How to replace access start authorization switch
victor35ma
Los Angeles CA.
C?ID=242342
car:
2007 Audi S6 Quattro Sedan (4F2)
V10-5.2L (BXA)
WAUGN94F47N033757
access start authorization switch. AKA ignition lock contact (i am sorry i don't know at this moment the module identification by nomenclature)
hello, hey i have a naive bunch of question here. car wont crank or activate ig switch, it does rotate the ignition key in the drum but nothing happens. can't give you a scan report.
so first question comes to mind is. i assuming there is an antenna in the ignition switch. my RF antena tester cant read a signal. so i am assuming is either a bad ignition switch. also i dont have remote key activity. I did test the remote key and it is okay.
if i need to replace that ignition switch. do i need to program or it is plug and play?
does this ignition switch have a coiled antenna ring around the insert ?
thank you for your help. and I'm hoping any comment is welcome.
Nothing scans at all?
Have you tried going directly to 05-Access & Start Control to see if it talks?
JMR
Romania
C?ID=432218
First of all.. check to see if steeeing column is locked or unlocked. It seems to me that you have a ESCL problem perhaps . Connect your VCDS then try to connect to address 05 . If you cant , try to wake up the car by switching the hazards on or the cars headlamps a few times while trying to connect to address 05. If you connect , read the errors . Save the errors and then you can erase them . The car ( in best case scenario ) will unlock or lock the escl and you ll be able to start again. But , that means you have a sick escl that needs to be replaced or resoft the car without it .
As far as the switch goes , of that is the problem , you can simply replace it with a similar part number ( use a ig switch module that is for automatic or manual , whatever the case ).
Dr Sheldon
Windsor UK
C?ID=334979
Even with a bad antenna coil or faulty key most functions in the car would work other than the engine will be immobilised. In fact your car would start and run for ~ 2 seconds then cut out. You would be able to scan it and get diagnostic direction !!
If you have the normal Blade type key - Insert and Turn ?? then you will not have ESCL on that car - Steering will be a mechanical lock !
Perhaps get to the back of the Ignition switch and test your Inputs and Outputs - With a wiring Diagram
EuroX
Northern NJ USA
C?ID=208579
Jump terminal 15 at obd connector pin 1 and 16. Scan the vehicle. Clear faults in 05 module. Remove jumper from obd port. Vehicle should now operate. Ignition should come on and vehicle should start.
Negative. That's not how well-equipped 4F chassis cars work, and since this is a NAR V10 S6, we can take it for granted that it's well equipped. Without being able to read a key, it won't power up most systems, and won't even try to crank the engine.
EuroX
Northern NJ USA
C?ID=208579
Access start module 05 is a common failure point on those vehicles. So much so that Audi even had a repair procedure when replacing the steering column as access start is bolted to the column is a very shitty spot. The procedure entailed cutting one wire going to the access start module that would lock the steering wheel. To prevent the steering wheel from being locked to keep this issue from happening in the future. Still I would test it all before just loading the parts cannon. I am going based of off experience with the brand and what I've seen. Nine times out of ten its the access start module, other than that it could be the ignition switch itself. The switch does not require programming even a used one will do AFAIK.
victor35ma
Los Angeles CA.
C?ID=242342
thank you for your answer. it does help me. I am going to do later today. then i will report back to you.
victor35ma
Los Angeles CA.
C?ID=242342
so it does have and antenna ring around the key insert Mr Uwe?
victor35ma
Los Angeles CA.
C?ID=242342
no. but i will later on today. and i will report that as well thank you.
I would assume so. We had a 2005 4F for 18 years, but effectively never put the key in the ignition; we just used the Engine Start button. My daughter, who was the last user of the car did have ESCL issues with it. See:
davisev5225
Democratic People's Republic of Commifornia, USA
C?ID=263265
I can attest to this, I've been down that road (though I didn't cut the wire, I found a different solution). What happens is the access start module also contains the steering lock, which is controlled by a worm gear mounted to a tiny motor. Over time, it loses its lubrication and eventually has too high a resistance for the motor to overcome, so it gets stuck in an "invalid" position. There's a pair of microswitches that determine if it is in the "locked" or "unlocked" position, and if those switches don't return what the KESSY network expects, you can't start the car. My solution was to grab a dremel tool, cut slots in the one-way bolt heads that hold it in, remove it, clean/lubricate the motor, test it in the vehicle while it's unbolted so I can very functionality, and finally bolt it back in with regular hex-head bolts instead of the one-way bullshit bolts Audi used.
