I need help adjusting some modules (2020 Golf)
wiradjuri
Unverified
Australia
C?ID=597967 (PNG/CB)
i need some help fixing my light configs dynamic light assist, lane assist and cruise control here is a scan:
Wednesday,20,November,2024,21:31:19:44342
VCDS Version: 24.7.1.0 (x64)  HEX-NET2 CB: 0.4643.5
VIN: WVWZZZAUZLW063701   License Plate:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 17 19 22 29 2B 36 39 3C 42 44
          47 4B 52 5F A5 A9 D6 D7
VIN: WVWZZZAUZLW063701   Mileage: 85865km-53354miles
29-Left Light -- Status: Not registered 0001
39-Right Light -- Status: Not registered 0011
D6-Light Ctrl Left 2 -- Status: Not registered 0001
D7-Light Ctrl Right 2 -- Status: Not registered 0001
Address 01: Engine (J623-DJHB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 259 J    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0003
   Revision: --H13---    CVN: 7530B9BC
   Coding: 092500122466050B3000
   Shop #: WSC 12345 123 61029
   ASAM Dataset: EV_ECM20TFS0208V0906259J 001005
   ROD: EV_ECM20TFS0208V0906259J.rod
   VCID: 47C0284CAF272752DE1-8012
   VINID: 9E69EAAAA465A9C9C01831C0040583173C
Readiness: 0010 0001
   Part No SW: 0GC 300 014 B    HW: 0GC 927 711 H
   Component: GSG DQ381     H06 2401
   Revision: 00H06V09    CVN: C78D81BB
   ROD: EV_TCMDQ381061.rod
   VCID: 241A9FC07E512C4A1B3-8070
   No subsystems:
   Part No SW: 5Q0 614 517 ES    HW: 5Q0 614 517 BP
   Component: ESC           H35 0190
   Revision: 00000000    Serial number: 62769000002658
   Coding: 01FA93A15026216F477E070060C46980C90A84E2E0069677384250B8D2A84B0B0000000012121212B835351919323200
   ROD: EV_Brake1UDSContiMK100IPB_038_VW37.rod
   VCID: 065EE548E8ADFE5A657-8052
   Part No SW: 3Q0 959 435 N    HW: 3Q0 959 435 N
   Component: VWKESSYMQB    037 1307
   Revision: 00037000    Serial number: 0530120667 Dataset Number: V03935272JC 0001
   Coding: 132C2C0723
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 45DC2244952B35422CD-8010
   Part No SW: 5G0 907 044 FD    HW: 5G0 907 044 FD
   Component: Climatronic   H04 2201
   Revision: 00001K10
   Coding: 001200242001000D110500001210142A
   ASAM Dataset: EV_ACClimaBHBVW37X 006150
   VCID: 6E8EBDE8E01DD61ABD7-803A
   Air quality sensor:
   Part No SW: 5Q0 937 084 DG    HW: 5Q0 937 084 CF
   Component: BCM MQBAB M+  H40 0312
   Serial number: 01001928001541 Dataset Number: V03935315NV 0001
   Coding: E21004378820A7000000000000008020007B004B00AD000C00440A040000
   ASAM Dataset: EV_BCMMQB 020001
   ROD: EV_BCMBOSCH_020_VW37.rod
   VCID: 0052F350CA89D06A5FB-8054
   Component: WWS    190915  042  0551
   Serial number:         190926204615
   Coding: 004DDD
   Subsystem 2 - Part No SW: 5Q0 955 547 C    HW: 5Q0 955 547 C  Labels: 5Q0-955-547.CLB
   Component: RLHS  051  0206
   Serial number: SBY19M10D10H18M53S07
   Coding: 07A8DD
   Component: Sensor, DWA  005  0316
   Serial number: 000000000ZY192701YZA
   Subsystem 4 - Part No SW: 5Q0 951 605 B    HW: 5Q0 951 605 B
   Component: Sirene, DWA  004  0007
   Serial number: 00000000000000641545
   Sunroof control module:
   Component: J245 PS73.404  H04  0005
   Serial number: 0000FST002EOB2H00000
   Coding: 181901
   Steering Column Switch:
   Subsystem 6 - Part No SW: 5Q1 953 507 M    HW: 5Q1 953 549
   Component: J527 SMLS MQB  004  0070
   Serial number: 00000029091904221259
7 Faults Found:
14858 - Bulb for Right Brake Lamp / Tail Lamp
          B133C 15 [00001001] - Open or Short to Plus
                    Reset counter: 214
                    Mileage: 85865 km
                    Date: 2024.11.20
                    Time: 21:56:45
                    Terminal 15 status: On
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    Status Bremslichtschalter (HW): On
                    Status Bremslichtschalter (CAN): On
                    OFF: Not operated
                    Position lamps: Not operated
                    Low beam: Not operated
                    Voltage: 12.1 V
                    Outside temperature: 25.0  C
526615 - Control Module Incorrectly Coded
          U1014 00 [00001001] - -
          [Steuerger t falsch codiert->Keine Anzeige]
                    Reset counter: 214
                    Mileage: 85865 km
                    Date: 2024.11.20
                    Time: 21:25:23
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 12.6 V
                    Outside temperature: 23.5  C
560917 - Databus
          [Areaview_01_alt Datenbus fehlende Botschaft]
                    Reset counter: 214
                    Mileage: 85865 km
                    Date: 2024.11.20
                    Time: 21:25:26
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 12.6 V
721156 - Control Module for Roof Shade
          U10A6 00 [00001001] - No Communications
          [Steuerger t f r Dachrollo->kein Signal/ Kommunikation]
                    Reset counter: 214
                    Mileage: 85865 km
                    Date: 2024.11.20
                    Time: 21:25:27
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 12.6 V
795662 - Switch for Driver Assist Systems
          B17F8 04 [00001001] - Internal System Fault
                    Reset counter: 214
                    Mileage: 85865 km
                    Date: 2024.11.20
                    Time: 21:25:28
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 12.6 V
798988 - Steering Column Control Module
          B105D 01 [00001001] - Electrical Failure
          [Schaltermodul Lenks ule (SMLS)->elektrischer Fehler]
                    Reset counter: 214
                    Mileage: 85865 km
                    Date: 2024.11.20
                    Time: 21:25:28
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 12.6 V
940292 - Sensor for Sunlight Exposure
          U11FB 00 [00001001] - No Communications
          [Sonnensensor->kein Signal / Kommunikation]
                    Reset counter: 214
                    Mileage: 85865 km
                    Date: 2024.11.20
                    Time: 21:25:27
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 12.6 V
   Part No SW: 5QA 919 294 G    HW: 5QA 919 294
   Component: PDC 8 Kanal   H08 0061
   Serial number: 000150058319284 Dataset Number: V03935292E  0001
   Coding: 0471155811
   ASAM Dataset: EV_EPHVA18AU3700000 009046
   VCID: 50F203105A69E0EA8FB-8004
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V2.clb
   Part No SW: 5Q0 907 572 P    HW: 3QF 907 572 A
   Dataset Number: V03935290LX 0001
   Coding: 32000071DDFFFF28009F813F8040030000000000008A000014
   VCID: 44DA3F409E110C4A3B3-8010
0267 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
          C1103 00 [00001001] - -
          [FAULT_ALIGNMENT_NOT_OK]
                    Reset counter: 209
                    Mileage: 85777 km
                    Date: 2024.11.20
                    Time: 00:41:06
                    Control Module temperature: 60  C
                    Voltage terminal 15: 12.6 V
                    Longitudinal_acceleration_vehicle_reference: 0.00 m/s
0803 - Databus
          [FAULT_BV1_FEHLER]
                    Fault Frequency: 13
                    Reset counter: 214
                    Mileage: 85777 km
                    Date: 2024.11.20
                    Time: 00:41:06
1136 - Databus
          [FAULT_TIMEOUT_SWA_OBJEKT_01_02]
                    Reset counter: 209
                    Mileage: 85777 km
                    Date: 2024.11.20
                    Time: 00:41:06
1137 - Databus
          [FAULT_TIMEOUT_SWA_OBJEKT_03_04]
                    Reset counter: 209
                    Mileage: 85777 km
                    Date: 2024.11.20
                    Time: 00:41:06
1138 - Databus
          [FAULT_TIMEOUT_SWA_OBJEKT_05_06]
                    Reset counter: 209
                    Mileage: 85777 km
                    Date: 2024.11.20
                    Time: 00:41:06
   Serial number: 21091941350034 Dataset Number: V03935231PP 0001
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 38225BB0D2D958AAA7B-806C
   Part No SW: 5Q0 959 655 BT    HW: 5Q0 959 655 BT
   Component: AirbagVW21    008 0403
   Serial number: 003FNR5SMPU6 Dataset Number: V03935279BC 0001
   Coding: 98CCC000000000005C000000008800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
   VCID: 1378CC1CABFF5BF2F29-8046
   Left seat belt tensioner:
   Serial number: 34169677E14101930238
   Coding: 333135
   Right seat belt tensioner:
   Serial number: 34169676E10101921197
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 001 410 19
   Serial number: 357000000000323D024%
   Subsystem 4 - Part No SW: -----------    HW: 480 001 510 19
   Serial number: 358000000005E97DD14$
   Subsystem 5 - Part No SW: -----------    HW: 480 401 510 19
   Component: SideSensor_Dr  005 6149
   Serial number: 3510001A6F1F57534B7D
   Subsystem 6 - Part No SW: -----------    HW: 480 401 410 19
   Component: SideSensor_Pr  005 6149
   Serial number: 3520001ACF2FD2065A4J
   Subsystem 7 - Part No SW: -----------    HW: 480 401 410 19
   Component: FrontSensor_D  005 6149
   Serial number: 3550001ACF1F5759A3CW
   Part No SW: 5G1 920 791 B    HW: 5G1 920 791 B
   Component: KOMBI         403 4191
   Coding: 23AC181EFFBC000801827B2B54020800A0000000
   VCID: 2B0874FC138FE332DA9-807E
9 Faults Found:
                    Reset counter: 212
                    Mileage: 85854 km
                    Date: 2024.11.20
                    Time: 11:10:12
1246802 - Interface Module for Vehicle Position/Orientation System
          B1306 52 [00001001] - Not Activated
                    Reset counter: 213
                    Mileage: 85865 km
                    Date: 2024.11.20
                    Time: 11:31:41
16776980 - Databus
          [PLA_Status_01 keine Kommunikation]
                    Reset counter: 212
                    Mileage: 85854 km
                    Date: 2024.11.20
                    Time: 11:10:12
16776987 - Databus
          [STS_01 keine Kommunikation]
                    Reset counter: 212
                    Mileage: 85854 km
                    Date: 2024.11.20
                    Time: 11:10:12
16776996 - Databus
          [FCW_01 keine Kommunikation]
                    Reset counter: 212
                    Mileage: 85854 km
                    Date: 2024.11.20
                    Time: 11:10:12
16777042 - Function Restricted due to Interrupted Communications
          U1110 00 [00001001] - -
          [BAP_PedAssist_0x3A keine Kommunikation]
                    Reset counter: 212
                    Mileage: 85854 km
                    Date: 2024.11.20
                    Time: 11:10:15
16777048 - Function Restricted due to Interrupted Communications
          [BAP_PEA_0x3C keine Kommunikation]
                    Reset counter: 212
                    Mileage: 85854 km
                    Date: 2024.11.20
                    Time: 11:10:15
16776985 - Databus
          [Quersperre (Botschaft tbd) keine Kommunikation]
                    Reset counter: 212
                    Mileage: 85854 km
                    Date: 2024.11.20
                    Time: 11:10:12
16777060 - Function Restricted due to Interrupted Communications
          [BAP_StartStopReasons_0x39 keine Kommunikation]
                    Reset counter: 212
                    Mileage: 85854 km
                    Date: 2024.11.20
                    Time: 11:10:15
   Part No SW: 3Q0 907 530 AC    HW: 3Q0 907 530 C
   Component: GW MQB High   521 5388
   Serial number: 05101910520674 Dataset Number: V03935303HQ 0001
   Coding: 030100047F485902FF1FBA7FFE1F00010001070100000000000000000000
   GVL: 01C63C100000060040DC80000000CC0000000000000200000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 70B2A390FA29C0EAAFB-8024
   Generator:
   Component: 4-00-03-00-04
   Subsystem 2 - Part No SW: 5G0 959 442 AE    HW: 5G0 959 442 AE  Labels: 3C8-959-537.CLB
   Component: E221__MFL-MD9  H12 0052
   Serial number: 29190002122670049385
   Coding: 2DFFFF
   Serial number: 2456402805
   Component: Haldex4Motion H55 7084
   Serial number: HA1-00012.09.19 Dataset Number: v1260x015G0 0000
   Coding: 0001
   VCID: 4CCA1760B641C40AF33-8018
Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
   Component: LCM_MLBevoH09 0014
   Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
   Component: ELV-MQBB      H08 0021
   Serial number: 19000278139012
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 3134669431A389E2E05-8064
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Part No SW: 5Q0 959 760 E    HW: 5Q0 959 760 E
   Component: Sitzmemory    H09 0026
   Serial number: Y0007SIO30727
   Coding: 0014000000000500018280808080000000008181000000F400
   ASAM Dataset: EV_SeatMemorDriveSide 002022
   VCID: 3FD030ACF7F76F92661-806A
Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
0033 - Supply voltage
          U1011 00 [00001000] - Voltage too Low
          [Supply voltage - lower limit exceeded]
                    Reset counter: 249
                    Mileage: 85777 km
                    Date: 2024.11.20
                    Time: 00:42:53
   Serial number: 0529186820 Dataset Number: V03935258DF 0001
   Coding: 02011203
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3D2C4AA4FDFB7D8274D-8068
   Component: HRE_Slave  H12 0081
   Serial number: 0529752812
   Coding: 020112
   Part No SW: 5Q0 959 593 K    HW: 5Q0 959 593 F
   Component: TSG FS002 0325
   Serial number: YE007SIH16414 Dataset Number: V03935306VE 0001
   Coding: 00331220D601048000001000
   VCID: 49C42E74B933D122C85-801C
   Subsystem 1 - Part No SW: 5Q0 959 408     HW: 5Q0 959 164   Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_DRV  007 0010
   Serial number: 00000000000034551614
   Coding: 0D0000
   Part No SW: 3Q0 909 144 M    HW: 3Q0 909 144 L
   Dataset Number: V03935302SY 0001
   Coding: 979F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 3C2A47A0E6E1748A433-8068
   Part No SW: 5Q0 035 456 A    HW: 5Q0 035 456 A
   Component: MIB2_lite_amp H40 0200
   Revision: 00000001    Serial number: VWZ8Z1KMD06AWWJ Dataset Number: V03935259RT 0001
   Coding: 12000000008AAA8A000000000000
   ASAM Dataset: EV_AMPMst11CGen2ALPI 001003
   ROD: EV_AMPMst11CGen2ALPI_VW37.rod
   VCID: 2E0E7DE8209D961AFD7-807A
0517 - Rear Left Treble Speaker
          B1066 13 [00001000] - Open Circuit
          [Hochtonlautsprecher Kanal 2: Unterbrechung (AC-Diagnose)]
                    Reset counter: 253
                    Mileage: 85777 km
                    Date: 2024.11.20
                    Time: 00:40:06
                    Voltage terminal 30: 12.9 V
   Part No SW: 3Q0 907 338 E    HW: 3Q0 907 338 E
   Component: FCM MQB Low   003 0367
   Serial number: 07101910801425 Dataset Number: V03935292JZ 0001
   Coding: 00000005090017F30720FAFFFA0000030000000000000000000000000000
   ROD: EV_MultiModulContiVW48X_003.rod
   VCID: 3720588CDFC757D2AE1-8062
14 Faults Found:
13705479 - Databus
          [Kamera_FDD_Obj01 data bus missing message]
                    Reset counter: 212
                    Mileage: 85854 km
                    Date: 2024.11.20
                    Time: 11:08:57
0035 - Databus for Front Lighting
          U12EB 00 [00001001] - Additional Installations Detected
          [CAN_AFS_multiple_plug_LCM_identified]
                    Reset counter: 214
                    Mileage: 85854 km
                    Date: 2024.11.20
                    Time: 11:08:57
0037 - Databus for Front Lighting
          [CAN_AFS_multiple_plug_LED_Leimo_identified]
                    Reset counter: 214
                    Mileage: 85854 km
                    Date: 2024.11.20
                    Time: 11:08:57
13705999 - Databus
          U1123 00 [10001001] - Received Error Message
          [Kamera_FDD_Funktionsstatus_Fehler received error status]
                    Reset counter: 214
                    Mileage: 85854 km
                    Date: 2024.11.20
                    Time: 11:08:57
13706000 - Databus
          [Kamera_FDD_Eigenblend_Guete received error status]
                    Reset counter: 214
                    Mileage: 85854 km
                    Date: 2024.11.20
                    Time: 11:08:57
0024 - invalid data record
          B2005 00 [10001001] - -
          [Data set MXB not valid]
                    Reset counter: 212
                    Mileage: 85854 km
                    Date: 2024.11.20
                    Time: 11:08:57
9437441 - invalid data record
          B2005 00 [00001001] - -
          [Data set RTM not valid]
                    Reset counter: 212
                    Mileage: 85854 km
                    Date: 2024.11.20
                    Time: 11:08:57
5350720 - Left Matrix High Beam
          C1175 54 [10001001] - Missing Calibration / Basic Setting
                    Reset counter: 212
                    Mileage: 85854 km
                    Date: 2024.11.20
                    Time: 11:08:57
5350976 - Right Matrix High Beam
          C1176 54 [10001001] - Missing Calibration / Basic Setting
                    Reset counter: 212
                    Mileage: 85854 km
                    Date: 2024.11.20
                    Time: 11:08:57
0032 - Headlight
          C107E 54 [10001001] - Missing Calibration / Basic Setting
                    Reset counter: 214
                    Mileage: 85865 km
                    Date: 2024.11.20
                    Time: 21:04:28
9437699 - Databus
          [RTM_CAN_communication_fault_to_BMC]
                    Reset counter: 212
                    Mileage: 85854 km
                    Date: 2024.11.20
                    Time: 11:08:57
9437700 - Databus
          [RTM_CAN_communication_fault_to_Drive_Motor_Control_Module]
                    Reset counter: 212
                    Mileage: 85854 km
                    Date: 2024.11.20
                    Time: 11:08:57
9437701 - Databus
          [RTM_CAN_communication_fault_to_Brake_Boost]
                    Reset counter: 212
                    Mileage: 85854 km
                    Date: 2024.11.20
                    Time: 11:08:57
9437703 - Databus
          [RTM_CAN_communication_fault_to_High_Voltage_Battery_Charge_Management]
                    Reset counter: 212
                    Mileage: 85854 km
                    Date: 2024.11.20
                    Time: 11:08:57
   Part No SW: 5Q0 959 592 K    HW: 5Q0 959 592 F
   Component: TSG BFS002 0325
   Serial number: YE007SII23473 Dataset Number: V03935306VP 0001
   Coding: 003F1020DE01048000001000
   VCID: 48C22B70A239282AD7B-801C
   Subsystem 1 - Part No SW: 5Q0 959 407     HW: 5Q0 959 163   Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_PSG  007 0010
   Serial number: 00000000000034543344
   Coding: 150000
   Part No SW: 5NA 035 045 E    HW: 5NA 035 045
   Component: MU-H-N-RW     H55 1367
   Serial number: A849J0KB004460 Dataset Number: V03935300WU 0001
   Coding: 027310080000000041512602000908001F0107F601A00402DF
   VCID: 3A2641B8ECD54ABA51F-806E
   Subsystem 1 - Part No SW: 5G6 919 606     HW: 5G6 919 606
   Component: ABT_High-2  H61 9214
   Serial number: VWZ6ZJW2833297
   Subsystem 2 - Part No SW: V03 959 806 FP    HW: -----------
   Component: ROW 2019  --- 0076
   Compact disc data bank:
   Component: Gracenote2  --- 4013
                    Reset counter: 209
                    Mileage: 85777 km
                    Date: 2024.11.20
                    Time: 00:41:14
                    Voltage terminal 30: 13.0 V
7172 - Function Restricted due to Missing Message(s)
          U1111 00 [00001001] - -
          [HUD (heads-up display) settings (0x04) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 209
                    Mileage: 85777 km
                    Date: 2024.11.20
                    Time: 00:41:16
                    BAP-BAP_Function_ID: 02
7179 - Function Restricted due to Missing Message(s)
          [Rear-view camera (0x0B) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 209
                    Mileage: 85777 km
                    Date: 2024.11.20
                    Time: 00:41:16
7226 - Function Restricted due to Missing Message(s)
          [Pedestrian assist (0x3A) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 209
                    Mileage: 85777 km
                    Date: 2024.11.20
                    Time: 00:41:16
   Part No SW: 3Q0 980 654 L    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H12 0610
   Serial number: 04101912K14159 Dataset Number: V03935313CE 0001
   Coding: 000307040305010101042357815781FFF9804F33F02000
   ROD: EV_MFKBoschMQBB_002.rod
   VCID: 40D233508A09106A1FB-8014
0660 - No Basic Setting
          B2010 00 [00001001] - -
          [Initial_calibration_missing]
                    Reset counter: 214
                    Mileage: 85859 km
                    Date: 2024.11.20
                    Time: 11:24:21
                    Control Module temperature: 50  C
                    Vehicle speed: 66.56 km/h
                    System run time: 545.6 s
                    Voltage terminal 15: 12.2 V
                    mid: 00 1E
                    Status of camera: operational
                    Engine_Running_Info: 1
                    Software_Info_4: 0
                    Software_Info_3: 1
                    Software_Info_2: 6
                    Software_Info_1: 0
1123377 - Databus
          [Timeout_Gateway_72_Anhaenger_01_alt]
                    Reset counter: 214
                    Mileage: 85859 km
                    Date: 2024.11.20
                    Time: 11:24:22
                    Vehicle speed: 65.41 km/h
                    System run time: 546.6 s
                    mid: 02 94
                    Status of camera: System malfunction
                    Software_Info_4: 0
                    Software_Info_3: 1
                    Software_Info_2: 6
                    Software_Info_1: 0
1122656 - Databus
          [TIMEOUT_SWA_Objekt_01_02]
                    Reset counter: 214
                    Mileage: 85859 km
                    Date: 2024.11.20
                    Time: 11:24:22
                    Vehicle speed: 66.02 km/h
                    System run time: 546.2 s
                    mid: 02 10
                    Software_Info_4: 0
                    Software_Info_3: 1
                    Software_Info_2: 6
                    Software_Info_1: 0
   Part No SW: 5G0 907 159 D    HW: 4H0 907 159 A
   Serial number: 190722201053
   VCID: 2F3060EC27979F12F61-807A
   Part No SW: 7P5 941 572 AG    HW: 7P5 941 572 A
   Component: LED1L         H07 0008
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481.rod
   Component: LED1R         H07 0008
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
End----------(Elapsed Time: 02:23, VBatt start/end: 12.3V/12.3V)-----------
How did they get broken?
PS: We'll move this once we determine where it belongs based on your answer.
wiradjuri
Unverified
Australia
I've been trying to understand the leutche channels I'm finding quiet hard even after a translation to English I think I have the rear lights figured out except the rear right park light on the outside have a flicker when the lights are on the left side isn't doing it tho and I also kneed some help with the front lighting light assist lane assist and cruise control acc
Dr Sheldon
Windsor UK
C?ID=334979
Second Request
How did they get Broken ??
Is it a Secret ?
wiradjuri
Unverified
Australia
There not broken the adoptions are incorrect
OK, let me re-phrase that: How did they get to be incorrect? VW certainly did not ship the car that way.
wiradjuri
Unverified
Australia
well obviously i did it so im asking for some help
Westbury, UK
You've 'tweaked' the leuchte channels in ways we don't know, so you need to post an adaptation channel map of the Cent. Elect. and ideally also the AdpLog.csv file in C:\Ross-Tech\VCDS\Debug so we can see what tweaks you have made.
wiradjuri
Unverified
Australia
Ok thankyou for your instructions much appreciated
wiradjuri
Unverified
Australia
;SW:5Q0-937-084-DG   HW:5Q0-937-084-CF ---  Cent. Elect.
