This happened after a few minutes on the highway, sudden onset, really bad and consistent sputtering. Pulled off into parking lot, drove back, lasted about 10 minutes, even a blinking engine light for about 3 or 4 seconds (which disappeared afterward not to return). Then it...cleared up. I turned around again and went off to my destination, without those symptoms.
This seems like the first really bad instance of something that would come and go for a second or two, that I had later attributed to maybe bad gas. Then the so called 'bad gas' hitches, hesitation, lurching, happened after being put through one of the new-gen car washes. Something getting wet under the hood?
But then this happened a week later, this morning. Nothing ever like it--clean AutoScan last time--but this time an engine fault code, a misfire recorded for the very first time.
What is the most likely cause if I don't want to replace everything and just want to start at the most likely possibility? Coils? MAF sensor? O2 sensor? This is a really acute thing when it happens just for a second or two, however it happens only every few days or every week or so, and then it runs comparatively fine. But then, this, this morning. But after ten continuous minutes of this this morning, the car worked normally.
It did throw a brake light with wavy lines, all the way to my destination--but disappeared after restarting the car in the afternoon.
Best guess to begin with? Do I buy coils first?
AutoScan follows. thanks for any help, advice.
Wednesday,13,November,2024,18:04:24:64836
VCDS Version: 24.7.1.0 (x64) HEX-V2 CB: 0.4643.4
VIN: 1VWAS7A34FC015864 License Plate:
Mileage: 183040km-113735mi Repair Order:
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 2E 42 44 46 4F 52 56 62 72 75
77
VIN: 1VWAS7A34FC015864 Mileage: 183040km-113735miles
Address 01: Engine (J623-CPKA) Labels:. 06K-907-425-V2.clb
Part No SW: 06K 997 071 F HW: 06K 907 425 C
Component: R4 1.8l TFS H13 9371
Revision: --H13--- CVN: AFB47EEF
Coding: 001A0012242400160000
Shop #: WSC 09003 957 00200
ASAM Dataset: EV_ECM18TFS02006K997071F 001005
ROD: EV_ECM18TFS02006K906071J.rod
VCID: 38292D5A02DC5F8AA7B-806C
VINID: 0669D18C74431164C0045206100712C5F1
17178 - Databus
U1123 00 [00100000] - Received Error Message
Mileage: 182961 km
Date: 2024.11.13.
Time: 08:37:18
Engine RPM: 1232.50 /min
Normed load value: 40.4 %
Vehicle speed: 75 km/h
Coolant temperature: 82 °C
Intake air temperature: 23 °C
Voltage terminal 30: 14.355 V
Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
Drivetrain coordinator: brake fault status-ESP system error: No
15125 - Cylinder 1
P0301 00 [01100000] - Misfire Detected
Mileage: 182961 km
Date: 2024.11.13.
Time: 08:37:18
Engine RPM: 1349.50 /min
Normed load value: 40.8 %
Vehicle speed: 74 km/h
Voltage terminal 30: 14.394 V
FAC_LAM_LIM[1]: 7.454 %
Time since engine start: 660.7 s
Engine: operating status: PL
26384 - Databus
U1123 00 [01100000] - Received Error Message
Mileage: 182961 km
Date: 2024.11.13.
Time: 08:37:19
Engine RPM: 1380.50 /min
Normed load value: 41.6 %
Voltage terminal 30: 14.414 V
STATE_LS_SAE[1]: OL_ERR
T_AST_SAE: 660 s
MAP_MES_SAE: 86 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 2.095 V
FAC_TPS_1_SAE: 19.921875 %
FUP_H_SAE: 14930.0 kPa
Address 02: Auto Trans (J217) Labels:* 09G-927-749-V1.clb
Part No SW: 09G 927 749 B HW: 09G 927 749 B
Component: AISIN AG6 G3 109 2855
CVN: E39A1153
Coding: 000348
ASAM Dataset: EV_TCMAQ250031 001004
ROD: EV_TCMAQ250031_001_VW25.rod
Part No SW: 1K0 907 379 BM HW: 1K0 907 379 BM
Component: ESP MK60EC1 H46 0164
Revision: 00H46001
Coding: C54BC0F5492300FFA31303EA921D0041A1100012
VCID: 7EA5FB4260F8A1BA2D7-802A
Fault Status: 00101101
Reset counter: 197
Mileage: 182961 km
Date: 2019.04.06.
Time: 08:37:19
Count: 32768
Count: 4608
Count: 8196
Count: 52555
Count: 765
02214 - Tire Pressure Warning
002 - Lower Limit Exceeded
Fault Status: 01100010
Reset counter: 135
Mileage: 181860 km
Date: 2019.02.19.
