Have ibiza 2019y need to change coding to manual clima in ecu but coding is rejected (error31).
Thursday,21,November,2024,13:08:41:41414
VCDS Version: 24.7.1.0 (x64) HEX-NET2 CB: 0.4643.5
VIN: VSSZZZ6JZHR041019 License Plate: 12TFSI
Mileage: 39988km-24847mi Repair Order:
Chassis Type: 6J-SE26 (6C0)
Scan: 01 03 09 10 15 17 19 44 5F
VIN: VSSZZZ6JZHR041019 Mileage: 39988km-24847miles
Address 01: Engine (J623-CJZC) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 027 BB HW: 04E 907 309 AF
Component: R4 1.2l TFS H23 9085
Revision: R4H23--- CVN: 16A91C2B
Coding: 01110012232410080000
Shop #: WSC 00049 770 00111
ASAM Dataset: EV_ECM12TFS01104E906027BB 001009
ROD: EV_ECM12TFS01104E906027BB_SK25.rod
VCID: 659CDD8C35EBDA42CCD-8030
VINID: 9A38EAAAA19AA98880101001240A6EA996
4640 - Engine Oil Temp. Sensor (G8)
P0197 00 [00100111] - Signal too Low
Mileage: 39988 km
Date: 2020.12.03
Time: 02:21:07
Engine RPM: 0.00 /min
Coolant temperature: 24 °C
Intake air temperature: 14 °C
Voltage terminal 30: 11.449 V
Mass flow through throttle valve: 0.0 kg/h
Mean injection time: 0.000 ms
Engine operating condition: Idle
4708 - No Communications with HVAC Control Module (J301)
U0164 00 [00100111] - -
Mileage: 39988 km
Date: 2020.12.03
Time: 02:21:04
Voltage terminal 30: 11.473 V
selected gear-Bits 0-7: 0
9025 - Manifold / Barometric Pressure Sensor (G71) / (F96)
P0106 00 [00100111] - Implausible Signal
Mileage: 39988 km
Date: 2020.12.03
Time: 02:21:06
7786 - Sensor for Ambient Air Temperature (G17)
P0070 00 [00100111] - Malfunction
Mileage: 39988 km
Date: 2020.12.03
Time: 02:21:05
Readiness: 1110 0001
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP90.clb
Part No SW: 6C0 907 379 N HW: 6R0 907 379 BA
Component: ESP9.0i H04 0005
Serial number: 08505817160909
Coding: 11DD287D492733C10914006A005A881492CC90000005C9098F00
ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
ROD: EV_Brake1ESP90iBOSCHPQ26_SE26.rod
VCID: 3A265EF0ECD585BA51F-806E
0625 - Display for Tire Pressure Monitoring
C1146 02 [10001001] - Signal Failure
Mileage: 39988 km
Date: 2020.12.03
Time: 02:21:02
0716 - Databus
[Scl_KBI_Aussen_Temp_gef_Error]
Mileage: 39988 km
Date: 2020.12.03
Time: 02:21:08
0717 - Databus
[Scl_KBI_Aussen_Temp_gef_Invalid]
Mileage: 39988 km
Date: 2020.12.03
Time: 02:21:08
Address 09: Cent. Elect. (J519) Labels:| 6C0-937-089-V1.clb
Part No SW: 6C0 937 089 D HW: 6C0 937 089
Component: BCM PQ26 Hi4R H10 0094
Serial number: 006308120282 Dataset Number: V03935234KL 0001
Coding: 0800084040530A7B0BA44000B12703400000690057010000000000000000
ASAM Dataset: EV_BCMA0 006002
ROD: EV_BCMA0_006_SE26.rod
VCID: 313479DC31A346E2E05-8064
Subsystem 1 - Part No SW: 5Q0 955 559 B HW: 5Q0 955 559 B Labels: 5Q0-955-547.CLB
Component: RLS 042 0105
Serial number: S7Y16M08D29H06M37S00
Coding: 00194D
Driver door control module:
Subsystem 2 - Part No SW: 6R0 959 801 DT HW: 6R0 959 801 DT Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 003 0630
Serial number: KU0KU006091662500413
Coding: 1000A5
Front passenger door control module:
Subsystem 3 - Part No SW: 6R0 959 802 AR HW: 6R0 959 802 AR Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 007 5110
Coding: 020000
Subsystem 4 - Part No SW: 6C0 951 171 HW: 5Q0 951 171
Serial number: 000000000ZY162181QH1
Serial number: 00000000000066987712
Subsystem 6 - Part No SW: 6R0 959 811 R HW: 6R0 959 811 R
Component: J388__TSG_HL 022 1112
Serial number: 13102719160908133840
Subsystem 7 - Part No SW: 6R0 959 812 R HW: 6R0 959 812 R
Component: J389__TSG_HR 022 1112
Serial number: 13102718160908113732
