Golf 7.5 headlight upgrade
OccasionCenterVenlo
C?ID=549643
Hi all, can someone help me? I have a 2019 GTI 7.5 that had a crash.
I have fitted the new headlights. The double DRL lights seem to work fine, but I have a few weird DTCs.
Old Headlight numbers are 5G1 941 035 D & 5G1 941 036 D
New headlight Numbers are 5G1 941 081 A & 5G1 941 082 A
Monday,18,November,2024,19:21:00:38066
VCDS Version: 24.9.1.0 (x64) HEX-NET2 CB: 0.4656.5
Data version: 20240926 DS359.0
VIN: WVWZZZAUZKW108209 License Plate:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 08 09 10 13 14 15 17 18 19 29 32 39 42 44 47 4B 52
          5F 69 6C 75 A5 A9 D6 D7
VIN: WVWZZZAUZKW108209 Mileage: 63178km-39256miles
29-Left Light -- Status: Cannot be reached 0100
39-Right Light -- Status: Cannot be reached 0100
D6-Light Ctrl Left 2 -- Status: Cannot be reached 0100
D7-Light Ctrl Right 2 -- Status: Cannot be reached 0100
Address 01: Engine (J623-DKTB) Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 S HW: 06K 907 425 J
   Component: 2.0l R4 TFSI H13 0002
   Revision: --H13--- CVN: 8BD73933
   Coding: 0925403A4474050B2000
   ASAM Dataset: EV_ECM20TFS0205G0906259S 001003
   ROD: EV_ECM20TFS0205G0906259S_VW37.rod
   VCID: 3E2E539680FEFEDA557-806A
   VINID: 9E69EAAAA465A9B9C10080802490FD0F2A
Readiness: 1010 0001
   Part No SW: 0GC 300 020 G HW: 0GC 927 711 H
   Component: GSG DQ381 H06 2402
   Revision: 00H06V08 CVN: 1271C65E
   ROD: EV_TCMDQ381061.rod
   VCID: 261E9BF6786E461A3D7-8072
   No subsystems:
   Part No SW: 5Q0 614 517 EF HW: 5Q0 614 517 BP
   Component: ESC H35 0107
   Revision: 00000000 Serial number: 63558000004004
   Coding: 01FA6BA1502021744779060060CC6980D60A84E260069677B84250F9D2084B0B0000000012121212B835351919323200
   ROD: EV_Brake1UDSContiMK100IPB_038.rod
   VCID: 79A4808AD95019E2205-802C
   Part No SW: 5G0 907 044 CG HW: 5G0 907 044 CG
   Component: Climatronic H04 1801
   Revision: 00001K08
   Coding: 0002001420411101110500000010102A
   VCID: 6E8EA3D6901E4E5A857-803A
   Air quality sensor:
262914 - Refrigerant Pressure
          B10AB F0 [00001001] - Too Low
                    Reset counter: 178
                    Mileage: 63178 km
                    Date: 2024.11.18
                    Time: 19:10:23
                    Outside temperature: 14.5 °C
                    Engine RPM: 700 /min
                    Temperature downstream of evaporator: 31.7 °C
                    System run time-Engine running time: 47 s
                    System run time-Terminal 15 on: 171 s
   Part No SW: 5Q0 937 084 DC HW: 5Q0 937 084 CF
   Component: BCM MQBAB M+ H38 0273
   Serial number: 00001901601215 Dataset Number: V03935292FD 0001
   ROD: EV_BCMBOSCH_019_VW37.rod
   VCID: 7CAA999ED6622CCA3B3-8028
   Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
   Component: WWS 181208 043 0551
   Serial number: 190110030248
   Component: RLHS 052 0107
   Serial number: SBY19M01D22H21M18S06
   Coding: 00A8DD
   Sunroof control module:
   Subsystem 3 - Part No SW: 8V3 959 591 A HW: 8V3 959 591 A
   Component: J245 PS73.404 H04 0005
   Serial number: 0000FST001Z0HM300000
   Coding: 181901
   Steering Column Switch:
   Subsystem 4 - Part No SW: 5Q1 953 507 HW: 5Q1 953 549
   Component: J527 SMLS MQB 004 0060
   Serial number: 00000018121808493794
   Part No SW: 5QA 919 298 D HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0050
   Serial number: 000308417319019 Dataset Number: V03935287MZ 0001
   Coding: 0A71163951
   ASAM Dataset: EV_EPHVA2CAU3700000 009041
   VCID: 51F4182A216071A2B85-8004
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V2.clb
   Part No SW: 5Q0 907 572 P HW: 3QF 907 572 A
   Dataset Number: V03935282JS 0001
   Coding: 330067C959FFC728949C810580400600000000000000000004
   VCID: 44DA217EEE12940A033-8010
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
   Part No SW: 5Q0 907 376 B HW: 5Q0 907 376 A
   Serial number: 16011941350179 Dataset Number: V03935231PP 0001
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 3822458EA2DAC0EA9FB-806C
   Part No SW: 5Q0 959 655 CA HW: 5Q0 959 655 CA
   Component: AirbagVW21 007 0403
   Serial number: 003FPR4W4NPT Dataset Number: V03935279BB 0001
   Coding: 98FCC0C0000000005C5400CF004800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
   VCID: 0154E86AB1804122685-8054
   Left seat belt tensioner:
   Component: BeltPretRevFL H37 0350
   Serial number: 34169667E28021840367
   Coding: 333135
   Right seat belt tensioner:
   Component: BeltPretRevFR H37 0350
   Serial number: 34169668E03031810662
   Coding: 333135
   Subsystem 3 - Part No SW: ----------- HW: 480 001 501 19
   Serial number: 3570000000072D68C73U
   Subsystem 4 - Part No SW: ----------- HW: 480 001 701 19
   Serial number: 3580000000055728D73N
