Skoda Rapid DSG - Gear selector blinking no communication with TCM
varunharidas
India
C?ID=519676
The car broke down while running, and the gear selectors blinked rapidly. Now, the car won't move in any gears. Attached is the full scan report. I tried changing the gear selector bush on the gearbox, reconnected it, and did a visual inspection of the mechatronics wiring harness.
When I try to do basic settings
Group 060
it shows values
The mechatronics TCM module was replaced on January 2021, also i never had any issues with jerky gear changes or any other issues with this transmission so far.
Im concerned if the TCM again went bad. Is there any way to confirm this?
Thursday,21,November,2024,11:46:09:42575
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 arm64(arm64 CPU)(Parallels)
VCDS Version 24.7.0.0 (arm64)  HEX-V2 CB: 0.4643.4
VIN: TMBBULNA4FG021112   License Plate:
Mileage: 94410km-58663mi   Repair Order:
Chassis Type: NA-SK25 (6RU)
Scan: 01 02 03 04 08 09 15 17 19 25 44
VIN: TMBBULNA4FG021112   Mileage: 94410km-58663miles
02-Auto Trans -- Status: Cannot be reached 1100
33-Flux Capacitor -- Status: Malfunction 0010
Address 01: Engine (J623-CWXB)       Labels: None
   Part No SW: 03L 906 023 SQ    HW: 03L 907 425 D
   Component: R4 1.5l TDI   H33 9977
   Revision: --H33---    Serial number: 00000000000000 CVN: 8E5E7A1E
   Coding: 00250116032500080000
   Shop #: WSC 01234 785 00200
   ASAM Dataset: EV_ECM15TDI02103L906023SQ 001001
   ROD: EV_ECM15TDI021_SK25.rod
   VCID: 074B961D6FA750C21E9-8053
   VINID: 91D49295C7911165C0081041082DAE771F
7332 - Mass Air Flow Sensor (G70)
          P0103 00 [10100101] - Signal too High
                    Mileage: 94411 km
                    Date: 2022.11.29
                    Time: 00:00:16
                    Engine RPM: 0.00 /min
                    Coolant temperature: 36 ∞C
                    Intake air temperature: 34 ∞C
                    Voltage terminal 30: 11.746 V
                    Engine RPM: 0 /min
                    Battery voltage: 11.7 V
                    EGR Vacuum Regulator Solen.val.: activation-ANG_SP_EGRV[0]: 0.000 %
                    Throttle_actuator_commanded_value-ANG_SP_THR[0]: 3.999 %
                    Air mass: specified value-MAF_SP_MMV: 239.95 mg/stroke
                    Air mass: actual value (mg/stroke)-MAF_MES: 0 mg/stroke
6088 - No Communication with Transmission Control Module
          U0101 00 [10101101] - -
                    Fault Frequency: 47
                    Mileage: 94411 km
                    Date: 2022.11.26
                    Time: 01:50:54
                    Coolant temperature: 32 ∞C
                    Intake air temperature: 32 ∞C
                    Voltage terminal 30: 12.085 V
                    Driver intention torque-TQI_DRIV_SUB: 0.00 Nm
                    Control Module temperature-TECU: 32 ∞C
Readiness: 1 1 0 0 1
   Part No SW: 0AM 300 065 L    HW: 0AM 927 769 D
   Component: GSG DSG AG7     451 6560
   Revision: 00045014    Serial number: CU502009157004
   Shop #: WSC 08518 004 1048576
   VCID: 382925E15E49EF3AA73-513D
006246 - Powertrain Data Bus
               P1866 - 000 - Missing Messages - MIL ON
                    Fault Status: 11100000
                    Fault Frequency: 48
                    Mileage: 94413 km
005940 - Starter Enable from Selector Lever Sensor System
               P1734 - 000 -
                    Fault Frequency: 25
                    Reset counter: 10
                    Mileage: 94413 km
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP90.clb
   Part No SW: 6R0 907 379 BN    HW: 6R0 907 379 AS
   Component: ESP9.0i front H03 0001
   Serial number: --------------
   Coding: 72F52C74422507C14E15346A4253E0820908
   ASAM Dataset: EV_Brake1ESP90iBOSCH 003031
   ROD: EV_Brake1ESP90iBOSCH_003_VW21.rod
   VCID: 0B43AA2D73CF34A23A1-805F
0915 - No Communication with Transmission Control Module
