Tire pressure reset not showing on MMI - A3 TDI MQB
sama13
Guatemala
C?ID=1044
Hello everyone, recently got a 2016 Audi A3 TDI (canadian market) and it is equipped with the traditional tire pressure monitoring thru the ABS speed wheel sensor, I wanted to reset the tire pressure and to my surprise it is not available thru the MMI on the service/control area, i checked if there was a button like on some older ones but nothing I even read the manual and it said it was done thru the MMI, I attach the auto-scan maybe a previous owner tampered with something and hide it somehow from displaying.
Thanks for the helping hand.
Thursday,07,November,2024,14:51:57:22246
VCDS Version: 24.7.1.0 (x64) HEX-V2 CB: 0.4643.4
VIN: WAUSRBFF6GA019871 License Plate:
Chassis Type: FF-AU37 (5Q0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 2B 3C 42 44 47 52 55 5F 6C
BB BC
VIN: WAUSRBFF6GA019871 Mileage: 37992km-23607miles
Address 01: Engine (J623-DEJA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 HH HW: 04L 907 309 S
Component: R4 2.0l TDI H23 4449
Revision: 85H23--- CVN: DB2AF0D692F1EF3C
Coding: 021D0112832410083000
Shop #: WSC 65535 000 00000
ASAM Dataset: EV_ECM20TDI01104L906021HH 004002
ROD: EV_ECM20TDI01104L906021HH.rod
VCID: 72BDD92E742A4FFA59F-8026
VINID: 9D1963892596197440049207045A7ED4BC
Readiness: 0 0 0 0 X
Part No SW: 0D9 300 041 H HW: 02E 927 770 AQ
Component: DQ250-6F MQB H53 4903
Revision: 06253104 Serial number: TFK01505290465 CVN: 0000CB6D
Shop #: WSC 04742 780 00200
ROD: EV_TCMDQ250021.rod
VCID: 1D67DA92DD34A08254D-8048
Part No SW: 3Q0 907 379 AA HW: 3Q0 907 379 F
Component: ESC H42 0623
Revision: 00000000 Serial number: 61625000000107
Coding: 12FF6A9224210A75017F020781C42548562450804081A4B2026100040208
Shop #: WSC 06314 790 00021
ROD: EV_Brake1UDSContiMK100IPB_034_AU37.rod
VCID: 79AFEE02295C3CA2185-802C
Revision: 00021000 Serial number: 0370150002 Dataset Number: 8V0909577C 0009
Coding: 030C0C
VCID: 3A2D310E6CDAF7BA51F-806E
Part No SW: 8V0 820 043 D HW: 8V0 820 043 D
Component: AC Automat H13 0060
Revision: 20027000 Serial number: 00000000673413
Coding: 03000114012000000000000000001400
VCID: 33331C2A4BB006F2929-8066
Humidity sensor: exterior:
Subsystem 1 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: 8C9886B7000000000001
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 085 AH HW: 5Q0 937 085 AE
Component: BCM MQBAB MNA H24 0173
Serial number: 01061517300797 Dataset Number: 8V0909514J 0089
Coding: 04151C46C04106FD41C44004531407A00800000000000000000000000000
ROD: EV_BCMBOSCH_015.rod
VCID: 7F5B001A37781292261-802A
Subsystem 1 - Part No SW: 8V1 955 119 A HW: 8V1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 150611 042 0580
Serial number: 150618033452
Coding: 0A47F7
Component: G397_RLFS H06 0002
Serial number: 24034136
Coding: 00006C
Subsystem 3 - Part No SW: 8V0 941 531 AA HW: 8V0 941 531 AA
Serial number: 18 04 2015 00000875
Serial number: 00000000000062944735
Sunroof control module:
Subsystem 5 - Part No SW: 8V3 959 591 A HW: 8V3 959 591 A
Component: J245 PS73.404 H03 0004
Serial number: 0000FST000DMX7300000
Coding: 101F00
Part No SW: 5Q0 919 294 K HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0054
Revision: -------- Serial number: 39391517006755 Dataset Number: 8V0909526E 0042
Coding: 0030150011
ROD: EV_EPHVA18AU3700000_VW26.rod
VCID: 43D34CEA1B10B672029-8016
Part No SW: 5Q0 959 655 J HW: 5Q0 959 655 J
Component: AirbagVW20 010 0830
Serial number: 003GCR02C15Z Dataset Number: 8V0909602G 0003
Coding: 9DFCFCC0000000005000001AC24800000065
VCID: 47CB58FA2F289A52DE1-8012
Left seat belt tensioner:
Component: BeltPretRevFL H36 0350
Serial number: 34178311B21051570025
Coding: 333135
Right seat belt tensioner:
Component: BeltPretRevFR H36 0350
Serial number: 34178312B21051540382
Coding: 333135
Subsystem 3 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Serial number: 694000000000001CZ82Y
Coding: 303334
Subsystem 4 - Part No SW: ----------- HW: 480 002 206 15
Serial number: 3570000000021445051.