;Component:BCM MQBAB M+  H40 0312     Coding:E010043B8C21C7008000000410008800037E000300000008000C00000000
;EV_BCMMQB    020001    EV_BCMBOSCH_020_VW37.rod
;Friday    01    November    2024    19:49:49:44342
;VCDS Version: Release 24.7.1 (x64)  Data version: 20240919 DS356.3
;VCID: 0052F350CA89D06A5FB-8054
IDE00001-ENG99061-Production mode-Access control    not active     3
IDE00001-ENG115730-Production mode-Exterior lighting    not active     3
IDE00001-ENG112304-Production mode-Heckwischer    not active     3
IDE00001-ENG98647-Production mode-Interior lights    not active     3
IDE00001-ENG115729-Production mode-Scheinwerferreinigung    not active     3
IDE00001-ENG115731-Production mode-Virtuel_pedal    not active     3
IDE00002-Transport mode    active     1
IDE00820-Activating and deactivating all development messages    not active     1
IDE01550-Service position    170.494336 °    2
IDE02152-Characteristics in production mode    2000 ms    4
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking    DELAY     10
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln    not active     10
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global    not active     10
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn    not active     10
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln    not active     10
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn    short     10
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung    not active     10
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte    not active     10
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen    active     10
IDE02269-ENG133345-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl    not active     10
IDE02269-ENG142248-Acknowledgement signals-ZV-Blinken_Abschluss_Dunkelzeit    300 ms    10
IDE02269-ENG142247-Acknowledgement signals-ZV-Blinken_Dunkelzeit    300 ms    10
IDE02269-ENG142246-Acknowledgement signals-ZV-Blinken_Hellzeit    300 ms    10
IDE02332-Deactivate production mode    0    3
IDE02488-Anti-theft system interior monitoring    100%    1
IDE02711-ENG116690-Rear wiper-Automatisches Heckwischen    not active     8
IDE02711-ENG133397-Rear wiper-Einzelansteuerung Heckintervallwischen    not active     8
IDE02711-ENG133395-Rear wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 1    8 s    8
IDE02711-ENG133396-Rear wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 2    16 s    8
IDE02711-ENG112304-Rear wiper-Heckwischer    logikgesteuert     8
IDE02711-ENG114947-Rear wiper-Heckwischer Weiterlauf    not active     8
IDE02711-ENG114946-Rear wiper-Komfortwischen Heck    active     8
IDE02711-ENG116695-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1    5 s    8
IDE02711-ENG116696-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2    3 s    8
IDE02711-ENG116694-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik    7 s    8
IDE02711-ENG116693-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall    7 s    8
IDE02711-ENG116689-Rear wiper-Menuesteuerung Komfortwischen HW    active     8
IDE02711-ENG154784-Rear wiper-Spannungsanforderung_konfig_Wischer    Keine_Spannungsanforderung     8
IDE02711-ENG116691-Rear wiper-Traenenwischen Heck    active     8
IDE02711-ENG154831-Rear wiper-Zeit_wasch_min_heck    0 ms    8
IDE03638-IDE04231-Stationary cornering lamp-Steering wheel angle: offset    0.3 °    16
IDE03638-ENG116677-Stationary cornering lamp-Abdimmgeschwindigkeit    100.0 %/s    16
IDE03638-ENG116673-Stationary cornering lamp-bei Rueckwaertsfahrt    both sides     16
IDE03638-ENG116675-Stationary cornering lamp-Lower speed threshold    0.0 km/h    16
IDE03638-ENG116682-Stationary cornering lamp-Maximaltemperatur    100.0 °C    16
IDE03638-ENG116679-Stationary cornering lamp-obere Grenztemperatur    95.0 °C    16
IDE03638-ENG116681-Stationary cornering lamp-Oberer Lenkradwinkel    120 °    16
IDE03638-ENG116680-Stationary cornering lamp-untere Grenztemperatur    80.0 °C    16
IDE03638-ENG116678-Stationary cornering lamp-Unterer Lenkradwinkel    80 °    16
IDE03638-ENG116676-Stationary cornering lamp-Upper speed threshold    110.0 km/h    16
IDE03638-ENG116674-Stationary cornering lamp-Vorschrift    ECE R119     16
IDE03638-ENG115830-Stationary cornering lamp-Zeitwert Einschaltzeit Abbiegelicht    2 min    16
IDE03787-Activate left/right hand drive switch-over    not active     1
IDE04927-IDE01446-Window heater-Running time of heated front window    240 s    11
IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung    35.0 °C    11
IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung    35.0 °C    11
IDE04927-ENG142251-Window heater-Frontscheibenheizung _maximale_Dauer    0 s    11
IDE04927-ENG142035-Window heater-Frontscheibenheizung_LED_direkt    not installed     11
IDE04927-ENG142018-Window heater-Frontscheibenheizungsansteuerung direkt von externem Algorithmus    not installed     11
IDE04927-ENG126845-Window heater-FSH Automatik    active     11
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert    320 s    11
IDE04927-ENG141955-Window heater-heizbare Heckscheibe    installed     11
IDE04927-ENG142021-Window heater-Heizbare_Frontscheibe    not installed     11
IDE04927-ENG246969-Window heater-HZG_Wischer_Ablage    not installed     11
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH    active     11
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH    active     11
IDE04927-ENG246996-Window heater-WAH_Temp_Wischer_aktiv    -2.0 °C    11
IDE04927-ENG141962-Window heater-Waschduesenheizung    not installed     11
IDE04927-ENG154810-Window heater-window heating front activation time pause    320 s    11
IDE04928-MAS01577-Anti-theft protection-Parking heater    not installed     8
IDE04928-ENG115867-Anti-theft protection-Akustischer Alarm Signalhorn    not active     8
IDE04928-ENG115864-Anti-theft protection-Alarmsignal    frequency modulated     8
IDE04928-ENG141960-Anti-theft protection-Anti-theft alarm system    active     8
IDE04928-ENG154588-Anti-theft protection-Deaktivierung DWA-Sensoren via Doppelklick    not_active     8
IDE04928-ENG154589-Anti-theft protection-Deaktivierung_DWA_Sensoren_HMI    activ     8
IDE04928-ENG115865-Anti-theft protection-DWA Alarmverzoegerung    not active     8
IDE04928-ENG115812-Anti-theft protection-DWA Camper Modus    not active     8
IDE04928-ENG142007-Anti-theft protection-DWA_Einfachhorn_oder_Sounder    Sounder_verbaut     8
IDE04928-ENG141961-Anti-theft protection-Heckscheibenbruchsensor    not installed     8
IDE04928-ENG142006-Anti-theft protection-IRUE_NGS_Deaktivierungstaster_direkt_am BCM_verdrahtet    No     8
IDE04928-ENG142249-Anti-theft protection-OBD Alarm    activ     8
IDE04928-ENG154722-Anti-theft protection-RHF_Panikalarm    activ     8
IDE04928-ENG142009-Anti-theft protection-Schliesszylinder in_Richtung Oeffnen_aktiv (Thatcham inaktiv)    No     8
IDE04928-ENG142010-Anti-theft protection-Sensor_fuer_Innenraumueberwachung    Yes     8
IDE04928-ENG115866-Anti-theft protection-Sirenen Alarmzahl    10 Alarme     8
IDE04928-ENG142008-Anti-theft protection-tilt_sensor    Yes     8
IDE04928-ENG126842-Anti-theft protection-Ueberwachung Innenentriegelungshebel    not active     8
IDE04928-ENG115868-Anti-theft protection-Verzoegerung Panikalarm    2 sekunden verzoegerung     8
IDE05143-MAS02985-Writing parameter-Value    130    5
IDE05143-MAS04381-Writing parameter-Parameter address    FE 00 00     5
IDE05144-Read parameter address    FE 00 00     3
IDE05145-Light configuration    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 00 00 00 14 00 64 00 00 00 00 00 00 00 00 00 04 3A 00 20 14 0B 7F 00 00 00 00 00 00 00 00 00 04 44 00 21 14 0C 7F 00 00 00 00 00 00 00 00 00 05 36 00 1A 0B 0F 7F 00 00 00 00 00 00 00 00 00 05 40 00 1B 0C 0F 7F 00 00 00 00 00 00 00 00 00 05 44 00 4B 46 00 7F 08 0A 7F 00 00 00 00 00 00 05 3A 00 49 46 00 7F 08 09 7F 00 00 00 00 00 00 02 37 00 1E 0D 0F 7F 00 00 00 00 00 00 00 00 00 02 41 00 1F 0E 0F 7F 00 00 00 00 00 00 00 00 00 06 38 00 22 12 0B 7F 00 00 00 00 00 00 00 00 00 06 42 00 23 0B 0C 7F 00 00 00 00 00 00 00 00 00     224
IDE05822-Anti-theft alarm system vehicle inclination sensor    100%    1
IDE05823-DWA Interior monitoring parameter set    01 0A 08 00 43 53 0A C8 01 14 0A 03 81 33 0C 00 00 00 01 CD D6 06 00 0F 1E 00 85 0F 39 F7 64 23 45 42 57 9B 25 44 3F 3A 69 58 95 2D 09 A3 02 7A 06 56 00 0F 17 00 89 10 2F F7 69 0F E3 42 87 1B 05 34 3F 3A 69 58 93 08 09 A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 69 1E 65 42 77 1B 05 24 3F 3A 69 47 93 08 09 A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 44 0C 42 20 57 1B 05 24 3F 3A 69 58 92 05 09 A3 05 34 26 19 15 0C 12 18 86 09 26 33 67 23 45 42 57 9B 25 24 0C FA 0A 34 95 2D 09 A3 21 03 00 02 02 02 02 02 02 B1 10 23 29 66     172
IDE06089-ENG246993-Seat heater level current consumption allocation-SIH_PWM_Teiler    1    30
IDE06089-ENG141976-Seat heater level current consumption allocation-Sitzheitzung_CAN    Heizmatten am BCM     30
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss    1 s    30
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss    0.00 °C    30
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle    22.50 °C    30
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle    21.50 °C    30
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle    22.50 °C    30
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle    21.50 °C    30
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle    36.00 °C    30
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle    35.00 °C    30
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle    36.00 °C    30
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle    35.00 °C    30
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle    48.00 °C    30
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle    47.00 °C    30
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle    48.00 °C    30
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle    47.00 °C    30
IDE06089-ENG154774-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase HI    Sollspannungsanforderung 14.7     30
IDE06089-ENG154775-Seat heater level current consumption allocation-Sitzheizung.Regelbetrieb LO    Keine_Spannungsanforderung     30
IDE06089-ENG141977-Seat heater level current consumption allocation-Sitzheizungsfreigabe    not installed     30
IDE06089-ENG154785-Seat heater level current consumption allocation-Spannungsoffset SIH_75    15.7 V    30
IDE06425-Dynamometer mode: functional    not active     1
IDE06507-MAS13125-Button in center console-Function of button 1    Start-stop     8
IDE06507-MAS13129-Button in center console-Function of button 2    not coded/not installed     8
IDE06507-MAS13132-Button in center console-Function of button 3    Driving program     8
IDE06507-MAS13135-Button in center console-Function of button 4    not coded/not installed     8
IDE06507-ENG140243-Button in center console-Zusatzcodierung Fahrprofiltaster hat keine LED    LED installed     8
IDE07007-ENG142253-Air conditioning/heating function via remote control-Abbruch_d_Warnblinker_moeglich    active     8
IDE07007-ENG142252-Air conditioning/heating function via remote control-Abbruch_Hupen_RSt    not active     8
IDE07007-ENG142255-Air conditioning/heating function via remote control-Aktivierung_Drehzahlanzeige    active     8
IDE07007-ENG142254-Air conditioning/heating function via remote control-Kombi_Fahrerhinweis_m_Akustik    active     8
IDE07007-ENG128461-Air conditioning/heating function via remote control-Kombi_Fahrerhinweis_m_Uebernahme_RSt    active     8
IDE07007-ENG249923-Air conditioning/heating function via remote control-pa_RSt_MOD_verbaut    not installed     8
IDE07007-ENG115720-Air conditioning/heating function via remote control-Remote Start    not installed     8
IDE07007-ENG246992-Air conditioning/heating function via remote control-Remotestart_externe_FFB_verbaut    not installed     8
IDE07007-ENG128460-Air conditioning/heating function via remote control-Rueckmeldung_bei_Aktivierung    active     8
IDE07356-Position during interval mode    31.494474 °    2
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs    abschalten ueber Abschaltstufen des Energiemanagements oder nach der Nachlaufzeit     6
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit    30 min    6
IDE07470-ENG126843-After-run for park light-ZV verriegeln bei Klemme 15 Ein    active     6
IDE08577-Garage door opener: use of GPS data    No Response From Subnet Component    6
IDE08578-Garage door opener: bi-directional communic.    No Response From Subnet Component    6
IDE08579-Garage door opener: drift adapt.    No Response From Subnet Component    6
IDE08580-Garage door opener: increasing transm. power    No Response From Subnet Component    6
IDE08583-Garage door opener: no. of channels    No Response From Subnet Component    6
IDE08584-MAS07165-Garage door opener: freq. selection-Frequency range A    No Response From Subnet Component    6
IDE08584-MAS07166-Garage door opener: freq. selection-Frequency range B    No Response From Subnet Component    6
IDE08584-MAS07167-Garage door opener: freq. selection-Frequency range C    No Response From Subnet Component    6
IDE08584-MAS07168-Garage door opener: freq. selection-Frequency range D    No Response From Subnet Component    6
IDE08584-MAS07169-Garage door opener: freq. selection-Frequency range E    No Response From Subnet Component    6
IDE08584-MAS07170-Garage door opener: freq. selection-Frequency range F    No Response From Subnet Component    6
IDE08584-MAS07171-Garage door opener: freq. selection-Frequency range G    No Response From Subnet Component    6
IDE08584-MAS07172-Garage door opener: freq. selection-Frequency range H    No Response From Subnet Component    6
IDE08584-MAS07173-Garage door opener: freq. selection-Frequency range I    No Response From Subnet Component    6
IDE08584-MAS07174-Garage door opener: freq. selection-Frequency range J    No Response From Subnet Component    6
IDE08584-MAS07175-Garage door opener: freq. selection-Frequency range K    No Response From Subnet Component    6
IDE08584-MAS09302-Garage door opener: freq. selection-Frequency range US-I    No Response From Subnet Component    6
IDE08584-MAS09303-Garage door opener: freq. selection-Frequency range US-II    No Response From Subnet Component    6
IDE08584-MAS09304-Garage door opener: freq. selection-Frequency range US-III    No Response From Subnet Component    6
IDE08584-MAS09305-Garage door opener: freq. selection-Frequency range US-IV    No Response From Subnet Component    6
IDE08584-MAS10461-Garage door opener: freq. selection-Frequency range AB    No Response From Subnet Component    6
IDE08585-Garage door opener: activation via remote key    No Response From Subnet Component    6
IDE08778-Garage door opener: surround. target area    No Response From Subnet Component    6
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen    active     9
IDE08786-ENG141956-Assistance light functions-Humidity sensor    installed     9
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit    normal     9
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe    active     9
IDE08786-ENG142228-Assistance light functions-Maskierung_Regenfunktion    active     9
IDE08786-ENG141985-Assistance light functions-Regen_Lichtsensor    LIN_REGEN_LICHT_SENSOR     9
IDE08786-ENG124476-Assistance light functions-Sunlight photo sensor    not installed     9
IDE09377-IDE00761-Multi contour seat driver's side-Run-on time    No Response From Subnet Component    9
IDE09377-IDE03006-Multi contour seat driver's side-Running time of massage function    No Response From Subnet Component    9
IDE09377-IDE03007-Multi contour seat driver's side-Component location    No Response From Subnet Component    9
IDE09377-IDE03099-Multi contour seat driver's side-Characteristics for manual seat adjustment    No Response From Subnet Component    9
IDE09377-IDE03100-Multi contour seat driver's side-Characteristics for seat adjustment using memory    No Response From Subnet Component    9
IDE09378-IDE00761-Multicontour seat passenger side-Run-on time    No Response From Subnet Component    9
IDE09378-IDE03006-Multicontour seat passenger side-Running time of massage function    No Response From Subnet Component    9
IDE09378-IDE03007-Multicontour seat passenger side-Component location    No Response From Subnet Component    9
IDE09378-IDE03099-Multicontour seat passenger side-Characteristics for manual seat adjustment    No Response From Subnet Component    9
IDE09378-IDE03100-Multicontour seat passenger side-Characteristics for seat adjustment using memory    No Response From Subnet Component    9
IDE09546-Multicontour seat on driver's side: reset compressor counter    No Response From Subnet Component    9
IDE09547-Multicontour seat on frt. pass. side: reset compressor counter    No Response From Subnet Component    9
IDE09548-Multicontour seat on driver's side: reset adaptation    No Response From Subnet Component    9
IDE09549-Multicontour seat on frt. pass. side: reset adaptation    No Response From Subnet Component    9
IDE09731-ENG154511-Int. light: 2nd generation-Ambiente_Fahrprofil_Individual    7    19
IDE09731-ENG249826-Int. light: 2nd generation-Ambiente_Fahrprofil_Offroad_Individual    11    19
IDE09731-ENG154512-Int. light: 2nd generation-Ambiente_Farbliste_HMI_mit_Farbtransformation    not active     19
IDE09731-ENG154513-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung    not active     19
IDE09731-ENG154514-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung_Status_hmi_default    active     19
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit    0.10 s    19
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1    2    19
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2    3    19
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3    1    19
IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig    not active     19
IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig    not active     19
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach    80%    19
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe    2    19
IDE09731-ENG115822-Int. light: 2nd generation-Defaultwert Ambienteprofil Fussraum    50%    19
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole    80%    19
IDE09731-ENG116685-Int. light: 2nd generation-Defaultwert Ambienteprofil Tuer    50%    19
IDE09731-ENG115823-Int. light: 2nd generation-Defaultwert Ambienteprofil Vorn    50%    19
IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen    active     19
IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen    active     19
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen    active     19
IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen    active     19
IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen    active     19
IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen    active     19
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen    active     19
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen    active     19
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen    active     19
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen    active     19
IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen    active     19
IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen    active     19
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen    active     19
IDE09731-ENG142233-Int. light: 2nd generation-Helligkeit_Tuertafelbeleuchtung_nicht_berechnen    not active     19
IDE09731-ENG116596-Int. light: 2nd generation-Innenlicht bei offenem Heckdeckel einschalten    active     19
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig    active     19
IDE09731-ENG98648-Int. light: 2nd generation-Interior lighting    Keine_Spannungsanforderung     19
IDE09731-ENG116597-Int. light: 2nd generation-KL30G ohne PWM    not active     19
IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig    not active     19
IDE09731-ENG142031-Int. light: 2nd generation-LIN-Dachkonsole mit Flaechenlicht    not installed     19
IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig    not active     19
IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren    not active     19
IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig    not active     19
IDE09731-ENG116687-Int. light: 2nd generation-Tuerinnengriff mit Tuertafel    not installed     19
IDE09731-ENG116686-Int. light: 2nd generation-Tuerinnengriffbeleuchtung mit I-Tafel    not installed     19
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig    not active     19
IDE09731-ENG142184-Int. light: 2nd generation-Weckfaehigkeit_klemme_30G    installed     19
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel    not active     19
IDE09732-ENG154509-Interior light: light configuration-Ambience_light_colorlist_default    63    5
IDE09732-ENG133384-Interior light: light configuration-Ambient_Farbliste_HMI    active     5
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel    installed     5
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel    installed     5
IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher    installed     5
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen    active     5
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus    not active     5
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung    installed     5
IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung    not installed     5
IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil    not installed     5
IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI    not installed     5
IDE09732-ENG114629-Interior light: light configuration-Footwell lighting    installed     5
IDE09732-ENG133385-Interior light: light configuration-Frei_Farbwahl_ueber_HMI    active     5
IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar    not active     5
IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung    not installed     5
IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung    not installed     5
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne    30%    17
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz    30%    17
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne    30%    17
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz    30%    17
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne    50%    17
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz    50%    17
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne    50%    17
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz    50%    17
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne    75%    17
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz    75%    17
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne    80%    17
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz    80%    17
IDE09761-ENG142025-Seat fan charac. curve-Seat pneumatics    not installed     17
IDE09761-ENG142024-Seat fan charac. curve-Sitzlueftung    not installed     17
IDE09761-ENG142183-Seat fan charac. curve-Sitzlueftung_reduzierbar    installed     17
IDE10298-Alternating park position 1    7.494498 °    2
IDE10299-Alternating park position 2    29.494476 °    2
IDE10308-Garage door opener: support door name    No Response From Subnet Component    2
IDE10349-MAS10436-Garage door opener: Default/Fix kit mode-Default mode    No Response From Subnet Component    2
IDE10349-MAS10437-Garage door opener: Default/Fix kit mode-Fixkit mode: button 1    No Response From Subnet Component    2
IDE10349-MAS10438-Garage door opener: Default/Fix kit mode-Fixkit mode: button 2    No Response From Subnet Component    2
IDE10349-MAS10439-Garage door opener: Default/Fix kit mode-Fixkit mode: button 3    No Response From Subnet Component    2
IDE10350-Garage door opener: programming antenna    No Response From Subnet Component    2
IDE11477-ENG128587-Interior lighting: parameter-p_adaption_kundenwunsch_cockpit    1    256
IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach    1    256
IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum    0.2    256
IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel    1    256
IDE11477-ENG128555-Interior lighting: parameter-p_adaption_kundenwunsch_lautsprecher    1    256
IDE11477-ENG128603-Interior lighting: parameter-p_adaption_kundenwunsch_miko    1    256
IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd    1    256
IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer    0.6    256
IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI    00000000      256
IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2    00000000      256
IDE11477-ENG128661-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_3    00000000      256
IDE11477-ENG128662-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_4    0    256
IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI    00000000      256
IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2    00000000      256
IDE11477-ENG128657-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_3    00000000      256
IDE11477-ENG128658-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_4    00000000      256
IDE11477-ENG128652-Interior lighting: parameter-p_dimmfaktor_farbwechsel_ab    1    256
IDE11477-ENG128651-Interior lighting: parameter-p_dimmfaktor_farbwechsel_auf    1    256
IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI    00000000      256
IDE11477-ENG128653-Interior lighting: parameter-p_farbwechsel_delay    0    256
IDE11477-ENG128596-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_cockpit    100%    256
IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach    100%    256
IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum    70%    256
IDE11477-ENG128516-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_innenlicht    100%    256
IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel    100%    256
IDE11477-ENG128564-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher    100%    256
IDE11477-ENG128612-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_miko    100%    256
IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd    100%    256
IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren    96%    256
IDE11477-ENG128593-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_cockpit    100%    256
IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach    100%    256
IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum    70%    256
IDE11477-ENG128513-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_innenlicht    100%    256
IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel    100%    256
IDE11477-ENG128561-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher    100%    256
IDE11477-ENG128609-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_miko    100%    256
IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd    100%    256
IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren    96%    256
IDE11477-ENG128595-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit    100%    256
IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach    100%    256
IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum    70%    256
IDE11477-ENG128515-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_innenlicht    100%    256
IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel    100%    256
IDE11477-ENG128563-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher    100%    256
IDE11477-ENG128611-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_miko    100%    256
IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd    100%    256
IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren    96%    256
IDE11477-ENG128592-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit    100%    256
IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach    100%    256
IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum    70%    256
IDE11477-ENG128512-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_innenlicht    100%    256
IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel    100%    256
IDE11477-ENG128560-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher    100%    256
IDE11477-ENG128608-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_miko    100%    256
IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd    100%    256
IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren    96%    256
IDE11477-ENG128597-Interior lighting: parameter-p_helligkeit_einausstieg_cockpit    100%    256
IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach    100%    256
IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum    70%    256
IDE11477-ENG128517-Interior lighting: parameter-p_helligkeit_einausstieg_innenlicht    100%    256
IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel    100%    256
IDE11477-ENG128565-Interior lighting: parameter-p_helligkeit_einausstieg_lautsprecher    100%    256
IDE11477-ENG128613-Interior lighting: parameter-p_helligkeit_einausstieg_miko    100%    256
IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd    100%    256
IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren    96%    256
IDE11477-ENG128588-Interior lighting: parameter-p_helligkeit_entriegelt_cockpit    100%    256
IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach    100%    256
IDE11477-ENG128540-Interior lighting: parameter-p_helligkeit_entriegelt_fussraum    0%    256
IDE11477-ENG128508-Interior lighting: parameter-p_helligkeit_entriegelt_innenlicht    100%    256
IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel    100%    256
IDE11477-ENG128556-Interior lighting: parameter-p_helligkeit_entriegelt_lautsprecher    100%    256
IDE11477-ENG128604-Interior lighting: parameter-p_helligkeit_entriegelt_miko    100%    256
IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd    100%    256
IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren    0%    256
IDE11477-ENG128602-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit    100%    256
IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach    100%    256
IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum    70%    256
IDE11477-ENG128522-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht    100%    256
IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel    100%    256
IDE11477-ENG128570-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher    100%    256
IDE11477-ENG128618-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_miko    100%    256
IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd    100%    256
IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren    96%    256
IDE11477-ENG128598-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit    100%    256
IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach    100%    256
IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum    127%    256
IDE11477-ENG128518-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht    100%    256
IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel    100%    256
IDE11477-ENG128566-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher    100%    256
IDE11477-ENG128614-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_miko    100%    256
IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd    100%    256
IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren    127%    256
IDE11477-ENG128594-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit    126%    256
IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach    126%    256
IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum    126%    256
IDE11477-ENG128514-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_innenlicht    0%    256
IDE11477-ENG128578-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel    126%    256
IDE11477-ENG128562-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher    126%    256
IDE11477-ENG128610-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_miko    126%    256
IDE11477-ENG128642-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd    126%    256
IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren    126%    256
IDE11477-ENG128591-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_cockpit    100%    256
IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach    100%    256
IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum    127%    256
IDE11477-ENG128511-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_innenlicht    100%    256
IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel    100%    256
IDE11477-ENG128559-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_lautsprecher    100%    256
IDE11477-ENG128607-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_miko    100%    256
IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd    100%    256
IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren    127%    256
IDE11477-ENG128590-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_cockpit    100%    256
IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach    100%    256
IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum    126%    256
IDE11477-ENG128510-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_innenlicht    100%    256
IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel    100%    256
IDE11477-ENG128558-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_lautsprecher    100%    256
