MK6 Golf TDI - Foglights inoperative
DEMON-S8
NY. USA
C?ID=56124
Hello All,
With guidance from memebers on the group, I've recently corrected a no start issue I was having with my MK6 Golf TDI. Part of the remedy to correct the no start issue was replacing the BCM.
I recently noticed however that the fog lights are inoperable. I have continuity from the light switch to the BCM, from BCM to the fog lights. But am getting no voltage out of the BCM to fog light, the bulbs are good.
In the BCM I can enable /disable fog lights (coding accepted) , which leads me to believe the BCM has protocols for foglights.
When I switch on the fog lights the LED indicator illuminates on the switch, however it doesn't reflect that the fog lights are engaged in BCM measuring blocks.
Post of full scan to follow if necessary.
Thanks!
Jef
HQ
DEMON-S8
NY. USA
C?ID=56124
Lol.
DEMON-S8
NY. USA
C?ID=56124
Below is Scan from October when I had seat airbag sensor issue,
(🙄unplugged connector).
VCDS Version: 24.7.1.0
Workshop Code: 444 08310 000118
VIN: WVWBM7AJ8CW283276   License Plate:
Mileage: 119200km-74067mi   Repair Order: airbag fault
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 37 42 44 46 47 52 55
          56
VIN: WVWBM7AJ8CW283276   Mileage: 119200km-74067miles
   Part No SW: 03L 906 019 HG    HW: 03L 907 309 AA
   Component: R4 2,0L EDC G000AG  2261
   Revision: 12H14---    Serial number: 00000000000000
   Coding: 0050078
   VCID: F7F7C1628657822E7A-80A2
   VINID: 9E69D274745A2139C22030871804DD7344
   Part No SW: 02E 300 057 P    HW: 02E 927 770 AL
   Component: GSG DSG AG6     512 3102
   Revision: 05551213    Serial number: 00001202240220
   VCID: A649DC26117DCBA611-80F2
   Revision: 00H31001
   Coding: 114B400C492A00FD880D02EB921F0042B70000
   VCID: FBFFDD527A7FA64E1E-80AE
   Part No SW: 5K0 959 434 B    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 085 0902
   Revision: 00085000    Serial number: 0169043623 Dataset Number: 5K0116v____ 5K0C
   Coding: 030C0C
   ROD: EV_KESSYPQ35G_A02_VW32.rod
   VCID: B46D366E1FA1A9369F-80E0
   Part No SW: 7N0 907 426 AN    HW: 7N0 907 426 AN
   Component: AC Manuell    H19 0404
   Revision: 00001018
   Coding: 0000001002
   VCID: 8005AABE1B99C5964B-80D4
   Part No SW: 1K0 937 084 J    HW: 1K0 937 084 J
   Component: BCM PQ35  B   111 0709
   Revision: AB111709
   Coding: 6F180A3B98673A04108800C07500890448052086574D85B0E48400208040
   Shop #: WSC 08310 444 00118
   VCID: B56B0B6A1CDBB03EA8-80E0
   Subsystem 1 - Part No: 5K1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 23021  26  0512
   Coding: 009795
   Part No SW: 5K0 959 655 H    HW: 5K0 959 655 H
   Component: AirbagVW10G   013 0724
   Serial number: 003GVRA1NGYW   Dataset Number: 5K0003v__B_ 0068
   Coding: 00003131
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: BF87694226E77A6E72-80EA
   Subsystem 1 - Part No SW: 5K0 959 339 B    HW: 5K0 959 339 B
   Component: BF-Gewichtss.  006 0001
   Serial number: ---0000R--00002RF700
   Serial number: 3572MSME4E42656AZZZ1
   Serial number: 3582MSME19594063ZZZV
   Serial number: 3512QSME46536D00ZZZS
   Serial number: 3522QSME46566D47ZZZ0
   Serial number: 35527SME3333632BZZZA
   Serial number: 35627SME5E29632BZZZT
9445972 - Seat occupied recognition control module
          B1022 54 [10001001] - Missing Calibration / Basic Setting
                    Mileage: 119205 km
                    Date: 2024.10.26.
                    Time: 03:11:55
9446148 - Pressure sensor for seat recognition
          B1023 04 [10001001] - is defective
                    Reset counter: 53
                    Mileage: 119205 km
                    Date: 2024.10.26.
                    Time: 03:12:53
9446419 - Seat Occupied Recognition Safety Belt Force Sensor
          B1024 13 [10001001] - Open Circuit
                    Reset counter: 53
                    Mileage: 119205 km
                    Date: 2024.10.26.
                    Time: 03:11:55
   Part No SW: 5K0 953 521 BR    HW: 5K0 953 569 E
   Revision: FF010040    Serial number: 20120229101409
   Coding: 101A140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: FDFBD34A6C6BA87E20-80A8
   Coding: E30000
   Part No SW: 5K0 920 972 C    HW: 5K0 920 972 C
   Coding: 271901
   VCID: B0653A7EEBB99516FB-80E4
   Part No SW: 7N0 907 530 M    HW: 1K0 907 951
   Component: J533  Gateway H42 1623
   Revision:   H42       Serial number: 280212F2001455
   Coding: 350000
   VCID: BA71185635C55F4645-80EE
   Coding: 000007
   VCID: EAD1E8160DE52FC6F5-80BE
   Part No SW: 5K0 905 861 A    HW: 5K0 905 861 A
   Component: ELV-PQ35      H20 0230
   Revision: 00000000    Serial number: 12000024707002
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X_VW32.rod
   VCID: AE592406F18D83E6E9-80FA
   Revision: A1001003    Serial number: 7662004628
   Coding: 020000
   VCID: A953D71AC063E4DE3C-80FC
   Part No SW: 1K0 035 274 B    HW: 1K0 035 274 B
   Component: RNS315-NAR    H35 0265
   Serial number: VWZAZ2M4203739
   Coding: 04050001010005000000100A
   ASAM Dataset: EV_RNS315NARV2UDS A01004
   ROD: EV_RNS315NARV2UDS_VW36.rod
   VCID: A34FC532AA4F3E8E76-80F6
   Component: NAR_V2  0002
                    Reset counter: 53
                    Mileage: 119205 km
                    Date: 2024.10.26.
