Audi Q7 4M Steering Assist Faults
SeattleMatt
C?ID=282387
I'm hoping someone on here can help me with these codes.
Just purchased a 2017 Q7 with a few minor issues. I usually avoid used dealers at all costs, but the price on this was good and I felt like i could handle the issues. It is clear that the dealer/PO replaced some components such as steering rack, and suspension, but likely did not code it all back in correctly. There are no accidents on the carfax report, but that doesn't mean something didn't happen. I've been following some steps to get the parts adapted, but I'm running into some stuck codes.
I tried clearing the Steering Assist controller and the codes come back immediately. This thread looks promising, but I haven't been able to find [80] module in my UI. Originally there were codes for crash sensor which I cleared successfully, but the steering codes came after that.
Sunday,17,November,2024,12:18:08:10308
VCDS Version: 24.7.0.0 (x64)
VIN: WA1LAAF7XHD014801   License Plate:
Mileage: 218993km-136075mi   Repair Order:
Chassis Type  F7-AU73 (8W6)
Scan: 01 02 03 06 08 09 15 16 17 19 29 36 39 3C 42 44 46 47 50 52
          5F 6C 6D 81 A5 BB BC CA CF D6 D7
VIN: WA1LAAF7XHD01XXXX   Mileage: 218993km-136075miles
29-Left Light -- Status: INTERFACE NOT COMPATIBLE
39-Right Light -- Status: INTERFACE NOT COMPATIBLE
50-Seat Adj. 3rd row -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: INTERFACE NOT COMPATIBLE
D7-Light Ctrl Right 2 -- Status: INTERFACE NOT COMPATIBLE
Address 01: Engine (J623-CREC)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 4M0 907 551 A    HW: 06E 907 425
   Component: 3.0l V6 TFSI  H10 0005
   Revision: --H10---    CVN: 08BDF7A0
   Coding: 2A2A00320526010D74280000000000000000000000000000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_ECM30TFS0214M0907551A 001007
   ROD: EV_ECM30TFS021_AU73.rod
   VCID: 2D5175A27C397AFE58-8078
   VINID: 9D105C451587A1850004420004CD13DCDE
24194 - PCV Valve Malfunction
          P052E 00 [00100111] - -
                    Mileage: 218991 km
                    Date: 2024.11.17
                    Time: 11:58:46
                    Engine RPM: 678.50 /min
                    Normed load value: 25.1 %
                    Coolant temperature: 94 °C
                    Intake air temperature: 49 °C
                    Voltage terminal 30: 14.140 V
                    Air mass: 17.90625 kg/h
                    Pressure upstream of throttle valve: corrected: 1.011 bar
                    Charge press.: average: 0.466 bar
                    Throttle valve angle: 2.465 °
                    Ambient air pressure: 1.012 bar
                    Accelerator pedal position: 0.00 %
                    Outside temperature: 18.0 °C
Readiness: 1010 1101
   Part No SW: 4M0 927 158 L    HW: 0D5 927 156 H
   Component: 0D5  30TSIUSA H03 1003
   Revision: --H03---    CVN: 3655CB50
   Coding: 100000
   ASAM Dataset: EV_TCMALX52011 002010