Subsystem 5 - Part No SW: ----------- HW: 480 002 206 15
Serial number: 3580000000032445051/
Subsystem 6 - Part No SW: ----------- HW: 480 402 306 15
Serial number: 3510002A91B65D5490DB
Subsystem 7 - Part No SW: ----------- HW: 480 402 306 15
Serial number: 3520002AD1C52F34220
Subsystem 8 - Part No SW: ----------- HW: 480 402 705 15
Serial number: 3550002BF1A14CC2629E
Subsystem 9 - Part No SW: ----------- HW: 480 402 705 15
Component: FrontSensor_P 001 6149
Serial number: 3560002C11A14CC5119%
Part No SW: 8V0 953 521 FB HW: 5Q0 953 549 E
Component: Lenks. Modul 003 0110
Revision: -------- Serial number: 23061508490108
Coding: A418
ROD: EV_SMLSKLOMQB_010_VW37.rod
Part No SW: 8V0 920 871 S HW: 8V0 920 871 S
Component: KOMBI H03 6420
Coding: 0BA50A192A8800080200FB001800000000000000
VCID: 4CC167D6364E790AF33-8018
Part No SW: 5Q0 907 530 AF HW: 5Q0 907 530 F
Component: GW MQB High 128 1223
Revision: -------- Serial number: 0003617622 Dataset Number: 8V0909515J 0062
Coding: 01010008100876005B00020C180B00000001010000000000000000000000
GVL: 01543C0000000600404C10000002C80000000000000000000000000000000000
ROD: EV_GatewLear_013.rod
VCID: 75B7E232054458C27CD-8020
Generator:
Subsystem 2 - Part No SW: 8U0 951 528 C HW: 8U0 951 528 C
Component: E221 - MFL H02 0014
Serial number: 03 06 2015 D0008303
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 15000168201010
Coding: 5D00000000000000
VCID: 34311F364EBE01CA8B3-8060
Part No SW: 5Q0 907 566 A HW: 8T0 907 566 B
Component: SWA Master H05 0080
Serial number: 0369571301 Dataset Number: 8V0909535E 0033
Coding: 030211
ROD: EV_LaneChangAssis_VW52.rod
VCID: 38292B0652D6E5AAA7B-806C
Subsystem 1 - Part No SW: 5Q0 907 568 A HW: 8T0 907 568 B
Component: SWA Slave H05 0080
Serial number: 0371175828
Coding: 030211
Component: TSG FS 020 0041
Serial number: 260515BEP01573 Dataset Number: 8V0909872G 0035
Coding: 005D1B204000048000000002
ROD: EV_DCUDriveSideEWMAXKLO.rod
Part No SW: 5Q0 909 144 R HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 125 1061
Dataset Number: 8V0909852K 0022
Coding: 8102
Part No SW: 8V0 035 465 D HW: 8V0 035 465
Component: MIBAMP1ALPINE H11 0420
Serial number: AUZ8ZAFN901CC7Z Dataset Number: 8V0909510D 0019
Coding: 01030300AAAA2AAA01
ASAM Dataset: EV_AMPMst16C1ALPI 004024
ROD: EV_AMPMst16C1ALPI_004_AU37.rod
VCID: 392F2E0269DCFCA2585-806C
Component: TSG BFS 020 0041
Serial number: 050615BF504382 Dataset Number: 8V0909873G 0035
Coding: 005D13204000048000000002
ROD: EV_DCUPasseSideEWMAXKLO.rod
VCID: 42DD49EE040ABF7A09F-8016
Part No SW: 7P6 907 357 C HW: 7P6 907 357 B
Component: AFS-ECU H01 0110