   Subsystem 5 - Part No SW: ----------- HW: 480 401 801 19
   Component: SideSensor_Dr 004 6149
   Serial number: 3510001182B805B4224P
   Subsystem 6 - Part No SW: ----------- HW: 480 401 801 19
   Component: SideSensor_Pr 004 6149
   Serial number: 35200011E2B72272E32Z
   Subsystem 7 - Part No SW: ----------- HW: 480 400 203 18
   Serial number: 3550001C92929725D402
9439515 - Seat Belt Tensioner Igniter; rear; driver's side
          B1009 1B [10001001] - Resistance Too High
                    Mileage: 63178 km
                    Date: 2024.11.18
                    Time: 19:10:24
9439259 - Igniter for Seat Belt Tensioner; Rear Passenger's Side
          B1008 1B [10001001] - Resistance Too High
                    Mileage: 63178 km
                    Date: 2024.11.18
                    Time: 19:10:24
   Part No SW: 5G1 920 791 B HW: 5G1 920 791 B
   Component: KOMBI 403 4191
   Coding: 07AD11087F84000801886B033401000800000000
   VCID: 2B086AC2638C7B72E29-807E
Address 18: Aux. Heat (J364) Labels:| 5Q0-963-272.clb
   Part No SW: 5Q0 963 272 HW: 5Q0 963 272
   Component: STH-MQB 005 0066
   Coding: 1315
   Shop #: WSC 05674 121 56740
   ASAM Dataset: EV_AuxilParkiHeateWOS 002012
   VCID: 73B8B2A2FB3C63B26A9-8026
   Auxiliary heating remote control:
   Subsystem 1 - Part No SW: 3Q0 963 513 HW: 3Q0 963 513
   Component: R64 D208L 004 0402
   Serial number: 00000000000000642881
   Part No SW: 3Q0 907 530 AA HW: 3Q0 907 530 C
   Component: GW MQB High 442 4366
   Revision: -------- Serial number: 0008937967 Dataset Number: V03935293G 0001
   Coding: 030100347F085900FB00027D9C0F00010001070000000000000000000000
   GVL: 01463C5000000000C08C80008006CC000C00C000000200000000000000000000
   ROD: EV_GatewNF_VW37.rod
   Generator:
   Component: 0-00-00-00-00
   Subsystem 2 - Part No SW: 5G0 959 442 AE HW: 5G0 959 442 AE Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1 H11 0052
   Serial number: 29180003015730078516
   Coding: 2DFFFF
   Subsystem 3 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
   Serial number: 7117130305
66304 - Databus
          U1124 00 [00001001] - Additional Installations Detected
          [Mehrverbau CAN]
                    Reset counter: 178
                    Mileage: 63178 km
                    Date: 2024.11.18
                    Time: 19:10:24
                    Terminal 30 power supply: 14.4 V
                    Terminal 15: On
Address 29: Left Light (J1018) Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 D HW: 8V0 907 399 D
   Component: LCM_MLBevoH08 0014
   VCID: 47C03672DF24BF12E61-8012
Address 32: Differential Locks (J492) Labels:| 0CQ-907-554-V2.clb
   Part No SW: 0CQ 907 554 P HW: 0CQ 907 554 P
   Component: Quersperre H55 8043
   Serial number: HA1-00014.11.18 Dataset Number: v1260x015G0 0000
   Coding: 0001
   ASAM Dataset: EV_LockElectHA1VW37X 001007
   ROD: EV_LockElectHA1VW37X.rod
   VCID: 52F6172624660ABA81F-8006
Address 39: Right Light (J1023) Labels: 8V0-907-399.clb
   Part No SW: 5Q0 959 593 F HW: 5Q0 959 593 F
   Component: TSG FS001 0287
   Serial number: YE007RLG01059 Dataset Number: V03935290SS 0001
   Coding: 003F0320D000048000001000
   ROD: EV_DCU2DriveSideMAXHKLO_VW37.rod
   Subsystem 1 - Part No SW: 5Q0 959 811 D HW: 5Q0 959 811 D Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_DRV 006 0007
   Serial number: 00000000000026782646
   Coding: 110000
   Part No SW: 3Q0 909 144 M HW: 3Q0 909 144 L
   Component: EPS_MQB_ZFLS 507 5082
   Dataset Number: V03935293MP 0001
   Coding: 931F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 3C2A599E96E2ECCA7B3-8068
Address 47: Sound System (J525) Labels:| 5Q0-035-456.clb
   Part No SW: 5Q0 035 456 A HW: 5Q0 035 456 A
   Component: MIB2_lite_amp H40 0200
   Revision: 00000001 Serial number: VWZ8Z1JMD040N9H Dataset Number: V03935259RT 0001
   Coding: 12000000008AAA8A000000000000
   ASAM Dataset: EV_AMPMst11CGen2ALPI 001003
   ROD: EV_AMPMst11CGen2ALPI_VW37.rod
   VCID: 2E0E63D6509E0E5AC57-807A
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V2.clb
   Part No SW: 3Q0 907 338 C HW: 3Q0 907 338 C
   Component: FCM MQB Low 002 0345
   Serial number: 08011911600217 Dataset Number: V03935286KS 0001
   Coding: 000000070900164A07200341020000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 002006
   ROD: EV_MultiModulContiVW48X_002_VW37.rod
   VCID: 353C4CBAB5C83D8284D-8060
0035 - Databus for Front Lighting
          U12EB 00 [00001001] - Additional Installations Detected
          [CAN_AFS_multiple_plug_LCM_identified]
                    Reset counter: 178
                    Mileage: 63178 km
                    Date: 2024.11.18
                    Time: 19:10:23
0032 - Headlight
          C107E 54 [10001001] - Missing Calibration / Basic Setting
                    Reset counter: 178