   ROD: EV_TCMALX52011.rod
   VCID: 3D7145E2AC59EA7EE8-8068
Address 03: ABS Brakes (J104)       Labels: 4M0-907-379-V1.clb
   Part No SW: 4M0 907 379 R    HW: 4M0 907 379 N
   Component: ESP9 Premium  H09 0653
   Dataset Number: 4M0909504L  0001 CVN: B1C8DCF9
   Coding: 28AA149C30A30A9A91A65891007E5292E6269A14280C50891A004A49676459
   ASAM Dataset: EV_ESP9BOSCHAU536K 012013
   ROD: EV_ESP9BOSCHAU536K_AU73.rod
   VCID: 46832A0EF98FA9A6B9-8012
   Part No SW: 4M0 959 760     HW: 4M0 959 760
   Component: MEM-BFS       008 0015
   Serial number: 00000196040490 Dataset Number: 4M0909866B  0013
   Coding: 000410000000B0010000210101010000000000000000000000000000000000
   ASAM Dataset: EV_SCMPasseSideCONTIAU736 006007
   ROD: EV_SCMPasseSideCONTIAU736_AU49.rod
   VCID: 75E19DC2D4E9723EE0-8020
   Part No SW: 4M0 820 043 R    HW: 4M0 820 043 R
   Component: Klima Zone 3  H52 0081
   Coding: 6608090C5144000D10200180000000000000000000000000000000000000
   Shop #: WSC 17180 005 1048576
   ASAM Dataset: EV_AirCondiFrontBHTCAU736 001013
   ROD: EV_AirCondiFrontBHTCAU736.rod
   VCID: 346760C69F132B3617-8060
   Subsystem 1 - Part No SW: 4M1 820 021     HW: 4M1 820 021
   Component: J216 FLuftV  H05 0001
   Serial number: 00000000000000821915
   Humidity sensor: exterior:
   Subsystem 2 - Part No SW: 4G0 907 658 B    HW: 4G0 907 658 B
   Component: Humidity_Sens  H01 0003
   Serial number: 8168CD18000000000001
   Subsystem 3 - Part No SW: 8W0 919 158     HW: 8W0 919 158
   Component: Klima Heck  H34 0050
Address 09: Cent. Elect. (J519)       Labels:* Redir Fail!
   Part No SW: 8W0 907 063 AG    HW: 8W0 907 063 G
   Component: BCM1 MLBevo   H12 0228
   Dataset Number: 4M0909514M  0047
   Coding: 07500363E0081CCD010D8715582E1CB911033D01900000000000000020001A0108690122025509
   ASAM Dataset: EV_BCM1BOSCHAU736 015005
   ROD: EV_BCM1BOSCHAU736_015.rod
   VCID: 000FFC169B2B4796C3-8054
   Subsystem 1 - Part No SW: 4M1 955 119 A    HW: 4H2 955 119 C  Labels: 1KX-955-119.CLB
   Component: WWS536 160227  043 0893
   Serial number: 895553?0401605800937
   Coding: 1BC7F7
   Serial number: 61632257
   Coding: 02006E
   Subsystem 3 - Part No SW: 4M0 941 531 AA    HW: 4M0 941 531 AA
   Component: E1 - LDS  H06 0008
   Serial number: 17 03 2016  00285020
   Subsystem 4 - Part No SW: 4M0 907 410 A    HW: 4M0 907 410 A
   Component: USHL5  H04 0050
   Serial number: 0000009600335Z0SSK02
   Coding: 350000
   Garage door opener control head:
   Subsystem 5 - Part No SW: 4M0 959 719 A    HW: 4M0 959 719 A
   Component: GTO BF  H01 0010
   Serial number: 20160304145536 00475
   Subsystem 6 - Part No SW: 4M0 857 511 B    HW: 4M0 857 511 B
   Component: Y7_Innenspieg  H04 0002
   Serial number: GX1CE130031611520992
   Coding: 030000
   Interior Light Module:
   Subsystem 7 - Part No SW: 4M0 947 135 AN    HW: 4M0 947 135
   Component: J528-Dachele  H13 0082
   Serial number: Q00116660
   Subsystem 8 - Part No SW: 4M0 907 705 A    HW: 4M0 907 705 A
