- Nov 14, 2024
- 2
- 1
- Ottawa, Canada
- C?ID=197836
Hello all,
New member, but long time VW owner and VCDS user.
I'm have a strange issue with my 2015 Golf TDI, there seems to be a fairly large parasitic draw occurring that is also intermittent (my nightmare). Hoping that some of the experts here might have some ideas on where to look next.
Some details:
-It is inconsistently intermittent, seems to be fine for a couple days, then will drain the battery in a few hours. I'm on the 2nd week with this issue.
-I have narrowed it down to the ECU power supply circuit, when I pull relay J317 in the engine compartment relay panel, the draw goes away.
-I've been checking this by putting a 50W sealed beam light bulb in series between the negative battery terminal and negative battery lead, it will light the bulb to full brightness. When I pull the relay, it goes out.
-The bulb will stay on for hours after the car has been parked with all the doors closed and is in sleep mode.
-Other times it will stay lit for maybe 15-20 seconds after the key is shut off and then significantly dim when the ECU relay shuts off as I would expect, it will then go out completely after maybe 5-10 minutes when the car goes to sleep.
Some other details about recent changes to the car:
-About two weeks ago, after a cold night, I came out to find the battery dead. I just assumed the battery finally gave up as it was the original and nearly 10 years old. I don't know whether it was actually the draw that caused this or just coincidence.
-I had been having another intermittent limp mode issue relating to an oil pressure code. First I changed both oil pressure switches, this didn't fix the issue. Next I replaced the oil pressure control solenoid, this appears to have fixed the issue. This solenoid had been superseded and looked significantly different from the original. The limp mode condition was quite repeatable and it has not happened since replacing the solenoid.
-I have had a very intermittent "boost control position sensor circuit" fault, which caused a limp mode condition. Several of my local dealers have tried to fix this, they usually just throw parts at it under warranty and then claim it's fixed. The last attempt was to do a "VW approved wiring overlay" from the ECU to the connector on the wastegate actuator. I guess I will say it has become less intermittent, but still happens every couple of months and will usually resolve itself when left overnight.
My theory is that there's nothing wrong with the relay or anything on the circuit, its just the ECU not commanding the relay to shut off. Looking through the wiring diagram, the power supply relay is presumably grounding pin 69 to control this relay. I'm not sure how to determine what conditions it considers for this control.
Here are a couple of full scans. The first is after I have scanned it, cleared all codes, started the engine and then re-scanned it. I keep getting this ESP code, but can't find much about it or how relevant it may be. The second scan is one I had taken after a few days of having issues, seems like most of the codes are related to low voltage after the dead battery.
Any thoughts would be much appreciated!
Some details:
Thursday,14,November,2024,23:08:29:53663
VCDS Version: 23.3.1.0 (x64)
VIN: 3VWRA7AU3FM029025 License Plate:
Mileage: 222546km-138283mi Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 15 16 17 19 20 42 44 52 5F
VIN: 3VWRA7AU3FM029025 Mileage: 222546km-138283miles
Address 01: Engine (J623-CRUA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 997 022 M HW: 04L 907 309
Component: R4 2.0l TDI H23 9458
Revision: 85H23--- CVN: 500D7A2038D3FF82B866C2AD
Coding: 01190012832410080000
Shop #: WSC 93267 999 00000
ASAM Dataset: EV_ECM20TDI01104L997022M 004002
ROD: EV_ECM20TDI01104L997022N_VW37.rod
VCID: 3A7BC7CBBD8E0643C5-806E
VINID: 0E69E24474650D674008900214362C2095
17158 - Implausible Data Received from ESP Control Module
U0416 00 [039] - -
Mileage: 222546 km
Date: 2024.11.14
Time: 23:03:31
Engine RPM: 864.00 /min
Normed load value: 31.0 %
Coolant temperature: 27 C
Intake air temperature: 21 C
Voltage terminal 30: 14.340 V
Drivetrain coordinator: brake fault status-Bits 0-7: 4
Acceleration: 0.000 m/s
Readiness: 0 0 0 1 1
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-ESP-V1.clb
Part No SW: 5Q0 907 379 K HW: 5Q0 907 379 F
Component: ESC H31 0371
Revision: 00000000 Serial number: 51914000000889
Coding: 01FA6AA1242209750077020281C82580562490004081A4B200630050C002
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_Brake1UDSContiMK100ESP 033001
ROD: EV_Brake1UDSContiMK100ESP_033_VW37.rod
VCID: 4487B933CF4A40B3AF-8010
Part No SW: 5G0 907 044 AN HW: 5G0 907 044 AN
Component: Climatronic H03 0907
Revision: 00001K08 Dataset Number: 0000
Coding: 00020114200100010005000010101000
VCID: 73E52AEFDA64B70BC6-8026
Air quality sensor:
Part No SW: 5Q0 937 087 N HW: 5Q0 937 087 N
Component: BCM PQ37BOSCH 028 0106
Revision: -------- Serial number: 86580608141777 Dataset Number: 5GM063v____ 0040
Coding: 00100946404182E949E44000091407001000000000000000000000000000
Shop #: WSC 00066 790 00219
ASAM Dataset: EV_BodyContrModul1UDSBosc 013005
ROD: EV_BCMBOSCH_013.rod
VCID: 4683A33BF97672A3B1-8012
Subsystem 1 - Part No SW: 5GM 955 119 HW: 5GM 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 140623 043 0581
Serial number: 140902072538
Component: RLHS 037 0059
Serial number: S5Y14M08D05H02M28S23
Coding: 00A8DD
Sunroof control module:
Subsystem 3 - Part No SW: 8V3 959 591 HW: 8V3 959 591
Component: J245 PS73.014 H02 0007
Serial number: WOO3090701.
Coding: 181801
Humidity sensor: interior:
Part No SW: 5Q0 959 655 T HW: 5Q0 959 655 T
Component: AirbagVW20 009 0825
Serial number: 003MHM00T6LY Dataset Number: 5GM003V____ 0031
VCID: 51A980670038A51B14-8004
Subsystem 1 - Part No SW: 4M0 959 339 A HW: 4M0 959 339 A
Component: BF-Gewichtss. H05 0016
Serial number: IBH0000J1400019NO301
Coding: 303335
Subsystem 2 - Part No SW: ----------- HW: 480 001 407 14
Serial number: 357000000009CC19401K
Subsystem 3 - Part No SW: ----------- HW: 480 001 407 14
Serial number: 35800000000ED759401Q
Subsystem 4 - Part No SW: ----------- HW: 480 400 108 14
Serial number: 3510002C716DB805D0FG
Subsystem 5 - Part No SW: ----------- HW: 480 400 108 14
Serial number: 3520002BB1656B9323D7
Subsystem 6 - Part No SW: ----------- HW: 480 400 207 14
Serial number: 3550002BD1617D2160D3
Subsystem 7 - Part No SW: ----------- HW: 480 400 207 14
Component: FrontSensor_P 001 6149
Serial number: 3560002BB1617D2152D3
Part No SW: 5Q0 953 521 K HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0155
Revision: FF028028 Serial number: 20140703400237
Coding: 0400
Shop #: WSC 66564 385 16448
ROD: EV_SMLSVALEOMQB.rod