                    Mileage: 63178 km
                    Date: 2024.11.18
                    Time: 19:10:23
   Part No SW: 5Q0 959 592 F HW: 5Q0 959 592 F
   Component: TSG BFS001 0287
   Serial number: YE007RLE16153 Dataset Number: V03935290SY 0001
   Coding: 003F0120DC00048000001000
   ROD: EV_DCU2PasseSideMAXHKLO_VW37.rod
   VCID: 43D82262EB1C93323A9-8016
   Subsystem 1 - Part No SW: 5Q0 959 812 D HW: 5Q0 959 812 D Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_PSG 006 0007
   Serial number: 00000000000026707673
   Coding: 090000
   Part No SW: 3Q0 035 874 C HW: 3Q0 035 874 C
   Component: MU-S-ND-ER 853 0891
   Serial number: Dataset Number: V03935282VN 0001
   Coding: 02731001000000004111010200880A231F0503E4012000008E
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 323677A644A62ABAA1F-8066
   Subsystem 1 - Part No SW: 5G6 919 605 B HW: 5G6 919 605 B
   Component: ABT_Std-2_Nav H52 8130
   Serial number: VWZ6ZHW0133560
   Subsystem 2 - Part No SW: 5NA 919 866 HW: -----------
   Component: ECE1 2018/19 --- 1030
   Part No SW: 5Q0 907 383 M HW: 5Q0 907 383 M
   Component: Anhaenger H27 0260
   Revision: 8B001004 Serial number: 0500115187 Dataset Number: V03935259HE 0001
   Coding: 0100000202000000
   VCID: 41D4286AF1008122285-8014
   Part No SW: 5Q0 980 568 B HW: 5Q0 980 568 B
   Component: RVC Compact+ H08 0250
   Dataset Number: V03935267KG 0001
   Coding: 0173000163002017000048
   ASAM Dataset: EV_CamSysRVRVCARPANAMQBAB 007012
   ROD: EV_CamSysRVRVCARPANAMQBAB_007.rod
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
   Part No SW: 5NA 035 284 C HW: 5NA 035 284 C
   Component: OCULowMQBLGE H19 0825
   Revision: -------- Dataset Number: V03935278EW 0001
   Coding: 02730001EA42380D3F1CBE000045400382E708
   ASAM Dataset: EV_OCULowMQBLGE 004049
   ROD: EV_OCULowMQBLGE_004_VW25.rod
   VCID: 3D2C549A8DF8E5C24CD-8068
9458195 - Control Module for Cellular Telephone
          B1052 13 [00001001] - Open Circuit
          [roofline module open load]
                    Reset counter: 178
                    Mileage: 63178 km
                    Date: 2024.11.18
                    Time: 19:10:28
                    Voltage terminal 30: 15.0 V
12866049 - Databus
          [Airbag: Error value received]
                    Reset counter: 178
                    Mileage: 63178 km
                    Date: 2024.11.18
                    Time: 19:10:25
   Part No SW: 3Q0 980 654 H HW: 3Q0 980 654 A
   Component: MQB_B_MFK H09 0272
   Serial number: 10091815K22090 Dataset Number: V03935273UR 0001
   Coding: 000307000000040100221345C150A90098000E300020
   Part No SW: 5G0 907 159 G HW: 4H0 907 159 A
   Component: SAS-GEN 2 H07 0001
   Serial number: 181203200522
   Part No SW: 7P5 941 572 A HW: 7P5 941 572 A
   Component: LED1L H06 0002
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481_VW37.rod
   VCID: 3924408A99D0D9E2605-806C
   Component: LED1R H06 0002
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
End----------(Elapsed Time: 01:51, VBatt start/end: 14.6V/14.6V)-----------
downtime
Finland
C?ID=280813
Are you sure the lights are compatible? What’s the difference compared to your old lights? These are matrix/DLA leds?
AINils
Germany (AIB)
C?ID=56975
   No subsystems:
   Revision: 00001K08
   Air quality sensor:
                    Reset counter: 178
                    Mileage: 63178 km
                    Date: 2024.11.18
                    Time: 19:10:23
   Coding: 00A8DD
   Coding: 181901
   Coding: 0A71163951
   Coding: 333135
   Coding: 333135
                    Mileage: 63178 km
                    Date: 2024.11.18
                    Time: 19:10:24
                    Mileage: 63178 km
                    Date: 2024.11.18
                    Time: 19:10:24
   Coding: 1315
   Generator:
   Coding: 2DFFFF
66304 - Databus
          [Mehrverbau CAN]
                    Reset counter: 178
                    Mileage: 63178 km
                    Date: 2024.11.18
                    Time: 19:10:24
                    Terminal 15: On
   Coding: 0001
   Coding: 110000
   Coding: 931F0000
                    Reset counter: 178
                    Mileage: 63178 km
                    Date: 2024.11.18
                    Time: 19:10:23
0032 - Headlight
                    Reset counter: 178
                    Mileage: 63178 km
                    Date: 2024.11.18
                    Time: 19:10:23
   Coding: 090000
                    Reset counter: 178
                    Mileage: 63178 km
                    Date: 2024.11.18
                    Time: 19:10:28
12866049 - Databus
                    Reset counter: 178
                    Mileage: 63178 km
                    Date: 2024.11.18
                    Time: 19:10:25
Done this retrofit 3 times this year.