   Component: J866-EVLS-SG  H03 0060
   Serial number: WA121128000014044408
   Coding: 020100
   Subsystem 9 - Part No SW: 4M0 925 301 A    HW: 4M0 925 301 A
   Component: SL-Q7NF/AU736  H10 0013
   Serial number: 00000000000000044531
   Part No SW: 4M0 959 655 A    HW: 4M0 959 655 A
   Component: Airbag10.44   H71 0086
   Serial number: 003M5000GHXA Dataset Number: 4M0909602WP 0001
   Coding: AECCFCC000800000A0F00033C24C00000000
   Shop #: WSC 48651 001 1048576
   ASAM Dataset: EV_AirbaAU10BPAAU736 005012
   ROD: EV_AirbaAU10BPAAU736_005.rod
   VCID: 397951F2B871D65EC4-806C
   Left seat belt tensioner:
   Subsystem 1 - Part No SW: 4M0 980 945     HW: 4M0 980 945
   Component: BeltPretRevFL  205 2033
   Serial number: 4M0857705E0103Q00116
   Coding: 88001B
   Right seat belt tensioner:
   Subsystem 2 - Part No SW: 4M0 980 946     HW: 4M0 980 946
   Component: BeltPretRevFR  205 2033
   Serial number: 4M0857706E0103Q00656
   Coding: 88001B
   Serial number: IBH0000J160004TUM20U
   Subsystem 4 - Part No SW: -----------    HW: 442 062 303 16
   Serial number: 3577Y00B31DE1402322Q
   Subsystem 5 - Part No SW: -----------    HW: 442 062 303 16
   Serial number: 3587Y009D1C5CD4411AD
   Subsystem 6 - Part No SW: -----------    HW: 442 0B2 203 16
   Serial number: 3517700B51F93E32C12F
   Subsystem 7 - Part No SW: -----------    HW: 442 0B0 903 16
   Serial number: 35277009D1F93E32810G
   Subsystem 8 - Part No SW: -----------    HW: 442 0C2 403 16
   Serial number: 3557500AB1FE78C6517-
   Subsystem 9 - Part No SW: -----------    HW: 442 0C2 403 16
   Serial number: 3567500AD1FE78C4804-
   Central crash sensor X/Y:
   Subsystem 10 - Part No SW: -----------    HW: 410 201 603 16
   Component: CentrSensorXY  1C8 0108
   Serial number: I0O78009D1EE7E43C0DW
   Part No SW: 4M0 907 129 GD    HW: 4M0 907 129 GD
   ROD: EV_SMLSKLOAU736_006.rod
   VCID: 78FF94F6C3FB0F56FB-802C
   Part No SW: 4M0 920 890 A    HW: 4M0 920 890 A
   Component: FBenUSA       H13 0280
   Coding: 08E600C12888D7050223E9601800000000000000
   ASAM Dataset: EV_DashBoardAU736 001020
   ROD: EV_DashBoardAU736_AU73.rod
   VCID: 2E5372AE713F01E661-807A
   Part No SW: 8W6 907 468     HW: 8W6 907 468
   Component: Gateway       H11 3079
   Revision: 3R050040    Serial number: 4083R012416406 Dataset Number: 4M0909515H  0061
   Coding: 0301000100000F4052070000005900304C120007008000000150000000000000
   GVL: 01503C000800000040FC08000002C800100C2000000000000000000000000000
   ASAM Dataset: EV_CGateCONTIAU491 002040
   ROD: EV_CGateCONTIAU491_002_AU49.rod
   VCID: 071DE70ABE0570AE82-8052
   Subsystem 1 - Part No SW: 4M0 951 523     HW: 4M0 951 523
   Component: J453 MFL  H06 0002
   Serial number: 20160329113201 00615
   Subsystem 2 - Part No SW: 8S0 915 181     HW: 8S0 915 181
   Component: J367-BDMHella  H10 9052
   Serial number: 6700259703
Address 29: Left Light
Interface not compatible.
Please upgrade to a current Ross-Tech interface.