137217 - Outside temperature sensor
B103F 1B [00001001] - Resistance Too High
Mileage: 39988 km
Date: 2020.12.03
Time: 02:21:04
Terminal 15 status: On
Terminal 50 status: OFF
OFF: operated
Position lamps: Not operated
Low beam: Not operated
Stoerschutzzaehler: 0
Voltage: 11.5 V
Outside temperature: 77.5 °C
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-283.clb
Part No SW: 5Q0 919 283 F HW: 5Q0 919 283
Component: PARKHILFE 4K H10 0054
Revision: -------- Serial number: 39231624201420 Dataset Number: V03935217SF 0002
Coding: 0000140001
ROD: EV_EPHVA14AU3700000_SE26.rod
VCID: 3C2A58E8E6E1BB8A433-8068
13637888 - Databus
[Steuergerät für Schalttafeleinsatz-J285 - Kombi_02.KBI_Aussen_Temp_gef - Fehlerspeicher auslesen]
Mileage: 39988 km
Date: 2020.12.03
Time: 02:21:03
Address 15: Airbags (J234) Labels:| 6C0-959-655.clb
Part No SW: 6C0 959 655 J HW: 6C0 959 655 J
Component: VW20Airbag002 002 0380
Revision: -------- Serial number: 003TH00AN220 Dataset Number: V03935228KU 0001
Coding: 88C0C000000000005C0000CA000800000000
ROD: EV_AirbaVW20BPAVW26X.rod
Subsystem 1 - Part No SW: ----------- HW: 410 271 908 16
Component: SideSensor_Df 15B 0148
Serial number: 3495R000429D1F1384BX
Subsystem 2 - Part No SW: ----------- HW: 410 271 908 16
Component: SideSensor_Pf 15B 0148
Serial number: 3505R001029D1F1363CK
Part No SW: 6P0 920 740 B HW: 6P0 920 740 B
Component: KOMBI 202 2310
Coding: 072409002180000800086A001000000000000000
ROD: EV_DashBoardVDDMQBAB_SE26.rod
VCID: 2E0E62A0209D591AFD7-807A
13639936 - Databus
[Steuergerät für BCM / Bordnetz / el. ZE: bitte Fehlerspeicher auslesen]
Mileage: 39988 km
Date: 2020.12.03
Time: 02:21:02
Address 19: CAN Gateway (J533) Labels:| 6C0-909-901-V1.clb
Part No SW: 6C0 909 901 A HW: 6C0 937 089
Component: GW MQB A0 H10 0094
Revision: -------- Serial number: 006308120282 Dataset Number: V03935226DB 0002
Coding: 010100082008560070000000000000000001000000000000000000000000
GVL: 01443C0000000000000000000000480000000000000000000000000000000000
ASAM Dataset: EV_GatewA0Lear 013020
ROD: EV_GatewA0Lear_013_VW26.rod
VCID: 261E9A80086D115A057-8072
Subsystem 1 - Part No SW: 5F0 959 537 B HW: 5F0 959 537 B Labels: 3C8-959-537.CLB
Component: E221__MFL-PR6 H04 0130
Serial number: 000000000A0726280616
Coding: 002000
Address 44: Steering Assist (J792) Labels:| 6Rx-909-144-V2.clb
Part No SW: 6C1 909 144 AJ HW: 6C1 909 144 D
Component: EPS_TRW_ALow 313 3242
Serial number: CGBB0854 Dataset Number: V03935233DT 0002
Coding: 000700
Shop #: WSC 00049 770 00143
ASAM Dataset: EV_SteerAssisUDSTRW 016134
ROD: EV_SteerAssisUDSTRW.rod
VCID: 70B2BCD8FA290FEAAFB-8024
Address 5F: Information Electr. (J794) Labels:| 5F0-035-MIB-STD2.clb
Part No SW: 5QA 035 846 A HW: 5QA 035 846 A
Component: MU-S-N-ER H30 0359
Serial number: SEZAZ2S0143655 Dataset Number: V03935238AD 0002
Coding: 04520001960A000011110001000808002F0200940120010046
ASAM Dataset: EV_MUStd6C1TSAT 001015
ROD: EV_MUStd6C1TSAT_SE26.rod
VCID: 42D626108405CD7A09F-8016
Subsystem 1 - Part No SW: 5F0 919 603 HW: 5F0 919 603
Component: ABTmin_Std_Rd H45 0020
Serial number: SEZ8Z9M55001C8
0518 - Front Right Treble Speaker
B1064 13 [00001001] - Open Circuit
[Hochtonlautsprecher Kanal 2: Unterbrechung (AC-Diagnose)]
Mileage: 39988 km
Date: 2020.12.03
Time: 02:21:04
Voltage terminal 30: 11.5 V
0523 - Front Left Treble Speaker
B1061 13 [00001001] - Open Circuit
[Hochtonlautsprecher Kanal 3: Unterbrechung (AC-Diagnose)]
Mileage: 39988 km
Date: 2020.12.03
Time: 02:21:04
End----(Elapsed Time: 00:49, VBatt start/end: 11.2V/11.3V. VIgn 11.1V)-----