You have also to activate the additional LCM in adaption of 4B
This should result in these values:
IDE01996-MAS14455-Verbauliste Sollverbau-Multifunktionsmodul am zweiten Busanschluss,ja
IDE01996-SFT00041-Verbauliste Sollverbau-Lichtsteuerung links,ja ,1
IDE01996-SFT00057-Verbauliste Sollverbau-Lichtsteuerung rechts,ja ,1
IDE01996-SFT00075-Verbauliste Sollverbau-Multifunktionsmodul,ja ,1
IDE01996-SFT00214-Verbauliste Sollverbau-Lichtsteuerung links 2,ja ,1
IDE01996-SFT00215-Verbauliste Sollverbau-Lichtsteuerung rechts 2,ja ,1
After you code this, turn off ignition for 10min and close car. After that xou should be able to do Basic Settings with an light adjustment device
OccasionCenterVenlo
C?ID=549643
The coding is alraddy how you want me to code the car the basic setting are done but keep getting
Wednesday,20,November,2024,20:46:37:38066
VCDS Version: Beta 24.9.1 (x64) Running on Windows 11 x64
Address 4B: Multifunc. Module Labels: 3Q0-907-338-V2.clb
Control Module Part Number: 3Q0 907 338 C HW: 3Q0 907 338 C
Component and/or Version: FCM MQB Low 002 0345
Software Coding: 000000070900164A07200341020000000000000000000000000000000000
Work Shop Code: WSC 01357 011 00200
ASAM Dataset: EV_MultiModulContiVW48X 002006 (VW37)
Reset counter: 178
Mileage: 63178 km
Date: 2024.11.20
Time: 20:42:27
OccasionCenterVenlo
C?ID=549643
Reset counter: 178
Mileage: 63178 km
Date: 2024.11.20
Time: 20:42:27
;SW:3Q0-907-338-C HW:3Q0-907-338-C --- Multifunc. Module
;Component:FCM MQB Low 002 0345, Coding:000000070900164A07200341020000000000000000000000000000000000
;EV_MultiModulContiVW48X,002006,EV_MultiModulContiVW48X_002_VW37.rod
;Wednesday,20,November,2024,20:48:27:38066
;VCDS Version: Beta 24.9.1 (x64) Data version: 20240926 DS359.0
;VCID: 353C4CBAB5C83D8284D-8060
IDE01996-MAS14455-Installation list: specified installations-Multifunction module on the second bus connection,Yes ,1
IDE01996-SFT00041-Installation list: specified installations-Left light control,Yes ,1
IDE01996-SFT00057-Installation list: specified installations-Right light control,Yes ,1
IDE01996-SFT00075-Installation list: specified installations-Multi-function module,Yes ,1
IDE01996-SFT00117-Installation list: specified installations-Emergency call module and communication unit,No ,1
IDE01996-SFT00214-Installation list: specified installations-Light Control Left 2,Yes ,1
IDE01996-SFT00215-Installation list: specified installations-Light Control Right 2,Yes ,1
IDE01996-SFT33031-Installation list: specified installations-Antenna module,No ,1
IDE03641-Presentation run dynamic AFS light,active ,1
IDE08418-Matrix light: total dimming,0.0 %,1
IDE09156-Matrix headlamp: function at standstill,not active ,1
IDE09568-MAS09833-Bit pattern of individual segment activation: left headlight-LED 1,OFF ,12
IDE09568-MAS09834-Bit pattern of individual segment activation: left headlight-LED 2,OFF ,12
IDE09568-MAS09835-Bit pattern of individual segment activation: left headlight-LED 3,OFF ,12
IDE09568-MAS09836-Bit pattern of individual segment activation: left headlight-LED 4,OFF ,12
IDE09568-MAS09837-Bit pattern of individual segment activation: left headlight-LED 5,OFF ,12
IDE09568-MAS09838-Bit pattern of individual segment activation: left headlight-LED 6,OFF ,12
IDE09568-MAS09839-Bit pattern of individual segment activation: left headlight-LED 7,OFF ,12
IDE09568-MAS09840-Bit pattern of individual segment activation: left headlight-LED 8,OFF ,12
IDE09568-MAS09841-Bit pattern of individual segment activation: left headlight-LED 9,OFF ,12
IDE09568-MAS09842-Bit pattern of individual segment activation: left headlight-LED 10,OFF ,12
IDE09568-MAS09843-Bit pattern of individual segment activation: left headlight-LED 11,OFF ,12
IDE09568-MAS09844-Bit pattern of individual segment activation: left headlight-LED 12,OFF ,12
IDE09568-MAS09845-Bit pattern of individual segment activation: left headlight-LED 13,OFF ,12
IDE09568-MAS09846-Bit pattern of individual segment activation: left headlight-LED 14,OFF ,12
IDE09568-MAS09847-Bit pattern of individual segment activation: left headlight-LED 15,OFF ,12
IDE09568-MAS09848-Bit pattern of individual segment activation: left headlight-LED 16,OFF ,12
IDE09568-MAS09849-Bit pattern of individual segment activation: left headlight-LED 17,OFF ,12
IDE09568-MAS09850-Bit pattern of individual segment activation: left headlight-LED 18,OFF ,12
IDE09568-MAS09851-Bit pattern of individual segment activation: left headlight-LED 19,OFF ,12
IDE09568-MAS09852-Bit pattern of individual segment activation: left headlight-LED 20,OFF ,12
IDE09568-MAS09853-Bit pattern of individual segment activation: left headlight-LED 21,OFF ,12
IDE09568-MAS09854-Bit pattern of individual segment activation: left headlight-LED 22,OFF ,12
IDE09568-MAS09855-Bit pattern of individual segment activation: left headlight-LED 23,OFF ,12