   Component: MEM-FS        008 0015
   Serial number: 00000196092420 Dataset Number: 4M0909856B  0013
   Coding: 001C1B000000B0010000210101010000000000000000000000000000000000
   ASAM Dataset: EV_SCMDriveSideCONTIAU736 006007
Address 39: Right Light
Address 3C: Lane Change (J769)       Labels:| 4M0-907-566.clb
   Part No SW: 4M0 907 566 B    HW: 4M0 907 566
   Component: MRR1Rear      H13 0230
   Revision: --------    Dataset Number: 4M0909535K  0013
   Coding: 0E8002
   ASAM Dataset: EV_RearRadarS1BoschAU736 001015
   Part No SW: 4M0 959 793 G    HW: 4M0 959 793 C
   Component: TSG FS        009 0052
   Serial number: 0000194035132  Dataset Number: 4M0909872F  0025
   Coding: 005F9B005E001080000120B0
   ROD: EV_DCU2DriveSideMAXHCONT_AU37.rod
   VCID: 428B361ED5A7958695-8016
   Part No SW: 4M0 909 144 G    HW: 4M0 909 144 B
   Component: EPS_MLBEVO1BS H20 0004
   Serial number: 0000922882 Dataset Number: 4M0909852G  0022
   Coding: B0000101000101
   ASAM Dataset: EV_EPSVWBSAU736 008020
   ROD: EV_EPSVWBSAU736_008.rod
   VCID: 336563DA9A1D2C0E0E-8066
3149825 - Databus
                    Reset counter: 90
                    Mileage: 218991 km
                    Date: 2024.11.17
                    Time: 11:57:18
                    FreezeFrame_mw_120C_Timeout-Engine RPM: 0 /min
                    FreezeFrame_mw_120C_Timeout-System status: Reset
                    FreezeFrame_mw_120C_Timeout-Terminal 30 power supply: 14.62 V
                    FreezeFrame_mw_120C_Timeout-Terminal 15 status measured: On
                    FreezeFrame_mw_120C_Timeout-Engine steering torque sensor: average value: 0.00 Nm
                    FreezeFrame_mw_120C_Timeout-Terminal 15 resulting: On
                    FreezeFrame_mw_120C_Timeout-Terminal 15 status signal: On
                    FreezeFrame_mw_120C_Timeout-Steering pinion angle: offset corrected: 4.83 °
                    FreezeFrame_mw_120C_Timeout-ARA signal red cyclic: 00
                    FreezeFrame_mw_120C_Timeout-PLA signal red cyclic: 00
                    FreezeFrame_mw_120C_Timeout-SCU state: System OK
                    FreezeFrame_mw_120C_Timeout-Steering_angle_sender_status: System OK
5258753 - Steering End Stops Not Learned
          C10AC F0 [10001001] - Unknown Error Elaboration
                    Reset counter: 90
                    Mileage: 218991 km
                    Date: 2024.11.17
                    Time: 11:57:18
                    FreezeFrame_mw_1216_EAL-Steering wheel angle: 00 32
                    FreezeFrame_mw_1216_EAL-Reason of EA unlearn: 00
                    FreezeFrame_mw_1216_EAL-SCU motor angle BUS: 4094 °
5570561 - Databus
                    Reset counter: 90
                    Mileage: 218991 km
                    Date: 2024.11.17
                    Time: 11:57:18
                    FreezeFrame_mw_1212-Vehicle speed: 0 km/h
                    FreezeFrame_mw_1212-Error Mask driver assistance functions: 00 00
                    FreezeFrame_mw_1212-Eventmask_IMS: 80 00
                    FreezeFrame_mw_1212-IMS Status AWA: 03
                    FreezeFrame_mw_1212-IMS Status DSR: 03
                    FreezeFrame_mw_1212-IMS Status HCA: 03
                    FreezeFrame_mw_1212-IMS Status STA: 04
                    FreezeFrame_mw_1212-Internal torque: 0.00
3148801 - Databus
                    Reset counter: 90
                    Mileage: 218991 km
                    Date: 2024.11.17
                    Time: 11:57:18
Address 46: Central Conv.
