Amarok 2016 Webasto engine preheat
Tarno
Norway
C?ID=448397
Hello!
Im new to the forum so please bear with me.
I am having trouble to get my webasto heater to preheat the engine instead of the cabin.
Therefor i am wondering if its possible to tweak the circulation to be directed to the engine instead of cabin.
My problem is that below -25C my engine has trouble starting, have tried running webasto for 1,5 hour with charger didtn help and running without climatecontrol on inside cabin and did not work either. The webasto just shuts off when reaching work temp around 82C.
My understanding after reading about the shutoff valve is that after the cabin is heated the engine should get some heat but this doesnt happen. Have a skoda octavia as well and the engine is 40-50c after just 30 minutes and cabin is free of ice. It must be possible to achive this on the Amarok as well. My last step is to buy engine block heater but that should not be nessecary with a 5kw diesel heater installed is my opinion.
The 2-3 walve (n279) is coded to heat both engine and cabin.
Heater works fine and heats cabin in no time.
When doing the scan of the car the battery was in poor condition, but this havent got anything to do with it have tried to fix this problem with the heater for over 3 years now. Have ordererd a new battery, probably got a death sentence last winter when i tried to get engine warm with webasto.....
Will also attach photo off values when running, it could seem to me that the resirc pump should be running but isnt?
Not sure if its possible to fix, i know that others here in Norway has the exact problem on their 2.0TDI.
Edit: How do i upload pictures? Or what site should i uppload to and then hyperlink?
Thursday,14,November,2024,10:59:33:40343
VIN: WV1ZZZ2HZGH007307   License Plate: AMAROK
Mileage: 140290km-87172mi   Repair Order:
Chassis Type: 2H-VN81 (7E0)
Scan: 01 02 03 04 08 09 10 15 17 18 19 25 2E 32 37 56 61 69 6C 6E
          77 0B
VIN: WV1ZZZ2HZGH007307   Mileage: 140290km-87172miles
32-Differential Locks -- Status: Malfunction 0010
6E-Ctrl Head Roof -- Status: OK 0000
Address 01: Engine (J623-CSHA)       Labels:. 03L-906-022-CFC.clb
   Part No SW: 03L 906 012 AA    HW: 03L 907 309 AB
   Component: R4 2.0l BTD   H24 9978
   Revision: 73H24---    Serial number: 00000000000000 CVN: D97856ED0000000000000000
   Coding: 012A401A233601080001
   Shop #: WSC 04231 004 1048576
   ASAM Dataset: EV_ECM20BTD01103L906012AA 004011
   ROD: EV_ECM20BTD01103L906012AA_004.rod
   VCID: 6393A62A6BDC6162229-8036
   VINID: 9E606AAAA098A976000070C01C6BD839BE
4814 - System Voltage
          P0562 00 [00100000] - Too Low
                    Mileage: 138844 km
                    Date: 2024.10.24.