Time: 15:16:44
Count: 2
Count: 14
Count: 20480
Count: 16401
Count: 43264
Count: 256
Count: 1281
Part No SW: 561 907 426 E HW: 561 907 426 E
Component: AC Manuell H02 0303
Revision: 00001K02
Coding: 0010001002
ROD: EV_ACManuaElectGen2BHTC_VW36.rod
VCID: 1D67DCCE8D3E1AA254D-8048
Part No SW: 5K0 937 085 AB HW: 5K0 937 085 AB
Component: BCM PQ35 B+ 122 0174
Revision: BH122001
Coding: EF200E18902908D4098000010600044800F1A08640801D20648060000C70
VCID: 73B3DA765BBAFCD2529-8026
Part No SW: 5C0 959 655 AB HW: 5C0 959 655 AB
Component: AirbagVW10 500 0975
Serial number: 003LZD01BX5- Dataset Number: 560003v__A_ 0130
Coding: 00004D4E
Shop #: WSC 49769 002 1048576
ASAM Dataset: EV_AirbaVW10SMEVW360 001030
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 72BDDF722420F5DA59F-8026
Serial number: 6940000Y14000178JX0/
Coding: 303044
Serial number: 3572MSME48007A45ZZZV
Serial number: 3582MSME116B7D44ZZZ+
Serial number: 3516KSME620E652EZZZ
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3526KSME4C1A7A2EZZZ7
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3556LSME700C022FZZZW
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3566LSME0100022FZZZF
Part No SW: 5K0 953 569 AL HW: 5K0 953 569 AL
Component: LENKS.MODUL 016 0180
Revision: --X01--- Serial number: 20200727300100
Coding: 488A140000
Shop #: WSC 01286 386 08256
ASAM Dataset: EV_SMLSNGVOLWS A01004
ROD: EV_SMLSNGVOLWS.rod
VCID: 025D8FB21480C55A49F-8056
Subsystem 1 - Part No SW: 561 959 537 HW: 561 959 537
Component: E221__MFL-YVJ H07 0022
Serial number: 00000000000000924046
Coding: 620000
Address 17: Instruments (J285) Labels:| 5K0-920-XXX-17.clb-SRI1
Part No SW: 561 920 960 D HW: 561 920 960 D
Component: KOMBI H04 0809
Coding: 230E01
VCID: 1A6DD7D29C106D9AB1F-804E
Part No SW: 7N0 907 530 AR HW: 7N0 907 530 AM
Component: J533 Gateway H55 1653
Revision: H55 Serial number: 03071403000133
Coding: 461000
VCID: 005985BA1A0CD74A5FB-8054
Component: IMMO H04 0809
VCID: 6A8DC7120CF03D1AE1F-803E
Address 2E: Media Player 3
Component: TUER-SG FT 002 0525
Revision: 13110009 Serial number: 0008670928
Coding: 040495
ROD: EV_TSGFPQ25BRFVW46X.rod
VCID: 5BE392D6D3AA54926A9-800E
Slave Driver:
Subsystem 1 - Part No SW: 561 959 811 B HW: 561 959 811 B Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG_HL 006 5470
Serial number: 14102630140721173848
Coding: 800000
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 211 3501
Revision: 00H22000
VCID: 392F285E35564682585-806C
Part No SW: 7N0 907 532 HW: 7N0 907 530 AM
Component: EZE_2 H55 1653
Coding: 00000008
VCID: 6FBBD6063792D832B61-803A
Subsystem 1 - Part No SW: 561 919 204 B HW: 561 919 204 B
Component: Analoguhr 009 0005
Component: TUER-SG BT 002 0525
Revision: 15110009 Serial number: 0008683982
Coding: 040494
ROD: EV_TSGBPQ25BRFVW46X.rod
VCID: 5CE191CAD6A453AA633-8008
Slave Passenger:
Subsystem 1 - Part No SW: 561 959 812 B HW: 561 959 812 B Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG_HR 006 5470
Serial number: 14202631140729224322
Coding: 800000
Part No SW: 1K0 035 164 F HW: 1K0 035 164 F
Component: LOW NAR SDARS H04 0005
Revision: -----08S Serial number: VWZ4Z6P3818274
Coding: 0100040002000B
VCID: 2517F42EA5EED2620CD-8070
Reset counter: 135
Mileage: 181860 km
Date: 2019.02.19.
Time: 15:16:43
Address 75: Telematics (J949) Labels:| 12E-035-284.clb
Part No SW: 561 035 285 HW: 561 035 285
Component: OCULowUSA 014 0102
Serial number: 000003554140524 Dataset Number: 561098V____ 0010
Coding: 02140102C2161A107F1606000000
ROD: EV_OCULow_001.rod
VCID: 53F37AF6BB7A9CD2B29-8006
2103041 - Control Module
B1788 F0 [00001001] - Start Prohibition Deactivated
Fault Priority: 8
Reset counter: 159
Mileage: 183046 km
Date: 2024.11.13.
Time: 18:02:05
Address 77: Telephone (J412) Labels:| 5N0-035-729.clb
Part No SW: 5N0 035 729 E HW: 5N0 035 729 E
Component: TELEFON H07 0593
Revision: 1B001001 Serial number: 00007666458115 Dataset Number: 5N0035729E 0001
Coding: 0A10030080010110
ROD: EV_UHVUMI.rod
VCID: 323D1F72E4A0B5DA99F-8066
End----------(Elapsed Time: 01:06, VBatt start/end: 12.1V/12.1V)-----------