IDE09568-MAS09856-Bit pattern of individual segment activation: left headlight-LED 24,OFF ,12
IDE09568-MAS09857-Bit pattern of individual segment activation: left headlight-LED 25,OFF ,12
IDE09568-MAS09858-Bit pattern of individual segment activation: left headlight-LED 26,OFF ,12
IDE09568-MAS09859-Bit pattern of individual segment activation: left headlight-LED 27,OFF ,12
IDE09568-MAS09860-Bit pattern of individual segment activation: left headlight-LED 28,OFF ,12
IDE09568-MAS09861-Bit pattern of individual segment activation: left headlight-LED 29,OFF ,12
IDE09568-MAS09862-Bit pattern of individual segment activation: left headlight-LED 30,OFF ,12
IDE09568-MAS09863-Bit pattern of individual segment activation: left headlight-LED 31,OFF ,12
IDE09568-MAS09864-Bit pattern of individual segment activation: left headlight-LED 32,OFF ,12
IDE09568-MAS09865-Bit pattern of individual segment activation: left headlight-LED 33,OFF ,12
IDE09568-MAS09866-Bit pattern of individual segment activation: left headlight-LED 34,OFF ,12
IDE09568-MAS09867-Bit pattern of individual segment activation: left headlight-LED 35,OFF ,12
IDE09568-MAS09868-Bit pattern of individual segment activation: left headlight-LED 36,OFF ,12
IDE09568-MAS09869-Bit pattern of individual segment activation: left headlight-LED 37,OFF ,12
IDE09568-MAS09870-Bit pattern of individual segment activation: left headlight-LED 38,OFF ,12
IDE09568-MAS09871-Bit pattern of individual segment activation: left headlight-LED 39,OFF ,12
IDE09568-MAS09872-Bit pattern of individual segment activation: left headlight-LED 40,OFF ,12
IDE09568-MAS09873-Bit pattern of individual segment activation: left headlight-LED 41,OFF ,12
IDE09568-MAS09874-Bit pattern of individual segment activation: left headlight-LED 42,OFF ,12
IDE09568-MAS09875-Bit pattern of individual segment activation: left headlight-LED 43,OFF ,12
IDE09568-MAS09876-Bit pattern of individual segment activation: left headlight-LED 44,OFF ,12
IDE09568-MAS09877-Bit pattern of individual segment activation: left headlight-LED 45,OFF ,12
IDE09568-MAS11516-Bit pattern of individual segment activation: left headlight-LED 46,OFF ,12
IDE09568-MAS11517-Bit pattern of individual segment activation: left headlight-LED 47,OFF ,12
IDE09568-MAS11518-Bit pattern of individual segment activation: left headlight-LED 48,OFF ,12
IDE09568-MAS11519-Bit pattern of individual segment activation: left headlight-LED 49,OFF ,12
IDE09568-MAS11520-Bit pattern of individual segment activation: left headlight-LED 50,OFF ,12
IDE09568-MAS11521-Bit pattern of individual segment activation: left headlight-LED 51,OFF ,12
IDE09568-MAS11522-Bit pattern of individual segment activation: left headlight-LED 52,OFF ,12
IDE09568-MAS11523-Bit pattern of individual segment activation: left headlight-LED 53,OFF ,12
IDE09568-MAS11524-Bit pattern of individual segment activation: left headlight-LED 54,OFF ,12
IDE09568-MAS11525-Bit pattern of individual segment activation: left headlight-LED 55,OFF ,12
IDE09568-MAS11526-Bit pattern of individual segment activation: left headlight-LED 56,OFF ,12
IDE09568-MAS11527-Bit pattern of individual segment activation: left headlight-LED 57,OFF ,12
IDE09568-MAS11528-Bit pattern of individual segment activation: left headlight-LED 58,OFF ,12
IDE09568-MAS11529-Bit pattern of individual segment activation: left headlight-LED 59,OFF ,12
IDE09568-MAS11530-Bit pattern of individual segment activation: left headlight-LED 60,OFF ,12
IDE09568-MAS11531-Bit pattern of individual segment activation: left headlight-LED 61,OFF ,12
IDE09568-MAS11532-Bit pattern of individual segment activation: left headlight-LED 62,OFF ,12
IDE09568-MAS11533-Bit pattern of individual segment activation: left headlight-LED 63,OFF ,12
IDE09568-MAS11534-Bit pattern of individual segment activation: left headlight-LED 64,OFF ,12
IDE09568-MAS11535-Bit pattern of individual segment activation: left headlight-LED 65,OFF ,12
IDE09568-MAS11536-Bit pattern of individual segment activation: left headlight-LED 66,OFF ,12
IDE09568-MAS11537-Bit pattern of individual segment activation: left headlight-LED 67,OFF ,12
IDE09568-MAS11538-Bit pattern of individual segment activation: left headlight-LED 68,OFF ,12
IDE09568-MAS11539-Bit pattern of individual segment activation: left headlight-LED 69,OFF ,12
IDE09568-MAS11540-Bit pattern of individual segment activation: left headlight-LED 70,OFF ,12
IDE09568-MAS11541-Bit pattern of individual segment activation: left headlight-LED 71,OFF ,12
IDE09568-MAS11542-Bit pattern of individual segment activation: left headlight-LED 72,OFF ,12
IDE09568-MAS11543-Bit pattern of individual segment activation: left headlight-LED 73,OFF ,12
IDE09568-MAS11544-Bit pattern of individual segment activation: left headlight-LED 74,OFF ,12
