELGANG_FAULT]
Reset counter: 17
DTC: 00 01 56
0343 - Please Check Fault Codes in Transmission Control Module
[MSG_GE1_WAHL_POS_FAULT]
Reset counter: 17
DTC: 00 01 57
Address 09: Cent. Elect. (J519) Labels:. 1S0-937-09x-V1.clb
Part No SW: 1S0 937 087 E HW: 1S0 937 087 E
Component: PQ25 BCM H30 0561
Revision: -E------ Serial number: --------------
Coding: 62B82B0000010000000000042C28ACC00040400C60020000200000400100
VCID: 3B285901236733B24A1-806E
Reset counter: 17
Mileage: 61890 km
Date: 2019.02.10.
Time: 03:53:06
Part No SW: 1S0 959 655 B HW: 1S0 959 655 B
Component: VW10Airbag00Q H03 0006
Revision: -------- Serial number: 003MY00606XI Dataset Number: 120003v____ 0109
Coding: 000000000000000000000000000000003051
ASAM Dataset: EV_AirbaVW10BPAVW12X 001001
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 3D2C57193DF33D82745-8068
Serial number: 3495RRB400G50PGAGHG$
Serial number: 3505RRB400M50OM6DH8R
Serial number: 3555NRB400250QM0PHRZ
Address 17: Instruments (J285) Labels:| 1Sx-920-xxx-17.clb-SRI1
Part No SW: 1S0 920 860 N HW: 1S0 920 860 N
Component: KOMBI H31 0205
Revision: X0031012 Serial number: 00000000000000
Coding: 114200
ASAM Dataset: EV_KombiUDSMM9RM10 A04752
ROD: EV_KombiUDSMM9RM10_A04_VW12.rod
VCID: 3B28590123E733B24A1-806E
Part No SW: 6N0 909 901 HW: 1S0 937 087 E
Component: GW-K-CAN TP20 H30 0561
Revision: -E------
Coding: 001300
VCID: 70B2BE2D3AA180EAAF3-8024
Address 25: Immobilizer (J334) Labels:. 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 1S0 920 860 N
Component: IMMO H31 0205
ASAM Dataset: EV_ImmoUDSMM9RM10 A01702
VCID: 6A86AC451CFD7A3AE17-803E
Address 44: Steering Assist (J792) Labels:| 6Rx-909-144-V2.clb
Part No SW: 6R2 909 144 R HW: 6R2 909 144 E
Component: EPS_TRW_ALow 321 3111
Serial number: CDC60317 Dataset Number: 1S0074v____ 0222
Coding: 0007
Shop #: WSC 55320 001 1048576
ASAM Dataset: EV_SteerAssisUDSTRW 011021
ROD: EV_SteerAssisUDSTRW_011.rod
VCID: 47C035F16F2F6752DE9-8012
1074688 - Function Restricted due to Insufficient Voltage
U1400 00 [00001000] - -
[DEM_SUPPLY_LOST_NO_ENG_CRANK_FAULT]
Reset counter: 17
Engine RPM: 0 /min
Vehicle speed: 0.00 km/h
Terminal 15 status: Terminal 15 off
Voltage terminal 30: 0.00 V
Power steering current consumption: 0.00 A
max.value: 255.99 A
End stage temperature: 215 °C
Steering assistance: engine output: 0.00 %
Engine angle: 511.984 °
Electric motor speed: 32767 /min
Steering assistance: target engine torque: 0.00 Nm
Steering torque: 0.00 Nm
Status: Measuring value not available
Address 56: Radio (J503) Labels: None
Part No SW: 1S0 035 156 C HW: 1S0 035 156 C
Component: Radio H03 0006
Revision: R0000000 Serial number: VWZAZ1N0644022
Coding: 0000020001
VCID: 2B086941D307A332DA1-807E
Address AD: Brake Sensors (J939) Labels: 1S0-907-201.clb
Part No SW: 1S0 907 201 A HW: 1S0 907 201 A
Component: CV-SENSOR H06 0460
ASAM Dataset: EV_CVSen 001001
ROD: EV_CVSen.rod
VCID: 2802964DC271882A373-807C
0004 - Function Restricted due to Insufficient Voltage
Fault Frequency: 22
Reset counter: 100
Mileage: 61592 km
Date: 2024.05.05.
Time: 11:31:42
End----------(Elapsed Time: 01:11, VBatt start/end: 13.6V/13.7V)-----------