   Part No SW: 4M0 035 223 A    HW: 4M0 035 223
   Component: MIB2_amp_PD   H02 0420
   Serial number: 00000000025676 Dataset Number: 4M1909510C  0008
   Coding: 0135060A008AF53AAF0000010000
   ASAM Dataset: EV_AMPMst16C4Gen2BOSE 001001
   ROD: EV_AMPMst16C4Gen2BOSE_AU73.rod
   VCID: 2149999230E1AE9EEC-8074
Address 50: Seat Adj. 3rd row
   Part No SW: 4M0 959 792 G    HW: 4M0 959 792 C
   Component: TSG BFS       009 0052
   Serial number: 0000194537499  Dataset Number: 4M0909873F  0025
   ROD: EV_DCU2PasseSideMAXHCONT_AU37.rod
   VCID: 41893912D0A18E9E8C-8014
Address 5F: Information Electr. (J794)       Labels:* 4M0-035-MIB-HGH2.clb
   Part No SW: 4M0 035 880 M    HW: 4M0 035 880
   Component: MU-P-LNS-US   051 0443
   Serial number: A289D0GB010822 Dataset Number: 4M0909545G  0034
   Coding: 013706020000000013220002041A00102F001BE501700104FE
   VCID: 36635ACE896F392629-8062
   Subsystem 1 - Part No SW: V03 959 801 GH    HW: -----------
   Component: NAR 2017/2018  --- 0060
   Multimedia System 1:
   Subsystem 2 - Part No SW: 4M0 919 605     HW: 4M0 919 605
   Component: AU536_DU_HIGH  H43 0008
   Serial number: AUZ8Z9GJ401XTZ
   Subsystem 3 - Part No SW: 4M0 919 615 D    HW: 4M0 919 615 D
   Component: ControlUnit_P  H14 0165
   Serial number: 07041600000000000056
   Compact disc data bank:
   Component: Gracenote2  --- 3007
   Part No SW: 4M0 907 428 D    HW: 4M0 907 428
   Component: Areaview 2    H11 0311
   Serial number: C854606JG004420 Dataset Number: 4M1909460F  0018
   Coding: 02350602BA0FA10008404004
   ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 004015
   ROD: EV_CamSysRVAV2CE2MLBEv_004.rod
   Part No SW: 8W8 959 107     HW: 8W8 959 107
   Component: HDSG-Modul    H13 0153
   Revision: --------    Serial number: 30582316800000 Dataset Number: 4M0909541F  0023
   Coding: 0030
   ASAM Dataset: EV_DeckLidCONTIAU736 001012
   VCID: 0603EA0EB90F69A6F9-8052
   Part No SW: 4M1 713 041 D    HW: 4M1 713 041 D
   Component: GSM-LL        H07 0068
   Revision: 0L0D5012    Serial number: 20160321003611
   ASAM Dataset: EV_GSMWaehlZFAU736 001013
   ROD: EV_GSMWaehlZFAU736_AU72.rod
   VCID: 26438A8E59CF49A699-8072
   Part No SW: 4M0 907 217 D    HW: 4M0 907 217 A
   Component: BVS           H13 0042
   Dataset Number: 4M0909466J  0038
   Coding: 0407030600000201022023A2A50000B400F0C020C000
   ROD: EV_BVSMLBevKOSTAAU736_AU73.rod
   VCID: 2F6D6FAA763508EE6A-807A
   Part No SW: 4M0 959 795 G    HW: 4M0 959 795 C
   Component: TSG HFS       009 0052
   Serial number: 0000194909224  Dataset Number: 4M0909897F  0026
   Coding: 004F9B0000001080400020A0
   ROD: EV_DCU2RearDriveMAXHCONT_VW37.rod
   VCID: 44873006CFB39BB6A7-8010
   Component: TSG HBFS      009 0052
   Serial number: 0000194908950  Dataset Number: 4M0909896F  0026
   ROD: EV_DCU2RearPasseMAXHCONT_VW37.rod
Address CA: Sunroof
Address CF: Lane Chge Asst 2
Address D6: Light Ctrl Left 2
Address D7: Light Ctrl Right 2
End-------------------------(Elapsed Time: 06:15)--------------------------
SeattleMatt
C?ID=282387
Ok, that would explain it. So, moving on from there, I believe my next step may be to perform a steering adaptation, but when I enter basic settings I only have the drop down with 4 options, not the menu described in the in the 83g or 4g steering angle adaptations.