IDE09568-MAS11545-Bit pattern of individual segment activation: left headlight-LED 75,OFF ,12
IDE09568-MAS11546-Bit pattern of individual segment activation: left headlight-LED 76,OFF ,12
IDE09568-MAS11547-Bit pattern of individual segment activation: left headlight-LED 77,OFF ,12
IDE09568-MAS11548-Bit pattern of individual segment activation: left headlight-LED 78,OFF ,12
IDE09568-MAS11549-Bit pattern of individual segment activation: left headlight-LED 79,OFF ,12
IDE09568-MAS11550-Bit pattern of individual segment activation: left headlight-LED 80,OFF ,12
IDE09568-MAS11551-Bit pattern of individual segment activation: left headlight-LED 81,OFF ,12
IDE09568-MAS11552-Bit pattern of individual segment activation: left headlight-LED 82,OFF ,12
IDE09568-MAS11553-Bit pattern of individual segment activation: left headlight-LED 83,OFF ,12
IDE09568-MAS11554-Bit pattern of individual segment activation: left headlight-LED 84,OFF ,12
IDE09568-MAS11555-Bit pattern of individual segment activation: left headlight-LED 85,OFF ,12
IDE09568-MAS11556-Bit pattern of individual segment activation: left headlight-LED 86,OFF ,12
IDE09568-MAS11557-Bit pattern of individual segment activation: left headlight-LED 87,OFF ,12
IDE09568-MAS11558-Bit pattern of individual segment activation: left headlight-LED 88,OFF ,12
IDE09568-MAS11559-Bit pattern of individual segment activation: left headlight-LED 89,OFF ,12
IDE09568-MAS11560-Bit pattern of individual segment activation: left headlight-LED 90,OFF ,12
IDE09569-MAS09833-Bit pattern of individual segment activation: right headlight-LED 1,OFF ,12
IDE09569-MAS09834-Bit pattern of individual segment activation: right headlight-LED 2,OFF ,12
IDE09569-MAS09835-Bit pattern of individual segment activation: right headlight-LED 3,OFF ,12
IDE09569-MAS09836-Bit pattern of individual segment activation: right headlight-LED 4,OFF ,12
IDE09569-MAS09837-Bit pattern of individual segment activation: right headlight-LED 5,OFF ,12
IDE09569-MAS09838-Bit pattern of individual segment activation: right headlight-LED 6,OFF ,12
IDE09569-MAS09839-Bit pattern of individual segment activation: right headlight-LED 7,OFF ,12
IDE09569-MAS09840-Bit pattern of individual segment activation: right headlight-LED 8,OFF ,12
IDE09569-MAS09841-Bit pattern of individual segment activation: right headlight-LED 9,OFF ,12
IDE09569-MAS09842-Bit pattern of individual segment activation: right headlight-LED 10,OFF ,12
IDE09569-MAS09843-Bit pattern of individual segment activation: right headlight-LED 11,OFF ,12
IDE09569-MAS09844-Bit pattern of individual segment activation: right headlight-LED 12,OFF ,12
IDE09569-MAS09845-Bit pattern of individual segment activation: right headlight-LED 13,OFF ,12
IDE09569-MAS09846-Bit pattern of individual segment activation: right headlight-LED 14,OFF ,12
IDE09569-MAS09847-Bit pattern of individual segment activation: right headlight-LED 15,OFF ,12
IDE09569-MAS09848-Bit pattern of individual segment activation: right headlight-LED 16,OFF ,12
IDE09569-MAS09849-Bit pattern of individual segment activation: right headlight-LED 17,OFF ,12
IDE09569-MAS09850-Bit pattern of individual segment activation: right headlight-LED 18,OFF ,12
IDE09569-MAS09851-Bit pattern of individual segment activation: right headlight-LED 19,OFF ,12
IDE09569-MAS09852-Bit pattern of individual segment activation: right headlight-LED 20,OFF ,12
IDE09569-MAS09853-Bit pattern of individual segment activation: right headlight-LED 21,OFF ,12
IDE09569-MAS09854-Bit pattern of individual segment activation: right headlight-LED 22,OFF ,12
IDE09569-MAS09855-Bit pattern of individual segment activation: right headlight-LED 23,OFF ,12
IDE09569-MAS09856-Bit pattern of individual segment activation: right headlight-LED 24,OFF ,12
IDE09569-MAS09857-Bit pattern of individual segment activation: right headlight-LED 25,OFF ,12
IDE09569-MAS09858-Bit pattern of individual segment activation: right headlight-LED 26,OFF ,12
IDE09569-MAS09859-Bit pattern of individual segment activation: right headlight-LED 27,OFF ,12
IDE09569-MAS09860-Bit pattern of individual segment activation: right headlight-LED 28,OFF ,12
IDE09569-MAS09861-Bit pattern of individual segment activation: right headlight-LED 29,OFF ,12
IDE09569-MAS09862-Bit pattern of individual segment activation: right headlight-LED 30,OFF ,12
IDE09569-MAS09863-Bit pattern of individual segment activation: right headlight-LED 31,OFF ,12
IDE09569-MAS09864-Bit pattern of individual segment activation: right headlight-LED 32,OFF ,12
IDE09569-MAS09865-Bit pattern of individual segment activation: right headlight-LED 33,OFF ,12
IDE09569-MAS09866-Bit pattern of individual segment activation: right headlight-LED 34,OFF ,12
IDE09569-MAS09867-Bit pattern of individual segment activation: right headlight-LED 35,OFF ,12
