Golf mk5 instrument cluster “error”
VOLKS HAUS
C?ID=175250
Hi guys. I have error on the display in the centre of the instrument cluster. Code 00003, I’m sure I read on the forum somewhere that is was a coding issue but I can’t find that thread again.
Monday,08,July,2024,01:30:48:45679
VCDS Version: 24.5.0.0 (x64)
VIN: WVWZZZ1KZ5B081490   License Plate: E3CDO
Mileage: 112700km-70028mi   Repair Order:
Chassis Type: 1K (1K0)
VIN: WVWZZZ1KZ5B081490   Mileage: 112700km-70028miles
Address 01: Engine        Labels: 03C-906-056-BAG.lbl
   Part No SW: 03C 906 056 BP    HW: Hardware No
   Component: MED9.5.10        00 7002
   Revision: 00000000    Serial number: VWZ7Z0D0621096
   Coding: 0000072
   Shop #: WSC 00046 412 08192
   VCID: 72EB17C66D1D4E0645-8026
   VINID: 9E69EAAAA05BA8548020110900EA28C31D
17446 - Heater Control Circuit for NOx Sensor
            P1038 - 004 - Open Circuit - MIL ON
17439 - Intake Manifold Tuning Valve (N316)
            P1031 - 008 - Setpoint Not Reached - MIL ON
Readiness: 1110 0101
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.clb
   Part No: 1K0 907 379 K
   Component: ESP FRONT MK60      0104
   Coding: 0019073
   VCID: 3A7BFFE675EDF6464D-806E
   Part No SW: 1K0 820 047 HN    HW: 1K0 820 047 HN
   VCID: 77FD26D2067F2B2E72-8022
   Part No SW: 1K0 937 049 M    HW: 1K0 937 049 M*
   Component: Bordnetz-SG     H34 0803
   Revision: 00H34000    Serial number: 00000001199120
   Coding: 008D0F0600041800001400001400000000087B075C
   Shop #: WSC 00046 412 40960
   VCID: 3979E0EA70EBFD5E44-806C
   Subsystem 1 - Part No: 1K2 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  012  0401
   Coding: 00065493
   Shop #: WSC 00046
   Part No SW: 1K0 909 605 C    HW: 1K0 909 605 C
   Component: 08 AIRBAG VW8   013 2100
   Revision: 02013000    Serial number: 0033HD01YTJX
   Coding: 0012344
   VCID: 2C57C9BE8FB958F6CF-8078
   Subsystem 1 - Serial number: 633  SME        6
   Subsystem 2 - Serial number: 634  SME        7
   Subsystem 3 - Serial number: 6351HSME05335113V
   Subsystem 4 - Serial number: 6361HSME05415354
01217 - Side Airbag Igniter; Driver Side (N199)
   Part No SW: 1K0 953 549 F    HW: 1K0 953 549 F
   Component: Lenksäulenmodul 021 0050
   Coding: 0000012
   Shop #: WSC 00046 412 1138688
   VCID: 3561ECDA5CF3193EA0-8060
   Part No: 1K0 920 961 A
   Component: KOMBIINSTRUMENT VDD 0814
   Coding: 0000403
   Shop #: WSC 00046 412 00000
   VCID: 285F35AE9B4174D62B-807C
00003 - Control Module
            014 - Defective
   Part No SW: 1K0 907 530 E    HW: 1K0 907 951
   Component: Gateway         H09 0110
   Revision: 09          Serial number: 2700104A160930
   Coding: 3D0F0340070001
   Shop #: WSC 00046 412 1269760
   VCID: 295930AA804B4DDE34-807C
                    Fault Frequency: 82
                    Reset counter: 213
                    Mileage: 112705 km
                    Time: 00:16:44
   Component: IMMO            VDD 0814
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
   Part No: 1K0 959 701 E
   Component: Tuersteuergeraet 09 0156
   Coding: 0000052
   VCID: 306FDDCEA3913C16F3-8064
   Part No: 1K2 909 144 H
   Component: EPS_ZFLS Kl.0       1502
   VCID: 3169D8CAA89B351EFC-8064
00750 - Warning Lamp
                    Mileage: 2680 km
                    Temperature: 6.0°C
                    Voltage: 12.20 V
                    Voltage: 12.00 V
   Part No: 1K0 959 433 BK
   Component: 01 KSG              0301
   Coding: 98C802087F2D8505485AC69010
   VCID: 7AFB3FE6356D36460D-802E
   Subsystem 2 - Part No: 1K0 907 719 B
   Component: Neigungssensor  004 0003
   Subsystem 3 - Part No: 1K0 951 177
   Component: Innenraumueberw.004 0101
   Component: Tuer-SG         006 1208
   Coding: 0000564
   Shop #: WSC 01279 785 00200
Address 56: Radio        Labels: 1K0-035-1xx-56.clb
   Part No: 1K0 035 186 AD
   Component: Radio GR0       034 0033
   Revision: 0003404S    Serial number: VWZ2Z2H6527891
   Coding: 0040400
   VCID: 68DF75AE5BC1B4D6EB-803C
End-------------------------(Elapsed Time: 01:34)--------------------------
No, I really don't think that "00003 - Control Module / 014 - Defective" is a coding issue.
You may be thinking of "00003 - Control Module / 005 - No or Incorrect Basic Setting". When found in an instrument cluster, that's usually a problem with the Service Reminder values.
golfi_vend
Tartu, Estonia
C?ID=195131
Can happen for incorrect bootup or any attempt to read immodata or mileage from the cluster.
Considering the age of the car and from what I've seen as a trend in UK, probably someone has added a extra key to it.
VOLKS HAUS
C?ID=175250
Thanks for the replies.
I think it might be the service reminder issue that Uwe I am getting confused with.
What is the recommended way to resolve this issue?
& thanks to whoever edited my scan into the box, I can never remember how to do it.
andy99
Portugal
C?ID=355926
LED malfunction also gives internal error
EuroX
Northern NJ USA
C?ID=208579
VOLKS HAUS
C?ID=175250
Someone has been into this instrument cluster and removed the airbag and steering wheel warning lamps. I’m assuming this is enough to cause the problem?
EuroX
Northern NJ USA
C?ID=208579
Yes this is your issue. You can try replacing the leds that are missing and it should be ok. Note Leds are most likely plcc type leds just have to match the size a color or put in funky colors if you want lol.
A better way would have been to simply cover them black electrical tape. ;)
VOLKS HAUS
C?ID=175250
EuroX. I have purchased a used set of clocks for parts to repair this cluster.
Uwe. Most annoyingly the airbag faults were just the usual yellow connectors on the seat harness, which I had already sorted before the scan and the other was the two twisty wires on the door side of the harness, which I took care of this morning.
When I have had to resort to removing dash lights the old fashioned way, I used black epoxy resin.
VOLKS HAUS
C?ID=175250
Following on from this, i received a similar instrument cluster to remove the leds from. Opened up the original cluster to find the board on the tacho and speedo have been properly butchered.
If I source a used cluster with identical part number to the original can I code it in with vcds or is it a more involved process?
cristo_844
Portugal
C?ID=412536
Source a used cluster it the same part number and replace the complet front pcb.
VOLKS HAUS
C?ID=175250
Will give that a try. Thank you.