IDE11477-ENG128606-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_miko    100%    256
IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd    100%    256
IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren    126%    256
IDE11477-ENG128589-Interior lighting: parameter-p_helligkeit_max_cockpit    100%    256
IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach    100%    256
IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum    70%    256
IDE11477-ENG128509-Interior lighting: parameter-p_helligkeit_max_innenlicht    100%    256
IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel    100%    256
IDE11477-ENG128557-Interior lighting: parameter-p_helligkeit_max_lautsprecher    100%    256
IDE11477-ENG128605-Interior lighting: parameter-p_helligkeit_max_miko    100%    256
IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd    100%    256
IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren    96%    256
IDE11477-ENG128599-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit    100%    256
IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach    100%    256
IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum    70%    256
IDE11477-ENG128519-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht    100%    256
IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel    100%    256
IDE11477-ENG128567-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher    100%    256
IDE11477-ENG128615-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko    100%    256
IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd    100%    256
IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren    96%    256
IDE11477-ENG128600-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit    100%    256
IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach    100%    256
IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum    70%    256
IDE11477-ENG128520-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht    100%    256
IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel    100%    256
IDE11477-ENG128568-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher    100%    256
IDE11477-ENG128616-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko    100%    256
IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd    100%    256
IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren    96%    256
IDE11477-ENG128601-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit    100%    256
IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach    100%    256
IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum    70%    256
IDE11477-ENG128521-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht    100%    256
IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel    100%    256
IDE11477-ENG128569-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher    100%    256
IDE11477-ENG128617-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_miko    100%    256
IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd    100%    256
IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren    96%    256
IDE11477-ENG137165-Interior lighting: parameter-p_t_HMI_verzoegerung_helligkeitswerte    200 ms    256
IDE11477-ENG128488-Interior lighting: parameter-p_t_verzoegerung_ausstieg_cockpit    0.0 s    256
IDE11477-ENG128502-Interior lighting: parameter-p_t_verzoegerung_ausstieg_dach    0.0 s    256
IDE11477-ENG128481-Interior lighting: parameter-p_t_verzoegerung_ausstieg_fussraum    0.0 s    256
IDE11477-ENG128467-Interior lighting: parameter-p_t_verzoegerung_ausstieg_innenlicht    0.0 s    256
IDE11477-ENG128495-Interior lighting: parameter-p_t_verzoegerung_ausstieg_miko    0.0 s    256
IDE11477-ENG128474-Interior lighting: parameter-p_t_verzoegerung_ausstieg_tueren    0.0 s    256
IDE11477-ENG128487-Interior lighting: parameter-p_t_verzoegerung_einstieg_cockpit    0.0 s    256
IDE11477-ENG128501-Interior lighting: parameter-p_t_verzoegerung_einstieg_dach    0.0 s    256
IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum    2.0 s    256
IDE11477-ENG128466-Interior lighting: parameter-p_t_verzoegerung_einstieg_innenlicht    0.0 s    256
IDE11477-ENG128494-Interior lighting: parameter-p_t_verzoegerung_einstieg_miko    0.0 s    256
IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren    0.5 s    256
IDE11477-ENG128490-Interior lighting: parameter-p_t_verzoegerung_entriegelt_cockpit    0.0 s    256
IDE11477-ENG128504-Interior lighting: parameter-p_t_verzoegerung_entriegelt_dach    0.0 s    256
IDE11477-ENG128483-Interior lighting: parameter-p_t_verzoegerung_entriegelt_fussraum    0.0 s    256
IDE11477-ENG128469-Interior lighting: parameter-p_t_verzoegerung_entriegelt_innenlicht    0.0 s    256
IDE11477-ENG128497-Interior lighting: parameter-p_t_verzoegerung_entriegelt_miko    0.0 s    256
IDE11477-ENG128476-Interior lighting: parameter-p_t_verzoegerung_entriegelt_tueren    0.0 s    256
IDE11477-ENG128489-Interior lighting: parameter-p_t_verzoegerung_oeffnen_cockpit    0.0 s    256
IDE11477-ENG128503-Interior lighting: parameter-p_t_verzoegerung_oeffnen_dach    0.0 s    256
IDE11477-ENG128482-Interior lighting: parameter-p_t_verzoegerung_oeffnen_fussraum    0.0 s    256
IDE11477-ENG128468-Interior lighting: parameter-p_t_verzoegerung_oeffnen_innenlicht    0.0 s    256
IDE11477-ENG128496-Interior lighting: parameter-p_t_verzoegerung_oeffnen_miko    0.0 s    256
IDE11477-ENG128475-Interior lighting: parameter-p_t_verzoegerung_oeffnen_tueren    0.0 s    256
IDE11477-ENG128491-Interior lighting: parameter-p_t_verzoegerung_schliessen_cockpit    0.0 s    256
IDE11477-ENG128505-Interior lighting: parameter-p_t_verzoegerung_schliessen_dach    0.0 s    256
IDE11477-ENG128484-Interior lighting: parameter-p_t_verzoegerung_schliessen_fussraum    0.0 s    256
IDE11477-ENG128470-Interior lighting: parameter-p_t_verzoegerung_schliessen_innenlicht    0.0 s    256
IDE11477-ENG128498-Interior lighting: parameter-p_t_verzoegerung_schliessen_miko    0.0 s    256
IDE11477-ENG128477-Interior lighting: parameter-p_t_verzoegerung_schliessen_tueren    0.0 s    256
IDE11477-ENG128492-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_cockpit    0.0 s    256
IDE11477-ENG128506-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_dach    0.0 s    256
IDE11477-ENG128485-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_fussraum    0.0 s    256
IDE11477-ENG128471-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_innenlicht    0.0 s    256
IDE11477-ENG128499-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_miko    0.0 s    256
IDE11477-ENG128478-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_tueren    0.0 s    256
IDE11477-ENG128493-Interior lighting: parameter-p_t_verzoegerung_verriegelt_cockpit    0.0 s    256
IDE11477-ENG128507-Interior lighting: parameter-p_t_verzoegerung_verriegelt_dach    0.0 s    256
IDE11477-ENG128486-Interior lighting: parameter-p_t_verzoegerung_verriegelt_fussraum    0.0 s    256
IDE11477-ENG128472-Interior lighting: parameter-p_t_verzoegerung_verriegelt_innenlicht    0.0 s    256
IDE11477-ENG128500-Interior lighting: parameter-p_t_verzoegerung_verriegelt_miko    0.0 s    256
IDE11477-ENG128479-Interior lighting: parameter-p_t_verzoegerung_verriegelt_tueren    0.0 s    256
IDE11477-ENG128663-Interior lighting: parameter-p_verzoegerung_berechnen    0    256
IDE11714-ENG126827-Ambient light color list-Blauwert Farbe 1    0    30
IDE11714-ENG133432-Ambient light color list-Blauwert Farbe 10    0    30
IDE11714-ENG126830-Ambient light color list-Blauwert Farbe 2    0    30
IDE11714-ENG126833-Ambient light color list-Blauwert Farbe 3    0    30
IDE11714-ENG133414-Ambient light color list-Blauwert Farbe 4    0    30
IDE11714-ENG133417-Ambient light color list-Blauwert Farbe 5    0    30
IDE11714-ENG133420-Ambient light color list-Blauwert Farbe 6    0    30
IDE11714-ENG133423-Ambient light color list-Blauwert Farbe 7    32    30
IDE11714-ENG133426-Ambient light color list-Blauwert Farbe 8    10    30
IDE11714-ENG133429-Ambient light color list-Blauwert Farbe 9    0    30
IDE11714-ENG126826-Ambient light color list-Gruenwert Farbe 1    0    30
IDE11714-ENG133431-Ambient light color list-Gruenwert Farbe 10    255    30
IDE11714-ENG126829-Ambient light color list-Gruenwert Farbe 2    61    30
IDE11714-ENG126832-Ambient light color list-Gruenwert Farbe 3    64    30
IDE11714-ENG133413-Ambient light color list-Gruenwert Farbe 4    128    30
IDE11714-ENG133416-Ambient light color list-Gruenwert Farbe 5    191    30
IDE11714-ENG133419-Ambient light color list-Gruenwert Farbe 6    255    30
IDE11714-ENG133422-Ambient light color list-Gruenwert Farbe 7    165    30
IDE11714-ENG133425-Ambient light color list-Gruenwert Farbe 8    241    30
IDE11714-ENG133428-Ambient light color list-Gruenwert Farbe 9    255    30
IDE11714-ENG126825-Ambient light color list-Rotwert Farbe 1    128    30
IDE11714-ENG133430-Ambient light color list-Rotwert Farbe 10    128    30
IDE11714-ENG126828-Ambient light color list-Rotwert Farbe 2    121    30
IDE11714-ENG126831-Ambient light color list-Rotwert Farbe 3    255    30
IDE11714-ENG133412-Ambient light color list-Rotwert Farbe 4    255    30
IDE11714-ENG133415-Ambient light color list-Rotwert Farbe 5    255    30
IDE11714-ENG133418-Ambient light color list-Rotwert Farbe 6    255    30
IDE11714-ENG133421-Ambient light color list-Rotwert Farbe 7    218    30
IDE11714-ENG133424-Ambient light color list-Rotwert Farbe 8    166    30
IDE11714-ENG133427-Ambient light color list-Rotwert Farbe 9    191    30
IDE11944-ENG142014-Keyless access and start authorization-Elektische_Lenkradverriegelung    installed     3
IDE11944-ENG141948-Keyless access and start authorization-Kessy    installed     3
IDE11944-ENG179141-Keyless access and start authorization-Kessy Bewegungsüberwachung IDGeber    active     3
IDE11944-ENG116653-Keyless access and start authorization-Kessy Komfort oeffnen    active     3
IDE11944-ENG116654-Keyless access and start authorization-Kessy Komfort schliessen    active     3
IDE11944-ENG116655-Keyless access and start authorization-Kessy Komfortbedienung Reichweitenbegrenzung    active     3
IDE11944-ENG179142-Keyless access and start authorization-Kessy Protokollvariante EntryExit    active     3
IDE11944-ENG179143-Keyless access and start authorization-Kessy Ruhephase EntryExit    not active     3
IDE11944-ENG116626-Keyless access and start authorization-Oeffnung Heckdeckel bei Wiederentriegelung    not active     3
IDE12119-Garage door opener: frequency range of bi-directional communication    No Response From Subnet Component    3
IDE12120-Garage door opener: piloted parking    No Response From Subnet Component    3
IDE12121-Garage door opener: vehicle variant    No Response From Subnet Component    3
IDE12122-Garage door opener: continuous transmission mode for level measurement    No Response From Subnet Component    3
IDE12302-SFT271873-Identification of sub-bus participant-Wiper motor control module    Not available     6
IDE12302-SFT271874-Identification of sub-bus participant-Rain/Light Recognition Sensor    Not available     6
IDE12302-SFT271875-Identification of sub-bus participant-Light switch    Not available     6
IDE12302-SFT271876-Identification of sub-bus participant-Garage door opener control module    Not available     6
IDE12302-SFT271877-Identification of sub-bus participant-Garage door opener control head    Not available     6
IDE12302-SFT271894-Identification of sub-bus participant-Anti-theft alarm system sensor    Not available     6
IDE12302-SFT271896-Identification of sub-bus participant-Alarm horn    Not available     6
IDE12302-SFT271904-Identification of sub-bus participant-Sunroof control module    Not available     6
IDE12302-SFT271910-Identification of sub-bus participant-Roof electronics control module    Not available     6
IDE12302-SFT271928-Identification of sub-bus participant-Roof shade control module    Not available     6
IDE12302-SFT271947-Identification of sub-bus participant-Humidity sensor: interior    Not available     6
IDE12302-SFT271966-Identification of sub-bus participant-Left head area heater    Not available     6
IDE12302-SFT271967-Identification of sub-bus participant-Right head area heater    Not available     6
IDE12302-SFT272065-Identification of sub-bus participant-Blower 1 for left front backrest    Not available     6
IDE12302-SFT272067-Identification of sub-bus participant-Blower 1 for left front seat cushion    Not available     6
IDE12302-SFT272069-Identification of sub-bus participant-Blower 1 for right front backrest    Not available     6
IDE12302-SFT272071-Identification of sub-bus participant-Blower 1 for right front seat cushion    Not available     6
IDE12302-ENG246961-Identification of sub-bus participant-Remote_Control    Not available     6
IDE12302-ENG246960-Identification of sub-bus participant-steering_column_switch    Not available     6
IDE12412-ENG154526-LIN Ambient light color list-Blauwert_Farbe_1_lin    0    30
IDE12412-ENG154527-LIN Ambient light color list-Blauwert_Farbe_10_lin    0    30
IDE12412-ENG154537-LIN Ambient light color list-Blauwert_Farbe_2_lin    0    30
IDE12412-ENG154557-LIN Ambient light color list-Blauwert_Farbe_3_lin    0    30
IDE12412-ENG154560-LIN Ambient light color list-Blauwert_Farbe_4_lin    0    30
IDE12412-ENG154561-LIN Ambient light color list-Blauwert_Farbe_5_lin    0    30
IDE12412-ENG154562-LIN Ambient light color list-Blauwert_Farbe_6_lin    0    30
IDE12412-ENG154563-LIN Ambient light color list-Blauwert_Farbe_7_lin    0    30
IDE12412-ENG154564-LIN Ambient light color list-Blauwert_Farbe_8_lin    0    30
IDE12412-ENG154565-LIN Ambient light color list-Blauwert_Farbe_9_lin    0    30
IDE12412-ENG154645-LIN Ambient light color list-Gruenwert_Farbe_1_lin    0    30
IDE12412-ENG154646-LIN Ambient light color list-Gruenwert_Farbe_10_lin    0    30
IDE12412-ENG154656-LIN Ambient light color list-Gruenwert_Farbe_2_lin    0    30
IDE12412-ENG154676-LIN Ambient light color list-Gruenwert_Farbe_3_lin    0    30
IDE12412-ENG154679-LIN Ambient light color list-Gruenwert_Farbe_4_lin    0    30
IDE12412-ENG154680-LIN Ambient light color list-Gruenwert_Farbe_5_lin    0    30
IDE12412-ENG154681-LIN Ambient light color list-Gruenwert_Farbe_6_lin    0    30
IDE12412-ENG154682-LIN Ambient light color list-Gruenwert_Farbe_7_lin    0    30
IDE12412-ENG154683-LIN Ambient light color list-Gruenwert_Farbe_8_lin    0    30
IDE12412-ENG154684-LIN Ambient light color list-Gruenwert_Farbe_9_lin    0    30
IDE12412-ENG154733-LIN Ambient light color list-Rotwert_Farbe_1_lin    0    30
IDE12412-ENG154734-LIN Ambient light color list-Rotwert_Farbe_10_lin    0    30
IDE12412-ENG154744-LIN Ambient light color list-Rotwert_Farbe_2_lin    0    30
IDE12412-ENG154764-LIN Ambient light color list-Rotwert_Farbe_3_lin    0    30
IDE12412-ENG154767-LIN Ambient light color list-Rotwert_Farbe_4_lin    0    30
IDE12412-ENG154768-LIN Ambient light color list-Rotwert_Farbe_5_lin    0    30
IDE12412-ENG154769-LIN Ambient light color list-Rotwert_Farbe_6_lin    0    30
IDE12412-ENG154770-LIN Ambient light color list-Rotwert_Farbe_7_lin    0    30
IDE12412-ENG154771-LIN Ambient light color list-Rotwert_Farbe_8_lin    0    30
IDE12412-ENG154772-LIN Ambient light color list-Rotwert_Farbe_9_lin    0    30
IDE80001-ENG125667-Analysis 1-EE_pMax_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80001-ENG125666-Analysis 1-EE_pMax_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80001-ENG125668-Analysis 1-EE_pMax_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80001-ENG125673-Analysis 1-EE_tEnt_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80001-ENG125672-Analysis 1-EE_tEnt_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80001-ENG125674-Analysis 1-EE_tEnt_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80001-ENG125670-Analysis 1-EE_tHalte_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80001-ENG125669-Analysis 1-EE_tHalte_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80001-ENG125671-Analysis 1-EE_tHalte_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80001-ENG125676-Analysis 1-EE_tWarte_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80001-ENG125675-Analysis 1-EE_tWarte_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80001-ENG125677-Analysis 1-EE_tWarte_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80001-ENG125664-Analysis 1-EE_Upumpe_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80001-ENG125663-Analysis 1-EE_Upumpe_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80001-ENG125665-Analysis 1-EE_Upumpe_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80002-ENG125667-Analysis 2-EE_pMax_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80002-ENG125666-Analysis 2-EE_pMax_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80002-ENG125668-Analysis 2-EE_pMax_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80002-ENG125673-Analysis 2-EE_tEnt_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80002-ENG125672-Analysis 2-EE_tEnt_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80002-ENG125674-Analysis 2-EE_tEnt_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80002-ENG125670-Analysis 2-EE_tHalte_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80002-ENG125669-Analysis 2-EE_tHalte_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80002-ENG125671-Analysis 2-EE_tHalte_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80002-ENG125676-Analysis 2-EE_tWarte_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80002-ENG125675-Analysis 2-EE_tWarte_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80002-ENG125677-Analysis 2-EE_tWarte_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80002-ENG125664-Analysis 2-EE_Upumpe_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80002-ENG125663-Analysis 2-EE_Upumpe_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80002-ENG125665-Analysis 2-EE_Upumpe_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80003-ENG125667-Analysis 3-EE_pMax_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80003-ENG125666-Analysis 3-EE_pMax_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80003-ENG125668-Analysis 3-EE_pMax_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80003-ENG125673-Analysis 3-EE_tEnt_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80003-ENG125672-Analysis 3-EE_tEnt_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80003-ENG125674-Analysis 3-EE_tEnt_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80003-ENG125670-Analysis 3-EE_tHalte_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80003-ENG125669-Analysis 3-EE_tHalte_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80003-ENG125671-Analysis 3-EE_tHalte_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80003-ENG125676-Analysis 3-EE_tWarte_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80003-ENG125675-Analysis 3-EE_tWarte_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80003-ENG125677-Analysis 3-EE_tWarte_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80003-ENG125664-Analysis 3-EE_Upumpe_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80003-ENG125663-Analysis 3-EE_Upumpe_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80003-ENG125665-Analysis 3-EE_Upumpe_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80004-ENG125667-Analysis 4-EE_pMax_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80004-ENG125666-Analysis 4-EE_pMax_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80004-ENG125668-Analysis 4-EE_pMax_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80004-ENG125673-Analysis 4-EE_tEnt_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80004-ENG125672-Analysis 4-EE_tEnt_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80004-ENG125674-Analysis 4-EE_tEnt_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80004-ENG125670-Analysis 4-EE_tHalte_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80004-ENG125669-Analysis 4-EE_tHalte_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80004-ENG125671-Analysis 4-EE_tHalte_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80004-ENG125676-Analysis 4-EE_tWarte_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80004-ENG125675-Analysis 4-EE_tWarte_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80004-ENG125677-Analysis 4-EE_tWarte_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80004-ENG125664-Analysis 4-EE_Upumpe_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80004-ENG125663-Analysis 4-EE_Upumpe_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80004-ENG125665-Analysis 4-EE_Upumpe_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80005-ENG125667-Analysis 5-EE_pMax_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80005-ENG125666-Analysis 5-EE_pMax_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80005-ENG125668-Analysis 5-EE_pMax_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80005-ENG125673-Analysis 5-EE_tEnt_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80005-ENG125672-Analysis 5-EE_tEnt_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80005-ENG125674-Analysis 5-EE_tEnt_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80005-ENG125670-Analysis 5-EE_tHalte_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80005-ENG125669-Analysis 5-EE_tHalte_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80005-ENG125671-Analysis 5-EE_tHalte_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80005-ENG125676-Analysis 5-EE_tWarte_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80005-ENG125675-Analysis 5-EE_tWarte_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80005-ENG125677-Analysis 5-EE_tWarte_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80005-ENG125664-Analysis 5-EE_Upumpe_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80005-ENG125663-Analysis 5-EE_Upumpe_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80005-ENG125665-Analysis 5-EE_Upumpe_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80006-ENG125667-Analysis 6-EE_pMax_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80006-ENG125666-Analysis 6-EE_pMax_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80006-ENG125668-Analysis 6-EE_pMax_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80006-ENG125673-Analysis 6-EE_tEnt_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80006-ENG125672-Analysis 6-EE_tEnt_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80006-ENG125674-Analysis 6-EE_tEnt_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80006-ENG125670-Analysis 6-EE_tHalte_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80006-ENG125669-Analysis 6-EE_tHalte_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80006-ENG125671-Analysis 6-EE_tHalte_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80006-ENG125676-Analysis 6-EE_tWarte_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80006-ENG125675-Analysis 6-EE_tWarte_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80006-ENG125677-Analysis 6-EE_tWarte_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80006-ENG125664-Analysis 6-EE_Upumpe_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80006-ENG125663-Analysis 6-EE_Upumpe_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80006-ENG125665-Analysis 6-EE_Upumpe_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80007-ENG125682-Analysis 7-s_GrobleckerkennungDauer    No Response From Subnet Component    30
IDE80007-ENG125680-Analysis 7-s_LatenzzeitHaengenderTaster    No Response From Subnet Component    30
IDE80007-ENG125681-Analysis 7-s_Leckageerkennung    No Response From Subnet Component    30
IDE80007-ENG125678-Analysis 7-s_UeberspannungsSschwelle    No Response From Subnet Component    30
IDE80007-ENG125679-Analysis 7-s_UnterspannungsSchwelle    No Response From Subnet Component    30
IDE80008-ENG125684-Analysis 8-s_DruckschwelleNachlauf    No Response From Subnet Component    30
IDE80008-ENG126855-Analysis 8-s_Maximaldruck_LRD_m    No Response From Subnet Component    30
IDE80008-ENG126854-Analysis 8-s_Maximaldruck_LRD_o    No Response From Subnet Component    30
IDE80008-ENG126856-Analysis 8-s_Maximaldruck_LRD_u    No Response From Subnet Component    30
IDE80008-ENG126857-Analysis 8-s_Maximaldruck_Sitzlehnenwangen    No Response From Subnet Component    30
IDE80008-ENG126863-Analysis 8-s_Maximaldruck_Ueberlastschutz    No Response From Subnet Component    30
IDE80008-ENG126862-Analysis 8-s_Maximaler_Differenzdruck_LRD_Vor_Zurueck    No Response From Subnet Component    30
IDE80008-ENG126859-Analysis 8-s_Minimaldruck_LRD_m    No Response From Subnet Component    30
IDE80008-ENG126858-Analysis 8-s_Minimaldruck_LRD_o    No Response From Subnet Component    30
IDE80008-ENG126860-Analysis 8-s_Minimaldruck_LRD_u    No Response From Subnet Component    30
IDE80008-ENG126864-Analysis 8-s_Minimaldruck_Massage    No Response From Subnet Component    30
IDE80008-ENG126861-Analysis 8-s_MinimaldruckSitzlehnenwangen    No Response From Subnet Component    30
IDE80008-ENG125683-Analysis 8-s_ZieldruckDerSitzlehnenwangenBeiPreCrash    No Response From Subnet Component    30
IDE80009-ENG125687-Analysis 9-s_AnzahlDruckmessungenIntervallerhoehung    No Response From Subnet Component    30
IDE80009-ENG125689-Analysis 9-s_AussendruckschwelleNachregelung    No Response From Subnet Component    30
IDE80009-ENG125685-Analysis 9-s_BasismessintervallNachregelung    No Response From Subnet Component    30
IDE80009-ENG125688-Analysis 9-s_BlasendruckschwelleNachregelung    No Response From Subnet Component    30
IDE80009-ENG125686-Analysis 9-s_ErhoehungsintervallNachregelung    No Response From Subnet Component    30
IDE80011-ENG125667-Analysis 11-EE_pMax_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80011-ENG125666-Analysis 11-EE_pMax_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80011-ENG125668-Analysis 11-EE_pMax_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80011-ENG125673-Analysis 11-EE_tEnt_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80011-ENG125672-Analysis 11-EE_tEnt_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80011-ENG125674-Analysis 11-EE_tEnt_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80011-ENG125670-Analysis 11-EE_tHalte_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80011-ENG125669-Analysis 11-EE_tHalte_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80011-ENG125671-Analysis 11-EE_tHalte_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80011-ENG125676-Analysis 11-EE_tWarte_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80011-ENG125675-Analysis 11-EE_tWarte_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80011-ENG125677-Analysis 11-EE_tWarte_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80011-ENG125664-Analysis 11-EE_Upumpe_LM_MSG_Px_Iy    No Response From Subnet Component    30
IDE80011-ENG125663-Analysis 11-EE_Upumpe_LO_MSG_Px_Iy    No Response From Subnet Component    30
IDE80011-ENG125665-Analysis 11-EE_Upumpe_LU_MSG_Px_Iy    No Response From Subnet Component    30
IDE80012-ENG125693-Analysis 12-s_DauerFuerGrobleckerkennung    No Response From Subnet Component    30
IDE80012-ENG125680-Analysis 12-s_LatenzzeitHaengenderTaster    No Response From Subnet Component    30
IDE80012-ENG125681-Analysis 12-s_Leckageerkennung    No Response From Subnet Component    30
IDE80012-ENG125678-Analysis 12-s_UeberspannungsSschwelle    No Response From Subnet Component    30
IDE80012-ENG125679-Analysis 12-s_UnterspannungsSchwelle    No Response From Subnet Component    30
IDE80013-ENG126871-Analysis 13-s_Druckschwelle_Nachlauf    No Response From Subnet Component    30
IDE80013-ENG126855-Analysis 13-s_Maximaldruck_LRD_m    No Response From Subnet Component    30
IDE80013-ENG126854-Analysis 13-s_Maximaldruck_LRD_o    No Response From Subnet Component    30
IDE80013-ENG126856-Analysis 13-s_Maximaldruck_LRD_u    No Response From Subnet Component    30
IDE80013-ENG126857-Analysis 13-s_Maximaldruck_Sitzlehnenwangen    No Response From Subnet Component    30
IDE80013-ENG126863-Analysis 13-s_Maximaldruck_Ueberlastschutz    No Response From Subnet Component    30
IDE80013-ENG126870-Analysis 13-s_Maximaler_Differenzdruck_LRD_VorZurueck    No Response From Subnet Component    30
IDE80013-ENG126859-Analysis 13-s_Minimaldruck_LRD_m    No Response From Subnet Component    30
IDE80013-ENG126858-Analysis 13-s_Minimaldruck_LRD_o    No Response From Subnet Component    30
IDE80013-ENG126860-Analysis 13-s_Minimaldruck_LRD_u    No Response From Subnet Component    30
IDE80013-ENG126864-Analysis 13-s_Minimaldruck_Massage    No Response From Subnet Component    30
IDE80013-ENG126869-Analysis 13-s_Minimaldruck_Sitzlehnenwangen    No Response From Subnet Component    30
IDE80013-ENG125683-Analysis 13-s_ZieldruckDerSitzlehnenwangenBeiPreCrash    No Response From Subnet Component    30
IDE80014-ENG125687-Analysis 14-s_AnzahlDruckmessungenIntervallerhoehung    No Response From Subnet Component    30
IDE80014-ENG125689-Analysis 14-s_AussendruckschwelleNachregelung    No Response From Subnet Component    30
IDE80014-ENG125685-Analysis 14-s_BasismessintervallNachregelung    No Response From Subnet Component    30
IDE80014-ENG125688-Analysis 14-s_BlasendruckschwelleNachregelung    No Response From Subnet Component    30
IDE80014-ENG125686-Analysis 14-s_ErhoehungsintervallNachregelung    No Response From Subnet Component    30
IDE80015-ENG126865-Analysis 15-s_Kompressorleistung_Manuelle_Befuellung_LRD    No Response From Subnet Component    30
IDE80015-ENG126867-Analysis 15-s_Kompressorleistung_Manueller_Befuellung_Seitenwangen    No Response From Subnet Component    30
IDE80015-ENG126866-Analysis 15-s_Kompressorleistung_Memorisierte_Befuellung_LRD    No Response From Subnet Component    30
IDE80015-ENG126868-Analysis 15-s_Kompressorleistung_Memorisierte_Befuellung_Seitenwangen    No Response From Subnet Component    30
IDE80015-ENG125690-Analysis 15-s_VerzoegerungszeitKompressoranlauf    No Response From Subnet Component    30
IDE80016-Analysis 16    No Response From Subnet Component    30
IDE80017-ENG133471-Analysis 17-Offset_PB1_LM    No Response From Subnet Component    30
IDE80017-ENG133470-Analysis 17-Offset_PB1_LO    No Response From Subnet Component    30
IDE80017-ENG133472-Analysis 17-Offset_PB1_LU    No Response From Subnet Component    30
IDE80017-ENG133473-Analysis 17-Offset_PB1_SH    No Response From Subnet Component    30
IDE80017-ENG133475-Analysis 17-Offset_PB2_LM    No Response From Subnet Component    30
IDE80017-ENG133474-Analysis 17-Offset_PB2_LO    No Response From Subnet Component    30
IDE80017-ENG133476-Analysis 17-Offset_PB2_LU    No Response From Subnet Component    30
IDE80017-ENG133477-Analysis 17-Offset_PB2_SH    No Response From Subnet Component    30
IDE80017-ENG133483-Analysis 17-Offset_PV1_LM    No Response From Subnet Component    30
IDE80017-ENG133482-Analysis 17-Offset_PV1_LO    No Response From Subnet Component    30
IDE80017-ENG133484-Analysis 17-Offset_PV1_LU    No Response From Subnet Component    30
IDE80017-ENG133485-Analysis 17-Offset_PV1_SH    No Response From Subnet Component    30
IDE80017-ENG133486-Analysis 17-Offset_PV2_LO    No Response From Subnet Component    30
IDE80017-ENG133488-Analysis 17-Offset_PV2_LU    No Response From Subnet Component    30
IDE80017-ENG133489-Analysis 17-Offset_PV2_SH    No Response From Subnet Component    30
IDE80017-ENG133480-Analysis 17-OffsetPP1    No Response From Subnet Component    30
IDE80017-ENG133481-Analysis 17-OffsetPP2    No Response From Subnet Component    30
IDE80017-ENG133487-Analysis 17-OffsetPV2_LMy    No Response From Subnet Component    30
IDE80017-ENG133478-Analysis 17-OffsetT1    No Response From Subnet Component    30
IDE80017-ENG133479-Analysis 17-OffsetT2    No Response From Subnet Component    30
IDE80017-ENG133490-Analysis 17-p_function_feedback_timeout    No Response From Subnet Component    30
IDE80017-ENG133491-Analysis 17-p_longpush_time    No Response From Subnet Component    30
IDE80017-ENG133497-Analysis 17-p_stoesselSchaltschwelle_eins    No Response From Subnet Component    30
IDE80017-ENG133498-Analysis 17-p_stoesselSchaltschwelle_zwei    No Response From Subnet Component    30
IDE80017-ENG133494-Analysis 17-p_tasterSchaltschwelle_drei    No Response From Subnet Component    30
IDE80017-ENG133492-Analysis 17-p_tasterSchaltschwelle_eins    No Response From Subnet Component    30
IDE80017-ENG133496-Analysis 17-p_tasterSchaltschwelle_fuenf    No Response From Subnet Component    30
IDE80017-ENG133495-Analysis 17-p_tasterSchaltschwelle_vier    No Response From Subnet Component    30
IDE80017-ENG133493-Analysis 17-p_tasterSchaltschwelle_zwei    No Response From Subnet Component    30
IDE80017-ENG133458-Analysis 17-s_Beruhigungszeit_Befuellen    No Response From Subnet Component    30
IDE80017-ENG133460-Analysis 17-s_Beruhigungszeit_Druckmessung    No Response From Subnet Component    30
IDE80017-ENG133459-Analysis 17-s_Beruhigungszeit_Entlueften    No Response From Subnet Component    30
IDE80017-ENG133469-Analysis 17-s_Faktor_Druck_Entlueftung_Seitenhalt    No Response From Subnet Component    30
IDE80017-ENG133464-Analysis 17-s_IntervallUmgebungsbedingungen    No Response From Subnet Component    30
IDE80017-ENG133465-Analysis 17-s_MaxIntervall    No Response From Subnet Component    30
IDE80017-ENG133461-Analysis 17-s_Messdauer_Initialisierung    No Response From Subnet Component    30
IDE80017-ENG133462-Analysis 17-s_Messdauer_Kurzzeitmessung    No Response From Subnet Component    30