                    Time: 17:23:30
                    Engine RPM: 0.00 /min
                    Coolant temperature: 25  C
                    Intake air temperature: 15  C
                    Ambient air pressure: 930 mbar
                    Voltage terminal 30: 10.440 V
                    Unlearning counter according OBD: 1
                    Limitation: torque: 0.0 Nm
                    Limitation: accelerator pedal: 218.0 Nm
                    Cruise Control System (CCS): status-Bits 0-7: 44
                    Engine torque: -500.0 Nm
                    Generator: load signal: 0.02 %
Address 02: Auto Trans (J217)       Labels:| 0CM-325-025.clb
   Part No SW: 2H0 927 158 D    HW: 0CM 325 025 A
   Component: 2H0 20RTDIRdW H19 3001
   Revision: --H19---    CVN: ABDE511D
   ASAM Dataset: EV_TCMAL450211 002011
   ROD: EV_TCMAL450211_002_VN81.rod
   VCID: 2E05071E709E9C0AFD7-807A
Address 03: ABS Brakes (-----)       Labels: 2H0-907-37x-ESP.clb
   Part No SW: 2H0 907 379 Q    HW: 2H0 907 379 D
   Component: ESP MK25A XT  H44 0112
   Revision: 00H44001
   Coding: C07324B69A94039C24A559A36F57F0
   Shop #: WSC 02310 790 49170
   VCID: 3E25375EA07E6C8A6D7-806A
   Serial number: 18122313470281
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EA5F75EE07EAC8A2D7-802A
Address 08: Auto HVAC (J255)       Labels:| 7E5-907-040.clb
   Part No SW: 2H0 907 040 E    HW: 2H0 907 040 E
   Component: ClimatronicT5 H19 0407
   Revision: 00001004
   Coding: 0000000002
   Shop #: WSC 02310 790 50316
   ASAM Dataset: EV_ClimatronicT5 A01003
   ROD: EV_ClimaAutoT5Basis_VN81.rod
   VCID: 2313E62A2B5C2162629-8076
9481988 - Air Quality Sensor
          B10AF 04 [00001000] - Internal System Fault
                    Fault Frequency: 17
                    Reset counter: 92
                    Mileage: 136842 km
                    Date: 2024.09.12.
                    Time: 16:26:46
   Part No SW: 7E0 937 089     HW: 7E0 937 089
   Component: BCM PQ25 MMI4 H80 0736
   Revision: BB080001    Serial number: 0772 295150654
   Coding: 220002380C610400933807316CCB86D43281654F608C7161300000030003
   Shop #: WSC 61265 002 1048576
   VCID: 70B9D966AAAACAFAAFB-8024
   Component: RLS 161015 05  54  0403
   Coding: 02302D
   Subsystem 2 - Part No SW: 6R0 959 801 N    HW: 6R0 959 801 N  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 3322
   Coding: 140000
   Subsystem 3 - Part No SW: 6R0 959 802 Q    HW: 6R0 959 802 Q  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 3322
   Coding: 140000
   Subsystem 4 - Part No: 5C0 951 171
   Subsystem 5 - Part No: 1K0 951 605 C
   Subsystem 6 - Part No: 5C0 951 171
   Subsystem 7 - Part No SW: 2H0 959 442     HW: 2H0 959 442   Labels: 3C8-959-537.CLB
   Component: E221__MFL-MD9  H02 0103
   Serial number: 29230000632400073191
   Coding: A40000
   Subsystem 8 - Part No SW: 6R0 959 811 D    HW: 6R0 959 811 D
   Component: J388__TSG_HL  002 3322
   Coding: 100000
   Subsystem 9 - Part No SW: 6R0 959 812 D    HW: 6R0 959 812 D
   Component: J389__TSG_HR  002 3322
   Coding: 100000
   Part No SW: 7E0 919 475 L    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0106
   Revision: --------    Serial number: 28261527901036
   Coding: 318103
   ASAM Dataset: EV_VW75XParkAssis8K 001003
   ROD: EV_VW75XParkAssis8K_001_VN81.rod
   VCID: 3B233E4AB3EC79A24A9-806E
   Part No SW: 2H0 959 655 B    HW: 2H0 959 655 B
   Component: VW10Airbag00B H07 0013