Part No SW: 5G1 920 741 HW: 5G1 920 741
Component: KOMBI 243 4270
Coding: 0BB41A0121808809020868001000000000000000
Shop #: WSC 00066 790 00202
VCID: 64C759B36F8A20B34F-8030
Part No SW: 5Q0 907 530 T HW: 5Q0 907 530 M
Component: GW MQB High 212 2186
Revision: -------- Serial number: 14081410001814 Dataset Number: 5G0067v____ 1821
Coding: 0101000800087300EF000208080F00000001050000000000000000000000
Shop #: WSC 00066 790 07029
GVL: 01503C0000000100400C00000000480000000000000000000000000000000000
ASAM Dataset: EV_GatewConti 011017
ROD: EV_GatewConti_011.rod
VCID: 428BBF2BD55E4E839D-8016
Generator:
Subsystem 2 - Part No SW: 5G0 959 442 P HW: 5G0 959 442 P Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H16 0101
Serial number: 29140001362790084274
Coding: 28FFFF
Address 20: High Beam Assist. (J844) Labels:| 8X0-857-511.clb
Part No SW: 5G0 857 511 D HW: 5G0 857 511
Component: FLA H04 0002
Revision: AA001001
Coding: 04018864727264565625393E01
ASAM Dataset: EV_HighBeamAssisAU37X 001009
ROD: EV_HighBeamAssisAU37X.rod
VCID: 2B55F28F42D4AFCB4E-807E
Part No SW: 5Q0 959 393 B HW: 5Q0 959 393 B
Component: TSG FS 020 0025
Serial number: 190814060504Y0 Dataset Number: V03935206HY 0006
Coding: 003003200000040000000000
VCID: 3E73CBDBA1A62A63F9-806A
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000003026876
Coding: 011000
Part No SW: 5Q0 909 144 P HW: 5Q0 909 144 P
Component: EPS_MQB_ZFLS 122 1043
Dataset Number: 5GM074V____ 0205
Coding: 0102
ROD: EV_SteerAssisMQB_010.rod
VCID: 4189B027D058559B84-8014
Part No SW: 5Q0 959 392 B HW: 5Q0 959 392 B
Component: TSG BFS 020 0025
Serial number: 220814060504Q3 Dataset Number: V03935206HZ 0006
VCID: 3D71CCD7ACA0317BE0-8068
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000003148643
Coding: 191000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD1.clb
Part No SW: 5G0 035 844 HW: 5G0 035 844
Component: MU-S-S-US 014 0645
Serial number: V7B02007142431 Dataset Number: 5G0CV1v____ 0001
Coding: 02730000FF00000021220001001800001F0100140100010002
ROD: EV_MUStd4CPASE_VW37.rod
Subsystem 1 - Part No SW: 5G0 919 605 H HW: 5G0 919 605 H
Component: ABT_Std_Plus H60 0030
Serial number: VWZ8Z9PS500H0L
B11CF 53 [009] - Deactivated
Reset counter: 176
Mileage: 222546 km
Date: 2024.11.14
Time: 23:00:40
Voltage terminal 30: 13.8 V
Satellite radio tuner status-SDARS Flash Regional code: US_Audio_Traffic_Travellink
End-------------------------(Elapsed Time: 03:34)--------------------------
Address 01: DTCs cleared
Address 01: Engine Labels: 04L-907-309-V1.clb
Control Module Part Number: 04L 997 022 M HW: 04L 907 309
Component and/or Version: R4 2.0l TDI H23 9458
Software Coding: 01190012832410080000
Work Shop Code: WSC 93267 999 00000
ASAM Dataset: EV_ECM20TDI01104L997022M 004002 (VW37)
17262 - Terminal 30
U140A 00 [175] - Open Circuit
Mileage: 222546 km
Engine RPM: 0.00 /min
Vehicle speed: 255 km/h
Coolant temperature: -40 C
Intake air temperature: -40 C
Voltage terminal 30: 12.100 V
Limitation: torque: 1000.0 Nm
Accelerator pedal travel: raw value: 0.00 %
Engine torque: -500.0 Nm
Generator: load signal: 0.00 %
Readiness: 1 1 0 1 1
17262 - Terminal 30
Mileage: 222546 km
17262 - Terminal 30
Mileage: 222546 km
Air quality sensor:
Coding: 00A8DD
Coding: 181801
Coding: 303335
Coding: 0400
Generator:
Coding: 28FFFF
Revision: AA001001
Coding: 011000
Coding: 0102
Coding: 191000
Reset counter: 176
Mileage: 222546 km