IDE80017-ENG133463-Analysis 17-s_Messdauer_Langzeitmessung    No Response From Subnet Component    30
IDE80017-ENG133468-Analysis 17-s_Sitzvariante    No Response From Subnet Component    30
IDE80017-ENG133467-Analysis 17-s_Timeout_Befuell_Linearbereich    No Response From Subnet Component    30
IDE80017-ENG133466-Analysis 17-s_Timeout_Befuell_Startbereich    No Response From Subnet Component    30
IDE80017-ENG133457-Analysis 17-s_Uebernahmedruck_P_u    No Response From Subnet Component    30
IDE80017-ENG133456-Analysis 17-s_Uebernahmedruck_PUe_o    No Response From Subnet Component    30
IDE80018-ENG133471-Analysis 18-Offset_PB1_LM    No Response From Subnet Component    30
IDE80018-ENG133472-Analysis 18-Offset_PB1_LU    No Response From Subnet Component    30
IDE80018-ENG133473-Analysis 18-Offset_PB1_SH    No Response From Subnet Component    30
IDE80018-ENG133475-Analysis 18-Offset_PB2_LM    No Response From Subnet Component    30
IDE80018-ENG133474-Analysis 18-Offset_PB2_LO    No Response From Subnet Component    30
IDE80018-ENG133476-Analysis 18-Offset_PB2_LU    No Response From Subnet Component    30
IDE80018-ENG133477-Analysis 18-Offset_PB2_SH    No Response From Subnet Component    30
IDE80018-ENG133483-Analysis 18-Offset_PV1_LM    No Response From Subnet Component    30
IDE80018-ENG133482-Analysis 18-Offset_PV1_LO    No Response From Subnet Component    30
IDE80018-ENG133484-Analysis 18-Offset_PV1_LU    No Response From Subnet Component    30
IDE80018-ENG133485-Analysis 18-Offset_PV1_SH    No Response From Subnet Component    30
IDE80018-ENG133486-Analysis 18-Offset_PV2_LO    No Response From Subnet Component    30
IDE80018-ENG133488-Analysis 18-Offset_PV2_LU    No Response From Subnet Component    30
IDE80018-ENG133489-Analysis 18-Offset_PV2_SH    No Response From Subnet Component    30
IDE80018-ENG133534-Analysis 18-OffsetPB1_LO    No Response From Subnet Component    30
IDE80018-ENG133480-Analysis 18-OffsetPP1    No Response From Subnet Component    30
IDE80018-ENG133481-Analysis 18-OffsetPP2    No Response From Subnet Component    30
IDE80018-ENG133487-Analysis 18-OffsetPV2_LMy    No Response From Subnet Component    30
IDE80018-ENG133478-Analysis 18-OffsetT1    No Response From Subnet Component    30
IDE80018-ENG133479-Analysis 18-OffsetT2    No Response From Subnet Component    30
IDE80018-ENG133490-Analysis 18-p_function_feedback_timeout    No Response From Subnet Component    30
IDE80018-ENG133491-Analysis 18-p_longpush_time    No Response From Subnet Component    30
IDE80018-ENG133497-Analysis 18-p_stoesselSchaltschwelle_eins    No Response From Subnet Component    30
IDE80018-ENG133498-Analysis 18-p_stoesselSchaltschwelle_zwei    No Response From Subnet Component    30
IDE80018-ENG133494-Analysis 18-p_tasterSchaltschwelle_drei    No Response From Subnet Component    30
IDE80018-ENG133492-Analysis 18-p_tasterSchaltschwelle_eins    No Response From Subnet Component    30
IDE80018-ENG133496-Analysis 18-p_tasterSchaltschwelle_fuenf    No Response From Subnet Component    30
IDE80018-ENG133495-Analysis 18-p_tasterSchaltschwelle_vier    No Response From Subnet Component    30
IDE80018-ENG133493-Analysis 18-p_tasterSchaltschwelle_zwei    No Response From Subnet Component    30
IDE80018-ENG133458-Analysis 18-s_Beruhigungszeit_Befuellen    No Response From Subnet Component    30
IDE80018-ENG133460-Analysis 18-s_Beruhigungszeit_Druckmessung    No Response From Subnet Component    30
IDE80018-ENG133459-Analysis 18-s_Beruhigungszeit_Entlueften    No Response From Subnet Component    30
IDE80018-ENG133469-Analysis 18-s_Faktor_Druck_Entlueftung_Seitenhalt    No Response From Subnet Component    30
IDE80018-ENG133464-Analysis 18-s_IntervallUmgebungsbedingungen    No Response From Subnet Component    30
IDE80018-ENG133465-Analysis 18-s_MaxIntervall    No Response From Subnet Component    30
IDE80018-ENG133461-Analysis 18-s_Messdauer_Initialisierung    No Response From Subnet Component    30
IDE80018-ENG133462-Analysis 18-s_Messdauer_Kurzzeitmessung    No Response From Subnet Component    30
IDE80018-ENG133463-Analysis 18-s_Messdauer_Langzeitmessung    No Response From Subnet Component    30
IDE80018-ENG133468-Analysis 18-s_Sitzvariante    No Response From Subnet Component    30
IDE80018-ENG133467-Analysis 18-s_Timeout_Befuell_Linearbereich    No Response From Subnet Component    30
IDE80018-ENG133466-Analysis 18-s_Timeout_Befuell_Startbereich    No Response From Subnet Component    30
IDE80018-ENG133532-Analysis 18-s_Uebernahmedruck_PUe_u    No Response From Subnet Component    30
IDE80018-ENG133533-Analysis 18-s_UebernahmedruckP_u    No Response From Subnet Component    30
MAS01490-ENG142027-Energy management-Energiemanagement Abschaltung    active     5
MAS01490-ENG116830-Energy management-Energy_Management_Adaptation    Energy management active     5
MAS01490-ENG142256-Energy management-Hochvoltfahrzeug    not installed     5
MAS01490-ENG141950-Energy management-Hybrid vehicle    No     5
MAS01490-ENG133400-Energy management-Praediktives_Energiemanagement    not active     5
MAS01490-ENG141978-Energy management-Recuperation    active     5
MAS01490-ENG142037-Energy management-Zweitbatterie    not installed     5
MAS05055-lower turn position    31.494474 °    2
MAS05056-upper turn position    170.494336 °    2
MAS08228-ENG133434-Light sensor-Daemmerungsgrenze: Hysterese_obergrenze    1200 lx    24
MAS08228-ENG133435-Light sensor-Daemmerungsgrenze_Hysterese_untergrenze    2200 lx    24
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle    0 lx    24
MAS08228-ENG133433-Light sensor-Einschaltgrenze_CHO_LHO    600 lx    24
MAS08228-ENG133437-Light sensor-Helligkeitsgrenze_Licht__einschalten    1200 lx    24
MAS08228-ENG133438-Light sensor-Helligkeitsgrenze_Licht_ausschalten    2200 lx    24
MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red    00 00     24
MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell    2000 lx    24
MAS08228-ENG142230-Light sensor-HMI_Exterior_light_on_highway    active     24
MAS08228-ENG142231-Light sensor-HMI_Exterior_light_on_rain    active     24
MAS08228-ENG142232-Light sensor-HMI_exterior_light_sensitivity    frueh     24
MAS08228-ENG142229-Light sensor-HMI_Wiper_Comfort_Rain_Sensor_OFF    not active     24
MAS08228-ENG126628-Light sensor-LS_Error_Ausgabe    not active     24
MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung    0 mV    24
MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke    0 lx    24
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung    0 mV    24
MAS08228-ENG133439-Light sensor-Minimale_Beleuchtungsstaerke    0 lx    24
MAS08228-ENG133443-Light sensor-Tunnel_einschalt_verzoegerung    02     24
ENG153709-ENG154696-Aktivierung_Entwicklungsdiagnose-log_dtc_status    not active     9
ENG153709-ENG154697-Aktivierung_Entwicklungsdiagnose-log-dtc_DFCC    00 00 00     9
ENG153709-ENG154714-Aktivierung_Entwicklungsdiagnose-Reaktion_LOG-DTC    First_dtc     9
ENG141683-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren    active     4
ENG141683-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT    active     4
ENG141683-ENG141975-Allwetterlicht_Spoiler-tt_spoiler    not installed     4
ENG153710-ENG154516-Ambience_lightning_color_list_2-Blauwert Farbe 11    0    60
ENG153710-ENG154517-Ambience_lightning_color_list_2-Blauwert Farbe 12    0    60
ENG153710-ENG154518-Ambience_lightning_color_list_2-Blauwert Farbe 13    64    60
ENG153710-ENG154519-Ambience_lightning_color_list_2-Blauwert Farbe 14    128    60
ENG153710-ENG154520-Ambience_lightning_color_list_2-Blauwert Farbe 15    191    60
ENG153710-ENG154521-Ambience_lightning_color_list_2-Blauwert Farbe 16    255    60
ENG153710-ENG154522-Ambience_lightning_color_list_2-Blauwert Farbe 17    255    60
ENG153710-ENG154523-Ambience_lightning_color_list_2-Blauwert Farbe 18    255    60
ENG153710-ENG154524-Ambience_lightning_color_list_2-Blauwert Farbe 19    255    60
ENG153710-ENG154525-Ambience_lightning_color_list_2-Blauwert Farbe 20    255    60
ENG153710-ENG154539-Ambience_lightning_color_list_2-Blauwert_Farbe_21    255    60
ENG153710-ENG154541-Ambience_lightning_color_list_2-Blauwert_Farbe_22    255    60
ENG153710-ENG154543-Ambience_lightning_color_list_2-Blauwert_Farbe_23    255    60
ENG153710-ENG154545-Ambience_lightning_color_list_2-Blauwert_Farbe_24    255    60
ENG153710-ENG154547-Ambience_lightning_color_list_2-Blauwert_Farbe_25    191    60
ENG153710-ENG154549-Ambience_lightning_color_list_2-Blauwert_Farbe_26    128    60
ENG153710-ENG154551-Ambience_lightning_color_list_2-Blauwert_Farbe_27    64    60
ENG153710-ENG154553-Ambience_lightning_color_list_2-Blauwert_Farbe_28    0    60
ENG153710-ENG154555-Ambience_lightning_color_list_2-Blauwert_Farbe_29    255    60
ENG153710-ENG154558-Ambience_lightning_color_list_2-Blauwert_Farbe_30    159    60
ENG153710-ENG154635-Ambience_lightning_color_list_2-Gruenwert Farbe 11    255    60
ENG153710-ENG154636-Ambience_lightning_color_list_2-Gruenwert Farbe 12    255    60
ENG153710-ENG154637-Ambience_lightning_color_list_2-Gruenwert Farbe 13    255    60
ENG153710-ENG154638-Ambience_lightning_color_list_2-Gruenwert Farbe 14    255    60
ENG153710-ENG154639-Ambience_lightning_color_list_2-Gruenwert Farbe 15    255    60
ENG153710-ENG154640-Ambience_lightning_color_list_2-Gruenwert Farbe 16    255    60
ENG153710-ENG154641-Ambience_lightning_color_list_2-Gruenwert Farbe 17    191    60
ENG153710-ENG154642-Ambience_lightning_color_list_2-Gruenwert Farbe 18    128    60
ENG153710-ENG154643-Ambience_lightning_color_list_2-Gruenwert Farbe 19    64    60
ENG153710-ENG154644-Ambience_lightning_color_list_2-Gruenwert Farbe 20    0    60
ENG153710-ENG154658-Ambience_lightning_color_list_2-Gruenwert_Farbe_21    0    60
ENG153710-ENG154660-Ambience_lightning_color_list_2-Gruenwert_Farbe_22    0    60
ENG153710-ENG154662-Ambience_lightning_color_list_2-Gruenwert_Farbe_23    0    60
ENG153710-ENG154664-Ambience_lightning_color_list_2-Gruenwert_Farbe_24    0    60
ENG153710-ENG154666-Ambience_lightning_color_list_2-Gruenwert_Farbe_25    0    60
ENG153710-ENG154668-Ambience_lightning_color_list_2-Gruenwert_Farbe_26    0    60
ENG153710-ENG154670-Ambience_lightning_color_list_2-Gruenwert_Farbe_27    0    60
ENG153710-ENG154672-Ambience_lightning_color_list_2-Gruenwert_Farbe_28    0    60
ENG153710-ENG154674-Ambience_lightning_color_list_2-Gruenwert_Farbe_29    255    60
ENG153710-ENG154677-Ambience_lightning_color_list_2-Gruenwert_Farbe_30    159    60
ENG153710-ENG154723-Ambience_lightning_color_list_2-Rotwert Farbe 11    64    60
ENG153710-ENG154724-Ambience_lightning_color_list_2-Rotwert Farbe 12    0    60
ENG153710-ENG154725-Ambience_lightning_color_list_2-Rotwert Farbe 13    0    60
ENG153710-ENG154726-Ambience_lightning_color_list_2-Rotwert Farbe 14    0    60
ENG153710-ENG154727-Ambience_lightning_color_list_2-Rotwert Farbe 15    0    60
ENG153710-ENG154728-Ambience_lightning_color_list_2-Rotwert Farbe 16    0    60
ENG153710-ENG154729-Ambience_lightning_color_list_2-Rotwert Farbe 17    0    60
ENG153710-ENG154730-Ambience_lightning_color_list_2-Rotwert Farbe 18    0    60
ENG153710-ENG154731-Ambience_lightning_color_list_2-Rotwert Farbe 19    0    60
ENG153710-ENG154732-Ambience_lightning_color_list_2-Rotwert Farbe 20    0    60
ENG153710-ENG154746-Ambience_lightning_color_list_2-Rotwert_Farbe_21    64    60
ENG153710-ENG154748-Ambience_lightning_color_list_2-Rotwert_Farbe_22    128    60
ENG153710-ENG154750-Ambience_lightning_color_list_2-Rotwert_Farbe_23    191    60
ENG153710-ENG154752-Ambience_lightning_color_list_2-Rotwert_Farbe_24    255    60
ENG153710-ENG154754-Ambience_lightning_color_list_2-Rotwert_Farbe_25    255    60
ENG153710-ENG154756-Ambience_lightning_color_list_2-Rotwert_Farbe_26    255    60
ENG153710-ENG154758-Ambience_lightning_color_list_2-Rotwert_Farbe_27    255    60
ENG153710-ENG154760-Ambience_lightning_color_list_2-Rotwert_Farbe_28    255    60
ENG153710-ENG154762-Ambience_lightning_color_list_2-Rotwert_Farbe_29    255    60
ENG153710-ENG154765-Ambience_lightning_color_list_2-Rotwert_Farbe_30    159    60
ENG153711-ENG154528-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_11_lin    0    60
ENG153711-ENG154529-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_12_lin    0    60
ENG153711-ENG154530-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_13_lin    0    60
ENG153711-ENG154531-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_14_lin    0    60
ENG153711-ENG154532-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_15_lin    0    60
ENG153711-ENG154533-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_16_lin    0    60
ENG153711-ENG154534-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_17_lin    0    60
ENG153711-ENG154535-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_18_lin    0    60
ENG153711-ENG154536-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_19_lin    0    60
ENG153711-ENG154538-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_20_lin    0    60
ENG153711-ENG154540-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_21_lin    0    60
ENG153711-ENG154542-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_22_lin    0    60
ENG153711-ENG154544-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_23_lin    0    60
ENG153711-ENG154546-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_24_lin    0    60
ENG153711-ENG154548-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_25_lin    0    60
ENG153711-ENG154550-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_26_lin    0    60
ENG153711-ENG154552-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_27_lin    0    60
ENG153711-ENG154554-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_28_lin    0    60
ENG153711-ENG154556-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_29_lin    0    60
ENG153711-ENG154559-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_30_lin    0    60
ENG153711-ENG154647-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_11_lin    0    60
ENG153711-ENG154648-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_12_lin    0    60
ENG153711-ENG154649-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_13_lin    0    60
ENG153711-ENG154650-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_14_lin    0    60
ENG153711-ENG154651-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_15_lin    0    60
ENG153711-ENG154652-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_16_lin    0    60
ENG153711-ENG154653-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_17_lin    0    60
ENG153711-ENG154654-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_18_lin    0    60
ENG153711-ENG154655-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_19_lin    0    60
ENG153711-ENG154657-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_20_lin    0    60
ENG153711-ENG154659-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_21_lin    0    60
ENG153711-ENG154661-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_22_lin    0    60
ENG153711-ENG154663-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_23_lin    0    60
ENG153711-ENG154665-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_24_lin    0    60
ENG153711-ENG154667-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_25_lin    0    60
ENG153711-ENG154669-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_26_lin    0    60
ENG153711-ENG154671-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_27_lin    0    60
ENG153711-ENG154673-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_28_lin    0    60
ENG153711-ENG154675-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_29_lin    0    60
ENG153711-ENG154678-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_30_lin    0    60
ENG153711-ENG154735-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_11_lin    0    60
ENG153711-ENG154736-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_12_lin    0    60
ENG153711-ENG154737-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_13_lin    0    60
ENG153711-ENG154738-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_14_lin    0    60
ENG153711-ENG154739-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_15_lin    0    60
ENG153711-ENG154740-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_16_lin    0    60
ENG153711-ENG154741-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_17_lin    0    60
ENG153711-ENG154742-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_18_lin    0    60
ENG153711-ENG154743-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_19_lin    0    60
ENG153711-ENG154745-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_20_lin    0    60
ENG153711-ENG154747-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_21_lin    0    60
ENG153711-ENG154749-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_22_lin    0    60
ENG153711-ENG154751-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_23_lin    0    60
ENG153711-ENG154753-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_24_lin    0    60
ENG153711-ENG154755-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_25_lin    0    60
ENG153711-ENG154757-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_26_lin    0    60
ENG153711-ENG154759-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_27_lin    0    60
ENG153711-ENG154761-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_28_lin    0    60
ENG153711-ENG154763-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_29_lin    0    60
ENG153711-ENG154766-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_30_lin    0    60
ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1    1    30
ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10    1    30
ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11    1    30
ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12    1    30
ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13    1    30
ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14    1    30
ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15    1    30
ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2    1    30
ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3    1    30
ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4    1    30
ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5    1    30
ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6    1    30
ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7    1    30
ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8    1    30
ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9    1    30
ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1    door     30
ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10    door     30
ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11    door     30
ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12    door     30
ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13    door     30
ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14    door     30
ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15    door     30
ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2    door     30
ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3    door     30
ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4    door     30
ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5    door     30
ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6    door     30
ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7    door     30
ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8    door     30
ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9    door     30
ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1    multicolor     30
ENG126649-ENG126899-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10    not installed     30
ENG126649-ENG126902-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11    not installed     30
ENG126649-ENG126905-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12    not installed     30
ENG126649-ENG126908-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13    not installed     30
ENG126649-ENG126911-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14    not installed     30
ENG126649-ENG126914-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15    not installed     30
ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2    not installed     30
ENG126649-ENG126878-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3    not installed     30
ENG126649-ENG126881-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4    not installed     30
ENG126649-ENG126884-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5    not installed     30
ENG126649-ENG126887-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6    not installed     30
ENG126649-ENG126890-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7    not installed     30
ENG126649-ENG126893-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8    not installed     30
ENG126649-ENG126896-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9    not installed     30
ENG128379-ENG128424-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_:12    0    60
ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1    0    60
ENG128379-ENG128418-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_10    0    60
ENG128379-ENG128421-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_11    0    60
ENG128379-ENG128427-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_13    0    60
ENG128379-ENG128430-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_14    0    60
ENG128379-ENG128433-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_15    0    60
ENG128379-ENG128436-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_16    0    60
ENG128379-ENG128439-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_17    0    60
ENG128379-ENG128442-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_18    0    60
ENG128379-ENG128445-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_19    0    60
ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2    0    60
ENG128379-ENG128448-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_20    0    60
ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3    0    60
ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4    0    60
ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5    0    60
ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6    0    60
ENG128379-ENG128409-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_7    0    60
ENG128379-ENG128412-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_8    0    60
ENG128379-ENG128415-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_9    0    60
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1    00     60
ENG128379-ENG128420-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_10    0    60
ENG128379-ENG128423-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_11    0    60
ENG128379-ENG128426-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_12    0    60
ENG128379-ENG128429-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_13    0    60
ENG128379-ENG128432-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_14    0    60
ENG128379-ENG128435-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_15    0    60
ENG128379-ENG128438-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_16    0    60
ENG128379-ENG128441-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_17    0    60
ENG128379-ENG128444-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_18    0    60
ENG128379-ENG128447-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_19    0    60
ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2    0    60
ENG128379-ENG128450-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_20    0    60
ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3    0    60
ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4    0    60
ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5    0    60
ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6    0    60
ENG128379-ENG128411-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_7    0    60
ENG128379-ENG128417-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_9    0    60
ENG128379-ENG128414-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave8    0    60
ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1    installed     60
ENG128379-ENG128419-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_10    not installed     60
ENG128379-ENG128422-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_11    not installed     60
ENG128379-ENG128425-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_12    not installed     60
ENG128379-ENG128428-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_13    not installed     60
ENG128379-ENG128431-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_14    not installed     60
ENG128379-ENG128434-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_15    not installed     60
ENG128379-ENG128437-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_16    not installed     60
ENG128379-ENG128440-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_17    not installed     60
ENG128379-ENG128443-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_18    not installed     60
ENG128379-ENG128446-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_19    not installed     60
ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2    not installed     60
ENG128379-ENG128449-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_20    not installed     60
ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3    not installed     60
ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4    not installed     60
ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5    not installed     60
ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6    not installed     60
ENG128379-ENG128410-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7    not installed     60
ENG128379-ENG128416-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_9    not installed     60
ENG128379-ENG128413-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8    not installed     60
ENG126650-ENG126926-Ambiente_light-Dimmung_auf_Zielwert deaktivieren_Suchbeleuchtung    No Response From Subnet Component    60
ENG126650-ENG126927-Ambiente_light-Dimmung_auf_Zielwert_deaktivieren_Innen_und_Leselicht    No Response From Subnet Component    60
ENG126650-ENG126922-Ambiente_light-Korrekturfaktor_ Flaechenlicht_vorne_Farbe_1    No Response From Subnet Component    60
ENG126650-ENG126924-Ambiente_light-Korrekturfaktor_Flaechenlicht_hinten_Farbe_1    No Response From Subnet Component    60
ENG126650-ENG126925-Ambiente_light-Korrekturfaktor_Flaechenlicht_hinten_Farbe_2    No Response From Subnet Component    60
ENG126650-ENG126923-Ambiente_light-Korrekturfaktor_Flaechenlicht_vorne_Farbe_2    No Response From Subnet Component    60
ENG126650-ENG126921-Ambiente_light-Korrekturfaktor_Funktionsbeleuchtung    No Response From Subnet Component    60
ENG126650-ENG126918-Ambiente_light-Korrekturfaktor_Leselicht_hinten    No Response From Subnet Component    60
ENG126650-ENG126919-Ambiente_light-Korrekturfaktor_Leselicht_Reihe_3    No Response From Subnet Component    60
ENG126650-ENG126917-Ambiente_light-Korrekturfaktor_Leselicht_vorne    No Response From Subnet Component    60
ENG126650-ENG126920-Ambiente_light-Korrekturfaktor_Schalter_und_Suchbeleuchtung    No Response From Subnet Component    60
ENG128378-ENG115658-Ambiente_Light_Kennlinie_Hochdimmen-x0    No Response From Subnet Component    60
ENG128378-ENG101574-Ambiente_Light_Kennlinie_Hochdimmen-X1    No Response From Subnet Component    60
ENG128378-ENG115664-Ambiente_Light_Kennlinie_Hochdimmen-x10    No Response From Subnet Component    60
ENG128378-ENG99557-Ambiente_Light_Kennlinie_Hochdimmen-X2    No Response From Subnet Component    60
ENG128378-ENG102140-Ambiente_Light_Kennlinie_Hochdimmen-X3    No Response From Subnet Component    60
ENG128378-ENG102936-Ambiente_Light_Kennlinie_Hochdimmen-X4    No Response From Subnet Component    60
ENG128378-ENG103548-Ambiente_Light_Kennlinie_Hochdimmen-X5    No Response From Subnet Component    60
ENG128378-ENG113992-Ambiente_Light_Kennlinie_Hochdimmen-X6    No Response From Subnet Component    60
ENG128378-ENG115661-Ambiente_Light_Kennlinie_Hochdimmen-x7    No Response From Subnet Component    60
ENG128378-ENG115662-Ambiente_Light_Kennlinie_Hochdimmen-x8    No Response From Subnet Component    60
ENG128378-ENG115663-Ambiente_Light_Kennlinie_Hochdimmen-x9    No Response From Subnet Component    60
ENG128378-ENG115659-Ambiente_Light_Kennlinie_Hochdimmen-y0    No Response From Subnet Component    60
ENG128378-ENG99777-Ambiente_Light_Kennlinie_Hochdimmen-Y1    No Response From Subnet Component    60
ENG128378-ENG115668-Ambiente_Light_Kennlinie_Hochdimmen-y10    No Response From Subnet Component    60
ENG128378-ENG100480-Ambiente_Light_Kennlinie_Hochdimmen-Y2    No Response From Subnet Component    60
ENG128378-ENG100773-Ambiente_Light_Kennlinie_Hochdimmen-Y3    No Response From Subnet Component    60
ENG128378-ENG100631-Ambiente_Light_Kennlinie_Hochdimmen-Y4    No Response From Subnet Component    60
ENG128378-ENG102174-Ambiente_Light_Kennlinie_Hochdimmen-Y5    No Response From Subnet Component    60
ENG128378-ENG113993-Ambiente_Light_Kennlinie_Hochdimmen-Y6    No Response From Subnet Component    60
ENG128378-ENG115665-Ambiente_Light_Kennlinie_Hochdimmen-y7    No Response From Subnet Component    60
ENG128378-ENG115666-Ambiente_Light_Kennlinie_Hochdimmen-y8    No Response From Subnet Component    60
ENG128378-ENG115667-Ambiente_Light_Kennlinie_Hochdimmen-y9    No Response From Subnet Component    60
ENG153712-ENG154510-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Ambiente    Keine_Spannungsanforderung     23
ENG153712-ENG154602-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_0    1    23
ENG153712-ENG154603-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_1    1    23
ENG153712-ENG154604-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_10    1    23
ENG153712-ENG154605-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_11    1    23
ENG153712-ENG154606-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_12    1    23
ENG153712-ENG154607-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_13    1    23
ENG153712-ENG154608-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_14    1    23
ENG153712-ENG154609-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_15    1    23
ENG153712-ENG154610-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_2    1    23
ENG153712-ENG154611-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_3    1    23
ENG153712-ENG154612-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_4    1    23
ENG153712-ENG154613-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_5    1    23
ENG153712-ENG154614-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_6    1    23
ENG153712-ENG154615-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_7    1    23
ENG153712-ENG154616-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_8    1    23
ENG153712-ENG154617-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_9    1    23
ENG141649-ENG122212-Außenlicht_Blinker-ABBA_Blinken    not active     10
ENG141649-ENG133379-Außenlicht_Blinker-Abbruch Komfortblinken    active     10
ENG141649-ENG116590-Außenlicht_Blinker-Blinkkontrolleuchte fuer Anhaenger    separte     10
ENG141649-ENG121966-Außenlicht_Blinker-Crash flashing    not active     10
ENG141649-ENG122207-Außenlicht_Blinker-DWA_Alarm_Blinken    active     10
ENG141649-ENG122206-Außenlicht_Blinker-DWA_Schaerfungsquittung    active     10
ENG141649-ENG142195-Außenlicht_Blinker-Dynamische_Blink_Delay    50 ms    10
ENG141649-ENG126819-Außenlicht_Blinker-Emergency_alert_blinken    not active     10
ENG141649-ENG154601-Außenlicht_Blinker-Fahrerassistenz_Blinkenfunktionen    Wechselblinken_Warnblinken     10
ENG141649-ENG115774-Außenlicht_Blinker-Komfortblinken    active     10
ENG141649-ENG116587-Außenlicht_Blinker-Komfortblinken Blinkzyklen    3    10
ENG141649-ENG122208-Außenlicht_Blinker-Multi_kollisions_Blinken    not active     10
ENG141649-ENG122209-Außenlicht_Blinker-Notwarn_blinken_NBA_Phase_2    not active     10
ENG141649-ENG121967-Außenlicht_Blinker-Panic flashing    active     10
ENG141649-ENG154711-Außenlicht_Blinker-PreCrash_RECAS    PreCrash_passiv     10
ENG141649-ENG122211-Außenlicht_Blinker-Richtungs_blinken_links    active     10
ENG141649-ENG122210-Außenlicht_Blinker-Richtungs_blinken_rechts    active     10
ENG141649-ENG249932-Außenlicht_Blinker-Rollenmodusblinken    active     10
ENG141649-ENG122201-Außenlicht_Blinker-Schluessel_Anlern_Blinken    active     10
ENG141649-ENG121968-Außenlicht_Blinker-Taxi alarm flashing    active     10
ENG141649-ENG126629-Außenlicht_Blinker-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken    active     10
ENG141649-ENG251922-Außenlicht_Blinker-Travel_Assist_Blinken    not active     10
ENG141649-ENG122202-Außenlicht_Blinker-UGDO_ Anlern_Blinken    active     10
ENG141649-ENG142029-Außenlicht_Blinker-Warnblinken_durch_Fahrerassistenz    active     10
ENG141649-ENG246997-Außenlicht_Blinker-Warnblinken_TP_max    120 min    10
ENG141649-ENG122214-Außenlicht_Blinker-Warnblinken_Zuendung_AUS    active     10
ENG141649-ENG122213-Außenlicht_Blinker-Warnblinken_Zuendung_EIN    active     10
