Hi All
New forum member, been using VCDS for a while and have managed to sort most things without the knowledge here.
But need a Long Code for my sons Golf 1.4 TSI BMY.
Car has been left parked for a while and he lost the keys
. Had locksmith out who has cut him 2 keys so can get in car but the IMMO pin could not be read??
And ABS pump has gone to all zeros as seen in attached log.
Could someone provide me with a coding please?
I also need advice on whether a replacement set of clocks will sort the IMMO problem so he can get the keys coded?. Or whether he just purchases an IMMO off ECU(will he get warning light in clocks?)
Apologies for all the questions 1st post.
I cant concentrate doing anything in the car with the clocks beeping because of ABS faults
I have an old HEX+CAN cable that I have used lots over the past 10 years and am waiting to be verified
Wednesday,20,November,2024,18:19:18:00711
VCDS Version: 24.7.0.0 (x64)
VIN: WVWZZZ1KZ9W019956 License Plate: CA08UOY
Mileage: 211490km-131413mi Repair Order:
Chassis Type: 1K-VW35 (1K0)
VIN: WVWZZZ1KZ9W019956 Mileage: 211490km-131413miles
Address 01: Engine Labels: 03C-906-032-BLG.lbl
Part No SW: 03C 906 032 Q HW: 03C 906 032 C
Component: MED17.5.1 G 6456
Revision: 96H07--- Serial number: VWX7Z0H43NK950
Coding: 0000072
Shop #: WSC 66565 257 00032
VCID: 2B5F2AE18A07F7CE46-807E
VINID: 9E69EAAAA05BA899C004924518AE79A9CE
008196 - Intake Manifold Flap; Bank 1
P2004 - 000 - Stuck Open
Fault Status: 01110000
Mileage: 211476 km
Time: 03:47:23
RPM: 706 /min
Load: 13.3 %
Temperature: 85.0 C
Temperature: 17.0 C
Absolute Pres.: 990.0 mbar
Voltage: 13.716 V
001378 - System Voltage
P0562 - 000 - Too Low
Mileage: 211493 km
Time: 00:04:06
Temperature: 9.0 C
Temperature: 11.0 C
Absolute Pres.: 1020.0 mbar
Voltage: 9.906 V
006481 - Radiator Fan 2 (V177)
P1951 - 000 - Movement Restricted / Jammed - Intermittent
Mileage: 211479 km
Time: 06:19:21
RPM: 1208 /min
Load: 10.6 %
Temperature: 75.0 C
Temperature: 16.0 C
Absolute Pres.: 1000.0 mbar
Voltage: 13.716 V
005699 - Please check DTC Memory of Electric Load Controller
P1643 - 000 - - Intermittent
Mileage: 211485 km
Time: 07:20:34
RPM: 711 /min
Load: 11.8 %
Temperature: 87.0 C
Temperature: 43.0 C
Absolute Pres.: 1010.0 mbar
Voltage: 13.335 V
001299 - Incorrect Immobilizer Key
P0513 - 000 -
Mileage: 211493 km
Time: 00:01:33
RPM: 1840 /min
Load: 17.2 %
Temperature: 9.0 C
Temperature: 11.0 C
Voltage: 11.303 V
Readiness: 0010 0001
Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AN HW: 1K0 907 379 AN
Component: ESP MK60EC1 H45 0107
Revision: 00H45001
Coding: 000000000000000000000000000000000000
Shop #: WSC 06314 123 12345
VCID: 7EF9D3B5E9F5B266B1-802A
Reset counter: 0
Count: 7
Count: 2
Count: 12288
Count: 195
Count: 41728
Fault Status: 01100101
Reset counter: 0
Count: 7
Count: 2
Count: 12288
Count: 291
Count: 41728
Part No SW: 3C8 907 336 J HW: 3C8 907 336 J
Component: Climatic H13 0203
Revision: 00006001
Coding: 0000000000
Shop #: WSC 00028 028 00304
ASAM Dataset: EV_Climatic A01001
ROD: EV_ClimaBasis_VW36.rod
VCID: 346D319D9F39A83617-8060
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl
Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
Revision: 00H54000 Serial number: 00000008498804
Coding: E58D8F27000415194714000014000000001800005C000108000000000000
Shop #: WSC 12345 785 00200
VCID: 336F32815237AF0E0E-8066
Subsystem 1 - Part No: 1K2 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 210508 021 0501
Coding: 00038805
Shop #: WSC 12345
Component: RLS 060608 054 0402
Coding: 00209069
Shop #: WSC 12345
Component: 38 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD21HE52
Coding: 0013112
Shop #: WSC 01269 785 00200
VCID: 3D7B14B96473697EE8-8068
Subsystem 1 - Serial number: 6332MSME39205216%
Subsystem 2 - Serial number: 6342MSME392052182
Subsystem 3 - Serial number: 6352QSME71784973N
Subsystem 4 - Serial number: 6362QSME6F741575S
Part No SW: 1K0 953 549 AF HW: 1K0 953 549 AF
Component: Lenks ulenmodul 634 0070
Coding: 0000042
Shop #: WSC 01279 785 00200
VCID: 76E9CB9501C5FA26E9-8022
Part No SW: 1K0 920 964 A HW: 1K0 920 964 A
Revision: V0002000 Serial number: 00000000000000
Coding: 0001403
Shop #: WSC 14557 067 57207
Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533 Gateway H07 0062
Revision: H07 01 Serial number: 280508F1000696
Coding: E9801F060002020001
VCID: 356B0C995C43B13E20-8060
Reset counter: 0
Mileage: 211493 km
Time: 01:05:27
Address 25: Immobilizer
Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
Component: Tuer-SG 006 1208
Coding: 0000628
VCID: 387505AD4B514C563B-806C
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 000 3001
Revision: 00H17000
VCID: 31633889A82B9D1E7C-8064
Fault Status: 11100101
Mileage: 211493 km
Time: 01:05:24
Battery Volts: 11.5 V
DD
Temperature: 9.0 C
Count: 3
Steering Angle: 0.00
SteerAng n.Init
Address 46: Central Conv. Labels:. 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AJ
Component: KSG 0401
Coding: 18D802087F2D8D0D481AC69010CC
Shop #: WSC 21490 758 00808
VCID: 78F5C5AD0BD18C56FB-802C
Subsystem 1 - Component: Sounder No Answer
Subsystem 2 - Component: NGS No Answer
Subsystem 3 - Part No: 1K0 951 177 A
Component: Innenraumueberw.005 0202
00323 - Vehicle Inclination Sensor (G384)
Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
Coding: 0000628
VCID: 397300A9705B555EC4-806C
Address 56: Radio Labels: None
Part No SW: 3TD 035 156 HW: 3TD 035 156
Component: RadioSK46MID 006 0010
Coding: 01000424041000
Shop #: WSC 00078 790 00000
VCID: 7F072EB1EEFFBB6EBA-802A
End-------------------------(Elapsed Time: 01:37)--------------------------