Revision: -------- Serial number: -------------- Dataset Number: 8V0909865L 0039
Coding: 010A000123200400
VCID: 3FDB401A77F8D292661-806A
Coding: E00100
Coding: E00100
Subsystem 3 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M Labels: 3D0-941-329.CLB
Component: LeiMo links H01 7050
Coding: E00100
Subsystem 4 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 7050
Coding: E00100
Address 5F: Information Electr. (J794) Labels:| 8V0-035-MIB-HGH1.clb
Part No SW: 8V0 035 047 G HW: 8V0 035 047 B
Component: MU-H-NS-US H43 0394
Serial number: A052F0FB006807 Dataset Number: 8V2909545H 0046
Coding: 017303020000000021220002041A00002F000124010001047E
ROD: EV_MUHig6C3HBAS_VW48.rod
Subsystem 1 - Part No SW: V03 959 800 SS HW: -----------
Component: NAR 2015 --- 0035
Multimedia System 1:
Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0014
Serial number: AUZ8Z9FY203GPL
Subsystem 3 - Part No SW: 8V0 919 614 L HW: 8V0 919 614 L
Component: ControlUnit_H H81 0816
Serial number: C1000029041500030267
Compact disc data bank:
Component: Gracenote --- 3006
Reset counter: 77
Mileage: 37992 km
Date: 2024.11.01
Time: 14:48:15
Voltage terminal 30: 12.4 V
Satellite radio tuner status-Audio Signal: available.
Satellite radio tuner status-Reception quality: good_signal
Satellite radio tuner status-SDARS Flash Regional code: US_Audio_Traffic_Travellink
Part No SW: 5Q0 907 441 A HW: 5Q0 907 441 A
Component: MQB RVC Mid H07 0140
Dataset Number: 8V0909460C 0017
Coding: 027300010201000300
ROD: EV_2CamSysRearPASE_AU37.rod
VCID: 30391326BAA63DEAEFB-8064
Part No SW: 5Q0 959 395 E HW: 5Q0 959 395 B
Component: TSG HFS 020 0041
Serial number: 180515BEG16719 Dataset Number: 8V0909897E 0021
Coding: 004D13204000048000000002
ROD: EV_DCURearDriveMAXKLO.rod
Component: TSG HBFS 020 0041
Serial number: 180515BEG1671C Dataset Number: 8V0909896E 0021
ROD: EV_DCURearPasseMAXKLO.rod
End----------(Elapsed Time: 01:38, VBatt start/end: 12.3V/12.3V)-----------
hmmm, I see what you mean. It may have been "unchecked" from the gateway list. I'm not sure how to access, but if you locate under "gateway list" check the box for TPMS .
Take a look at this interactive manual ; scroll down to the INDEX.
sama13
Guatemala
C?ID=1044
Well i thought it wouldn't be useful as the car has rubber valves so not real tpms so I activated it on the GW but error as it cannot find it, i think is something directly on the mmi not showing.
Maybe ABS -> Basic Settings:
IDE05334-ENG114972 -- Reset tire pressure monitoring display warnings
sama13
Guatemala
C?ID=1044
I tried and got a request out of range, tried reset to factory setting and got malfunction