SeattleMatt
C?ID=282387
Ok, I was able to get the steering angle done, I was using the wrong controller, I wasn't in 16.
Now the remaining codes are back to the 3 for Steering Assist
3149825 - Databus
[Message_ACC_10_Time_Out]
5570561 - Databus
3148801 - Databus
[COMI_TIMEOUT_ACC07]
SeattleMatt
C?ID=282387
The most likely scenario here is that there is an adaptation necessary for the new steering rack which has not been performed. I searched around and was unable to find anything beyond the steering angle settings. The rack is working perfectly and beyond these 3 codes there is nothing else that I can find that indicates a problem with the rack. ( I do know the PCV valve needs replacement)
SeattleMatt
C?ID=282387
I know that my cable is from 2007, so it has no UDS. Does this prevent me from clearing these codes, or does it just prevent me from getting the descriptions?
This premise is incorrect. It clearly communicates with a number of modules in your vehicle that use UDS. However, it does not support a few of the features on UDS modules that newer cables do, and lacks the addressing modes required to access some of the control modules in that car.
It does not prevent you from clearing faults in any control module that you can access with it.
SeattleMatt
C?ID=282387
Uwe,
Thanks for clarifying, I know my cable is part of ancient history, but I can't let it go :).
Actually I was almost 10 years off, I purchased it in 2016.
Your order #100094070​
Placed on July 26, 2016 10:11:04 PM EDT
Item in your orderQtyPrice
VAG-COM Diagnostic Tool with HEX-USB+CAN Interface
SKU: 000035
1$349.00
Doesn't matter, but I was happy to find my original invoice
golfi_vend
Tartu, Estonia
C?ID=195131
I wonder why people assume this? I have a fleabay cable from 2005, cost 10eur and with my own program it can communicate with UDS very well.
Westbury, UK
UDS is a function of the modules fitted to the car, it is not related to the diagnostic cable.
SeattleMatt
C?ID=282387
The reason for the assumption is the messaging in the software.
Implausible Message
SeattleMatt
C?ID=282387
Back to original issue.
So current status is still just those 3 codes. Any ideas on adaptations for the j500?
golfi_vend
Tartu, Estonia
C?ID=195131
Have You tired fixing the fault of Steering ends, by just turning the wheel to MAX Mechanical Stop on both ends?
SeattleMatt
C?ID=282387
Yep, that cleared and took me from 4 codes down to 3 :)
golfi_vend
Tartu, Estonia
C?ID=195131
you have acc warnings, but no acc. Indicates wrong coding is 44 or adaption or dataset.
SeattleMatt
C?ID=282387
Can you clarify what is meant by " is 44 or adaption or dataset." ?
golfi_vend
Tartu, Estonia
C?ID=195131
Module 44 is Steering Assist(Steering rack), fault code indicates missing message from ACC. This means that module is coded/adapted/calibrated to think car has ACC installed. Check possible coding options to clear that option. Or Adaption channels.
If it is in memory where dataset is used to set this option, You probably need to visit a dealer or someone smarter than dealer to get it fixed. Without looking into parts catalogue, if this option is based on HW, that means incorrect unit is installed.
Dealer option only if the unit is correct and follows correct supersession path. Also sometimes SVM code is needed to update coding with ODIS, but smart dealer would know this.
XCHG44A001
SeattleMatt
C?ID=282387
I found this thread which mentions a similar if not identical issue. @piotr303 did you resolve this issue?