   Revision: --------    Serial number: 003HN00NG4VV Dataset Number: 2H0003v____ 0156
   Coding: 000000000000000000000000000000003042
   Shop #: WSC 02739 790 50316
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 3333166A9BBCB1E2929-8066
   Serial number: 3495RRB40613FSTU1H6B
   Serial number: 3505RRB405T3FSTUFOEG
   Serial number: 3555YRB401C54QJ69P9
   Serial number: 3565YRB401C54QJ6EHE+
   Part No SW: 2H0 920 871 B    HW: 2H0 920 871 B
   Component: KOMBI         H04 1009
   Coding: 151C000000
   ROD: EV_Kombi_UDS_VDD_RM09_005_VW31.rod
   VCID: 270BF23A5F64CD423E1-8072
Address 18: Aux. Heat        Labels: 7E0-819-008.clb
   Part No: 7E0 819 008 F
   Component: J737__Standheizung  0605
   Revision: 00086000    Serial number: 09024901A00000
   Coding: 0031332
   Shop #: WSC 02757 790 00000
   VCID: 2C010D164A02EE1AD33-8078
   Part No SW: 7E0 909 901     HW: 7E0 937 089
   Component: GW-K-CAN TP20 H80 0736
   Revision: BB080001
   Coding: 742200
   VCID: 6889B106927A023AF7B-803C
   Component: IMMO          H04 1009
   VCID: 6A8DCB0E8CF6302AE1F-803E
Address 2E: Media Player 3
Address 32: Differential Locks (J647)       Labels:* 2H0-927-771.clb
   Part No SW: 2H0 927 771 A    HW: 2H0 927 771
   Component: Quersperre    H04 0017
   Revision: 11001001    Serial number: 4DG 24.08.15 00
   ASAM Dataset: EV_QuersUDSAAMVN817 A01606
   ROD: EV_QuersUDSAAMVN817.rod
   VCID: 2C010D164682EE1AD33-8078
0003 - Supply voltage
          U1011 00 [00001000] - Voltage too Low
          [System Battery Voltage Low]
                    Reset counter: 96
                    Mileage: 139957 km
                    Date: 2024.11.12.
                    Time: 16:21:10
                    Engine RPM: 1190.00 /min
                    Voltage terminal 30: 8.8 V
                    Voltage at sensor: 1.1 V
                    Actuator: coil current: 0.0 A
   Part No SW: 2H0 035 680 A    HW: 2H0 035 680 A
   Component: RNS-MID       H30 6276
   Revision: AB001001    Serial number: VWZ6Z7R9293086
   Coding: 04000402020000A00016
   Shop #: WSC 02739 790 00000
   VCID: 211FEC2231C03372705-8074
   Component: EU West V13  8316
01327 - Control Module for Parking Aid (J446)
                    Reset counter: 71
                    Mileage: 139092 km
                    Date: 2019.03.21.
                    Time: 14:41:12
01129 - S Terminal (H15)
                    Reset counter: 71
                    Mileage: 139092 km
                    Date: 2019.03.21.
                    Time: 14:41:12
00576 - Terminal 15
                    Reset counter: 71
                    Mileage: 139092 km
                    Date: 2019.03.21.
                    Time: 14:41:12
00001 - Brake Control Unit
                    Reset counter: 71
                    Mileage: 139092 km
                    Date: 2019.03.21.
                    Time: 14:41:12
                    Reset counter: 71
                    Mileage: 139092 km
                    Date: 2019.03.21.
                    Time: 14:41:12
                    Reset counter: 71
                    Mileage: 139092 km
                    Date: 2019.03.21.
                    Time: 14:41:12
00576 - Terminal 15
                    Reset counter: 71
                    Mileage: 139092 km
                    Date: 2019.03.21.
                    Time: 14:41:12
                    Reset counter: 71
                    Mileage: 139092 km
                    Date: 2019.03.21.