IDE09569-MAS09868-Bit pattern of individual segment activation: right headlight-LED 36,OFF ,12
IDE09569-MAS09869-Bit pattern of individual segment activation: right headlight-LED 37,OFF ,12
IDE09569-MAS09870-Bit pattern of individual segment activation: right headlight-LED 38,OFF ,12
IDE09569-MAS09871-Bit pattern of individual segment activation: right headlight-LED 39,OFF ,12
IDE09569-MAS09872-Bit pattern of individual segment activation: right headlight-LED 40,OFF ,12
IDE09569-MAS09873-Bit pattern of individual segment activation: right headlight-LED 41,OFF ,12
IDE09569-MAS09874-Bit pattern of individual segment activation: right headlight-LED 42,OFF ,12
IDE09569-MAS09875-Bit pattern of individual segment activation: right headlight-LED 43,OFF ,12
IDE09569-MAS09876-Bit pattern of individual segment activation: right headlight-LED 44,OFF ,12
IDE09569-MAS09877-Bit pattern of individual segment activation: right headlight-LED 45,OFF ,12
IDE09569-MAS11516-Bit pattern of individual segment activation: right headlight-LED 46,OFF ,12
IDE09569-MAS11517-Bit pattern of individual segment activation: right headlight-LED 47,OFF ,12
IDE09569-MAS11518-Bit pattern of individual segment activation: right headlight-LED 48,OFF ,12
IDE09569-MAS11519-Bit pattern of individual segment activation: right headlight-LED 49,OFF ,12
IDE09569-MAS11520-Bit pattern of individual segment activation: right headlight-LED 50,OFF ,12
IDE09569-MAS11521-Bit pattern of individual segment activation: right headlight-LED 51,OFF ,12
IDE09569-MAS11522-Bit pattern of individual segment activation: right headlight-LED 52,OFF ,12
IDE09569-MAS11523-Bit pattern of individual segment activation: right headlight-LED 53,OFF ,12
IDE09569-MAS11524-Bit pattern of individual segment activation: right headlight-LED 54,OFF ,12
IDE09569-MAS11525-Bit pattern of individual segment activation: right headlight-LED 55,OFF ,12
IDE09569-MAS11526-Bit pattern of individual segment activation: right headlight-LED 56,OFF ,12
IDE09569-MAS11527-Bit pattern of individual segment activation: right headlight-LED 57,OFF ,12
IDE09569-MAS11528-Bit pattern of individual segment activation: right headlight-LED 58,OFF ,12
IDE09569-MAS11529-Bit pattern of individual segment activation: right headlight-LED 59,OFF ,12
IDE09569-MAS11530-Bit pattern of individual segment activation: right headlight-LED 60,OFF ,12
IDE09569-MAS11531-Bit pattern of individual segment activation: right headlight-LED 61,OFF ,12
IDE09569-MAS11532-Bit pattern of individual segment activation: right headlight-LED 62,OFF ,12
IDE09569-MAS11533-Bit pattern of individual segment activation: right headlight-LED 63,OFF ,12
IDE09569-MAS11534-Bit pattern of individual segment activation: right headlight-LED 64,OFF ,12
IDE09569-MAS11535-Bit pattern of individual segment activation: right headlight-LED 65,OFF ,12
IDE09569-MAS11536-Bit pattern of individual segment activation: right headlight-LED 66,OFF ,12
IDE09569-MAS11537-Bit pattern of individual segment activation: right headlight-LED 67,OFF ,12
IDE09569-MAS11538-Bit pattern of individual segment activation: right headlight-LED 68,OFF ,12
IDE09569-MAS11539-Bit pattern of individual segment activation: right headlight-LED 69,OFF ,12
IDE09569-MAS11540-Bit pattern of individual segment activation: right headlight-LED 70,OFF ,12
IDE09569-MAS11541-Bit pattern of individual segment activation: right headlight-LED 71,OFF ,12
IDE09569-MAS11542-Bit pattern of individual segment activation: right headlight-LED 72,OFF ,12
IDE09569-MAS11543-Bit pattern of individual segment activation: right headlight-LED 73,OFF ,12
IDE09569-MAS11544-Bit pattern of individual segment activation: right headlight-LED 74,OFF ,12
IDE09569-MAS11545-Bit pattern of individual segment activation: right headlight-LED 75,OFF ,12
IDE09569-MAS11546-Bit pattern of individual segment activation: right headlight-LED 76,OFF ,12
IDE09569-MAS11547-Bit pattern of individual segment activation: right headlight-LED 77,OFF ,12
IDE09569-MAS11548-Bit pattern of individual segment activation: right headlight-LED 78,OFF ,12
IDE09569-MAS11549-Bit pattern of individual segment activation: right headlight-LED 79,OFF ,12
IDE09569-MAS11550-Bit pattern of individual segment activation: right headlight-LED 80,OFF ,12
IDE09569-MAS11551-Bit pattern of individual segment activation: right headlight-LED 81,OFF ,12
IDE09569-MAS11552-Bit pattern of individual segment activation: right headlight-LED 82,OFF ,12
IDE09569-MAS11553-Bit pattern of individual segment activation: right headlight-LED 83,OFF ,12
IDE09569-MAS11554-Bit pattern of individual segment activation: right headlight-LED 84,OFF ,12
IDE09569-MAS11555-Bit pattern of individual segment activation: right headlight-LED 85,OFF ,12