I also recall getting an error in the dash about "unloading the steering wheel" or some such - basically the system assumes the steering lock is jammed because you're wrenching on the wheel when trying to start the car, rather than because it's no longer lubricated.
victor35ma
Los Angeles CA.
C?ID=242342
I did as requested. now i got some ignition activity. this is today afternoon report.
Wednesday,13,November,2024,15:21:25:23194
VCDS Version: 24.7.1.0 (x64)  HEX-NET CB: 0.4643.4
VIN: WAUGN94F47N033757   License Plate:
Mileage: 166510km-103464mi   Repair Order:
Chassis Type: 4F (4L0)
Scan: 01 02 03 05 07 08 09 0E 0F 11 31 13 15 16 17 19 36 37 42 46
          47 4F 52 53 55 56 61 62 65 67 6C 72 76 77
VIN: WAUGN94F47N033757   Mileage: 166510km-103464miles
05-Acc/Start Auth. -- Status: Sporadic communication error 1000
0E-Media Player 1 -- Status: Malfunction 0010
11-Engine II -- Status: Malfunction 0010
31-Engine other -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 1010
67-Voice Control -- Status: Malfunction 0010
Address 01: Engine        Labels:. 07L-910-552-BSM1.clb
   Part No SW: 4F1 910 552 A    HW: 4F1 907 552
   Component: 5.2L V10/4V FSI     0040
   Revision: 59H09---    Serial number:
   Coding: 01050009190F0260
   Shop #: WSC 26149 444 53361
   VCID: 22080D26FD956B86FD-8076
   VINID: 9D19577891161077800C31C51C400C9970
009523 - Ignition Switch; ON Position
               P2533 - 002 - Short to Plus - Intermittent
                    Fault Status: 00110010
                    Mileage: 166516 km
                    Temperature: 19.0 C
                    Temperature: 27.0 C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 10.160 V
                    Temperature: -40.0 C
                    Absolute Pres.: 0.0 mbar
                    Voltage: 0.000 V
006457 - Powertrain Databus
               P1939 - 008 - Missing Message from Controller for Access & Start Auth.
                    Fault Status: 01101000
                    Mileage: 166516 km
                    Date: 2006.03.17
                    Time: 10:24:41
                    Temperature: 20.0 C
                    Temperature: 26.0 C
                    Voltage: 11.430 V
006435 - Please Check DTC Memory of ECU Number 2
               P1923 - 008 -
                    Mileage: 166516 km
                    Date: 2006.03.17
                    Time: 10:35:48
                    Temperature: 20.0 C
                    Temperature: 26.0 C
                    Voltage: 11.684 V
005712 - Powertrain Data Bus
               P1650 - 008 - Missing Message from Instrument Cluster
                    Mileage: 166516 km
                    Date: 2006.03.17
                    Time: 10:35:52
                    Temperature: 20.0 C
                    Temperature: 26.0 C
                    Voltage: 11.684 V
Readiness: 0110 1101
Address 02: Auto Trans        Labels: 09E-927-156.lbl
   Part No SW: 4F2 910 156 M    HW: 09E 927 156 C
   Component: AG6 09E 5,2 FSI USA 0020
   Revision: --H01---    Serial number:        0088698
   Coding: 0000002
   Shop #: WSC 02325 785 00200
   VCID: 2F2EF412BE47D6EE62-807A
053258 - No Communications with Control Module for Access/Start Authorization
               U100A - 000 -
                    Mileage: 166516 km
                    Date: 2006.03.17
                    Time: 10:24:41
                    (no units): 30.0
                    (no units): 145.0
                    Temperature: 20.0 C
                    T.B. Angle: 0.0
049448 - No Communications with Parking Brake Control Module
               U0128 - 000 -  - Intermittent
                    Mileage: 166516 km
                    Date: 2006.03.17
                    Time: 10:24:48
Address 03: ABS Brakes        Labels: 4F0-910-517.clb
   Part No SW: 4F0 910 517 P    HW: 4F0 614 517 P
   Component: ESP 8.0 quattro H05 0070
   Coding: 0020920
   VCID: 312AF26AA873C01E74-8064
02847 - Brake Pressure Sensor; Front Left
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Fault Frequency: 37
                    Reset counter: 105
                    Mileage: 166515 km