                    Time: 14:41:12
   Part No SW: 7E0 907 534     HW: 7E0 937 089
   Component: Batt.regelung H80 0736
   Coding: 330B1873
   Shop #: WSC 02310 790 00114
   Subsystem 1 - Part No SW: 2H0 915 181 A    HW: 2H0 915 181 A
   Component: J367-BDM  H08 0181
   Serial number: 62272404422191796025
   Component: Anhaenger     H12 0100
   Revision: 3A001001    Serial number: 00000384025028
   Coding: 010D000100000000
   VCID: 303919666A2A8AFAEFB-8064
   Part No SW: 2H0 907 441     HW: 2H0 907 441
   Component: J772__Rearview      0020
   Revision: 00H13000    Serial number: 525 PA8JA91579
   Coding: 0030017
   VCID: 6393A62A675C6162229-8036
Address 6E: Ctrl Head Roof (J702)       Labels:. 7E5-919-037-W2.clb
   Part No SW: 7E5 919 037 G    HW: 7E5 919 037 G
   Component: Dachdisplay   H15 0185
   Revision: 10100011    Serial number: 402490
   Coding: 000103
   VCID: 353728729548AFD2BCD-8060
   Part No SW: 7P6 035 730 N    HW: 7P6 035 730 N
   Component: TELEFON       H16 4217
   Revision: 1B001001    Serial number: 00007670452468 Dataset Number: 7P6035730N  0001
   Coding: 0A01010000010110
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 3D273052ADF8779274D-8068
End----(Elapsed Time: 02:36, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
Dr Sheldon
Windsor UK
C?ID=334979
Makes no sense !!
You have no reason to diagnose any part of that car with a poor battery - A good battery is your first stepping Stone !!
Tarno
Norway
C?ID=448397
Yes i understand that if there was an part malfunction. But my question is if its possible to make it heat engine first as it doesnt do it properly from factory. Posted this case on a norwegian FB site for amarok owners and 8 guys said straight away that they had the same case on the 2.0 tdi. The newer V6 3.0 doesnt have this issue.
VWT6
Finland
C?ID=295527
I would try a coding change in controller 18:
Coding: 0031332 ===> Coding: 0031032
Tarno
Norway
C?ID=448397
Okay i will try. The VCDS suggest that this bit is about the 2/3 way valve.
Tarno
Norway
C?ID=448397
No news is good news?
It looks likes it working. Engine and cabin heats at the same time. Therefore cabin doesnt heat that quick but engine is 50 degrees in no time with about 0 degrees outside.
VWT6
Finland
C?ID=295527
Isn't there now actually a couple of minutes delay before cabin blower starts?
Tarno
Norway
C?ID=448397
There was a delay before editing the code, maybe the delay is a bit longer now. Havent tought about it, I can check next time running the webasto.
Tarno
Norway
C?ID=448397
I clocked it to 5 minutes when the temperature was about -18C. My theory is that the fan inside the cab only starts at a certain temperature.
Its around 30-40C, therefore when heating engine also it takes longer time before the fan starts. Because when the car wasnt heating engine at all the temp got up to that pretty quick.
VWT6
Finland
C?ID=295527
Agreed. I think the Webasto monitors the return flow and when it's somewhere +30C, Webasto commands Climatronic HVAC to start the blower. Does the Climatronic cabin control panel (temp dials, etc.) light up when the blower is started? Also air flow direction controls are active?
Tarno
Norway
C?ID=448397
Yes everything lights up as usual. It starts at 22 and auto high. You can change the fan speed at lest havent tried the directions but would assume you could do that as well. Only thing i noticed is that you cant switch to off, only set the fan at lowest speed. Did once for heating engine quicker.
VWT6
Finland
C?ID=295527
A somewhat related trick you could try - and please report if works or not for you:
If need to start cool engine for a brief moment when ambient temperature is below +5°C:
- to avoid Webasto starting - turn cabin fan off = speed to "0"
Normally the Webasto is "forced" to start when engine is started when ambient temperature is below +5°C AND there is heating request from 08-HVAC controller.
Tarno
Norway
C?ID=448397
If need to start cool engine for a brief moment when ambient temperature is below +°5 C:
Normally the Webasto is "forced" to start when engine is started when ambient temperature is below +°5 C AND there is heating request from 08-HVAC controller.
The engines logic would kick in and demaning help because engine temperatures are below operating temperature.
If I have understod correctly these 2.0L engines need webasto because of emissions standards, so everytime engine temperature drops below a certain point or in a cold start it would always start.
Could try with the fan off but almost certain it will start anyways.
