So im at the end of this build. After sitting 5 years , running it at least monthly, its time for mechanical. What I want to do is erase all codes (including airbag) put some miles on it and test again. Mods done include replacing the seats ( airbag code) chopping and gluing bolting riveting the kit on, paint stereo. THOUGHTS?
Here is the scan
Here is the scan
Thursday,21,November,2024,14:40:40:48149
VCDS Version: 24.7.1.0 (x64) HEX-V2 CB: 0.4643.5
VIN: 3VWCD21C4YM483293 License Plate:
Mileage: 142820km-88744mi Repair Order:
Chassis Type: 1C - VW New Beetle (1998 > 2010)
Scan: 01 02 03 08 15 17 19 25 29 35 37 39 46 54 56 65 75
Mileage: 142820km-88744miles
Address 01: Engine Labels: 06A-906-032-AVC.lbl
Part No: 06A 906 032 A
Component: 1.8l 5VT NB AT G 3157
Coding: 00003
Shop #: WSC 00066
VCID: 1C660CDE2FB006BAA33-5160
16486 - Mass Air Flow Sensor (G70)
P0102 - 35-00 - Signal too Low
18010 - Power Supply Terminal 30
P1602 - 35-10 - Voltage too Low - Intermittent
17748 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28)
P1340 - 35-00 - Incor. Correlation
16524 - Oxygen (Lambda) Sensor B1 S2
P0140 - 35-10 - No Activity - Intermittent
17606 - Oxygen (Lambda) Sensor Heater Circuit: B1 S2
P1198 - 35-00 - Electrical Malfunction
Readiness: 0110 1101
Address 02: Auto Trans Labels: 01M-927-733.lbl
Part No: 01M 927 733 FB
Component: AG4 Getriebe 01M 4609
Coding: 00000
VCID: 75B0397AECDAF7F27CD-0962
35-10 - - - Intermittent
Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.clb
Part No: 1J0 907 379 AF
Component: ASR 20 IE CAN 0001
Coding: 13204
Shop #: WSC 00066
VCID: 75B0397AECDAF7F27CD-4B1E
16-00 - Signal Outside Specifications
79-00 - Please Check Fault Codes
00283 - ABS Wheel Speed Sensor; Front Left (G47)
16-10 - Signal Outside Specifications - Intermittent
Part No: 6Q0 909 605 A
Component: 06 AIRBAG VW5 0003
Coding: 12342
Shop #: WSC 00066
VCID: 3530F97AAC5AB7F2BCD-4B1E
01217 - Side Airbag Igniter; Driver Side (N199)
32-10 - Resistance Too High - Intermittent
01218 - Side Airbag Igniter; Passenger Side (N200)
Address 17: Instruments Labels: 1C0-920-xx0.lbl
Part No: 1C0 920 901 GX
Component: KOMBI+WEGFAHRS. M73 V07
Coding: 07202
Shop #: WSC 06434
VCID: 78AE304EFBC88A9A67B-4B1E
Subsystem 1 - Part No: Ident
Component: Nr. Wegfahrs.:VWZ5Z0E4272333
Ident.-Nr. Wegfahrs.:VWZ5Z0E4272333
Address 19: CAN Gateway Labels: 6N0-909-901-19.clb
Part No: 6N0 909 901
Component: Gateway K<->CAN V072
Coding: 00007
VCID: 70BE086E93B8D2DAAFB-4B1E
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 AJ
Component: 5X Zentral-SG Komf. 0001
Coding: 00256
Shop #: WSC 00066
VCID: 06524EB6813CEC6A657-4B1E
Subsystem 1 - Part No: 1J2959802C
Component: 5X Tõrsteuerger. FS0002r
Subsystem 2 - Part No: 1J2959801D
Component: 5X Tõrsteuerger. BF0002r
8 Faults Found:
00953 - Interior Light Time limit
25-10 - Unknown Switch Condition - Intermittent
35-00 - -
01358 - Internal Central Locking Switch; Driver Side (E150)
35-00 - -
End----------(Elapsed Time: 03:53, VBatt start/end: 12.6V/12.6V)-----------