                    Date: 2023.12.02
                    Time: 19:21:53
                    Hex Value: 0x0000
                    Hex Value: 0x4282
                    Hex Value: 0x0048
                    Hex Value: 0x4190
                    Hex Value: 0x00FF
                    Reset counter: 105
                    Mileage: 166515 km
                    Date: 2023.12.02
                    Time: 19:22:02
                    Hex Value: 0x0000
                    Hex Value: 0x4282
                    Hex Value: 0x0024
                    Hex Value: 0x0190
                    Hex Value: 0x00FF
                    Reset counter: 145
                    Mileage: 166516 km
                    Date: 2006.03.17
                    Time: 10:24:52
                    Hex Value: 0x0000
                    Hex Value: 0x42A2
                    Hex Value: 0x0035
                    Hex Value: 0x058E
                    Hex Value: 0x00FF
Address 05: Acc/Start Auth.        Labels: None
   Part No SW:                HW:
   Revision: 05100701    Serial number:
   VCID: 74A43B7E17E1B536DF-8020
No Faults Found
Address 07: Control Head        Labels: 4F0-910-7xx-07-H.clb
   Part No SW: 4F0 910 731 P    HW: 4E0 035 729 A
   Component: Interfacebox    H43 2750
   Revision: 00000000    Serial number: 393GQ067500065
   Coding: 0010003
   Shop #: WSC 02335 785 00200
   Component: Bedienteil MMIC6H02 0060
   Subsystem 2 - Serial number: 00000000476247
   Subsystem 3 - Serial number: 0119.07.060000000100010171
   Subsystem 4 - Serial number: 010171
01964 - Control Module for Seat & Steering Column Memory (J136)
                    Fault Frequency: 9
                    Reset counter: 145
                    Mileage: 166516 km
                    Date: 2024.04.07
                    Time: 16:40:19
01319 - Control Module for Distance Control (J428)
                    Reset counter: 144
                    Mileage: 166516 km
                    Date: 2024.05.10
                    Time: 01:10:06
                    Reset counter: 144
                    Mileage: 166516 km
                    Date: 2024.05.19
                    Time: 16:06:55
Address 08: Auto HVAC        Labels: 4F0-910-043.clb
   Part No SW: 4F0 910 043     HW: 4F1 820 043 AC
   Component: KLIMABETAETIGUNGH20 0170
   Revision: 00000030    Serial number: 00000000288608
   Coding: 0524330
   VCID: 5BF670C29A7F1A4EFE-800E
00456 - Control Module for Access and Start Control (J518)
                    Reset counter: 105
                    Mileage: 166516 km
                    Date: 2006.03.17
                    Time: 10:36:00
                    Bin. Bits: 00001000
                    Reset counter: 105
                    Mileage: 166516 km
                    Date: 2006.03.17
                    Time: 10:36:00
   Part No SW: 4F0 910 279 J    HW: 4F0 907 279 A
   Component: ILM Fahrer      H17 0240
   Coding: 0115123
   VCID: 302CF76EA379C9167B-8064
   Subsystem 1 - Component: Fehler Lin-Slave 01
   Subsystem 2 - Component: Fehler Lin-Slave 02
                    Reset counter: 105
                    Mileage: 166516 km
                    Date: 2024.10.29
                    Time: 09:57:00
            010 - Open or Short to Plus
                    Fault Status: 01111010
                    Reset counter: 105
                    Mileage: 166512 km
                    Date: 2023.12.02
                    Time: 19:21:00
02382 - Sensor for Light Detection (G399)
                    Fault Status: 00101110
                    Reset counter: 145
                    Mileage: 166516 km
                    Date: 2024.04.07
                    Time: 16:39:00
01024 - Rain Sensor (G213)
                    Reset counter: 145
                    Mileage: 166516 km
                    Date: 2024.04.07
                    Time: 16:39:00
01498 - Bulb for Parking Lamps; Right (M3)
                    Fault Status: 01111011
                    Reset counter: 105
                    Mileage: 166512 km
                    Date: 2023.12.02
                    Time: 19:21:00