                    Time: 03:11:51
   Part No SW: 5K0 959 701 H    HW: 5K0 959 701 H
   Component: Tuer-SG         009 2103
   Coding: 0001076
   VCID: B7770162C6D7422EBA-80E2
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 70     3305
   Revision: 00H22000
Address 47: Sound System (R12)       Labels: None
   Part No HW: 5K0 035 456 B
   Component: KonzernAmp 8K H07 0368
   Revision: --------    Serial number: EAA085A0016186 Dataset Number: 1K8050v____ 5K04
   ASAM Dataset: EV_AudioVerst8KanalBNO1 A01003
   ROD: EV_AudioVerst8KanalBNO1.rod
   VCID: D5ABABEAB49B903E48-8080
   Part No SW: 5K0 959 702 B    HW: 5K0 959 702 B
   Component: Tuer-SG         009 2117
   Coding: 0001076
   VCID: B26130762DB5A7068D-80E6
Address 55: Headlight Range        Labels: 5M0-907-357-V2.clb
   Coding: 1446940
   VCID: B46D366ED7A1A9369F-80E0
   Component: AFS-Lst.-Modul l    0005
   Coding: 00000022
   Subsystem 2 - Part No: 7L6 941 329 B  Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul r    0005
   Coding: 00000022
End-------------------------(Elapsed Time: 02:42)----------
DEMON-S8
NY. USA
C?ID=56124
Update:
Swapped out E1 with another know working unit... No luck
Is it possible that the BCM although showing fog light capabilities is not programmed for foglight functions?
So is that from before or after you swapped out the BCM?
DEMON-S8
NY. USA
C?ID=56124
Post BCM swap
DEMON-S8
NY. USA
C?ID=56124
Updated full scan
Sunday,17,November,2024,13:06:09:39494
Mileage: 119200km-74067mi Repair Order: ...
          56
   Coding: 0050078
   Revision: 00H31001
   Coding: 030C0C
   Revision: 00001018
   Coding: 0000001002
   Revision: AB111709
   Coding: 6F180A3B98673A04108800C07500890448052086574D85B0E48440208040
   Coding: 009795
   Coding: 00003131
   Coding: 101A140000
   Coding: E30000
   Coding: 271901
   Coding: 350000
   Coding: 000007
   Coding: 020000
                    Reset counter: 55
                    Mileage: 119205 km
                    Date: 2024.11.17.
                    Time: 19:54:05
   Coding: 0001076
   Revision: 00H22000
   Coding: 0001076
   Coding: 1446940
   Coding: 00000022
   Coding: 00000022
End-------------------------(Elapsed Time: 02:41)--------------------------
Show quoted text
Dr Sheldon
Windsor UK
C?ID=334979
No DTC for Fog Light there !!
You may have to switch the Fog Light of for the DTC to set !!
Rear Fog lights or Front ??
cristo_844
Portugal
C?ID=412536
Have you check if the bcm has the pins for the fog lights?
2kaa52
Ceska Republica, Praha
C?ID=319193
084 Basic BCM, cant used for Fog Lights
You need Minimum a 086 BCM
DEMON-S8
NY. USA
C?ID=56124
Front fogs
Dr Sheldon
Windsor UK
C?ID=334979
Have you absorbed that from @2kaa52 ?
I think that is why I enquired Front or Rear Fogs - Equally I have no Clue what the requirement in your region is !!
In the Uk we have to have at least one rear fog light and no requirement for Front Fog lights - At least it was - may have changed recently - I cannot say for certain without looking !!
We see Japanese Grey Imports here that do not have rear fog light when they land.
Scan PRE BCM Swap ??
Your Scan PRE BCM Swap might help establish if you threw the wrong part at it ??
DEMON-S8
NY. USA
C?ID=56124
1K0 937 086 P is part # for the original BCM (TDI), It had water damage from faulty sunroof drainage.
The current BCM in vehicle was purchased on ebay, listed from a Golf R, assumed it was high line. I will attempt to make contact with the seller.
Thanks all for direction.
Is it safe to say BCM with part # 1K0 937 087 will work?
Thanks!
DEMON-S8
NY. USA
C?ID=56124
Do we know if there was a Golf R variant with out headlights?
Jef
HQ
Surely you meant without fog lights rather than without headlights? Headlights are required on all road-legal cars. Fog lights aren't. ;)
DEMON-S8
NY. USA
C?ID=56124
Understood. 👍
2kaa52
C?ID=319193
Yes
087 BCM is a Highline Version that have all available Options.
086 BCM is also Safe to Work with Front Fog Lights.
Check your 084, there are No Pins in the Connector for Front Fog Lights.