Date: 2024.11.14
Time: 23:08:49
Voltage terminal 30: 13.9 V
End-------------------------(Elapsed Time: 03:32)--------------------------
Monday,11,November,2024,19:47:14:53663
Mileage: 222339km-138155mi Repair Order:
VIN: 3VWRA7AU3FM029025 Mileage: 222339km-138155miles
20-High Beam Assist. -- Status: Malfunction 0010
U0416 00 [032] - -
Mileage: 222229 km
Date: 2024.11.11
Time: 07:54:55
Engine RPM: 925.50 /min
Normed load value: 37.3 %
Coolant temperature: 12 C
Intake air temperature: 12 C
Voltage terminal 30: 12.140 V
7938 - Turbocharger Boost Control Position Sensor Circuit
P2563 00 [167] - Implausible Signal
Mileage: 222339 km
Date: 2024.11.11
Time: 19:40:38
Coolant temperature: 74 C
Intake air temperature: 60 C
Voltage terminal 30: 11.160 V
Turbine actuator 1 bank 1: posit.feedback - Specified value: 0.00 %
Turbine actuator 1 bank 1: posit.feedback - Actual value: 0.00 %
Turbine actuator 1 bank 1: posit.feedback - Offset closed: -3.06 %
Turbine actuator 1 bank 1: monitoring - status-Bits 0-7: 0
Turbine actuator 1 bank 1: monitoring - status-Bits 0-7: 7
Turbine actuator 1 bank 1: monitoring - status-Bits 0-7: 8
Turbine actuator 1 bank 1: posit.feedback - Raw voltage: 170.0 mV
5334 - Turbocharger Boost Control Position Sensor Circuit
P2564 00 [167] - Signal too Low
Mileage: 222339 km
Date: 2024.11.11
Time: 19:34:36
Coolant temperature: 80 C
Intake air temperature: 71 C
Voltage terminal 30: 10.220 V
Turbine actuator 1 bank 1: posit.feedback - Actual value: 100.00 %
Turbine actuator 1 bank 1: posit.feedback - Raw voltage: 14.6 mV
U0428 00 [032] - -
Mileage: 222229 km
Date: 2024.11.11
Time: 07:54:55
Engine RPM: 935.00 /min
Normed load value: 36.5 %
Voltage terminal 30: 11.920 V
17262 - Terminal 30
U140A 00 [168] - Open Circuit
Ambient air pressure: 0 mbar
Voltage terminal 30: 0.000 V
4629 - ECM Power Relay Load Circuit
P068A 00 [032] - Opens Too Early
Starter control: Interlock- or P/N-signal-Bits 0-7: 0
Engine status: COENG_STANDBY
Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 0
Readiness: 1 1 0 0 0
0128 - Function Restricted due to Insufficient Voltage
U1400 00 [136] - -
Reset counter: 211
Mileage: 222229 km
Date: 2024.11.11
Time: 07:49:03
0297 - Steering angle sensor
B1168 16 [008] - Voltage Too Low
Reset counter: 209
Mileage: 222229 km
Date: 2024.11.11
Time: 07:53:28
C1146 02 [008] - Signal Failure
Reset counter: 209
Mileage: 222229 km
Date: 2024.11.11
Time: 07:55:05
Air quality sensor:
B10CD 00 [009] - -
Reset counter: 171
Mileage: 222339 km
Date: 2024.11.11
Time: 19:37:48
Voltage terminal 30: 7.3 V
CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 1
CAN input signal(s) status-Back-up lamp: OFF
Coding: 00A8DD
Coding: 181801
8 Faults Found:
131330 - Supply voltage
Reset counter: 211
Mileage: 222278 km
Date: 2024.11.11
Time: 17:49:31
Terminal 15 status: OFF
Terminal 50 status: OFF
CAN-Bus_aktiv: OFF
OFF: Not operated
Position lamps: Not operated
Low beam: Not operated
Voltage: 8.7 V
Outside temperature: 10.0 C
U1400 00 [008] - -
Reset counter: 211
Mileage: 222229 km
Date: 2024.11.11
Time: 07:49:00
Terminal 15 status: On
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 6.4 V
Outside temperature: 9.5 C
919560 - Light Switch
B126A 29 [136] - Signal Implausible
Reset counter: 211
Mileage: 222278 km
Date: 2024.11.11
Time: 17:49:31
CAN-Bus_aktiv: OFF
OFF: operated
Voltage: 8.7 V
12307 - License Plate Light