   Part No SW: 4E0 910 111 F    HW: 4E0 035 111 A
   Component: CD-Changer      H44 0470
   Revision: 00000000    Serial number: AUZ5ZBF8159838
   VCID: 1C7433DEDFF15D7637-8048
                    Reset counter: 104
                    Mileage: 166516 km
                    Date: 2024.05.19
                    Time: 16:09:12
Address 0F: Digital Radio        Labels: 4E0-910-593-SIR.lbl
   Part No SW: 4E0 910 593 D    HW: 4E0 035 593
   Component: SDAR SIRIUS     H04 0670
   Revision: 00000000    Serial number: AUZ4Z7F3031026
   VCID: 281C1F0E9BA981D6A3-807C
                    Reset counter: 144
                    Mileage: 166516 km
                    Date: 2024.05.10
                    Time: 02:18:25
                    Voltage: 8.40 V
                    Reset counter: 144
                    Mileage: 166516 km
                    Date: 2024.05.10
                    Time: 02:18:25
                    Voltage: 8.40 V
                    Reset counter: 104
                    Mileage: 166515 km
                    Date: 2023.12.02
                    Time: 19:19:00
Address 11: Engine II        Labels:. 07L-910-552-BSM2.clb
                    Voltage: 0.000 V
                    Mileage: 166516 km
                    Date: 2006.03.17
                    Time: 10:24:41
                    Temperature: 20.0 C
                    Temperature: 26.0 C
                    Voltage: 11.430 V
                    Mileage: 166516 km
                    Date: 2006.03.17
                    Time: 10:35:52
                    Temperature: 20.0 C
                    Temperature: 26.0 C
                    Voltage: 11.684 V
Address 13: Auto Dist. Reg        Labels: 4F0-910-561.lbl
   Part No SW: 4F0 910 561 B    HW: 4F0 907 561 A
   Component: ABSTANDSREGELUNGH05 0060
   Revision: --------    Serial number: 00000000000000
   Coding: 0041118
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Fault Frequency: 24
                    Reset counter: 105
                    Mileage: 166515 km
                    Date: 2023.12.02
                    Time: 19:19:02
                    Temperature: 27.0 C
                    Voltage: 11.52 V
                    Bin. Bits:    01000
                    Hex Value: 0x2513
                    Hex Value: 0x0007
                    Lateral Accel.: 0.00 m/s^2
                    Reset counter: 105
                    Mileage: 166516 km
                    Date: 2006.03.17
                    Time: 10:35:48
                    Temperature: 27.0 C
                    Voltage: 11.14 V
                    Bin. Bits:    01000
                    Hex Value: 0x2511
                    Hex Value: 0x0041
Address 15: Airbags        Labels: 4F0-910-655-8R.clb
   Part No SW: 4F0 910 655 K    HW: 4F0 959 655 D
   Component: 7H AIRBAG AUDI8RH29 0400
   Revision: 01H29000    Serial number: 003BMD0000FL
   Coding: 0014152
   Subsystem 1 - Part No: 4F0 910 339 A
   Component: BF-Gewichtsens. H02 0050
   Subsystem 2 - Serial number: 6332CSME0F3C11452
   Subsystem 3 - Serial number: 6342CSME1211497F2
   Subsystem 4 - Serial number: 6352QSME111C3E7FV
   Subsystem 5 - Serial number: 6362QSME112B0B17C
   Subsystem 6 - Serial number: 63734SME0E4D1E17C
   Subsystem 7 - Serial number: 63834SME1069533D%
01739 - Crash Sensor for Front Airbag; Pass. Side (G284)
            014 - Defective - MIL ON
01738 - Crash Sensor for Front Airbag; Drivers Side (G283)
            002 - Lower Limit Exceeded - Intermittent - MIL ON
01587 - Igniter 2 for Airbag; Drivers Side (N250)
   Part No SW: 4F0 910 549     HW: 4F0 953 549 A
   Component: Lenks ulenmodul H08 0230
   Revision: 00H08000    Serial number: 90055061760041
   Coding: 0012151
   Shop #: WSC 02323 785 00200
   VCID: 66805136513D57A651-8032
   Component: Lenkradmodul    H02 0100
                    Reset counter: 145
                    Mileage: 166516 km
                    Date: 2024.05.19
                    Time: 16:07:34
                    Reset counter: 145
                    Mileage: 166516 km
                    Date: 2024.05.19
                    Time: 16:09:46