ENG141649-ENG122204-Außenlicht_Blinker-ZV_Blinken_auf    active     10
ENG141649-ENG122203-Außenlicht_Blinker-ZV_Blinken_zu    active     10
ENG141647-ENG141986-Außenlicht_Front-Abblendlicht_Leuchtentyp    H7     9
ENG141647-ENG246962-Außenlicht_Front-ABL Redundanz Check sperren    active     9
ENG141647-ENG116705-Außenlicht_Front-Allwetterlicht Ausschaltgrenze    350 km/h    9
ENG141647-ENG116704-Außenlicht_Front-Allwetterlicht Einschaltgrenze    350 km/h    9
ENG141647-ENG115833-Außenlicht_Front-Fahrlicht bei Tag    Daytime running lamps     9
ENG141647-ENG142193-Außenlicht_Front-Geschwindigkeitsabhaengiges TFL    5 km/h    9
ENG141647-ENG115861-Außenlicht_Front-Lichthupe bei Zuendung aus moeglich    active     9
ENG141647-ENG115832-Außenlicht_Front-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht    active     9
ENG141647-ENG142191-Außenlicht_Front-Signaturlicht HMI-default Anzeige im Kombiinstrument    not active     9
ENG141647-ENG142190-Außenlicht_Front-Signaturlicht_verbaut    not installed     9
ENG141647-ENG116592-Außenlicht_Front-Standlicht aktiviert zusaetzlich Tagfahrlicht    active     9
ENG141647-ENG116594-Außenlicht_Front-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich    active     9
ENG141647-ENG122184-Außenlicht_Front-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten    not active     9
ENG141647-ENG115734-Außenlicht_Front-Tagfahrlicht nur in Schalterstellung AUTO    active     9
ENG141647-ENG116593-Außenlicht_Front-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht    not active     9
ENG141647-ENG115733-Außenlicht_Front-Tagfahrlichtkontrollleuchte    not active     9
ENG141647-ENG142192-Außenlicht_Front-TFL_Abschaltung_ueber_Geschwindigkeit    not active     9
ENG141647-ENG116591-Außenlicht_Front-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge    not active     9
ENG141647-ENG115860-Außenlicht_Front-Zahl der aktiven Scheinwerfer auf 2 limitieren    limitieren     9
ENG141648-ENG141987-Aussenlicht_Heck-Bremslicht_ist_auch_Blinklicht    No     5
ENG141648-ENG115782-Aussenlicht_Heck-Nebelschlusslicht Warngeschwindigkeit    0 km/h    5
ENG141648-ENG116636-Aussenlicht_Heck-Notbremsanzeige NBA    active     5
ENG141648-ENG115831-Aussenlicht_Heck-Schlusslicht mit Bremslichtfunktion    active     5
ENG141648-ENG142004-Aussenlicht_Heck-Umgreifende_Heckklappe    not installed     5
ENG141656-ENG249813-Außenlicht_uebergreifend-ABL_Abschaltung_nach_ECE48_Rev6    No     18
ENG141656-ENG142020-Außenlicht_uebergreifend-All-weather light    not installed     18
ENG141656-ENG133381-Außenlicht_uebergreifend-Bedingungen zur Parklichtbegrenzung    abschaltbar über Energiemanagement     18
ENG141656-ENG133380-Außenlicht_uebergreifend-Bedingungen zur Standlichtbegrenzung    abschaltbar über Energiemanagement     18
ENG141656-ENG142188-Außenlicht_uebergreifend-bewusstes Standlicht    Aktive Begrenzung     18
ENG141656-ENG246968-Außenlicht_uebergreifend-CHo_LHo_Nachlauf    0 ms    18
ENG141656-ENG115656-Außenlicht_uebergreifend-Coming Home Leuchten    Low beam     18
ENG141656-ENG116601-Außenlicht_uebergreifend-Coming Home Verbaustatus    manual     18
ENG141656-ENG116604-Außenlicht_uebergreifend-Coming-home Einschaltereignis    Driver door     18
ENG141656-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach    active     18
ENG141656-ENG126818-Außenlicht_uebergreifend-Fahrlichtwarnung_Hinweis_Konfig    Hinweis_in_LDS-Stellung_Null_und_SL     18
ENG141656-ENG137034-Außenlicht_uebergreifend-Faktor fuer Verfuegbarkeitstimer    Faktor fuer x5 Minuten     18
ENG141656-ENG154619-Außenlicht_uebergreifend-Fernlicht_LH    Keine_Spannungsanforderung     18
ENG141656-ENG154177-Außenlicht_uebergreifend-Fog lamp    Keine_Spannungsanforderung     18
ENG141656-ENG116608-Außenlicht_uebergreifend-Helligkeitsschwelle Forward-Messung    46400 lx    18
ENG141656-ENG116605-Außenlicht_uebergreifend-Helligkeitsschwelle Infrarot-Messung    12 lx    18
ENG141656-ENG142189-Außenlicht_uebergreifend-HVLM_Ladezustandsanzeige    No     18
ENG141656-ENG115858-Außenlicht_uebergreifend-Kontrollleuchte fuer Begrenzungslicht    integriert in Suchbeleuchtung     18
ENG141656-ENG142185-Außenlicht_uebergreifend-LCM_blinker    false     18
ENG141656-ENG141992-Außenlicht_uebergreifend-LDS_mit_AFL    Yes     18
ENG141656-ENG141991-Außenlicht_uebergreifend-LDS_mit_Nebel_Schlusslicht    Yes     18
ENG141656-ENG141990-Außenlicht_uebergreifend-LDS_mit_Nebellicht    No     18
ENG141656-ENG141993-Außenlicht_uebergreifend-LDS_mit_Standlichtstellung    Yes     18
ENG141656-ENG115657-Außenlicht_uebergreifend-Leaving-Home Verbausstatus    Enabled     18
ENG141656-ENG249901-Außenlicht_uebergreifend-Licht_Schaltung_nach_ECE48_Rev6    not active     18
ENG141656-ENG141989-Außenlicht_uebergreifend-Lichtdrehschalter (LDS)    discrete     18
ENG141656-ENG115862-Außenlicht_uebergreifend-Lichtwarnungsverhalten    klemmenabhaengig     18
ENG141656-ENG142034-Außenlicht_uebergreifend-Light_Control_Module    installed     18
ENG141656-ENG98354-Außenlicht_uebergreifend-Low beam    Keine_Spannungsanforderung     18
ENG141656-ENG115863-Außenlicht_uebergreifend-Menueeinstellung CHO LHO    Menuesteuerung Zeit aktivieren     18
ENG141656-ENG116603-Außenlicht_uebergreifend-Menueeinstellung Cominghome    30 seconds     18
ENG141656-ENG116607-Außenlicht_uebergreifend-Menueeinstellung Leaving-home Zeit per BAP    10 seconds     18
ENG141656-ENG116602-Außenlicht_uebergreifend-Menuesteuerung Coming Home Werkseinstellung    active     18
ENG141656-ENG116606-Außenlicht_uebergreifend-Menuesteuerung Leaving-home Freischaltung per BAP    active     18
ENG141656-ENG115859-Außenlicht_uebergreifend-Parklicht ueber LSS aktiviert    both sides     18
ENG141656-ENG126816-Außenlicht_uebergreifend-Standlicht aus    active     18
ENG141656-ENG115829-Außenlicht_uebergreifend-Standlichtreduzierung mit beidseitigem Parklicht    active     18
ENG141656-ENG133383-Außenlicht_uebergreifend-Standlicht-Verfügbarkeit    24 s    18
ENG141656-ENG249943-Außenlicht_uebergreifend-TFL_Abschaltung_nach_ECE48_Rev6    No     18
ENG141656-ENG154174-Außenlicht_uebergreifend-Turn signal lamp    Keine_Spannungsanforderung     18
ENG141656-ENG126817-Außenlicht_uebergreifend-Umfeldleuchte als Manoevrierleuchte    active     18
ENG125611-ENG125698-Blower_1_Backrest_Left-Counter_For_Blockage_Validation    No Response From Subnet Component    18
ENG125611-ENG125700-Blower_1_Backrest_Left-Critical_Temperature_Treshold    No Response From Subnet Component    18
ENG125611-ENG125697-Blower_1_Backrest_Left-Hysteresis_Treshold_For_Undervoltage    No Response From Subnet Component    18
ENG125611-ENG125699-Blower_1_Backrest_Left-Latency_For_Blockage_Validation    No Response From Subnet Component    18
ENG125611-ENG125701-Blower_1_Backrest_Left-Maximum_Blower_Rotation_Speed    No Response From Subnet Component    18
ENG125611-ENG125695-Blower_1_Backrest_Left-Overvoltage_treshold    No Response From Subnet Component    18
ENG125611-ENG125702-Blower_1_Backrest_Left-Read_Coding_Pin    No Response From Subnet Component    18
ENG125611-ENG125696-Blower_1_Backrest_Left-Undervoltage_treshold    No Response From Subnet Component    18
ENG125612-ENG125698-Blower_1_Backrest_Right-Counter_For_Blockage_Validation    No Response From Subnet Component    18
ENG125612-ENG125700-Blower_1_Backrest_Right-Critical_Temperature_Treshold    No Response From Subnet Component    18
ENG125612-ENG125697-Blower_1_Backrest_Right-Hysteresis_Treshold_For_Undervoltage    No Response From Subnet Component    18
ENG125612-ENG125699-Blower_1_Backrest_Right-Latency_For_Blockage_Validation    No Response From Subnet Component    18
ENG125612-ENG125701-Blower_1_Backrest_Right-Maximum_Blower_Rotation_Speed    No Response From Subnet Component    18
ENG125612-ENG125695-Blower_1_Backrest_Right-Overvoltage_treshold    No Response From Subnet Component    18
ENG125612-ENG125702-Blower_1_Backrest_Right-Read_Coding_Pin    No Response From Subnet Component    18
ENG125612-ENG125696-Blower_1_Backrest_Right-Undervoltage_treshold    No Response From Subnet Component    18
ENG125609-ENG125698-Blower_1_Cushion_Left-Counter_For_Blockage_Validation    No Response From Subnet Component    18
ENG125609-ENG125700-Blower_1_Cushion_Left-Critical_Temperature_Treshold    No Response From Subnet Component    18
ENG125609-ENG125697-Blower_1_Cushion_Left-Hysteresis_Treshold_For_Undervoltage    No Response From Subnet Component    18
ENG125609-ENG125699-Blower_1_Cushion_Left-Latency_For_Blockage_Validation    No Response From Subnet Component    18
ENG125609-ENG125701-Blower_1_Cushion_Left-Maximum_Blower_Rotation_Speed    No Response From Subnet Component    18
ENG125609-ENG125695-Blower_1_Cushion_Left-Overvoltage_treshold    No Response From Subnet Component    18
ENG125609-ENG125702-Blower_1_Cushion_Left-Read_Coding_Pin    No Response From Subnet Component    18
ENG125609-ENG125696-Blower_1_Cushion_Left-Undervoltage_treshold    No Response From Subnet Component    18
ENG125610-ENG125698-Blower_1_Cushion_Right-Counter_For_Blockage_Validation    No Response From Subnet Component    18
ENG125610-ENG125700-Blower_1_Cushion_Right-Critical_Temperature_Treshold    No Response From Subnet Component    18
ENG125610-ENG125697-Blower_1_Cushion_Right-Hysteresis_Treshold_For_Undervoltage    No Response From Subnet Component    18
ENG125610-ENG125699-Blower_1_Cushion_Right-Latency_For_Blockage_Validation    No Response From Subnet Component    18
ENG125610-ENG125701-Blower_1_Cushion_Right-Maximum_Blower_Rotation_Speed    No Response From Subnet Component    18
ENG125610-ENG125695-Blower_1_Cushion_Right-Overvoltage_treshold    No Response From Subnet Component    18
ENG125610-ENG125702-Blower_1_Cushion_Right-Read_Coding_Pin    No Response From Subnet Component    18
ENG125610-ENG125696-Blower_1_Cushion_Right-Undervoltage_treshold    No Response From Subnet Component    18
ENG126647-ENG98399-debug_light_function-Activation    0    11
ENG126647-ENG101417-debug_light_function-Adresse    0    11
ENG126647-ENG126820-debug_light_function-Bitmask    0    11
ENG126647-ENG126821-debug_light_function-Divisor    0    11
ENG126647-ENG98827-debug_light_function-Offset    0    11
ENG126647-ENG126822-debug_light_function-Polaritaet    0    11
ENG246955-ENG246967-digital_key-central_locking_digital_key_general    not installed     3
ENG246955-ENG246972-digital_key-komfortbedienung_fh_oeffnen_ueber_btle    not active     3
ENG246955-ENG246973-digital_key-komfortbedienung_fh_oeffnen_ueber_btle_sonderfunktion    not active     3
ENG246955-ENG246974-digital_key-komfortbedienung_fh_oeffnen_ueber_nfc_fahrertuer    not active     3
ENG246955-ENG246975-digital_key-komfortbedienung_fh_schliessen_ueber_btle    not active     3
ENG246955-ENG246976-digital_key-komfortbedienung_fh_schliessen_ueber_btle_sonderfunktion    not active     3
ENG246955-ENG246977-digital_key-komfortbedienung_fh_schliessen_ueber_nfc_fahrertuer    not active     3
ENG246955-ENG246991-digital_key-pa_Two_Keys    not active     3
ENG141675-ENG115658-Dimmunt_KL_58xs_PWM-x0    0.00%    6
ENG141675-ENG101574-Dimmunt_KL_58xs_PWM-X1    50.00%    6
ENG141675-ENG99557-Dimmunt_KL_58xs_PWM-X2    100.00%    6
ENG141675-ENG115659-Dimmunt_KL_58xs_PWM-y0    0.00%    6
ENG141675-ENG99777-Dimmunt_KL_58xs_PWM-Y1    50.00%    6
ENG141675-ENG100480-Dimmunt_KL_58xs_PWM-Y2    100.00%    6
ENG125597-ENG126865-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Manuelle_Befuellung_LRD    No Response From Subnet Component    6
ENG125597-ENG126867-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Manueller_Befuellung_Seitenwangen    No Response From Subnet Component    6
ENG125597-ENG126866-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Memorisierte_Befuellung_LRD    No Response From Subnet Component    6
ENG125597-ENG126868-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Memorisierte_Befuellung_Seitenwangen    No Response From Subnet Component    6
ENG125597-ENG125690-Driver_compressor_parameter_multi-contour_seat-s_VerzoegerungszeitKompressoranlauf    No Response From Subnet Component    6
ENG133364-ENG133507-Driver_multi-contour_seat_Error_Mask-ERROR_CODE_PIN    No Response From Subnet Component    6
ENG133364-ENG133526-Driver_multi-contour_seat_Error_Mask-ERROR_EEPROM    No Response From Subnet Component    6
ENG133364-ENG133528-Driver_multi-contour_seat_Error_Mask-ERROR_HW_VERSION    No Response From Subnet Component    6
ENG133364-ENG133500-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB1_CTRL_LEAK    No Response From Subnet Component    6
ENG133364-ENG133499-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB1_LEAK    No Response From Subnet Component    6
ENG133364-ENG133502-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB2_CTRL_LEAK    No Response From Subnet Component    6
ENG133364-ENG133501-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB2_LEAK    No Response From Subnet Component    6
ENG133364-ENG133504-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB3_CTRL_LEAK    No Response From Subnet Component    6
ENG133364-ENG133503-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB3_LEAK    No Response From Subnet Component    6
ENG133364-ENG133511-Driver_multi-contour_seat_Error_Mask-ERROR_PUMP_BLOCK    No Response From Subnet Component    6
ENG133364-ENG133508-Driver_multi-contour_seat_Error_Mask-ERROR_PUMP_OPEN    No Response From Subnet Component    6
ENG133364-ENG133509-Driver_multi-contour_seat_Error_Mask-ERROR_PUMP_SHORT_GND    No Response From Subnet Component    6
ENG133364-ENG133510-Driver_multi-contour_seat_Error_Mask-ERROR_PUMP_SHORT_UB    No Response From Subnet Component    6
ENG133364-ENG133524-Driver_multi-contour_seat_Error_Mask-ERROR_RAM    No Response From Subnet Component    6
ENG133364-ENG133525-Driver_multi-contour_seat_Error_Mask-ERROR_ROM    No Response From Subnet Component    6
ENG133364-ENG133506-Driver_multi-contour_seat_Error_Mask-ERROR_SIDE_CTRL_LEAK    No Response From Subnet Component    6
ENG133364-ENG133505-Driver_multi-contour_seat_Error_Mask-ERROR_SIDE_LEAK    No Response From Subnet Component    6
ENG133364-ENG133531-Driver_multi-contour_seat_Error_Mask-ERROR_SIG_RESPONSE    No Response From Subnet Component    6
ENG133364-ENG133512-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_1    No Response From Subnet Component    6
ENG133364-ENG133515-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_2    No Response From Subnet Component    6
ENG133364-ENG133518-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_3    No Response From Subnet Component    6
ENG133364-ENG133521-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_4    No Response From Subnet Component    6
ENG133364-ENG133513-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_1    No Response From Subnet Component    6
ENG133364-ENG133516-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_2    No Response From Subnet Component    6
ENG133364-ENG133519-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_3    No Response From Subnet Component    6
ENG133364-ENG133522-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_4    No Response From Subnet Component    6
ENG133364-ENG133514-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_1    No Response From Subnet Component    6
ENG133364-ENG133517-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_2    No Response From Subnet Component    6
ENG133364-ENG133520-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_3    No Response From Subnet Component    6
ENG133364-ENG133523-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_4    No Response From Subnet Component    6
ENG133364-ENG133529-Driver_multi-contour_seat_Error_Mask-ERROR_VOLTAGE_HIGH    No Response From Subnet Component    6
ENG133364-ENG133530-Driver_multi-contour_seat_Error_Mask-ERROR_VOLTAGE_LOW    No Response From Subnet Component    6
ENG133364-ENG133527-Driver_multi-contour_seat_Error_Mask-ERROR_WDT    No Response From Subnet Component    6
ENG122925-DWA_Interior_Monitoring_Data_Set_Development    FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF     150
ENG122934-erase_error_table    55 00 00     3
ENG122933-error_mask    0 bit    2
ENG141650-MAS13782-Fernlicht_assistent-Will Beam assistant: responsivity adjustable via BAP    present     6
ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung    AFS: FLA: Fernlicht (GLW:MDF)     6
ENG141650-ENG116639-Fernlicht_assistent-Fernlichtassistent Reset    active     6
ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent    present     6
ENG141650-ENG116641-Fernlicht_assistent-Menuesteuerung Fernlichtassistent Werkseinstellung    present     6
ENG141685-Front_wash_function    10    2
ENG141682-ENG115835-Front_wiper-Adaptives Nachwischen bei SRA    not active     6
ENG141682-ENG142250-Front_wiper-Anfahrzeit_servicestellung    800 ms    6
ENG141682-ENG115836-Front_wiper-Frontwischer Notlaufprogramm    active     6
ENG141682-ENG116614-Front_wiper-Frontwischer Referenzlauf    active     6
ENG141682-ENG154620-Front_wiper-Frontwischer Spannungsanforderung_konfig    Keine_Spannungsanforderung     6
ENG141682-ENG133394-Front_wiper-Frontwischer_Abtauposition    not active     6
ENG141682-ENG141966-Front_wiper-Frontwischertyp    LIN     6
ENG141682-ENG116617-Front_wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung    active     6
ENG141682-ENG116615-Front_wiper-Menuesteuerung Frontwischer    not active     6
ENG141682-ENG154706-Front_wiper-Mindestwaschzeit_Frontwischer    0 ms    6
ENG141682-ENG115771-Front_wiper-Regensensor aktivieren    Deactivating     6
ENG141682-ENG154790-Front_wiper-Timer_DWP_SRA_delay    300 ms    6
ENG141682-ENG116616-Front_wiper-Tippwischen mit erhoehter Wischfrequenz    active     6
ENG141682-ENG116618-Front_wiper-Traenenwischen Front Status    not active     6
ENG141682-ENG115770-Front_wiper-Variable Regensensoraktivierung    not active     6
ENG141682-ENG126844-Front_wiper-Washer_Tipwiping_Variant    not active     6
ENG141682-ENG116613-Front_wiper-Wischer abparken bei Oeffnen der Motorhaube    not active     6
ENG141682-ENG116612-Front_wiper-Wischer stop bei KL15 aus    not active     6
ENG141682-ENG122185-Front_wiper-Wischer Stopp bei Oeffnen der Motorhaube    active     6
ENG99457-ENG117394-Head area heater-blower_speed    1    2
ENG99457-ENG98971-Head area heater-Temperature    -2    2
ENG141645-MAS00211-HW_Verbau-Insufficient brake fluid    installed     8
ENG141645-MAS00212-HW_Verbau-Insufficient washer fluid    not installed     8
ENG141645-MAS00213-HW_Verbau-Insufficient coolant    installed     8
ENG141645-MAS00214-HW_Verbau-Brake pad wear    installed     8
ENG141645-ENG142026-HW_Verbau-Druckklappe    not installed     8
ENG141645-ENG141963-HW_Verbau-Elektrische Laderaumabdeckung aktiv    not active     8
ENG141645-ENG142012-HW_Verbau-Elektrische_Laderaumabdeckung    not installed     8
ENG141645-ENG141952-HW_Verbau-Exterior temp. sensor    installed     8
ENG141645-ENG142005-HW_Verbau-Kontaktschalter_fuer_Motorhaube    installed     8
ENG141645-ENG142186-HW_Verbau-Ladesteckerverriegelung    not installed     8
ENG141645-ENG142036-HW_Verbau-PTC Zuheizer    not installed     8
ENG141645-ENG115809-HW_Verbau-Signalhorn ohne KL15    active     8
ENG141645-ENG142003-HW_Verbau-Status_Tankdeckelverriegelung    not active     8
ENG126651-ENG115658-Kennlinie Abdimmen-x0    No Response From Subnet Component    8
ENG126651-ENG101574-Kennlinie Abdimmen-X1    No Response From Subnet Component    8
ENG126651-ENG115664-Kennlinie Abdimmen-x10    No Response From Subnet Component    8
ENG126651-ENG99557-Kennlinie Abdimmen-X2    No Response From Subnet Component    8
ENG126651-ENG102140-Kennlinie Abdimmen-X3    No Response From Subnet Component    8
ENG126651-ENG102936-Kennlinie Abdimmen-X4    No Response From Subnet Component    8
ENG126651-ENG103548-Kennlinie Abdimmen-X5    No Response From Subnet Component    8
ENG126651-ENG113992-Kennlinie Abdimmen-X6    No Response From Subnet Component    8
ENG126651-ENG115661-Kennlinie Abdimmen-x7    No Response From Subnet Component    8
ENG126651-ENG115662-Kennlinie Abdimmen-x8    No Response From Subnet Component    8
ENG126651-ENG115663-Kennlinie Abdimmen-x9    No Response From Subnet Component    8
ENG126651-ENG115659-Kennlinie Abdimmen-y0    No Response From Subnet Component    8
ENG126651-ENG99777-Kennlinie Abdimmen-Y1    No Response From Subnet Component    8
ENG126651-ENG115668-Kennlinie Abdimmen-y10    No Response From Subnet Component    8
ENG126651-ENG100480-Kennlinie Abdimmen-Y2    No Response From Subnet Component    8
ENG126651-ENG100773-Kennlinie Abdimmen-Y3    No Response From Subnet Component    8
ENG126651-ENG100631-Kennlinie Abdimmen-Y4    No Response From Subnet Component    8
ENG126651-ENG102174-Kennlinie Abdimmen-Y5    No Response From Subnet Component    8
ENG126651-ENG113993-Kennlinie Abdimmen-Y6    No Response From Subnet Component    8
ENG126651-ENG115665-Kennlinie Abdimmen-y7    No Response From Subnet Component    8
ENG126651-ENG115666-Kennlinie Abdimmen-y8    No Response From Subnet Component    8
ENG126651-ENG115667-Kennlinie Abdimmen-y9    No Response From Subnet Component    8
ENG141660-ENG115658-Kennlinie_sLWR_Soll-x0    100.00%    30
ENG141660-ENG101574-Kennlinie_sLWR_Soll-X1    100.00%    30
ENG141660-ENG99557-Kennlinie_sLWR_Soll-X2    100.00%    30
ENG141660-ENG102140-Kennlinie_sLWR_Soll-X3    100.00%    30
ENG141660-ENG102936-Kennlinie_sLWR_Soll-X4    83.00%    30
ENG141660-ENG103548-Kennlinie_sLWR_Soll-X5    67.00%    30
ENG141660-ENG113992-Kennlinie_sLWR_Soll-X6    50.00%    30
ENG141660-ENG115661-Kennlinie_sLWR_Soll-x7    33    30
ENG141660-ENG115662-Kennlinie_sLWR_Soll-x8    17.00%    30
ENG141660-ENG115663-Kennlinie_sLWR_Soll-x9    0.00%    30
ENG141660-ENG115659-Kennlinie_sLWR_Soll-y0    58.50%    30
ENG141660-ENG99777-Kennlinie_sLWR_Soll-Y1    58.50%    30
ENG141660-ENG100480-Kennlinie_sLWR_Soll-Y2    58.50%    30
ENG141660-ENG100773-Kennlinie_sLWR_Soll-Y3    58.50%    30
ENG141660-ENG100631-Kennlinie_sLWR_Soll-Y4    54.50%    30
ENG141660-ENG102174-Kennlinie_sLWR_Soll-Y5    49.50%    30
ENG141660-ENG113993-Kennlinie_sLWR_Soll-Y6    46.50%    30
ENG141660-ENG115665-Kennlinie_sLWR_Soll-y7    35.50%    30
ENG141660-ENG115666-Kennlinie_sLWR_Soll-y8    31.50%    30
ENG141660-ENG115667-Kennlinie_sLWR_Soll-y9    20.00%    30
ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0    maximize     16
ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0    maximize     16
ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0    maximize     16
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0    0    16
ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0    0    16
ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0    0    16
ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0    0    16
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0    00     16
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0    00     16
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0    not active     16
ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0    Always     16
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0    not active     16
ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0    not active     16
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0    not active     16
ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0    not active     16
ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0    not active     16
ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0    not active     16
ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0    not active     16
ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0    not active     16
ENG141657-ENG116167-Leuchte 35 LED Warnblinktaster C48-Dimming Direction CD 15    maximize     16
ENG141657-ENG116171-Leuchte 35 LED Warnblinktaster C48-Dimming Direction EF 15    maximize     16
ENG141657-ENG116175-Leuchte 35 LED Warnblinktaster C48-Dimming Direction GH 15    maximize     16
ENG141657-ENG116162-Leuchte 35 LED Warnblinktaster C48-Dimmwert AB 15    100    16
ENG141657-ENG116166-Leuchte 35 LED Warnblinktaster C48-Dimmwert CD 15    0    16
ENG141657-ENG116170-Leuchte 35 LED Warnblinktaster C48-Dimmwert EF 15    0    16
ENG141657-ENG116174-Leuchte 35 LED Warnblinktaster C48-Dimmwert GH 15    0    16
ENG141657-ENG116159-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 15    63    16
ENG141657-ENG116566-Leuchte 35 LED Warnblinktaster C48-Lampendefektbitposition 15    00     16
ENG141657-ENG116157-Leuchte 35 LED Warnblinktaster C48-Lasttyp 15    41 - LED Kleinleistung     16
ENG141657-ENG116163-Leuchte 35 LED Warnblinktaster C48-Lichtansteuerung HD AB 15    Always     16
ENG141657-ENG116160-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion A 15    Warnblinktaster_Suchbeleuchtung     16
ENG141657-ENG116161-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion B 15    not active     16
ENG141657-ENG116164-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion C 15    not active     16
ENG141657-ENG116165-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion D 15    not active     16
ENG141657-ENG116168-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion E 15    not active     16
ENG141657-ENG116169-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion F 15    not active     16
ENG141657-ENG116172-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion G 15    not active     16
ENG141657-ENG116173-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion H 15    not active     16
ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10    maximize     16
ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10    maximize     16
ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10    maximize     16
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10    127    16
ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10    0    16
ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10    0    16
ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10    0    16
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10    1E     16
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10    37    16
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10    2 - Shutter: Diagnosesensierung für 'LED low'     16
ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10    Always     16
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10    Left high beam     16
ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10    Lichthupe generell     16
ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10    not active     16
ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10    not active     16
ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10    not active     16
ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10    not active     16
ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10    not active     16
ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10    not active     16
ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11    maximize     16
ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11    maximize     16
ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11    maximize     16
ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11    127    16
ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11    0    16
ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11    0    16
ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11    0    16
ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11    1F     16
ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11    41    16
ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11    2 - Shutter: Diagnosesensierung für 'LED low'     16
ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11    Always     16
ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11    Right high beam     16
ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11    Lichthupe generell     16
ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11    not active     16
ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11    not active     16
ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11    not active     16
ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11    not active     16
ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11    not active     16
ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11    not active     16
ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12    maximize     16
ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12    maximize     16
ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12    maximize     16
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12    127    16
ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12    0    16
ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12    0    16
ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12    0    16
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12    22    16
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12    38    16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12    6 - LED Lichtmodul     16
ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12    Always     16
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12    Nebellicht links     16
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12    Abblendlicht links     16
ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12    not active     16
ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12    not active     16
ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12    not active     16
ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12    not active     16
ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12    not active     16
ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12    not active     16
ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13    maximize     16
ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13    maximize     16
ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13    maximize     16
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13    127    16
ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13    0    16
ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13    0    16
ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13    0    16
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13    23    16
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13    42    16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13    6 - LED Lichtmodul     16
ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13    Always     16
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13    Abblendlicht links     16
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13    Abblendlicht rechts     16
ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13    not active     16
ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13    not active     16
ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13    not active     16
ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13    not active     16
ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13    not active     16
ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13    not active     16
ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16    maximize     16
ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16    maximize     16
ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16    maximize     16
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16    127    16
ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16    0    16
ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16    127    16
ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16    0    16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16    36    16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16    00     16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16    43 - allgemeine LED     16
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16    only_if_closed     16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16    Blinken links Hellphase     16
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16    Parking light right     16
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16    not active     16
ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16    not active     16
ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16    not active     16
ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16    not active     16
ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16    not active     16
ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16    not active     16
ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17    maximize     16
ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17    maximize     16
ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17    maximize     16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17    127    16
ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17    0    16
ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17    0    16
ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17    0    16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17    35    16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17    00     16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17    43 - allgemeine LED     16
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17    only_if_closed     16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17    Blinken rechts Hellphase     16