B12CA 01 [009] - Electrical Failure
Reset counter: 171
Mileage: 222229 km
Date: 2024.11.11
Time: 07:54:15
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 12.4 V
17674 - Bulb for Front Left Side Marker Lamp
B12BA 15 [009] - Open or Short to Plus
Reset counter: 169
Mileage: 222229 km
Date: 2024.11.10
Time: 15:37:47
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 9.4 V
Outside temperature: 8.5 C
17930 - Bulb for Front Right Side Marker Lamp
B12BB 15 [009] - Open or Short to Plus
Reset counter: 169
Mileage: 222229 km
Date: 2024.11.10
Time: 15:37:47
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 9.4 V
203016 - Unlock Switch in Rear Lid Handle
B140B 29 [008] - Signal Implausible
Reset counter: 211
Mileage: 222278 km
Date: 2024.11.11
Time: 17:48:40
CAN-Bus_aktiv: OFF
OFF: Not operated
Voltage: 7.6 V
Reset counter: 211
Mileage: 222229 km
Date: 2024.11.11
Time: 07:49:40
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 9.0 V
Outside temperature: 9.0 C
Coding: 303335
B10B4 00 [008] - Function Restriction due to Undervoltage
Reset counter: 209
Mileage: 222229 km
Date: 2024.11.11
Time: 07:49:27
Coding: 0400
13635840 - Supply voltage
Reset counter: 211
Mileage: 222339 km
Date: 2024.11.11
Time: 19:37:01
Generator:
Coding: 28FFFF
1282 - Supply voltage
Reset counter: 211
Mileage: 222339 km
Date: 2024.11.11
Time: 19:37:01
Terminal 30 power supply: 8.4 V
Terminal 15: On
Revision: AA001001
114178 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
Reset counter: 211
Mileage: 222339 km
Date: 2024.11.11
Time: 19:37:01
136194 - Supply voltage
Reset counter: 211
Mileage: 222339 km
Date: 2024.11.11
Time: 19:37:01
Coding: 011000
65548 - Supply voltage
Reset counter: 211
Mileage: 222278 km
Date: 2024.11.11
Time: 17:47:44
589829 - Window Regulator; Rear Driver side
B131F F5 [008] - Supply Voltage too Low
Reset counter: 211
Mileage: 222229 km
Date: 2024.11.11
Time: 07:48:58
Coding: 0102
Coding: 191000
Reset counter: 211
Mileage: 222339 km
Date: 2024.11.11
Time: 19:37:07
589845 - Window Regulator; Front Passenger side
B1320 F5 [008] - Supply Voltage too Low
Reset counter: 211
Mileage: 222229 km
Date: 2024.11.11
Time: 07:48:58
1537 - Supply voltage
Reset counter: 211
Mileage: 222339 km
Date: 2024.11.11
Time: 19:37:01
Voltage terminal 30: 8.3 V
U1400 00 [008] - -
Fault Frequency: 9
Reset counter: 211
Mileage: 222229 km
Date: 2024.11.11
Time: 07:48:59
Voltage terminal 30: 6.9 V
Reset counter: 169
Mileage: 222229 km
Date: 2024.11.10
Time: 15:37:46
Voltage terminal 30: 9.5 V
End-------------------------(Elapsed Time: 03:38)--------------------------
U0416 00 [039] - -
Mileage: 222339 km
Date: 2024.11.11
Time: 19:47:30
Coolant temperature: 70 C
Intake air temperature: 54 C
Voltage terminal 30: 10.620 V
Air quality sensor:
B10CD 00 [009] - -
Reset counter: 171
Mileage: 222339 km
Date: 2024.11.11
Time: 19:47:29
Voltage terminal 30: 10.0 V
CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 2
Coding: 00A8DD
Coding: 181801
Reset counter: 171
Mileage: 222339 km
Date: 2024.11.11
Time: 19:47:32
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 10.4 V
Outside temperature: 15.0 C
Reset counter: 171
Mileage: 222339 km
Date: 2024.11.11
Time: 19:47:32
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 10.4 V
Coding: 303335
Coding: 0400
Generator:
Coding: 28FFFF
Revision: AA001001
Coding: 011000
Coding: 0102
Coding: 191000