                    Fault Status: 00100001
                    Reset counter: 145
                    Mileage: 166516 km
                    Date: 2024.05.19
                    Time: 16:18:26
                    Reset counter: 105
                    Mileage: 166517 km
                    Date: 2024.10.26
                    Time: 15:55:43
Address 17: Instruments        Labels: 4F0-920-KOM-V1.clb
   Part No SW: 4F0 910 930 C    HW: 4F0 920 980 S
   Component: KOMBIINSTR. M73 H18 0110
   Revision: 00300000    Serial number: 5H656UD76
   Coding: 2257263
   Shop #: WSC 22168 444 81660
   VCID: 23060822E28F628EF6-8076
                    Reset counter: 144
                    Mileage: 166516 km
                    Date: 2024.05.19
                    Time: 16:03:44
02759 - Operating Switch for Instrument Cluster
                    Fault Status: 00101010
                    Reset counter: 145
                    Mileage: 166516 km
                    Date: 2006.03.15
                    Time: 12:00:00
Address 19: CAN Gateway        Labels:. 4L0-910-468.clb
   Part No SW: 4L0 910 468     HW: 4L0 907 468 A
   Component: J533__Gateway   H06 0040
   Revision: 00H06000    Serial number: 0800D06619802B
   Coding: F5D5DEF7317A06
   Shop #: WSC 02334 785 00200
   VCID: 6C94231E4FD16DF607-8038
                    Reset counter: 104
                    Mileage: 166515 km
                    Date: 2023.12.02
                    Time: 19:19:59
00384 - Optical Databus
                    Fault Status: 00101011
                    Reset counter: 144
                    Mileage: 166515 km
                    Date: 2023.12.08
                    Time: 01:11:05
                    Reset counter: 145
                    Mileage: 166517 km
                    Date: 2024.10.26
                    Time: 15:55:43
                    Reset counter: 145
                    Mileage: 166516 km
                    Date: 2006.03.17
                    Time: 10:24:49
   Part No SW: 4F0 910 760     HW: 4F0 959 760
   Component: Sitzmemory FS   H04 0050
   Revision: 00000000    Serial number: 00000000896400
   Coding: 0082954
   VCID: 618A422AB813309EA4-8034
                    Fault Frequency: 11
                    Reset counter: 144
                    Mileage: 166516 km
                    Date: 2024.05.10
                    Time: 02:17:54
                    Fault Frequency: 19
                    Reset counter: 105
                    Mileage: 166516 km
                    Date: 2024.10.29
                    Time: 09:57:21
   Part No SW: 4E0 910 888 C    HW: 4E0 919 887 D
   Component: MNS US          H48 0960
   Revision: 00000000    Serial number: 381GI067503123
   VCID: 2E10E916B94DDFE669-807A
                    Reset counter: 144
                    Mileage: 166516 km
                    Date: 2024.05.10
                    Time: 02:19:46
                    Hex Value: 0x664A
                    Hex Value: 0x2654
                    Hex Value: 0x0050
Address 46: Central Conv.        Labels:. 4F0-910-289.lbl
   Part No SW: 4F0 910 289 G    HW: 4F0 907 289 G
   Component: Komfortgeraet   H22 0170
   Revision: 01700022    Serial number: 01016259580000
   Coding: 4618269
7 Faults Found:
02199 - Bulb for Tail Light 2; Right (M50)
                    Reset counter: 105
                    Mileage: 158287 km
                    Date: 2022.08.05
                    Time: 13:59:32
                    Reset counter: 105
                    Mileage: 158287 km
                    Date: 2022.08.05
                    Time: 13:59:32
01506 - Bulb for Rear Fog; Right (L47)
                    Reset counter: 105
                    Mileage: 157261 km
                    Date: 2006.04.06
                    Time: 09:31:06
02735 - Bulb for Tail Light 3; Right
                    Reset counter: 105
                    Mileage: 158287 km
                    Date: 2022.08.05
                    Time: 14:04:22
                    Fault Status: 01101100
                    Fault Frequency: 54
                    Reset counter: 105
                    Mileage: 166515 km