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17    Parklicht links (beidseitiges Parklicht aktiviert li & re)     16
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17    not active     16
ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17    not active     16
ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17    not active     16
ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17    not active     16
ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17    not active     16
ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17    not active     16
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18    maximize     16
ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18    maximize     16
ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18    maximize     16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18    127    16
ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18    0    16
ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18    0    16
ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18    0    16
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18    16    16
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18    08     16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18    38 - LED Blinkleuchten     16
ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18    Always     16
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18    Blinken links Hellphase     16
ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18    not active     16
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18    not active     16
ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18    not active     16
ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18    not active     16
ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18    not active     16
ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18    not active     16
ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18    not active     16
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19    maximize     16
ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19    maximize     16
ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19    maximize     16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19    127    16
ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19    0    16
ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19    0    16
ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19    0    16
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19    18    16
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19    18    16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19    38 - LED Blinkleuchten     16
ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19    Always     16
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19    Blinken rechts Hellphase     16
ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19    not active     16
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19    not active     16
ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19    not active     16
ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19    not active     16
ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19    not active     16
ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19    not active     16
ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19    not active     16
ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1    maximize     16
ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1    maximize     16
ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1    maximize     16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1    0    16
ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1    0    16
ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1    0    16
ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1    0    16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1    00     16
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1    00     16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1    not active     16
ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1    Always     16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1    not active     16
ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1    not active     16
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1    not active     16
ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1    not active     16
ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1    not active     16
ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1    not active     16
ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1    not active     16
ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1    not active     16
ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20    maximize     16
ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20    maximize     16
ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20    maximize     16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20    127    16
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20    0    16
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20    0    16
ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20    0    16
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20    2B     16
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20    09     16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20    34 - LED Bremsleuchten     16
ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20    Always     16
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20    Brake lamp     16
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20    not active     16
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20    not active     16
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20    not active     16
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20    not active     16
ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20    not active     16
ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20    not active     16
ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20    not active     16
ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21    maximize     16
ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21    maximize     16
ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21    maximize     16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21    127    16
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21    0    16
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21    0    16
ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21    0    16
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21    2D     16
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21    19    16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21    34 - LED Bremsleuchten     16
ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21    Always     16
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21    Brake lamp     16
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21    not active     16
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21    not active     16
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21    not active     16
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21    not active     16
ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21    not active     16
ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21    not active     16
ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21    not active     16
ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22    maximize     16
ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22    maximize     16
ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22    maximize     16
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22    127    16
ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22    0    16
ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22    0    16
ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22    0    16
ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22    2C     16
ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22    29    16
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22    42 - LED dritte Bremsleuchte     16
ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22    Always     16
ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22    Brake lamp     16
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22    Quittierungsfunktion 1     16
ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22    not active     16
ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22    not active     16
ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22    not active     16
ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22    not active     16
ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22    not active     16
ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22    not active     16
ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23    maximize     16
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23    maximize     16
ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23    maximize     16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23    127    16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23    0    16
ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23    0    16
ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23    0    16
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23    29    16
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23    0A     16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23    43 - allgemeine LED     16
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23    Always     16
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23    Parklicht links (beidseitiges Parklicht aktiviert li & re)     16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23    not active     16
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23    not active     16
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23    not active     16
ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23    not active     16
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23    not active     16
ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23    not active     16
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24    minimize     16
ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24    maximize     16
ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24    maximize     16
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24    127    16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24    0    16
ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24    0    16
ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24    0    16
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24    2A     16
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24    1A     16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24    43 - allgemeine LED     16
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24    Always     16
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24    Right high beam     16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24    not active     16
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24    not active     16
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24    not active     16
ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24    not active     16
ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24    not active     16
ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24    not active     16
ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25    maximize     16
ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25    maximize     16
ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25    maximize     16
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25    127    16
ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25    0    16
ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25    0    16
ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25    0    16
ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25    30    16
ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25    28    16
ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25    43 - allgemeine LED     16
ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25    Always     16
ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25    not active     16
ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25    not active     16
ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25    not active     16
ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25    not active     16
ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25    not active     16
ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25    not active     16
ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25    not active     16
ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26    maximize     16
ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26    maximize     16
ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26    maximize     16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26    127    16
ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26    0    16
ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26    0    16
ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26    0    16
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26    2E     16
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26    0C     16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26    43 - allgemeine LED     16
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26    only_if_closed     16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26    Nebelschlusslicht wenn kein Anhaenger gesteckt und Rechtsverkehr     16
ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26    not active     16
ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26    not active     16
ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26    not active     16
ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26    not active     16
ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26    not active     16
ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26    not active     16
ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26    not active     16
ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27    maximize     16
ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27    maximize     16
ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27    maximize     16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27    0    16
ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27    0    16
ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27    0    16
ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27    0    16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27    00     16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27    00     16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27    not active     16
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27    Always     16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27    not active     16
ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27    not active     16
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27    not active     16
ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27    not active     16
ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27    not active     16
ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27    not active     16
ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27    not active     16
ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27    not active     16
ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28    maximize     16
ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28    maximize     16
ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28    maximize     16
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28    127    16
ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28    0    16
ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28    0    16
ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28    0    16
ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28    31    16
ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28    0B     16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28    43 - allgemeine LED     16
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28    only_if_closed     16
ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28    Rueckfahrlicht     16
ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28    not active     16
ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28    not active     16
ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28    not active     16
ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28    not active     16
ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28    not active     16
ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28    not active     16
ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28    not active     16
ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29    maximize     16
ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29    maximize     16
ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29    maximize     16
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29    127    16
ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29    0    16
ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29    0    16
ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29    0    16
ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29    32    16
ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29    1B     16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29    43 - allgemeine LED     16
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29    only_if_closed     16
ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29    Rueckfahrlicht     16
ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29    not active     16
ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29    not active     16
ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29    not active     16
ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29    not active     16
ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29    not active     16
ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29    not active     16
ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29    not active     16
ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2    maximize     16
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2    maximize     16
ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2    maximize     16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2    0    16
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2    0    16
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2    0    16
ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2    0    16
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2    00     16
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2    00     16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2    not active     16
ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2    Always     16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2    not active     16
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2    not active     16
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2    not active     16
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2    not active     16
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2    not active     16
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2    not active     16
ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2    not active     16
ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2    not active     16
ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30    maximize     16
ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30    maximize     16
ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30    maximize     16
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30    89    16
ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30    0    16
ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30    0    16
ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30    0    16
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30    02     16
ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30    00     16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30    36 - LED Kleinleistung     16
ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30    Always     16
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30    Footwell lamp     16
ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30    not active     16
ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30    not active     16
ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30    not active     16
ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30    not active     16
ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30    not active     16
ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30    not active     16
ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30    not active     16
ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31    maximize     16
ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31    maximize     16
ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31    maximize     16
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31    0    16
ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31    0    16
ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31    0    16
ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31    0    16
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31    00     16
ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31    00     16
ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31    not active     16
ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31    Always     16
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31    not active     16
ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31    not active     16
ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31    not active     16
ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31    not active     16
ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31    not active     16
ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31    not active     16
ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31    not active     16
ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31    not active     16
ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32    maximize     16
ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32    maximize     16
ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32    maximize     16
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32    0    16
ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32    0    16
ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32    0    16
ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32    0    16
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32    00     16
ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32    00     16
ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32    not active     16
ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32    Always     16
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32    not active     16
ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32    not active     16
ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32    not active     16
ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32    not active     16
ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32    not active     16
ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32    not active     16
ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32    not active     16
ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32    not active     16
ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33    maximize     16
ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33    maximize     16
ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33    maximize     16
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33    0    16
ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33    0    16
ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33    0    16
ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33    0    16
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33    00     16
ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33    00     16
ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33    not active     16
ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33    Always     16
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33    not active     16
ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33    not active     16
ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33    not active     16
ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33    not active     16
ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33    not active     16
ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33    not active     16
ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33    not active     16
ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33    not active     16
ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34    maximize     16
ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34    maximize     16
ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34    maximize     16
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34    0    16
ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34    0    16
ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34    0    16
ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34    0    16
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34    00     16
ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34    00     16
ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34    not active     16
ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34    Always     16
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34    not active     16
ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34    not active     16
ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34    not active     16
ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34    not active     16
ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34    not active     16
ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34    not active     16
ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34    not active     16
ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34    not active     16
ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3    maximize     16
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3    maximize     16
ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3    maximize     16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3    100    16
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3    0    16
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3    0    16
ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3    0    16
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3    00     16
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3    00     16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3    4 - LED Tagfahrlichtmodul Signal     16
ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3    Always     16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3    Daytime running lamps     16
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3    not active     16
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3    not active     16
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3    not active     16
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3    not active     16
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3    not active     16
ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3    not active     16
ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3    not active     16
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4    maximize     16
ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4    maximize     16
ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4    maximize     16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4    127    16
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4    0    16
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4    0    16
ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4    0    16
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4    20    16
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4    3A     16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4    4 - LED Tagfahrlichtmodul Signal     16
ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4    Always     16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4    Daytime running lamps     16
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4    Abblendlicht links     16
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4    not active     16
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4    not active     16
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4    not active     16
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4    not active     16
ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4    not active     16
ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4    not active     16
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5    maximize     16
ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5    maximize     16
ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5    maximize     16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5    127    16
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5    0    16
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5    0    16
ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5    0    16
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5    21    16
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5    44    16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5    4 - LED Tagfahrlichtmodul Signal     16
ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5    Always     16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5    Daytime running lamps     16
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5    Abblendlicht rechts     16
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5    not active     16
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5    not active     16
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5    not active     16
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5    not active     16
ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5    not active     16
ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5    not active     16
ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6    maximize     16
ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6    maximize     16
ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6    maximize     16
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6    127    16
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6    0    16
ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6    0    16
ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6    0    16
ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6    1A     16
ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6    36    16
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6    5 - LED Abblendlicht     16
ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6    Always     16
ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6    Abblendlicht links     16
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6    Lichthupe generell     16
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6    not active     16
ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6    not active     16
ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6    not active     16
ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6    not active     16
ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6    not active     16
ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6    not active     16
ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7    maximize     16
ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7    maximize     16
ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7    maximize     16
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7    127    16
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7    0    16
ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7    0    16
ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7    0    16
ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7    1B     16
ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7    40    16
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7    5 - LED Abblendlicht     16
ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7    Always     16
ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7    Abblendlicht rechts     16
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7    Lichthupe generell     16
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7    not active     16
ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7    not active     16
ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7    not active     16
ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7    not active     16
ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7    not active     16
ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7    not active     16
ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8    maximize     16
ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8    maximize     16
ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8    maximize     16
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8    127    16
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8    127    16
ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8    0    16
ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8    0    16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8    4B     16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8    44    16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8    5 - LED Abblendlicht     16
ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8    Always     16
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8    Versorgungsbedarf der LCM Module     16
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8    not active     16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8    Parking light right     16
ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8    not active     16
ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8    not active     16
ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8    not active     16
ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8    not active     16
ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9    maximize     16
ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9    maximize     16
ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9    maximize     16
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9    127    16
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9    127    16
ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9    0    16
ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9    0    16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9    49    16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9    3A     16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9    5 - LED Abblendlicht     16
ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9    Always     16
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9    Versorgungsbedarf der LCM Module     16
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9    not active     16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9    Parklicht links (beidseitiges Parklicht aktiviert li & re)     16
ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9    not active     16
ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9    not active     16
ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9    not active     16
ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9    not active     16
ENG141661-Leuchtenkonfiguration_Aussenlich_Heck    26 08 00 16 02 00 7F 00 00 00 00 00 00 00 00 00 26 18 00 18 04 00 7F 00 00 00 00 00 00 00 00 00 22 09 00 2B 18 00 7F 00 00 00 00 00 00 00 00 00 22 19 00 2D 18 00 7F 00 00 00 00 00 00 00 00 00 2A 29 00 2C 18 24 7F 00 00 00 00 00 00 00 00 00 2B 0A 00 29 08 09 7F 00 00 00 00 00 00 00 00 00 2B 1A 00 2A 08 0E 7F 00 00 80 00 00 00 00 00 00 2B 28 00 30 08 00 7F 00 00 00 00 00 00 00 00 00 2B 0C 00 2E 1B 00 FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2B 0B 00 31 19 00 FF 00 00 00 00 00 00 00 00 00 2B 1B 00 32 19 00 FF 00 00 00 00 00 00 00 00 00     192
ENG141662-Leuchtenkonfiguration_Sonstiges    2B 00 00 36 02 0A FF 00 00 00 00 00 7F 00 00 00 2B 00 00 35 04 09 FF 00 00 00 00 00 00 00 00 00 24 00 00 02 2B 00 59 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 29 00 00 63 4C 00 64 00 00 00 00 00 00 00 00 00     128
ENG141658-ENG142197-Leuchtweitenregulierung-1_Sensor_LWR    2-Sensor LWR     62
ENG141658-ENG142219-Leuchtweitenregulierung-Achsabstand_des_Fahrzeuges    0 mm    62
ENG141658-ENG142201-Leuchtweitenregulierung-Aktivierung_LWR_Fehlerlampe    active     62
ENG141658-ENG142211-Leuchtweitenregulierung-Ansteuerung_obere_grenze    90.00%    62
ENG141658-ENG142210-Leuchtweitenregulierung-Ansteuerung_untere_grenze    10.00%    62
ENG141658-ENG154591-Leuchtweitenregulierung-Delay_DC_Motor_Versorgung    -114.3 ms    62
ENG141658-ENG142209-Leuchtweitenregulierung-diagnose_soll_toleranz    15%    62
ENG141658-ENG142203-Leuchtweitenregulierung-Entprellung_Fehlerlampe    10.0 s    62
ENG141658-ENG142214-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_1    -8.00 mm/%    62
ENG141658-ENG142216-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_2    -8.00 mm/%    62
ENG141658-ENG154599-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_3    -8.00 mm/%    62
ENG141658-ENG142213-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_1    -8.00 mm/%    62
ENG141658-ENG142215-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_2    -8.00 mm/%    62
ENG141658-ENG154600-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_3    -8.00 mm/%    62
ENG141658-ENG142198-Leuchtweitenregulierung-Fahrwerk_Variante    Variante_2     62
ENG141658-ENG142204-Leuchtweitenregulierung-Fail_Safe_sLWR    0.00%    62
ENG141658-ENG142223-Leuchtweitenregulierung-fFiltEinf    0.00 Hz    62
ENG141658-ENG142212-Leuchtweitenregulierung-Lineare_Abbildung    normal     62
ENG141658-ENG142202-Leuchtweitenregulierung-Logik_PWM_Signal    Negative     62
ENG141658-ENG154702-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_1    0 mm    62
ENG141658-ENG154703-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_2    0 mm    62
ENG141658-ENG154704-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_3    0 mm    62
ENG141658-ENG154705-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_4    0 mm    62
ENG141658-ENG142220-Leuchtweitenregulierung-lwr_lFzg_Sw_Abstand    0 mm    62
ENG141658-ENG142221-Leuchtweitenregulierung-lwr_lFzg_Sw_Hoehe    0 mm    62
ENG141658-ENG142226-Leuchtweitenregulierung-lwr_pwm_obere_schwelle    95.00%    62
ENG141658-ENG142225-Leuchtweitenregulierung-lwr_pwm_untere_schwelle    2.50%    62
ENG141658-ENG142227-Leuchtweitenregulierung-max_v_slwr    255 km/h    62
ENG141658-ENG142222-Leuchtweitenregulierung-pa_fDynFiltStatLwr    100 Hz    62
ENG141658-ENG142224-Leuchtweitenregulierung-pa_fFiltSwNeigung    0.00 Hz    62
ENG141658-ENG142200-Leuchtweitenregulierung-Quelle_Hoehenwerte    BCM     62
ENG141658-ENG142042-Leuchtweitenregulierung-sensor_headlight_range_control_installed    NOT-DEFINED     62
ENG141658-ENG142199-Leuchtweitenregulierung-sLWR_bei_Abblendlicht    not active     62
ENG141658-ENG142208-Leuchtweitenregulierung-sLWR_Hysterese    20.00%    62
ENG141658-ENG154776-Leuchtweitenregulierung-sLWR_nach_Motorstart    not active     62
ENG141658-ENG142207-Leuchtweitenregulierung-sLWR_SW_Grad    0.0 %/s    62
ENG141658-ENG142206-Leuchtweitenregulierung-sLWR_Touristenlicht    80.00%    62
ENG141658-ENG142196-Leuchtweitenregulierung-sLWR_verbaut    Potentiometer     62
ENG141658-ENG142205-Leuchtweitenregulierung-Zyklus_sLWR    0.00 s    62
ENG246957-ENG246963-Lichttaster-Anzeigezeit_LTM_PopUp1    2.0 s    7
ENG246957-ENG246964-Lichttaster-Anzeigezeit_LTM_PopUp1_lang    10 s    7
ENG246957-ENG246965-Lichttaster-Beleuchtung_Auto_LED_bei_Nebelfunktion    active     7
ENG246957-ENG246966-Lichttaster-Beleuchtung_LTM_Auto_LED_58xt_logik    active     7
ENG246957-ENG246978-Lichttaster-Licht_anforderung_FAS    Nicht_verbaut     7
ENG246957-ENG246979-Lichttaster-Licht_anforderung_Pilopark    not active     7
ENG246957-ENG246980-Lichttaster-Licht_Reaktivierungs_grenze    100 m    7
ENG246957-ENG246981-Lichttaster-Lichttastermodul    lds     7
ENG246957-ENG246982-Lichttaster-LTM_Anzeige_Config    00000001      7
ENG246957-ENG246983-Lichttaster-LTM_Beleuchtung_Geschwindigkeits_Schwelle    30 km/h    7
ENG246957-ENG246984-Lichttaster-LTM_BGL_Geschwindigkeitsabhängig    not active     7
ENG246957-ENG246985-Lichttaster-LTM_BGL_Geschwindigkeitsabhängig_Parameter    active     7
ENG246957-ENG246986-Lichttaster-LTM_BGL_Wegabhängig    active     7
ENG246957-ENG246987-Lichttaster-LTM_GlobalOFF_Geschwindigkeitsabhängig    not active     7
ENG246957-ENG246988-Lichttaster-LTM_GlobalOFF_Geschwindigkeitsabhängig_Parameter    active     7
ENG246957-ENG246989-Lichttaster-LTM_GlobalOFF_Wegabhängig    active     7
ENG246957-ENG246990-Lichttaster-LTM_GlobalOFF_Zündungsabhängig    not active     7
ENG126648-MAS10452-LIN-Mirrormode-Data bus LIN 1    not active     1
ENG126648-MAS10453-LIN-Mirrormode-Data bus LIN 2    not active     1
ENG126648-MAS10454-LIN-Mirrormode-Data bus LIN 3    not active     1
ENG126648-MAS12782-LIN-Mirrormode-Data bus LIN 4    not active     1
ENG126648-MAS12783-LIN-Mirrormode-Data bus LIN 5    not active     1
ENG126648-MAS12784-LIN-Mirrormode-Data bus LIN 6    not active     1
ENG126648-ENG118465-LIN-Mirrormode-mirror_mode_typ    not active     1
ENG153727-ENG154566-LIN-SMLS_konfig_1-blinker_entprellen    40 ms    26
ENG153727-ENG154578-LIN-SMLS_konfig_1-blinker_gra_entprellen    40 ms    26
ENG153727-ENG154579-LIN-SMLS_konfig_1-blinker_sperrzeit    100 ms    26
ENG153727-ENG154597-LIN-SMLS_konfig_1-erkennung_fahrt    10 ms    26
ENG153727-ENG154618-LIN-SMLS_konfig_1-fas_entprellen    40 ms    26
ENG153727-ENG154624-LIN-SMLS_konfig_1-grahebel_entprellen    40 ms    26
ENG153727-ENG154634-LIN-SMLS_konfig_1-grenze_v    1 km/h    26
ENG153727-ENG154686-LIN-SMLS_konfig_1-hupe_entprellen    40 ms    26
ENG153727-ENG154690-LIN-SMLS_konfig_1-hupe_indien_entprellen    500 ms    26
ENG153727-ENG154692-LIN-SMLS_konfig_1-k_i    0.04    26
ENG153727-ENG154693-LIN-SMLS_konfig_1-k_i_offset    4 °C    26
ENG153727-ENG154694-LIN-SMLS_konfig_1-k_p    13.00%    26
ENG153727-ENG154695-LIN-SMLS_konfig_1-leistung_lrh    110 W    26
ENG153727-ENG154699-LIN-SMLS_konfig_1-lrh_entprellen    40 ms    26
ENG153727-ENG154713-LIN-SMLS_konfig_1-pwm_lrh    25 Hz    26
ENG153727-ENG154773-LIN-SMLS_konfig_1-s_NWDF_spg    0    26
ENG153727-ENG154777-LIN-SMLS_konfig_1-soll_0    39 °C    26
ENG153727-ENG154778-LIN-SMLS_konfig_1-soll_1    43 °C    26
ENG153727-ENG154779-LIN-SMLS_konfig_1-soll_2    47 °C    26
ENG153727-ENG154786-LIN-SMLS_konfig_1-speedlimiter_entprellen    40 ms    26
ENG153727-ENG154788-LIN-SMLS_konfig_1-temlenkradheizung_aus    50 °C    26
ENG153727-ENG154804-LIN-SMLS_konfig_1-verriegelt_entprellen    40 ms    26
ENG153727-ENG246995-LIN-SMLS_konfig_1-w_zss_direktansteuerung    0 ms    26
ENG153727-ENG154811-LIN-SMLS_konfig_1-wischer_entprellen    40 ms    26
ENG153727-ENG154823-LIN-SMLS_konfig_1-wischer_intervall_entprellen    40 ms    26
ENG153727-ENG154824-LIN-SMLS_konfig_1-wischer_winterstellung    60 s    26
ENG153727-ENG154830-LIN-SMLS_konfig_1-zeit_temperatur_statisch_lrh    60 s    26
ENG153728-IDE00329-LIN-SMLS_konfig_2-Buttons for multi-function display    not installed     2
ENG153728-IDE02694-LIN-SMLS_konfig_2-Horn operation    Always     2
ENG153728-IDE02711-LIN-SMLS_konfig_2-Rear wiper    installed     2
ENG153728-IDE02745-LIN-SMLS_konfig_2-Ignition Switch Key Lock Solenoid    not installed     2
ENG153728-MAS00128-LIN-SMLS_konfig_2-Distance Regulation    not installed     2
ENG153728-MAS00242-LIN-SMLS_konfig_2-Driver assistance systems button    not installed     2
ENG153728-MAS05091-LIN-SMLS_konfig_2-CCS Switch    not installed     2
ENG153728-MAS06090-LIN-SMLS_konfig_2-CCS on turn signal switch    not installed     2
ENG153728-MAS06091-LIN-SMLS_konfig_2-Contact bounce suppression for signal horn    not active     2
ENG153728-MAS08540-LIN-SMLS_konfig_2-reading P locked    not active     2
ENG153728-ENG154465-LIN-SMLS_konfig_2-diagnosis limitation    not active     2
ENG153728-ENG154623-LIN-SMLS_konfig_2-gra_grahebel_2_st    not installed     2
ENG153728-ENG154461-LIN-SMLS_konfig_2-speed_limiter_button    not installed     2
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0    0.00%    12
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1    5.00%    12
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2    50.00%    12
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3    75.00%    12
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4    110    12
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5    126.5    12
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0    0.00%    12
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1    6.00%    12
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2    16.00%    12
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3    30.00%    12
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4    60.00%    12
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5    100.00%    12
ENG141659-ENG115658-lwr_ofs_RSw_Ah1S-x0    -5.00%    20
ENG141659-ENG101574-lwr_ofs_RSw_Ah1S-X1    -5.00%    20
ENG141659-ENG99557-lwr_ofs_RSw_Ah1S-X2    -5.00%    20
ENG141659-ENG102140-lwr_ofs_RSw_Ah1S-X3    -5.00%    20
ENG141659-ENG102936-lwr_ofs_RSw_Ah1S-X4    -5.00%    20
ENG141659-ENG115659-lwr_ofs_RSw_Ah1S-y0    -5    20
ENG141659-ENG99777-lwr_ofs_RSw_Ah1S-Y1    -5    20
ENG141659-ENG100480-lwr_ofs_RSw_Ah1S-Y2    -5    20
ENG141659-ENG100773-lwr_ofs_RSw_Ah1S-Y3    -5    20
ENG141659-ENG100631-lwr_ofs_RSw_Ah1S-Y4    -5    20
ENG133365-ENG133451-Multikontursitz_BFS_Wildmoser-Differenzdruck_Toleranzband    No Response From Subnet Component    20
ENG133365-ENG133447-Multikontursitz_BFS_Wildmoser-Leckage_Fehlerschwelle_Druck    No Response From Subnet Component    20
ENG133365-ENG133453-Multikontursitz_BFS_Wildmoser-Nachentlueftzeit_LRD_mitte    No Response From Subnet Component    20
ENG133365-ENG133452-Multikontursitz_BFS_Wildmoser-Nachentlueftzeit_LRD_oben    No Response From Subnet Component    20
ENG133365-ENG133454-Multikontursitz_BFS_Wildmoser-Nachentlueftzeit_LRD_unten    No Response From Subnet Component    20
ENG133365-ENG133455-Multikontursitz_BFS_Wildmoser-Nachentlueftzeit_Seitenwangen    No Response From Subnet Component    20
ENG133365-ENG133448-Multikontursitz_BFS_Wildmoser-Nachregelung_PWM_1    No Response From Subnet Component    20
ENG133365-ENG133449-Multikontursitz_BFS_Wildmoser-Nachregelung_PWM_2    No Response From Subnet Component    20
ENG133365-ENG133450-Multikontursitz_BFS_Wildmoser-Nachregelung_PWM_3    No Response From Subnet Component    20
ENG133365-ENG133446-Multikontursitz_BFS_Wildmoser-Schwellwert_Temperaturkompensation    No Response From Subnet Component    20
ENG133362-ENG133451-Multikontursitz_FS_Wildmoser-Differenzdruck_Toleranzband    No Response From Subnet Component    20
ENG133362-ENG133447-Multikontursitz_FS_Wildmoser-Leckage_Fehlerschwelle_Druck    No Response From Subnet Component    20
ENG133362-ENG133453-Multikontursitz_FS_Wildmoser-Nachentlueftzeit_LRD_mitte    No Response From Subnet Component    20
ENG133362-ENG133452-Multikontursitz_FS_Wildmoser-Nachentlueftzeit_LRD_oben    No Response From Subnet Component    20
ENG133362-ENG133454-Multikontursitz_FS_Wildmoser-Nachentlueftzeit_LRD_unten    No Response From Subnet Component    20
ENG133362-ENG133455-Multikontursitz_FS_Wildmoser-Nachentlueftzeit_Seitenwangen    No Response From Subnet Component    20
ENG133362-ENG133448-Multikontursitz_FS_Wildmoser-Nachregelung_PWM_1    No Response From Subnet Component    20
ENG133362-ENG133449-Multikontursitz_FS_Wildmoser-Nachregelung_PWM_2    No Response From Subnet Component    20
ENG133362-ENG133450-Multikontursitz_FS_Wildmoser-Nachregelung_PWM_3    No Response From Subnet Component    20
ENG133362-ENG133446-Multikontursitz_FS_Wildmoser-Schwellwert_Temperaturkompensation    No Response From Subnet Component    20
ENG122979-ENG141954-Networking-A/C electronics    installed     8
ENG122979-ENG141968-Networking-Anhaengeranschlussgeraet    not installed     8
ENG122979-ENG141974-Networking-Bremsen_Steuergeraet    installed     8
ENG122979-ENG141953-Networking-Getriebesteuergeraet    installed     8
ENG122979-ENG99457-Networking-Head area heater    not installed     8
ENG122979-ENG142040-Networking-Kunden_spezifisches_Funktions_SG    not installed     8
ENG124714-ENG142044-OCU-DWA_push    not active     8
ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare    not active     8
ENG124714-ENG246970-OCU-IAA -Nutzer_management    not installed     8
ENG124714-OCU-    not installed     8
ENG124714-ENG142261-OCU-Remote HuF Abbruch    20 km/h    8
ENG124714-ENG142262-OCU-Remote HuF Hupfrequenz    3 Hz    8
ENG124714-ENG133391-OCU-Remote Lock Unlock Timer s1    80 s    8
ENG124714-ENG133392-OCU-Remote Lock Unlock Timer s3    2000 ms    8
ENG124714-ENG125657-OCU-Remote_Unlock_Lock    not_active     8
ENG125598-ENG125667-Passenger_massage_program_1_Intensity_1-EE_pMax_LM_MSG_Px_Iy    No Response From Subnet Component    8
ENG125598-ENG125691-Passenger_massage_program_1_Intensity_1-EE_pMax_LO_MSG_Px_I    No Response From Subnet Component    8
ENG125598-ENG125668-Passenger_massage_program_1_Intensity_1-EE_pMax_LU_MSG_Px_Iy    No Response From Subnet Component    8
ENG125598-ENG125673-Passenger_massage_program_1_Intensity_1-EE_tEnt_LM_MSG_Px_Iy    No Response From Subnet Component    8
ENG125598-ENG125672-Passenger_massage_program_1_Intensity_1-EE_tEnt_LO_MSG_Px_Iy    No Response From Subnet Component    8
ENG125598-ENG125674-Passenger_massage_program_1_Intensity_1-EE_tEnt_LU_MSG_Px_Iy    No Response From Subnet Component    8
ENG125598-ENG125670-Passenger_massage_program_1_Intensity_1-EE_tHalte_LM_MSG_Px_Iy    No Response From Subnet Component    8
ENG125598-ENG125669-Passenger_massage_program_1_Intensity_1-EE_tHalte_LO_MSG_Px_Iy    No Response From Subnet Component    8
ENG125598-ENG125671-Passenger_massage_program_1_Intensity_1-EE_tHalte_LU_MSG_Px_Iy    No Response From Subnet Component    8
ENG125598-ENG125676-Passenger_massage_program_1_Intensity_1-EE_tWarte_LM_MSG_Px_Iy    No Response From Subnet Component    8
ENG125598-ENG125675-Passenger_massage_program_1_Intensity_1-EE_tWarte_LO_MSG_Px_Iy    No Response From Subnet Component    8
ENG125598-ENG125677-Passenger_massage_program_1_Intensity_1-EE_tWarte_LU_MSG_Px_Iy    No Response From Subnet Component    8
ENG125598-ENG125664-Passenger_massage_program_1_Intensity_1-EE_Upumpe_LM_MSG_Px_Iy    No Response From Subnet Component    8
ENG125598-ENG125663-Passenger_massage_program_1_Intensity_1-EE_Upumpe_LO_MSG_Px_Iy    No Response From Subnet Component    8
ENG125598-ENG125665-Passenger_massage_program_1_Intensity_1-EE_Upumpe_LU_MSG_Px_Iy    No Response From Subnet Component    8
ENG125599-ENG125667-Passenger_massage_program_1_Intensity_2-EE_pMax_LM_MSG_Px_Iy    No Response From Subnet Component    8
ENG125599-ENG125666-Passenger_massage_program_1_Intensity_2-EE_pMax_LO_MSG_Px_Iy    No Response From Subnet Component    8
ENG125599-ENG125668-Passenger_massage_program_1_Intensity_2-EE_pMax_LU_MSG_Px_Iy    No Response From Subnet Component    8
ENG125599-ENG125673-Passenger_massage_program_1_Intensity_2-EE_tEnt_LM_MSG_Px_Iy    No Response From Subnet Component    8
ENG125599-ENG125672-Passenger_massage_program_1_Intensity_2-EE_tEnt_LO_MSG_Px_Iy    No Response From Subnet Component    8
ENG125599-ENG125674-Passenger_massage_program_1_Intensity_2-EE_tEnt_LU_MSG_Px_Iy    No Response From Subnet Component    8
ENG125599-ENG125670-Passenger_massage_program_1_Intensity_2-EE_tHalte_LM_MSG_Px_Iy    No Response From Subnet Component    8
ENG125599-ENG125669-Passenger_massage_program_1_Intensity_2-EE_tHalte_LO_MSG_Px_Iy    No Response From Subnet Component    8
ENG125599-ENG125671-Passenger_massage_program_1_Intensity_2-EE_tHalte_LU_MSG_Px_Iy    No Response From Subnet Component    8
ENG125599-ENG125676-Passenger_massage_program_1_Intensity_2-EE_tWarte_LM_MSG_Px_Iy    No Response From Subnet Component    8
ENG125599-ENG125675-Passenger_massage_program_1_Intensity_2-EE_tWarte_LO_MSG_Px_Iy    No Response From Subnet Component    8
ENG125599-ENG125677-Passenger_massage_program_1_Intensity_2-EE_tWarte_LU_MSG_Px_Iy    No Response From Subnet Component    8
ENG125599-ENG125664-Passenger_massage_program_1_Intensity_2-EE_Upumpe_LM_MSG_Px_Iy    No Response From Subnet Component    8
ENG125599-ENG125663-Passenger_massage_program_1_Intensity_2-EE_Upumpe_LO_MSG_Px_Iy    No Response From Subnet Component    8
ENG125599-ENG125665-Passenger_massage_program_1_Intensity_2-EE_Upumpe_LU_MSG_Px_Iy    No Response From Subnet Component    8
ENG125600-ENG125667-Passenger_massage_program_1_Intensity_3-EE_pMax_LM_MSG_Px_Iy    No Response From Subnet Component    8
ENG125600-ENG125666-Passenger_massage_program_1_Intensity_3-EE_pMax_LO_MSG_Px_Iy    No Response From Subnet Component    8
ENG125600-ENG125668-Passenger_massage_program_1_Intensity_3-EE_pMax_LU_MSG_Px_Iy    No Response From Subnet Component    8
ENG125600-ENG125673-Passenger_massage_program_1_Intensity_3-EE_tEnt_LM_MSG_Px_Iy    No Response From Subnet Component    8
ENG125600-ENG125672-Passenger_massage_program_1_Intensity_3-EE_tEnt_LO_MSG_Px_Iy    No Response From Subnet Component    8
ENG125600-ENG125674-Passenger_massage_program_1_Intensity_3-EE_tEnt_LU_MSG_Px_Iy    No Response From Subnet Component    8
ENG125600-ENG125670-Passenger_massage_program_1_Intensity_3-EE_tHalte_LM_MSG_Px_Iy    No Response From Subnet Component    8
ENG125600-ENG125669-Passenger_massage_program_1_Intensity_3-EE_tHalte_LO_MSG_Px_Iy    No Response From Subnet Component    8
ENG125600-ENG125671-Passenger_massage_program_1_Intensity_3-EE_tHalte_LU_MSG_Px_Iy    No Response From Subnet Component    8
ENG125600-ENG125676-Passenger_massage_program_1_Intensity_3-EE_tWarte_LM_MSG_Px_Iy    No Response From Subnet Component    8
ENG125600-ENG125675-Passenger_massage_program_1_Intensity_3-EE_tWarte_LO_MSG_Px_Iy    No Response From Subnet Component    8
ENG125600-ENG125677-Passenger_massage_program_1_Intensity_3-EE_tWarte_LU_MSG_Px_Iy    No Response From Subnet Component    8
ENG125600-ENG125692-Passenger_massage_program_1_Intensity_3-EE_Upumpe_LM_MSG_Px_I    No Response From Subnet Component    8
ENG125600-ENG125663-Passenger_massage_program_1_Intensity_3-EE_Upumpe_LO_MSG_Px_Iy    No Response From Subnet Component    8
ENG125600-ENG125665-Passenger_massage_program_1_Intensity_3-EE_Upumpe_LU_MSG_Px_Iy    No Response From Subnet Component    8
ENG125601-ENG125667-Passenger_massage_program_2_Intensity_1-EE_pMax_LM_MSG_Px_Iy    No Response From Subnet Component    8
ENG125601-ENG125666-Passenger_massage_program_2_Intensity_1-EE_pMax_LO_MSG_Px_Iy    No Response From Subnet Component    8
ENG125601-ENG125668-Passenger_massage_program_2_Intensity_1-EE_pMax_LU_MSG_Px_Iy    No Response From Subnet Component    8
ENG125601-ENG125673-Passenger_massage_program_2_Intensity_1-EE_tEnt_LM_MSG_Px_Iy    No Response From Subnet Component    8
ENG125601-ENG125672-Passenger_massage_program_2_Intensity_1-EE_tEnt_LO_MSG_Px_Iy    No Response From Subnet Component    8
ENG125601-ENG125674-Passenger_massage_program_2_Intensity_1-EE_tEnt_LU_MSG_Px_Iy    No Response From Subnet Component    8
ENG125601-ENG125670-Passenger_massage_program_2_Intensity_1-EE_tHalte_LM_MSG_Px_Iy    No Response From Subnet Component    8
ENG125601-ENG125669-Passenger_massage_program_2_Intensity_1-EE_tHalte_LO_MSG_Px_Iy    No Response From Subnet Component    8
ENG125601-ENG125671-Passenger_massage_program_2_Intensity_1-EE_tHalte_LU_MSG_Px_Iy    No Response From Subnet Component    8
ENG125601-ENG125676-Passenger_massage_program_2_Intensity_1-EE_tWarte_LM_MSG_Px_Iy    No Response From Subnet Component    8
ENG125601-ENG125675-Passenger_massage_program_2_Intensity_1-EE_tWarte_LO_MSG_Px_Iy    No Response From Subnet Component    8
ENG125601-ENG125677-Passenger_massage_program_2_Intensity_1-EE_tWarte_LU_MSG_Px_Iy    No Response From Subnet Component    8
ENG125601-ENG125664-Passenger_massage_program_2_Intensity_1-EE_Upumpe_LM_MSG_Px_Iy    No Response From Subnet Component    8
ENG125601-ENG125663-Passenger_massage_program_2_Intensity_1-EE_Upumpe_LO_MSG_Px_Iy    No Response From Subnet Component    8
ENG125601-ENG125665-Passenger_massage_program_2_Intensity_1-EE_Upumpe_LU_MSG_Px_Iy    No Response From Subnet Component    8
ENG125602-ENG125667-Passenger_massage_program_2_Intensity_2-EE_pMax_LM_MSG_Px_Iy    No Response From Subnet Component    8
ENG125602-ENG125666-Passenger_massage_program_2_Intensity_2-EE_pMax_LO_MSG_Px_Iy    No Response From Subnet Component    8
ENG125602-ENG125668-Passenger_massage_program_2_Intensity_2-EE_pMax_LU_MSG_Px_Iy    No Response From Subnet Component    8
ENG125602-ENG125673-Passenger_massage_program_2_Intensity_2-EE_tEnt_LM_MSG_Px_Iy    No Response From Subnet Component    8
ENG125602-ENG125672-Passenger_massage_program_2_Intensity_2-EE_tEnt_LO_MSG_Px_Iy    No Response From Subnet Component    8
ENG125602-ENG125674-Passenger_massage_program_2_Intensity_2-EE_tEnt_LU_MSG_Px_Iy    No Response From Subnet Component    8
ENG125602-ENG125670-Passenger_massage_program_2_Intensity_2-EE_tHalte_LM_MSG_Px_Iy    No Response From Subnet Component    8
ENG125602-ENG125669-Passenger_massage_program_2_Intensity_2-EE_tHalte_LO_MSG_Px_Iy    No Response From Subnet Component    8
ENG125602-ENG125671-Passenger_massage_program_2_Intensity_2-EE_tHalte_LU_MSG_Px_Iy    No Response From Subnet Component    8
ENG125602-ENG125676-Passenger_massage_program_2_Intensity_2-EE_tWarte_LM_MSG_Px_Iy    No Response From Subnet Component    8
ENG125602-ENG125675-Passenger_massage_program_2_Intensity_2-EE_tWarte_LO_MSG_Px_Iy    No Response From Subnet Component    8
ENG125602-ENG125677-Passenger_massage_program_2_Intensity_2-EE_tWarte_LU_MSG_Px_Iy    No Response From Subnet Component    8
ENG125602-ENG125664-Passenger_massage_program_2_Intensity_2-EE_Upumpe_LM_MSG_Px_Iy    No Response From Subnet Component    8
ENG125602-ENG125663-Passenger_massage_program_2_Intensity_2-EE_Upumpe_LO_MSG_Px_Iy    No Response From Subnet Component    8
ENG125602-ENG125665-Passenger_massage_program_2_Intensity_2-EE_Upumpe_LU_MSG_Px_Iy    No Response From Subnet Component    8
ENG133367-ENG133507-Passenger_multi-contour_seat_Error_Mask-ERROR_CODE_PIN    No Response From Subnet Component    8
ENG133367-ENG133526-Passenger_multi-contour_seat_Error_Mask-ERROR_EEPROM    No Response From Subnet Component    8
ENG133367-ENG133528-Passenger_multi-contour_seat_Error_Mask-ERROR_HW_VERSION    No Response From Subnet Component    8
ENG133367-ENG133500-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB1_CTRL_LEAK    No Response From Subnet Component    8
ENG133367-ENG133499-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB1_LEAK    No Response From Subnet Component    8
ENG133367-ENG133502-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB2_CTRL_LEAK    No Response From Subnet Component    8
ENG133367-ENG133501-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB2_LEAK    No Response From Subnet Component    8
ENG133367-ENG133504-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB3_CTRL_LEAK    No Response From Subnet Component    8
ENG133367-ENG133503-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB3_LEAK    No Response From Subnet Component    8
ENG133367-ENG133511-Passenger_multi-contour_seat_Error_Mask-ERROR_PUMP_BLOCK    No Response From Subnet Component    8
ENG133367-ENG133508-Passenger_multi-contour_seat_Error_Mask-ERROR_PUMP_OPEN    No Response From Subnet Component    8
ENG133367-ENG133509-Passenger_multi-contour_seat_Error_Mask-ERROR_PUMP_SHORT_GND    No Response From Subnet Component    8
ENG133367-ENG133510-Passenger_multi-contour_seat_Error_Mask-ERROR_PUMP_SHORT_UB    No Response From Subnet Component    8
ENG133367-ENG133524-Passenger_multi-contour_seat_Error_Mask-ERROR_RAM    No Response From Subnet Component    8
ENG133367-ENG133525-Passenger_multi-contour_seat_Error_Mask-ERROR_ROM    No Response From Subnet Component    8
ENG133367-ENG133506-Passenger_multi-contour_seat_Error_Mask-ERROR_SIDE_CTRL_LEAK    No Response From Subnet Component    8
ENG133367-ENG133505-Passenger_multi-contour_seat_Error_Mask-ERROR_SIDE_LEAK    No Response From Subnet Component    8
ENG133367-ENG133531-Passenger_multi-contour_seat_Error_Mask-ERROR_SIG_RESPONSE    No Response From Subnet Component    8
ENG133367-ENG133512-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_1    No Response From Subnet Component    8
ENG133367-ENG133515-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_2    No Response From Subnet Component    8
ENG133367-ENG133518-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_3    No Response From Subnet Component    8
ENG133367-ENG133521-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_4    No Response From Subnet Component    8
ENG133367-ENG133513-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_1    No Response From Subnet Component    8
ENG133367-ENG133516-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_2    No Response From Subnet Component    8
ENG133367-ENG133519-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_3    No Response From Subnet Component    8
ENG133367-ENG133522-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_4    No Response From Subnet Component    8
ENG133367-ENG133514-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_1    No Response From Subnet Component    8
ENG133367-ENG133517-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_2    No Response From Subnet Component    8
ENG133367-ENG133520-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_3    No Response From Subnet Component    8
ENG133367-ENG133523-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_4    No Response From Subnet Component    8
ENG133367-ENG133529-Passenger_multi-contour_seat_Error_Mask-ERROR_VOLTAGE_HIGH    No Response From Subnet Component    8
ENG133367-ENG133530-Passenger_multi-contour_seat_Error_Mask-ERROR_VOLTAGE_LOW    No Response From Subnet Component    8
ENG133367-ENG133527-Passenger_multi-contour_seat_Error_Mask-ERROR_WDT    No Response From Subnet Component    8
ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar    active     16
ENG98831-ENG133401-Personalization-Anzahl_Benutzerkonten    4    16
ENG98831-ENG133402-Personalization-Automatische_ Schluesselzuordnung    not active     16
ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar    active     16
ENG98831-ENG126848-Personalization-Personalisierung_aktiv    active     16
ENG98831-ENG141994-Personalization-Personalisierung_Profilfunkion    profiles_active     16
ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar    active     16
ENG98831-ENG142030-Personalization-Profil_Variante    Konto (v. 1.x)     16
ENG98831-ENG133404-Personalization-PSO_FSG_Setup2_Bit_1    active     16
ENG98831-ENG133405-Personalization-PSO_FSG_Setup2_Bit_2    active     16
ENG98831-ENG133406-Personalization-PSO_FSG_Setup2_Bit_3    active     16
ENG98831-ENG133407-Personalization-PSO_FSG_Setup2_Bit_4    not active     16
ENG249801-ENG249833-PKW-Schiebetueren-CAN_TSG_HBFS_verbaut    No     4
ENG249801-ENG249834-PKW-Schiebetueren-CAN_TSG_HFS_verbaut    No     4
ENG249801-ENG249925-PKW-Schiebetueren-PKW_Schiebetuer_HBFS_nachverriegeln    No     4
ENG249801-ENG249926-PKW-Schiebetueren-PKW_Schiebetuer_HBFS_verbaut    No     4
ENG249801-ENG249927-PKW-Schiebetueren-PKW_Schiebetuer_HFS_nachverriegeln    No     4
ENG249801-ENG249928-PKW-Schiebetueren-PKW_Schiebetuer_HFS_verbaut    No     4
ENG249801-ENG251921-PKW-Schiebetueren-SBT_Entr_im_Zustand_entriegelt    No     4
ENG249801-ENG249939-PKW-Schiebetueren-STSG_HBFS_verbaut    No     4
ENG249801-ENG249940-PKW-Schiebetueren-STSG_HFS_verbaut    No     4
ENG141646-MAS01065-Querschnitts_funktionen-Brand    VW     5
ENG141646-ENG141980-Querschnitts_funktionen-Bedien_und_Anzeigeprotokoll    active     5
ENG141646-ENG116624-Querschnitts_funktionen-CAN Wecken bei Softtouchbetaetigung    active     5
ENG141646-ENG141967-Querschnitts_funktionen-Codierungsabsicherung    not active     5
ENG141646-ENG142028-Querschnitts_funktionen-Fahrgeschwindigkeit_aus_ESP_21    active     5
ENG141646-ENG142187-Querschnitts_funktionen-Hardware_Eingang_Drucktankklappenstatus    Pin A31     5
ENG141646-ENG154685-Querschnitts_funktionen-Hupe    Sollspannungsanforderung 13.5     5
ENG141646-ENG115810-Querschnitts_funktionen-Klemmenfehler auf CAN ausgeben    active     5
ENG141646-ENG142015-Querschnitts_funktionen-Personalisierungsuebernahme    not_installed     5
ENG141646-ENG141983-Querschnitts_funktionen-Schnittstelle_TrackingSystem    not active     5
ENG141646-ENG141964-Querschnitts_funktionen-Steering alignment    Right     5
ENG141646-ENG141965-Querschnitts_funktionen-Traffic side    Left     5
ENG249802-ENG249933-Rear_view_camera_wash-RVC_Speed_Hysteresis    5 km/h    8
ENG249802-ENG249934-Rear_view_camera_wash-RVC_Speed_max    50 km/h    8
ENG249802-ENG249935-Rear_view_camera_wash-RVC_Time_cleaning_Pumpe_active_BCM    1.5 s    8
ENG249802-ENG249936-Rear_view_camera_wash-RVC_Waschen_HMI    not active     8
ENG249802-ENG249937-Rear_view_camera_wash-RVC_Wash    not installed     8
ENG125614-Reset_Blower_1_Backrest_Left    No Response From Subnet Component    8
ENG125615-Reset_Blower_1_Backrest_Right    No Response From Subnet Component    8
ENG125613-Reset_Blower_1_Cushion_Left    No Response From Subnet Component    8
