Looking for information on the probable cause of the gear selection display all lit up after starting the car. After starting the car the gear display all lights up and there is not any box around P. While it is running and foot on the brake the gear shift lever is move through the gears several times. The car is then shut off and restarted. The box appears around the P and the transmission acts normal without any loss of the indicator of the gear selected. After returning the shift lever to park the box is around P. The car is shut off and when the car is restarted the box high lighting the gear has gone and the PRNDS are high lighted in red.
The TCM has been changed as the original was water logged. Identical part number. The range selector on the side of the transmission has been changed also. When scanning the transmission info does not come up. Lack off communication.
It would appear to be a voltage drop that triggers the issue but from where? Does anyone have any information on the shaft that drives the range selector. Is it possible the shaft has some play and on initial start up moves the range selector slightly causing a loss of contact in the range selector. The MAF has also been mentioned on the web as a possible cause of the issue.
If anyone has any insight as to the possible cause of the issue it would be appreciated.