                    Date: 2023.12.02
                    Time: 17:29:41
02743 - Bulb for Brake/Turn Signal Light; Right
                    Fault Status: 00101001
                    Reset counter: 144
                    Mileage: 166515 km
                    Date: 2023.12.08
                    Time: 01:09:50
                    Reset counter: 105
                    Mileage: 166517 km
                    Date: 2024.10.29
                    Time: 09:57:22
Address 47: Sound System        Labels: 4F0-910-223-BO.lbl
   Part No SW: 4F0 910 223 F    HW: 4F0 035 223 F
   Component: DSP-High C6     H09 0190
   Revision: PROD_01     Serial number: 00000000008271
   Coding: 0000026
   VCID: 210A022AF893709EE4-8074
   Part No SW: 4F0 910 280     HW: 4F0 907 280 B
   Component: ILM Beifahrer   H10 0080
   Revision:             Serial number: 00000000032553
   Coding: 0012014
   VCID: 5EF079D6896D0F6699-800A
                    Reset counter: 105
                    Mileage: 166516 km
                    Voltage: 12.300 V
                    Temperature: 23.0 C
                    Reset counter: 144
                    Mileage: 166516 km
                    Voltage: 6.500 V
                    Temperature: 19.0 C
                    Reset counter: 144
                    Mileage: 166516 km
                    Voltage: 8.400 V
                    Temperature: 31.0 C
                    Reset counter: 144
                    Mileage: 166516 km
                    Voltage: 16.700 V
                    Temperature: 77.0 C
Address 52: Door Elect, Pass.
Address 53: Parking Brake        Labels: 4F0-910-801.clb
   Part No SW: 4F0 910 801 B    HW: 4F0 907 801 A
   Component: EPB  CB4C0060   H04 0060
   Revision: --H04---
   Coding: 0008022
   Shop #: WSC 02324 785 00200
   VCID: 1F0E04D2CEE7466ED2-804A
00576 - Terminal 15
                    Fault Status: 11101100
                    Reset counter: 105
                    Mileage: 166512 km
                    Date: 2006.03.17
                    Time: 10:24:41
                    Voltage: 10.56 V
                    Count: 41
                    Fault Status: 11100100
                    Reset counter: 105
                    Mileage: 166512 km
                    Date: 2006.03.17
                    Time: 10:24:41
                    Voltage: 10.56 V
                    Count: 247
   Part No SW: 4F0 910 357 F    HW: 4F0 907 357 F
   Coding: 0000255
   VCID: 291A1A0A80A3B8DEBC-807C
   Subsystem 1 - Part No: NOSUBSYSTEM
   Component: AFS-Modul links
   Subsystem 2 - Component: AFS-Modul rechtsH02 0020
                    Fault Status: 11100101
                    Reset counter: 104
                    Mileage: 166520 km
                    Date: 2023.12.02
                    Time: 19:18:59
            000 - - - MIL ON
                    Fault Status: 11100000
                    Reset counter: 104
                    Mileage: 166520 km
                    Date: 2023.12.02
                    Time: 19:18:59
02233 - Left Headlight Power Output Stage (J667)
                    Fault Frequency: 37
                    Reset counter: 105
                    Mileage: 166520 km
                    Date: 2023.12.02
                    Time: 19:19:00
   Part No SW: 4E0 910 541 M    HW: 4F0 035 541 H
   Component: TUNER EU/US/RDW H42 0570
   Revision: 00000000    Serial number: 394G-067665551
   Coding: 0000002
   VCID: 2A18E50685A5B3C6B5-807E
                    Reset counter: 144
                    Mileage: 166516 km
                    Date: 2024.05.19
                    Time: 16:07:36
                    Fault Frequency: 253
                    Reset counter: 145
Address 61: Battery Regul.        Labels: 4F0-910-181.clb
   Part No SW: 4F0 910 181 E    HW: 4F0 915 181 A
   Component: J0644 BEM       H12 0590
   Revision: 00000000    Serial number: 00000000073654
   Shop #: WSC 42286 444 85933
   Subsystem 1 - Part No: 4F0 915 105 D
   Component: von VA0  310429T023
   Coding: 344630393135313035442056413033313034323954303233
   Shop #: WSC 41389 004 1048576
02272 - Quiescent Current Stage 1