          U0101 00 [00001001] - -
          [ComScl_mGetriebe_1_Timeout]
                    Reset counter: 46
                    Mileage: 94411 km
                    Date: 2022.11.26
                    Time: 01:50:53
   Serial number: 11061504650199
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EA5F3F9307D110A2DF-802B
   Part No SW: 5J5 907 044 C    HW: 5J5 907 044 C
   Component: Climatronic   H10 0616
   Revision: K0000000
   VCID: 2F3B1EBDA7172882F69-807B
   Part No SW: 6RU 937 087 M    HW: 6RU 937 087
   Component: BCM IM H+4    H40 0432
   Revision: BZ040001    Serial number: 0300 295150193
   Coding: 3B904ABF08A10000013800003C0B16900080414F60040000200000000000
   VCID: 6C81C9B15681939A93B-8039
   Component: RLS 110815 05  54  0403
   Coding: 03302D
   Subsystem 2 - Part No SW: 6R0 959 802 CC    HW: 6R0 959 802 CC  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  007 5261
   Serial number: 13202670150811213138
   Coding: 050000
   Subsystem 3 - Part No SW: 6R0 959 801 BT    HW: 6R0 959 801 BT  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  007 5261
   Serial number: 13102671150809020906
   Coding: 040000
   Subsystem 4 - Part No SW: 5E0 919 719 C    HW: 5E0 919 719 C
   Component: E221__MFL-PR6  H05 0130
   Serial number: 000000000C1089030815
   Subsystem 5 - Part No SW: 6R0 959 811 L    HW: 6R0 959 811 L
   Component: J388__TSG_HL  006 5260
   Serial number: 13202580150707233303
   Coding: 020000
   Subsystem 6 - Part No SW: 6R0 959 812 L    HW: 6R0 959 812 L
   Component: J389__TSG_HR  006 5260
   Serial number: 13202581150812165253
   Coding: 020000
   Part No SW: 6R0 959 655 J    HW: 6R0 959 655 J
   Component: VW10AirbagQ02 H10 0020
   Revision: --------    Serial number: 003GW0117NMJ Dataset Number: t0030006607 0001
   Coding: 003032
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 49CF5025393366B2C8D-801D
   Part No SW: 5J5 920 860 C    HW: 5J5 920 860 C
   Component: KOMBI         H01 0214
   Coding: 110A000000
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05729
   ROD: EV_Kombi_UDS_VDD_RM09_005_VW31.rod
   VCID: 30391DC1BAA9377AEF3-8065
12648704 - Function Restricted due to Missing Message(s)
          U1111 00 [00001001] - -
          [Steuerger‰t f¸r Getriebe: keine Kommunikation]
                    Reset counter: 46
                    Mileage: 94411 km
                    Date: 2022.11.26
                    Time: 01:51:04
   Part No SW: 6RU 909 901     HW: 6RU 937 087
   Component: GW-K-CAN TP20 H40 0432
   Revision: BZ040001
   Coding: 132300
   VCID: 196FC065C993D632B8D-804D
                    Reset counter: 46
                    Mileage: 94411 km
                    Date: 2022.11.26
                    Time: 01:51:10
   Component: IMMO          H01 0214
   VCID: 6A8DCFA95CF58DAAE17-803F
Address 44: Steering Assist (J500)       Labels:| 1Sx-909-144-44.clb
   Part No SW: 1S2 909 144 P    HW: 1S2 909 144 P
   Component: EPS_ECU       H61 1702
   Dataset Number: 607074v____ 0108
   Coding: 0001000000000000
   ASAM Dataset: EV_SteerAssisNSK 014008
   ROD: EV_SteerAssisNSK_014_VW12.rod
   VCID: 41DF48050103AEF210D-8015
0067 - Terminal 30
          U140A 00 [00001001] - Open Circuit
          [Failure monitoring terminal 31]
                    Voltage terminal 15: 11.216 V
                    Voltage terminal 30: 11.834 V
                    Vehicle speed: 50 km/h
                    Status: Initialization
End----(Elapsed Time: 01:22, VBatt start/end: 12.0V/11.7V. VIgn 11.7V)-----
Common problem, the Mechatronic has failed, new unit 0AM 325 025 H ZLZ
varunharidas
India
C?ID=519676
tha
thanks btw in January 2021 when i had this same issue, the part number that was replaced with was
0AM927769D CONTR UNIT
I assume this is the tcm module alone of the mechatronics; this will be a bit cheaper than the entire unit, right? Is this recommended or a full unit swap, which is obviously expensive?