IDE09569-MAS11556-Bit pattern of individual segment activation: right headlight-LED 86,OFF ,12
IDE09569-MAS11557-Bit pattern of individual segment activation: right headlight-LED 87,OFF ,12
IDE09569-MAS11558-Bit pattern of individual segment activation: right headlight-LED 88,OFF ,12
IDE09569-MAS11559-Bit pattern of individual segment activation: right headlight-LED 89,OFF ,12
IDE09569-MAS11560-Bit pattern of individual segment activation: right headlight-LED 90,OFF ,12
IDE12488-Antenna 1 for short-range communication,General reject,12
IDE12489-Antenna 2 for short-range communication,General reject,12
IDE12648-MAS09833-Headlights left: low beam segment actuation-LED 1,OFF ,3
IDE12648-MAS09834-Headlights left: low beam segment actuation-LED 2,OFF ,3
IDE12648-MAS09835-Headlights left: low beam segment actuation-LED 3,OFF ,3
IDE12648-MAS09836-Headlights left: low beam segment actuation-LED 4,OFF ,3
IDE12648-MAS09837-Headlights left: low beam segment actuation-LED 5,OFF ,3
IDE12648-MAS09838-Headlights left: low beam segment actuation-LED 6,OFF ,3
IDE12648-MAS09839-Headlights left: low beam segment actuation-LED 7,OFF ,3
IDE12648-MAS09840-Headlights left: low beam segment actuation-LED 8,OFF ,3
IDE12648-MAS09841-Headlights left: low beam segment actuation-LED 9,OFF ,3
IDE12648-MAS09842-Headlights left: low beam segment actuation-LED 10,OFF ,3
IDE12648-MAS09843-Headlights left: low beam segment actuation-LED 11,OFF ,3
IDE12648-MAS09844-Headlights left: low beam segment actuation-LED 12,OFF ,3
IDE12648-MAS09845-Headlights left: low beam segment actuation-LED 13,OFF ,3
IDE12648-MAS09846-Headlights left: low beam segment actuation-LED 14,OFF ,3
IDE12648-MAS09847-Headlights left: low beam segment actuation-LED 15,OFF ,3
IDE12648-MAS09848-Headlights left: low beam segment actuation-LED 16,OFF ,3
IDE12648-MAS09849-Headlights left: low beam segment actuation-LED 17,OFF ,3
IDE12648-MAS09850-Headlights left: low beam segment actuation-LED 18,OFF ,3
IDE12648-MAS09851-Headlights left: low beam segment actuation-LED 19,OFF ,3
IDE12648-MAS09852-Headlights left: low beam segment actuation-LED 20,OFF ,3
IDE12649-MAS09833-Headlights right: low beam segment actuation-LED 1,OFF ,3
IDE12649-MAS09834-Headlights right: low beam segment actuation-LED 2,OFF ,3
IDE12649-MAS09835-Headlights right: low beam segment actuation-LED 3,OFF ,3
IDE12649-MAS09836-Headlights right: low beam segment actuation-LED 4,OFF ,3
IDE12649-MAS09837-Headlights right: low beam segment actuation-LED 5,OFF ,3
IDE12649-MAS09838-Headlights right: low beam segment actuation-LED 6,OFF ,3
IDE12649-MAS09839-Headlights right: low beam segment actuation-LED 7,OFF ,3
IDE12649-MAS09840-Headlights right: low beam segment actuation-LED 8,OFF ,3
IDE12649-MAS09841-Headlights right: low beam segment actuation-LED 9,OFF ,3
IDE12649-MAS09842-Headlights right: low beam segment actuation-LED 10,OFF ,3
IDE12649-MAS09843-Headlights right: low beam segment actuation-LED 11,OFF ,3
IDE12649-MAS09844-Headlights right: low beam segment actuation-LED 12,OFF ,3
IDE12649-MAS09845-Headlights right: low beam segment actuation-LED 13,OFF ,3
IDE12649-MAS09846-Headlights right: low beam segment actuation-LED 14,OFF ,3
IDE12649-MAS09847-Headlights right: low beam segment actuation-LED 15,OFF ,3
IDE12649-MAS09848-Headlights right: low beam segment actuation-LED 16,OFF ,3
IDE12649-MAS09849-Headlights right: low beam segment actuation-LED 17,OFF ,3
IDE12649-MAS09850-Headlights right: low beam segment actuation-LED 18,OFF ,3
IDE12649-MAS09851-Headlights right: low beam segment actuation-LED 19,OFF ,3
IDE12649-MAS09852-Headlights right: low beam segment actuation-LED 20,OFF ,3
IDE13611-Cornering lamp in operation,not active ,1
IDE13612-Matrix head lamps: steering angle,9600.00 ,2
IDE14431-ENG244972-Wireless charging: functions-Attenuation_internal_BTLE_antenna,General reject,2
IDE14431-ENG153904-Wireless charging: functions-NFC_MiKo_debug_switch,General reject,2
ENG153902-NFC_FS_debug_switch,General reject,2
ENG153904-NFC_MiKo_debug_switch,General reject,2
ENG124608-Order_Reference_Run_Activation_Effect,No dependency ,1
ENG124607-Reference_Run_Activation_Effect,Activation effect disabled ,1
ENG103979-Reference_Run_Start_Condition,Engine start ,1
Elapsed Time: 00:11
OccasionCenterVenlo
C?ID=549643
The old headlights were unusable anymore due to the crash damage, and the old ones were single DRL/blinker, and the new ones have dual DRL/blinkers. I should test the old ones, but there's a chance they have DLA.
vastechnics
C?ID=143747
Check coding in 4B, think that is not ok. need some good coding. You can make DLA work with good coding
downtime
Finland
C?ID=280813
DLA needs also dataset update in case the car did not have DLA earlier. And not just for the 4B but also LCMs need to be flashed on the headlights... How do I know...... :)
