Error 01176 (Mk.4 Golf)
Telboy
Verified VCDS-Lite User
UK, Crawley
C?ID=250830
Hi i did a autoscan on my car today and this is what i got
VCDS-Lite Version: Release 1.2
Monday, 23 November 2015, 13:50:04:29282
Chassis Type: 01 - My Golf
Scan: 01,03,08,15,17,19,46,56
Address 01: Engine       Labels: 06A-906-032-AJQ.LBL
   Controller: 06A 906 032 MJ
   Component: 1.8L R4/5VT         0003
   Coding: 11510
   Shop #: WSC 01266
   VCID: 72972BA92DB7
   WVWZZZ1JZ4W112895     VWZ6Z0C0133447
Address 03: ABS Brakes       Labels: None
   Controller: 1C0 907 379 M
   Coding: 0019970
   Shop #: WSC 01266
   VCID: 341BEDB11723
Address 08: Auto HVAC       Labels: 3Bx-907-044.LBL
   Controller: 3B1 907 044 C
   Component: CLIMATRONIC     C 2.0.0
   Coding: 11000
   Shop #: WSC 01266
   VCID: 213514E5B8D1
Address 15: Airbags       Labels: 6Q0-909-605-VW5.LBL
   Controller: 1C0 909 605 A
   Component: 27 AIRBAG VW51 01   0008
   Coding: 12855
   Shop #: WSC 01266
   VCID: 22371BE9BDD7
Address 17: Instruments       Labels: 1J0-920-xx5-17.LBL
   Controller: 1J0 920 926 A
   Component: KOMBI+WEGFAHRS. RB8 V29
   Coding: 05414
   VCID: 282309C1DBEB
01176 -  Key
            07-10 -  Signal too Low - Intermittent
Address 19: CAN Gateway       Labels: 6N0-909-901-19.LBL
   Controller: 6N0 909 901
   Coding: 00006
   Shop #: WSC 01266
   VCID: F093A1A1A3BB
Address 46: Central Conv.       Labels: 1C0-959-799.LBL
   Controller: 1C0 959 799 B
   Component: 1X Komfortgerát HLO 0003
   Coding: 00259
   Shop #: WSC 54146
   VCID: 361FD7B9015F
Address 56: Radio       Labels: 1J0-035-18x-56.LBL
   Controller: 1J0 035 186 D
   Component:  RADIO SON         0004
   Coding: 01403
   Shop #: WSC 01266
   VCID: 263F07F9D1FF
End   --------------------------------------------------------------------------------------------------
I see it could be my key, I did change the key batt about a month ago. The reason I did the scan was this morning I got STOP Check coolant service manual. yet had coolant at the correct level and only had waterpump changed 4 months ago with timing belt. yet no error code for that.
How can I test this error more as hate to think its the Immobilizer.
My girlfriend said when she use the car about amonth ago after changing the key bat. she got in the car and it went all blank as she went to start. she had to lock the car and open again and all was fine after she said.
The battery in your key has nothing to do with that fault code. The immobilizer transponder is a separate (passive) device from the remote transmitter in your key.
A transponder issue will not cause the rest of the electrics in the car to blank out either.
Check, clean, condition connections between immo pickup coil at ignition switch and instrument cluster.
Check connections at Central Convenience Module as well.
Telboy
UK, Crawley
C?ID=250830
Thanks for the reply
As it has only happen once, I think it will be easier to just reset and see if the code comes back in the future. if so then will check all the wiring with a meter at the ignition.
Were would I look for the Central Convenience Module.