You can't buy it separately, it comes as a Vehicle Intelligent Part that has to be ordered to the VIN and programmed for the individual car before being despatched. In the UK you have to pay for them before the parts company will order it and the are non cancelable and none returnable under any circumstances if it is found to be faulty after installation. When installed it MUST be matched to the car, the software version checked and basic settings carried out and this can only be done using ODIS.
varunharidas
India
C?ID=519676
I have successfully replaced the mechatronics unit and carried out basic settings using ODIS. Now there is only one error left: the car starts but refuses to move the gear selector, and here is the error that im getting on both VCDS and ODIS.
               P1734 - 000 -
                    Fault Frequency: 25
                    Reset counter: 10
                    Mileage: 94413 km
varunharidas
India
C?ID=519676
I checked the switch in the selector, and it is working as expected. When I check for faults in VCDs, I get a new error: the engine is starting, but the gear lever refuses to disengage, and the indicators are blinking. There's also a coil icon on the instrument cluster, which is also blinking.
006228 - Powertrain Data Bus
               P1854 - 000 - Hardware Malfunction
                    Mileage: 79028 km
varunharidas
India
C?ID=519676
Here is the full scan
Saturday,07,December,2024,11:55:03:42575
VIN: TMBBULNA4FG021112   License Plate: BCM-OLD
          U0101 00 [10100101] - -
                    Fault Frequency: 16
                    Mileage: 94411 km
                    Date: 2022.12.02
                    Time: 21:40:47
                    Engine RPM: 778.25 /min
                    Normed load value: 45.5 %
                    Coolant temperature: 59 ∞C
                    Voltage terminal 30: 13.440 V
                    Control Module temperature-TECU: 30 ∞C
   Part No SW: 0AM 300 043 A    HW: 0AM 927 769 F
   Component: GSG DQ200G2_PQ  050 2901
   Revision: 00005008    Serial number: CU501812176600
   VCID: 290FF0A595E346B228D-5161
                    Fault Frequency: 15
                    Mileage: 79028 km
               P1734 - 000 -
                    Fault Frequency: 9
                    Reset counter: 10
                    Mileage: 79028 km
                    Reset counter: 46
                    Mileage: 94411 km
                    Date: 2022.12.02
                    Time: 21:40:46
   Coding: 01
   Revision: K0000000
   Coding: 03302D
   Coding: 050000
   Coding: 040000
   Coding: 020000
   Coding: 020000
   Coding: 003032
   Coding: 110A000000
                    Reset counter: 46
                    Mileage: 94411 km
                    Date: 2022.12.02
                    Time: 17:13:33
   Revision: BZ040001
   Coding: 132300
                    Reset counter: 46
                    Mileage: 94411 km
                    Date: 2022.12.02
                    Time: 17:48:09
End(Elapsed Time: 01:22, VBatt start/end: 11.9V/11.9V. VIgn 11.9V, udsna)--
please post full scans and not just snippets
iichel
Netherlands, Operation Market Garden
C?ID=284912
These communication errors with TCU are also interesting. Are you sure the new mechatronic is good?
varunharidas
India
C?ID=519676
Finally, the problem was solved. The old mechatronics was good; there was an issue with the wiring routing under the wiper. The CAN high and low lines for the selector were damaged. This caused the TCU communication errors to be brought up in the scans. The car is up and running now.
Just as a note with the shift unit switch fault, we tried the VW overlay (AKA bodge) repair on an Octavia a few weeks ago and it seems to have done the job.