ENG125616-Reset_Blower_1_Cushion_Right    No Response From Subnet Component    8
ENG122927-RLS_close_glazing    2.0 s    1
ENG122928-ENG121637-RLS_lights_for_autobahn-p_t_autobahn_delay_off    120 s    3
ENG122928-ENG121636-RLS_lights_for_autobahn-p_t_autobahn_delay_on    10 s    3
ENG122928-ENG121635-RLS_lights_for_autobahn-p_v_autobahn_off    65 km/h    3
ENG122928-ENG121634-RLS_lights_for_autobahn-p_v_autobahn_on    140 km/h    3
ENG122931-ENG123004-RLS_Lights_on_at_Rain-p_lx_regenlichtschwelle    6000 lx    2
ENG122931-ENG123002-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_high    12    2
ENG122931-ENG123003-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_low    6    2
ENG122931-ENG123005-RLS_Lights_on_at_Rain-p_t_regenlicht    30 s    2
ENG122929-RLS_LIN_Communication    4 s    1
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn    200 lx    1
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day    500 lx    1
ENG122930-RLS_tunel_gateway_recognize    5 s    1
ENG122935-RLS_Washer_Front    15 s    1
ENG122926-RLS_wiper_position_parking    15 s    1
ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung    10    10
ENG115729-ENG141949-Scheinwerferreinigung-Headlamp washer system    not installed     10
ENG115729-ENG249900-Scheinwerferreinigung-Init Versatz Betaetigungen Frontwaschanlage pro SRA Aktivierung    0    10
ENG115729-ENG115769-Scheinwerferreinigung-SRA bei Waschwassermangel    active     10
ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit    2000 ms    10
ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit    400 ms    10
ENG115729-ENG116611-Scheinwerferreinigung-SRA Pausenzeit    0 ms    10
ENG115729-ENG116610-Scheinwerferreinigung-SRA Verzoegerungszeit    0 ms    10
ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit    400 ms    10
ENG115729-ENG154424-Scheinwerferreinigung-Waschen    Keine_Spannungsanforderung     10
ENG153742-ENG154567-SMLS_konfig_entw-blinker_err_el_kurzschluss    200 ms    48
ENG153742-ENG154568-SMLS_konfig_entw-blinker_err_el_unterbrechung    1000 ms    48
ENG153742-ENG154569-SMLS_konfig_entw-blinker_err_fernlicht_haengt_aus    5000 ms    48
ENG153742-ENG154570-SMLS_konfig_entw-blinker_err_fernlicht_haengt_ein    300 s    48
ENG153742-ENG154571-SMLS_konfig_entw-blinker_err_gra_haengt_aus    5000 ms    48
ENG153742-ENG154572-SMLS_konfig_entw-blinker_err_gra_haengt_ein    300 s    48
ENG153742-ENG154573-SMLS_konfig_entw-blinker_err_lichthupe_haengt_aus    5000 ms    48
ENG153742-ENG154574-SMLS_konfig_entw-blinker_err_lichthupe_haengt_ein    300 s    48
ENG153742-ENG154575-SMLS_konfig_entw-blinker_err_unplausibel    200 ms    48
ENG153742-ENG154576-SMLS_konfig_entw-blinker_err_weckkontakthaengt_aus    5000 ms    48
ENG153742-ENG154577-SMLS_konfig_entw-blinker_err_weckkontakthaengt_ein    5000 ms    48
ENG153742-ENG154594-SMLS_konfig_entw-entprellung_unplausibel    400 ms    48
ENG153742-ENG154595-SMLS_konfig_entw-entprellzeit_ueberspannung    90000 ms    48
ENG153742-ENG154596-SMLS_konfig_entw-entprellzeit_unterspannung    90000 ms    48
ENG153742-ENG154622-SMLS_konfig_entw-gra_ea_error    200 ms    48
ENG153742-ENG154625-SMLS_konfig_entw-grahebel_err_el_kurzschluss    200 ms    48
ENG153742-ENG154626-SMLS_konfig_entw-grahebel_err_el_unterbrechung    1000 ms    48
ENG153742-ENG154627-SMLS_konfig_entw-grahebel_err_gra_haengt_aus    5000 ms    48
ENG153742-ENG154628-SMLS_konfig_entw-grahebel_err_gra_haengt_ein    300 s    48
ENG153742-ENG154629-SMLS_konfig_entw-grahebel_err_unplausibel    200 ms    48
ENG153742-ENG154687-SMLS_konfig_entw-hupe_err_hinweis    2000 ms    48
ENG153742-ENG154688-SMLS_konfig_entw-hupe_err_hupe_haengt_aus    5000 ms    48
ENG153742-ENG154689-SMLS_konfig_entw-hupe_err_hupe_haengt_ein    60 s    48
ENG153742-ENG154700-SMLS_konfig_entw-lrh_kurzschluss_entprellen    20 ms    48
ENG153742-ENG154701-SMLS_konfig_entw-lrh_unterbrechung_entprellen    100 ms    48
ENG153742-ENG154701-SMLS_konfig_entw-lrh_unterbrechung_entprellen    60 s    48
ENG153742-ENG154701-SMLS_konfig_entw-lrh_unterbrechung_entprellen    50 ms    48
ENG153742-ENG154707-SMLS_konfig_entw-n_fehler_verriegelt    250    48
ENG153742-ENG154780-SMLS_konfig_entw-spannung_obere_schwelle    16.5 V    48
ENG153742-ENG154781-SMLS_konfig_entw-spannung_obere_schwelle_funkt_einschr    15.5 V    48
ENG153742-ENG154782-SMLS_konfig_entw-spannung_untere_schwelle    8.5 V    48
ENG153742-ENG154783-SMLS_konfig_entw-spannung_untere_schwelle_funkt_einschr    8.5 V    48
ENG153742-ENG154805-SMLS_konfig_entw-verriegelt_err_el_kurzschluss    200 ms    48
ENG153742-ENG154806-SMLS_konfig_entw-verriegelt_err_unplausibel_aus    200 ms    48
ENG153742-ENG154807-SMLS_konfig_entw-verriegelt_err_unplausibel_ein    2000 ms    48
ENG153742-ENG154808-SMLS_konfig_entw-verriegelt_err_unplausibel_in_parkposition_aus    1000 ms    48
ENG153742-ENG154809-SMLS_konfig_entw-verriegelt_err_unplausibel_in_parkposition_ein    30 s    48
ENG153742-ENG154812-SMLS_konfig_entw-wischer_err_el_kurzschluss    200 ms    48
ENG153742-ENG154813-SMLS_konfig_entw-wischer_err_el_unterbrechung    1000 ms    48
ENG153742-ENG154814-SMLS_konfig_entw-wischer_err_intervallpoti_haengt_aus    5.0 s    48
ENG153742-ENG154815-SMLS_konfig_entw-wischer_err_intervallpoti_haengt_ein    300 s    48
ENG153742-ENG154816-SMLS_konfig_entw-wischer_err_mfa_haengt_aus    5000 ms    48
ENG153742-ENG154817-SMLS_konfig_entw-wischer_err_mfa_haengt_ein    300 s    48
ENG153742-ENG154818-SMLS_konfig_entw-wischer_err_unplausibel    200 ms    48
ENG153742-ENG154819-SMLS_konfig_entw-wischer_err_waschen_haengt_aus    5000 ms    48
ENG153742-ENG154820-SMLS_konfig_entw-wischer_err_waschen_haengt_ein    300 s    48
ENG153742-ENG154821-SMLS_konfig_entw-wischer_err_wischen_haengt_aus    5000 ms    48
ENG153742-ENG154822-SMLS_konfig_entw-wischer_err_wischen_haengt_ein    300 s    48
ENG116588-ENG248517-Sonderfunktionen-Blinkerueberwachug Sonderfunktions-SG    not installed     4
ENG116588-ENG116589-Sonderfunktionen-Signalprioritaet fuer Blinker    MFG     4
ENG116588-Sonderfunktionen-    not enabled     4
ENG116588-ENG141979-Sonderfunktionen-Sonderfunktionen 1    not installed     4
ENG141635-ENG116658-Spiegelverstellung-Funk Spiegelanklappen    active     5
ENG141635-ENG116665-Spiegelverstellung-Funk Spiegelanklappung Modus    by look command via remote control key     5
ENG141635-ENG116660-Spiegelverstellung-Menuesteuerung Funk Spiegel anklappen    active     5
ENG141635-ENG116657-Spiegelverstellung-Menuesteuerung Spiegelabsenkung    active     5
ENG141635-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellung    active     5
ENG141635-ENG126841-Spiegelverstellung-Profilfunktion fuer Anklappung der Aussenspiegel    active     5
ENG141635-ENG126610-Spiegelverstellung-Signalisierung_Spiegelanklappung    active     5
ENG141635-ENG116650-Spiegelverstellung-Spiegelabsenkung bei Rueckwaertsfahrt    active     5
ENG141635-ENG133411-Spiegelverstellung-Spiegelanklappen_bei_Wiederverriegelung    active     5
ENG141635-ENG116656-Spiegelverstellung-Spiegelverstellung Synchron    active     5
ENG153700-ENG154515-Steering Column Switch-Anzahl_fehler_P-verriegelt    250    10
ENG153700-ENG154621-Steering Column Switch-Geschwindigkeitesschwele_erkennung_fahrt_P_plausibel    10 km/h    10
ENG153700-ENG154803-Steering Column Switch-Verbauort_Lenkstockschalter    LIN     10
ENG153700-ENG154828-Steering Column Switch-Zeit_erkennung_fahrt_für_P_plausibel    1000 ms    10
ENG153700-ENG154829-Steering Column Switch-Zeit_t_P-verriegelt_entprellen    40 ms    10
ENG141678-ENG115658-Suchbeleuchtung_58_xs_Bus_Kennlinie-x0    0.0 lx    10
ENG141678-ENG101574-Suchbeleuchtung_58_xs_Bus_Kennlinie-X1    8.0 lx    10
ENG141678-ENG99557-Suchbeleuchtung_58_xs_Bus_Kennlinie-X2    50.0 lx    10
ENG141678-ENG102140-Suchbeleuchtung_58_xs_Bus_Kennlinie-X3    80.0 lx    10
ENG141678-ENG102936-Suchbeleuchtung_58_xs_Bus_Kennlinie-X4    100.0 lx    10
ENG141678-ENG115659-Suchbeleuchtung_58_xs_Bus_Kennlinie-y0    6    10
ENG141678-ENG99777-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y1    6    10
ENG141678-ENG100480-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y2    20    10
ENG141678-ENG100773-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y3    50    10
ENG141678-ENG100631-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y4    100    10
ENG141679-ENG115658-Suchbeleuchtung_58xt_Bus_Kennlinie-x0    0.0 lx    10
ENG141679-ENG101574-Suchbeleuchtung_58xt_Bus_Kennlinie-X1    8.0 lx    10
ENG141679-ENG99557-Suchbeleuchtung_58xt_Bus_Kennlinie-X2    50.0 lx    10
ENG141679-ENG102140-Suchbeleuchtung_58xt_Bus_Kennlinie-X3    80.0 lx    10
ENG141679-ENG102936-Suchbeleuchtung_58xt_Bus_Kennlinie-X4    100.0 lx    10
ENG141679-ENG115659-Suchbeleuchtung_58xt_Bus_Kennlinie-y0    6    10
ENG141679-ENG99777-Suchbeleuchtung_58xt_Bus_Kennlinie-Y1    6    10
ENG141679-ENG100480-Suchbeleuchtung_58xt_Bus_Kennlinie-Y2    20    10
ENG141679-ENG100773-Suchbeleuchtung_58xt_Bus_Kennlinie-Y3    50    10
ENG141679-ENG100631-Suchbeleuchtung_58xt_Bus_Kennlinie-Y4    100    10
ENG141666-ENG115658-Suchbeleuchtung_Abdimmen-x0    0 ms    22
ENG141666-ENG101574-Suchbeleuchtung_Abdimmen-X1    200 ms    22
ENG141666-ENG115664-Suchbeleuchtung_Abdimmen-x10    2000 ms    22
ENG141666-ENG99557-Suchbeleuchtung_Abdimmen-X2    400 ms    22
ENG141666-ENG102140-Suchbeleuchtung_Abdimmen-X3    600 ms    22
ENG141666-ENG102936-Suchbeleuchtung_Abdimmen-X4    800 ms    22
ENG141666-ENG103548-Suchbeleuchtung_Abdimmen-X5    1000 ms    22
ENG141666-ENG113992-Suchbeleuchtung_Abdimmen-X6    1200 ms    22
ENG141666-ENG115661-Suchbeleuchtung_Abdimmen-x7    1400 ms    22
ENG141666-ENG115662-Suchbeleuchtung_Abdimmen-x8    1600 ms    22
ENG141666-ENG115663-Suchbeleuchtung_Abdimmen-x9    1800 ms    22
ENG141666-ENG115659-Suchbeleuchtung_Abdimmen-y0    100.00%    22
ENG141666-ENG99777-Suchbeleuchtung_Abdimmen-Y1    100.00%    22
ENG141666-ENG115668-Suchbeleuchtung_Abdimmen-y10    0.00%    22
ENG141666-ENG100480-Suchbeleuchtung_Abdimmen-Y2    95.00%    22
ENG141666-ENG100773-Suchbeleuchtung_Abdimmen-Y3    80.00%    22
ENG141666-ENG100631-Suchbeleuchtung_Abdimmen-Y4    40.00%    22
ENG141666-ENG102174-Suchbeleuchtung_Abdimmen-Y5    20.00%    22
ENG141666-ENG113993-Suchbeleuchtung_Abdimmen-Y6    10.00%    22
ENG141666-ENG115665-Suchbeleuchtung_Abdimmen-y7    5.00%    22
ENG141666-ENG115666-Suchbeleuchtung_Abdimmen-y8    3.00%    22
ENG141666-ENG115667-Suchbeleuchtung_Abdimmen-y9    1.00%    22
ENG141663-ENG142240-Suchbeleuchtung_allgemein-Daempfung Abdimmen KL 58xd PWM    0.00 s    21
ENG141663-ENG154582-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xs_PWM    0.00 s    21
ENG141663-ENG154583-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xt_PWM    0.00 s    21
ENG141663-ENG154584-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xd_PWM    0.00 s    21
ENG141663-ENG154585-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xt_PWM    0.00 s    21
ENG141663-ENG141988-Suchbeleuchtung_allgemein-Eingabemedium_Suchbeleuchtung    HMI     21
ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen    1.1 s    21
ENG141663-ENG142241-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Aufdimmen    0.0 s    21
ENG141663-ENG116598-Suchbeleuchtung_allgemein-KL58 Einschalten mit Rampe    not active     21
ENG141663-ENG116599-Suchbeleuchtung_allgemein-KL58 Verriegelungsausschalten    not_active     21
ENG141663-ENG116600-Suchbeleuchtung_allgemein-Lichtsensor wirkt auf Suchbeleuchtung    active     21
ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS    11    21
ENG141663-ENG154712-Suchbeleuchtung_allgemein-PWM_Daempfung_Aufdimmen_KL58xs_PWM    0.00 s    21
ENG141663-ENG115631-Suchbeleuchtung_allgemein-Suchbeleuchtung Festwert    100%    21
ENG141663-ENG142234-Suchbeleuchtung_allgemein-Umgebungs_helligkeit_auswahl    Fotosensor_Kombi     21
ENG141663-ENG115819-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Aktivierung    parking light activated     21
ENG141663-ENG115821-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Faktor    0.1    21
ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert    6.00%    21
ENG141667-ENG115658-Suchbeleuchtung_Fotosensor-x0    0    22
ENG141667-ENG101574-Suchbeleuchtung_Fotosensor-X1    50    22
ENG141667-ENG115664-Suchbeleuchtung_Fotosensor-x10    0    22
ENG141667-ENG99557-Suchbeleuchtung_Fotosensor-X2    100    22
ENG141667-ENG102140-Suchbeleuchtung_Fotosensor-X3    200    22
ENG141667-ENG102936-Suchbeleuchtung_Fotosensor-X4    253    22
ENG141667-ENG103548-Suchbeleuchtung_Fotosensor-X5    0    22
ENG141667-ENG113992-Suchbeleuchtung_Fotosensor-X6    0    22
ENG141667-ENG115661-Suchbeleuchtung_Fotosensor-x7    0    22
ENG141667-ENG115662-Suchbeleuchtung_Fotosensor-x8    0    22
ENG141667-ENG115663-Suchbeleuchtung_Fotosensor-x9    0    22
ENG141667-ENG115659-Suchbeleuchtung_Fotosensor-y0    0 lx    22
ENG141667-ENG99777-Suchbeleuchtung_Fotosensor-Y1    50 lx    22
ENG141667-ENG115668-Suchbeleuchtung_Fotosensor-y10    0 lx    22
ENG141667-ENG100480-Suchbeleuchtung_Fotosensor-Y2    100 lx    22
ENG141667-ENG100773-Suchbeleuchtung_Fotosensor-Y3    200    22
ENG141667-ENG100631-Suchbeleuchtung_Fotosensor-Y4    500    22
ENG141667-ENG102174-Suchbeleuchtung_Fotosensor-Y5    0    22
ENG141667-ENG113993-Suchbeleuchtung_Fotosensor-Y6    0 lx    22
ENG141667-ENG115665-Suchbeleuchtung_Fotosensor-y7    0 lx    22
ENG141667-ENG115666-Suchbeleuchtung_Fotosensor-y8    0 lx    22
ENG141667-ENG115667-Suchbeleuchtung_Fotosensor-y9    0 lx    22
ENG141665-ENG115658-Suchbeleuchtung_Hochdimmen-x0    0 ms    22
ENG141665-ENG101574-Suchbeleuchtung_Hochdimmen-X1    200 ms    22
ENG141665-ENG115664-Suchbeleuchtung_Hochdimmen-x10    2000 ms    22
ENG141665-ENG99557-Suchbeleuchtung_Hochdimmen-X2    400 ms    22
ENG141665-ENG102140-Suchbeleuchtung_Hochdimmen-X3    600 ms    22
ENG141665-ENG102936-Suchbeleuchtung_Hochdimmen-X4    800 ms    22
ENG141665-ENG103548-Suchbeleuchtung_Hochdimmen-X5    1000 ms    22
ENG141665-ENG113992-Suchbeleuchtung_Hochdimmen-X6    1200 ms    22
ENG141665-ENG115661-Suchbeleuchtung_Hochdimmen-x7    1400 ms    22
ENG141665-ENG115662-Suchbeleuchtung_Hochdimmen-x8    1600 ms    22
ENG141665-ENG115663-Suchbeleuchtung_Hochdimmen-x9    1800 ms    22
ENG141665-ENG115659-Suchbeleuchtung_Hochdimmen-y0    0.00%    22
ENG141665-ENG99777-Suchbeleuchtung_Hochdimmen-Y1    1.00%    22
ENG141665-ENG115668-Suchbeleuchtung_Hochdimmen-y10    100.00%    22
ENG141665-ENG100480-Suchbeleuchtung_Hochdimmen-Y2    3.00%    22
ENG141665-ENG100773-Suchbeleuchtung_Hochdimmen-Y3    5.00%    22
ENG141665-ENG100631-Suchbeleuchtung_Hochdimmen-Y4    11.00%    22
ENG141665-ENG102174-Suchbeleuchtung_Hochdimmen-Y5    22.00%    22
ENG141665-ENG113993-Suchbeleuchtung_Hochdimmen-Y6    40.00%    22
ENG141665-ENG115665-Suchbeleuchtung_Hochdimmen-y7    80.00%    22
ENG141665-ENG115666-Suchbeleuchtung_Hochdimmen-y8    95.00%    22
ENG141665-ENG115667-Suchbeleuchtung_Hochdimmen-y9    100.00%    22
ENG141669-ENG115658-Suchbeleuchtung_KL 58xs max-x0    0 lx    8
ENG141669-ENG101574-Suchbeleuchtung_KL 58xs max-X1    8 lx    8
ENG141669-ENG99557-Suchbeleuchtung_KL 58xs max-X2    50 lx    8
ENG141669-ENG102140-Suchbeleuchtung_KL 58xs max-X3    500 lx    8
ENG141669-ENG115659-Suchbeleuchtung_KL 58xs max-y0    100    8
ENG141669-ENG99777-Suchbeleuchtung_KL 58xs max-Y1    100    8
ENG141669-ENG100480-Suchbeleuchtung_KL 58xs max-Y2    100    8
ENG141669-ENG100773-Suchbeleuchtung_KL 58xs max-Y3    100    8
ENG141668-ENG115658-Suchbeleuchtung_KL 58xs min-x0    0 lx    8
ENG141668-ENG101574-Suchbeleuchtung_KL 58xs min-X1    8 lx    8
ENG141668-ENG99557-Suchbeleuchtung_KL 58xs min-X2    50 lx    8
ENG141668-ENG102140-Suchbeleuchtung_KL 58xs min-X3    500 lx    8
ENG141668-ENG115659-Suchbeleuchtung_KL 58xs min-y0    6    8
ENG141668-ENG99777-Suchbeleuchtung_KL 58xs min-Y1    6    8
ENG141668-ENG100480-Suchbeleuchtung_KL 58xs min-Y2    100    8
ENG141668-ENG100773-Suchbeleuchtung_KL 58xs min-Y3    100    8
ENG141674-ENG115658-Suchbeleuchtung_KL_58xd_log_Bus-x0    0.00%    12
ENG141674-ENG101574-Suchbeleuchtung_KL_58xd_log_Bus-X1    6.00%    12
ENG141674-ENG99557-Suchbeleuchtung_KL_58xd_log_Bus-X2    16.00%    12
ENG141674-ENG102140-Suchbeleuchtung_KL_58xd_log_Bus-X3    30.00%    12
ENG141674-ENG102936-Suchbeleuchtung_KL_58xd_log_Bus-X4    60.00%    12
ENG141674-ENG103548-Suchbeleuchtung_KL_58xd_log_Bus-X5    100.00%    12
ENG141674-ENG115659-Suchbeleuchtung_KL_58xd_log_Bus-y0    10    12
ENG141674-ENG99777-Suchbeleuchtung_KL_58xd_log_Bus-Y1    10    12
ENG141674-ENG100480-Suchbeleuchtung_KL_58xd_log_Bus-Y2    100    12
ENG141674-ENG100773-Suchbeleuchtung_KL_58xd_log_Bus-Y3    150    12
ENG141674-ENG100631-Suchbeleuchtung_KL_58xd_log_Bus-Y4    220    12
ENG141674-ENG102174-Suchbeleuchtung_KL_58xd_log_Bus-Y5    253    12
ENG141673-ENG115658-Suchbeleuchtung_KL_58xd_max-x0    0 lx    10
ENG141673-ENG101574-Suchbeleuchtung_KL_58xd_max-X1    8 lx    10
ENG141673-ENG99557-Suchbeleuchtung_KL_58xd_max-X2    200 lx    10
ENG141673-ENG102140-Suchbeleuchtung_KL_58xd_max-X3    300 lx    10
ENG141673-ENG102936-Suchbeleuchtung_KL_58xd_max-X4    500 lx    10
ENG141673-ENG115659-Suchbeleuchtung_KL_58xd_max-y0    16    10
ENG141673-ENG99777-Suchbeleuchtung_KL_58xd_max-Y1    16    10
ENG141673-ENG100480-Suchbeleuchtung_KL_58xd_max-Y2    100    10
ENG141673-ENG100773-Suchbeleuchtung_KL_58xd_max-Y3    100    10
ENG141673-ENG100631-Suchbeleuchtung_KL_58xd_max-Y4    100    10
ENG141672-ENG115658-Suchbeleuchtung_KL_58xd_min-x0    0 lx    10
ENG141672-ENG101574-Suchbeleuchtung_KL_58xd_min-X1    8 lx    10
ENG141672-ENG99557-Suchbeleuchtung_KL_58xd_min-X2    220 lx    10
ENG141672-ENG102140-Suchbeleuchtung_KL_58xd_min-X3    300 lx    10
ENG141672-ENG102936-Suchbeleuchtung_KL_58xd_min-X4    500 lx    10
ENG141672-ENG115659-Suchbeleuchtung_KL_58xd_min-y0    6    10
ENG141672-ENG99777-Suchbeleuchtung_KL_58xd_min-Y1    6    10
ENG141672-ENG100480-Suchbeleuchtung_KL_58xd_min-Y2    100    10
ENG141672-ENG100773-Suchbeleuchtung_KL_58xd_min-Y3    100    10
ENG141672-ENG100631-Suchbeleuchtung_KL_58xd_min-Y4    100    10
ENG141677-ENG115658-Suchbeleuchtung_KL_58xd_PWM-x0    0    12
ENG141677-ENG101574-Suchbeleuchtung_KL_58xd_PWM-X1    10    12
ENG141677-ENG99557-Suchbeleuchtung_KL_58xd_PWM-X2    50    12
ENG141677-ENG102140-Suchbeleuchtung_KL_58xd_PWM-X3    100    12
ENG141677-ENG102936-Suchbeleuchtung_KL_58xd_PWM-X4    220    12
ENG141677-ENG103548-Suchbeleuchtung_KL_58xd_PWM-X5    253    12
ENG141677-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0    2.00%    12
ENG141677-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1    2.00%    12
ENG141677-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2    6.00%    12
ENG141677-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3    10.00%    12
ENG141677-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4    80.00%    12
ENG141677-ENG102174-Suchbeleuchtung_KL_58xd_PWM-Y5    100.00%    12
ENG141670-ENG115658-Suchbeleuchtung_KL_58xt min-x0    0 lx    8
ENG141670-ENG101574-Suchbeleuchtung_KL_58xt min-X1    8 lx    8
ENG141670-ENG99557-Suchbeleuchtung_KL_58xt min-X2    50 lx    8
ENG141670-ENG102140-Suchbeleuchtung_KL_58xt min-X3    500 lx    8
ENG141670-ENG115659-Suchbeleuchtung_KL_58xt min-y0    6    8
ENG141670-ENG99777-Suchbeleuchtung_KL_58xt min-Y1    6    8
ENG141670-ENG100480-Suchbeleuchtung_KL_58xt min-Y2    100    8
ENG141670-ENG100773-Suchbeleuchtung_KL_58xt min-Y3    100    8
ENG141671-ENG115658-Suchbeleuchtung_KL_58xt_max-x0    0 lx    8
ENG141671-ENG101574-Suchbeleuchtung_KL_58xt_max-X1    8 lx    8
ENG141671-ENG99557-Suchbeleuchtung_KL_58xt_max-X2    50 lx    8
ENG141671-ENG102140-Suchbeleuchtung_KL_58xt_max-X3    500 lx    8
ENG141671-ENG115659-Suchbeleuchtung_KL_58xt_max-y0    100    8
ENG141671-ENG99777-Suchbeleuchtung_KL_58xt_max-Y1    100    8
ENG141671-ENG100480-Suchbeleuchtung_KL_58xt_max-Y2    100    8
ENG141671-ENG100773-Suchbeleuchtung_KL_58xt_max-Y3    100    8
ENG141676-ENG115658-Suchbeleuchtung_KL_58xt_PWM-x0    0.00%    6
ENG141676-ENG101574-Suchbeleuchtung_KL_58xt_PWM-X1    50.00%    6
ENG141676-ENG99557-Suchbeleuchtung_KL_58xt_PWM-X2    100.00%    6
ENG141676-ENG115659-Suchbeleuchtung_KL_58xt_PWM-y0    0.00%    6
ENG141676-ENG99777-Suchbeleuchtung_KL_58xt_PWM-Y1    50.00%    6
ENG141676-ENG100480-Suchbeleuchtung_KL_58xt_PWM-Y2    100.00%    6
ENG141680-ENG115658-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-x0    0 lx    12
ENG141680-ENG101574-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X1    200 lx    12
ENG141680-ENG99557-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X2    400 lx    12
ENG141680-ENG102140-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X3    600 lx    12
ENG141680-ENG102936-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X4    800 lx    12
ENG141680-ENG103548-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X5    1020 lx    12
ENG141680-ENG115659-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-y0    0    12
ENG141680-ENG99777-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y1    84    12
ENG141680-ENG100480-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y2    166    12
ENG141680-ENG100773-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y3    250    12
ENG141680-ENG100631-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y4    370    12
ENG141680-ENG102174-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y5    500    12
ENG141664-ENG115633-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x0    0 ms    10
ENG141664-ENG115634-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x1    2000 ms    10
ENG141664-ENG115635-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x2    3000 ms    10
ENG141664-ENG115636-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x3    4000 ms    10
ENG141664-ENG115637-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x4    5100 ms    10
ENG141664-ENG115638-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y0    1.00%    10
ENG141664-ENG115639-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y1    5    10
ENG141664-ENG115640-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y2    15    10
ENG141664-ENG115641-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y3    40    10
ENG141664-ENG115642-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y4    100    10
ENG141632-ENG116647-Sunroof-SAD Komfort oeffnen    active     4
ENG141632-ENG116646-Sunroof-SAD Komfort schliessen    active     4
ENG141632-ENG116645-Sunroof-SAD Richtung Komfortoeffnen    tilting     4
ENG141632-ENG141970-Sunroof-Schiebedachmodul_MD_1    installed     4
ENG141632-ENG141971-Sunroof-Schiebedachmodul_MD_3    installed     4
ENG141632-ENG141972-Sunroof-Schiebedachmodul_MD_Rollo    installed     4
ENG141632-ENG142022-Sunroof-Verortung Schiebedachmodule    CAN     4
ENG141969-ENG249827-UGDO-Anlernblinken    not active     3
ENG141969-ENG249832-UGDO-Bedienfeld    not installed     3
ENG141969-ENG172987-UGDO-ugdo_transmitter    not installed     3
ENG141969-ENG172966-UGDO-ugdo_via_mmi_configurable    not active     3
ENG141634-ENG142013-Verdecksteuergeraet-Cabrio_Verdeck    not_installed     9
ENG141634-ENG116716-Verdecksteuergeraet-Doppelpuls nur Verdeck    active     9
ENG141634-ENG128459-Verdecksteuergeraet-easycloselight_aktiv    not active     9
ENG141634-ENG116718-Verdecksteuergeraet-Heckdeckel sperren bei Verdeckbetrieb    not active     9
ENG141634-ENG142259-Verdecksteuergeraet-Kick_and_close    not installed     9
ENG141634-ENG116711-Verdecksteuergeraet-Komfortbedienung Verdeck global    active     9
ENG141634-ENG122189-Verdecksteuergeraet-Komfortbedienung Verdeck oeffnen    active     9
ENG141634-ENG116712-Verdecksteuergeraet-Komfortbedienung Verdeck schließen    active     9
ENG141634-ENG125654-Verdecksteuergeraet-Nachsaven_nach_Verdecklauf    not active     9
ENG141634-ENG126630-Verdecksteuergeraet-Reichweitenbegrenzung fuer Servoheck schliessen    not active     9
ENG141634-ENG125652-Verdecksteuergeraet-Servoheck Schlossansteuerung    Always     9
ENG141634-ENG126838-Verdecksteuergeraet-Softtouch-Betaetigung senden    Always     9
ENG141634-ENG142011-Verdecksteuergeraet-trunk_lid_conrol_unit    not installed     9
ENG141634-ENG116717-Verdecksteuergeraet-Verdeck mit Schiebedach    not active     9
ENG141634-ENG122191-Verdecksteuergeraet-Verdeck oeffnen via Funkfernbedienung    active     9
ENG141634-ENG122192-Verdecksteuergeraet-Verdeck oeffnen via Kessy    active     9
ENG141634-ENG122190-Verdecksteuergeraet-Verdeck oeffnen via Schliesszylinder    active     9
ENG141634-ENG116714-Verdecksteuergeraet-Verdeck schließen via Funkfernbedienung    active     9
ENG141634-ENG116715-Verdecksteuergeraet-Verdeck schließen via Kessy    active     9
ENG141634-ENG116713-Verdecksteuergeraet-Verdeck schließen via Schließzylinder    active     9
ENG141634-ENG115869-Verdecksteuergeraet-Virtuelles_Pedal    not active     9
ENG141634-ENG126611-Verdecksteuergeraet-virtuelles_pedal_HMI_einstellbar    not active     9
ENG141634-ENG142257-Verdecksteuergeraet-Virtuelles_Pedal_Verbau    not installed     9
ENG141634-ENG246994-Verdecksteuergeraet-Virtuelles_Pedal_Version    Version_1_2     9
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1    00 00     20
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2    00 00     20
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3    00 00     20
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4    00 00     20
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1    00 00     20
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2    00 00     20
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3    00 00     20
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4    00 00     20
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5    00 00     20
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6    00 00     20
ENG249803-ENG249921-Waschen_Parameter-N_RVC_Activation    5    8
ENG249803-ENG249941-Waschen_Parameter-T1_RVC_Treshold    30 s    8
ENG249803-ENG249942-Waschen_Parameter-T2_RVC_Deactivation    180 s    8
ENG116832-ENG126852-Wischgeschwindigkeiten-Dauerwischen Stufe_1 Zyklen pro Minute    40    3
ENG116832-ENG126853-Wischgeschwindigkeiten-Dauerwischen Stufe_2 Zyklen pro Minute    60    3
ENG116832-ENG116699-Wischgeschwindigkeiten-Reduzierte Wischgeschwindigkeit Zyklen pro Minute    30    3
ENG141651-ENG116632-ZV allgemein-Bewusstes Safe mit 2. Betaetigung der FFB    not active     7
ENG141651-ENG133387-ZV allgemein-Deaktivierung_Laderaumschliessung_extern    not active     7
ENG141651-ENG125653-ZV allgemein-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster    active     7
ENG141651-ENG126837-ZV allgemein-Entsafen mit autorisierte Klemme 15 Ein    active     7
ENG141651-ENG115754-ZV allgemein-Funk bei Klemme 15 ein    not active     7
ENG141651-ENG141981-ZV allgemein-Lock_Unlock_Taster_direkt    not installed     7
ENG141651-ENG142019-ZV allgemein-Lock_Unlock_Toggle_Taster    not installed     7
ENG141651-ENG133388-ZV allgemein-LS_Taster_Togglefunktion    not active     7
ENG141651-ENG116633-ZV allgemein-Menuesteuerung Tuerentriegelung    active     7
ENG141651-ENG115755-ZV allgemein-Notschließfunktion    active     7
ENG141651-ENG133389-ZV allgemein-Nutzfahrzeug_Schliessung    not active     7
ENG141651-ENG141957-ZV allgemein-Radio freq.    434.42MHz     7
ENG141651-ENG141958-ZV allgemein-Tankschloss    Bidirectional     7
ENG141651-ENG133390-ZV allgemein-Wiederverriegelung_Laderaum    Freigabe_Softtouch     7
ENG141651-ENG116623-ZV allgemein-ZV Tuerentriegelung    Globale Entriegelung     7
ENG141651-ENG141996-ZV allgemein-ZV_ohne_Safe_Funktion    not installed     7
ENG141654-ENG116628-ZV Autolock-Autolock Autounlock wirkt auf Heck    active     3
ENG141654-ENG116621-ZV Autolock-automatisches Entriegeln    active     3
ENG141654-ENG115756-ZV Autolock-automatisches Verriegeln bei Geschwindigkeit    not active     3
ENG141654-ENG116706-ZV Autolock-Autounlock NAR    not active     3
ENG141654-ENG116622-ZV Autolock-Geschwindigkeitsabhaengige Tankdeckelverriegelung    not active     3
ENG141654-ENG116634-ZV Autolock-Menuesteuerung ZV Autolock-Unlock    adjustable     3
ENG141655-ENG116627-ZV Crash-Heckdeckel-Bedienstellen nachCrash temporaer sperren    active     4
ENG141655-ENG116661-ZV Crash-SAD PreCrash Konturschliessen    active     4
ENG141655-ENG116635-ZV Crash-ZV-Entriegelung nach Seitencrash    not active     4
ENG141653-ENG115759-ZV Heck-Direkter Auswurf des Heckdeckels    active     7
ENG141653-ENG126839-ZV Heck-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang    not active     7
ENG141653-ENG116707-ZV Heck-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster    not active     7
ENG141653-ENG142016-ZV Heck-Heckdeckelentriegelung_HDF_Innentaster    not installed     7
ENG141653-ENG133386-ZV Heck-Heckfreigabe_Ohne_Verzoegerung    not active     7
ENG141653-ENG142245-ZV Heck-Heckoeffnung_ueber_2_Bedienhandlungen    not active     7
ENG141653-ENG141998-ZV Heck-Heckschloss_mit_Vorraste    Yes     7
ENG141653-ENG141995-ZV Heck-Heckschloss_Steuerung    Contact control     7
ENG141653-ENG137162-ZV Heck-Mindestbetaetigung_HDF_Innentaster    0.0 s    7
ENG141653-ENG115761-ZV Heck-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt    not active     7
ENG141653-ENG141982-ZV Heck-Tausch_Tank_Hecktreiberausgang    No     7
ENG141653-ENG115760-ZV Heck-ZV entriegelt auch Heckdeckel    active     7
ENG141653-ENG116629-ZV Heck-ZV Heck nur direkt auswerfen    not active     7
ENG141653-ENG141997-ZV Heck-ZV_Heck_Schlosstyp    1 or 2 notch rear actuator     7
ENG141681-IDE02021-ZV Komfort-Comfort closing    active     8
ENG141681-IDE02022-ZV Komfort-Comfort opening    active     8
ENG141681-ENG141984-ZV Komfort-elektrischer_Fensterheber_hinten    Yes     8
ENG141681-ENG116663-ZV Komfort-Fahrertuerbedienung Fensterheber oeffnen    active     8
ENG141681-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessen    active     8
ENG141681-ENG116662-ZV Komfort-FH SAD Kl15Aus Freigabezeit    600 s    8
ENG141681-ENG116648-ZV Komfort-Freigabenachlauf FH bei Kl 15 aus    active     8
ENG141681-ENG122993-ZV Komfort-Freigabenachlauf FH bei Tueroeffnen abbrechen    not active     8
ENG141681-ENG116652-ZV Komfort-Funk Komfort oeffnen    active     8
ENG141681-ENG116651-ZV Komfort-Funk Komfort schliessen    active     8
ENG141681-ENG115670-ZV Komfort-Komfortbedienung global    active     8
ENG141681-ENG116642-ZV Komfort-Komfortoeffnen nur FH Fahrertuer    not active     8
ENG141681-ENG122994-ZV Komfort-Menuesteuerung Komfortbedienung einstellbar    adjustable     8
ENG141681-ENG122186-ZV Komfort-Menuesteuerung Regenschliessen    not active     8
ENG141681-ENG125656-ZV Komfort-Regenschliessen_art    once     8
ENG141681-ENG125655-ZV Komfort-Regenschliessen_ein_aus    active     8
ENG141681-ENG116643-ZV Komfort-Schliesszylinder Komfort oeffnen    not active     8
ENG141681-ENG116644-ZV Komfort-Schliesszylinder Komfort schliessen    not active     8
ENG141652-ENG141999-ZV Türkonfiguration-Fond_Schloss    2-Motorenschloesser     5
ENG141652-ENG142043-ZV Türkonfiguration-HFT_Invertierung_Drehfallensignal    nicht invertiert     5
ENG141652-ENG142039-ZV Türkonfiguration-Schiebetuer_Kontaktmodul_Beifahrerseite    not installed     5
ENG141652-ENG142038-ZV Türkonfiguration-Schiebetuer_Kontaktmodul_Fahrerseite    not installed     5
ENG141652-ENG142001-ZV Türkonfiguration-Schiebetuer_links    No     5
ENG141652-ENG142002-ZV Türkonfiguration-Schiebetuer_rechts    No     5
ENG141652-ENG142041-ZV Türkonfiguration-Schiebetueren_Crafter    not installed     5
ENG141652-ENG142244-ZV Türkonfiguration-Schiebetuerschloss_direkt_BCM    Driver side     5
ENG141652-ENG116631-ZV Türkonfiguration-Schliessung der Schiebetuer bei geoeffneter Tankklappe    not active     5
ENG141652-ENG142000-ZV Türkonfiguration-Schlosstyp_NAR    No     5
ENG141652-ENG141959-ZV Türkonfiguration-Viertuerer    Yes     5
Elapsed Time: 02:07
wiradjuri
Unverified
Australia
C?ID=597967 (PNG/CB)
So are you gonna help me pleaee
mathi9020010
C?ID=573263
Have you been into a crash? Many things you got problems with are front-related.
  1. AFS Modules have been newly detected and the system tried to register them to the network...
  2. Your ACC Sensor (behind your VW Logo?) is misaligned.
  3. Your A5 Camera has no basic settings, is coded badly. Has it been replaced?
You got Area View and RFK coded, but I cant find them in your Auto-Scan. Correct me if I'm wrong, but the golf does not come with Area View unless you retrofit it.
Your problem with the "Leuchte Channels" (Light system) are the smallest compared with the others -.-!
Primarily because this thread does not belong in the LCode & VCDSToolBox section of this forum, and I'm trying to figure out where it does belong.
If this is a crash repair using the correct factory parts, then I'll move it to Car Repair Support. If you're replaced parts "upgrading" the car, then it will be moved to retrofits.
So you have a choice: Give us the back-story. Tell us how this stuff got to be "incorrect" and let us move this thread to the appropriate section of the forum, or don't, and I'll lock the thread.
wiradjuri
Unverified
Australia
It's hasn't been in a crash cause everything was working fine when. I got the car in may of this year nothing has been replaced the only work that has been done to it is a stage 2 apr tune and full exhaust system everything was working fine until I started playing around with it
wiradjuri
Unverified
Australia
Dr SHeldon your a deadset fucking gronk mate