                    Fault Frequency: 33
                    Mileage: 166516 km
                    Date: 2024.02.17
                    Time: 02:12:07
02273 - Quiescent Current Stage 2
                    Fault Frequency: 29
                    Mileage: 166516 km
                    Date: 2024.02.17
                    Time: 03:13:28
02276 - Quiescent Current Stage 5
                    Fault Frequency: 15
                    Mileage: 166516 km
                    Date: 2024.03.02
                    Time: 23:08:33
02277 - Quiescent Current Stage 6
                    Mileage: 166516 km
                    Date: 2006.03.17
                    Time: 10:36:53
                    Fault Frequency: 255
                    Reset counter: 105
                    Mileage: 166517 km
                    Date: 2024.10.26
                    Time: 15:55:42
Address 62: Door, Rear Left
Address 65: Tire Pressure        Labels: 4F0-910-273-BA.clb
   Part No SW: 4F0 910 273 B    HW: 4F0 907 273 A
   Component: Reifendruck 3   H05 0100
   Revision: 00050100    Serial number: 00000900025596
   Coding: 0062725
   Shop #: WSC 00000 785 00200
                    Reset counter: 105
                    Mileage: 166517 km
                    Date: 2024.10.29
                    Time: 09:57:27
                    (no units): 0.0
                    Voltage: 12.00 V
                    (no units): 33.0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
02214 - Tire Pressure Warning
                    Reset counter: 0
                    Mileage: 166515 km
                    Date: 2023.08.25
                    Time: 13:09:58
                    (no units): 0.0
                    Temperature: 32.0 C
                    Error Code: 1
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
   Part No SW: 4E0 910 754 Q    HW: 4E0 035 753 A
   Component: SDS 3501 US     H45 0630
   Revision: 00000000    Serial number: 00000606230151
   Shop #: WSC 12336 024 394758
   VCID: 3424FB7E5761F5361F-8060
                    Reset counter: 144
                    Mileage: 166516 km
                    Date: 2024.05.19
                    Time: 16:04:40
Address 6C: Back-up Cam.
Address 72: Door, Rear Right
   Part No SW: 4F0 910 283 F    HW: 4F0 919 283 F
   Component: Parkhilfe 4-Kan H09 0060
   Revision: 00H09000    Serial number: 06220619800612
   Coding: 0021306
   VCID: 271E1C3296B78EAEAA-8072
                    Reset counter: 105
                    Mileage: 166517 km
                    Date: 2024.10.26
                    Time: 15:55:42
00576 - Terminal 15
                    Reset counter: 105
                    Mileage: 166516 km
                    Date: 2006.03.17
                    Time: 10:24:42
Address 77: Telephone
End----(Elapsed Time: 02:08, VBatt start/end: 11.6V/11.5V. VIgn 11.5V)-----
Please charge this poor car's battery.
Part No SW: HW:
No Faults Found
That does not look good. I'm guessing this car needs a Kessy module.
EuroX
Northern NJ USA
C?ID=208579
Yes the access start module motor and microswitches do also fail over time. But they can be rebuilt, just make sure you get good quality parts and not china shit. Judging by the scan. Access start cannot talk it seems like or there is no comms to it which is suspect of a possible other issue.
victor35ma
Los Angeles CA.
C?ID=242342
Have to sign into ???? No can do.
video 1
oh I'm sorry, my video don't have audio...
basically what i tried to demonstrate is, even though i got some ignition activity using abrites terminal 15 device, it did not power up cluster and ignition switch module. so i am testing as we speak the ignition switch lock (where the key is inserted in ) yesterday i replaced the EZS steering lock module same outcome. that report might be creating false dtcs on some modules, don't you think? due to the fact we are using an external way to power up systems ... i've seem it before.
any idea how to test the ignition switch since this module power up based in other modules activity? so power and ground are a little bit sketchy.... anyway thanks for your help very much appreciated
